    D1s 烧录 W25N01 出错,请问是什么问题呢?
    5553
    • U
      uuuuid LV 6 最后由 编辑
      [1258]fes begin commit:88480af-dirty
      [1261]set pll start
      [1263]periph0 has been enabled
      [1266]set pll end
      [1268][pmu]: bus read error
      [1270]board init ok
      [1272]beign to init dram
      [1274]ZQ value = 0x2f
      [1276]get_pmu_exist() = -1
      [1279]ddr_efuse_type: 0xa
      [1281]trefi:7.8ms
      [1284][AUTO DEBUG] single rank and full DQ!
      [1288]ddr_efuse_type: 0xa
      [1290]trefi:7.8ms
      [1292][AUTO DEBUG] rank 0 row = 13
      [1295][AUTO DEBUG] rank 0 bank = 4
      [1299][AUTO DEBUG] rank 0 page size = 2 KB
      [1302]DRAM BOOT DRIVE INFO: V0.33
      [1306]DRAM CLK = 528 MHz
      [1308]DRAM Type = 2 (2:DDR2,3:DDR3)
      [1311]DRAMC read ODT  off.
      [1314]DRAM ODT off.
      [1316]ddr_efuse_type: 0xa
      [1318]DRAM SIZE =64 M
      [1320]dram_tpr4:0x0
      [1322]PLL_DDR_CTRL_REG:0xf8002b00
      [1325]DRAM_CLK_REG:0xc0000000
      [1328][TIMING DEBUG] MR2= 0x0
      [1333]DRAM simple test OK.
      [1335]init dram ok
      U-Boot 2018.05-g24521d6-dirty (Nov 13 2022 - 12:14:17 +0800) Allwinner Technology
      [04.390]DRAM:  64 MiB
      [04.395]Relocation Offset is: 01ee3000
      [04.421]secure enable bit: 0
      [04.427]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [04.434]flash init start
      [04.436]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [04.444][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
      [04.453][mmc]: get sdc_type fail and use default host:tm4.
      [04.486][mmc]: Is not Boot mode!
      [04.489][mmc]: SUNXI SDMMC Controller Version:0x50310
      [04.500][mmc]: ************Try SD card 2************
      [04.505][mmc]: mmc 2 cmd timeout 100 status 100
      [04.509][mmc]: smc 2 err, cmd 8,  RTO
      [04.513][mmc]: mmc 2 close bus gating and reset
      [04.518][mmc]: mmc 2 cmd timeout 100 status 100
      [04.522][mmc]: smc 2 err, cmd 55,  RTO
      [04.526][mmc]: mmc 2 close bus gating and reset
      [04.530][mmc]: ************Try MMC card 2************
      [04.539][mmc]: mmc 2 cmd timeout 100 status 100
      [04.543][mmc]: smc 2 err, cmd 1,  RTO
      [04.546][mmc]: mmc 2 close bus gating and reset
      [04.551][mmc]: Card did not respond to voltage select!
      [04.555][mmc]: ************SD/MMC 2 init error!************
      [04.561][mmc]: mmc init product failed
      MMC init failed
      try emmc fail
      [04.577]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
      [04.583]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
      [04.649]sunxi-spinand-phy: request spi0 gpio ok
      [04.653]sunxi-spinand-phy: request general tx dma channel ok!
      [04.658]sunxi-spinand-phy: request general rx dma channel ok!
      [04.664]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [04.668]sunxi-spinand-phy: init spic0 clk ok
      [04.714]sunxi-spinand-phy: not detect any munufacture from id table
      [04.730]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [04.736]sunxi-spinand-phy: get phy info from fdt fail
      [04.740]sunxi-spinand-phy: not detect munufacture from fdt
      [04.746]sunxi-spinand-phy: detect munufacture from id table: Winbond
      [04.752]sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
      [04.757]sunxi-spinand-phy: ========== arch info ==========
      [04.762]sunxi-spinand-phy: Model:               W25N01GVZEIG
      [04.768]sunxi-spinand-phy: Munufacture:         Winbond
      [04.773]sunxi-spinand-phy: DieCntPerChip:       1
      [04.777]sunxi-spinand-phy: BlkCntPerDie:        1024
      [04.782]sunxi-spinand-phy: PageCntPerBlk:       64
      [04.786]sunxi-spinand-phy: SectCntPerPage:      4
      [04.791]sunxi-spinand-phy: OobSizePerPage:      64
      [04.795]sunxi-spinand-phy: BadBlockFlag:        0x0
      [04.800]sunxi-spinand-phy: OperationOpt:        0x7
      [04.804]sunxi-spinand-phy: MaxEraseTimes:       65000
      [04.809]sunxi-spinand-phy: EccFlag:             0x0
      [04.814]sunxi-spinand-phy: EccType:             2
      [04.818]sunxi-spinand-phy: EccProtectedType:    3
      [04.823]sunxi-spinand-phy: ========================================
      [04.829]sunxi-spinand-phy:
      [04.831]sunxi-spinand-phy: ========== physical info ==========
      [04.837]sunxi-spinand-phy: TotalSize:    128 M
      [04.841]sunxi-spinand-phy: SectorSize:   512 B
      [04.845]sunxi-spinand-phy: PageSize:     2 K
      [04.849]sunxi-spinand-phy: BlockSize:    128 K
      [04.853]sunxi-spinand-phy: OOBSize:      64 B
      [04.857]sunxi-spinand-phy: ========================================
      [04.863]sunxi-spinand-phy:
      [04.866]sunxi-spinand-phy: ========== logical info ==========
      [04.871]sunxi-spinand-phy: TotalSize:    128 M
      [04.875]sunxi-spinand-phy: SectorSize:   512 B
      [04.880]sunxi-spinand-phy: PageSize:     4 K
      [04.884]sunxi-spinand-phy: BlockSize:    256 K
      [04.888]sunxi-spinand-phy: OOBSize:      128 B
      [04.892]sunxi-spinand-phy: ========================================
      [04.908]sunxi-spinand-phy: set spic0 clk to 100 Mhz
      [04.913]sunxi-spinand-phy: block lock register: 0x00
      [04.918]sunxi-spinand-phy: feature register: 0x19
      [04.922]sunxi-spinand-phy: sunxi physic nand init end
      [04.933]Loading Environment from SUNXI_FLASH... OK
      [04.946]try to burn key
      [04.950]out of usb burn from boot: not need burn key
      [04.954]Net:   [04.956]No ethernet found.
      sunxi work mode=0x10
      run usb efex
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x39
      set address 0x39 ok
      set address 0x3b
      set address 0x3b ok
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x12
      origin_erase_flag = 0x1
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      the 0 mbr table is ok
      the 1 mbr table is ok
      the 2 mbr table is ok
      the 3 mbr table is ok
      total mbr part 8
      part[0] classname :DISK
      part[0] addrlo    :0x8000
      part[0] lenlo     :0x800
      part[0] user_type :32768
      part[0] keydata   :0
      part[0] ro        :0
      part[1] name      :env
      part[1] classname :DISK
      part[1] addrlo    :0x8800
      part[1] lenlo     :0x1f8
      part[1] user_type :32768
      part[1] keydata   :0
      part[1] ro        :0
      part[2] name      :env-redund
      part[2] classname :DISK
      part[2] addrlo    :0x89f8
      part[2] lenlo     :0x1f8
      part[2] user_type :32768
      part[2] keydata   :0
      part[2] ro        :0
      part[3] name      :boot
      part[3] classname :DISK
      part[3] addrlo    :0x8bf0
      part[3] lenlo     :0x5000
      part[3] user_type :32768
      part[3] keydata   :0
      part[3] ro        :0
      part[4] name      :rootfs
      part[4] classname :DISK
      part[4] addrlo    :0xdbf0
      part[4] lenlo     :0x103e8
      part[4] user_type :32768
      part[4] keydata   :0
      part[4] ro        :0
      part[5] name      :recovery
      part[5] classname :DISK
      part[5] addrlo    :0x1dfd8
      part[5] lenlo     :0x5780
      part[5] user_type :32768
      part[5] keydata   :0
      part[5] ro        :0
      part[6] classname :DISK
      part[6] addrlo    :0x23758
      part[6] lenlo     :0x78f0
      part[6] user_type :32768
      part[6] keydata   :0
      part[6] ro        :0
      part[7] name      :UDISK
      part[7] classname :DISK
      part[7] addrlo    :0x2b048
      part[7] lenlo     :0x0
      part[7] user_type :0
      part[7] keydata   :0
      part[7] ro        :0
      total part: 9
      mbr 0, 8000, 8000
      boot-resource 1, 800, 8000
      env 2, 1f8, 8000
      env-redund 3, 1f8, 8000
      boot 4, 5000, 8000
      rootfs 5, 103e8, 8000
      recovery 6, 5780, 8000
      rootfs_data 7, 78f0, 8000
      UDISK 8, 0, 0
      [08.296]erase blk 0 to blk 32
      need erase flash: 18
      [08.322]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
      defaults:
      mtdids  : nand0=nand
      [08.382]MTD info (4)
      [08.384]pagesize: 0x1000
      [08.387]blksize: 0x40000
      [08.389]num  offset     bytes      name
      [08.392]0    0x00000000 0x00100000 boot0
      [08.396]1    0x00100000 0x00300000 uboot
      [08.400]2    0x00400000 0x00100000 secure_storage
      [08.404]3    0x00500000 0x07b00000 sys
      [08.408]ubi attach the last part of mtd device: NO.3
      [08.528]ubi0: attaching mtd4
      [08.531]ubi0 warning: scan_peb: bad ec header at pnum 0, drop this block
      [08.537]ubi0 warning: scan_peb: bad ec header at pnum 1, drop this block
      [08.544]ubi0 warning: scan_peb: bad ec header at pnum 2, drop this block
      [08.551]ubi0 warning: scan_peb: bad ec header at pnum 3, drop this block
      [08.557]ubi0 warning: scan_peb: bad ec header at pnum 4, drop this block
      [08.564]ubi0 warning: scan_peb: bad ec header at pnum 5, drop this block
      [08.571]ubi0 warning: scan_peb: bad ec header at pnum 6, drop this block
      [08.577]ubi0 warning: scan_peb: bad ec header at pnum 7, drop this block
      [08.584]ubi0 warning: scan_peb: bad ec header at pnum 8, drop this block
      [08.591]ubi0 warning: scan_peb: bad ec header at pnum 9, drop this block
      [08.597]ubi0 warning: scan_peb: bad ec header at pnum 10, drop this block
      [08.604]ubi0 warning: scan_peb: bad ec header at pnum 11, drop this block
      [08.611]ubi0 warning: scan_peb: bad ec header at pnum 12, drop this block
      [08.618]ubi0 warning: scan_peb: bad ec header at pnum 13, drop this block
      [08.625]ubi0 warning: scan_peb: bad ec header at pnum 14, drop this block
      [08.631]ubi0 warning: scan_peb: bad ec header at pnum 15, drop this block
      [08.638]ubi0 warning: scan_peb: bad ec header at pnum 16, drop this block
      [08.645]ubi0 warning: scan_peb: bad ec header at pnum 17, drop this block
      [08.652]ubi0 warning: scan_peb: bad ec header at pnum 18, drop this block
      [08.659]ubi0 warning: scan_peb: bad ec header at pnum 19, drop this block
      [08.665]ubi0 warning: scan_peb: bad ec header at pnum 20, drop this block
      [08.672]ubi0 warning: scan_peb: bad ec header at pnum 21, drop this block
      [08.679]ubi0 warning: scan_peb: bad ec header at pnum 22, drop this block
      [08.686]ubi0 warning: scan_peb: bad ec header at pnum 23, drop this block
      [08.692]ubi0 warning: scan_peb: bad ec header at pnum 24, drop this block
      [08.699]ubi0 warning: scan_peb: bad ec header at pnum 25, drop this block
      [08.706]ubi0 warning: scan_peb: bad ec header at pnum 26, drop this block
      [08.713]ubi0 warning: scan_peb: bad ec header at pnum 27, drop this block
      [08.720]ubi0 warning: scan_peb: bad ec header at pnum 28, drop this block
      [08.726]ubi0 warning: scan_peb: bad ec header at pnum 29, drop this block
      [08.733]ubi0 warning: scan_peb: bad ec header at pnum 30, drop this block
      [08.740]ubi0 warning: scan_peb: bad ec header at pnum 31, drop this block
      [08.747]ubi0 warning: scan_peb: bad ec header at pnum 32, drop this block
      [08.753]ubi0 warning: scan_peb: bad ec header at pnum 33, drop this block
      [08.760]ubi0 warning: scan_peb: bad ec header at pnum 34, drop this block
      [08.767]ubi0 warning: scan_peb: bad ec header at pnum 35, drop this block
      [08.774]ubi0 warning: scan_peb: bad ec header at pnum 36, drop this block
      [08.781]ubi0 warning: scan_peb: bad ec header at pnum 37, drop this block
      [08.787]ubi0 warning: scan_peb: bad ec header at pnum 38, drop this block
      [08.794]ubi0 warning: scan_peb: bad ec header at pnum 39, drop this block
      [08.801]ubi0 warning: scan_peb: bad ec header at pnum 40, drop this block
      [08.808]ubi0 warning: scan_peb: bad ec header at pnum 41, drop this block
      [08.815]ubi0 warning: scan_peb: bad ec header at pnum 42, drop this block
      [08.821]ubi0 warning: scan_peb: bad ec header at pnum 43, drop this block
      [08.828]ubi0 warning: scan_peb: bad ec header at pnum 44, drop this block
      [08.835]ubi0 warning: scan_peb: bad ec header at pnum 45, drop this block
      [08.842]ubi0 warning: scan_peb: bad ec header at pnum 46, drop this block
      [08.848]ubi0 warning: scan_peb: bad ec header at pnum 47, drop this block
      [08.855]ubi0 warning: scan_peb: bad ec header at pnum 48, drop this block
      [08.862]ubi0 warning: scan_peb: bad ec header at pnum 49, drop this block
      [08.869]ubi0 warning: scan_peb: bad ec header at pnum 50, drop this block
      [08.876]ubi0 warning: scan_peb: bad ec header at pnum 51, drop this block
      [08.882]ubi0 warning: scan_peb: bad ec header at pnum 52, drop this block
      [08.889]ubi0 warning: scan_peb: bad ec header at pnum 53, drop this block
      [08.896]ubi0 warning: scan_peb: bad ec header at pnum 54, drop this block
      [08.903]ubi0 warning: scan_peb: bad ec header at pnum 55, drop this block
      [08.910]ubi0 warning: scan_peb: bad ec header at pnum 56, drop this block
      [08.916]ubi0 warning: scan_peb: bad ec header at pnum 57, drop this block
      [08.923]ubi0 warning: scan_peb: bad ec header at pnum 58, drop this block
      [08.930]ubi0 warning: scan_peb: bad ec header at pnum 59, drop this block
      [08.937]ubi0 warning: scan_peb: bad ec header at pnum 60, drop this block
      [08.943]ubi0 warning: scan_peb: bad ec header at pnum 61, drop this block
      [08.950]ubi0 warning: scan_peb: bad ec header at pnum 62, drop this block
      [08.957]ubi0 warning: scan_peb: bad ec header at pnum 63, drop this block
      [08.964]ubi0 warning: scan_peb: bad ec header at pnum 64, drop this block
      [08.971]ubi0 warning: scan_peb: bad ec header at pnum 65, drop this block
      [08.977]ubi0 warning: scan_peb: bad ec header at pnum 66, drop this block
      [08.984]ubi0 warning: scan_peb: bad ec header at pnum 67, drop this block
      [08.991]ubi0 warning: scan_peb: bad ec header at pnum 68, drop this block
      [08.998]ubi0 warning: scan_peb: bad ec header at pnum 69, drop this block
      [09.004]ubi0 warning: scan_peb: bad ec header at pnum 70, drop this block
      [09.011]ubi0 warning: scan_peb: bad ec header at pnum 71, drop this block
      [09.018]ubi0 warning: scan_peb: bad ec header at pnum 72, drop this block
      [09.025]ubi0 warning: scan_peb: bad ec header at pnum 73, drop this block
      [09.032]ubi0 warning: scan_peb: bad ec header at pnum 74, drop this block
      [09.038]ubi0 warning: scan_peb: bad ec header at pnum 75, drop this block
      [09.045]ubi0 warning: scan_peb: bad ec header at pnum 76, drop this block
      [09.052]ubi0 warning: scan_peb: bad ec header at pnum 77, drop this block
      [09.059]ubi0 warning: scan_peb: bad ec header at pnum 78, drop this block
      [09.066]ubi0 warning: scan_peb: bad ec header at pnum 79, drop this block
      [09.072]ubi0 warning: scan_peb: bad ec header at pnum 80, drop this block
      [09.079]ubi0 warning: scan_peb: bad ec header at pnum 81, drop this block
      [09.086]ubi0 warning: scan_peb: bad ec header at pnum 82, drop this block
      [09.093]ubi0 warning: scan_peb: bad ec header at pnum 83, drop this block
      [09.099]ubi0 warning: scan_peb: bad ec header at pnum 84, drop this block
      [09.106]ubi0 warning: scan_peb: bad ec header at pnum 85, drop this block
      [09.113]ubi0 warning: scan_peb: bad ec header at pnum 86, drop this block
      [09.120]ubi0 warning: scan_peb: bad ec header at pnum 87, drop this block
      [09.127]ubi0 warning: scan_peb: bad ec header at pnum 88, drop this block
      [09.133]ubi0 warning: scan_peb: bad ec header at pnum 89, drop this block
      [09.140]ubi0 warning: scan_peb: bad ec header at pnum 90, drop this block
      [09.147]ubi0 warning: scan_peb: bad ec header at pnum 91, drop this block
      [09.154]ubi0 warning: scan_peb: bad ec header at pnum 92, drop this block
      [09.160]ubi0 warning: scan_peb: bad ec header at pnum 93, drop this block
      [09.167]ubi0 warning: scan_peb: bad ec header at pnum 94, drop this block
      [09.174]ubi0 warning: scan_peb: bad ec header at pnum 95, drop this block
      [09.181]ubi0 warning: scan_peb: bad ec header at pnum 96, drop this block
      [09.188]ubi0 warning: scan_peb: bad ec header at pnum 97, drop this block
      [09.194]ubi0 warning: scan_peb: bad ec header at pnum 98, drop this block
      [09.201]ubi0 warning: scan_peb: bad ec header at pnum 99, drop this block
      [09.208]ubi0 warning: scan_peb: bad ec header at pnum 100, drop this block
      [09.215]ubi0 warning: scan_peb: bad ec header at pnum 101, drop this block
      [09.222]ubi0 warning: scan_peb: bad ec header at pnum 102, drop this block
      [09.229]ubi0 warning: scan_peb: bad ec header at pnum 103, drop this block
      [09.235]ubi0 warning: scan_peb: bad ec header at pnum 104, drop this block
      [09.242]ubi0 warning: scan_peb: bad ec header at pnum 105, drop this block
      [09.249]ubi0 warning: scan_peb: bad ec header at pnum 106, drop this block
      [09.256]ubi0 warning: scan_peb: bad ec header at pnum 107, drop this block
      [09.263]ubi0 warning: scan_peb: bad ec header at pnum 108, drop this block
      [09.270]ubi0 warning: scan_peb: bad ec header at pnum 109, drop this block
      [09.277]ubi0 warning: scan_peb: bad ec header at pnum 110, drop this block
      [09.284]ubi0 warning: scan_peb: bad ec header at pnum 111, drop this block
      [09.290]ubi0 warning: scan_peb: bad ec header at pnum 112, drop this block
      [09.297]ubi0 warning: scan_peb: bad ec header at pnum 113, drop this block
      [09.304]ubi0 warning: scan_peb: bad ec header at pnum 114, drop this block
      [09.311]ubi0 warning: scan_peb: bad ec header at pnum 115, drop this block
      [09.318]ubi0 warning: scan_peb: bad ec header at pnum 116, drop this block
      [09.325]ubi0 warning: scan_peb: bad ec header at pnum 117, drop this block
      [09.332]ubi0 warning: scan_peb: bad ec header at pnum 118, drop this block
      [09.338]ubi0 warning: scan_peb: bad ec header at pnum 119, drop this block
      [09.345]ubi0 warning: scan_peb: bad ec header at pnum 120, drop this block
      [09.352]ubi0 warning: scan_peb: bad ec header at pnum 121, drop this block
      [09.359]ubi0 warning: scan_peb: bad ec header at pnum 122, drop this block
      [09.366]ubi0 warning: scan_peb: bad ec header at pnum 123, drop this block
      [09.373]ubi0 warning: scan_peb: bad ec header at pnum 124, drop this block
      [09.380]ubi0 warning: scan_peb: bad ec header at pnum 125, drop this block
      [09.387]ubi0 warning: scan_peb: bad ec header at pnum 126, drop this block
      [09.393]ubi0 warning: scan_peb: bad ec header at pnum 127, drop this block
      [09.400]ubi0 warning: scan_peb: bad ec header at pnum 128, drop this block
      [09.407]ubi0 warning: scan_peb: bad ec header at pnum 129, drop this block
      [09.414]ubi0 warning: scan_peb: bad ec header at pnum 130, drop this block
      [09.421]ubi0 warning: scan_peb: bad ec header at pnum 131, drop this block
      [09.428]ubi0 warning: scan_peb: bad ec header at pnum 132, drop this block
      [09.435]ubi0 warning: scan_peb: bad ec header at pnum 133, drop this block
      [09.442]ubi0 warning: scan_peb: bad ec header at pnum 134, drop this block
      [09.448]ubi0 warning: scan_peb: bad ec header at pnum 135, drop this block
      [09.455]ubi0 warning: scan_peb: bad ec header at pnum 136, drop this block
      [09.462]ubi0 warning: scan_peb: bad ec header at pnum 137, drop this block
      [09.469]ubi0 warning: scan_peb: bad ec header at pnum 138, drop this block
      [09.476]ubi0 warning: scan_peb: bad ec header at pnum 139, drop this block
      [09.483]ubi0 warning: scan_peb: bad ec header at pnum 140, drop this block
      [09.490]ubi0 warning: scan_peb: bad ec header at pnum 141, drop this block
      [09.496]ubi0 warning: scan_peb: bad ec header at pnum 142, drop this block
      [09.503]ubi0 warning: scan_peb: bad ec header at pnum 143, drop this block
      [09.510]ubi0 warning: scan_peb: bad ec header at pnum 144, drop this block
      [09.517]ubi0 warning: scan_peb: bad ec header at pnum 145, drop this block
      [09.524]ubi0 warning: scan_peb: bad ec header at pnum 146, drop this block
      [09.531]ubi0 warning: scan_peb: bad ec header at pnum 147, drop this block
      [09.538]ubi0 warning: scan_peb: bad ec header at pnum 148, drop this block
      [09.545]ubi0 warning: scan_peb: bad ec header at pnum 149, drop this block
      [09.551]ubi0 warning: scan_peb: bad ec header at pnum 150, drop this block
      [09.558]ubi0 warning: scan_peb: bad ec header at pnum 151, drop this block
      [09.565]ubi0 warning: scan_peb: bad ec header at pnum 152, drop this block
      [09.572]ubi0 warning: scan_peb: bad ec header at pnum 153, drop this block
      [09.579]ubi0 warning: scan_peb: bad ec header at pnum 154, drop this block
      [09.586]ubi0 warning: scan_peb: bad ec header at pnum 155, drop this block
      [09.593]ubi0 warning: scan_peb: bad ec header at pnum 156, drop this block
      [09.600]ubi0 warning: scan_peb: bad ec header at pnum 157, drop this block
      [09.606]ubi0 warning: scan_peb: bad ec header at pnum 158, drop this block
      [09.613]ubi0 warning: scan_peb: bad ec header at pnum 159, drop this block
      [09.620]ubi0 warning: scan_peb: bad ec header at pnum 160, drop this block
      [09.627]ubi0 warning: scan_peb: bad ec header at pnum 161, drop this block
      [09.634]ubi0 warning: scan_peb: bad ec header at pnum 162, drop this block
      [09.641]ubi0 warning: scan_peb: bad ec header at pnum 163, drop this block
      [09.648]ubi0 warning: scan_peb: bad ec header at pnum 164, drop this block
      [09.654]ubi0 warning: scan_peb: bad ec header at pnum 165, drop this block
      [09.661]ubi0 warning: scan_peb: bad ec header at pnum 166, drop this block
      [09.668]ubi0 warning: scan_peb: bad ec header at pnum 167, drop this block
      [09.675]ubi0 warning: scan_peb: bad ec header at pnum 168, drop this block
      [09.682]ubi0 warning: scan_peb: bad ec header at pnum 169, drop this block
      [09.689]ubi0 warning: scan_peb: bad ec header at pnum 170, drop this block
      [09.696]ubi0 warning: scan_peb: bad ec header at pnum 171, drop this block
      [09.703]ubi0 warning: scan_peb: bad ec header at pnum 172, drop this block
      [09.709]ubi0 warning: scan_peb: bad ec header at pnum 173, drop this block
      [09.716]ubi0 warning: scan_peb: bad ec header at pnum 174, drop this block
      [09.723]ubi0 warning: scan_peb: bad ec header at pnum 175, drop this block
      [09.730]ubi0 warning: scan_peb: bad ec header at pnum 176, drop this block
      [09.737]ubi0 warning: scan_peb: bad ec header at pnum 177, drop this block
      [09.744]ubi0 warning: scan_peb: bad ec header at pnum 178, drop this block
      [09.751]ubi0 warning: scan_peb: bad ec header at pnum 179, drop this block
      [09.758]ubi0 warning: scan_peb: bad ec header at pnum 180, drop this block
      [09.764]ubi0 warning: scan_peb: bad ec header at pnum 181, drop this block
      [09.771]ubi0 warning: scan_peb: bad ec header at pnum 182, drop this block
      [09.778]ubi0 warning: scan_peb: bad ec header at pnum 183, drop this block
      [09.785]ubi0 warning: scan_peb: bad ec header at pnum 184, drop this block
      [09.792]ubi0 warning: scan_peb: bad ec header at pnum 185, drop this block
      [09.799]ubi0 warning: scan_peb: bad ec header at pnum 186, drop this block
      [09.806]ubi0 warning: scan_peb: bad ec header at pnum 187, drop this block
      [09.812]ubi0 warning: scan_peb: bad ec header at pnum 188, drop this block
      [09.819]ubi0 warning: scan_peb: bad ec header at pnum 189, drop this block
      [09.826]ubi0 warning: scan_peb: bad ec header at pnum 190, drop this block
      [09.833]ubi0 warning: scan_peb: bad ec header at pnum 191, drop this block
      [09.840]ubi0 warning: scan_peb: bad ec header at pnum 192, drop this block
      [09.847]ubi0 warning: scan_peb: bad ec header at pnum 193, drop this block
      [09.854]ubi0 warning: scan_peb: bad ec header at pnum 194, drop this block
      [09.861]ubi0 warning: scan_peb: bad ec header at pnum 195, drop this block
      [09.867]ubi0 warning: scan_peb: bad ec header at pnum 196, drop this block
      [09.874]ubi0 warning: scan_peb: bad ec header at pnum 197, drop this block
      [09.881]ubi0 warning: scan_peb: bad ec header at pnum 198, drop this block
      [09.888]ubi0 warning: scan_peb: bad ec header at pnum 199, drop this block
      [09.895]ubi0 warning: scan_peb: bad ec header at pnum 200, drop this block
      [09.902]ubi0 warning: scan_peb: bad ec header at pnum 201, drop this block
      [09.909]ubi0 warning: scan_peb: bad ec header at pnum 202, drop this block
      [09.916]ubi0 warning: scan_peb: bad ec header at pnum 203, drop this block
      [09.922]ubi0 warning: scan_peb: bad ec header at pnum 204, drop this block
      [09.929]ubi0 warning: scan_peb: bad ec header at pnum 205, drop this block
      [09.936]ubi0 warning: scan_peb: bad ec header at pnum 206, drop this block
      [09.943]ubi0 warning: scan_peb: bad ec header at pnum 207, drop this block
      [09.950]ubi0 warning: scan_peb: bad ec header at pnum 208, drop this block
      [09.957]ubi0 warning: scan_peb: bad ec header at pnum 209, drop this block
      [09.964]ubi0 warning: scan_peb: bad ec header at pnum 210, drop this block
      [09.971]ubi0 warning: scan_peb: bad ec header at pnum 211, drop this block
      [09.977]ubi0 warning: scan_peb: bad ec header at pnum 212, drop this block
      [09.984]ubi0 warning: scan_peb: bad ec header at pnum 213, drop this block
      [09.991]ubi0 warning: scan_peb: bad ec header at pnum 214, drop this block
      [09.998]ubi0 warning: scan_peb: bad ec header at pnum 215, drop this block
      [10.005]ubi0 warning: scan_peb: bad ec header at pnum 216, drop this block
      [10.012]ubi0 warning: scan_peb: bad ec header at pnum 217, drop this block
      [10.019]ubi0 warning: scan_peb: bad ec header at pnum 218, drop this block
      [10.025]ubi0 warning: scan_peb: bad ec header at pnum 219, drop this block
      [10.032]ubi0 warning: scan_peb: bad ec header at pnum 220, drop this block
      [10.039]ubi0 warning: scan_peb: bad ec header at pnum 221, drop this block
      [10.046]ubi0 warning: scan_peb: bad ec header at pnum 222, drop this block
      [10.053]ubi0 warning: scan_peb: bad ec header at pnum 223, drop this block
      [10.060]ubi0 warning: scan_peb: bad ec header at pnum 224, drop this block
      [10.067]ubi0 warning: scan_peb: bad ec header at pnum 225, drop this block
      [10.074]ubi0 warning: scan_peb: bad ec header at pnum 226, drop this block
      [10.080]ubi0 warning: scan_peb: bad ec header at pnum 227, drop this block
      [10.087]ubi0 warning: scan_peb: bad ec header at pnum 228, drop this block
      [10.094]ubi0 warning: scan_peb: bad ec header at pnum 229, drop this block
      [10.101]ubi0 warning: scan_peb: bad ec header at pnum 230, drop this block
      [10.108]ubi0 warning: scan_peb: bad ec header at pnum 231, drop this block
      [10.115]ubi0 warning: scan_peb: bad ec header at pnum 232, drop this block
