    tina如何更改wifi的sdc总线?
    8
    7597
      yelong98 LV 7 最后由 编辑
      如题,默认是用sdc1,因为项目需要,sdc1被占用了做网口,板子实际是用sdc0作为wifi的sdio总线,wifi模块是8189ftv,改了board.dts,加载ko文件,没有扫卡动作。请教修改wifi的sdio号,需要做哪些操作?改动哪些文件?
        参考这个,配置SDC2的WIFI
         * Allwinner Technology CO., Ltd. sun20iw1p1 fpga.
         * fpga support.
        /dts-v1/;
        #include "sun20iw1p1u1.dtsi"
        	compatible = "allwinner,d1", "arm,sun20iw1p1", "allwinner,sun20iw1p1";
        	aliases {
        		dsp0 = &dsp0;
        		dsp0_gpio_int= &dsp0_gpio_int;
        	dsp0: dsp0 {
        		compatible = "allwinner,sun20iw1-dsp";
        		status = "disabled";
        	dsp0_gpio_int: dsp0_gpio_int {
        		compatible = "allwinner,sun20iw1-dsp-gpio-int";
        		pin-group = "PB", "PC", "PD", "PE";
        	reg_vdd_cpu: vdd-cpu {
        		pwms = <&pwm 0 5000 1>;
        		regulator-name = "vdd_cpu";
        		regulator-ramp-delay = <25>;
        		regulator-always-on;
        		regulator-boot-on;
        	reg_usb1_vbus: usb1-vbus {
        		regulator-name = "usb1-vbus";
        		gpio = <&pio PB 3 GPIO_ACTIVE_HIGH>;
        		enable-active-high;
        &CPU0 {
        	cpu-supply = <&reg_vdd_cpu>;
        &pio {
        	sdc0_pins_a: sdc0@0 {
        				 "PF3", "PF4", "PF5";
        		allwinner,function = "sdc0";
        		allwinner,muxsel = <2>;
        		allwinner,drive = <3>;
        		allwinner,pull = <1>;
        		function = "sdc0";
        		drive-strength = <30>;
        		bias-pull-up;
        		power-source = <3300>;
        	sdc0_pins_b: sdc0@1 {
        		function = "sdc0";
        		bias-pull-up;
        		power-source = <1800>;
        	sdc0_pins_c: sdc0@2 {
        		function = "gpio_in";
        	/* TODO: add jtag pin */
        	sdc0_pins_d: sdc0@3 {
        		pins = "PF2", "PF4";
        		function = "uart0";
        		drive-strength = <10>;
        		bias-pull-up;
        	sdc0_pins_e: sdc0@4 {
        		pins = "PF0", "PF1", "PF3",
        			"PF5";
        		function = "jtag";
        		bias-pull-up;
        	sdc1_pins_a: sdc1@0 {
        		pins = "PG0", "PG1", "PG2",
        		       "PG3", "PG4", "PG5";
        		function = "sdc1";
        		bias-pull-up;
        	sdc1_pins_b: sdc1@1 {
        	sdc2_pins_a: sdc2@0 {
        		pins = "PC2", "PC3", "PC4",
        			"PC5", "PC6", "PC7";
        		function = "sdc2";
        		bias-pull-up;
        	sdc2_pins_b: sdc2@1 {
        	wlan_pins_a:wlan@0 {
        		pins = "PG11";
        		function = "clk_fanout1";
                pins = "PE2", "PE3";
                function = "uart0";
                bias-pull-up;
        		pins = "PE8", "PE9", "PE10", "PE11";
        		function = "uart1";
        		bias-pull-up;
        	uart1_pins_b: uart1_pins@1 {  /* For EVB1 board */
        		pins = "PC0", "PC1";
        		function = "uart2";
        		bias-pull-up;
        		pins = "PB6", "PB7";
        		function = "uart3";
        		muxsel = <7>;
        		bias-pull-up;
        	uart3_pins_b: uart3_pins@1 {  /* For EVB1 board */
        	twi0_pins_a: twi0@0 {
        		function = "twi0";
        	twi0_pins_b: twi0@1 {
        	twi1_pins_a: twi1@0 {
        		pins = "PB4", "PB5";
        		function = "twi1";
