    板子启动失败,怎么重新烧录
    • I
      inomec LV 5 最后由 编辑
      平台V536, 系统TinaLinux4.9
      启动log如下,板子无法启动了,请问怎么重新烧录
      sunxi#[152]HELLO! BOOT0 is starting!
      [155]boot0 commit : edb664ec9618b2388deb8d5658aa223a2f47d641
      [172]rsb_send_initseq: rsb clk 400Khz -> 3Mhz
      [177]PMU: AXP2101
      [179]set pll start
      [182]set pll end
      [183]rtc[3] value = 0x0000b015
      [186]DRAM BOOT DRIVE INFO: V0.41
      [190]the chip id is 0x00000004
      [193]the chip id is 0x00000004
      [196]the chip id is 0x00000004
      [199]the chip id is 0x00000004
      [202]the chip id is 0x00000004
      [205]chip id check OK
      [207]DRAM_VCC set to 1500 mv
      [210]DRAM CLK =792 MHZ
      [212]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
      [251]Training result is = 00000007
      [254]Actual DRAM SIZE =1024 M
      [257]DRAM SIZE =1024 MBytes, para1 = 000030fa, para2 = 04000000, dram_tpr13 = 08006843
      [274]DRAM simple test OK.
      [277]dram size =1024
      [281]card no is 2
      [283]sdcard 2 line count 8
      [285][mmc]: mmc driver ver 2017-09-26 15:04
      [289][mmc]: mmc 2 bias 00000000
      [298][mmc]: ***Try MMC card %u***
      [312][mmc]: MMC 5.1
      [314][mmc]: HSDDR52/DDR50 %u bit
      [317][mmc]: %u Hz
      [319][mmc]: %u MB
      [321][mmc]: ***SD/MMC %u init OK!!!***
      [449]Loading boot-pkg Succeed(index=0).
      [452]Entry_name        = scp
      [463]set arisc reset to de-assert state
      [466]Entry_name        = optee
      [470]Entry_name        = u-boot
      [495]Entry_name        = soc-cfg
      [499]Entry_name        = dtb
      [503]Ready to disable icache.
      [506]0xffffffff 0xffffffff
      [508]0xff17ffff 0xffffffff
      [511]0xff0c10ff 0xffffffff
      [513]0x1111ffff 0xffffff13
      [516]0xff17ffff 0xffffffff
      [518]0x1212ffff 0xffffff11
      [521]Jump to secend Boot.
      U-Boot 2014.07 (Jan 11 2020 - 17:10:39) Allwinner Technology
      uboot commit : 671972499d340c9bf2e6efc256418bd11668e23a
      secure enable bit: 0
      normal mode: with secure monitor
      [0.556]pmbus:   ready
      [0.556]PMU: AXP21
      [0.558]PMU: cpux 912 Mhz,AXI=304 Mhz
      PLL6=600 Mhz,AHB1=200 Mhz, APB1=150Mhz MBus=400Mhz
      DRAM:  1 GiB
      Relocation Offset is: 3bc1a000
      gic: sec monitor mode
      drv_disp_init
      init_clocks: finish init_clocks.
      pwm_request: reg = 0x300a000. pwm = 8.
      request pwm success, pwm = 8.
      drv_disp_init finish
      [0.645]fetch script data boot_disp.auto_hpd fail
      workmode = 0,storage type = 2
      [0.646]MMC:      2
      SUNXI SD/MMC: 2
      Normal
      used mbr [0], count = 9
      read item0 copy0
      Item0 (Map) magic is bad
      the secure storage item0 copy0 is bad
      read item0 copy1
      the secure storage item0 copy0 == copy1, the data is good
      the secure storage map is empty
      no item name device_unlock in the map
      sunxi storage read fail
      no item name fastboot_status_flag in the map
      sunxi secure storage has no flag
      --------fastboot partitions--------
      -total partitions:9-
      -name-        -start-       -size-
      boot-resource: 1000000       100000
      env         : 1100000       100000
      boot        : 1200000       1000000
      rootfs      : 2200000       20000000
      recovery    : 22200000      20000000
      rootfs_data : 42200000      100000
      misc        : 42300000      100000
      private     : 42400000      100000
      UDISK       : 42500000      0
      PowerBus = 2( 2:vBus 3:acBus other: not exist)
      no battery exist
      sunxi_bmp_logo_display
      230454 bytes read in 5 ms (44 MiB/s)
      [0.769]fetch script data boot_disp.output_full fail
      [0.772]
      BMP file is to large!!!!!!!!!!!!!!