      [10.122]ubi0 warning: scan_peb: bad ec header at pnum 233, drop this block
      [10.129]ubi0 warning: scan_peb: bad ec header at pnum 234, drop this block
      [10.135]ubi0 warning: scan_peb: bad ec header at pnum 235, drop this block
      [10.142]ubi0 warning: scan_peb: bad ec header at pnum 236, drop this block
      [10.149]ubi0 warning: scan_peb: bad ec header at pnum 237, drop this block
      [10.156]ubi0 warning: scan_peb: bad ec header at pnum 238, drop this block
      [10.163]ubi0 warning: scan_peb: bad ec header at pnum 239, drop this block
      [10.170]ubi0 warning: scan_peb: bad ec header at pnum 240, drop this block
      [10.177]ubi0 warning: scan_peb: bad ec header at pnum 241, drop this block
      [10.183]ubi0 warning: scan_peb: bad ec header at pnum 242, drop this block
      [10.190]ubi0 warning: scan_peb: bad ec header at pnum 243, drop this block
      [10.197]ubi0 warning: scan_peb: bad ec header at pnum 244, drop this block
      [10.204]ubi0 warning: scan_peb: bad ec header at pnum 245, drop this block
      [10.211]ubi0 warning: scan_peb: bad ec header at pnum 246, drop this block
      [10.218]ubi0 warning: scan_peb: bad ec header at pnum 247, drop this block
      [10.225]ubi0 warning: scan_peb: bad ec header at pnum 248, drop this block
      [10.232]ubi0 warning: scan_peb: bad ec header at pnum 249, drop this block
      [10.238]ubi0 warning: scan_peb: bad ec header at pnum 250, drop this block
      [10.245]ubi0 warning: scan_peb: bad ec header at pnum 251, drop this block
      [10.252]ubi0 warning: scan_peb: bad ec header at pnum 252, drop this block
      [10.259]ubi0 warning: scan_peb: bad ec header at pnum 253, drop this block
      [10.266]ubi0 warning: scan_peb: bad ec header at pnum 254, drop this block
      [10.273]ubi0 warning: scan_peb: bad ec header at pnum 255, drop this block
      [10.280]ubi0 warning: scan_peb: bad ec header at pnum 256, drop this block
      [10.287]ubi0 warning: scan_peb: bad ec header at pnum 257, drop this block
      [10.293]ubi0 warning: scan_peb: bad ec header at pnum 258, drop this block
      [10.300]ubi0 warning: scan_peb: bad ec header at pnum 259, drop this block
      [10.307]ubi0 warning: scan_peb: bad ec header at pnum 260, drop this block
      [10.314]ubi0 warning: scan_peb: bad ec header at pnum 261, drop this block
      [10.321]ubi0 warning: scan_peb: bad ec header at pnum 262, drop this block
      [10.328]ubi0 warning: scan_peb: bad ec header at pnum 263, drop this block
      [10.335]ubi0 warning: scan_peb: bad ec header at pnum 264, drop this block
      [10.342]ubi0 warning: scan_peb: bad ec header at pnum 265, drop this block
      [10.348]ubi0 warning: scan_peb: bad ec header at pnum 266, drop this block
      [10.355]ubi0 warning: scan_peb: bad ec header at pnum 267, drop this block
      [10.362]ubi0 warning: scan_peb: bad ec header at pnum 268, drop this block
      [10.369]ubi0 warning: scan_peb: bad ec header at pnum 269, drop this block
      [10.376]ubi0 warning: scan_peb: bad ec header at pnum 270, drop this block
      [10.383]ubi0 warning: scan_peb: bad ec header at pnum 271, drop this block
      [10.390]ubi0 warning: scan_peb: bad ec header at pnum 272, drop this block
      [10.396]ubi0 warning: scan_peb: bad ec header at pnum 273, drop this block
      [10.403]ubi0 warning: scan_peb: bad ec header at pnum 274, drop this block
      [10.410]ubi0 warning: scan_peb: bad ec header at pnum 275, drop this block
      [10.417]ubi0 warning: scan_peb: bad ec header at pnum 276, drop this block
      [10.424]ubi0 warning: scan_peb: bad ec header at pnum 277, drop this block
      [10.431]ubi0 warning: scan_peb: bad ec header at pnum 278, drop this block
      [10.438]ubi0 warning: scan_peb: bad ec header at pnum 279, drop this block
      [10.445]ubi0 warning: scan_peb: bad ec header at pnum 280, drop this block
      [10.451]ubi0 warning: scan_peb: bad ec header at pnum 281, drop this block
      [10.458]ubi0 warning: scan_peb: bad ec header at pnum 282, drop this block
      [10.465]ubi0 warning: scan_peb: bad ec header at pnum 283, drop this block
      [10.472]ubi0 warning: scan_peb: bad ec header at pnum 284, drop this block
      [10.479]ubi0 warning: scan_peb: bad ec header at pnum 285, drop this block
      [10.486]ubi0 warning: scan_peb: bad ec header at pnum 286, drop this block
      [10.493]ubi0 warning: scan_peb: bad ec header at pnum 287, drop this block
      [10.500]ubi0 warning: scan_peb: bad ec header at pnum 288, drop this block
      [10.506]ubi0 warning: scan_peb: bad ec header at pnum 289, drop this block
      [10.513]ubi0 warning: scan_peb: bad ec header at pnum 290, drop this block
      [10.520]ubi0 warning: scan_peb: bad ec header at pnum 291, drop this block
      [10.527]ubi0 warning: scan_peb: bad ec header at pnum 292, drop this block
      [10.534]ubi0 warning: scan_peb: bad ec header at pnum 293, drop this block
      [10.541]ubi0 warning: scan_peb: bad ec header at pnum 294, drop this block
      [10.548]ubi0 warning: scan_peb: bad ec header at pnum 295, drop this block
      [10.554]ubi0 warning: scan_peb: bad ec header at pnum 296, drop this block
      [10.561]ubi0 warning: scan_peb: bad ec header at pnum 297, drop this block
      [10.568]ubi0 warning: scan_peb: bad ec header at pnum 298, drop this block
      [10.575]ubi0 warning: scan_peb: bad ec header at pnum 299, drop this block
      [10.582]ubi0 warning: scan_peb: bad ec header at pnum 300, drop this block
      [10.589]ubi0 warning: scan_peb: bad ec header at pnum 301, drop this block
      [10.596]ubi0 warning: scan_peb: bad ec header at pnum 302, drop this block
      [10.603]ubi0 warning: scan_peb: bad ec header at pnum 303, drop this block
      [10.609]ubi0 warning: scan_peb: bad ec header at pnum 304, drop this block
      [10.616]ubi0 warning: scan_peb: bad ec header at pnum 305, drop this block
      [10.623]ubi0 warning: scan_peb: bad ec header at pnum 306, drop this block
      [10.630]ubi0 warning: scan_peb: bad ec header at pnum 307, drop this block
      [10.637]ubi0 warning: scan_peb: bad ec header at pnum 308, drop this block
      [10.644]ubi0 warning: scan_peb: bad ec header at pnum 309, drop this block
      [10.651]ubi0 warning: scan_peb: bad ec header at pnum 310, drop this block
      [10.658]ubi0 warning: scan_peb: bad ec header at pnum 311, drop this block
      [10.664]ubi0 warning: scan_peb: bad ec header at pnum 312, drop this block
      [10.671]ubi0 warning: scan_peb: bad ec header at pnum 313, drop this block
      [10.678]ubi0 warning: scan_peb: bad ec header at pnum 314, drop this block
      [10.685]ubi0 warning: scan_peb: bad ec header at pnum 315, drop this block
      [10.692]ubi0 warning: scan_peb: bad ec header at pnum 316, drop this block
      [10.699]ubi0 warning: scan_peb: bad ec header at pnum 317, drop this block
      [10.706]ubi0 warning: scan_peb: bad ec header at pnum 318, drop this block
      [10.713]ubi0 warning: scan_peb: bad ec header at pnum 319, drop this block
      [10.719]ubi0 warning: scan_peb: bad ec header at pnum 320, drop this block
      [10.726]ubi0 warning: scan_peb: bad ec header at pnum 321, drop this block
      [10.733]ubi0 warning: scan_peb: bad ec header at pnum 322, drop this block
      [10.740]ubi0 warning: scan_peb: bad ec header at pnum 323, drop this block
      [10.747]ubi0 warning: scan_peb: bad ec header at pnum 324, drop this block
      [10.754]ubi0 warning: scan_peb: bad ec header at pnum 325, drop this block
      [10.761]ubi0 warning: scan_peb: bad ec header at pnum 326, drop this block
      [10.767]ubi0 warning: scan_peb: bad ec header at pnum 327, drop this block
      [10.774]ubi0 warning: scan_peb: bad ec header at pnum 328, drop this block
      [10.781]ubi0 warning: scan_peb: bad ec header at pnum 329, drop this block
      [10.788]ubi0 warning: scan_peb: bad ec header at pnum 330, drop this block
      [10.795]ubi0 warning: scan_peb: bad ec header at pnum 331, drop this block
      [10.802]ubi0 warning: scan_peb: bad ec header at pnum 332, drop this block
      [10.809]ubi0 warning: scan_peb: bad ec header at pnum 333, drop this block
      [10.816]ubi0 warning: scan_peb: bad ec header at pnum 334, drop this block
      [10.822]ubi0 warning: scan_peb: bad ec header at pnum 335, drop this block
      [10.829]ubi0 warning: scan_peb: bad ec header at pnum 336, drop this block
      [10.836]ubi0 warning: scan_peb: bad ec header at pnum 337, drop this block
      [10.843]ubi0 warning: scan_peb: bad ec header at pnum 338, drop this block
      [10.850]ubi0 warning: scan_peb: bad ec header at pnum 339, drop this block
      [10.857]ubi0 warning: scan_peb: bad ec header at pnum 340, drop this block
      [10.864]ubi0 warning: scan_peb: bad ec header at pnum 341, drop this block
      [10.871]ubi0 warning: scan_peb: bad ec header at pnum 342, drop this block
      [10.877]ubi0 warning: scan_peb: bad ec header at pnum 343, drop this block
      [10.884]ubi0 warning: scan_peb: bad ec header at pnum 344, drop this block
      [10.891]ubi0 warning: scan_peb: bad ec header at pnum 345, drop this block
      [10.898]ubi0 warning: scan_peb: bad ec header at pnum 346, drop this block
      [10.905]ubi0 warning: scan_peb: bad ec header at pnum 347, drop this block
      [10.912]ubi0 warning: scan_peb: bad ec header at pnum 348, drop this block
      [10.919]ubi0 warning: scan_peb: bad ec header at pnum 349, drop this block
      [10.925]ubi0 warning: scan_peb: bad ec header at pnum 350, drop this block
      [10.932]ubi0 warning: scan_peb: bad ec header at pnum 351, drop this block
      [10.939]ubi0 warning: scan_peb: bad ec header at pnum 352, drop this block
      [10.946]ubi0 warning: scan_peb: bad ec header at pnum 353, drop this block
      [10.953]ubi0 warning: scan_peb: bad ec header at pnum 354, drop this block
      [10.960]ubi0 warning: scan_peb: bad ec header at pnum 355, drop this block
      [10.967]ubi0 warning: scan_peb: bad ec header at pnum 356, drop this block
      [10.974]ubi0 warning: scan_peb: bad ec header at pnum 357, drop this block
      [10.980]ubi0 warning: scan_peb: bad ec header at pnum 358, drop this block
      [10.987]ubi0 warning: scan_peb: bad ec header at pnum 359, drop this block
      [10.994]ubi0 warning: scan_peb: bad ec header at pnum 360, drop this block
      [11.001]ubi0 warning: scan_peb: bad ec header at pnum 361, drop this block
      [11.008]ubi0 warning: scan_peb: bad ec header at pnum 362, drop this block
      [11.015]ubi0 warning: scan_peb: bad ec header at pnum 363, drop this block
      [11.022]ubi0 warning: scan_peb: bad ec header at pnum 364, drop this block
      [11.029]ubi0 warning: scan_peb: bad ec header at pnum 365, drop this block
      [11.035]ubi0 warning: scan_peb: bad ec header at pnum 366, drop this block
      [11.042]ubi0 warning: scan_peb: bad ec header at pnum 367, drop this block
      [11.049]ubi0 warning: scan_peb: bad ec header at pnum 368, drop this block
      [11.056]ubi0 warning: scan_peb: bad ec header at pnum 369, drop this block
      [11.063]ubi0 warning: scan_peb: bad ec header at pnum 370, drop this block
      [11.070]ubi0 warning: scan_peb: bad ec header at pnum 371, drop this block
      [11.077]ubi0 warning: scan_peb: bad ec header at pnum 372, drop this block
      [11.084]ubi0 warning: scan_peb: bad ec header at pnum 373, drop this block
      [11.090]ubi0 warning: scan_peb: bad ec header at pnum 374, drop this block
      [11.097]ubi0 warning: scan_peb: bad ec header at pnum 375, drop this block
      [11.104]ubi0 warning: scan_peb: bad ec header at pnum 376, drop this block
      [11.111]ubi0 warning: scan_peb: bad ec header at pnum 377, drop this block
      [11.118]ubi0 warning: scan_peb: bad ec header at pnum 378, drop this block
      [11.125]ubi0 warning: scan_peb: bad ec header at pnum 379, drop this block
      [11.132]ubi0 warning: scan_peb: bad ec header at pnum 380, drop this block
      [11.138]ubi0 warning: scan_peb: bad ec header at pnum 381, drop this block
      [11.145]ubi0 warning: scan_peb: bad ec header at pnum 382, drop this block
      [11.152]ubi0 warning: scan_peb: bad ec header at pnum 383, drop this block
      [11.159]ubi0 warning: scan_peb: bad ec header at pnum 384, drop this block
      [11.166]ubi0 warning: scan_peb: bad ec header at pnum 385, drop this block
      [11.173]ubi0 warning: scan_peb: bad ec header at pnum 386, drop this block
      [11.180]ubi0 warning: scan_peb: bad ec header at pnum 387, drop this block
      [11.187]ubi0 warning: scan_peb: bad ec header at pnum 388, drop this block
      [11.193]ubi0 warning: scan_peb: bad ec header at pnum 389, drop this block
      [11.200]ubi0 warning: scan_peb: bad ec header at pnum 390, drop this block
      [11.207]ubi0 warning: scan_peb: bad ec header at pnum 391, drop this block
      [11.214]ubi0 warning: scan_peb: bad ec header at pnum 392, drop this block
      [11.221]ubi0 warning: scan_peb: bad ec header at pnum 393, drop this block
      [11.228]ubi0 warning: scan_peb: bad ec header at pnum 394, drop this block
      [11.235]ubi0 warning: scan_peb: bad ec header at pnum 395, drop this block
      [11.242]ubi0 warning: scan_peb: bad ec header at pnum 396, drop this block
      [11.248]ubi0 warning: scan_peb: bad ec header at pnum 397, drop this block
      [11.255]ubi0 warning: scan_peb: bad ec header at pnum 398, drop this block
      [11.262]ubi0 warning: scan_peb: bad ec header at pnum 399, drop this block
      [11.269]ubi0 warning: scan_peb: bad ec header at pnum 400, drop this block
      [11.276]ubi0 warning: scan_peb: bad ec header at pnum 401, drop this block
      [11.283]ubi0 warning: scan_peb: bad ec header at pnum 402, drop this block
      [11.290]ubi0 warning: scan_peb: bad ec header at pnum 403, drop this block
      [11.296]ubi0 warning: scan_peb: bad ec header at pnum 404, drop this block
      [11.303]ubi0 warning: scan_peb: bad ec header at pnum 405, drop this block
      [11.310]ubi0 warning: scan_peb: bad ec header at pnum 406, drop this block
      [11.317]ubi0 warning: scan_peb: bad ec header at pnum 407, drop this block
      [11.324]ubi0 warning: scan_peb: bad ec header at pnum 408, drop this block
      [11.331]ubi0 warning: scan_peb: bad ec header at pnum 409, drop this block
      [11.338]ubi0 warning: scan_peb: bad ec header at pnum 410, drop this block
      [11.345]ubi0 warning: scan_peb: bad ec header at pnum 411, drop this block
      [11.351]ubi0 warning: scan_peb: bad ec header at pnum 412, drop this block
      [11.358]ubi0 warning: scan_peb: bad ec header at pnum 413, drop this block
      [11.365]ubi0 warning: scan_peb: bad ec header at pnum 414, drop this block
      [11.372]ubi0 warning: scan_peb: bad ec header at pnum 415, drop this block
      [11.379]ubi0 warning: scan_peb: bad ec header at pnum 416, drop this block
      [11.386]ubi0 warning: scan_peb: bad ec header at pnum 417, drop this block
      [11.393]ubi0 warning: scan_peb: bad ec header at pnum 418, drop this block
      [11.400]ubi0 warning: scan_peb: bad ec header at pnum 419, drop this block
      [11.406]ubi0 warning: scan_peb: bad ec header at pnum 420, drop this block
      [11.413]ubi0 warning: scan_peb: bad ec header at pnum 421, drop this block
      [11.420]ubi0 warning: scan_peb: bad ec header at pnum 422, drop this block
      [11.427]ubi0 warning: scan_peb: bad ec header at pnum 423, drop this block
      [11.434]ubi0 warning: scan_peb: bad ec header at pnum 424, drop this block
      [11.441]ubi0 warning: scan_peb: bad ec header at pnum 425, drop this block
      [11.448]ubi0 warning: scan_peb: bad ec header at pnum 426, drop this block
      [11.454]ubi0 warning: scan_peb: bad ec header at pnum 427, drop this block
      [11.461]ubi0 warning: scan_peb: bad ec header at pnum 428, drop this block
      [11.468]ubi0 warning: scan_peb: bad ec header at pnum 429, drop this block
      [11.475]ubi0 warning: scan_peb: bad ec header at pnum 430, drop this block
      [11.482]ubi0 warning: scan_peb: bad ec header at pnum 431, drop this block
      [11.489]ubi0 warning: scan_peb: bad ec header at pnum 432, drop this block
      [11.496]ubi0 warning: scan_peb: bad ec header at pnum 433, drop this block
      [11.503]ubi0 warning: scan_peb: bad ec header at pnum 434, drop this block
      [11.509]ubi0 warning: scan_peb: bad ec header at pnum 435, drop this block
      [11.516]ubi0 warning: scan_peb: bad ec header at pnum 436, drop this block
      [11.523]ubi0 warning: scan_peb: bad ec header at pnum 437, drop this block
      [11.530]ubi0 warning: scan_peb: bad ec header at pnum 438, drop this block
      [11.537]ubi0 warning: scan_peb: bad ec header at pnum 439, drop this block
      [11.544]ubi0 warning: scan_peb: bad ec header at pnum 440, drop this block
      [11.551]ubi0 warning: scan_peb: bad ec header at pnum 441, drop this block
      [11.558]ubi0 warning: scan_peb: bad ec header at pnum 442, drop this block
      [11.564]ubi0 warning: scan_peb: bad ec header at pnum 443, drop this block
      [11.571]ubi0 warning: scan_peb: bad ec header at pnum 444, drop this block
      [11.578]ubi0 warning: scan_peb: bad ec header at pnum 445, drop this block
      [11.585]ubi0 warning: scan_peb: bad ec header at pnum 446, drop this block
      [11.592]ubi0 warning: scan_peb: bad ec header at pnum 447, drop this block
      [11.599]ubi0 warning: scan_peb: bad ec header at pnum 448, drop this block
      [11.606]ubi0 warning: scan_peb: bad ec header at pnum 449, drop this block
      [11.613]ubi0 warning: scan_peb: bad ec header at pnum 450, drop this block
      [11.619]ubi0 warning: scan_peb: bad ec header at pnum 451, drop this block
      [11.626]ubi0 warning: scan_peb: bad ec header at pnum 452, drop this block
      [11.633]ubi0 warning: scan_peb: bad ec header at pnum 453, drop this block
      [11.640]ubi0 warning: scan_peb: bad ec header at pnum 454, drop this block
      [11.647]ubi0 warning: scan_peb: bad ec header at pnum 455, drop this block
      [11.654]ubi0 warning: scan_peb: bad ec header at pnum 456, drop this block
      [11.661]ubi0 warning: scan_peb: bad ec header at pnum 457, drop this block
      [11.667]ubi0 warning: scan_peb: bad ec header at pnum 458, drop this block
      [11.674]ubi0 warning: scan_peb: bad ec header at pnum 459, drop this block
      [11.681]ubi0 warning: scan_peb: bad ec header at pnum 460, drop this block
      [11.688]ubi0 warning: scan_peb: bad ec header at pnum 461, drop this block
      [11.695]ubi0 warning: scan_peb: bad ec header at pnum 462, drop this block
      [11.702]ubi0 warning: scan_peb: bad ec header at pnum 463, drop this block
      [11.709]ubi0 warning: scan_peb: bad ec header at pnum 464, drop this block
      [11.716]ubi0 warning: scan_peb: bad ec header at pnum 465, drop this block
      [11.722]ubi0 warning: scan_peb: bad ec header at pnum 466, drop this block
      [11.729]ubi0 warning: scan_peb: bad ec header at pnum 467, drop this block
      [11.736]ubi0 warning: scan_peb: bad ec header at pnum 468, drop this block
      [11.743]ubi0 warning: scan_peb: bad ec header at pnum 469, drop this block
      [11.750]ubi0 warning: scan_peb: bad ec header at pnum 470, drop this block
      [11.757]ubi0 warning: scan_peb: bad ec header at pnum 471, drop this block
      [11.764]ubi0 warning: scan_peb: bad ec header at pnum 472, drop this block
      [11.771]ubi0 warning: scan_peb: bad ec header at pnum 473, drop this block
      [11.777]ubi0 warning: scan_peb: bad ec header at pnum 474, drop this block
      [11.784]ubi0 warning: scan_peb: bad ec header at pnum 475, drop this block
      [11.791]ubi0 warning: scan_peb: bad ec header at pnum 476, drop this block
      [11.798]ubi0 warning: scan_peb: bad ec header at pnum 477, drop this block
      [11.805]ubi0 warning: scan_peb: bad ec header at pnum 478, drop this block
      [11.812]ubi0 warning: scan_peb: bad ec header at pnum 479, drop this block
      [11.819]ubi0 warning: scan_peb: bad ec header at pnum 480, drop this block
      [11.825]ubi0 warning: scan_peb: bad ec header at pnum 481, drop this block
      [11.832]ubi0 warning: scan_peb: bad ec header at pnum 482, drop this block
      [11.839]ubi0 warning: scan_peb: bad ec header at pnum 483, drop this block
      [11.846]ubi0 warning: scan_peb: bad ec header at pnum 484, drop this block
      [11.853]ubi0 warning: scan_peb: bad ec header at pnum 485, drop this block
      [11.860]ubi0 warning: scan_peb: bad ec header at pnum 486, drop this block
      [11.867]ubi0 warning: scan_peb: bad ec header at pnum 487, drop this block
      [11.874]ubi0 warning: scan_peb: bad ec header at pnum 488, drop this block
      [11.880]ubi0 warning: scan_peb: bad ec header at pnum 489, drop this block
      [11.887]ubi0 warning: scan_peb: bad ec header at pnum 490, drop this block
      [11.894]ubi0 warning: scan_peb: bad ec header at pnum 491, drop this block
      [11.901]ubi0: scanning is finished
      [11.904]ubi0: empty MTD device detected
      [11.948]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [11.952]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [11.959]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [11.965]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [11.971]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [11.976]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
      [11.983]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
      [11.991]ubi0: available PEBs: 468, total reserved PEBs: 24, PEBs reserved for bad PEB handling: 20
      [13.105]erase blk 0 to blk 32
      [13.125]erase blk 40 to blk 1024
      [13.672]sunxi-spinand: spinand secure storage ok for phy blk 32 and 33
      [13.678]sunxi-spinand: secure storage blks have never used before
      [13.685]sunxi-spinand: secure storage has no valid data on item 0
      [13.691]Item0 (Map) magic is bad
      [13.694]the secure storage map is empty
      [13.853]sunxi-spinand: write secure storage itme 0 ok
      [13.858]erase secure storage: 0 ok
      SUNXI_EFEX_MBR_TAG
      mbr size = 0x10000
      force mbr
      defaults:
      mtdids  : nand0=nand
      [13.912]MTD info (4)
      [13.913]pagesize: 0x1000
      [13.916]blksize: 0x40000
      [13.918]num  offset     bytes      name
      [13.922]0    0x00000000 0x00100000 boot0
      [13.925]1    0x00100000 0x00300000 uboot
      [13.929]2    0x00400000 0x00100000 secure_storage
      [13.933]3    0x00500000 0x07b00000 sys
      [13.937]MBR info (unalign):
      [13.939]partno   addr       sects      type       name
      [13.944]0        0x00000000 0x00008000 0x00000001 mbr
      [13.949]1        0x00008000 0x00000800 0x00008000 boot-resource
      [13.954]2        0x00008800 0x000001f8 0x00008000 env
      [13.959]3        0x000089f8 0x000001f8 0x00008000 env-redund
      [13.965]4        0x00008bf0 0x00005000 0x00008000 boot
      [13.969]5        0x0000dbf0 0x000103e8 0x00008000 rootfs
      [13.974]6        0x0001dfd8 0x00005780 0x00008000 recovery
      [13.980]7        0x00023758 0x000078f0 0x00008000 rootfs_data
      [13.985]8        0x0002b048 0x00000000 0x00000000 UDISK
      [13.990]ubi attach the last part of mtd device: NO.3
      [13.995]MBR info (align):
      [13.997]partno   addr       sects      type       name
      [14.002]0        0x00002800 0x000081f0 0x00000001 mbr
      [14.007]1        0x0000a9f0 0x000009d8 0x00008000 boot-resource
      [14.012]2        0x0000b3c8 0x000001f8 0x00008000 env
      [14.017]3        0x0000b5c0 0x000001f8 0x00008000 env-redund
      [14.022]4        0x0000b7b8 0x000050b8 0x00008000 boot
      [14.027]5        0x00010870 0x000105d8 0x00008000 rootfs
      [14.032]6        0x00020e48 0x00005898 0x00008000 recovery
      [14.038]7        0x000266e0 0x00007a10 0x00008000 rootfs_data
      [14.043]8        0x0002e0f0 0x00000000 0x00000000 UDISK
      [14.048]ubi attach the last part of mtd device: NO.3
      [14.053]ubi attatch mtd, name: sys
      [14.056]ubi0: detaching mtd4
      [14.061]ubi0: mtd4 is detached
      [14.064]ubi0: attaching mtd4
      [14.168]ubi0: scanning is finished
      [14.171]ubi0: empty MTD device detected
      [14.215]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [14.219]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [14.226]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [14.232]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [14.238]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [14.243]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
      [14.250]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
      [14.258]ubi0: available PEBs: 468, total reserved PEBs: 24, PEBs reserved for bad PEB handling: 20
      Creating dynamic volume boot-resource of size 1290240
      Creating dynamic volume boot of size 10579968
      Creating dynamic volume rootfs of size 34320384
      Creating dynamic volume recovery of size 11612160
      Creating dynamic volume rootfs_data of size 15998976
      No size specified -> Using max size (29417472)
      [15.624]reset last volume size to 0xe070
      Creating dynamic volume UDISK of size 29417472
      [15.719]fill gap start: volume mbr sects 0x7f80
      [26.994]ubi0 warning: ubi_io_read_vid_hdr: bad magic number at PEB 149: ddcecded instead of 55424921
      [27.003]Volume identifier header dump:
      [27.006]        magic     ddcecded
      [27.009]        version   205
      [27.011]        vol_type  206
      [27.013]        copy_flag 204
      [27.015]        compat    204
      [27.017]        vol_id    -858993460
      [27.020]        lnum      -858993460
      [27.022]        data_size -858784564
      [27.025]        used_ebs  -858993458
      [27.028]        data_pad  -858993460
      [27.030]        sqnum     14757395258967641311
      [27.034]        hdr_crc   dffcfdcc
      [27.036]Volume identifier header hexdump:
      [27.040]ubi0 warning: ubi_eba_read_leb: corrupted VID header at PEB 149, LEB 0:0
      [27.048]ubi0 warning: ubi_volume_continue_write: volume 0 on UBI device 0 is corrupt
      [27.055]fill gap end: volume mbr
      [27.059]update partition map
      [27.061]logical area info: 468 258048 last_lba: 235871
      read from corrupted volume 0[27.078]mbr magic error: ▒▒▒▒▒▒▒▒ wanted softw411
      *** ERROR: Can't read MBR header ***
      read from corrupted volume 0[27.100]mbr magic error: ▒▒▒▒▒▒▒▒ wanted softw411
      [27.414]fill gap start: volume boot-resource sects 0x264
      [27.627]fill gap end: volume boot-resource
      FEX_CMD_fes_verify_value, start 0x8000, size high 0x0:low 0xb3800
      FEX_CMD_fes_verify_value 0x35b4e32e
      • U
        uuuuid LV 6 最后由 编辑
        [1163]fes begin commit:88480af-dirty
        [1166]set pll start
        [1168]periph0 has been enabled
        [1171]set pll end
        [1173][pmu]: bus read error
        [1175]board init ok
        [1177]beign to init dram
        [1179]ZQ value = 0x2f
        [1181]get_pmu_exist() = -1
        [1184]ddr_efuse_type: 0xa
        [1186]trefi:7.8ms
        [1189][AUTO DEBUG] single rank and full DQ!