        	twi1_pins_b: twi1@1 {
            twi2_pins_a: twi2@0 {
                pins = "PE12", "PE13";
                function = "twi2";
            twi2_pins_b: twi2@1 {
        	twi3_pins_a: twi3@0 {
        		pins = "PE6", "PE7";
        		function = "twi3";
        	twi3_pins_b: twi3@1 {
        	gmac_pins_a: gmac@0 {
        		pins = "PG0", "PG1", "PG2", "PG3",
        		       "PG4", "PG5", "PG6", "PG7",
        		       "PG8", "PG9", "PG10", "PG12",
        			   "PG13", "PG14", "PG15";
        		function = "gmac0";
        	gmac_pins_b: gmac@1 {
        	dmic_pins_a: dmic@0 {
        		function = "dmic";
        		drive-strength = <20>;
        		bias-disable;
        	dmic_pins_b: dmic@1 {
        		function = "io_disabled";
        		bias-disable;
        	daudio0_pins_a: daudio0@0 {
        		function = "i2s0";
        		bias-disable;
        		bias-disable;
        	daudio1_pins_a: daudio1@0 {
        		function = "i2s1";
        		bias-disable;
        	daudio1_pins_b: daudio1_sleep@0 {
        		bias-disable;
        	daudio2_pins_a: daudio2@0 {
        		pins = "PF6", "PF3", "PF5";
        		function = "i2s2";
        		bias-disable;
        	daudio2_pins_b: daudio2@1 {
        		/* I2S_PIN: DOUT0 */
        		pins = "PF1";
        		function = "i2s2_dout";
        		bias-disable;
        	daudio2_pins_c: daudio2@2 {
        		/* I2S_PIN: DIN0 */
        		pins = "PF0";
        		function = "i2s2_din";
        		bias-disable;
        		pins = "PF6", "PF3", "PF5", "PF1", "PF0";
        		bias-disable;
        	spdif_pins_a: spdif@0 {
        		/* SPDIF_PIN: SPDIF_OUT */
        		pins = "PG18";
        		function = "spdif";
        		bias-disable;
        	spdif_pins_b: spdif_sleep@0 {
        		pins = "PG18";
        		bias-disable;
        	spi0_pins_a: spi0@0 {
        		function = "spi0";
        		muxsel = <2>;
        	spi0_pins_b: spi0@1 {
        		pins = "PC3", "PC7", "PC6";
        		function = "spi0";
        		muxsel = <2>;
        	spi0_pins_c: spi0@2 {
        		muxsel = <0>;
        	spi1_pins_a: spi1@0 {
        		function = "spi1";
        	spi1_pins_b: spi1@1 {
        		function = "spi1";
        	spi1_pins_c: spi1@2 {
        	ledc_pins_a: ledc@0 {
        		pins = "PC0";
        		function = "ledc";
        	ledc_pins_b: ledc@1 {
        		pins = "PC0";
        	pwm0_pin_a: pwm0@0 {
        		pins = "PD16";
        		function = "pwm0";
        		bias-pull-up;
        	pwm0_pin_b: pwm0@1 {
        		pins = "PD16";
        		bias-disable;
        	pwm2_pin_a: pwm2@0 {
        		pins = "PD18";
        		function = "pwm2";
        		bias-pull-up;
        	pwm2_pin_b: pwm2@1 {
        		pins = "PD18";
        		function = "gpio_out";
        	pwm7_pin_a: pwm7@0 {
        		pins = "PD22";
        		function = "pwm7";
        		bias-pull-up;
        	pwm7_pin_b: pwm7@1 {
        		pins = "PD22";
        	s_cir0_pins_a: s_cir@0 {
        		pins = "PB7";
        		function = "ir";
        		bias-pull-up;
        	s_cir0_pins_b: s_cir@1 {
        		pins = "PB7";
        	ir1_pins_a: ir1@0 {
        		pins = "PB0";
        		function = "ir";
        		bias-pull-up;
        	ir1_pins_b: ir1@1 {
        		pins = "PB0";