      cmdline: boot_type=2
      ## Booting kernel from Legacy Image at 40007fc0 ...
         Image Name:   ARM OpenWrt Linux-4.9.118
         Image Type:   ARM Linux Kernel Image (uncompressed)
         Data Size:    3273072 Bytes = 3.1 MiB
         Load Address: 40008000
         Entry Point:  40008000
         XIP Kernel Image ... OK
         reserving fdt memory region: addr=419e4000 size=13000
         reserving fdt memory region: addr=419f7000 size=4000
         reserving fdt memory region: addr=419fb000 size=5000
         Using Device Tree in place at 42000000, end 4201a1bf
      Starting kernel ...
      [    0.000000] Linux version 4.9.118 (jamo@bm-wuzhaohua) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #772 SMP PREEMPT Mon Oct 17 05:24:31 UTC 2022
      [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
      [    0.000000] OF: fdt:Machine model: sun8iw16
      [    0.000000] cma: Reserved 384 MiB at 0x58000000
      [    0.000000] On node 0 totalpages: 262144
      [    0.000000] free_area_init_node: node 0, pgdat c04e1580, node_mem_map d7738000
      [    0.000000]   Normal zone: 1536 pages used for memmap
      [    0.000000]   Normal zone: 196608 pages, LIFO batch:31
      [    0.000000]   HighMem zone: 65536 pages, LIFO batch:15
      [    0.000000] percpu: Embedded 13 pages/cpu @d76de000 s24524 r8192 d20532 u53248
      [    0.000000] pcpu-alloc: s24524 r8192 d20532 u53248 alloc=13*4096
      [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260608
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000c00 initcall_debug=0 console=ttyS4,115200 loglevel=8 root=/dev/mmcblk0p7 rw rootwait init=/pseudo_init partitions=boot-resource@mmcblk0p2:env@mmcblk0p5:boot@mmcblk0p6:rootfs@mmcblk0p7:recovery@mmcblk0p8:rootfs_data@mmcblk0p9:misc@mmcblk0p10:private@mmcblk0p11:UDISK@mmcblk0p1 cma=384M boot_type=2
      [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
      [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
      [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
      [    0.000000] Memory: 639892K/1048576K available (3162K kernel code, 241K rwdata, 1232K rodata, 168K init, 150K bss, 15468K reserved, 393216K cma-reserved, 262144K highmem)
      [    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
      [    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
      [    0.000000]     modules : 0xbf800000 - 0xbfe00000   (   6 MB)
      [    0.000000]       .text : 0xc0008000 - 0xc031ebec   (3163 kB)
      [    0.000000]       .init : 0xc047c000 - 0xc04a6000   ( 168 kB)
      [    0.000000]       .data : 0xc04a6000 - 0xc04e24c0   ( 242 kB)
      [    0.000000]        .bss : 0xc04e24c0 - 0xc0507f4c   ( 151 kB)
      [    0.000019] Switching to timer-based delay loop, resolution 41ns
      [    0.000058] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.000071] pid_max: default: 4096 minimum: 301
      [    0.000214] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
      [    0.000225] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
      [    0.000906] CPU: Testing write buffer coherency: ok
      [    0.001330] CPU0: update cpu_capacity 1024
      [    0.001343] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.001369] Setting up static identity map for 0x40008240 - 0x4000828c
      [    0.170571] CPU1: update cpu_capacity 1024
      [    0.170579] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.170666] Brought up 2 CPUs
      [    0.170686] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.170693] CPU: All CPU(s) started in SVC mode.
      [    0.171422] devtmpfs: initialized
      [    0.193194] OF: Duplicate name in regulator@0, renamed to "regulator2#1"
      [    0.193235] OF: Duplicate name in regulator@0, renamed to "regulator3#1"
      [    0.193266] OF: Duplicate name in regulator@0, renamed to "regulator7#1"
      [    0.198612] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.199123] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.199144] futex hash table entries: 16 (order: -2, 1024 bytes)
      [    0.212359] pinctrl core: initialized pinctrl subsystem
      [    0.213713] NET: Registered protocol family 16
      [    0.214809] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.216205] dump_class_init,862, success
      [    0.220262] sun8iw16p1-r-pinctrl r_pio: initialized sunXi PIO driver
      [    0.233102] sun8iw16p1-pinctrl pio: initialized sunXi PIO driver
      [    0.234609] sunxi hwspinlock vbase:0xf0858000
      [    0.274721] pwm module init!