        [1193]ddr_efuse_type: 0xa
        [1195]trefi:7.8ms
        [1197][AUTO DEBUG] rank 0 row = 13
        [1200][AUTO DEBUG] rank 0 bank = 4
        [1204][AUTO DEBUG] rank 0 page size = 2 KB
        [1208]DRAM BOOT DRIVE INFO: V0.33
        [1211]DRAM CLK = 528 MHz
        [1213]DRAM Type = 2 (2:DDR2,3:DDR3)
        [1216]DRAMC read ODT  off.
        [1219]DRAM ODT off.
        [1221]ddr_efuse_type: 0xa
        [1223]DRAM SIZE =64 M
        [1225]dram_tpr4:0x0
        [1227]PLL_DDR_CTRL_REG:0xf8002b00
        [1230]DRAM_CLK_REG:0xc0000000
        [1233][TIMING DEBUG] MR2= 0x0
        [1238]DRAM simple test OK.
        [1240]init dram ok
        U-Boot 2018.05-g24521d6-dirty (Nov 13 2022 - 12:34:54 +0800) Allwinner Technology
        [04.303]DRAM:  64 MiB
        [04.308]Relocation Offset is: 01ee3000
        [04.334]secure enable bit: 0
        [04.340]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
        [04.346]flash init start
        [04.349]workmode = 16,storage type = 0
        try card 2
        set card number 2
        get card number 2
        [04.356][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
        [04.366][mmc]: get sdc_type fail and use default host:tm4.
        [04.399][mmc]: Is not Boot mode!
        [04.401][mmc]: SUNXI SDMMC Controller Version:0x50310
        [04.413][mmc]: ************Try SD card 2************
        [04.418][mmc]: mmc 2 cmd timeout 100 status 100
        [04.422][mmc]: smc 2 err, cmd 8,  RTO
        [04.426][mmc]: mmc 2 close bus gating and reset
        [04.431][mmc]: mmc 2 cmd timeout 100 status 100
        [04.435][mmc]: smc 2 err, cmd 55,  RTO
        [04.438][mmc]: mmc 2 close bus gating and reset
        [04.443][mmc]: ************Try MMC card 2************
        [04.451][mmc]: mmc 2 cmd timeout 100 status 100
        [04.456][mmc]: smc 2 err, cmd 1,  RTO
        [04.459][mmc]: mmc 2 close bus gating and reset
        [04.463][mmc]: Card did not respond to voltage select!
        [04.468][mmc]: ************SD/MMC 2 init error!************
        [04.473][mmc]: mmc init product failed
        MMC init failed
        try emmc fail
        [04.490]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
        [04.496]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
        [04.561]sunxi-spinand-phy: request spi0 gpio ok
        [04.566]sunxi-spinand-phy: request general tx dma channel ok!
        [04.571]sunxi-spinand-phy: request general rx dma channel ok!
        [04.576]sunxi-spinand-phy: set spic0 clk to 20 Mhz
        [04.581]sunxi-spinand-phy: init spic0 clk ok
        [04.627]sunxi-spinand-phy: not detect any munufacture from id table
        [04.643]sunxi-spinand-phy: get spi-nand Model from fdt fail
        [04.648]sunxi-spinand-phy: get phy info from fdt fail
        [04.653]sunxi-spinand-phy: not detect munufacture from fdt
        [04.658]sunxi-spinand-phy: detect munufacture from id table: Winbond
        [04.664]sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
        [04.670]sunxi-spinand-phy: ========== arch info ==========
        [04.675]sunxi-spinand-phy: Model:               W25N01GVZEIG
        [04.681]sunxi-spinand-phy: Munufacture:         Winbond
        [04.686]sunxi-spinand-phy: DieCntPerChip:       1
        [04.690]sunxi-spinand-phy: BlkCntPerDie:        1024
        [04.695]sunxi-spinand-phy: PageCntPerBlk:       64
        [04.699]sunxi-spinand-phy: SectCntPerPage:      4
        [04.704]sunxi-spinand-phy: OobSizePerPage:      64
        [04.708]sunxi-spinand-phy: BadBlockFlag:        0x0
        [04.713]sunxi-spinand-phy: OperationOpt:        0x7
        [04.717]sunxi-spinand-phy: MaxEraseTimes:       65000
        [04.722]sunxi-spinand-phy: EccFlag:             0x0
        [04.727]sunxi-spinand-phy: EccType:             2
        [04.731]sunxi-spinand-phy: EccProtectedType:    3
        [04.735]sunxi-spinand-phy: ========================================
        [04.741]sunxi-spinand-phy:
        [04.744]sunxi-spinand-phy: ========== physical info ==========
        [04.749]sunxi-spinand-phy: TotalSize:    128 M
        [04.754]sunxi-spinand-phy: SectorSize:   512 B
        [04.758]sunxi-spinand-phy: PageSize:     2 K
        [04.762]sunxi-spinand-phy: BlockSize:    128 K
        [04.766]sunxi-spinand-phy: OOBSize:      64 B
        [04.770]sunxi-spinand-phy: ========================================
        [04.776]sunxi-spinand-phy:
        [04.779]sunxi-spinand-phy: ========== logical info ==========
        [04.784]sunxi-spinand-phy: TotalSize:    128 M
        [04.788]sunxi-spinand-phy: SectorSize:   512 B
        [04.792]sunxi-spinand-phy: PageSize:     4 K
        [04.796]sunxi-spinand-phy: BlockSize:    256 K
        [04.800]sunxi-spinand-phy: OOBSize:      128 B
        [04.805]sunxi-spinand-phy: ========================================
        [04.821]sunxi-spinand-phy: set spic0 clk to 30 Mhz
        [04.826]sunxi-spinand-phy: block lock register: 0x00
        [04.830]sunxi-spinand-phy: feature register: 0x19
        [04.835]sunxi-spinand-phy: sunxi physic nand init end
        [04.845]Loading Environment from SUNXI_FLASH... OK
        [04.859]try to burn key
        [04.863]out of usb burn from boot: not need burn key
        [04.867]Net:   [04.868]No ethernet found.
        run usb efex
        delay time 2500
        weak:otg_phy_config
        usb init ok
        set address 0x33
        set address 0x33 ok
        set address 0x3f
        set address 0x3f ok
        erase_flag = 0x12
        total mbr part 8
        part[0] keydata   :0
        part[0] ro        :0
        part[1] name      :env
        part[1] keydata   :0
        part[1] ro        :0
        part[2] keydata   :0
        part[2] ro        :0
        part[3] name      :boot
        part[3] keydata   :0
        part[3] ro        :0
        part[4] keydata   :0
        part[4] ro        :0
        part[5] keydata   :0
        part[5] ro        :0
        part[6] keydata   :0
        part[6] ro        :0
        part[7] name      :UDISK
        part[7] lenlo     :0x0
        part[7] keydata   :0
        part[7] ro        :0
        total part: 9
        mbr 0, 8000, 8000
        env 2, 1f8, 8000
        boot 4, 5000, 8000
        UDISK 8, 0, 0
        [08.196]erase blk 0 to blk 32
        [08.223]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
        defaults:
        mtdids  : nand0=nand
        [08.283]MTD info (4)
        [08.285]pagesize: 0x1000
        [08.287]blksize: 0x40000
        [08.290]num  offset     bytes      name
        [08.293]0    0x00000000 0x00100000 boot0
        [08.297]1    0x00100000 0x00300000 uboot
        [08.301]2    0x00400000 0x00100000 secure_storage
        [08.305]3    0x00500000 0x07b00000 sys
        [08.308]ubi attach the last part of mtd device: NO.3
        [08.429]ubi0: attaching mtd4
        [08.431]ubi0 warning: scan_peb: bad ec header at pnum 0, drop this block
        [08.438]ubi0 warning: scan_peb: bad ec header at pnum 1, drop this block
        [08.445]ubi0 warning: scan_peb: bad ec header at pnum 2, drop this block
        [08.452]ubi0 warning: scan_peb: bad ec header at pnum 3, drop this block
        [08.458]ubi0 warning: scan_peb: bad ec header at pnum 4, drop this block
        [08.465]ubi0 warning: scan_peb: bad ec header at pnum 5, drop this block
        [08.472]ubi0 warning: scan_peb: bad ec header at pnum 6, drop this block
        [08.479]ubi0 warning: scan_peb: bad ec header at pnum 7, drop this block
        [08.485]ubi0 warning: scan_peb: bad ec header at pnum 8, drop this block
        [08.492]ubi0 warning: scan_peb: bad ec header at pnum 9, drop this block
        [08.499]ubi0 warning: scan_peb: bad ec header at pnum 10, drop this block
        [08.506]ubi0 warning: scan_peb: bad ec header at pnum 11, drop this block
        [08.513]ubi0 warning: scan_peb: bad ec header at pnum 12, drop this block
        [08.520]ubi0 warning: scan_peb: bad ec header at pnum 13, drop this block
        [08.526]ubi0 warning: scan_peb: bad ec header at pnum 14, drop this block
        [08.533]ubi0 warning: scan_peb: bad ec header at pnum 15, drop this block
        [08.540]ubi0 warning: scan_peb: bad ec header at pnum 16, drop this block
        [08.547]ubi0 warning: scan_peb: bad ec header at pnum 17, drop this block
        [08.554]ubi0 warning: scan_peb: bad ec header at pnum 18, drop this block
        [08.561]ubi0 warning: scan_peb: bad ec header at pnum 19, drop this block
        [08.568]ubi0 warning: scan_peb: bad ec header at pnum 20, drop this block
        [08.574]ubi0 warning: scan_peb: bad ec header at pnum 21, drop this block
        [08.581]ubi0 warning: scan_peb: bad ec header at pnum 22, drop this block
        [08.588]ubi0 warning: scan_peb: bad ec header at pnum 23, drop this block
        [08.595]ubi0 warning: scan_peb: bad ec header at pnum 24, drop this block
        [08.602]ubi0 warning: scan_peb: bad ec header at pnum 25, drop this block
        [08.609]ubi0 warning: scan_peb: bad ec header at pnum 26, drop this block
        [08.616]ubi0 warning: scan_peb: bad ec header at pnum 27, drop this block
        [08.622]ubi0 warning: scan_peb: bad ec header at pnum 28, drop this block
        [08.629]ubi0 warning: scan_peb: bad ec header at pnum 29, drop this block
        [08.636]ubi0 warning: scan_peb: bad ec header at pnum 30, drop this block
        [08.643]ubi0 warning: scan_peb: bad ec header at pnum 31, drop this block
        [08.650]ubi0 warning: scan_peb: bad ec header at pnum 32, drop this block
        [08.657]ubi0 warning: scan_peb: bad ec header at pnum 33, drop this block
        [08.664]ubi0 warning: scan_peb: bad ec header at pnum 34, drop this block
        [08.670]ubi0 warning: scan_peb: bad ec header at pnum 35, drop this block
        [08.677]ubi0 warning: scan_peb: bad ec header at pnum 36, drop this block
        [08.684]ubi0 warning: scan_peb: bad ec header at pnum 37, drop this block
        [08.691]ubi0 warning: scan_peb: bad ec header at pnum 38, drop this block
        [08.698]ubi0 warning: scan_peb: bad ec header at pnum 39, drop this block
        [08.705]ubi0 warning: scan_peb: bad ec header at pnum 40, drop this block
        [08.712]ubi0 warning: scan_peb: bad ec header at pnum 41, drop this block
        [08.718]ubi0 warning: scan_peb: bad ec header at pnum 42, drop this block
        [08.725]ubi0 warning: scan_peb: bad ec header at pnum 43, drop this block
        [08.732]ubi0 warning: scan_peb: bad ec header at pnum 44, drop this block
        [08.739]ubi0 warning: scan_peb: bad ec header at pnum 45, drop this block
        [08.746]ubi0 warning: scan_peb: bad ec header at pnum 46, drop this block
        [08.753]ubi0 warning: scan_peb: bad ec header at pnum 47, drop this block
        [08.759]ubi0 warning: scan_peb: bad ec header at pnum 48, drop this block
        [08.766]ubi0 warning: scan_peb: bad ec header at pnum 49, drop this block
        [08.773]ubi0 warning: scan_peb: bad ec header at pnum 50, drop this block
        [08.780]ubi0 warning: scan_peb: bad ec header at pnum 51, drop this block
        [08.787]ubi0 warning: scan_peb: bad ec header at pnum 52, drop this block
        [08.794]ubi0 warning: scan_peb: bad ec header at pnum 53, drop this block
        [08.801]ubi0 warning: scan_peb: bad ec header at pnum 54, drop this block
        [08.807]ubi0 warning: scan_peb: bad ec header at pnum 55, drop this block
        [08.814]ubi0 warning: scan_peb: bad ec header at pnum 56, drop this block
        [08.821]ubi0 warning: scan_peb: bad ec header at pnum 57, drop this block
        [08.828]ubi0 warning: scan_peb: bad ec header at pnum 58, drop this block
        [08.835]ubi0 warning: scan_peb: bad ec header at pnum 59, drop this block
        [08.842]ubi0 warning: scan_peb: bad ec header at pnum 60, drop this block
        [08.849]ubi0 warning: scan_peb: bad ec header at pnum 61, drop this block
        [08.855]ubi0 warning: scan_peb: bad ec header at pnum 62, drop this block
        [08.862]ubi0 warning: scan_peb: bad ec header at pnum 63, drop this block
        [08.869]ubi0 warning: scan_peb: bad ec header at pnum 64, drop this block
        [08.876]ubi0 warning: scan_peb: bad ec header at pnum 65, drop this block
        [08.883]ubi0 warning: scan_peb: bad ec header at pnum 66, drop this block
        [08.890]ubi0 warning: scan_peb: bad ec header at pnum 67, drop this block
        [08.897]ubi0 warning: scan_peb: bad ec header at pnum 68, drop this block
        [08.903]ubi0 warning: scan_peb: bad ec header at pnum 69, drop this block
        [08.910]ubi0 warning: scan_peb: bad ec header at pnum 70, drop this block
        [08.917]ubi0 warning: scan_peb: bad ec header at pnum 71, drop this block
        [08.924]ubi0 warning: scan_peb: bad ec header at pnum 72, drop this block
        [08.931]ubi0 warning: scan_peb: bad ec header at pnum 73, drop this block
        [08.938]ubi0 warning: scan_peb: bad ec header at pnum 74, drop this block
        [08.945]ubi0 warning: scan_peb: bad ec header at pnum 75, drop this block
        [08.951]ubi0 warning: scan_peb: bad ec header at pnum 76, drop this block
        [08.958]ubi0 warning: scan_peb: bad ec header at pnum 77, drop this block
        [08.965]ubi0 warning: scan_peb: bad ec header at pnum 78, drop this block
        [08.972]ubi0 warning: scan_peb: bad ec header at pnum 79, drop this block
        [08.979]ubi0 warning: scan_peb: bad ec header at pnum 80, drop this block
        [08.986]ubi0 warning: scan_peb: bad ec header at pnum 81, drop this block
        [08.993]ubi0 warning: scan_peb: bad ec header at pnum 82, drop this block
        [08.999]ubi0 warning: scan_peb: bad ec header at pnum 83, drop this block
        [09.006]ubi0 warning: scan_peb: bad ec header at pnum 84, drop this block
        [09.013]ubi0 warning: scan_peb: bad ec header at pnum 85, drop this block
        [09.020]ubi0 warning: scan_peb: bad ec header at pnum 86, drop this block
        [09.027]ubi0 warning: scan_peb: bad ec header at pnum 87, drop this block
        [09.034]ubi0 warning: scan_peb: bad ec header at pnum 88, drop this block
        [09.041]ubi0 warning: scan_peb: bad ec header at pnum 89, drop this block
        [09.047]ubi0 warning: scan_peb: bad ec header at pnum 90, drop this block
        [09.054]ubi0 warning: scan_peb: bad ec header at pnum 91, drop this block
        [09.061]ubi0 warning: scan_peb: bad ec header at pnum 92, drop this block
        [09.068]ubi0 warning: scan_peb: bad ec header at pnum 93, drop this block
        [09.075]ubi0 warning: scan_peb: bad ec header at pnum 94, drop this block
        [09.082]ubi0 warning: scan_peb: bad ec header at pnum 95, drop this block
        [09.089]ubi0 warning: scan_peb: bad ec header at pnum 96, drop this block
        [09.095]ubi0 warning: scan_peb: bad ec header at pnum 97, drop this block
        [09.102]ubi0 warning: scan_peb: bad ec header at pnum 98, drop this block
        [09.109]ubi0 warning: scan_peb: bad ec header at pnum 99, drop this block
        [09.116]ubi0 warning: scan_peb: bad ec header at pnum 100, drop this block
        [09.123]ubi0 warning: scan_peb: bad ec header at pnum 101, drop this block
        [09.130]ubi0 warning: scan_peb: bad ec header at pnum 102, drop this block
        [09.137]ubi0 warning: scan_peb: bad ec header at pnum 103, drop this block
        [09.144]ubi0 warning: scan_peb: bad ec header at pnum 104, drop this block
        [09.151]ubi0 warning: scan_peb: bad ec header at pnum 105, drop this block
        [09.158]ubi0 warning: scan_peb: bad ec header at pnum 106, drop this block
        [09.165]ubi0 warning: scan_peb: bad ec header at pnum 107, drop this block
        [09.171]ubi0 warning: scan_peb: bad ec header at pnum 108, drop this block
        [09.178]ubi0 warning: scan_peb: bad ec header at pnum 109, drop this block
        [09.185]ubi0 warning: scan_peb: bad ec header at pnum 110, drop this block
        [09.192]ubi0 warning: scan_peb: bad ec header at pnum 111, drop this block
        [09.199]ubi0 warning: scan_peb: bad ec header at pnum 112, drop this block
        [09.206]ubi0 warning: scan_peb: bad ec header at pnum 113, drop this block
        [09.213]ubi0 warning: scan_peb: bad ec header at pnum 114, drop this block
        [09.220]ubi0 warning: scan_peb: bad ec header at pnum 115, drop this block
        [09.227]ubi0 warning: scan_peb: bad ec header at pnum 116, drop this block
        [09.234]ubi0 warning: scan_peb: bad ec header at pnum 117, drop this block
        [09.241]ubi0 warning: scan_peb: bad ec header at pnum 118, drop this block
        [09.248]ubi0 warning: scan_peb: bad ec header at pnum 119, drop this block
        [09.255]ubi0 warning: scan_peb: bad ec header at pnum 120, drop this block
        [09.262]ubi0 warning: scan_peb: bad ec header at pnum 121, drop this block
        [09.269]ubi0 warning: scan_peb: bad ec header at pnum 122, drop this block
        [09.276]ubi0 warning: scan_peb: bad ec header at pnum 123, drop this block
        [09.283]ubi0 warning: scan_peb: bad ec header at pnum 124, drop this block
        [09.289]ubi0 warning: scan_peb: bad ec header at pnum 125, drop this block
        [09.296]ubi0 warning: scan_peb: bad ec header at pnum 126, drop this block
        [09.303]ubi0 warning: scan_peb: bad ec header at pnum 127, drop this block
        [09.310]ubi0 warning: scan_peb: bad ec header at pnum 128, drop this block
        [09.317]ubi0 warning: scan_peb: bad ec header at pnum 129, drop this block
        [09.324]ubi0 warning: scan_peb: bad ec header at pnum 130, drop this block
        [09.331]ubi0 warning: scan_peb: bad ec header at pnum 131, drop this block
        [09.338]ubi0 warning: scan_peb: bad ec header at pnum 132, drop this block
        [09.345]ubi0 warning: scan_peb: bad ec header at pnum 133, drop this block
        [09.352]ubi0 warning: scan_peb: bad ec header at pnum 134, drop this block
        [09.359]ubi0 warning: scan_peb: bad ec header at pnum 135, drop this block
        [09.366]ubi0 warning: scan_peb: bad ec header at pnum 136, drop this block
        [09.373]ubi0 warning: scan_peb: bad ec header at pnum 137, drop this block
        [09.380]ubi0 warning: scan_peb: bad ec header at pnum 138, drop this block
        [09.387]ubi0 warning: scan_peb: bad ec header at pnum 139, drop this block
        [09.394]ubi0 warning: scan_peb: bad ec header at pnum 140, drop this block
        [09.401]ubi0 warning: scan_peb: bad ec header at pnum 141, drop this block
        [09.407]ubi0 warning: scan_peb: bad ec header at pnum 142, drop this block
        [09.414]ubi0 warning: scan_peb: bad ec header at pnum 143, drop this block
        [09.421]ubi0 warning: scan_peb: bad ec header at pnum 144, drop this block
        [09.428]ubi0 warning: scan_peb: bad ec header at pnum 145, drop this block
        [09.435]ubi0 warning: scan_peb: bad ec header at pnum 146, drop this block
        [09.442]ubi0 warning: scan_peb: bad ec header at pnum 147, drop this block
        [09.449]ubi0 warning: scan_peb: bad ec header at pnum 148, drop this block
        [09.456]ubi0 warning: scan_peb: bad ec header at pnum 149, drop this block
        [09.463]ubi0 warning: scan_peb: bad ec header at pnum 150, drop this block
        [09.470]ubi0 warning: scan_peb: bad ec header at pnum 151, drop this block
        [09.477]ubi0 warning: scan_peb: bad ec header at pnum 152, drop this block
        [09.484]ubi0 warning: scan_peb: bad ec header at pnum 153, drop this block
        [09.491]ubi0 warning: scan_peb: bad ec header at pnum 154, drop this block
        [09.498]ubi0 warning: scan_peb: bad ec header at pnum 155, drop this block
        [09.505]ubi0 warning: scan_peb: bad ec header at pnum 156, drop this block
        [09.512]ubi0 warning: scan_peb: bad ec header at pnum 157, drop this block
        [09.519]ubi0 warning: scan_peb: bad ec header at pnum 158, drop this block
        [09.526]ubi0 warning: scan_peb: bad ec header at pnum 159, drop this block
        [09.532]ubi0 warning: scan_peb: bad ec header at pnum 160, drop this block
        [09.539]ubi0 warning: scan_peb: bad ec header at pnum 161, drop this block
        [09.546]ubi0 warning: scan_peb: bad ec header at pnum 162, drop this block
        [09.553]ubi0 warning: scan_peb: bad ec header at pnum 163, drop this block
        [09.560]ubi0 warning: scan_peb: bad ec header at pnum 164, drop this block
        [09.567]ubi0 warning: scan_peb: bad ec header at pnum 165, drop this block
        [09.574]ubi0 warning: scan_peb: bad ec header at pnum 166, drop this block
        [09.581]ubi0 warning: scan_peb: bad ec header at pnum 167, drop this block
        [09.588]ubi0 warning: scan_peb: bad ec header at pnum 168, drop this block
        [09.595]ubi0 warning: scan_peb: bad ec header at pnum 169, drop this block
        [09.602]ubi0 warning: scan_peb: bad ec header at pnum 170, drop this block
        [09.609]ubi0 warning: scan_peb: bad ec header at pnum 171, drop this block
        [09.616]ubi0 warning: scan_peb: bad ec header at pnum 172, drop this block
        [09.623]ubi0 warning: scan_peb: bad ec header at pnum 173, drop this block
        [09.630]ubi0 warning: scan_peb: bad ec header at pnum 174, drop this block
        [09.637]ubi0 warning: scan_peb: bad ec header at pnum 175, drop this block
        [09.644]ubi0 warning: scan_peb: bad ec header at pnum 176, drop this block
        [09.650]ubi0 warning: scan_peb: bad ec header at pnum 177, drop this block
        [09.657]ubi0 warning: scan_peb: bad ec header at pnum 178, drop this block
        [09.664]ubi0 warning: scan_peb: bad ec header at pnum 179, drop this block
        [09.671]ubi0 warning: scan_peb: bad ec header at pnum 180, drop this block
        [09.678]ubi0 warning: scan_peb: bad ec header at pnum 181, drop this block
        [09.685]ubi0 warning: scan_peb: bad ec header at pnum 182, drop this block
        [09.692]ubi0 warning: scan_peb: bad ec header at pnum 183, drop this block
        [09.699]ubi0 warning: scan_peb: bad ec header at pnum 184, drop this block
        [09.706]ubi0 warning: scan_peb: bad ec header at pnum 185, drop this block
        [09.713]ubi0 warning: scan_peb: bad ec header at pnum 186, drop this block
        [09.720]ubi0 warning: scan_peb: bad ec header at pnum 187, drop this block
        [09.727]ubi0 warning: scan_peb: bad ec header at pnum 188, drop this block
        [09.734]ubi0 warning: scan_peb: bad ec header at pnum 189, drop this block
        [09.741]ubi0 warning: scan_peb: bad ec header at pnum 190, drop this block
        [09.748]ubi0 warning: scan_peb: bad ec header at pnum 191, drop this block
        [09.755]ubi0 warning: scan_peb: bad ec header at pnum 192, drop this block
        [09.762]ubi0 warning: scan_peb: bad ec header at pnum 193, drop this block
        [09.768]ubi0 warning: scan_peb: bad ec header at pnum 194, drop this block
        [09.775]ubi0 warning: scan_peb: bad ec header at pnum 195, drop this block
        [09.782]ubi0 warning: scan_peb: bad ec header at pnum 196, drop this block
        [09.789]ubi0 warning: scan_peb: bad ec header at pnum 197, drop this block
        [09.796]ubi0 warning: scan_peb: bad ec header at pnum 198, drop this block
        [09.803]ubi0 warning: scan_peb: bad ec header at pnum 199, drop this block
        [09.810]ubi0 warning: scan_peb: bad ec header at pnum 200, drop this block
        [09.817]ubi0 warning: scan_peb: bad ec header at pnum 201, drop this block
        [09.824]ubi0 warning: scan_peb: bad ec header at pnum 202, drop this block
        [09.831]ubi0 warning: scan_peb: bad ec header at pnum 203, drop this block
        [09.838]ubi0 warning: scan_peb: bad ec header at pnum 204, drop this block
        [09.845]ubi0 warning: scan_peb: bad ec header at pnum 205, drop this block
        [09.852]ubi0 warning: scan_peb: bad ec header at pnum 206, drop this block
        [09.859]ubi0 warning: scan_peb: bad ec header at pnum 207, drop this block
        [09.866]ubi0 warning: scan_peb: bad ec header at pnum 208, drop this block
        [09.873]ubi0 warning: scan_peb: bad ec header at pnum 209, drop this block
        [09.880]ubi0 warning: scan_peb: bad ec header at pnum 210, drop this block
        [09.886]ubi0 warning: scan_peb: bad ec header at pnum 211, drop this block
        [09.893]ubi0 warning: scan_peb: bad ec header at pnum 212, drop this block
        [09.900]ubi0 warning: scan_peb: bad ec header at pnum 213, drop this block
        [09.907]ubi0 warning: scan_peb: bad ec header at pnum 214, drop this block
        [09.914]ubi0 warning: scan_peb: bad ec header at pnum 215, drop this block
        [09.921]ubi0 warning: scan_peb: bad ec header at pnum 216, drop this block
        [09.928]ubi0 warning: scan_peb: bad ec header at pnum 217, drop this block
        [09.935]ubi0 warning: scan_peb: bad ec header at pnum 218, drop this block
        [09.942]ubi0 warning: scan_peb: bad ec header at pnum 219, drop this block
        [09.949]ubi0 warning: scan_peb: bad ec header at pnum 220, drop this block
        [09.956]ubi0 warning: scan_peb: bad ec header at pnum 221, drop this block
        [09.963]ubi0 warning: scan_peb: bad ec header at pnum 222, drop this block
        [09.970]ubi0 warning: scan_peb: bad ec header at pnum 223, drop this block
        [09.977]ubi0 warning: scan_peb: bad ec header at pnum 224, drop this block
        [09.984]ubi0 warning: scan_peb: bad ec header at pnum 225, drop this block
        [09.991]ubi0 warning: scan_peb: bad ec header at pnum 226, drop this block
        [09.998]ubi0 warning: scan_peb: bad ec header at pnum 227, drop this block
        [10.004]ubi0 warning: scan_peb: bad ec header at pnum 228, drop this block
        [10.011]ubi0 warning: scan_peb: bad ec header at pnum 229, drop this block
        [10.018]ubi0 warning: scan_peb: bad ec header at pnum 230, drop this block
        [10.025]ubi0 warning: scan_peb: bad ec header at pnum 231, drop this block
        [10.032]ubi0 warning: scan_peb: bad ec header at pnum 232, drop this block
        [10.039]ubi0 warning: scan_peb: bad ec header at pnum 233, drop this block
        [10.046]ubi0 warning: scan_peb: bad ec header at pnum 234, drop this block
        [10.053]ubi0 warning: scan_peb: bad ec header at pnum 235, drop this block
        [10.060]ubi0 warning: scan_peb: bad ec header at pnum 236, drop this block
        [10.067]ubi0 warning: scan_peb: bad ec header at pnum 237, drop this block
        [10.074]ubi0 warning: scan_peb: bad ec header at pnum 238, drop this block
        [10.081]ubi0 warning: scan_peb: bad ec header at pnum 239, drop this block
        [10.088]ubi0 warning: scan_peb: bad ec header at pnum 240, drop this block
        [10.095]ubi0 warning: scan_peb: bad ec header at pnum 241, drop this block