        	can0_pins_a: can0_pins_a@0 {
        		pins = "PB2", "PB3";
        		function = "can0";
        		bias-pull-up;
        	can0_pins_b: can0_pins_b@1 {
        	can1_pins_a: can1_pins_a@0 {
        		function = "can1";
        		bias-pull-up;
        	can1_pins_b: can1_pins_b@1 {
        &uart0 {
        	pinctrl-0 = <&uart0_pins_a>;
        	pinctrl-1 = <&uart0_pins_b>;
        &uart1 {
        	pinctrl-0 = <&uart1_pins_a>;
        	pinctrl-1 = <&uart1_pins_b>;
        &uart2 {
        	pinctrl-0 = <&uart2_pins_a>;
        	pinctrl-1 = <&uart2_pins_b>;
        &uart3 {
        	pinctrl-0 = <&uart3_pins_a>;
        	pinctrl-1 = <&uart3_pins_b>;
        &soc {
        	card0_boot_para@2 {
        		reg = <0x0 0x2 0x0 0x0>;
        		card_ctrl = <0x0>;
        		card_high_speed = <0x1>;
        		card_line = <0x4>;
        		pinctrl-0 = <&sdc0_pins_a>;
        	rfkill: rfkill@0 {
        		chip_en;
        		power_en;
        		pinctrl-0 = <&wlan_pins_a>;
        		pinctrl-names = "default";
        		status        = "okay";
        		wlan: wlan@0 {
        			wlan_busnum    = <0x2>;
        			wlan_regon    = <&pio PE 4 GPIO_ACTIVE_HIGH>;
        			wlan_hostwake  = <&pio PE 0 GPIO_ACTIVE_HIGH>;
        			/*interrupt-parent = <&pio>;
        			wakeup-source;
        		bt: bt@0 {
        			/*bt_power_num = <0x01>;*/
        			/*bt_io_vol = <3300000>;*/
        			/*bt_power_vol = <330000>;*/
        			bt_rst_n      = <&pio PE 5 GPIO_ACTIVE_LOW>;
        			status        = "okay";
        	btlpm: btlpm@0 {
        		uart_index  = <0x1>;
        		bt_wake     = <&pio PE 7 GPIO_ACTIVE_HIGH>;
        		bt_hostwake = <&pio PE 6 GPIO_ACTIVE_HIGH>;
        		status      = "okay";
        	addr_mgt: addr_mgt@0 {
        		type_addr_wifi = <0x0>;
        		type_addr_bt   = <0x0>;
        		type_addr_eth  = <0x0>;
        		status         = "okay";
        	sdc2: sdmmc@4022000 {
        		device_type = "sdc2";
        		interrupts-extended = <&plic0 58 IRQ_TYPE_LEVEL_HIGH>;
        		clocks = <&dcxo24M>,
        				 <&ccu CLK_PLL_PERIPH0_2X>,
        				 <&ccu CLK_MMC2>,
        				 <&ccu CLK_BUS_MMC2>;
        		resets = <&ccu RST_BUS_MMC2>;
        		reset-names = "rst";
        		pinctrl-0 = <&sdc2_pins_a>;
        		pinctrl-1 = <&sdc2_pins_b>;
        		max-frequency = <50000000>;
        		bus-width = <4>;
        		cap-sd-highspeed;
        		no-mmc;
        		keep-power-in-suspend;
        		sunxi-dly-52M-ddr4  = <1 0 0 0 2>;
        		sunxi-dly-104M  = <1 0 0 0 1>;
        		sunxi-dly-208M  = <1 0 0 0 1>;
        &sdc2 {
        	bus-width = <4>;
        	no-mmc;
        	no-sd;
        	cap-sd-highspeed;
        	/*sd-uhs-sdr12*/
        	/*sd-uhs-sdr25;*/
        	/*sd-uhs-sdr50;*/
        	sd-uhs-ddr50;
        	/*sd-uhs-sdr104;*/
        	/*sunxi-power-save-mode;*/
        	/*sunxi-dis-signal-vol-sw;*/
        	cap-sdio-irq;
        	ignore-pm-notify;
        	max-frequency = <150000000>;
        	ctl-spec-caps = <0x8>;
        &sdc0 {
        	bus-width = <4>;
        	/*non-removable;*/
        	/*broken-cd;*/
        	/*cd-inverted;*/
        	/*data3-detect;*/
        	cap-sd-highspeed;
        	/*sd-uhs-sdr50;*/
        	/*sd-uhs-ddr50;*/