      [    0.279673] sunxi-pm debug v3.10
      [    0.280864] G2D: Module initialized.major:253
      [    0.281367] SCSI subsystem initialized
      [    0.282368] usbcore: registered new interface driver usbfs
      [    0.282487] usbcore: registered new interface driver hub
      [    0.282619] usbcore: registered new device driver usb
      [    0.282847] media: Linux media interface: v0.10
      [    0.282949] Linux video capture interface: v2.00
      [    0.284355] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
      [    0.284608] ion_parse_dt_heap_common: id 1 type 1 name sys_contig align 1000
      [    0.284836] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
      [    0.285443] Advanced Linux Sound Architecture Driver Initialized.
      [    0.286773] [axp2101] chip id detect 0x47 !
      [    0.286905] [axp2101] enable dcdc2 dvm.
      [    0.306955] clocksource: Switched to clocksource arch_sys_counter
      [    0.310435] get androidboot.mode fail
      [    0.310454] sunxi_i2c_adap_init()2494 - init
      [    0.310879] [i2c0] twi_regulator: vcc-pi
      [    0.310950] sunxi_i2c_probe()2253 - [i2c0] twi_drv_used = 1
      [    0.311044] twi_request_gpio()450 - [i2c0] init name: twi0
      [    0.312141] sunxi_i2c_dma_request()1104 - [i2c0] using dma0chan0 (tx) and dma0chan1 (rx)for DMA transfers
      [    0.312482] [i2c1] twi_regulator: vcc-io
      [    0.312546] sunxi_i2c_probe()2253 - [i2c1] twi_drv_used = 1
      [    0.312624] twi_request_gpio()450 - [i2c1] init name: twi1
      [    0.313026] sunxi_i2c_dma_request()1104 - [i2c1] using dma0chan2 (tx) and dma0chan3 (rx)for DMA transfers
      [    0.314978] NET: Registered protocol family 2
      [    0.315602] TCP established hash table entries: 16 (order: -6, 64 bytes)
      [    0.315616] TCP bind hash table entries: 16 (order: -5, 128 bytes)
      [    0.315625] TCP: Hash tables configured (established 16 bind 16)
      [    0.315687] UDP hash table entries: 128 (order: 0, 4096 bytes)
      [    0.315709] UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
      [    0.315871] NET: Registered protocol family 1
      [    0.316158] sunxi budget cooling probe start !
      [    0.316182] CPU freq cooling register Success
      [    0.316199] CPU hotplug cooling register Success
      [    0.316545] CPU budget cooling register Success
      [    0.318857] workingset: timestamp_bits=30 max_order=18 bucket_order=0
      [    0.330472] bounce: pool size: 64 pages
      [    0.330811] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
      [    0.330824] io scheduler noop registered
      [    0.330832] io scheduler deadline registered
      [    0.331073] io scheduler cfq registered (default)
      [    0.332016] [DISP]disp_module_init
      [    0.382718] rotation hw function is configed to zero degree
      [    0.387721] [DISP]disp_module_init finish
      [    0.389445] uart0: ttyS0 at MMIO 0x5000000 (irq = 297, base_baud = 1500000) is a SUNXI
      [    0.390350] uart1: ttyS1 at MMIO 0x5000400 (irq = 298, base_baud = 1500000) is a SUNXI
      [    0.391189] uart4: ttyS4 at MMIO 0x5001000 (irq = 299, base_baud = 1500000) is a SUNXI
      [    0.391210] sw_console_setup()1777 - console setup baud 115200 parity n bits 8, flow n
      [    1.235018] console [ttyS4] enabled
      [    1.240016] misc dump reg init
      [    1.247026] loop: module loaded
      [    1.251554] [NAND]Failed to insmod nand!!!
