    D1H emmc启动问题
      lgkgkfg LV 6 最后由 YuzukiTsuru 编辑
      U-Boot 2018.05-g24521d6-dirty (Oct 11 2022 - 05:48:04 +0000) Allwinner Technology
      [00.300]DRAM:  1 GiB
      [00.302]Relocation Offset is: 3dee7000
      [00.306]secure enable bit: 0
      [00.309]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.315]flash init start
      [00.317]workmode = 0,storage type = 2
      [00.321][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
      [00.326][mmc]: get sdc_type fail and use default host:tm4.
      [00.332][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.357][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
      [00.364]sunxi flash init ok
      [00.366]line:703 init_clocks
      [00.370]drv_disp_init
      request pwm success, pwm2:pwm2:0x2000c00.
      [00.387]drv_disp_init finish
      [00.389]boot_gui_init:start
      [00.392]set disp.dev2_output_type fail. using defval=0
      [00.419]boot_gui_init:finish
      54 bytes read in 0 ms
      [00.595]bmp_name=bootlogo.bmp size 3072054
      [00.652]LCD open finish
      3072054 bytes read in 67 ms (43.7 MiB/s)
      [00.690]Loading Environment from SUNXI_FLASH... OK
      [00.705]out of usb burn from boot: not need burn key
      [00.710][mmc]: memalign dst_align is NULL!
      read first backup failed in fun sunxi_flash_mmc_secread line 358
      [00.719][mmc]: memalign dst_align is NULL!
      [00.729]unknown error happen in item 0 read
      [00.732]get secure storage map err
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.745]update part info
      [00.747]update bootcmd
      [00.751]change working_fdt 0x7eaa6da0 to 0x7ea86da0
      [00.756][mmc]: no mmc-hs400-1_8v!
      [00.759][mmc]: delete mmc-hs200-1_8v from dtb
      [00.763][mmc]: get max-frequency ok 50000000 Hz
      [00.792]update dts
      noncached_alloc(): addr = 0x7eefb080
      noncached_alloc(): addr = 0x7eefb0c0
      noncached_alloc(): addr = 0x7eefb100
      noncached_alloc(): addr = 0x7eefb94
      日志如下,请问可能是啥问题?
        看着已经启动了,是不是kernel没有配置串口或者配置的串口不对
          lgkgkfg LV 6 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru 确实是没配置串口,我改硬件了,只有BOOT0那里修改了,内核设备树那里没改,😂