        [10.102]ubi0 warning: scan_peb: bad ec header at pnum 242, drop this block
        [10.109]ubi0 warning: scan_peb: bad ec header at pnum 243, drop this block
        [10.116]ubi0 warning: scan_peb: bad ec header at pnum 244, drop this block
        [10.122]ubi0 warning: scan_peb: bad ec header at pnum 245, drop this block
        [10.129]ubi0 warning: scan_peb: bad ec header at pnum 246, drop this block
        [10.136]ubi0 warning: scan_peb: bad ec header at pnum 247, drop this block
        [10.143]ubi0 warning: scan_peb: bad ec header at pnum 248, drop this block
        [10.150]ubi0 warning: scan_peb: bad ec header at pnum 249, drop this block
        [10.157]ubi0 warning: scan_peb: bad ec header at pnum 250, drop this block
        [10.164]ubi0 warning: scan_peb: bad ec header at pnum 251, drop this block
        [10.171]ubi0 warning: scan_peb: bad ec header at pnum 252, drop this block
        [10.178]ubi0 warning: scan_peb: bad ec header at pnum 253, drop this block
        [10.185]ubi0 warning: scan_peb: bad ec header at pnum 254, drop this block
        [10.192]ubi0 warning: scan_peb: bad ec header at pnum 255, drop this block
        [10.199]ubi0 warning: scan_peb: bad ec header at pnum 256, drop this block
        [10.206]ubi0 warning: scan_peb: bad ec header at pnum 257, drop this block
        [10.213]ubi0 warning: scan_peb: bad ec header at pnum 258, drop this block
        [10.220]ubi0 warning: scan_peb: bad ec header at pnum 259, drop this block
        [10.227]ubi0 warning: scan_peb: bad ec header at pnum 260, drop this block
        [10.234]ubi0 warning: scan_peb: bad ec header at pnum 261, drop this block
        [10.240]ubi0 warning: scan_peb: bad ec header at pnum 262, drop this block
        [10.247]ubi0 warning: scan_peb: bad ec header at pnum 263, drop this block
        [10.254]ubi0 warning: scan_peb: bad ec header at pnum 264, drop this block
        [10.261]ubi0 warning: scan_peb: bad ec header at pnum 265, drop this block
        [10.268]ubi0 warning: scan_peb: bad ec header at pnum 266, drop this block
        [10.275]ubi0 warning: scan_peb: bad ec header at pnum 267, drop this block
        [10.282]ubi0 warning: scan_peb: bad ec header at pnum 268, drop this block
        [10.289]ubi0 warning: scan_peb: bad ec header at pnum 269, drop this block
        [10.296]ubi0 warning: scan_peb: bad ec header at pnum 270, drop this block
        [10.303]ubi0 warning: scan_peb: bad ec header at pnum 271, drop this block
        [10.310]ubi0 warning: scan_peb: bad ec header at pnum 272, drop this block
        [10.317]ubi0 warning: scan_peb: bad ec header at pnum 273, drop this block
        [10.324]ubi0 warning: scan_peb: bad ec header at pnum 274, drop this block
        [10.331]ubi0 warning: scan_peb: bad ec header at pnum 275, drop this block
        [10.338]ubi0 warning: scan_peb: bad ec header at pnum 276, drop this block
        [10.345]ubi0 warning: scan_peb: bad ec header at pnum 277, drop this block
        [10.352]ubi0 warning: scan_peb: bad ec header at pnum 278, drop this block
        [10.359]ubi0 warning: scan_peb: bad ec header at pnum 279, drop this block
        [10.365]ubi0 warning: scan_peb: bad ec header at pnum 280, drop this block
        [10.372]ubi0 warning: scan_peb: bad ec header at pnum 281, drop this block
        [10.379]ubi0 warning: scan_peb: bad ec header at pnum 282, drop this block
        [10.386]ubi0 warning: scan_peb: bad ec header at pnum 283, drop this block
        [10.393]ubi0 warning: scan_peb: bad ec header at pnum 284, drop this block
        [10.400]ubi0 warning: scan_peb: bad ec header at pnum 285, drop this block
        [10.407]ubi0 warning: scan_peb: bad ec header at pnum 286, drop this block
        [10.414]ubi0 warning: scan_peb: bad ec header at pnum 287, drop this block
        [10.421]ubi0 warning: scan_peb: bad ec header at pnum 288, drop this block
        [10.428]ubi0 warning: scan_peb: bad ec header at pnum 289, drop this block
        [10.435]ubi0 warning: scan_peb: bad ec header at pnum 290, drop this block
        [10.442]ubi0 warning: scan_peb: bad ec header at pnum 291, drop this block
        [10.449]ubi0 warning: scan_peb: bad ec header at pnum 292, drop this block
        [10.456]ubi0 warning: scan_peb: bad ec header at pnum 293, drop this block
        [10.463]ubi0 warning: scan_peb: bad ec header at pnum 294, drop this block
        [10.470]ubi0 warning: scan_peb: bad ec header at pnum 295, drop this block
        [10.477]ubi0 warning: scan_peb: bad ec header at pnum 296, drop this block
        [10.483]ubi0 warning: scan_peb: bad ec header at pnum 297, drop this block
        [10.490]ubi0 warning: scan_peb: bad ec header at pnum 298, drop this block
        [10.497]ubi0 warning: scan_peb: bad ec header at pnum 299, drop this block
        [10.504]ubi0 warning: scan_peb: bad ec header at pnum 300, drop this block
        [10.511]ubi0 warning: scan_peb: bad ec header at pnum 301, drop this block
        [10.518]ubi0 warning: scan_peb: bad ec header at pnum 302, drop this block
        [10.525]ubi0 warning: scan_peb: bad ec header at pnum 303, drop this block
        [10.532]ubi0 warning: scan_peb: bad ec header at pnum 304, drop this block
        [10.539]ubi0 warning: scan_peb: bad ec header at pnum 305, drop this block
        [10.546]ubi0 warning: scan_peb: bad ec header at pnum 306, drop this block
        [10.553]ubi0 warning: scan_peb: bad ec header at pnum 307, drop this block
        [10.560]ubi0 warning: scan_peb: bad ec header at pnum 308, drop this block
        [10.567]ubi0 warning: scan_peb: bad ec header at pnum 309, drop this block
        [10.574]ubi0 warning: scan_peb: bad ec header at pnum 310, drop this block
        [10.581]ubi0 warning: scan_peb: bad ec header at pnum 311, drop this block
        [10.588]ubi0 warning: scan_peb: bad ec header at pnum 312, drop this block
        [10.595]ubi0 warning: scan_peb: bad ec header at pnum 313, drop this block
        [10.601]ubi0 warning: scan_peb: bad ec header at pnum 314, drop this block
        [10.608]ubi0 warning: scan_peb: bad ec header at pnum 315, drop this block
        [10.615]ubi0 warning: scan_peb: bad ec header at pnum 316, drop this block
        [10.622]ubi0 warning: scan_peb: bad ec header at pnum 317, drop this block
        [10.629]ubi0 warning: scan_peb: bad ec header at pnum 318, drop this block
        [10.636]ubi0 warning: scan_peb: bad ec header at pnum 319, drop this block
        [10.643]ubi0 warning: scan_peb: bad ec header at pnum 320, drop this block
        [10.650]ubi0 warning: scan_peb: bad ec header at pnum 321, drop this block
        [10.657]ubi0 warning: scan_peb: bad ec header at pnum 322, drop this block
        [10.664]ubi0 warning: scan_peb: bad ec header at pnum 323, drop this block
        [10.671]ubi0 warning: scan_peb: bad ec header at pnum 324, drop this block
        [10.678]ubi0 warning: scan_peb: bad ec header at pnum 325, drop this block
        [10.685]ubi0 warning: scan_peb: bad ec header at pnum 326, drop this block
        [10.692]ubi0 warning: scan_peb: bad ec header at pnum 327, drop this block
        [10.699]ubi0 warning: scan_peb: bad ec header at pnum 328, drop this block
        [10.706]ubi0 warning: scan_peb: bad ec header at pnum 329, drop this block
        [10.713]ubi0 warning: scan_peb: bad ec header at pnum 330, drop this block
        [10.720]ubi0 warning: scan_peb: bad ec header at pnum 331, drop this block
        [10.726]ubi0 warning: scan_peb: bad ec header at pnum 332, drop this block
        [10.733]ubi0 warning: scan_peb: bad ec header at pnum 333, drop this block
        [10.740]ubi0 warning: scan_peb: bad ec header at pnum 334, drop this block
        [10.747]ubi0 warning: scan_peb: bad ec header at pnum 335, drop this block
        [10.754]ubi0 warning: scan_peb: bad ec header at pnum 336, drop this block
        [10.761]ubi0 warning: scan_peb: bad ec header at pnum 337, drop this block
        [10.768]ubi0 warning: scan_peb: bad ec header at pnum 338, drop this block
        [10.775]ubi0 warning: scan_peb: bad ec header at pnum 339, drop this block
        [10.782]ubi0 warning: scan_peb: bad ec header at pnum 340, drop this block
        [10.789]ubi0 warning: scan_peb: bad ec header at pnum 341, drop this block
        [10.796]ubi0 warning: scan_peb: bad ec header at pnum 342, drop this block
        [10.803]ubi0 warning: scan_peb: bad ec header at pnum 343, drop this block
        [10.810]ubi0 warning: scan_peb: bad ec header at pnum 344, drop this block
        [10.817]ubi0 warning: scan_peb: bad ec header at pnum 345, drop this block
        [10.824]ubi0 warning: scan_peb: bad ec header at pnum 346, drop this block
        [10.831]ubi0 warning: scan_peb: bad ec header at pnum 347, drop this block
        [10.838]ubi0 warning: scan_peb: bad ec header at pnum 348, drop this block
        [10.844]ubi0 warning: scan_peb: bad ec header at pnum 349, drop this block
        [10.851]ubi0 warning: scan_peb: bad ec header at pnum 350, drop this block
        [10.858]ubi0 warning: scan_peb: bad ec header at pnum 351, drop this block
        [10.865]ubi0 warning: scan_peb: bad ec header at pnum 352, drop this block
        [10.872]ubi0 warning: scan_peb: bad ec header at pnum 353, drop this block
        [10.879]ubi0 warning: scan_peb: bad ec header at pnum 354, drop this block
        [10.886]ubi0 warning: scan_peb: bad ec header at pnum 355, drop this block
        [10.893]ubi0 warning: scan_peb: bad ec header at pnum 356, drop this block
        [10.900]ubi0 warning: scan_peb: bad ec header at pnum 357, drop this block
        [10.907]ubi0 warning: scan_peb: bad ec header at pnum 358, drop this block
        [10.914]ubi0 warning: scan_peb: bad ec header at pnum 359, drop this block
        [10.921]ubi0 warning: scan_peb: bad ec header at pnum 360, drop this block
        [10.928]ubi0 warning: scan_peb: bad ec header at pnum 361, drop this block
        [10.935]ubi0 warning: scan_peb: bad ec header at pnum 362, drop this block
        [10.942]ubi0 warning: scan_peb: bad ec header at pnum 363, drop this block
        [10.949]ubi0 warning: scan_peb: bad ec header at pnum 364, drop this block
        [10.956]ubi0 warning: scan_peb: bad ec header at pnum 365, drop this block
        [10.962]ubi0 warning: scan_peb: bad ec header at pnum 366, drop this block
        [10.969]ubi0 warning: scan_peb: bad ec header at pnum 367, drop this block
        [10.976]ubi0 warning: scan_peb: bad ec header at pnum 368, drop this block
        [10.983]ubi0 warning: scan_peb: bad ec header at pnum 369, drop this block
        [10.990]ubi0 warning: scan_peb: bad ec header at pnum 370, drop this block
        [10.997]ubi0 warning: scan_peb: bad ec header at pnum 371, drop this block
        [11.004]ubi0 warning: scan_peb: bad ec header at pnum 372, drop this block
        [11.011]ubi0 warning: scan_peb: bad ec header at pnum 373, drop this block
        [11.018]ubi0 warning: scan_peb: bad ec header at pnum 374, drop this block
        [11.025]ubi0 warning: scan_peb: bad ec header at pnum 375, drop this block
        [11.032]ubi0 warning: scan_peb: bad ec header at pnum 376, drop this block
        [11.039]ubi0 warning: scan_peb: bad ec header at pnum 377, drop this block
        [11.046]ubi0 warning: scan_peb: bad ec header at pnum 378, drop this block
        [11.053]ubi0 warning: scan_peb: bad ec header at pnum 379, drop this block
        [11.060]ubi0 warning: scan_peb: bad ec header at pnum 380, drop this block
        [11.067]ubi0 warning: scan_peb: bad ec header at pnum 381, drop this block
        [11.074]ubi0 warning: scan_peb: bad ec header at pnum 382, drop this block
        [11.080]ubi0 warning: scan_peb: bad ec header at pnum 383, drop this block
        [11.087]ubi0 warning: scan_peb: bad ec header at pnum 384, drop this block
        [11.094]ubi0 warning: scan_peb: bad ec header at pnum 385, drop this block
        [11.101]ubi0 warning: scan_peb: bad ec header at pnum 386, drop this block
        [11.108]ubi0 warning: scan_peb: bad ec header at pnum 387, drop this block
        [11.115]ubi0 warning: scan_peb: bad ec header at pnum 388, drop this block
        [11.122]ubi0 warning: scan_peb: bad ec header at pnum 389, drop this block
        [11.129]ubi0 warning: scan_peb: bad ec header at pnum 390, drop this block
        [11.136]ubi0 warning: scan_peb: bad ec header at pnum 391, drop this block
        [11.143]ubi0 warning: scan_peb: bad ec header at pnum 392, drop this block
        [11.150]ubi0 warning: scan_peb: bad ec header at pnum 393, drop this block
        [11.157]ubi0 warning: scan_peb: bad ec header at pnum 394, drop this block
        [11.164]ubi0 warning: scan_peb: bad ec header at pnum 395, drop this block
        [11.171]ubi0 warning: scan_peb: bad ec header at pnum 396, drop this block
        [11.178]ubi0 warning: scan_peb: bad ec header at pnum 397, drop this block
        [11.185]ubi0 warning: scan_peb: bad ec header at pnum 398, drop this block
        [11.192]ubi0 warning: scan_peb: bad ec header at pnum 399, drop this block
        [11.199]ubi0 warning: scan_peb: bad ec header at pnum 400, drop this block
        [11.205]ubi0 warning: scan_peb: bad ec header at pnum 401, drop this block
        [11.212]ubi0 warning: scan_peb: bad ec header at pnum 402, drop this block
        [11.219]ubi0 warning: scan_peb: bad ec header at pnum 403, drop this block
        [11.226]ubi0 warning: scan_peb: bad ec header at pnum 404, drop this block
        [11.233]ubi0 warning: scan_peb: bad ec header at pnum 405, drop this block
        [11.240]ubi0 warning: scan_peb: bad ec header at pnum 406, drop this block
        [11.247]ubi0 warning: scan_peb: bad ec header at pnum 407, drop this block
        [11.254]ubi0 warning: scan_peb: bad ec header at pnum 408, drop this block
        [11.261]ubi0 warning: scan_peb: bad ec header at pnum 409, drop this block
        [11.268]ubi0 warning: scan_peb: bad ec header at pnum 410, drop this block
        [11.275]ubi0 warning: scan_peb: bad ec header at pnum 411, drop this block
        [11.282]ubi0 warning: scan_peb: bad ec header at pnum 412, drop this block
        [11.289]ubi0 warning: scan_peb: bad ec header at pnum 413, drop this block
        [11.296]ubi0 warning: scan_peb: bad ec header at pnum 414, drop this block
        [11.303]ubi0 warning: scan_peb: bad ec header at pnum 415, drop this block
        [11.310]ubi0 warning: scan_peb: bad ec header at pnum 416, drop this block
        [11.317]ubi0 warning: scan_peb: bad ec header at pnum 417, drop this block
        [11.323]ubi0 warning: scan_peb: bad ec header at pnum 418, drop this block
        [11.330]ubi0 warning: scan_peb: bad ec header at pnum 419, drop this block
        [11.337]ubi0 warning: scan_peb: bad ec header at pnum 420, drop this block
        [11.344]ubi0 warning: scan_peb: bad ec header at pnum 421, drop this block
        [11.351]ubi0 warning: scan_peb: bad ec header at pnum 422, drop this block
        [11.358]ubi0 warning: scan_peb: bad ec header at pnum 423, drop this block
        [11.365]ubi0 warning: scan_peb: bad ec header at pnum 424, drop this block
        [11.372]ubi0 warning: scan_peb: bad ec header at pnum 425, drop this block
        [11.379]ubi0 warning: scan_peb: bad ec header at pnum 426, drop this block
        [11.386]ubi0 warning: scan_peb: bad ec header at pnum 427, drop this block
        [11.393]ubi0 warning: scan_peb: bad ec header at pnum 428, drop this block
        [11.400]ubi0 warning: scan_peb: bad ec header at pnum 429, drop this block
        [11.407]ubi0 warning: scan_peb: bad ec header at pnum 430, drop this block
        [11.414]ubi0 warning: scan_peb: bad ec header at pnum 431, drop this block
        [11.421]ubi0 warning: scan_peb: bad ec header at pnum 432, drop this block
        [11.428]ubi0 warning: scan_peb: bad ec header at pnum 433, drop this block
        [11.435]ubi0 warning: scan_peb: bad ec header at pnum 434, drop this block
        [11.441]ubi0 warning: scan_peb: bad ec header at pnum 435, drop this block
        [11.448]ubi0 warning: scan_peb: bad ec header at pnum 436, drop this block
        [11.455]ubi0 warning: scan_peb: bad ec header at pnum 437, drop this block
        [11.462]ubi0 warning: scan_peb: bad ec header at pnum 438, drop this block
        [11.469]ubi0 warning: scan_peb: bad ec header at pnum 439, drop this block
        [11.476]ubi0 warning: scan_peb: bad ec header at pnum 440, drop this block
        [11.483]ubi0 warning: scan_peb: bad ec header at pnum 441, drop this block
        [11.490]ubi0 warning: scan_peb: bad ec header at pnum 442, drop this block
        [11.497]ubi0 warning: scan_peb: bad ec header at pnum 443, drop this block
        [11.504]ubi0 warning: scan_peb: bad ec header at pnum 444, drop this block
        [11.511]ubi0 warning: scan_peb: bad ec header at pnum 445, drop this block
        [11.518]ubi0 warning: scan_peb: bad ec header at pnum 446, drop this block
        [11.525]ubi0 warning: scan_peb: bad ec header at pnum 447, drop this block
        [11.532]ubi0 warning: scan_peb: bad ec header at pnum 448, drop this block
        [11.539]ubi0 warning: scan_peb: bad ec header at pnum 449, drop this block
        [11.546]ubi0 warning: scan_peb: bad ec header at pnum 450, drop this block
        [11.553]ubi0 warning: scan_peb: bad ec header at pnum 451, drop this block
        [11.560]ubi0 warning: scan_peb: bad ec header at pnum 452, drop this block
        [11.566]ubi0 warning: scan_peb: bad ec header at pnum 453, drop this block
        [11.573]ubi0 warning: scan_peb: bad ec header at pnum 454, drop this block
        [11.580]ubi0 warning: scan_peb: bad ec header at pnum 455, drop this block
        [11.587]ubi0 warning: scan_peb: bad ec header at pnum 456, drop this block
        [11.594]ubi0 warning: scan_peb: bad ec header at pnum 457, drop this block
        [11.601]ubi0 warning: scan_peb: bad ec header at pnum 458, drop this block
        [11.608]ubi0 warning: scan_peb: bad ec header at pnum 459, drop this block
        [11.615]ubi0 warning: scan_peb: bad ec header at pnum 460, drop this block
        [11.622]ubi0 warning: scan_peb: bad ec header at pnum 461, drop this block
        [11.629]ubi0 warning: scan_peb: bad ec header at pnum 462, drop this block
        [11.636]ubi0 warning: scan_peb: bad ec header at pnum 463, drop this block
        [11.643]ubi0 warning: scan_peb: bad ec header at pnum 464, drop this block
        [11.650]ubi0 warning: scan_peb: bad ec header at pnum 465, drop this block
        [11.657]ubi0 warning: scan_peb: bad ec header at pnum 466, drop this block
        [11.664]ubi0 warning: scan_peb: bad ec header at pnum 467, drop this block
        [11.671]ubi0 warning: scan_peb: bad ec header at pnum 468, drop this block
        [11.678]ubi0 warning: scan_peb: bad ec header at pnum 469, drop this block
        [11.684]ubi0 warning: scan_peb: bad ec header at pnum 470, drop this block
        [11.691]ubi0 warning: scan_peb: bad ec header at pnum 471, drop this block
        [11.698]ubi0 warning: scan_peb: bad ec header at pnum 472, drop this block
        [11.705]ubi0 warning: scan_peb: bad ec header at pnum 473, drop this block
        [11.712]ubi0 warning: scan_peb: bad ec header at pnum 474, drop this block
        [11.719]ubi0 warning: scan_peb: bad ec header at pnum 475, drop this block
        [11.726]ubi0 warning: scan_peb: bad ec header at pnum 476, drop this block
        [11.733]ubi0 warning: scan_peb: bad ec header at pnum 477, drop this block
        [11.740]ubi0 warning: scan_peb: bad ec header at pnum 478, drop this block
        [11.747]ubi0 warning: scan_peb: bad ec header at pnum 479, drop this block
        [11.754]ubi0 warning: scan_peb: bad ec header at pnum 480, drop this block
        [11.761]ubi0 warning: scan_peb: bad ec header at pnum 481, drop this block
        [11.768]ubi0 warning: scan_peb: bad ec header at pnum 482, drop this block
        [11.775]ubi0 warning: scan_peb: bad ec header at pnum 483, drop this block
        [11.782]ubi0 warning: scan_peb: bad ec header at pnum 484, drop this block
        [11.789]ubi0 warning: scan_peb: bad ec header at pnum 485, drop this block
        [11.796]ubi0 warning: scan_peb: bad ec header at pnum 486, drop this block
        [11.802]ubi0 warning: scan_peb: bad ec header at pnum 487, drop this block
        [11.809]ubi0 warning: scan_peb: bad ec header at pnum 488, drop this block
        [11.816]ubi0 warning: scan_peb: bad ec header at pnum 489, drop this block
        [11.823]ubi0 warning: scan_peb: bad ec header at pnum 490, drop this block
        [11.830]ubi0 warning: scan_peb: bad ec header at pnum 491, drop this block
        [11.837]ubi0: scanning is finished
        [11.840]ubi0: empty MTD device detected
        [11.886]ubi0: attached mtd4 (name "sys", size 123 MiB)
        [11.891]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
        [11.897]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
        [11.904]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
        [11.910]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
        [11.915]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
        [11.922]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
        [11.930]ubi0: available PEBs: 468, total reserved PEBs: 24, PEBs reserved for bad PEB handling: 20
        [13.104]erase blk 0 to blk 32
        [13.124]erase blk 40 to blk 1024
        [13.674]sunxi-spinand: spinand secure storage ok for phy blk 32 and 33
        [13.680]sunxi-spinand: secure storage blks have never used before
        [13.687]sunxi-spinand: secure storage has no valid data on item 0
        [13.693]Item0 (Map) magic is bad
        [13.696]the secure storage map is empty
        [13.877]sunxi-spinand: write secure storage itme 0 ok
        [13.881]erase secure storage: 0 ok
        SUNXI_EFEX_MBR_TAG
        mbr size = 0x10000
        force mbr
        defaults:
        mtdids  : nand0=nand
        [13.935]MTD info (4)
        [13.937]pagesize: 0x1000
        [13.939]blksize: 0x40000
        [13.942]num  offset     bytes      name
        [13.945]0    0x00000000 0x00100000 boot0
        [13.949]1    0x00100000 0x00300000 uboot
        [13.953]2    0x00400000 0x00100000 secure_storage
        [13.957]3    0x00500000 0x07b00000 sys
        [13.960]MBR info (unalign):
        [13.963]partno   addr       sects      type       name
        [13.968]0        0x00000000 0x00008000 0x00000001 mbr
        [13.973]1        0x00008000 0x00000800 0x00008000 boot-resource
        [13.978]2        0x00008800 0x000001f8 0x00008000 env
        [13.983]3        0x000089f8 0x000001f8 0x00008000 env-redund
        [13.988]4        0x00008bf0 0x00005000 0x00008000 boot
        [13.993]5        0x0000dbf0 0x000103e8 0x00008000 rootfs
        [13.998]6        0x0001dfd8 0x00005780 0x00008000 recovery
        [14.003]7        0x00023758 0x000078f0 0x00008000 rootfs_data
        [14.009]8        0x0002b048 0x00000000 0x00000000 UDISK
        [14.014]ubi attach the last part of mtd device: NO.3
        [14.019]MBR info (align):
        [14.021]partno   addr       sects      type       name
        [14.026]0        0x00002800 0x000081f0 0x00000001 mbr
        [14.030]1        0x0000a9f0 0x000009d8 0x00008000 boot-resource
        [14.036]2        0x0000b3c8 0x000001f8 0x00008000 env
        [14.041]3        0x0000b5c0 0x000001f8 0x00008000 env-redund
        [14.046]4        0x0000b7b8 0x000050b8 0x00008000 boot
        [14.051]5        0x00010870 0x000105d8 0x00008000 rootfs
        [14.056]6        0x00020e48 0x00005898 0x00008000 recovery
        [14.061]7        0x000266e0 0x00007a10 0x00008000 rootfs_data
        [14.067]8        0x0002e0f0 0x00000000 0x00000000 UDISK
        [14.072]ubi attach the last part of mtd device: NO.3
        [14.076]ubi attatch mtd, name: sys
        [14.080]ubi0: detaching mtd4
        [14.085]ubi0: mtd4 is detached
        [14.088]ubi0: attaching mtd4
        [14.227]ubi0: scanning is finished
        [14.230]ubi0: empty MTD device detected
        [14.277]ubi0: attached mtd4 (name "sys", size 123 MiB)
        [14.281]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
        [14.288]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
        [14.294]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
        [14.300]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
        [14.305]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
        [14.312]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
        [14.320]ubi0: available PEBs: 468, total reserved PEBs: 24, PEBs reserved for bad PEB handling: 20
        [15.755]reset last volume size to 0xe070
        [15.856]fill gap start: volume mbr sects 0x7f80
        [27.949]ubi0 warning: ubi_io_read_vid_hdr: bad magic number at PEB 149: ddcecded instead of 55424921
        [27.958]Volume identifier header dump:
        [27.961]        magic     ddcecded
        [27.964]        version   205
        [27.966]        vol_type  206
        [27.968]        copy_flag 204
        [27.970]        compat    204
        [27.972]        vol_id    -858993460
        [27.975]        lnum      -858993460
        [27.978]        data_size -858784564
        [27.980]        used_ebs  -858993458
        [27.983]        data_pad  -858993460
        [27.986]        sqnum     14757395258967641311
        [27.989]        hdr_crc   dffcfdcc
        [27.992]Volume identifier header hexdump:
        [27.996]ubi0 warning: ubi_eba_read_leb: corrupted VID header at PEB 149, LEB 0:0
        [28.003]ubi0 warning: ubi_volume_continue_write: volume 0 on UBI device 0 is corrupt
        [28.010]fill gap end: volume mbr
        [28.014]update partition map
        [28.016]logical area info: 468 258048 last_lba: 235871
        read from corrupted volume 0[28.035]mbr magic error: ▒▒▒▒▒▒▒▒ wanted softw411
        read from corrupted volume 0[28.060]mbr magic error: ▒▒▒▒▒▒▒▒ wanted softw411
        FEX_CMD_fes_verify_status
        FEX_CMD_fes_verify last err=0
        [28.402]fill gap start: volume boot-resource sects 0x264
        [28.631]fill gap end: volume boot-resource
        改成20M也还是炸了
        • U
          uuuuid LV 6 最后由 编辑
          [1208]fes begin commit:88480af-dirty
          [1211]set pll start
          [1213]periph0 has been enabled
          [1216]set pll end
          [1218][pmu]: bus read error
          [1221]board init ok
          [1222]beign to init dram
          [1225]ZQ value = 0x2f
          [1227]get_pmu_exist() = -1
          [1229]ddr_efuse_type: 0xa
          [1232]trefi:7.8ms
          [1234][AUTO DEBUG] single rank and full DQ!