      [    1.256734] sunxi-wlan wlan: wlan_busnum (1)
      [    1.261590] sunxi-wlan wlan: wlan_power_num (-1)
      [    1.266785] sunxi-wlan wlan: io_regulator_name (vcc-pg)
      [    1.272716] sunxi-wlan wlan: request pincrtl handle for device [wlan] failed
      [    1.280706] sunxi-wlan wlan: wlan_regon gpio=203  mul-sel=1  pull=-1  drv_level=-1  data=0
      [    1.290070] sunxi-wlan wlan: get gpio chip_en failed
      [    1.295668] sunxi-wlan wlan: wlan_hostwake gpio=357  mul-sel=6  pull=-1  drv_level=-1  data=0
      [    1.305373] sunxi-wlan wlan: clk_name ()
      [    1.310896] libphy: Fixed MDIO Bus: probed
      [    1.316252] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.325107] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.333971] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.342801] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.351648] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.360481] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.369325] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.378157] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:ephy_25m
      [    1.387334] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.396150] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.404981] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.413807] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.422637] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.431457] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.440284] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:mad
      [    1.448917] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:mdio
      [    1.458444] gmac-power1: NULL
      [    1.461781] gmac-power2: NULL
      [    1.466327] Failed to alloc md5
      [    1.469891] eth0: Use random mac address
      [    1.474662] usbcore: registered new interface driver asix
      [    1.480880] usbcore: registered new interface driver ax88179_178a
      [    1.487862] usbcore: registered new interface driver cdc_ether
      [    1.494534] usbcore: registered new interface driver net1080
      [    1.501023] usbcore: registered new interface driver cdc_subset
      [    1.507810] usbcore: registered new interface driver zaurus
      [    1.514197] usbcore: registered new interface driver cdc_ncm
      [    1.520588] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.527943] ehci-platform: EHCI generic platform driver
      [    1.534319] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    1.541318] ohci-platform: OHCI generic platform driver
      [    1.547638] usb_serial_number:20080411
      [    1.552111] sunxi_gpadc_init,1773, success
      [    1.557517] input: sunxi-gpadc0 as /devices/virtual/input/input0
      [    1.565432] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
      [    1.572365] sunxi-rtc rtc: RTC enabled
      [    1.576967] i2c /dev entries driver
      [    1.581465] google_vp9: sunxi google vp9 version 0.1
      [    1.587796] bat_param node not found
      [    1.613849] input: axp2101-powerkey as /devices/platform/soc/pmu0/axp2101-powerkey/input/input1
      [    1.633111] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    1.642428] sunxi_cpufreq_init: only one opp_table
      [    1.647847] [cpu_freq] ERR: DEBUG: get cpu 0 device
      [    1.655716] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.32 2019-9-24 15:55)
      [    1.664670] sunxi-mmc sdc2: regulator prop vmmc,str vcc-emmc
      [    1.671052] sunxi-mmc sdc2: regulator prop vqmmc,str vcc-pc
      [    1.677336] sunxi-mmc sdc2: regulator prop vdmmc,str none
      [    1.683407] sunxi-mmc sdc2: Can't get vdmmc33sw regulator string
      [    1.690174] sunxi-mmc sdc2: Can't get vdmmc18sw regulator string
      [    1.696928] sunxi-mmc sdc2: Can't get vqmmc33sw regulator string
      [    1.703693] sunxi-mmc sdc2: Can't get vqmmc18sw regulator string
      [    1.710501] get() with no identifier
      [    1.714516] get() with no identifier
      [    1.718542] get() with no identifier
      [    1.722556] get() with no identifier
      [    1.726573] sunxi-mmc sdc2: No vmmc regulator found
      [    1.732064] sunxi-mmc sdc2: No vqmmc regulator found
      [    1.737656] sunxi-mmc sdc2: No vdmmc regulator found
      [    1.743235] sunxi-mmc sdc2: No vd33sw regulator found
      [    1.748925] sunxi-mmc sdc2: No vd18sw regulator found
      [    1.754603] sunxi-mmc sdc2: No vq33sw regulator found
      [    1.760291] sunxi-mmc sdc2: No vq18sw regulator found
      [    1.765981] sunxi-mmc sdc2: Cann't get uart0 pinstate,check if needed
      [    1.773682] sunxi-mmc sdc2: set host busy
      [    1.778277] mmc:failed to get gpios
      [    1.783162] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.816973] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.856978] sunxi-mmc sdc2: detmode:alway in(non removable)
      [    1.863281] sunxi-mmc sdc2: smc 0 p2 err, cmd 52, RTO !!
