    V853 buildroot系统,SPI通信超时
    9
    6594
    • N
      Negro LV 5 最后由 编辑
      spi从设备是20MHz的频率,CS是低电平有效。dts配置如下:
      &spi3 {
          pinctrl-0 = <&spi3_pins_a &spi3_pins_b>;
          pinctrl-1 = <&spi3_pins_c>;
          spi_slave_mode = <0>;
          spi_dbi_enable = <1>;
          spi_cs_bitmap = <1>;
          spi3_cs_number = <1>;
          spidev@0 {
              device_type = "spidev";
              compatible = "rohm,dh2228fv";
              spi-max-frequency = <100000000>;
              reg = <0x0>;
              spi-cs-high;
              spi-rx-bus-width = <0x8>;
              spi-tx-bus-width = <0x8>;
          spi3_pins_a: spi3@0 {
              allwinner,pins = "PH11", "PH12", "PH13";
              allwinner,pname = "spi3_sclk", "spi3_mosi","spi3_miso";
              allwinner,function = "spi3";
              allwinner,muxsel = <6>;
              allwinner,drive = <1>;
              allwinner,pull = <0>;
          spi3_pins_b: spi3@1 {
              allwinner,pins = "PH14";
              allwinner,pname = "spi3_cs0";
              allwinner,pull = <1>;   // only CS should be pulled up
          spi3_pins_c: spi3@2 {
              allwinner,pins = "PH11", "PH12", "PH13", "PH14";
              allwinner,muxsel = <0xf>;
      测试程序是这样的:
      #include <stdint.h>
      #include <unistd.h>
      #include <stdlib.h>
      #include <getopt.h>
      #include <fcntl.h>
      #include <sys/ioctl.h>
      #include <linux/types.h>
      #include <linux/spi/spidev.h>
      static uint8_t mode = 0; /* SPI通信使用全双工,设置CPOL=0,CPHA=0。 */
      static uint8_t bits = 8; /* 8bits读写,MSB first。*/
      static uint32_t speed = 20 * 1000 * 1000;/* 设置20M传输速度 */
      static uint16_t delay = 0;
      static int g_SPI_Fd = 0;
      unsigned char r_buf[256];
      unsigned char w_buf[256];
      int SPI_Write(uint8_t *TxBuf, int len)
          int ret;
          int fd = g_SPI_Fd;
          ret = write(fd, TxBuf, len);
          if (ret < 0)
              printf("SPI Write error\n");
              int i;
              printf("\nSPI Write [Len:%d]: ", len);
              for (i = 0; i < len; i++)
                  if (i % 8 == 0)
                  printf("\n\t");
                  printf("0x%02X ", TxBuf[i]);
              printf("\n");
          return ret;
      static int SPI_Open(const char* device)
          int fd;
          int ret = 0;
          if (g_SPI_Fd != 0) /* 设备已打开 */
              return 0xF1;
          fd = open(device, O_RDWR);
          if (fd < 0)
              printf("can't open device");
              printf("SPI - Open Succeed. Start Init SPI...\n");
          g_SPI_Fd = fd;
           * spi mode
          ret = ioctl(fd, SPI_IOC_WR_MODE, &mode);
          if (ret == -1)
              printf("can't set spi mode");
            ret = ioctl(fd, SPI_IOC_RD_MODE, &mode);
          if (ret == -1)
              printf("can't get spi mode");
           * bits per word
          ret = ioctl(fd, SPI_IOC_WR_BITS_PER_WORD, &bits);
          if (ret == -1)
              printf("can't set bits per word");
          ret = ioctl(fd, SPI_IOC_RD_BITS_PER_WORD, &bits);
          if (ret == -1)
              printf("can't get bits per word");
           * max speed hz
          ret = ioctl(fd, SPI_IOC_WR_MAX_SPEED_HZ, &speed);
          if (ret == -1)
              printf("can't set max speed hz");
          ret = ioctl(fd, SPI_IOC_RD_MAX_SPEED_HZ, &speed);
          if (ret == -1)
              printf("can't get max speed hz");
          printf("spi mode: %d\n", mode);
          printf("bits per word: %d\n", bits);
          printf("max speed: %d KHz (%d MHz)\n", speed / 1000, speed / 1000 / 1000);
          return ret;
      int SPI_Close(void)
          int fd = g_SPI_Fd;
              if (fd == 0) /* SPI是否已经打开*/
          close(fd);
          g_SPI_Fd = 0;
      int main(int argc, char* argv[])
          char *str="hello";
          int len = 5;
          SPI_Open("/dev/spidev3.0");
          SPI_Write(str, len);
          SPI_Close();
      交叉编译后放到板子上运行,会出现这样的超时报错,想问问看各位有没有什么思路解决,十分感谢。
      root:/root# ./spi
      SPI - Open Succeed. Start Init S[  586.085918] spi_set_clk()459 - set spi clock 100000000, mclk 20000000
      PI...