          [1238]ddr_efuse_type: 0xa
          [1240]trefi:7.8ms
          [1242][AUTO DEBUG] rank 0 row = 13
          [1246][AUTO DEBUG] rank 0 bank = 4
          [1249][AUTO DEBUG] rank 0 page size = 2 KB
          [1253]DRAM BOOT DRIVE INFO: V0.33
          [1256]DRAM CLK = 528 MHz
          [1258]DRAM Type = 2 (2:DDR2,3:DDR3)
          [1261]DRAMC read ODT  off.
          [1264]DRAM ODT off.
          [1266]ddr_efuse_type: 0xa
          [1269]DRAM SIZE =64 M
          [1271]dram_tpr4:0x0
          [1273]PLL_DDR_CTRL_REG:0xf8002b00
          [1276]DRAM_CLK_REG:0xc0000000
          [1278][TIMING DEBUG] MR2= 0x0
          [1283]DRAM simple test OK.
          [1285]init dram ok
          U-Boot 2018.05-g24521d6-dirty (Nov 13 2022 - 12:44:07 +0800) Allwinner Technology
          [04.463]DRAM:  64 MiB
          [04.468]Relocation Offset is: 01ee3000
          [04.494]secure enable bit: 0
          [04.500]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
          [04.507]flash init start
          [04.509]workmode = 16,storage type = 0
          try card 2
          set card number 2
          get card number 2
          [04.517][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
          [04.526][mmc]: get sdc_type fail and use default host:tm4.
          [04.559][mmc]: Is not Boot mode!
          [04.562][mmc]: SUNXI SDMMC Controller Version:0x50310
          [04.573][mmc]: ************Try SD card 2************
          [04.578][mmc]: mmc 2 cmd timeout 100 status 100
          [04.582][mmc]: smc 2 err, cmd 8,  RTO
          [04.586][mmc]: mmc 2 close bus gating and reset
          [04.591][mmc]: mmc 2 cmd timeout 100 status 100
          [04.595][mmc]: smc 2 err, cmd 55,  RTO
          [04.599][mmc]: mmc 2 close bus gating and reset
          [04.603][mmc]: ************Try MMC card 2************
          [04.612][mmc]: mmc 2 cmd timeout 100 status 100
          [04.616][mmc]: smc 2 err, cmd 1,  RTO
          [04.619][mmc]: mmc 2 close bus gating and reset
          [04.624][mmc]: Card did not respond to voltage select!
          [04.628][mmc]: ************SD/MMC 2 init error!************
          [04.634][mmc]: mmc init product failed
          MMC init failed
          try emmc fail
          [04.650]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
          [04.656]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
          [04.722]sunxi-spinand-phy: request spi0 gpio ok
          [04.726]sunxi-spinand-phy: request general tx dma channel ok!
          [04.731]sunxi-spinand-phy: request general rx dma channel ok!
          [04.737]sunxi-spinand-phy: set spic0 clk to 20 Mhz
          [04.741]sunxi-spinand-phy: init spic0 clk ok
          [04.787]sunxi-spinand-phy: not detect any munufacture from id table
          [04.803]sunxi-spinand-phy: get spi-nand Model from fdt fail
          [04.809]sunxi-spinand-phy: get phy info from fdt fail
          [04.813]sunxi-spinand-phy: not detect munufacture from fdt
          [04.819]sunxi-spinand-phy: detect munufacture from id table: Winbond
          [04.825]sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
          [04.830]sunxi-spinand-phy: ========== arch info ==========
          [04.835]sunxi-spinand-phy: Model:               W25N01GVZEIG
          [04.841]sunxi-spinand-phy: Munufacture:         Winbond
          [04.846]sunxi-spinand-phy: DieCntPerChip:       1
          [04.850]sunxi-spinand-phy: BlkCntPerDie:        1024
          [04.855]sunxi-spinand-phy: PageCntPerBlk:       64
          [04.859]sunxi-spinand-phy: SectCntPerPage:      4
          [04.864]sunxi-spinand-phy: OobSizePerPage:      64
          [04.868]sunxi-spinand-phy: BadBlockFlag:        0x0
          [04.873]sunxi-spinand-phy: OperationOpt:        0x7
          [04.878]sunxi-spinand-phy: MaxEraseTimes:       65000
          [04.882]sunxi-spinand-phy: EccFlag:             0x0
          [04.887]sunxi-spinand-phy: EccType:             2
          [04.891]sunxi-spinand-phy: EccProtectedType:    3
          [04.896]sunxi-spinand-phy: ========================================
          [04.902]sunxi-spinand-phy:
          [04.904]sunxi-spinand-phy: ========== physical info ==========
          [04.910]sunxi-spinand-phy: TotalSize:    128 M
          [04.914]sunxi-spinand-phy: SectorSize:   512 B
          [04.918]sunxi-spinand-phy: PageSize:     2 K
          [04.922]sunxi-spinand-phy: BlockSize:    128 K
          [04.926]sunxi-spinand-phy: OOBSize:      64 B
          [04.930]sunxi-spinand-phy: ========================================
          [04.936]sunxi-spinand-phy:
          [04.939]sunxi-spinand-phy: ========== logical info ==========
          [04.944]sunxi-spinand-phy: TotalSize:    128 M
          [04.948]sunxi-spinand-phy: SectorSize:   512 B
          [04.953]sunxi-spinand-phy: PageSize:     4 K
          [04.957]sunxi-spinand-phy: BlockSize:    256 K
          [04.961]sunxi-spinand-phy: OOBSize:      128 B
          [04.965]sunxi-spinand-phy: ========================================
          [04.982]sunxi-spinand-phy: set spic0 clk to 6 Mhz
          [04.986]sunxi-spinand-phy: block lock register: 0x00
          [04.991]sunxi-spinand-phy: feature register: 0x19
          [04.995]sunxi-spinand-phy: sunxi physic nand init end
          [05.005]Loading Environment from SUNXI_FLASH... OK
          [05.019]try to burn key
          [05.023]out of usb burn from boot: not need burn key
          [05.027]Net:   [05.029]No ethernet found.
          sunxi work mode=0x10
          run usb efex
          delay time 2500
          weak:otg_phy_config
          usb init ok
          set address 0xd
          set address 0xd ok
          set address 0xc
          set address 0xc ok
          SUNXI_EFEX_ERASE_TAG
          erase_flag = 0x0
          origin_erase_flag = 0x1
          the 0 mbr table is ok
          the 1 mbr table is ok
          the 2 mbr table is ok
          the 3 mbr table is ok
          total mbr part 8
          part[0] classname :DISK
          part[0] addrlo    :0x8000
          part[0] lenlo     :0x800
          part[0] user_type :32768
          part[0] keydata   :0
          part[0] ro        :0
          part[1] name      :env
          part[1] classname :DISK
          part[1] addrlo    :0x8800
          part[1] lenlo     :0x1f8
          part[1] user_type :32768
          part[1] keydata   :0
          part[1] ro        :0
          part[2] name      :env-redund
          part[2] classname :DISK
          part[2] addrlo    :0x89f8
          part[2] lenlo     :0x1f8
          part[2] user_type :32768
          part[2] keydata   :0
          part[2] ro        :0
          part[3] name      :boot
          part[3] classname :DISK
          part[3] addrlo    :0x8bf0
          part[3] lenlo     :0x5000
          part[3] user_type :32768
          part[3] keydata   :0
          part[3] ro        :0
          part[4] name      :rootfs
          part[4] classname :DISK
          part[4] addrlo    :0xdbf0
          part[4] lenlo     :0x103e8
          part[4] user_type :32768
          part[4] keydata   :0
          part[4] ro        :0
          part[5] name      :recovery
          part[5] classname :DISK
          part[5] addrlo    :0x1dfd8
          part[5] lenlo     :0x5780
          part[5] user_type :32768
          part[5] keydata   :0
          part[5] ro        :0
          part[6] classname :DISK
          part[6] addrlo    :0x23758
          part[6] lenlo     :0x78f0
          part[6] user_type :32768
          part[6] keydata   :0
          part[6] ro        :0
          part[7] name      :UDISK
          part[7] classname :DISK
          part[7] addrlo    :0x2b048
          part[7] lenlo     :0x0
          part[7] user_type :0
          part[7] keydata   :0
          part[7] ro        :0
          total part: 9
          mbr 0, 8000, 8000
          boot-resource 1, 800, 8000
          env 2, 1f8, 8000
          env-redund 3, 1f8, 8000
          boot 4, 5000, 8000
          rootfs 5, 103e8, 8000
          recovery 6, 5780, 8000
          rootfs_data 7, 78f0, 8000
          UDISK 8, 0, 0
          [08.358]erase blk 0 to blk 32
          need erase flash: 0
          [08.385]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
          defaults:
          mtdids  : nand0=nand
          [08.445]MTD info (4)
          [08.447]pagesize: 0x1000
          [08.449]blksize: 0x40000
          [08.451]num  offset     bytes      name
          [08.455]0    0x00000000 0x00100000 boot0
          [08.459]1    0x00100000 0x00300000 uboot
          [08.462]2    0x00400000 0x00100000 secure_storage
          [08.467]3    0x00500000 0x07b00000 sys
          [08.470]ubi attach the last part of mtd device: NO.3
          [08.592]ubi0: attaching mtd4
          [08.595]ubi0 warning: scan_peb: bad ec header at pnum 0, drop this block
          [08.602]ubi0 warning: scan_peb: bad ec header at pnum 1, drop this block
          [08.609]ubi0 warning: scan_peb: bad ec header at pnum 2, drop this block
          [08.616]ubi0 warning: scan_peb: bad ec header at pnum 3, drop this block
          [08.623]ubi0 warning: scan_peb: bad ec header at pnum 4, drop this block
          [08.629]ubi0 warning: scan_peb: bad ec header at pnum 5, drop this block
          [08.636]ubi0 warning: scan_peb: bad ec header at pnum 6, drop this block
          [08.643]ubi0 warning: scan_peb: bad ec header at pnum 7, drop this block
          [08.650]ubi0 warning: scan_peb: bad ec header at pnum 8, drop this block
          [08.657]ubi0 warning: scan_peb: bad ec header at pnum 9, drop this block
          [08.664]ubi0 warning: scan_peb: bad ec header at pnum 10, drop this block
          [08.671]ubi0 warning: scan_peb: bad ec header at pnum 11, drop this block
          [08.678]ubi0 warning: scan_peb: bad ec header at pnum 12, drop this block
          [08.684]ubi0 warning: scan_peb: bad ec header at pnum 13, drop this block
          [08.691]ubi0 warning: scan_peb: bad ec header at pnum 14, drop this block
          [08.698]ubi0 warning: scan_peb: bad ec header at pnum 15, drop this block
          [08.705]ubi0 warning: scan_peb: bad ec header at pnum 16, drop this block
          [08.712]ubi0 warning: scan_peb: bad ec header at pnum 17, drop this block
          [08.719]ubi0 warning: scan_peb: bad ec header at pnum 18, drop this block
          [08.726]ubi0 warning: scan_peb: bad ec header at pnum 19, drop this block
          [08.733]ubi0 warning: scan_peb: bad ec header at pnum 20, drop this block
          [08.740]ubi0 warning: scan_peb: bad ec header at pnum 21, drop this block
          [08.747]ubi0 warning: scan_peb: bad ec header at pnum 22, drop this block
          [08.754]ubi0 warning: scan_peb: bad ec header at pnum 23, drop this block
          [08.761]ubi0 warning: scan_peb: bad ec header at pnum 24, drop this block
          [08.768]ubi0 warning: scan_peb: bad ec header at pnum 25, drop this block
          [08.775]ubi0 warning: scan_peb: bad ec header at pnum 26, drop this block
          [08.782]ubi0 warning: scan_peb: bad ec header at pnum 27, drop this block
          [08.789]ubi0 warning: scan_peb: bad ec header at pnum 28, drop this block
          [08.796]ubi0 warning: scan_peb: bad ec header at pnum 29, drop this block
          [08.802]ubi0 warning: scan_peb: bad ec header at pnum 30, drop this block
          [08.809]ubi0 warning: scan_peb: bad ec header at pnum 31, drop this block
          [08.816]ubi0 warning: scan_peb: bad ec header at pnum 32, drop this block
          [08.823]ubi0 warning: scan_peb: bad ec header at pnum 33, drop this block
          [08.830]ubi0 warning: scan_peb: bad ec header at pnum 34, drop this block
          [08.837]ubi0 warning: scan_peb: bad ec header at pnum 35, drop this block
          [08.844]ubi0 warning: scan_peb: bad ec header at pnum 36, drop this block
          [08.851]ubi0 warning: scan_peb: bad ec header at pnum 37, drop this block
          [08.858]ubi0 warning: scan_peb: bad ec header at pnum 38, drop this block
          [08.865]ubi0 warning: scan_peb: bad ec header at pnum 39, drop this block
          [08.872]ubi0 warning: scan_peb: bad ec header at pnum 40, drop this block
          [08.879]ubi0 warning: scan_peb: bad ec header at pnum 41, drop this block
          [08.886]ubi0 warning: scan_peb: bad ec header at pnum 42, drop this block
          [08.893]ubi0 warning: scan_peb: bad ec header at pnum 43, drop this block
          [08.900]ubi0 warning: scan_peb: bad ec header at pnum 44, drop this block
          [08.907]ubi0 warning: scan_peb: bad ec header at pnum 45, drop this block
          [08.914]ubi0 warning: scan_peb: bad ec header at pnum 46, drop this block
          [08.920]ubi0 warning: scan_peb: bad ec header at pnum 47, drop this block
          [08.927]ubi0 warning: scan_peb: bad ec header at pnum 48, drop this block
          [08.934]ubi0 warning: scan_peb: bad ec header at pnum 49, drop this block
          [08.941]ubi0 warning: scan_peb: bad ec header at pnum 50, drop this block
          [08.948]ubi0 warning: scan_peb: bad ec header at pnum 51, drop this block
          [08.955]ubi0 warning: scan_peb: bad ec header at pnum 52, drop this block
          [08.962]ubi0 warning: scan_peb: bad ec header at pnum 53, drop this block
          [08.969]ubi0 warning: scan_peb: bad ec header at pnum 54, drop this block
          [08.976]ubi0 warning: scan_peb: bad ec header at pnum 55, drop this block
          [08.983]ubi0 warning: scan_peb: bad ec header at pnum 56, drop this block
          [08.990]ubi0 warning: scan_peb: bad ec header at pnum 57, drop this block
          [08.997]ubi0 warning: scan_peb: bad ec header at pnum 58, drop this block
          [09.004]ubi0 warning: scan_peb: bad ec header at pnum 59, drop this block
          [09.011]ubi0 warning: scan_peb: bad ec header at pnum 60, drop this block
          [09.018]ubi0 warning: scan_peb: bad ec header at pnum 61, drop this block
          [09.025]ubi0 warning: scan_peb: bad ec header at pnum 62, drop this block
          [09.032]ubi0 warning: scan_peb: bad ec header at pnum 63, drop this block
          [09.038]ubi0 warning: scan_peb: bad ec header at pnum 64, drop this block
          [09.045]ubi0 warning: scan_peb: bad ec header at pnum 65, drop this block
          [09.052]ubi0 warning: scan_peb: bad ec header at pnum 66, drop this block
          [09.059]ubi0 warning: scan_peb: bad ec header at pnum 67, drop this block
          [09.066]ubi0 warning: scan_peb: bad ec header at pnum 68, drop this block
          [09.073]ubi0 warning: scan_peb: bad ec header at pnum 69, drop this block
          [09.080]ubi0 warning: scan_peb: bad ec header at pnum 70, drop this block
          [09.087]ubi0 warning: scan_peb: bad ec header at pnum 71, drop this block
          [09.094]ubi0 warning: scan_peb: bad ec header at pnum 72, drop this block
          [09.101]ubi0 warning: scan_peb: bad ec header at pnum 73, drop this block
          [09.108]ubi0 warning: scan_peb: bad ec header at pnum 74, drop this block
          [09.115]ubi0 warning: scan_peb: bad ec header at pnum 75, drop this block
          [09.122]ubi0 warning: scan_peb: bad ec header at pnum 76, drop this block
          [09.129]ubi0 warning: scan_peb: bad ec header at pnum 77, drop this block
          [09.136]ubi0 warning: scan_peb: bad ec header at pnum 78, drop this block
          [09.143]ubi0 warning: scan_peb: bad ec header at pnum 79, drop this block
          [09.150]ubi0 warning: scan_peb: bad ec header at pnum 80, drop this block
          [09.156]ubi0 warning: scan_peb: bad ec header at pnum 81, drop this block
          [09.163]ubi0 warning: scan_peb: bad ec header at pnum 82, drop this block
          [09.170]ubi0 warning: scan_peb: bad ec header at pnum 83, drop this block
          [09.177]ubi0 warning: scan_peb: bad ec header at pnum 84, drop this block
          [09.184]ubi0 warning: scan_peb: bad ec header at pnum 85, drop this block
          [09.191]ubi0 warning: scan_peb: bad ec header at pnum 86, drop this block
          [09.198]ubi0 warning: scan_peb: bad ec header at pnum 87, drop this block
          [09.205]ubi0 warning: scan_peb: bad ec header at pnum 88, drop this block
          [09.212]ubi0 warning: scan_peb: bad ec header at pnum 89, drop this block
          [09.219]ubi0 warning: scan_peb: bad ec header at pnum 90, drop this block
          [09.226]ubi0 warning: scan_peb: bad ec header at pnum 91, drop this block
          [09.233]ubi0 warning: scan_peb: bad ec header at pnum 92, drop this block
          [09.240]ubi0 warning: scan_peb: bad ec header at pnum 93, drop this block
          [09.247]ubi0 warning: scan_peb: bad ec header at pnum 94, drop this block
          [09.254]ubi0 warning: scan_peb: bad ec header at pnum 95, drop this block
          [09.261]ubi0 warning: scan_peb: bad ec header at pnum 96, drop this block
          [09.268]ubi0 warning: scan_peb: bad ec header at pnum 97, drop this block
          [09.274]ubi0 warning: scan_peb: bad ec header at pnum 98, drop this block
          [09.281]ubi0 warning: scan_peb: bad ec header at pnum 99, drop this block
          [09.288]ubi0 warning: scan_peb: bad ec header at pnum 100, drop this block
          [09.295]ubi0 warning: scan_peb: bad ec header at pnum 101, drop this block
          [09.302]ubi0 warning: scan_peb: bad ec header at pnum 102, drop this block
          [09.309]ubi0 warning: scan_peb: bad ec header at pnum 103, drop this block
          [09.316]ubi0 warning: scan_peb: bad ec header at pnum 104, drop this block
          [09.323]ubi0 warning: scan_peb: bad ec header at pnum 105, drop this block
          [09.331]ubi0 warning: scan_peb: bad ec header at pnum 106, drop this block
          [09.338]ubi0 warning: scan_peb: bad ec header at pnum 107, drop this block
          [09.345]ubi0 warning: scan_peb: bad ec header at pnum 108, drop this block
          [09.352]ubi0 warning: scan_peb: bad ec header at pnum 109, drop this block
          [09.359]ubi0 warning: scan_peb: bad ec header at pnum 110, drop this block
          [09.366]ubi0 warning: scan_peb: bad ec header at pnum 111, drop this block
          [09.373]ubi0 warning: scan_peb: bad ec header at pnum 112, drop this block
          [09.380]ubi0 warning: scan_peb: bad ec header at pnum 113, drop this block
          [09.387]ubi0 warning: scan_peb: bad ec header at pnum 114, drop this block
          [09.394]ubi0 warning: scan_peb: bad ec header at pnum 115, drop this block
          [09.401]ubi0 warning: scan_peb: bad ec header at pnum 116, drop this block
          [09.408]ubi0 warning: scan_peb: bad ec header at pnum 117, drop this block
          [09.415]ubi0 warning: scan_peb: bad ec header at pnum 118, drop this block
          [09.422]ubi0 warning: scan_peb: bad ec header at pnum 119, drop this block
          [09.429]ubi0 warning: scan_peb: bad ec header at pnum 120, drop this block
          [09.436]ubi0 warning: scan_peb: bad ec header at pnum 121, drop this block
          [09.443]ubi0 warning: scan_peb: bad ec header at pnum 122, drop this block
          [09.450]ubi0 warning: scan_peb: bad ec header at pnum 123, drop this block
          [09.457]ubi0 warning: scan_peb: bad ec header at pnum 124, drop this block
          [09.464]ubi0 warning: scan_peb: bad ec header at pnum 125, drop this block
          [09.471]ubi0 warning: scan_peb: bad ec header at pnum 126, drop this block
          [09.478]ubi0 warning: scan_peb: bad ec header at pnum 127, drop this block
          [09.485]ubi0 warning: scan_peb: bad ec header at pnum 128, drop this block
          [09.492]ubi0 warning: scan_peb: bad ec header at pnum 129, drop this block
          [09.499]ubi0 warning: scan_peb: bad ec header at pnum 130, drop this block
          [09.506]ubi0 warning: scan_peb: bad ec header at pnum 131, drop this block
          [09.513]ubi0 warning: scan_peb: bad ec header at pnum 132, drop this block
          [09.520]ubi0 warning: scan_peb: bad ec header at pnum 133, drop this block
          [09.527]ubi0 warning: scan_peb: bad ec header at pnum 134, drop this block
          [09.534]ubi0 warning: scan_peb: bad ec header at pnum 135, drop this block
          [09.541]ubi0 warning: scan_peb: bad ec header at pnum 136, drop this block
          [09.548]ubi0 warning: scan_peb: bad ec header at pnum 137, drop this block
          [09.555]ubi0 warning: scan_peb: bad ec header at pnum 138, drop this block
          [09.562]ubi0 warning: scan_peb: bad ec header at pnum 139, drop this block
          [09.569]ubi0 warning: scan_peb: bad ec header at pnum 140, drop this block
          [09.577]ubi0 warning: scan_peb: bad ec header at pnum 141, drop this block
          [09.584]ubi0 warning: scan_peb: bad ec header at pnum 142, drop this block
          [09.591]ubi0 warning: scan_peb: bad ec header at pnum 143, drop this block
          [09.598]ubi0 warning: scan_peb: bad ec header at pnum 144, drop this block
          [09.605]ubi0 warning: scan_peb: bad ec header at pnum 145, drop this block
          [09.612]ubi0 warning: scan_peb: bad ec header at pnum 146, drop this block
          [09.619]ubi0 warning: scan_peb: bad ec header at pnum 147, drop this block
          [09.626]ubi0 warning: scan_peb: bad ec header at pnum 148, drop this block
          [09.633]ubi0 warning: scan_peb: bad ec header at pnum 149, drop this block
          [09.640]ubi0 warning: scan_peb: bad ec header at pnum 150, drop this block
          [09.647]ubi0 warning: scan_peb: bad ec header at pnum 151, drop this block
          [09.654]ubi0 warning: scan_peb: bad ec header at pnum 152, drop this block
          [09.661]ubi0 warning: scan_peb: bad ec header at pnum 153, drop this block
          [09.668]ubi0 warning: scan_peb: bad ec header at pnum 154, drop this block
          [09.675]ubi0 warning: scan_peb: bad ec header at pnum 155, drop this block
          [09.682]ubi0 warning: scan_peb: bad ec header at pnum 156, drop this block
          [09.689]ubi0 warning: scan_peb: bad ec header at pnum 157, drop this block
          [09.696]ubi0 warning: scan_peb: bad ec header at pnum 158, drop this block
          [09.703]ubi0 warning: scan_peb: bad ec header at pnum 159, drop this block
          [09.710]ubi0 warning: scan_peb: bad ec header at pnum 160, drop this block
          [09.717]ubi0 warning: scan_peb: bad ec header at pnum 161, drop this block
          [09.724]ubi0 warning: scan_peb: bad ec header at pnum 162, drop this block
          [09.731]ubi0 warning: scan_peb: bad ec header at pnum 163, drop this block
          [09.738]ubi0 warning: scan_peb: bad ec header at pnum 164, drop this block
          [09.745]ubi0 warning: scan_peb: bad ec header at pnum 165, drop this block
          [09.752]ubi0 warning: scan_peb: bad ec header at pnum 166, drop this block
          [09.759]ubi0 warning: scan_peb: bad ec header at pnum 167, drop this block
          [09.766]ubi0 warning: scan_peb: bad ec header at pnum 168, drop this block
          [09.773]ubi0 warning: scan_peb: bad ec header at pnum 169, drop this block
          [09.780]ubi0 warning: scan_peb: bad ec header at pnum 170, drop this block
          [09.787]ubi0 warning: scan_peb: bad ec header at pnum 171, drop this block
          [09.794]ubi0 warning: scan_peb: bad ec header at pnum 172, drop this block
          [09.801]ubi0 warning: scan_peb: bad ec header at pnum 173, drop this block
          [09.808]ubi0 warning: scan_peb: bad ec header at pnum 174, drop this block
          [09.815]ubi0 warning: scan_peb: bad ec header at pnum 175, drop this block
          [09.823]ubi0 warning: scan_peb: bad ec header at pnum 176, drop this block
          [09.830]ubi0 warning: scan_peb: bad ec header at pnum 177, drop this block
          [09.837]ubi0 warning: scan_peb: bad ec header at pnum 178, drop this block
          [09.844]ubi0 warning: scan_peb: bad ec header at pnum 179, drop this block