      [    1.869287] sunxi-mmc sdc2: smc 0 p2 err, cmd 52, RTO !!
      [    1.869311] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.877361] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.889196] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RTO !!
      [    1.899988] sunxi-mmc sdc2: smc 0 p2 err, cmd 5, RTO !!
      [    1.905878] sunxi-mmc sdc2: smc 0 p2 err, cmd 5, RTO !!
      [    1.911777] sunxi-mmc sdc2: smc 0 p2 err, cmd 5, RTO !!
      [    1.917676] sunxi-mmc sdc2: smc 0 p2 err, cmd 5, RTO !!
      [    1.923570] sunxi-mmc sdc2: smc 0 p2 err, cmd 55, RTO !!
      [    1.929470] sunxi-mmc sdc2: smc 0 p2 err, cmd 55, RTO !!
      [    1.935459] sunxi-mmc sdc2: smc 0 p2 err, cmd 55, RTO !!
      [    1.941457] sunxi-mmc sdc2: smc 0 p2 err, cmd 55, RTO !!
      [    1.941474] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.947527] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.947579] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.955614] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.000034] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
      [    2.009379] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
      [    2.018692] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
      [    2.028002] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
      [    2.037325] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
      [    2.046641] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
      [    2.056239] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.32 2019-9-24 15:55)
      [    2.065082] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.076038] sunxi-mmc sdc0: regulator prop vmmc,str vcc-sdc
      [    2.082361] sunxi-mmc sdc0: Can't get vqmmc regulator string
      [    2.088768] sunxi-mmc sdc0: Can't get vdmmc regulator string
      [    2.095221] sunxi-mmc sdc0: regulator prop vdmmc33sw,str vcc33-pf
      [    2.102116] sunxi-mmc sdc0: regulator prop vdmmc18sw,str vcc18-pf
      [    2.109005] sunxi-mmc sdc0: regulator prop vqmmc33sw,str vcc33-pf
      [    2.115875] sunxi-mmc sdc0: regulator prop vqmmc18sw,str vcc18-pf
      [    2.122762] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 8 timing LEGACY(SDR12) dt B
      [    2.133891] get() with no identifier
      [    2.137939] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS200 dt B
      [    2.148398] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS200 dt B
      [    2.159152] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
      [    2.159197] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
      [    2.181226] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS400 dt B
      [    2.181269] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS400 dt B
      [    2.191853] mmc0: new HS400 MMC card at address 0001
      [    2.202482] mmcblk0: mmc0:0001 58A431 14.6 GiB
      [    2.212786] mmcblk0boot0: mmc0:0001 58A431 partition 1 4.00 MiB
      [    2.219846] get() with no identifier
      [    2.223067] mmcblk0boot1: mmc0:0001 58A431 partition 2 4.00 MiB
      [    2.230767] sunxi-mmc sdc0: No vmmc regulator found
      [    2.236253] sunxi-mmc sdc0: No vqmmc regulator found
      [    2.241855] sunxi-mmc sdc0: No vdmmc regulator found
      [    2.248098] sunxi-mmc sdc0: set host busy
      [    2.251209]  mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 p10 p11 >
      [    2.251235] mmcblk0: p1 size 28418048 extends beyond EOD, truncated
      [    2.266265] sunxi-mmc sdc0: Got CD GPIO
      [    2.270696] sunxi-mmc sdc0: filter speed is 7340032 B/s
      [    2.276573] sunxi-mmc sdc0: filter sector is 8 sector
      [    2.282266] sunxi-mmc sdc0: Perf function is enable
      [    2.288019] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.326973] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.367120] sunxi-mmc sdc0: detmode:gpio irq
      [    2.367142] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.383761] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.32 2019-9-24 15:55)
      [    2.392672] sunxi-mmc sdc1: Can't get vmmc regulator string
      [    2.398957] sunxi-mmc sdc1: Can't get vqmmc regulator string
      [    2.405321] sunxi-mmc sdc1: Can't get vdmmc regulator string
      [    2.411698] sunxi-mmc sdc1: Can't get vdmmc33sw regulator string
      [    2.418464] sunxi-mmc sdc1: Can't get vdmmc18sw regulator string
      [    2.425218] sunxi-mmc sdc1: Can't get vqmmc33sw regulator string
      [    2.431981] sunxi-mmc sdc1: Can't get vqmmc18sw regulator string
      [    2.438742] get() with no identifier
      [    2.442757] get() with no identifier
      [    2.446770] get() with no identifier
      [    2.450793] get() with no identifier
      [    2.454807] get() with no identifier
      [    2.458830] get() with no identifier