        	/*sd-uhs-sdr104;*/
        	no-sdio;
        	no-mmc;
        &sdc1 {
        	bus-width = <4>;
        	no-mmc;
        	no-sd;
        	cap-sd-highspeed;
        	/*sd-uhs-sdr12*/
        	/*sd-uhs-sdr25;*/
        	/*sd-uhs-sdr50;*/
        	sd-uhs-ddr50;
        	/*sd-uhs-sdr104;*/
        	cap-sdio-irq;
        	ignore-pm-notify;
        tvd configuration
                               mode,mean enable)
        &tvd {
        	tvd_sw          = <1>;
        	tvd_interface   = <0>;
        	tvd_format      = <0>;
        	tvd_system      = <1>;
        	tvd_row         = <1>;
        	tvd_column      = <1>;
        	tvd_channel0_en = <1>;
        	tvd_channel1_en = <0>;
        	tvd_channel2_en = <0>;
        	tvd_channel3_en = <0>;
        	/*tvd_power0      = "dc1sw"*/
        	/*tvd_power1      = "eldo3"*/
        &tvd0 {
        /* Audio Driver modules */
        &sunxi_rpaf_dsp0 {
        &codec {
        	mic1gain 	= <0x1F>;
        	mic2gain 	= <0x1F>;
        	mic3gain 	= <0x1F>;
        	adcdrc_cfg 	= <0x0>;
        	adchpf_cfg 	= <0x1>;
        	dacdrc_cfg 	= <0x0>;
        	dachpf_cfg 	= <0x0>;
        	/* Volume about */
        	digital_vol 	= <0x00>;
        	lineout_vol 	= <0x1a>;
        	headphonegain	= <0x03>;
        	/* Pa enabled about */
        	pa_level 	= <0x01>;
        	pa_pwr_level 	= <0x01>;
        	pa_msleep_time 	= <0x78>;
        	/* gpio-spk	= <&pio PF 2 GPIO_ACTIVE_HIGH>;*/
        	/* CMA config about */
        	playback_cma	= <128>;
        	capture_cma	= <256>;
        	/* regulator about */
        &sndcodec {
        	hp_detect_case = <0x01>;
        	jack_enable = <0x01>;
        &dummy_cpudai {
        &dmic {
        &dmic_codec {
        &sounddmic {
         * tdm_config		0 --> pcm
         *			1 --> i2s
         * mclk_div		0 --> not output
         *			1 --> HDMI audio type
        &daudio0 {
        	mclk_div 	= <0x01>;
        	frametype 	= <0x00>;
        	tdm_config 	= <0x01>;
        	sign_extend 	= <0x00>;
        	msb_lsb_first 	= <0x00>;
        	pcm_lrck_period = <0x80>;
        	slot_width_select = <0x20>;
        	pinctrl_used	= <0x0>;
        &sounddaudio0 {
        		/* sound-dai = <&ac108>; */
        &daudio1 {
        	mclk_div 	= <0x01>;
        	frametype 	= <0x00>;
        	pinctrl-0       = <&daudio1_pins_a>;
        	pinctrl-1       = <&daudio1_pins_b>;
        &sounddaudio1 {
        &daudio2 {
        	mclk_div 	= <0x01>;
        	frametype 	= <0x00>;
        	tx_data_mode 	= <0x00>;
        	rx_data_mode 	= <0x00>;
        	asrc_function_en  = <0x00>;
        	pinctrl_used	= <0x1>;
        	daudio_type	= <0x0>;
        &hdmiaudio {
        &sounddaudio2 {
        &spdif {
        &soundspdif {
        &usbc0 {
        	device_type = "usbc0";
        	usb_port_type = <0x0>;
        	usb_detect_type = <0x0>;
        	usb_detect_mode = <0>;
        	usb_id_gpio = <&pio PB 6 GPIO_ACTIVE_HIGH>; /*unused */
        	enable-active-high;
        	usb_det_vbus_gpio = <&pio PB 2 GPIO_ACTIVE_HIGH>;/*unused */
        	usb_wakeup_suspend = <0>;
        	usb_serial_unique = <0>;
        	rndis_wceis = <1>;
        &ehci0 {
        &ohci0 {
        &usbc1 {
