    v851s 在分区表中新建分区报错
    4158
      htujun LV 3 最后由 编辑
      v851s 在分区表中新建分区报错, 主要修改tina-fastboot-v85x/device/config/chips/v851s/configs/fastboot/linux/sys_partition_nor.fex文件。
      请问新建分区,除了修改以上文件,还需要修改哪里呢?
      相关格式如下:
      ;    mbr的大小, 以Kbyte为单位
      [mbr]
      size = 16
      ;  partition 定义范例:
      ; 注:1、name唯一, 不允许同名
      ;     2、name最大12个字符
      ;     4、为了安全和效率考虑,分区大小最好保证为16M字节的整数倍
      [partition_start]
      [partition]
          name         = boot
          size         = 7040
          downloadfile = "boot.fex"
          user_type    = 0x8000
      [partition]
          name         = rootfs
          size         = 11264
          downloadfile = "rootfs.fex"
          user_type    = 0x8000
      [partition]
          name         = rootfsA
          size         = 11264
          downloadfile = "rootfs1.fex"
          user_type    = 0x8000
      [partition]
          name         = extend
          size         = 7040
          downloadfile = "usr.fex"
          user_type    = 0x8000
      [partition]
          name         = rootfs_data
          size         = 1024
          user_type    = 0x8000
      ;[partition]
      ;   name         = env
      ;   size         = 512
      ;   downloadfile = "env_nor.fex"
      ;   user_type    = 0x8000
      ;[partition]
      ;   name         = misc
      ;   size         = 128
      ;[partition]
      ;   name         = bootlogo
      ;   size         = 768
      ;   downloadfile = "bootlogo.fex"
        rootfsA需要加入到设备树的分区表内。tina linux有分区错误检查
          htujun LV 3 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru 好的
            Z_z LV 4 最后由 编辑
            (507芯片)问一下,想尝试新建一个分区,然后修改了一下sys_partition.fex文件,具体如下
            ;    mbr的大小, 以Kbyte为单位
            [mbr]
            size = 16384
            ;  partition 定义范例:
            ; 注:1、name唯一, 不允许同名
            ;     2、name最大12个字符
            [partition_start]
            ;------------------------------>mmcblk0p1/nand0p1
            [partition]
                name         = boot-resource
                size         = 65536
                user_type    = 0x8000
            ;------------------------------>mmcblk0p2/nand0p2
            [partition]
                name         = env
                size         = 32768
                downloadfile = "env.fex"
                user_type    = 0x8000
            ;------------------------------>mmcblk0p3/nand0p3
            [partition]
                name         = boot
                size         = 131072
                user_type    = 0x8000
            ;------------------------------>mmcblk0p4/nand0p4
            [partition]
                name         = rootfs
                size         = 4194304
            	user_type    = 0x8000
            ;------------------------------>mmcblk0p5/nand0p5
            [partition]
                name         = rootfsbak
                size         = 4194304
                    user_type    = 0x8000
            ;------------------------------>mmcblk0p6/nand0p6
            [partition]
                name         = recovery
                size         = 231072
                ;downloadfile = "recovery.fex"
                user_type    = 0x8000
            ;------------------------------>mmcblk0p7/nand0p7
            [partition]
                name         = private
                size         = 32768
                ro           = 0
                user_type    = 0x8000
            ;------------------------------>mmcblk0p8/nand0p8
            [partition]
                name         = test
                size         = 4194304
                user_type    = 0x8000
            ;------------------------------>mmcblk0p9/nand0p9
            ;------------------------------>UDISK
            [partition]
                name         = UDISK
                user_type    = 0x8100
            然后执行打包编译也提示成功,
            BuildImg 0
            但是烧录到板子上,分区也出来了,但有另外一个错误,
            [02.831]Starting kernel ...
            [02.834][mmc]: mmc exit start
            [02.852][mmc]: mmc 2 exit ok
            [    0.000000] Linux version 4.9.170 (root@ubuntu) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #2 SMP PREEMPT Fri Sep 16 19:19:55 PDT 2022
            [    0.000000] Boot CPU: AArch64 Processor [410fd034]
            [    0.000000] bootconsole [earlycon0] enabled
            [/init]: getty is ttyS0
            [/init]: RootDevice is "/dev/mmcblk0p4" , GPT_SUPPORT=1
            [/init]: Try to load EMMC ...
            e2fsck 1.42.12 (29-Aug-2014)
            The filesystem size (according to the superblock) is 1572864 blocks
            The physical size of the device is 524288 blocks
            Either the superblock or the partition table is likely to be corrupt!
            Abort? yes
            mount: mounting /dev/mmcblk0p4 on /mnt failed: Invalid argument
            [/init]: Failed to mount /dev/mmcblk0p4!
            我也尝试在uboot里面去设置一下
            env set mmc_root /dev/mmcblk0p4
            saveenv,但是没有效果,这个该怎么处理呢?另外还有一个问题就是我能给新加的这个分区在制作的时候加密上吗?访问改分区的时候需要密码才给访问。这个怎么实现?