      [    2.462845] get() with no identifier
      [    2.466862] sunxi-mmc sdc1: No vmmc regulator found
      [    2.472354] sunxi-mmc sdc1: No vqmmc regulator found
      [    2.477944] sunxi-mmc sdc1: No vdmmc regulator found
      [    2.483524] sunxi-mmc sdc1: No vd33sw regulator found
      [    2.489212] sunxi-mmc sdc1: No vd18sw regulator found
      [    2.494890] sunxi-mmc sdc1: No vq33sw regulator found
      [    2.500583] sunxi-mmc sdc1: No vq18sw regulator found
      [    2.506270] sunxi-mmc sdc1: Cann't get uart0 pinstate,check if needed
      [    2.513923] sunxi-mmc sdc1: set host busy
      [    2.518506] mmc:failed to get gpios
      [    2.522686] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.533005] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [    2.566970] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.606973] sunxi-mmc sdc1: detmode:manually by software
      [    2.607803] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [    2.613782] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [    2.618972] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.627017] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.637964] sunxi-mmc sdc1: smc 2 p1 err, cmd 8, RTO !!
      [    2.648746] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    2.654628] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    2.660518] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    2.666400] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    2.672289] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
      [    2.678181] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
      [    2.684160] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
      [    2.690147] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
      [    2.690166] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.696125] sunxi-mmc sdc1: smc 2 p1 err, cmd 1, RTO !!
      [    2.696145] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.730678] usbcore: registered new interface driver usbhid
      [    2.737003] usbhid: USB HID core driver
      [    2.742483] [sunxi_hdmi_codec_init] driver and deivce register finished.
      [    2.751076] sun8iw16p1-pinctrl pio: pin PH7 already requested by uart0; cannot claim for dmic
      [    2.760740] sun8iw16p1-pinctrl pio: pin-231 (dmic) status -22
      [    2.767223] sun8iw16p1-pinctrl pio: could not request pin 231 (PH7) from group PH7  on device pio
      [    2.777234] sunxi-dmic dmic: Error applying setting, reverse things back
      [    2.784792] sunxi-dmic: probe of dmic failed with error -22
      [    2.792399] gpio-spk setting ok
      [    2.796395] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
      [    2.805380] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2 DACL Switch -> AIF1 AD0L Mixer
      [    2.817259] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
      [    2.825969] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2 DACR Switch -> AIF1 AD0L Mixer
      [    2.837846] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
      [    2.846555] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2 DACR Switch -> AIF1 AD0R Mixer
      [    2.858420] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
      [    2.867143] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2 DACL Switch -> AIF1 AD0R Mixer
      [    2.879003] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
      [    2.887724] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2 DACL Switch -> AIF1 AD1L Mixer
      [    2.899575] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
      [    2.908296] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2 DACR Switch -> AIF1 AD1R Mixer
      [    2.920180] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
      [    2.928900] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2DACL Switch -> DACL Mixer
      [    2.940168] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
      [    2.948888] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2DACR Switch -> DACR Mixer
      [    2.960832] sunxi-codec-machine sndcodec: codec-aif1 <-> i2s mapping ok
      [    2.970665] sndhdmi sndhdmi: audiohdmi-dai <-> audiohdmi mapping ok
      [    2.978577] sndhdmi sndhdmi: [sunxi_sndhdmi_dev_probe] register card finished.
      [    2.987556] snddmic snddmic: ASoC: CPU DAI (null) not registered
      [    2.994317] snddmic snddmic: snd_soc_register_card() fail: -517
      [    3.001173] snddmic: probe of snddmic failed with error -16
      [    3.007983] NET: Registered protocol family 17
      [    3.013049] 8021q: 802.1Q VLAN Support v1.8
      [    3.018787] sid_get_phy_base()316 - Failed to find "" in dts.
      [    3.025285] sid_get_phy_base()316 - Failed to find "" in dts.
      [    3.032222] sid_get_phy_base()316 - Failed to find "" in dts.