          [09.851]ubi0 warning: scan_peb: bad ec header at pnum 180, drop this block
          [09.858]ubi0 warning: scan_peb: bad ec header at pnum 181, drop this block
          [09.865]ubi0 warning: scan_peb: bad ec header at pnum 182, drop this block
          [09.872]ubi0 warning: scan_peb: bad ec header at pnum 183, drop this block
          [09.879]ubi0 warning: scan_peb: bad ec header at pnum 184, drop this block
          [09.886]ubi0 warning: scan_peb: bad ec header at pnum 185, drop this block
          [09.893]ubi0 warning: scan_peb: bad ec header at pnum 186, drop this block
          [09.900]ubi0 warning: scan_peb: bad ec header at pnum 187, drop this block
          [09.907]ubi0 warning: scan_peb: bad ec header at pnum 188, drop this block
          [09.914]ubi0 warning: scan_peb: bad ec header at pnum 189, drop this block
          [09.921]ubi0 warning: scan_peb: bad ec header at pnum 190, drop this block
          [09.928]ubi0 warning: scan_peb: bad ec header at pnum 191, drop this block
          [09.935]ubi0 warning: scan_peb: bad ec header at pnum 192, drop this block
          [09.942]ubi0 warning: scan_peb: bad ec header at pnum 193, drop this block
          [09.949]ubi0 warning: scan_peb: bad ec header at pnum 194, drop this block
          [09.956]ubi0 warning: scan_peb: bad ec header at pnum 195, drop this block
          [09.963]ubi0 warning: scan_peb: bad ec header at pnum 196, drop this block
          [09.970]ubi0 warning: scan_peb: bad ec header at pnum 197, drop this block
          [09.977]ubi0 warning: scan_peb: bad ec header at pnum 198, drop this block
          [09.984]ubi0 warning: scan_peb: bad ec header at pnum 199, drop this block
          [09.991]ubi0 warning: scan_peb: bad ec header at pnum 200, drop this block
          [09.998]ubi0 warning: scan_peb: bad ec header at pnum 201, drop this block
          [10.005]ubi0 warning: scan_peb: bad ec header at pnum 202, drop this block
          [10.012]ubi0 warning: scan_peb: bad ec header at pnum 203, drop this block
          [10.019]ubi0 warning: scan_peb: bad ec header at pnum 204, drop this block
          [10.026]ubi0 warning: scan_peb: bad ec header at pnum 205, drop this block
          [10.033]ubi0 warning: scan_peb: bad ec header at pnum 206, drop this block
          [10.040]ubi0 warning: scan_peb: bad ec header at pnum 207, drop this block
          [10.047]ubi0 warning: scan_peb: bad ec header at pnum 208, drop this block
          [10.054]ubi0 warning: scan_peb: bad ec header at pnum 209, drop this block
          [10.062]ubi0 warning: scan_peb: bad ec header at pnum 210, drop this block
          [10.069]ubi0 warning: scan_peb: bad ec header at pnum 211, drop this block
          [10.076]ubi0 warning: scan_peb: bad ec header at pnum 212, drop this block
          [10.083]ubi0 warning: scan_peb: bad ec header at pnum 213, drop this block
          [10.090]ubi0 warning: scan_peb: bad ec header at pnum 214, drop this block
          [10.097]ubi0 warning: scan_peb: bad ec header at pnum 215, drop this block
          [10.104]ubi0 warning: scan_peb: bad ec header at pnum 216, drop this block
          [10.111]ubi0 warning: scan_peb: bad ec header at pnum 217, drop this block
          [10.118]ubi0 warning: scan_peb: bad ec header at pnum 218, drop this block
          [10.125]ubi0 warning: scan_peb: bad ec header at pnum 219, drop this block
          [10.132]ubi0 warning: scan_peb: bad ec header at pnum 220, drop this block
          [10.139]ubi0 warning: scan_peb: bad ec header at pnum 221, drop this block
          [10.146]ubi0 warning: scan_peb: bad ec header at pnum 222, drop this block
          [10.153]ubi0 warning: scan_peb: bad ec header at pnum 223, drop this block
          [10.160]ubi0 warning: scan_peb: bad ec header at pnum 224, drop this block
          [10.167]ubi0 warning: scan_peb: bad ec header at pnum 225, drop this block
          [10.174]ubi0 warning: scan_peb: bad ec header at pnum 226, drop this block
          [10.181]ubi0 warning: scan_peb: bad ec header at pnum 227, drop this block
          [10.188]ubi0 warning: scan_peb: bad ec header at pnum 228, drop this block
          [10.195]ubi0 warning: scan_peb: bad ec header at pnum 229, drop this block
          [10.202]ubi0 warning: scan_peb: bad ec header at pnum 230, drop this block
          [10.209]ubi0 warning: scan_peb: bad ec header at pnum 231, drop this block
          [10.216]ubi0 warning: scan_peb: bad ec header at pnum 232, drop this block
          [10.223]ubi0 warning: scan_peb: bad ec header at pnum 233, drop this block
          [10.230]ubi0 warning: scan_peb: bad ec header at pnum 234, drop this block
          [10.237]ubi0 warning: scan_peb: bad ec header at pnum 235, drop this block
          [10.244]ubi0 warning: scan_peb: bad ec header at pnum 236, drop this block
          [10.251]ubi0 warning: scan_peb: bad ec header at pnum 237, drop this block
          [10.258]ubi0 warning: scan_peb: bad ec header at pnum 238, drop this block
          [10.265]ubi0 warning: scan_peb: bad ec header at pnum 239, drop this block
          [10.272]ubi0 warning: scan_peb: bad ec header at pnum 240, drop this block
          [10.279]ubi0 warning: scan_peb: bad ec header at pnum 241, drop this block
          [10.286]ubi0 warning: scan_peb: bad ec header at pnum 242, drop this block
          [10.293]ubi0 warning: scan_peb: bad ec header at pnum 243, drop this block
          [10.300]ubi0 warning: scan_peb: bad ec header at pnum 244, drop this block
          [10.308]ubi0 warning: scan_peb: bad ec header at pnum 245, drop this block
          [10.315]ubi0 warning: scan_peb: bad ec header at pnum 246, drop this block
          [10.322]ubi0 warning: scan_peb: bad ec header at pnum 247, drop this block
          [10.329]ubi0 warning: scan_peb: bad ec header at pnum 248, drop this block
          [10.336]ubi0 warning: scan_peb: bad ec header at pnum 249, drop this block
          [10.343]ubi0 warning: scan_peb: bad ec header at pnum 250, drop this block
          [10.350]ubi0 warning: scan_peb: bad ec header at pnum 251, drop this block
          [10.357]ubi0 warning: scan_peb: bad ec header at pnum 252, drop this block
          [10.364]ubi0 warning: scan_peb: bad ec header at pnum 253, drop this block
          [10.371]ubi0 warning: scan_peb: bad ec header at pnum 254, drop this block
          [10.378]ubi0 warning: scan_peb: bad ec header at pnum 255, drop this block
          [10.385]ubi0 warning: scan_peb: bad ec header at pnum 256, drop this block
          [10.392]ubi0 warning: scan_peb: bad ec header at pnum 257, drop this block
          [10.399]ubi0 warning: scan_peb: bad ec header at pnum 258, drop this block
          [10.406]ubi0 warning: scan_peb: bad ec header at pnum 259, drop this block
          [10.413]ubi0 warning: scan_peb: bad ec header at pnum 260, drop this block
          [10.420]ubi0 warning: scan_peb: bad ec header at pnum 261, drop this block
          [10.427]ubi0 warning: scan_peb: bad ec header at pnum 262, drop this block
          [10.434]ubi0 warning: scan_peb: bad ec header at pnum 263, drop this block
          [10.441]ubi0 warning: scan_peb: bad ec header at pnum 264, drop this block
          [10.448]ubi0 warning: scan_peb: bad ec header at pnum 265, drop this block
          [10.455]ubi0 warning: scan_peb: bad ec header at pnum 266, drop this block
          [10.462]ubi0 warning: scan_peb: bad ec header at pnum 267, drop this block
          [10.469]ubi0 warning: scan_peb: bad ec header at pnum 268, drop this block
          [10.476]ubi0 warning: scan_peb: bad ec header at pnum 269, drop this block
          [10.483]ubi0 warning: scan_peb: bad ec header at pnum 270, drop this block
          [10.490]ubi0 warning: scan_peb: bad ec header at pnum 271, drop this block
          [10.497]ubi0 warning: scan_peb: bad ec header at pnum 272, drop this block
          [10.504]ubi0 warning: scan_peb: bad ec header at pnum 273, drop this block
          [10.511]ubi0 warning: scan_peb: bad ec header at pnum 274, drop this block
          [10.518]ubi0 warning: scan_peb: bad ec header at pnum 275, drop this block
          [10.525]ubi0 warning: scan_peb: bad ec header at pnum 276, drop this block
          [10.532]ubi0 warning: scan_peb: bad ec header at pnum 277, drop this block
          [10.539]ubi0 warning: scan_peb: bad ec header at pnum 278, drop this block
          [10.546]ubi0 warning: scan_peb: bad ec header at pnum 279, drop this block
          [10.554]ubi0 warning: scan_peb: bad ec header at pnum 280, drop this block
          [10.561]ubi0 warning: scan_peb: bad ec header at pnum 281, drop this block
          [10.568]ubi0 warning: scan_peb: bad ec header at pnum 282, drop this block
          [10.575]ubi0 warning: scan_peb: bad ec header at pnum 283, drop this block
          [10.582]ubi0 warning: scan_peb: bad ec header at pnum 284, drop this block
          [10.589]ubi0 warning: scan_peb: bad ec header at pnum 285, drop this block
          [10.596]ubi0 warning: scan_peb: bad ec header at pnum 286, drop this block
          [10.603]ubi0 warning: scan_peb: bad ec header at pnum 287, drop this block
          [10.610]ubi0 warning: scan_peb: bad ec header at pnum 288, drop this block
          [10.617]ubi0 warning: scan_peb: bad ec header at pnum 289, drop this block
          [10.624]ubi0 warning: scan_peb: bad ec header at pnum 290, drop this block
          [10.631]ubi0 warning: scan_peb: bad ec header at pnum 291, drop this block
          [10.638]ubi0 warning: scan_peb: bad ec header at pnum 292, drop this block
          [10.645]ubi0 warning: scan_peb: bad ec header at pnum 293, drop this block
          [10.652]ubi0 warning: scan_peb: bad ec header at pnum 294, drop this block
          [10.659]ubi0 warning: scan_peb: bad ec header at pnum 295, drop this block
          [10.666]ubi0 warning: scan_peb: bad ec header at pnum 296, drop this block
          [10.673]ubi0 warning: scan_peb: bad ec header at pnum 297, drop this block
          [10.680]ubi0 warning: scan_peb: bad ec header at pnum 298, drop this block
          [10.687]ubi0 warning: scan_peb: bad ec header at pnum 299, drop this block
          [10.694]ubi0 warning: scan_peb: bad ec header at pnum 300, drop this block
          [10.701]ubi0 warning: scan_peb: bad ec header at pnum 301, drop this block
          [10.708]ubi0 warning: scan_peb: bad ec header at pnum 302, drop this block
          [10.715]ubi0 warning: scan_peb: bad ec header at pnum 303, drop this block
          [10.722]ubi0 warning: scan_peb: bad ec header at pnum 304, drop this block
          [10.729]ubi0 warning: scan_peb: bad ec header at pnum 305, drop this block
          [10.736]ubi0 warning: scan_peb: bad ec header at pnum 306, drop this block
          [10.743]ubi0 warning: scan_peb: bad ec header at pnum 307, drop this block
          [10.750]ubi0 warning: scan_peb: bad ec header at pnum 308, drop this block
          [10.757]ubi0 warning: scan_peb: bad ec header at pnum 309, drop this block
          [10.764]ubi0 warning: scan_peb: bad ec header at pnum 310, drop this block
          [10.771]ubi0 warning: scan_peb: bad ec header at pnum 311, drop this block
          [10.778]ubi0 warning: scan_peb: bad ec header at pnum 312, drop this block
          [10.785]ubi0 warning: scan_peb: bad ec header at pnum 313, drop this block
          [10.793]ubi0 warning: scan_peb: bad ec header at pnum 314, drop this block
          [10.800]ubi0 warning: scan_peb: bad ec header at pnum 315, drop this block
          [10.807]ubi0 warning: scan_peb: bad ec header at pnum 316, drop this block
          [10.814]ubi0 warning: scan_peb: bad ec header at pnum 317, drop this block
          [10.821]ubi0 warning: scan_peb: bad ec header at pnum 318, drop this block
          [10.828]ubi0 warning: scan_peb: bad ec header at pnum 319, drop this block
          [10.835]ubi0 warning: scan_peb: bad ec header at pnum 320, drop this block
          [10.842]ubi0 warning: scan_peb: bad ec header at pnum 321, drop this block
          [10.849]ubi0 warning: scan_peb: bad ec header at pnum 322, drop this block
          [10.856]ubi0 warning: scan_peb: bad ec header at pnum 323, drop this block
          [10.863]ubi0 warning: scan_peb: bad ec header at pnum 324, drop this block
          [10.870]ubi0 warning: scan_peb: bad ec header at pnum 325, drop this block
          [10.877]ubi0 warning: scan_peb: bad ec header at pnum 326, drop this block
          [10.884]ubi0 warning: scan_peb: bad ec header at pnum 327, drop this block
          [10.891]ubi0 warning: scan_peb: bad ec header at pnum 328, drop this block
          [10.898]ubi0 warning: scan_peb: bad ec header at pnum 329, drop this block
          [10.905]ubi0 warning: scan_peb: bad ec header at pnum 330, drop this block
          [10.912]ubi0 warning: scan_peb: bad ec header at pnum 331, drop this block
          [10.919]ubi0 warning: scan_peb: bad ec header at pnum 332, drop this block
          [10.926]ubi0 warning: scan_peb: bad ec header at pnum 333, drop this block
          [10.933]ubi0 warning: scan_peb: bad ec header at pnum 334, drop this block
          [10.940]ubi0 warning: scan_peb: bad ec header at pnum 335, drop this block
          [10.947]ubi0 warning: scan_peb: bad ec header at pnum 336, drop this block
          [10.954]ubi0 warning: scan_peb: bad ec header at pnum 337, drop this block
          [10.961]ubi0 warning: scan_peb: bad ec header at pnum 338, drop this block
          [10.968]ubi0 warning: scan_peb: bad ec header at pnum 339, drop this block
          [10.975]ubi0 warning: scan_peb: bad ec header at pnum 340, drop this block
          [10.982]ubi0 warning: scan_peb: bad ec header at pnum 341, drop this block
          [10.989]ubi0 warning: scan_peb: bad ec header at pnum 342, drop this block
          [10.996]ubi0 warning: scan_peb: bad ec header at pnum 343, drop this block
          [11.003]ubi0 warning: scan_peb: bad ec header at pnum 344, drop this block
          [11.010]ubi0 warning: scan_peb: bad ec header at pnum 345, drop this block
          [11.017]ubi0 warning: scan_peb: bad ec header at pnum 346, drop this block
          [11.024]ubi0 warning: scan_peb: bad ec header at pnum 347, drop this block
          [11.031]ubi0 warning: scan_peb: bad ec header at pnum 348, drop this block
          [11.039]ubi0 warning: scan_peb: bad ec header at pnum 349, drop this block
          [11.046]ubi0 warning: scan_peb: bad ec header at pnum 350, drop this block
          [11.053]ubi0 warning: scan_peb: bad ec header at pnum 351, drop this block
          [11.060]ubi0 warning: scan_peb: bad ec header at pnum 352, drop this block
          [11.067]ubi0 warning: scan_peb: bad ec header at pnum 353, drop this block
          [11.074]ubi0 warning: scan_peb: bad ec header at pnum 354, drop this block
          [11.081]ubi0 warning: scan_peb: bad ec header at pnum 355, drop this block
          [11.088]ubi0 warning: scan_peb: bad ec header at pnum 356, drop this block
          [11.095]ubi0 warning: scan_peb: bad ec header at pnum 357, drop this block
          [11.102]ubi0 warning: scan_peb: bad ec header at pnum 358, drop this block
          [11.109]ubi0 warning: scan_peb: bad ec header at pnum 359, drop this block
          [11.116]ubi0 warning: scan_peb: bad ec header at pnum 360, drop this block
          [11.123]ubi0 warning: scan_peb: bad ec header at pnum 361, drop this block
          [11.130]ubi0 warning: scan_peb: bad ec header at pnum 362, drop this block
          [11.137]ubi0 warning: scan_peb: bad ec header at pnum 363, drop this block
          [11.144]ubi0 warning: scan_peb: bad ec header at pnum 364, drop this block
          [11.151]ubi0 warning: scan_peb: bad ec header at pnum 365, drop this block
          [11.158]ubi0 warning: scan_peb: bad ec header at pnum 366, drop this block
          [11.165]ubi0 warning: scan_peb: bad ec header at pnum 367, drop this block
          [11.172]ubi0 warning: scan_peb: bad ec header at pnum 368, drop this block
          [11.179]ubi0 warning: scan_peb: bad ec header at pnum 369, drop this block
          [11.186]ubi0 warning: scan_peb: bad ec header at pnum 370, drop this block
          [11.193]ubi0 warning: scan_peb: bad ec header at pnum 371, drop this block
          [11.200]ubi0 warning: scan_peb: bad ec header at pnum 372, drop this block
          [11.207]ubi0 warning: scan_peb: bad ec header at pnum 373, drop this block
          [11.214]ubi0 warning: scan_peb: bad ec header at pnum 374, drop this block
          [11.221]ubi0 warning: scan_peb: bad ec header at pnum 375, drop this block
          [11.228]ubi0 warning: scan_peb: bad ec header at pnum 376, drop this block
          [11.235]ubi0 warning: scan_peb: bad ec header at pnum 377, drop this block
          [11.242]ubi0 warning: scan_peb: bad ec header at pnum 378, drop this block
          [11.249]ubi0 warning: scan_peb: bad ec header at pnum 379, drop this block
          [11.256]ubi0 warning: scan_peb: bad ec header at pnum 380, drop this block
          [11.263]ubi0 warning: scan_peb: bad ec header at pnum 381, drop this block
          [11.270]ubi0 warning: scan_peb: bad ec header at pnum 382, drop this block
          [11.278]ubi0 warning: scan_peb: bad ec header at pnum 383, drop this block
          [11.285]ubi0 warning: scan_peb: bad ec header at pnum 384, drop this block
          [11.292]ubi0 warning: scan_peb: bad ec header at pnum 385, drop this block
          [11.299]ubi0 warning: scan_peb: bad ec header at pnum 386, drop this block
          [11.306]ubi0 warning: scan_peb: bad ec header at pnum 387, drop this block
          [11.313]ubi0 warning: scan_peb: bad ec header at pnum 388, drop this block
          [11.320]ubi0 warning: scan_peb: bad ec header at pnum 389, drop this block
          [11.327]ubi0 warning: scan_peb: bad ec header at pnum 390, drop this block
          [11.334]ubi0 warning: scan_peb: bad ec header at pnum 391, drop this block
          [11.341]ubi0 warning: scan_peb: bad ec header at pnum 392, drop this block
          [11.348]ubi0 warning: scan_peb: bad ec header at pnum 393, drop this block
          [11.355]ubi0 warning: scan_peb: bad ec header at pnum 394, drop this block
          [11.362]ubi0 warning: scan_peb: bad ec header at pnum 395, drop this block
          [11.369]ubi0 warning: scan_peb: bad ec header at pnum 396, drop this block
          [11.376]ubi0 warning: scan_peb: bad ec header at pnum 397, drop this block
          [11.383]ubi0 warning: scan_peb: bad ec header at pnum 398, drop this block
          [11.390]ubi0 warning: scan_peb: bad ec header at pnum 399, drop this block
          [11.397]ubi0 warning: scan_peb: bad ec header at pnum 400, drop this block
          [11.404]ubi0 warning: scan_peb: bad ec header at pnum 401, drop this block
          [11.411]ubi0 warning: scan_peb: bad ec header at pnum 402, drop this block
          [11.418]ubi0 warning: scan_peb: bad ec header at pnum 403, drop this block
          [11.425]ubi0 warning: scan_peb: bad ec header at pnum 404, drop this block
          [11.432]ubi0 warning: scan_peb: bad ec header at pnum 405, drop this block
          [11.439]ubi0 warning: scan_peb: bad ec header at pnum 406, drop this block
          [11.446]ubi0 warning: scan_peb: bad ec header at pnum 407, drop this block
          [11.453]ubi0 warning: scan_peb: bad ec header at pnum 408, drop this block
          [11.460]ubi0 warning: scan_peb: bad ec header at pnum 409, drop this block
          [11.467]ubi0 warning: scan_peb: bad ec header at pnum 410, drop this block
          [11.474]ubi0 warning: scan_peb: bad ec header at pnum 411, drop this block
          [11.481]ubi0 warning: scan_peb: bad ec header at pnum 412, drop this block
          [11.488]ubi0 warning: scan_peb: bad ec header at pnum 413, drop this block
          [11.495]ubi0 warning: scan_peb: bad ec header at pnum 414, drop this block
          [11.502]ubi0 warning: scan_peb: bad ec header at pnum 415, drop this block
          [11.509]ubi0 warning: scan_peb: bad ec header at pnum 416, drop this block
          [11.516]ubi0 warning: scan_peb: bad ec header at pnum 417, drop this block
          [11.524]ubi0 warning: scan_peb: bad ec header at pnum 418, drop this block
          [11.531]ubi0 warning: scan_peb: bad ec header at pnum 419, drop this block
          [11.538]ubi0 warning: scan_peb: bad ec header at pnum 420, drop this block
          [11.545]ubi0 warning: scan_peb: bad ec header at pnum 421, drop this block
          [11.552]ubi0 warning: scan_peb: bad ec header at pnum 422, drop this block
          [11.559]ubi0 warning: scan_peb: bad ec header at pnum 423, drop this block
          [11.566]ubi0 warning: scan_peb: bad ec header at pnum 424, drop this block
          [11.573]ubi0 warning: scan_peb: bad ec header at pnum 425, drop this block
          [11.580]ubi0 warning: scan_peb: bad ec header at pnum 426, drop this block
          [11.587]ubi0 warning: scan_peb: bad ec header at pnum 427, drop this block
          [11.594]ubi0 warning: scan_peb: bad ec header at pnum 428, drop this block
          [11.601]ubi0 warning: scan_peb: bad ec header at pnum 429, drop this block
          [11.608]ubi0 warning: scan_peb: bad ec header at pnum 430, drop this block
          [11.615]ubi0 warning: scan_peb: bad ec header at pnum 431, drop this block
          [11.622]ubi0 warning: scan_peb: bad ec header at pnum 432, drop this block
          [11.629]ubi0 warning: scan_peb: bad ec header at pnum 433, drop this block
          [11.636]ubi0 warning: scan_peb: bad ec header at pnum 434, drop this block
          [11.643]ubi0 warning: scan_peb: bad ec header at pnum 435, drop this block
          [11.650]ubi0 warning: scan_peb: bad ec header at pnum 436, drop this block
          [11.657]ubi0 warning: scan_peb: bad ec header at pnum 437, drop this block
          [11.664]ubi0 warning: scan_peb: bad ec header at pnum 438, drop this block
          [11.671]ubi0 warning: scan_peb: bad ec header at pnum 439, drop this block
          [11.678]ubi0 warning: scan_peb: bad ec header at pnum 440, drop this block
          [11.685]ubi0 warning: scan_peb: bad ec header at pnum 441, drop this block
          [11.692]ubi0 warning: scan_peb: bad ec header at pnum 442, drop this block
          [11.699]ubi0 warning: scan_peb: bad ec header at pnum 443, drop this block
          [11.706]ubi0 warning: scan_peb: bad ec header at pnum 444, drop this block
          [11.713]ubi0 warning: scan_peb: bad ec header at pnum 445, drop this block
          [11.720]ubi0 warning: scan_peb: bad ec header at pnum 446, drop this block
          [11.727]ubi0 warning: scan_peb: bad ec header at pnum 447, drop this block
          [11.734]ubi0 warning: scan_peb: bad ec header at pnum 448, drop this block
          [11.741]ubi0 warning: scan_peb: bad ec header at pnum 449, drop this block
          [11.748]ubi0 warning: scan_peb: bad ec header at pnum 450, drop this block
          [11.755]ubi0 warning: scan_peb: bad ec header at pnum 451, drop this block
          [11.762]ubi0 warning: scan_peb: bad ec header at pnum 452, drop this block
          [11.770]ubi0 warning: scan_peb: bad ec header at pnum 453, drop this block
          [11.777]ubi0 warning: scan_peb: bad ec header at pnum 454, drop this block
          [11.784]ubi0 warning: scan_peb: bad ec header at pnum 455, drop this block
          [11.791]ubi0 warning: scan_peb: bad ec header at pnum 456, drop this block
          [11.798]ubi0 warning: scan_peb: bad ec header at pnum 457, drop this block
          [11.805]ubi0 warning: scan_peb: bad ec header at pnum 458, drop this block
          [11.812]ubi0 warning: scan_peb: bad ec header at pnum 459, drop this block
          [11.819]ubi0 warning: scan_peb: bad ec header at pnum 460, drop this block
          [11.826]ubi0 warning: scan_peb: bad ec header at pnum 461, drop this block
          [11.833]ubi0 warning: scan_peb: bad ec header at pnum 462, drop this block
