    T113的SPIDEV只能发送几次,就卡住了?
    5
    7
    6793
    • zhongtao1701
      钟工 LV 7 最后由 whycan 编辑
      使用spidev_test进行测试,发现前面几次可以成功收发,使用示波器可以观察到正确的波形, 然后spidev_test应用就卡住了,试过程如下,为了避免console被卡住,把测试放在后台:
      #spidev_test -D /dev/spidev0.0 -v -s 1000000 -p 12345678&
      [1] 1114
      spi mode: 0x0
      bits per word: 8
      max speed: 1000000 Hz (1000 KHz)
      TX | 31 32 33 34 35 36 37 38 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __  | 12345678
      RX | FF FF FF FF FF FF FF FF __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __  | ........
      # spidev_test -D /dev/spidev0.0 -v -s 1000000 -p 12345678&
      [2] 1116
      [1]   Done                    spidev_test -D /dev/spidev0.0 -v -s 1000000 -p 12345678
      spi mode: 0x0
      bits per word: 8
      [3] 1117
      [2]   Done                    spidev_test -D /dev/spidev0.0 -v -s 1000000 -p 12345678
      spi mode: 0x0
      bits per word: 8
      [4] 1118
      [3]   Done                    spidev_test -D /dev/spidev0.0 -v -s 1000000 -p 12345678
      spi mode: 0x0
      bits per word: 8
      [5] 1120
      [4]   Done                    spidev_test -D /dev/spidev0.0 -v -s 1000000 -p 12345678
      spi mode: 0x0
      bits per word: 8
      [6] 1121
      [5]   Done                    spidev_test -D /dev/spidev0.0 -v -s 1000000 -p 12345678
      spi mode: 0x0
      bits per word: 8
      [7] 1122
      [6]   Done                    spidev_test -D /dev/spidev0.0 -v -s 1000000 -p 12345678
      spi mode: 0x0
      bits per word: 8
      spidev_test应用被卡住,没有数据输出,应该是spi的驱动没有返回
      # ps
      PID   USER     COMMAND
          1 root     init [3]
          2 root     [kthreadd]
          3 root     [rcu_gp]
          4 root     [rcu_par_gp]
          5 root     [kworker/0:0-eve]
          6 root     [kworker/0:0H-kb]
          7 root     [kworker/u4:0-ev]
          8 root     [mm_percpu_wq]
          9 root     [ksoftirqd/0]
         10 root     [rcu_preempt]
         11 root     [migration/0]
         12 root     [cpuhp/0]
         13 root     [kdevtmpfs]
         14 root     [kworker/u4:1-ev]
         16 root     [rcu_tasks_kthre]
         26 root     [kworker/0:1-eve]
        420 root     [oom_reaper]
        421 root     [writeback]
        455 root     [kblockd]
        529 root     [kworker/u4:2-ev]
        593 root     [ion_system_heap]
        615 root     [watchdogd]
        710 root     [cfg80211]
        714 root     [spi0]
        725 root     [kswapd0]
        737 root     [vsync proc 0]
        738 root     [vsync proc 1]
        795 root     [uas]
        835 root     [rc0]
        862 root     [irq/40-mmc0]
        864 root     [irq/202-4020000]
        866 root     [kworker/0:2-eve]
        867 root     [irq/41-mmc1]
        873 root     [kworker/0:3-eve]
        888 root     [mmc_complete]
        892 root     [kworker/0:1H-kb]
        901 root     [ipv6_addrconf]
        916 root     [krfcommd]
        953 root     [usb-hardware-sc]
        956 root     [goodix_wq]
        969 root     [kworker/0:2H-kb]
        970 root     [jbd2/mmcblk0p5-]
        971 root     [ext4-rsv-conver]
       1009 root     /sbin/syslogd -n
       1013 root     /sbin/klogd -n
       1024 root     /sbin/udevd -d
       1092 root     /usr/bin/swupdate -v -w -r /var/www/swupdate -p 8080
       1093 root     -bash
       1099 root     /usr/bin/swupdate-progress -w -r
       1105 root     /usr/bin/swupdate -v -w -r /var/www/swupdate -p 8080
       1122 root     spidev_test -D /dev/spidev0.0 -v -s 1000000 -p 12345678
       1124 root     ps
      # cat /proc/1122/status
      Umask:  0022
      State:  R (running)
      Tgid:   1122
      Ngid:   0
      Pid:    1122
      PPid:   1093
      TracerPid:      0
      Uid:    0       0       0       0
      Gid:    0       0       0       0
      FDSize: 256
      Groups: 0 10
      VmPeak:     1352 kB
      VmSize:     1352 kB
      VmLck:         0 kB
      VmPin:         0 kB
      VmHWM:       132 kB
      VmRSS:       132 kB
      RssAnon:              28 kB
      RssFile:             104 kB
      RssShmem:              0 kB
      VmData:      168 kB
      VmStk:       132 kB
      VmExe:         8 kB
      VmLib:       964 kB
      VmPTE:         8 kB
      VmSwap:        0 kB
      CoreDumping:    0
      THP_enabled:    0
      Threads:        1
      SigQ:   0/726
      SigPnd: 0000000000000000
      ShdPnd: 0000000000000000
      SigBlk: 0000000000000000
      SigIgn: 0000000000000000
      SigCgt: 0000000000000000
      CapInh: 0000000000000000
      CapPrm: 0000003fffffffff
      CapEff: 0000003fffffffff
      CapBnd: 0000003fffffffff
      CapAmb: 0000000000000000
      NoNewPrivs:     0
      Speculation_Store_Bypass:       unknown
      Cpus_allowed:   3
      Cpus_allowed_list:      0-1
      voluntary_ctxt_switches:        0
      nonvoluntary_ctxt_switches:     1398
      硬件平台是 MQ-R(T113), dts中配置如下,只
      使用了CLK, CS, MISO, MOSI4根线
      sun8iw20p1-t113-100ask-t113-pro.dts
              spi0_pins_a: spi0@0 {
                      pins = "PC2", "PC4", "PC5"; /*clk mosi miso*/
                      function = "spi0";
                      drive-strength = <10>;
              spi0_pins_b: spi0@1 {
                      pins = "PC3";
                      function = "spi0";
                      bias-pull-up;   /* only CS should be pulled up */
              spi0_pins_c: spi0@2 {
                      pins = "PC2", "PC3", "PC4", "PC5";
                      function = "gpio_in";
      &spi0 {
              pinctrl-1 = <&spi0_pins_c>;
              spi_slave_mode = <0>;
              spi0_cs_number = <1>;
              spi0_cs_bitmap = <1>;
              spi_board0@0 {
                      device_type = "spi_board0";
                      compatible = "rohm,dh2228fv";
                      reg = <0x0>;
                      spi-rx-bus-width = <0x01>;
                      spi-tx-bus-width = <0x01>;
      在D1s平台上测试也有类似的问题,各位大侠,是否遇到这个情况, 请指点一下,谢谢!
