    请问D1 tina v1.0.0 是不是默认支持了自带的mipi屏幕, 可是为什么我的没有显示呢?背光是亮的
    6
    18
    12038
      memory LV 7 最后由 whycan 编辑
      me@ubuntu:/opt/lichee/brandy-2.0/u-boot-2018$ git log .
      commit 0a88ac94ab4c4c7942423d3b447e6a147fae7fbd (HEAD -> product-smartx-d1-tina-v1.0-release, tag: smartx-d1-tina-v1.0.1-release, tag: smartx-d1-tina-v1.0.0-release, tina/product-smartx-d1-tina-v1.0-release, m/master)
      Author: liwencong <liwencong@allwinnertech.com>
      Date:   Fri Apr 30 19:23:28 2021 +0800
          smartx-d1-tina-v1.0.0-release release
      烧这个固件可以显示:
      https://d1.docs.aw-ol.com/source/3_getimg/
      • BedRock
        BedRock LV 6 最后由 编辑
        v 1.0.1 默认是支持了的v1.0.0不是很清楚,开机确实会显示哪吒的logo.
        M 1 条回复 最后回复 回复 引用 分享 0
          memory LV 7 @BedRock 最后由 编辑
          @bedrock 请问怎么更新 v1.0.1呢?
            DOT小文哥 LV 8 @memory 最后由 编辑
            @memory 拿到代码,repo sync就是最新的
              memory LV 7 @xiaowenge 最后由 编辑
              @xiaowenge
              $ repo sync
              Fetching project repo
              Fetching project lichee/brandy-2.0/tools
              Fetching project product/tina/dl
              Fetching project lichee/device/config/d1
              Fetching projects:  23% (4/17)
              Fetching project lichee/brandy-2.0/opensbi
              Fetching projects:  29% (5/17)
              Fetching project lichee/linux-5.4
              Fetching projects:  35% (6/17)
              Fetching project lichee/brandy-2.0/u-boot-2018
              Fetching projects:  41% (7/17)
              Fetching project product/tina/package
              Fetching projects:  47% (8/17)
              Fetching project product/tina/prebuilt
              Fetching projects:  52% (9/17)
              Fetching project product/tina/build
              Fetching projects:  58% (10/17)
              Fetching project product/tina/tools
              Fetching projects:  64% (11/17)
              Fetching project product/tina/target
              Fetching projects:  70% (12/17)
              Fetching project lichee/brandy-2.0/spl
              Fetching projects:  76% (13/17)
              Fetching project product/tina/config
              Fetching projects:  82% (14/17)
              Fetching project lichee/device/config/common
              Fetching projects:  88% (15/17)
              Fetching project product/tina/scripts
              Fetching projects:  94% (16/17)
              Fetching project product/tina/toolchain
              Fetching projects: 100% (17/17)
              Fetching projects: 100% (17/17), done.
              我再试一试.
                memory LV 7 最后由 编辑
                貌似可以了, 感谢楼上两位大佬.
                  触摸校正正常, 其实电容屏不需要校正, ( 逃
                  BedRock 1 条回复 最后回复 回复 引用 分享 0
                  • BedRock
                    BedRock LV 6 @memory 最后由 编辑
                    @memory 在 请问D1 tina v1.0.0 是不是默认支持了自带的mipi屏幕, 可是为什么我的没有显示呢?背光是亮的 中说:
                    🤠 🤠 🤠 又是一个小功能
                      memory LV 7 最后由 编辑
                      先整个LVGL上去看看效果, 触摸屏还没整合.
                      N 1 条回复 最后回复 回复 引用 分享 0
                      • N
                        nideyida LV 5 @memory 最后由 编辑
                        @memory 请问这个LVGL怎么搞上去的?有没有玩的教程?
                        tigger M 2 条回复 最后回复 回复 引用 分享 0
                          把编译好的 lvgl 复制到 target/allwinner/d1-nezha/base-files/usr/bin/ 目录, 然后 make;pack 重烧, 命令行运行就可以了.
                          X 1 条回复 最后回复 回复 引用 分享 0
                          • tigger
                            tigger LV 7 @nideyida 最后由 编辑
                            • X
                              xiaoliqi LV 3 @memory 最后由 编辑
                              @memory 烧进去了咋运行,找不到烧哪儿了
                                memory LV 7 @xiaoliqi 最后由 编辑
                                @xiaoliqi 在 请问D1 tina v1.0.0 是不是默认支持了自带的mipi屏幕, 可是为什么我的没有显示呢?背光是亮的 中说:
                                晚点我发个烧录固件上来
                                  添加开机脚本文件 /etc/init.d/lvgldemo
                                  #!/bin/sh /etc/rc.common
                                  START=99
                                  STOP=15
                                  start(){
                                      echo start lvgl demo
                                      /usr/bin/lvgl_demo &
                                  stop(){
                                      echo stop demo
                                  restart(){
                                      echo restart demo
                                  enable(){
                                      echo enable demo
                                  disable(){
                                      echo disable demo
                                  现在可以开机运行了, 准备打包 img 文件.
                                    ubuntu:/opt/d1$ find . |grep lvgl_demo$
                                    ./out/d1-nezha/staging_dir/target/rootfs/usr/bin/lvgl_demo
                                    ./out/d1-nezha/compile_dir/target/linux-d1-nezha/base-files/ipkg-sunxi/base-files/usr/bin/lvgl_demo
                                    ./target/allwinner/d1-nezha/base-files/usr/bin/lvgl_demo
                                    ubuntu:/opt/d1$
                                    ubuntu:/opt/d1$ find . |grep lvgldemo$
                                    ./out/d1-nezha/staging_dir/target/rootfs/etc/init.d/lvgldemo
                                    ./out/d1-nezha/compile_dir/target/linux-d1-nezha/base-files/ipkg-sunxi/base-files/etc/init.d/lvgldemo
                                    ./target/allwinner/d1-nezha/base-files/etc/init.d/lvgldemo
                                    尴尬了, 虽然查看 文件系统有文件, 但是打包的 img 里面却没有 /usr/bin/lvgl_demo
                                      memory LV 7 @nideyida 最后由 编辑
                                      @nideyida
                                      哪吒D1开发板 LVGL7 源码下载, 带git仓库
                                      https://bbs.aw-ol.com/topic/303
                                      • BedRock
                                        @memory 效率拉满