          [11.840]ubi0 warning: scan_peb: bad ec header at pnum 463, drop this block
          [11.847]ubi0 warning: scan_peb: bad ec header at pnum 464, drop this block
          [11.854]ubi0 warning: scan_peb: bad ec header at pnum 465, drop this block
          [11.861]ubi0 warning: scan_peb: bad ec header at pnum 466, drop this block
          [11.868]ubi0 warning: scan_peb: bad ec header at pnum 467, drop this block
          [11.875]ubi0 warning: scan_peb: bad ec header at pnum 468, drop this block
          [11.882]ubi0 warning: scan_peb: bad ec header at pnum 469, drop this block
          [11.889]ubi0 warning: scan_peb: bad ec header at pnum 470, drop this block
          [11.896]ubi0 warning: scan_peb: bad ec header at pnum 471, drop this block
          [11.903]ubi0 warning: scan_peb: bad ec header at pnum 472, drop this block
          [11.910]ubi0 warning: scan_peb: bad ec header at pnum 473, drop this block
          [11.917]ubi0 warning: scan_peb: bad ec header at pnum 474, drop this block
          [11.924]ubi0 warning: scan_peb: bad ec header at pnum 475, drop this block
          [11.931]ubi0 warning: scan_peb: bad ec header at pnum 476, drop this block
          [11.938]ubi0 warning: scan_peb: bad ec header at pnum 477, drop this block
          [11.945]ubi0 warning: scan_peb: bad ec header at pnum 478, drop this block
          [11.952]ubi0 warning: scan_peb: bad ec header at pnum 479, drop this block
          [11.959]ubi0 warning: scan_peb: bad ec header at pnum 480, drop this block
          [11.966]ubi0 warning: scan_peb: bad ec header at pnum 481, drop this block
          [11.973]ubi0 warning: scan_peb: bad ec header at pnum 482, drop this block
          [11.980]ubi0 warning: scan_peb: bad ec header at pnum 483, drop this block
          [11.987]ubi0 warning: scan_peb: bad ec header at pnum 484, drop this block
          [11.994]ubi0 warning: scan_peb: bad ec header at pnum 485, drop this block
          [12.001]ubi0 warning: scan_peb: bad ec header at pnum 486, drop this block
          [12.009]ubi0 warning: scan_peb: bad ec header at pnum 487, drop this block
          [12.016]ubi0 warning: scan_peb: bad ec header at pnum 488, drop this block
          [12.023]ubi0 warning: scan_peb: bad ec header at pnum 489, drop this block
          [12.030]ubi0 warning: scan_peb: bad ec header at pnum 490, drop this block
          [12.037]ubi0 warning: scan_peb: bad ec header at pnum 491, drop this block
          [12.043]ubi0: scanning is finished
          [12.046]ubi0: empty MTD device detected
          [12.099]ubi0: attached mtd4 (name "sys", size 123 MiB)
          [12.103]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
          [12.110]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
          [12.116]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
          [12.122]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
          [12.128]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
          [12.134]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
          [12.142]ubi0: available PEBs: 468, total reserved PEBs: 24, PEBs reserved for bad PEB handling: 20
          no part need to protect user data
          [13.262]erase blk 0 to blk 32
          SUNXI_EFEX_MBR_TAG
          mbr size = 0x10000
          force mbr
          defaults:
          mtdids  : nand0=nand
          [13.333]MTD info (4)
          [13.335]pagesize: 0x1000
          [13.337]blksize: 0x40000
          [13.339]num  offset     bytes      name
          [13.343]0    0x00000000 0x00100000 boot0
          [13.347]1    0x00100000 0x00300000 uboot
          [13.350]2    0x00400000 0x00100000 secure_storage
          [13.355]3    0x00500000 0x07b00000 sys
          [13.358]MBR info (unalign):
          [13.361]partno   addr       sects      type       name
          [13.365]0        0x00000000 0x00008000 0x00000001 mbr
          [13.370]1        0x00008000 0x00000800 0x00008000 boot-resource
          [13.376]2        0x00008800 0x000001f8 0x00008000 env
          [13.381]3        0x000089f8 0x000001f8 0x00008000 env-redund
          [13.386]4        0x00008bf0 0x00005000 0x00008000 boot
          [13.391]5        0x0000dbf0 0x000103e8 0x00008000 rootfs
          [13.396]6        0x0001dfd8 0x00005780 0x00008000 recovery
          [13.401]7        0x00023758 0x000078f0 0x00008000 rootfs_data
          [13.407]8        0x0002b048 0x00000000 0x00000000 UDISK
          [13.412]ubi attach the last part of mtd device: NO.3
          [13.416]MBR info (align):
          [13.418]partno   addr       sects      type       name
          [13.423]0        0x00002800 0x000081f0 0x00000001 mbr
          [13.428]1        0x0000a9f0 0x000009d8 0x00008000 boot-resource
          [13.434]2        0x0000b3c8 0x000001f8 0x00008000 env
          [13.439]3        0x0000b5c0 0x000001f8 0x00008000 env-redund
          [13.444]4        0x0000b7b8 0x000050b8 0x00008000 boot
          [13.449]5        0x00010870 0x000105d8 0x00008000 rootfs
          [13.454]6        0x00020e48 0x00005898 0x00008000 recovery
          [13.459]7        0x000266e0 0x00007a10 0x00008000 rootfs_data
          [13.464]8        0x0002e0f0 0x00000000 0x00000000 UDISK
          [13.469]ubi attach the last part of mtd device: NO.3
          [13.474]ubi attatch mtd, name: sys
          [13.477]ubi0: detaching mtd4
          [13.482]ubi0: mtd4 is detached
          [13.485]ubi0: attaching mtd4
          [13.489]ubi0 warning: scan_peb: bad ec header at pnum 1, drop this block
          [13.495]ubi0 warning: scan_peb: bad ec header at pnum 2, drop this block
          [13.502]ubi0 warning: scan_peb: bad ec header at pnum 3, drop this block
          [13.509]ubi0 warning: scan_peb: bad ec header at pnum 4, drop this block
          [13.516]ubi0 warning: scan_peb: bad ec header at pnum 5, drop this block
          [13.523]ubi0 warning: scan_peb: bad ec header at pnum 6, drop this block
          [13.530]ubi0 warning: scan_peb: bad ec header at pnum 7, drop this block
          [13.537]ubi0 warning: scan_peb: bad ec header at pnum 8, drop this block
          [13.543]ubi0 warning: scan_peb: bad ec header at pnum 9, drop this block
          [13.550]ubi0 warning: scan_peb: bad ec header at pnum 10, drop this block
          [13.557]ubi0 warning: scan_peb: bad ec header at pnum 11, drop this block
          [13.564]ubi0 warning: scan_peb: bad ec header at pnum 12, drop this block
          [13.571]ubi0 warning: scan_peb: bad ec header at pnum 13, drop this block
          [13.578]ubi0 warning: scan_peb: bad ec header at pnum 14, drop this block
          [13.585]ubi0 warning: scan_peb: bad ec header at pnum 15, drop this block
          [13.592]ubi0 warning: scan_peb: bad ec header at pnum 16, drop this block
          [13.599]ubi0 warning: scan_peb: bad ec header at pnum 17, drop this block
          [13.606]ubi0 warning: scan_peb: bad ec header at pnum 18, drop this block
          [13.613]ubi0 warning: scan_peb: bad ec header at pnum 19, drop this block
          [13.620]ubi0 warning: scan_peb: bad ec header at pnum 20, drop this block
          [13.627]ubi0 warning: scan_peb: bad ec header at pnum 21, drop this block
          [13.634]ubi0 warning: scan_peb: bad ec header at pnum 22, drop this block
          [13.641]ubi0 warning: scan_peb: bad ec header at pnum 23, drop this block
          [13.647]ubi0 warning: scan_peb: bad ec header at pnum 24, drop this block
          [13.654]ubi0 warning: scan_peb: bad ec header at pnum 25, drop this block
          [13.661]ubi0 warning: scan_peb: bad ec header at pnum 26, drop this block
          [13.668]ubi0 warning: scan_peb: bad ec header at pnum 27, drop this block
          [13.675]ubi0 warning: scan_peb: bad ec header at pnum 28, drop this block
          [13.682]ubi0 warning: scan_peb: bad ec header at pnum 29, drop this block
          [13.689]ubi0 warning: scan_peb: bad ec header at pnum 30, drop this block
          [13.696]ubi0 warning: scan_peb: bad ec header at pnum 31, drop this block
          [13.703]ubi0 warning: scan_peb: bad ec header at pnum 32, drop this block
          [13.710]ubi0 warning: scan_peb: bad ec header at pnum 33, drop this block
          [13.717]ubi0 warning: scan_peb: bad ec header at pnum 34, drop this block
          [13.724]ubi0 warning: scan_peb: bad ec header at pnum 35, drop this block
          [13.731]ubi0 warning: scan_peb: bad ec header at pnum 36, drop this block
          [13.738]ubi0 warning: scan_peb: bad ec header at pnum 37, drop this block
          [13.745]ubi0 warning: scan_peb: bad ec header at pnum 38, drop this block
          [13.752]ubi0 warning: scan_peb: bad ec header at pnum 39, drop this block
          [13.759]ubi0 warning: scan_peb: bad ec header at pnum 40, drop this block
          [13.765]ubi0 warning: scan_peb: bad ec header at pnum 41, drop this block
          [13.772]ubi0 warning: scan_peb: bad ec header at pnum 42, drop this block
          [13.779]ubi0 warning: scan_peb: bad ec header at pnum 43, drop this block
          [13.786]ubi0 warning: scan_peb: bad ec header at pnum 44, drop this block
          [13.793]ubi0 warning: scan_peb: bad ec header at pnum 45, drop this block
          [13.800]ubi0 warning: scan_peb: bad ec header at pnum 46, drop this block
          [13.807]ubi0 warning: scan_peb: bad ec header at pnum 47, drop this block
          [13.814]ubi0 warning: scan_peb: bad ec header at pnum 48, drop this block
          [13.821]ubi0 warning: scan_peb: bad ec header at pnum 49, drop this block
          [13.828]ubi0 warning: scan_peb: bad ec header at pnum 50, drop this block
          [13.835]ubi0 warning: scan_peb: bad ec header at pnum 51, drop this block
          [13.842]ubi0 warning: scan_peb: bad ec header at pnum 52, drop this block
          [13.849]ubi0 warning: scan_peb: bad ec header at pnum 53, drop this block
          [13.856]ubi0 warning: scan_peb: bad ec header at pnum 54, drop this block
          [13.863]ubi0 warning: scan_peb: bad ec header at pnum 55, drop this block
          [13.870]ubi0 warning: scan_peb: bad ec header at pnum 56, drop this block
          [13.877]ubi0 warning: scan_peb: bad ec header at pnum 57, drop this block
          [13.884]ubi0 warning: scan_peb: bad ec header at pnum 58, drop this block
          [13.890]ubi0 warning: scan_peb: bad ec header at pnum 59, drop this block
          [13.897]ubi0 warning: scan_peb: bad ec header at pnum 60, drop this block
          [13.904]ubi0 warning: scan_peb: bad ec header at pnum 61, drop this block
          [13.911]ubi0 warning: scan_peb: bad ec header at pnum 62, drop this block
          [13.918]ubi0 warning: scan_peb: bad ec header at pnum 63, drop this block
          [13.925]ubi0 warning: scan_peb: bad ec header at pnum 64, drop this block
          [13.932]ubi0 warning: scan_peb: bad ec header at pnum 65, drop this block
          [13.939]ubi0 warning: scan_peb: bad ec header at pnum 66, drop this block
          [13.946]ubi0 warning: scan_peb: bad ec header at pnum 67, drop this block
          [13.953]ubi0 warning: scan_peb: bad ec header at pnum 68, drop this block
          [13.960]ubi0 warning: scan_peb: bad ec header at pnum 69, drop this block
          [13.967]ubi0 warning: scan_peb: bad ec header at pnum 70, drop this block
          [13.974]ubi0 warning: scan_peb: bad ec header at pnum 71, drop this block
          [13.981]ubi0 warning: scan_peb: bad ec header at pnum 72, drop this block
          [13.988]ubi0 warning: scan_peb: bad ec header at pnum 73, drop this block
          [13.995]ubi0 warning: scan_peb: bad ec header at pnum 74, drop this block
          [14.002]ubi0 warning: scan_peb: bad ec header at pnum 75, drop this block
          [14.008]ubi0 warning: scan_peb: bad ec header at pnum 76, drop this block
          [14.015]ubi0 warning: scan_peb: bad ec header at pnum 77, drop this block
          [14.022]ubi0 warning: scan_peb: bad ec header at pnum 78, drop this block
          [14.029]ubi0 warning: scan_peb: bad ec header at pnum 79, drop this block
          [14.036]ubi0 warning: scan_peb: bad ec header at pnum 80, drop this block
          [14.043]ubi0 warning: scan_peb: bad ec header at pnum 81, drop this block
          [14.050]ubi0 warning: scan_peb: bad ec header at pnum 82, drop this block
          [14.057]ubi0 warning: scan_peb: bad ec header at pnum 83, drop this block
          [14.064]ubi0 warning: scan_peb: bad ec header at pnum 84, drop this block
          [14.071]ubi0 warning: scan_peb: bad ec header at pnum 85, drop this block
          [14.078]ubi0 warning: scan_peb: bad ec header at pnum 86, drop this block
          [14.085]ubi0 warning: scan_peb: bad ec header at pnum 87, drop this block
          [14.092]ubi0 warning: scan_peb: bad ec header at pnum 88, drop this block
          [14.099]ubi0 warning: scan_peb: bad ec header at pnum 89, drop this block
          [14.106]ubi0 warning: scan_peb: bad ec header at pnum 90, drop this block
          [14.113]ubi0 warning: scan_peb: bad ec header at pnum 91, drop this block
          [14.120]ubi0 warning: scan_peb: bad ec header at pnum 92, drop this block
          [14.126]ubi0 warning: scan_peb: bad ec header at pnum 93, drop this block
          [14.133]ubi0 warning: scan_peb: bad ec header at pnum 94, drop this block
          [14.140]ubi0 warning: scan_peb: bad ec header at pnum 95, drop this block
          [14.147]ubi0 warning: scan_peb: bad ec header at pnum 96, drop this block
          [14.154]ubi0 warning: scan_peb: bad ec header at pnum 97, drop this block
          [14.161]ubi0 warning: scan_peb: bad ec header at pnum 98, drop this block
          [14.168]ubi0 warning: scan_peb: bad ec header at pnum 99, drop this block
          [14.175]ubi0 warning: scan_peb: bad ec header at pnum 100, drop this block
          [14.182]ubi0 warning: scan_peb: bad ec header at pnum 101, drop this block
          [14.189]ubi0 warning: scan_peb: bad ec header at pnum 102, drop this block
          [14.196]ubi0 warning: scan_peb: bad ec header at pnum 103, drop this block
          [14.203]ubi0 warning: scan_peb: bad ec header at pnum 104, drop this block
          [14.210]ubi0 warning: scan_peb: bad ec header at pnum 105, drop this block
          [14.217]ubi0 warning: scan_peb: bad ec header at pnum 106, drop this block
          [14.224]ubi0 warning: scan_peb: bad ec header at pnum 107, drop this block
          [14.231]ubi0 warning: scan_peb: bad ec header at pnum 108, drop this block
          [14.238]ubi0 warning: scan_peb: bad ec header at pnum 109, drop this block
          [14.245]ubi0 warning: scan_peb: bad ec header at pnum 110, drop this block
          [14.252]ubi0 warning: scan_peb: bad ec header at pnum 111, drop this block
          [14.259]ubi0 warning: scan_peb: bad ec header at pnum 112, drop this block
          [14.266]ubi0 warning: scan_peb: bad ec header at pnum 113, drop this block
          [14.273]ubi0 warning: scan_peb: bad ec header at pnum 114, drop this block
          [14.280]ubi0 warning: scan_peb: bad ec header at pnum 115, drop this block
          [14.288]ubi0 warning: scan_peb: bad ec header at pnum 116, drop this block
          [14.295]ubi0 warning: scan_peb: bad ec header at pnum 117, drop this block
          [14.302]ubi0 warning: scan_peb: bad ec header at pnum 118, drop this block
          [14.309]ubi0 warning: scan_peb: bad ec header at pnum 119, drop this block
          [14.316]ubi0 warning: scan_peb: bad ec header at pnum 120, drop this block
          [14.323]ubi0 warning: scan_peb: bad ec header at pnum 121, drop this block
          [14.330]ubi0 warning: scan_peb: bad ec header at pnum 122, drop this block
          [14.337]ubi0 warning: scan_peb: bad ec header at pnum 123, drop this block
          [14.344]ubi0 warning: scan_peb: bad ec header at pnum 124, drop this block
          [14.351]ubi0 warning: scan_peb: bad ec header at pnum 125, drop this block
          [14.358]ubi0 warning: scan_peb: bad ec header at pnum 126, drop this block
          [14.365]ubi0 warning: scan_peb: bad ec header at pnum 127, drop this block
          [14.372]ubi0 warning: scan_peb: bad ec header at pnum 128, drop this block
          [14.379]ubi0 warning: scan_peb: bad ec header at pnum 129, drop this block
          [14.386]ubi0 warning: scan_peb: bad ec header at pnum 130, drop this block
          [14.393]ubi0 warning: scan_peb: bad ec header at pnum 131, drop this block
          [14.400]ubi0 warning: scan_peb: bad ec header at pnum 132, drop this block
          [14.407]ubi0 warning: scan_peb: bad ec header at pnum 133, drop this block
          [14.414]ubi0 warning: scan_peb: bad ec header at pnum 134, drop this block
          [14.421]ubi0 warning: scan_peb: bad ec header at pnum 135, drop this block
          [14.428]ubi0 warning: scan_peb: bad ec header at pnum 136, drop this block
          [14.435]ubi0 warning: scan_peb: bad ec header at pnum 137, drop this block
          [14.442]ubi0 warning: scan_peb: bad ec header at pnum 138, drop this block
          [14.449]ubi0 warning: scan_peb: bad ec header at pnum 139, drop this block
          [14.456]ubi0 warning: scan_peb: bad ec header at pnum 140, drop this block
          [14.463]ubi0 warning: scan_peb: bad ec header at pnum 141, drop this block
          [14.470]ubi0 warning: scan_peb: bad ec header at pnum 142, drop this block
          [14.477]ubi0 warning: scan_peb: bad ec header at pnum 143, drop this block
          [14.484]ubi0 warning: scan_peb: bad ec header at pnum 144, drop this block
          [14.491]ubi0 warning: scan_peb: bad ec header at pnum 145, drop this block
          [14.498]ubi0 warning: scan_peb: bad ec header at pnum 146, drop this block
          [14.505]ubi0 warning: scan_peb: bad ec header at pnum 147, drop this block
          [14.512]ubi0 warning: scan_peb: bad ec header at pnum 148, drop this block
          [14.519]ubi0 warning: scan_peb: bad ec header at pnum 149, drop this block
          [14.527]ubi0 warning: scan_peb: bad ec header at pnum 150, drop this block
          [14.534]ubi0 warning: scan_peb: bad ec header at pnum 151, drop this block
          [14.541]ubi0 warning: scan_peb: bad ec header at pnum 152, drop this block
          [14.548]ubi0 warning: scan_peb: bad ec header at pnum 153, drop this block
          [14.555]ubi0 warning: scan_peb: bad ec header at pnum 154, drop this block
          [14.562]ubi0 warning: scan_peb: bad ec header at pnum 155, drop this block
          [14.569]ubi0 warning: scan_peb: bad ec header at pnum 156, drop this block
          [14.576]ubi0 warning: scan_peb: bad ec header at pnum 157, drop this block
          [14.583]ubi0 warning: scan_peb: bad ec header at pnum 158, drop this block
          [14.590]ubi0 warning: scan_peb: bad ec header at pnum 159, drop this block
          [14.597]ubi0 warning: scan_peb: bad ec header at pnum 160, drop this block
          [14.604]ubi0 warning: scan_peb: bad ec header at pnum 161, drop this block
          [14.611]ubi0 warning: scan_peb: bad ec header at pnum 162, drop this block
          [14.618]ubi0 warning: scan_peb: bad ec header at pnum 163, drop this block
          [14.625]ubi0 warning: scan_peb: bad ec header at pnum 164, drop this block
          [14.632]ubi0 warning: scan_peb: bad ec header at pnum 165, drop this block
          [14.639]ubi0 warning: scan_peb: bad ec header at pnum 166, drop this block
          [14.646]ubi0 warning: scan_peb: bad ec header at pnum 167, drop this block
          [14.653]ubi0 warning: scan_peb: bad ec header at pnum 168, drop this block
          [14.660]ubi0 warning: scan_peb: bad ec header at pnum 169, drop this block
          [14.667]ubi0 warning: scan_peb: bad ec header at pnum 170, drop this block
          [14.674]ubi0 warning: scan_peb: bad ec header at pnum 171, drop this block
          [14.681]ubi0 warning: scan_peb: bad ec header at pnum 172, drop this block
          [14.688]ubi0 warning: scan_peb: bad ec header at pnum 173, drop this block
          [14.695]ubi0 warning: scan_peb: bad ec header at pnum 174, drop this block
          [14.702]ubi0 warning: scan_peb: bad ec header at pnum 175, drop this block
          [14.709]ubi0 warning: scan_peb: bad ec header at pnum 176, drop this block
          [14.716]ubi0 warning: scan_peb: bad ec header at pnum 177, drop this block
          [14.723]ubi0 warning: scan_peb: bad ec header at pnum 178, drop this block
          [14.730]ubi0 warning: scan_peb: bad ec header at pnum 179, drop this block
          [14.737]ubi0 warning: scan_peb: bad ec header at pnum 180, drop this block
          [14.744]ubi0 warning: scan_peb: bad ec header at pnum 181, drop this block
          [14.751]ubi0 warning: scan_peb: bad ec header at pnum 182, drop this block
          [14.758]ubi0 warning: scan_peb: bad ec header at pnum 183, drop this block
          [14.766]ubi0 warning: scan_peb: bad ec header at pnum 184, drop this block
          [14.773]ubi0 warning: scan_peb: bad ec header at pnum 185, drop this block
          [14.780]ubi0 warning: scan_peb: bad ec header at pnum 186, drop this block
          [14.787]ubi0 warning: scan_peb: bad ec header at pnum 187, drop this block
          [14.794]ubi0 warning: scan_peb: bad ec header at pnum 188, drop this block
          [14.801]ubi0 warning: scan_peb: bad ec header at pnum 189, drop this block
          [14.808]ubi0 warning: scan_peb: bad ec header at pnum 190, drop this block
          [14.815]ubi0 warning: scan_peb: bad ec header at pnum 191, drop this block
          [14.822]ubi0 warning: scan_peb: bad ec header at pnum 192, drop this block
          [14.829]ubi0 warning: scan_peb: bad ec header at pnum 193, drop this block
          [14.836]ubi0 warning: scan_peb: bad ec header at pnum 194, drop this block
          [14.843]ubi0 warning: scan_peb: bad ec header at pnum 195, drop this block
          [14.850]ubi0 warning: scan_peb: bad ec header at pnum 196, drop this block
          [14.857]ubi0 warning: scan_peb: bad ec header at pnum 197, drop this block
          [14.864]ubi0 warning: scan_peb: bad ec header at pnum 198, drop this block
          [14.871]ubi0 warning: scan_peb: bad ec header at pnum 199, drop this block
          [14.878]ubi0 warning: scan_peb: bad ec header at pnum 200, drop this block
          [14.885]ubi0 warning: scan_peb: bad ec header at pnum 201, drop this block
          [14.892]ubi0 warning: scan_peb: bad ec header at pnum 202, drop this block
          [14.899]ubi0 warning: scan_peb: bad ec header at pnum 203, drop this block
          [14.906]ubi0 warning: scan_peb: bad ec header at pnum 204, drop this block
          [14.913]ubi0 warning: scan_peb: bad ec header at pnum 205, drop this block
          [14.920]ubi0 warning: scan_peb: bad ec header at pnum 206, drop this block
          [14.927]ubi0 warning: scan_peb: bad ec header at pnum 207, drop this block
          [14.934]ubi0 warning: scan_peb: bad ec header at pnum 208, drop this block
          [14.941]ubi0 warning: scan_peb: bad ec header at pnum 209, drop this block
          [14.948]ubi0 warning: scan_peb: bad ec header at pnum 210, drop this block
          [14.955]ubi0 warning: scan_peb: bad ec header at pnum 211, drop this block
          [14.962]ubi0 warning: scan_peb: bad ec header at pnum 212, drop this block
          [14.969]ubi0 warning: scan_peb: bad ec header at pnum 213, drop this block
          [14.976]ubi0 warning: scan_peb: bad ec header at pnum 214, drop this block
          [14.983]ubi0 warning: scan_peb: bad ec header at pnum 215, drop this block
          [14.990]ubi0 warning: scan_peb: bad ec header at pnum 216, drop this block
          [14.997]ubi0 warning: scan_peb: bad ec header at pnum 217, drop this block
          [15.005]ubi0 warning: scan_peb: bad ec header at pnum 218, drop this block
          [15.012]ubi0 warning: scan_peb: bad ec header at pnum 219, drop this block