        echo 255 > /sys/module/spi_sunxi/parameters/debug 开调试看一下
        zhongtao1701 1 条回复 最后回复 回复 引用 分享 0
        • zhongtao1701
          钟工 LV 7 @YuzukiTsuru 最后由 YuzukiTsuru 编辑
          @yuzukitsuru 谢谢大侠回复
          # echo 255 > /sys/module/spi_sunxi/parameters/debug
          [   96.048082] spi_set_clk()532 - set spi clock 100000000, mclk 1000000
          [   96.055418] spi_set_clk()532 - set spi clock 100000000, mclk 100000000
          [   96.062767] spi_set_clk()532 - set spi clock 1000000, mclk 100000000
          spi mode: 0x0[   96.071087] sunxi_spi_transfer_one()1637 - [spi0] begin transfer, txbuf 684e7dd8, rxbuf 989b57fc, len 8
          bits per word: 8
          [   96.083098] sunxi_spi_mode_check()1313 - [spi0] Single mode Full duplex tx & rx
          [   96.095818] sunxi_spi_transfer_one()1674 - [spi0] dump reg:
          [   96.102085] 0x04025000: 00010001 00000083 00002044 00000000
          [   96.108655] 0x04025010: 00001700 00000032 00200020 00000000
          [   96.115268] 0x04025020: 00000000 00000002 00002000 00000000
          [   96.121632] 0x04025030: 00000008 00000008 00000008 00000000
          [   96.128206] sunxi_spi_dma_transfer()1551 - [spi0] rx and tx -> by ahb
          [   96.135668] sunxi_spi_cpu_writel()1417 - t->len = 8
          [   96.141155] 000: 31 32 33 34 35 36 37 38
          [   96.145935] sunxi_spi_cpu_readl()1386 - t->len = 8
          [   96.145945] sunxi_spi_handler()1728 - [spi0] irq status = 1033
          [   96.157855] sunxi_spi_handler()1744 - [spi0] SPI TC comes
          [   96.164245] 000: ff ff ff ff ff ff ff ff
          [   96.168751] sunxi_spi_transfer_one()1685 - [spi0] dump reg:
          [   96.175279] 0x04025000: 00010001 00000083 00002044 00000000
          [   96.181640] 0x04025010: 00000000 00000032 00200020 00000000
          [   96.188197] 0x04025020: 00000000 00000002 00002000 00000000
          [   96.194687] 0x04025030: 00000000 00000000 00000000 00000000
          重复几十次测试,没有卡住, 我就要下面命令加大收发数据量,也不会卡住
          spi-pipe --device=/dev/spidev0.0 -b 8 -n 256 -s 1000000 < /dev/zero
          然后我再把调试关闭,重复几次,很快就复现原来的问题
          # echo 0 > /sys/module/spi_sunxi/parameters/debug
          spi mode: 0x0
          bits per word: 8
          spi mode: 0x0
          bits per word: 8
          spi mode: 0x0
          bits per word: 8
          spi mode: 0x0
          bits per word: 8
          spi mode: 0x0
          bits per word: 8
          卡住了,后面没有输出了
          我用示波器观察,最后一次卡住时,也是有波形的,感觉spi的驱动没有收到传输结束中断,调试输出可能会影响到中断的设置时序,请大侠帮助分析分析,谢谢!
          在T113/D1s上都可以重现,我对比了一下它们驱动sunxi_spi.c是相同的
          T113的软件版本
          https://gitee.com/weidongshan/buildroot_100ask_t113-pro
          F133的软件版本
          https://github.com/YuzukiHD/Buildroot-YuzukiSBC
          Y J 2 条回复 最后回复 回复 引用 分享 1
            yy_fly LV 4 @zhongtao1701 最后由 编辑
            @zhongtao1701 我也有碰到了同样的问题 spi原厂驱动有问题
              JauneNahy LV 3 最后由 编辑
              你好,请问最后的原因找到了吗?是因为中断的问题而导致进程卡死的吗。如果找到原因了麻烦解答一下,谢谢。
                JauneNahy LV 3 @zhongtao1701 最后由 编辑
                @zhongtao1701 你好,请问最后的原因找到了吗?是因为中断的问题而导致进程卡死的吗。如果找到原因了麻烦解答一下,谢谢。
                  wangkonglaosong LV 3 最后由 编辑
                  D1s上spi操作有同样的问题,而且spi驱动里的函数执行卡死后,没有任何结束进程的方式。不知道全志解决这个spi驱动的问题了没有
