    RTL8188EU USB网卡接 R11,运行hostapd 出错,请问这是什么问题呢?
    A Series
    r11 hostapd rtl8188eu
    5424
    • U
      ubuntu LV 7 最后由 编辑
      nl80211 driver initialization failed.
      wlan0: interface state UNINITIALIZED->DISABLED
      wlan0: AP-DISABLED
      hostapd_free_hapd_data: Interface wlan0 wasn't started
        nl80211 driver initialization failed. 单独运行下试试
        U 1 条回复 最后回复 回复 引用 分享 0
        • U
          ubuntu LV 7 @YuzukiTsuru 最后由 whycan 编辑
          @yuzukitsuru
          网上搜索说是驱动问题,不能用 staging 目录里面的 rtl8188eu 驱动程序
          https://unix.stackexchange.com/questions/584559/tp-link-tl-wn722n-v2-and-ap-mode-nl80211-driver-does-not-support-authenticatio
          Answer from Larry Finger, maintainer of derived work from Realtek:
          Only very old hostapd is supported by the staging driver, and not very well.
          Your best chance is to use the v5.2.2.4 branch pf http://github.com/lwfinger/rtl8188eu.git.
          This driver uses cfg80211/nl80211 commands and supports the latest hostapd.
          source: http://lists.infradead.org/pipermail/hostap/2020-May/041657.html
          I just wonder, why that cleanup development is happening out-of-tree (having it mainline would be easier for users). UPDATE: out-of-tree code is that complex that it'd take years to get it in a shape. That unfortunately leads to out-of-tree driver.
          • U
            ubuntu LV 7 @ubuntu 最后由 编辑
            @ubuntu
            https://github.com/lwfinger/rtl8188eu
            这个驱动整到 linux-4.9 里面很多编译错误。
            • U
              ubuntu LV 7 最后由 编辑
              https://github.com/mfruba/kernel
              终于找到了,这个驱动在 Linux4.9 编译正常,试一试能不能运行。
              • Moved from 创龙科技专区 by  xiaowenge xiaowenge