        	device_type = "usbc1";
        	usb_port_type = <1>;
        	usb_detect_type = <0>;
        	usb_regulator_io = "nocare";
        &ehci1 {
        &ohci1 {
        &twi0 {
        	clock-frequency = <400000>;
        	pinctrl-0 = <&twi0_pins_a>;
        	pinctrl-1 = <&twi0_pins_b>;
        	eeprom@50 {
        		compatible = "atmel,24c16";
        		reg = <0x50>;
        &twi1 {
        	pinctrl-0 = <&twi1_pins_a>;
        	pinctrl-1 = <&twi1_pins_b>;
        &twi2 {
        	pinctrl-0 = <&twi2_pins_a>;
        	pinctrl-1 = <&twi2_pins_b>;
        	dmas = <&dma 45>, <&dma 45>;
        	dma-names = "tx", "rx";
        	/* pcf8574-usage:
        	 * pin set:
        	 * interrupt set:
        	pcf8574: gpio@38 {
        		compatible = "nxp,pcf8574";
        		reg = <0x38>;
        		gpio_base = <2020>;
        		gpio-controller;
        		#gpio-cells = <2>;
        		interrupt-controller;
        		#interrupt-cells = <2>;
        	ctp@14 {
                device_type = "ctp";
                reg = <0x14>;
                ctp_name = "gt9xxnew_ts";
                ctp_twi_id = <0x2>;
                ctp_twi_addr = <0x14>;
                ctp_screen_max_x = <0x320>;
                ctp_screen_max_y = <0x1e0>;
                ctp_revert_x_flag = <0x0>;
                ctp_revert_y_flag = <0x0>;
                ctp_int_port = <&pio PE 10 GPIO_ACTIVE_HIGH>;
                ctp_wakeup = <&pio PE 11 GPIO_ACTIVE_HIGH>;
                /*ctp-supply = <&reg_aldo2>;*/
                /*ctp_power_ldo = <&reg_aldo2>;*/
                /*ctp_power_ldo_vol = <3300>;*/
        &twi3 {
        	pinctrl-0 = <&twi3_pins_a>;
        	pinctrl-1 = <&twi3_pins_b>;
        	rda5807@11 {
        		compatible = "rdamicro,rda5807";
        		reg = <0x11>;
        		lnap;
        		lna-current = <2500>;
        		analog-out;
        &gmac0 {
        	phy-mode = "rgmii";
        	use_ephy25m = <0>;
        	pinctrl-0 = <&gmac_pins_a>;
        	pinctrl-1 = <&gmac_pins_b>;
        	tx-delay = <3>; /*2~4*/
        	rx-delay = <0>;
        &spi0 {
        	pinctrl-1 = <&spi0_pins_c>;
        	spi_slave_mode = <0>;
        	spi0_cs_number = <1>;
            spi0_cs_bitmap = <1>;
        	spi-nand@0 {
        		compatible = "spi-nand";
        		spi-max-frequency=<0x5F5E100>;
        		reg = <0x0>;
        		spi-rx-bus-width=<0x04>;
        		spi-tx-bus-width=<0x04>;
        		status="disabled";
        &spi1 {
        	pinctrl-1 = <&spi1_pins_c>;
        	spi_board1@0 {
        		device_type = "spi_board1";
        		compatible = "rohm,dh2228fv";
        		reg = <0x0>;
        		spi-rx-bus-width = <0x4>;
        		spi-tx-bus-width = <0x4>;
        &ledc {
        	pinctrl-0 = <&ledc_pins_a>;
        	pinctrl-1 = <&ledc_pins_b>;
        	led_count = <12>;
        	output_mode = "GRB";
        	reset_ns = <84>;
        	t1h_ns = <800>;
        	t1l_ns = <320>;
        	t0h_ns = <300>;
        	t0l_ns = <800>;
        	wait_time0_ns = <84>;
        	wait_time1_ns = <84>;
        	wait_data_time_ns = <600000>;
        &keyboard0 {
        	key0 = <210 0x160>;
        	wakeup-source;
        disp init configuration
        set fbX_height to lcd_x)
                           in display.