      [  586.095997] spi_set_clk()459 - set spi clock 100000000, mclk 100000000
      [  586.104382] spi_set_clk()459 - set spi clock 20000000, mclk 100000000
      spi mode: 0[  586.111792] sunxi_spi_transfer_one()1433 - [spi3] begin transfer, txbuf df6ab000, rxbuf   (null), len 5
      bits per word: 8
      max speed: 2[  586.123289] spi_set_clk()459 - set spi clock 20000000, mclk 20000000
      0000 KHz (20 MHz)
      [  586.133363] sunxi_spi_mode_check()1166 - [spi3] Single mode Half duplex tx
      [  586.142730] spi_config_dbi()376 - DBI mode configurate : 40
      [  586.148979] sunxi_spi_xfer()1376 - [spi3] tx -> by ahb
      [  586.155060] sunxi_spi_cpu_writel()1250 - t->len = 5
      [  586.160602] 000: 68 65 6c 6c 6f
      [  596.275684] sunxi_spi_cpu_writel()1276 - [spi3] cpu transfer data time out!
      [  596.283516] sunxi_spi_transfer_one()1462 - [spi3] dump reg:
      [  596.289762] 0x04028000: 00010001 00000098 00002104 00000000
      [  596.296582] 0x04028010: 00000000 00000012 00200020 000f0000
      [  596.303189] 0x04028020: 00000000 00000002 00002000 00000000
      [  596.309535] 0x04028030: 00000005 00000005 00000005 00000000
      [  601.351828] sunxi_spi_transfer_one()1471 - [spi3] xfer timeout
      [  601.358391] spidev spi3.0: SPI transfer failed: -1
      [  601.364475] spi_master spi3: failed to transfer one message from queue
      SPI Write error
      启动时的spi log
      [    0.650370] sunxi_spi_probe()2251 - [spi3] SPI DBI INTERFACE
      [    0.656168] sunxi_spi_probe()2260 - [spi3] SPI MASTER MODE
      [    0.661799] sunxi_spi_resource_get()1909 - Failed to get sample mode
      [    0.668268] sunxi_spi_resource_get()1914 - Failed to get sample delay
      [    0.674824] sunxi_spi_resource_get()1918 - sample_mode:aaaaffff sample_delay:aaaaffff
      [    0.682785] spi3 supply spi not found, using dummy regulator
      [    0.688624] sunxi_spi_request_gpio()1884 - [spi3] Pinctrl init spi3
      [    0.695128] sunxi_spi_clk_init()1955 - [spi3] mclk 100000000
      [    0.701466] spi_master spi3: spi-tx-bus-width 8 not supported
      [    0.707476] spi_master spi3: spi-rx-bus-width 8 not supported
      [    0.713865] sunxi_spi_probe()2340 - [spi3]: driver probe succeed, base e0834000, irq 295
      N 1 条回复 最后回复 回复 引用 分享 2
      • N
        Negro LV 5 最后由 编辑
        想知道DTS里面的这个参数是什么含义呢?
        我是把这个注释掉之后,就正常了。
        • N
          Negro LV 5 @Negro 最后由 编辑
          将spi_dbi_enable = <1> 注释掉就可以了😵
          照着前边的spi节点写的dts,不知道这个是做什么用的。
            chengwei_peng LV 6 @Negro 最后由 编辑
            @negro 这个一般的spi设备去掉就好,di是用来接spi屏的,我们一般的spi设备都不需要开启。
            N M 2 条回复 最后回复 回复 引用 分享 0
            • N
              Negro LV 5 @chengwei_peng 最后由 编辑
              @chengwei_peng
              感谢回复。
              现在这个测试程序是显示可正常发数据了,但是我用示波器量SPI的时钟,发现一直都是低电压,没有方波,MISO,MOSI,CS0三根线都是一只低电平,我甚至是可以echo 235~238 > /sys/class/gpio/export 导出GPIO并控制IO口输出高低电频。这样是正常的吗?虽然设备节/dev/spidev3.0点出来了,但是总感觉好像这几个IO口没有正确配置成SPI接口。
              我用的是buildroot系统。
                @negro 你能正常的读到正确的数据,那么引脚配置肯定没问题的。至于你说的波形问题,倾向于你没有抓到波形。
                而引脚问题,你看看你export后,引脚的功能属性是不是发生变化了。
                N 1 条回复 最后回复 回复 引用 分享 0
                • N
                  @chengwei_peng
                  export后查看引脚属性,依旧是spi3功能没变,我再检查一下是不是我的测波形的方法不对,感谢指导。谢谢
                    mysteryli LV 7 @chengwei_peng 最后由 编辑
                    • F
                      frank LV 3 最后由 编辑
                      来个教程啊来个教程啊