          [15.019]ubi0 warning: scan_peb: bad ec header at pnum 220, drop this block
          [15.026]ubi0 warning: scan_peb: bad ec header at pnum 221, drop this block
          [15.033]ubi0 warning: scan_peb: bad ec header at pnum 222, drop this block
          [15.040]ubi0 warning: scan_peb: bad ec header at pnum 223, drop this block
          [15.047]ubi0 warning: scan_peb: bad ec header at pnum 224, drop this block
          [15.054]ubi0 warning: scan_peb: bad ec header at pnum 225, drop this block
          [15.061]ubi0 warning: scan_peb: bad ec header at pnum 226, drop this block
          [15.068]ubi0 warning: scan_peb: bad ec header at pnum 227, drop this block
          [15.075]ubi0 warning: scan_peb: bad ec header at pnum 228, drop this block
          [15.082]ubi0 warning: scan_peb: bad ec header at pnum 229, drop this block
          [15.089]ubi0 warning: scan_peb: bad ec header at pnum 230, drop this block
          [15.096]ubi0 warning: scan_peb: bad ec header at pnum 231, drop this block
          [15.103]ubi0 warning: scan_peb: bad ec header at pnum 232, drop this block
          [15.110]ubi0 warning: scan_peb: bad ec header at pnum 233, drop this block
          [15.117]ubi0 warning: scan_peb: bad ec header at pnum 234, drop this block
          [15.124]ubi0 warning: scan_peb: bad ec header at pnum 235, drop this block
          [15.131]ubi0 warning: scan_peb: bad ec header at pnum 236, drop this block
          [15.138]ubi0 warning: scan_peb: bad ec header at pnum 237, drop this block
          [15.145]ubi0 warning: scan_peb: bad ec header at pnum 238, drop this block
          [15.152]ubi0 warning: scan_peb: bad ec header at pnum 239, drop this block
          [15.159]ubi0 warning: scan_peb: bad ec header at pnum 240, drop this block
          [15.166]ubi0 warning: scan_peb: bad ec header at pnum 241, drop this block
          [15.173]ubi0 warning: scan_peb: bad ec header at pnum 242, drop this block
          [15.180]ubi0 warning: scan_peb: bad ec header at pnum 243, drop this block
          [15.187]ubi0 warning: scan_peb: bad ec header at pnum 244, drop this block
          [15.194]ubi0 warning: scan_peb: bad ec header at pnum 245, drop this block
          [15.201]ubi0 warning: scan_peb: bad ec header at pnum 246, drop this block
          [15.208]ubi0 warning: scan_peb: bad ec header at pnum 247, drop this block
          [15.215]ubi0 warning: scan_peb: bad ec header at pnum 248, drop this block
          [15.222]ubi0 warning: scan_peb: bad ec header at pnum 249, drop this block
          [15.229]ubi0 warning: scan_peb: bad ec header at pnum 250, drop this block
          [15.236]ubi0 warning: scan_peb: bad ec header at pnum 251, drop this block
          [15.244]ubi0 warning: scan_peb: bad ec header at pnum 252, drop this block
          [15.251]ubi0 warning: scan_peb: bad ec header at pnum 253, drop this block
          [15.258]ubi0 warning: scan_peb: bad ec header at pnum 254, drop this block
          [15.265]ubi0 warning: scan_peb: bad ec header at pnum 255, drop this block
          [15.272]ubi0 warning: scan_peb: bad ec header at pnum 256, drop this block
          [15.279]ubi0 warning: scan_peb: bad ec header at pnum 257, drop this block
          [15.286]ubi0 warning: scan_peb: bad ec header at pnum 258, drop this block
          [15.293]ubi0 warning: scan_peb: bad ec header at pnum 259, drop this block
          [15.300]ubi0 warning: scan_peb: bad ec header at pnum 260, drop this block
          [15.307]ubi0 warning: scan_peb: bad ec header at pnum 261, drop this block
          [15.314]ubi0 warning: scan_peb: bad ec header at pnum 262, drop this block
          [15.321]ubi0 warning: scan_peb: bad ec header at pnum 263, drop this block
          [15.328]ubi0 warning: scan_peb: bad ec header at pnum 264, drop this block
          [15.335]ubi0 warning: scan_peb: bad ec header at pnum 265, drop this block
          [15.342]ubi0 warning: scan_peb: bad ec header at pnum 266, drop this block
          [15.349]ubi0 warning: scan_peb: bad ec header at pnum 267, drop this block
          [15.356]ubi0 warning: scan_peb: bad ec header at pnum 268, drop this block
          [15.363]ubi0 warning: scan_peb: bad ec header at pnum 269, drop this block
          [15.370]ubi0 warning: scan_peb: bad ec header at pnum 270, drop this block
          [15.377]ubi0 warning: scan_peb: bad ec header at pnum 271, drop this block
          [15.384]ubi0 warning: scan_peb: bad ec header at pnum 272, drop this block
          [15.391]ubi0 warning: scan_peb: bad ec header at pnum 273, drop this block
          [15.398]ubi0 warning: scan_peb: bad ec header at pnum 274, drop this block
          [15.405]ubi0 warning: scan_peb: bad ec header at pnum 275, drop this block
          [15.412]ubi0 warning: scan_peb: bad ec header at pnum 276, drop this block
          [15.419]ubi0 warning: scan_peb: bad ec header at pnum 277, drop this block
          [15.426]ubi0 warning: scan_peb: bad ec header at pnum 278, drop this block
          [15.433]ubi0 warning: scan_peb: bad ec header at pnum 279, drop this block
          [15.440]ubi0 warning: scan_peb: bad ec header at pnum 280, drop this block
          [15.447]ubi0 warning: scan_peb: bad ec header at pnum 281, drop this block
          [15.454]ubi0 warning: scan_peb: bad ec header at pnum 282, drop this block
          [15.461]ubi0 warning: scan_peb: bad ec header at pnum 283, drop this block
          [15.468]ubi0 warning: scan_peb: bad ec header at pnum 284, drop this block
          [15.475]ubi0 warning: scan_peb: bad ec header at pnum 285, drop this block
          [15.483]ubi0 warning: scan_peb: bad ec header at pnum 286, drop this block
          [15.490]ubi0 warning: scan_peb: bad ec header at pnum 287, drop this block
          [15.497]ubi0 warning: scan_peb: bad ec header at pnum 288, drop this block
          [15.504]ubi0 warning: scan_peb: bad ec header at pnum 289, drop this block
          [15.511]ubi0 warning: scan_peb: bad ec header at pnum 290, drop this block
          [15.518]ubi0 warning: scan_peb: bad ec header at pnum 291, drop this block
          [15.525]ubi0 warning: scan_peb: bad ec header at pnum 292, drop this block
          [15.532]ubi0 warning: scan_peb: bad ec header at pnum 293, drop this block
          [15.539]ubi0 warning: scan_peb: bad ec header at pnum 294, drop this block
          [15.546]ubi0 warning: scan_peb: bad ec header at pnum 295, drop this block
          [15.553]ubi0 warning: scan_peb: bad ec header at pnum 296, drop this block
          [15.560]ubi0 warning: scan_peb: bad ec header at pnum 297, drop this block
          [15.567]ubi0 warning: scan_peb: bad ec header at pnum 298, drop this block
          [15.574]ubi0 warning: scan_peb: bad ec header at pnum 299, drop this block
          [15.581]ubi0 warning: scan_peb: bad ec header at pnum 300, drop this block
          [15.588]ubi0 warning: scan_peb: bad ec header at pnum 301, drop this block
          [15.595]ubi0 warning: scan_peb: bad ec header at pnum 302, drop this block
          [15.602]ubi0 warning: scan_peb: bad ec header at pnum 303, drop this block
          [15.609]ubi0 warning: scan_peb: bad ec header at pnum 304, drop this block
          [15.616]ubi0 warning: scan_peb: bad ec header at pnum 305, drop this block
          [15.623]ubi0 warning: scan_peb: bad ec header at pnum 306, drop this block
          [15.630]ubi0 warning: scan_peb: bad ec header at pnum 307, drop this block
          [15.637]ubi0 warning: scan_peb: bad ec header at pnum 308, drop this block
          [15.644]ubi0 warning: scan_peb: bad ec header at pnum 309, drop this block
          [15.651]ubi0 warning: scan_peb: bad ec header at pnum 310, drop this block
          [15.658]ubi0 warning: scan_peb: bad ec header at pnum 311, drop this block
          [15.665]ubi0 warning: scan_peb: bad ec header at pnum 312, drop this block
          [15.672]ubi0 warning: scan_peb: bad ec header at pnum 313, drop this block
          [15.679]ubi0 warning: scan_peb: bad ec header at pnum 314, drop this block
          [15.686]ubi0 warning: scan_peb: bad ec header at pnum 315, drop this block
          [15.693]ubi0 warning: scan_peb: bad ec header at pnum 316, drop this block
          [15.700]ubi0 warning: scan_peb: bad ec header at pnum 317, drop this block
          [15.707]ubi0 warning: scan_peb: bad ec header at pnum 318, drop this block
          [15.714]ubi0 warning: scan_peb: bad ec header at pnum 319, drop this block
          [15.722]ubi0 warning: scan_peb: bad ec header at pnum 320, drop this block
          [15.729]ubi0 warning: scan_peb: bad ec header at pnum 321, drop this block
          [15.736]ubi0 warning: scan_peb: bad ec header at pnum 322, drop this block
          [15.743]ubi0 warning: scan_peb: bad ec header at pnum 323, drop this block
          [15.750]ubi0 warning: scan_peb: bad ec header at pnum 324, drop this block
          [15.757]ubi0 warning: scan_peb: bad ec header at pnum 325, drop this block
          [15.764]ubi0 warning: scan_peb: bad ec header at pnum 326, drop this block
          [15.771]ubi0 warning: scan_peb: bad ec header at pnum 327, drop this block
          [15.778]ubi0 warning: scan_peb: bad ec header at pnum 328, drop this block
          [15.785]ubi0 warning: scan_peb: bad ec header at pnum 329, drop this block
          [15.792]ubi0 warning: scan_peb: bad ec header at pnum 330, drop this block
          [15.799]ubi0 warning: scan_peb: bad ec header at pnum 331, drop this block
          [15.806]ubi0 warning: scan_peb: bad ec header at pnum 332, drop this block
          [15.813]ubi0 warning: scan_peb: bad ec header at pnum 333, drop this block
          [15.820]ubi0 warning: scan_peb: bad ec header at pnum 334, drop this block
          [15.827]ubi0 warning: scan_peb: bad ec header at pnum 335, drop this block
          [15.834]ubi0 warning: scan_peb: bad ec header at pnum 336, drop this block
          [15.841]ubi0 warning: scan_peb: bad ec header at pnum 337, drop this block
          [15.848]ubi0 warning: scan_peb: bad ec header at pnum 338, drop this block
          [15.855]ubi0 warning: scan_peb: bad ec header at pnum 339, drop this block
          [15.862]ubi0 warning: scan_peb: bad ec header at pnum 340, drop this block
          [15.869]ubi0 warning: scan_peb: bad ec header at pnum 341, drop this block
          [15.876]ubi0 warning: scan_peb: bad ec header at pnum 342, drop this block
          [15.883]ubi0 warning: scan_peb: bad ec header at pnum 343, drop this block
          [15.890]ubi0 warning: scan_peb: bad ec header at pnum 344, drop this block
          [15.897]ubi0 warning: scan_peb: bad ec header at pnum 345, drop this block
          [15.904]ubi0 warning: scan_peb: bad ec header at pnum 346, drop this block
          [15.911]ubi0 warning: scan_peb: bad ec header at pnum 347, drop this block
          [15.918]ubi0 warning: scan_peb: bad ec header at pnum 348, drop this block
          [15.925]ubi0 warning: scan_peb: bad ec header at pnum 349, drop this block
          [15.932]ubi0 warning: scan_peb: bad ec header at pnum 350, drop this block
          [15.939]ubi0 warning: scan_peb: bad ec header at pnum 351, drop this block
          [15.946]ubi0 warning: scan_peb: bad ec header at pnum 352, drop this block
          [15.953]ubi0 warning: scan_peb: bad ec header at pnum 353, drop this block
          [15.960]ubi0 warning: scan_peb: bad ec header at pnum 354, drop this block
          [15.968]ubi0 warning: scan_peb: bad ec header at pnum 355, drop this block
          [15.975]ubi0 warning: scan_peb: bad ec header at pnum 356, drop this block
          [15.982]ubi0 warning: scan_peb: bad ec header at pnum 357, drop this block
          [15.989]ubi0 warning: scan_peb: bad ec header at pnum 358, drop this block
          [15.996]ubi0 warning: scan_peb: bad ec header at pnum 359, drop this block
          [16.003]ubi0 warning: scan_peb: bad ec header at pnum 360, drop this block
          [16.010]ubi0 warning: scan_peb: bad ec header at pnum 361, drop this block
          [16.017]ubi0 warning: scan_peb: bad ec header at pnum 362, drop this block
          [16.024]ubi0 warning: scan_peb: bad ec header at pnum 363, drop this block
          [16.031]ubi0 warning: scan_peb: bad ec header at pnum 364, drop this block
          [16.038]ubi0 warning: scan_peb: bad ec header at pnum 365, drop this block
          [16.045]ubi0 warning: scan_peb: bad ec header at pnum 366, drop this block
          [16.052]ubi0 warning: scan_peb: bad ec header at pnum 367, drop this block
          [16.059]ubi0 warning: scan_peb: bad ec header at pnum 368, drop this block
          [16.066]ubi0 warning: scan_peb: bad ec header at pnum 369, drop this block
          [16.073]ubi0 warning: scan_peb: bad ec header at pnum 370, drop this block
          [16.080]ubi0 warning: scan_peb: bad ec header at pnum 371, drop this block
          [16.087]ubi0 warning: scan_peb: bad ec header at pnum 372, drop this block
          [16.094]ubi0 warning: scan_peb: bad ec header at pnum 373, drop this block
          [16.101]ubi0 warning: scan_peb: bad ec header at pnum 374, drop this block
          [16.108]ubi0 warning: scan_peb: bad ec header at pnum 375, drop this block
          [16.115]ubi0 warning: scan_peb: bad ec header at pnum 376, drop this block
          [16.122]ubi0 warning: scan_peb: bad ec header at pnum 377, drop this block
          [16.129]ubi0 warning: scan_peb: bad ec header at pnum 378, drop this block
          [16.136]ubi0 warning: scan_peb: bad ec header at pnum 379, drop this block
          [16.143]ubi0 warning: scan_peb: bad ec header at pnum 380, drop this block
          [16.150]ubi0 warning: scan_peb: bad ec header at pnum 381, drop this block
          [16.157]ubi0 warning: scan_peb: bad ec header at pnum 382, drop this block
          [16.164]ubi0 warning: scan_peb: bad ec header at pnum 383, drop this block
          [16.171]ubi0 warning: scan_peb: bad ec header at pnum 384, drop this block
          [16.178]ubi0 warning: scan_peb: bad ec header at pnum 385, drop this block
          [16.185]ubi0 warning: scan_peb: bad ec header at pnum 386, drop this block
          [16.192]ubi0 warning: scan_peb: bad ec header at pnum 387, drop this block
          [16.199]ubi0 warning: scan_peb: bad ec header at pnum 388, drop this block
          [16.207]ubi0 warning: scan_peb: bad ec header at pnum 389, drop this block
          [16.214]ubi0 warning: scan_peb: bad ec header at pnum 390, drop this block
          [16.221]ubi0 warning: scan_peb: bad ec header at pnum 391, drop this block
          [16.228]ubi0 warning: scan_peb: bad ec header at pnum 392, drop this block
          [16.235]ubi0 warning: scan_peb: bad ec header at pnum 393, drop this block
          [16.242]ubi0 warning: scan_peb: bad ec header at pnum 394, drop this block
          [16.249]ubi0 warning: scan_peb: bad ec header at pnum 395, drop this block
          [16.256]ubi0 warning: scan_peb: bad ec header at pnum 396, drop this block
          [16.263]ubi0 warning: scan_peb: bad ec header at pnum 397, drop this block
          [16.270]ubi0 warning: scan_peb: bad ec header at pnum 398, drop this block
          [16.277]ubi0 warning: scan_peb: bad ec header at pnum 399, drop this block
          [16.284]ubi0 warning: scan_peb: bad ec header at pnum 400, drop this block
          [16.291]ubi0 warning: scan_peb: bad ec header at pnum 401, drop this block
          [16.298]ubi0 warning: scan_peb: bad ec header at pnum 402, drop this block
          [16.305]ubi0 warning: scan_peb: bad ec header at pnum 403, drop this block
          [16.312]ubi0 warning: scan_peb: bad ec header at pnum 404, drop this block
          [16.319]ubi0 warning: scan_peb: bad ec header at pnum 405, drop this block
          [16.326]ubi0 warning: scan_peb: bad ec header at pnum 406, drop this block
          [16.333]ubi0 warning: scan_peb: bad ec header at pnum 407, drop this block
          [16.340]ubi0 warning: scan_peb: bad ec header at pnum 408, drop this block
          [16.347]ubi0 warning: scan_peb: bad ec header at pnum 409, drop this block
          [16.354]ubi0 warning: scan_peb: bad ec header at pnum 410, drop this block
          [16.361]ubi0 warning: scan_peb: bad ec header at pnum 411, drop this block
          [16.368]ubi0 warning: scan_peb: bad ec header at pnum 412, drop this block
          [16.375]ubi0 warning: scan_peb: bad ec header at pnum 413, drop this block
          [16.382]ubi0 warning: scan_peb: bad ec header at pnum 414, drop this block
          [16.389]ubi0 warning: scan_peb: bad ec header at pnum 415, drop this block
          [16.396]ubi0 warning: scan_peb: bad ec header at pnum 416, drop this block
          [16.403]ubi0 warning: scan_peb: bad ec header at pnum 417, drop this block
          [16.410]ubi0 warning: scan_peb: bad ec header at pnum 418, drop this block
          [16.417]ubi0 warning: scan_peb: bad ec header at pnum 419, drop this block
          [16.424]ubi0 warning: scan_peb: bad ec header at pnum 420, drop this block
          [16.431]ubi0 warning: scan_peb: bad ec header at pnum 421, drop this block
          [16.438]ubi0 warning: scan_peb: bad ec header at pnum 422, drop this block
          [16.446]ubi0 warning: scan_peb: bad ec header at pnum 423, drop this block
          [16.453]ubi0 warning: scan_peb: bad ec header at pnum 424, drop this block
          [16.460]ubi0 warning: scan_peb: bad ec header at pnum 425, drop this block
          [16.467]ubi0 warning: scan_peb: bad ec header at pnum 426, drop this block
          [16.474]ubi0 warning: scan_peb: bad ec header at pnum 427, drop this block
          [16.481]ubi0 warning: scan_peb: bad ec header at pnum 428, drop this block
          [16.488]ubi0 warning: scan_peb: bad ec header at pnum 429, drop this block
          [16.495]ubi0 warning: scan_peb: bad ec header at pnum 430, drop this block
          [16.502]ubi0 warning: scan_peb: bad ec header at pnum 431, drop this block
          [16.509]ubi0 warning: scan_peb: bad ec header at pnum 432, drop this block
          [16.516]ubi0 warning: scan_peb: bad ec header at pnum 433, drop this block
          [16.523]ubi0 warning: scan_peb: bad ec header at pnum 434, drop this block
          [16.530]ubi0 warning: scan_peb: bad ec header at pnum 435, drop this block
          [16.537]ubi0 warning: scan_peb: bad ec header at pnum 436, drop this block
          [16.544]ubi0 warning: scan_peb: bad ec header at pnum 437, drop this block
          [16.551]ubi0 warning: scan_peb: bad ec header at pnum 438, drop this block
          [16.558]ubi0 warning: scan_peb: bad ec header at pnum 439, drop this block
          [16.565]ubi0 warning: scan_peb: bad ec header at pnum 440, drop this block
          [16.572]ubi0 warning: scan_peb: bad ec header at pnum 441, drop this block
          [16.579]ubi0 warning: scan_peb: bad ec header at pnum 442, drop this block
          [16.586]ubi0 warning: scan_peb: bad ec header at pnum 443, drop this block
          [16.593]ubi0 warning: scan_peb: bad ec header at pnum 444, drop this block
          [16.600]ubi0 warning: scan_peb: bad ec header at pnum 445, drop this block
          [16.607]ubi0 warning: scan_peb: bad ec header at pnum 446, drop this block
          [16.614]ubi0 warning: scan_peb: bad ec header at pnum 447, drop this block
          [16.621]ubi0 warning: scan_peb: bad ec header at pnum 448, drop this block
          [16.628]ubi0 warning: scan_peb: bad ec header at pnum 449, drop this block
          [16.635]ubi0 warning: scan_peb: bad ec header at pnum 450, drop this block
          [16.642]ubi0 warning: scan_peb: bad ec header at pnum 451, drop this block
          [16.649]ubi0 warning: scan_peb: bad ec header at pnum 452, drop this block
          [16.656]ubi0 warning: scan_peb: bad ec header at pnum 453, drop this block
          [16.663]ubi0 warning: scan_peb: bad ec header at pnum 454, drop this block
          [16.670]ubi0 warning: scan_peb: bad ec header at pnum 455, drop this block
          [16.677]ubi0 warning: scan_peb: bad ec header at pnum 456, drop this block
          [16.684]ubi0 warning: scan_peb: bad ec header at pnum 457, drop this block
          [16.692]ubi0 warning: scan_peb: bad ec header at pnum 458, drop this block
          [16.699]ubi0 warning: scan_peb: bad ec header at pnum 459, drop this block
          [16.706]ubi0 warning: scan_peb: bad ec header at pnum 460, drop this block
          [16.713]ubi0 warning: scan_peb: bad ec header at pnum 461, drop this block
          [16.720]ubi0 warning: scan_peb: bad ec header at pnum 462, drop this block
          [16.727]ubi0 warning: scan_peb: bad ec header at pnum 463, drop this block
          [16.734]ubi0 warning: scan_peb: bad ec header at pnum 464, drop this block
          [16.741]ubi0 warning: scan_peb: bad ec header at pnum 465, drop this block
          [16.748]ubi0 warning: scan_peb: bad ec header at pnum 466, drop this block
          [16.755]ubi0 warning: scan_peb: bad ec header at pnum 467, drop this block
          [16.762]ubi0 warning: scan_peb: bad ec header at pnum 468, drop this block
          [16.769]ubi0 warning: scan_peb: bad ec header at pnum 469, drop this block
          [16.776]ubi0 warning: scan_peb: bad ec header at pnum 470, drop this block
          [16.783]ubi0 warning: scan_peb: bad ec header at pnum 471, drop this block
          [16.790]ubi0 warning: scan_peb: bad ec header at pnum 472, drop this block
          [16.797]ubi0 warning: scan_peb: bad ec header at pnum 473, drop this block
          [16.804]ubi0 warning: scan_peb: bad ec header at pnum 474, drop this block
          [16.811]ubi0 warning: scan_peb: bad ec header at pnum 475, drop this block
          [16.818]ubi0 warning: scan_peb: bad ec header at pnum 476, drop this block
          [16.825]ubi0 warning: scan_peb: bad ec header at pnum 477, drop this block
          [16.832]ubi0 warning: scan_peb: bad ec header at pnum 478, drop this block
          [16.839]ubi0 warning: scan_peb: bad ec header at pnum 479, drop this block
          [16.846]ubi0 warning: scan_peb: bad ec header at pnum 480, drop this block
          [16.853]ubi0 warning: scan_peb: bad ec header at pnum 481, drop this block
          [16.860]ubi0 warning: scan_peb: bad ec header at pnum 482, drop this block
          [16.867]ubi0 warning: scan_peb: bad ec header at pnum 483, drop this block
          [16.874]ubi0 warning: scan_peb: bad ec header at pnum 484, drop this block
          [16.881]ubi0 warning: scan_peb: bad ec header at pnum 485, drop this block
          [16.888]ubi0 warning: scan_peb: bad ec header at pnum 486, drop this block
          [16.895]ubi0 warning: scan_peb: bad ec header at pnum 487, drop this block
          [16.902]ubi0 warning: scan_peb: bad ec header at pnum 488, drop this block
          [16.909]ubi0 warning: scan_peb: bad ec header at pnum 489, drop this block
          [16.916]ubi0 warning: scan_peb: bad ec header at pnum 490, drop this block
          [16.923]ubi0 warning: scan_peb: bad ec header at pnum 491, drop this block
          [16.930]ubi0: scanning is finished
          [16.934]ubi0 error: ubi_read_volume_table: the layout volume was not found
          [16.941]ubi0 error: ubi_attach_mtd_dev: failed to attach mtd4, error -22
          [16.948]UBI error: cannot attach mtd4
          [16.951]UBI error: cannot initialize UBI, error -22
          UBI init error 22
          Please check, if the correct MTD partition is used (size big enough?)
          [16.963]ubi part sys err !
          [16.966]initialize sunxi spinand ubi failed
          download_standard_gpt:write mbr sectors fail ret = 0
          6Mhz也一样,奇怪了.
            之前遇到过,spi nand焊接的时候虚焊了,电源虚没给电数据线给电访问了,全是坏块
            U 2 条回复 最后回复 回复 引用 分享 0
            • U
              uuuuid LV 6 @YuzukiTsuru 最后由 编辑
              @yuzukitsuru
              为什么可以读到 ID 呢?
              • U
                @yuzukitsuru
                发现2/5/6 没有上拉.