        &disp {
        	/*VCC-LCD*/
        	/*VCC-DSI*/
        	/*VCC-PD*/
        ;lcd0 configuration
        ;Pin setting for gpio:
        ;fsync setting, pulse to csi
        &lcd0 {
        	lcd_used            = <1>;
        	lcd_driver_name     = "d310t9362v1";
        	lcd_if              = <4>;
        	lcd_x               = <480>;
        	lcd_y               = <800>;
        	lcd_width           = <40>;
        	lcd_height          = <67>;
        	lcd_dclk_freq       = <34>;
        	lcd_hbp             = <120>;
        	lcd_ht              = <624>;
        	lcd_hspw            = <48>;
        	lcd_vbp             = <28>;
        	lcd_vt              = <908>;
        	lcd_vspw            = <12>;
        	lcd_dsi_if          = <0>;
        	lcd_dsi_lane        = <2>;
        	lcd_lvds_if         = <0>;
        	lcd_lvds_colordepth = <0>;
        	lcd_lvds_mode       = <0>;
        	lcd_frm             = <0>;
        	lcd_hv_clk_phase    = <0>;
        	lcd_hv_sync_polarity= <0>;
        	lcd_gamma_en        = <0>;
        	lcd_bright_curve_en = <0>;
        	lcd_cmap_en         = <0>;
        	lcd_fsync_en        = <0>;
        	lcd_fsync_act_time  = <1000>;
        	lcd_fsync_dis_time  = <1000>;
        	lcd_fsync_pol       = <0>;
        	deu_mode            = <0>;
        	lcdgamma4iep        = <22>;
        	smart_color         = <90>;
        	lcd_gpio_0 = <&pio PD 9 GPIO_ACTIVE_HIGH>;
        	lcd_bl_en = <&pio PE 12 GPIO_ACTIVE_HIGH>;
        	pinctrl-0 = <&dsi2lane_pins_a>;
        	pinctrl-1 = <&dsi2lane_pins_b>;
        	lcd_backlight       = <150>;
        	lcd_if              = <3>;
        	lcd_x               = <1280>;
        	lcd_y               = <800>;
        	lcd_width           = <150>;
        	lcd_height          = <94>;
        	lcd_dclk_freq       = <71>;
        	lcd_rb_swap			= <0>;
        	lcd_pwm_used        = <1>;
        	lcd_pwm_ch          = <7>;
        	lcd_pwm_pol         = <1>;
        	lcd_pwm_max_limit   = <255>;
        	lcd_hbp             = <20>;
        	lcd_ht              = <1418>;
        	lcd_hspw            = <10>;
        	lcd_vbp             = <10>;
        	lcd_vt              = <814>;
        	lcd_vspw            = <5>;
        	lcd_lvds_if         = <0>;
        	lcd_lvds_colordepth = <1>;
        	lcd_frm             = <1>;
        	lcd_hv_sync_polarity = <0>;
        	lcd_gamma_en        = <0>;
        	lcd_cmap_en         = <0>;
        	deu_mode            = <0>;
        	smart_color         = <90>;
        	pinctrl-0 = <&lvds0_pins_a>;
        	pinctrl-1 = <&lvds0_pins_b>;
        	lcd_bl_en = <&pio PD 20 GPIO_ACTIVE_HIGH>;