      [    3.039091] sid_efuse_key_is_readable()756 - The key thermal_sensor write protect bit not burned!
      [    3.049174] sid_get_phy_base()316 - Failed to find "" in dts.
      [    3.055996] sid_get_phy_base()316 - Failed to find "" in dts.
      [    3.062817] sid_get_phy_base()316 - Failed to find "" in dts.
      [    3.072045] Registering SWP/SWPB emulation handler
      [    3.079069] HDMI 2.0 driver init start!
      [    3.083389] boot_hdmi=false
      [    3.086793] Get hdmi_power0:vcc18-hdmi
      [    3.092894] HDMI2.0 module init end
      [    3.102294] input: gpiokey as /devices/platform/soc/gpiokey/input/input2
      [    3.110429] sunxi-rtc rtc: setting system clock to 1970-01-01 00:02:23 UTC (143)
      [    3.119543] axp2101_dcdc2: incomplete constraints, leaving on
      [    3.126075] axp2101_dcdc4: incomplete constraints, leaving on
      [    3.132617] axp2101_rtc1: incomplete constraints, leaving on
      [    3.139283] axp2101_aldo3: incomplete constraints, leaving on
      [    3.145944] axp2101_cpuldos: incomplete constraints, leaving on
      [    3.152827] ALSA device list:
      [    3.156159]   #0: audiocodec
      [    3.159404]   #1: sndhdmi
      [    3.164428] EXT4-fs (mmcblk0p7): couldn't mount as ext3 due to feature incompatibilities
      [    3.174043] EXT4-fs (mmcblk0p7): couldn't mount as ext2 due to feature incompatibilities
      [    3.186781] EXT4-fs (mmcblk0p7): warning: mounting fs with errors, running e2fsck is recommended
      [    3.197382] EXT4-fs (mmcblk0p7): recovery complete
      [    3.202780] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
      [    3.211952] VFS: Mounted root (ext4 filesystem) on device 179:7.
      [    3.220702] devtmpfs: mounted
      [    3.224285] Freeing unused kernel memory: 168K
      [    3.229327] This architecture does not have kernel memory protection.
      [    3.238301] EXT4-fs error (device mmcblk0p7): ext4_iget:4567: inode #145: comm swapper/0: bad extra_isize (45842 != 256)
      [    3.250864] Kernel panic - not syncing: Requested init /pseudo_init failed (error -117).
      [    3.259968] CPU1: stopping
      [    3.263013] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.9.118 #772
      [    3.269959] Hardware name: sun8iw16
      [    3.273902] [<c0012501>] (unwind_backtrace) from [<c000ff37>] (show_stack+0xb/0xc)
      [    3.282423] [<c000ff37>] (show_stack) from [<c0136383>] (dump_stack+0x5b/0x70)
      [    3.290551] [<c0136383>] (dump_stack) from [<c0011b21>] (handle_IPI+0x8d/0x104)
      [    3.298774] [<c0011b21>] (handle_IPI) from [<c000930b>] (gic_handle_irq+0x4b/0x54)
      [    3.307291] [<c000930b>] (gic_handle_irq) from [<c00105e5>] (__irq_svc+0x65/0xac)
      [    3.315703] Exception stack(0xd7093f98 to 0xd7093fe0)
      [    3.321381] 3f80:                                                       00000000 0000089e
      [    3.330580] 3fa0: d76ed304 c00161e1 d7092000 c04a8fec 00000002 c04a903c 4000406a 410fc075
      [    3.339779] 3fc0: 00000000 00000000 c04a8d00 d7093fe8 c000deb5 c000deac 40000133 ffffffff
      [    3.348980] [<c00105e5>] (__irq_svc) from [<c000deac>] (arch_cpu_idle+0xc/0x20)
      [    3.357207] [<c000deac>] (arch_cpu_idle) from [<c003d339>] (cpu_startup_entry+0xa1/0xb8)
      [    3.366310] [<c003d339>] (cpu_startup_entry) from [<400094f1>] (0x400094f1)
      [    3.374142] ---[ end Kernel panic - not syncing: Requested init /pseudo_init failed (error -117).
      D 1 条回复 最后回复 回复 引用 分享 0
        文件系统损坏了,重新编译文件系统
          dream LV 6 @inomec 最后由 编辑
          @inomec 强刷呀。找 boot 或者 fel 的按键,按下再复位或者重上电。