        	lcd_driver_name     = "he0801a068";
        	lcd_backlight       = <50>;
        	lcd_if              = <4>;
        	lcd_x               = <800>;
        	lcd_y               = <1280>;
        	lcd_width           = <52>;
        	lcd_height          = <52>;
        	lcd_dclk_freq       = <78>;
        	lcd_pwm_used        = <1>;
        	lcd_pwm_ch          = <7>;
        	lcd_pwm_pol         = <1>;
        	lcd_hbp             = <149>;
        	lcd_ht              = <978>;
        	lcd_hspw            = <16>;
        	lcd_vbp             = <7>;
        	lcd_vt              = <1329>;
        	lcd_vspw            = <5>;
        	lcd_dsi_lane        = <4>;
        	lcd_lvds_if         = <0>;
        	lcd_frm             = <0>;
        	lcd_gamma_en        = <0>;
        	lcd_cmap_en         = <0>;
        	deu_mode            = <0>;
        	smart_color         = <90>;
        	lcd_gpio_0 = <&pio PD 20 GPIO_ACTIVE_HIGH>;
        &hdmi {
        	hdmi_used = <0>;
        	hdmi_power_cnt = <0>;
        	hdmi_cts_compatibility = <1>;
        	hdmi_hdcp_enable = <1>;
        	hdmi_hdcp22_enable = <0>;
        	hdmi_cec_support = <1>;
        	hdmi_cec_super_standby = <0>;
        	ddc_en_io_ctrl = <0>;
        	power_io_ctrl = <0>;
        &pwm0 {
        	pinctrl-0 = <&pwm0_pin_a>;
        	pinctrl-1 = <&pwm0_pin_b>;
        &pwm2 {
        	pinctrl-0 = <&pwm2_pin_a>;
        	pinctrl-1 = <&pwm2_pin_b>;
        &pwm7 {
        	pinctrl-0 = <&pwm7_pin_a>;
        	pinctrl-1 = <&pwm7_pin_b>;
        &rtp {
        	allwinner,ts-attached;
        &tpadc {
        	key_cnt = <5>;
        	key1 = <420 115>;
        	key2 = <870 114>;
        	key3 = <1290 119>;
        	key4 = <1630 373>;
        	key5 = <1950 28>;
        &gpadc {
        	channel_num = <1>;
        	channel_select = <0x01>;
        	channel_data_select = <0>;
        	channel_cld_select = <0x01>;
        	channel_chd_select = <0>;
        	channel0_compare_lowdata = <1600000>;
        	key_cnt = <5>;
        	key0_vol = <210>;
        	key0_val = <0x19c>;
        	key1_vol = <410>;
        	key1_val = <0x197>;
        	key2_vol = <590>;
        	key2_val = <158>;
        	key3_vol = <750>;
        	key3_val = <28>;
        	key4_vol = <880>;
        	key4_val = <28>;
        	wakeup-source;
        &s_cir0 {
        	pinctrl-0 = <&s_cir0_pins_a>;
        	pinctrl-1 = <&s_cir0_pins_b>;
        	ir_protocol_used		= <0>;
        	ir_addr_code0			= <0x0>;
        &ir1 {
        	pinctrl-0 = <&ir1_pins_a>;
        	pinctrl-1 = <&ir1_pins_b>;
        Y C 2 条回复 最后回复 回复 引用 分享 0
          yelong98 LV 7 @YuzukiTsuru 最后由 YuzukiTsuru 编辑
          @yuzukitsuru 多谢指导,除了这个dts还需要改动哪些部分?
          启动log
          [    3.781995] ======== XRADIO WIFI OPEN ========
          [    3.787549] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
          [    3.794401] [XRADIO] Allocated hw_priv @ 11d5702d
          [    3.900290] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 w                      idth 1 timing LEGACY(SDR12) dt B
          [    3.911433] [XRADIO] Detect SDIO card 0
          [    3.917686] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
          [    3.937827] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd                       21 width 1 timing LEGACY(SDR12) dt B
          [    3.962058] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd                       21 width 1 timing LEGACY(SDR12) dt B
          [    3.976660] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd                       21 width 1 timing LEGACY(SDR12) dt B
          [    3.990431] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 8, RTO !!
          [    3.997998] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
          [    4.005661] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
          [    4.013323] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
          [    4.020986] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
          [    4.027841] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 w                      idth 1 timing LEGACY(SDR12) dt B
          [    6.067663] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 w                      idth 1 timing LEGACY(SDR12) dt B
          [    6.078800] [XRADIO] Remove SDIO card 0
          [    6.087666] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
          [    6.100291] [SBUS_ERR] sdio probe timeout!
          [    6.104879] [XRADIO_ERR] sbus_sdio_init failed
          [    6.109884] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd                       21 width 1 timing LEGACY(SDR12) dt B
          [    6.121771] xradio_core_init failed (-110)!
          [    6.134299] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd                       21 width 1 timing LEGACY(SDR12) dt B
          [    6.148920] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd                       21 width 1 timing LEGACY(SDR12) dt B
          [    6.162714] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 8, RTO !!
          [    6.170283] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
          [    6.177943] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
          [    6.185603] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
          [    6.193261] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
          [    6.200114] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 w                      idth 1 timing LEGACY(SDR12) dt B
          [    6.266172] ======== XRADIO WIFI OPEN ========
          [    6.271756] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
          [    6.278560] [XRADIO] Allocated hw_priv @ da90b9c5
          [    6.337854] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supp                      ly udc not found, using dummy regulator
          [    6.384450] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 w                      idth 1 timing LEGACY(SDR12) dt B
          [    6.395596] [XRADIO] Detect SDIO card 0
          [    6.407677] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
          [    6.427823] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd                       21 width 1 timing LEGACY(SDR12) dt B
          [    6.452046] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd                       21 width 1 timing LEGACY(SDR12) dt B
          [    6.466653] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd                       21 width 1 timing LEGACY(SDR12) dt B
          [    6.480416] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 8, RTO !!
          [    6.487981] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
          [    6.495644] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
          [    6.503305] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
          [    6.510965] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
          [    6.517821] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 w                      idth 1 timing LEGACY(SDR12) dt B
          [    8.547676] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 w                      idth 1 timing LEGACY(SDR12) dt B
          [    8.558817] [XRADIO] Remove SDIO card 0
          8189fs.ko已经编译出来了
          启动进入系统以后
          insmod 8189fs.ko
          [ 667.086099] (missing .modinfo section or name field): module has no symbols (stripped?)
          failed to insert 8189fs.ko
          这里是哪没有配置好,新手入门,贻笑大方了
            柚木 鉉 LV 9 @yelong98 最后由 编辑
            @yelong98 xr829需要配置wl_reg_on,8189fs估计是因为驱动版本不适配
            Y 1 条回复 最后回复 回复 引用 分享 0
              yelong98 LV 7 @YuzukiTsuru 最后由 编辑
              @yuzukitsuru 麻烦再问一下除了dts需要修改,还需要修改其他文件么?
                lingeasy LV 5 @yelong98 最后由 编辑
                @yelong98 后来你的这个问题有解决吗?我也遇到相同的问题,给指点一下。
                  yelong98 LV 7 @lingeasy 最后由 编辑
                  @lingeasy 没解决,放弃吧,我花了一周多时间全浪费了,我得结论是wifi的sdio只能接到参考设计的那个口,我最后重新改了板子解决的,把口换回去
                    cdzlll LV 3 @YuzukiTsuru 最后由 编辑
                    @yuzukitsuru 在 tina如何更改wifi的sdc总线? 中说:
                    参考这个,配置SDC2的WIFI
                    你这个也看不出来哪里配置的WIFI的SDC总线啊!
