    A133 起不来
    7049
      zhoutian LV 5 最后由 编辑
      您好,请问大家有没有遇到过A133启动异常的问题,系统跑到02-09 08:32:00.006 2072 2072 D KeyguardClockSwitch: Updating clock: 0832 就停下了,实在是没有找到问题,麻烦大家帮忙看下
      dmesg_e.txt
      logcat_e.txt
      uboot_e.txt
        whycan晕哥 LV 9 @zhoutian 最后由 编辑
        @zhoutian
        麻烦接调试串口,贴出完整日志。
        Z 1 条回复 最后回复 回复 引用 分享 0
          zhoutian LV 5 最后由 q1215200171 编辑
          [130]HELLO! SBOOT is starting!
          [133]sboot commit : 54b5c2f5b3
          [136]set pll start
          [138]periph0 has been enabled
          [141]set pll end
          [142]PL gpio voltage : 3.3V
          [145][pmu]: bus read error
          [148]PMU: AXP803
          [150][pmu]: bus read error
          [198]vaild para:1  select dram para0
          [202]board init ok, set sys_vol to 950mv!
          [226]try to probe rtc region
          [229]DRAM BOOT DRIVE INFO: V0.697
          [232]the chip id is 0x1400
          [235]the chip id is 0x1400
          [237]the chip id is 0x1400
          [240]the chip id is 0x1400
          [242]the chip id is 0x1400
          [245]chip id check OK
          [255]DRAM_VCC set to 1200 mv
          [258]DRAM CLK =744 MHZ
          [260]DRAM Type =4 (3:DDR3,4:DDR4,6:LPDDR2,7:LPDDR3,8:LPDDR4)
          [269]DRAM SIZE =1024 MBytes, para1 = 60fa, para2 = 4000000, tpr13 = 80007501
          [278]DRAM simple test OK.
          [280]chipid = 53801400
          [283]nsi init ok 2020-4-7
          [285][mmc]: mmc driver ver 2020-05-25 09:40-202007019516
          [296][mmc]: Wrong media type 0x0
          [299][mmc]: ***Try SD card 2***
          [303][mmc]: mmc 2 cmd 8 timeout, err 100
          [307][mmc]: mmc 2 cmd 8 err 100
          [310][mmc]: mmc 2 send if cond failed
          [315][mmc]: mmc 2 cmd 55 timeout, err 100
          [319][mmc]: mmc 2 cmd 55 err 100
          [322][mmc]: mmc 2 send app cmd failed
          [326][mmc]: ***Try MMC card 2***
          [351][mmc]: RMCA OK!
          [353][mmc]: bias 4
          [354][mmc]: mmc 2 bias 4
          [358][mmc]: MMC 5.1
          [360][mmc]: HSSDR52/SDR25 8 bit
          [363][mmc]: 50000000 Hz
          [365][mmc]: 7456 MB
          [367][mmc]: ***SD/MMC 2 init OK!!!***
          [399]read toc1 from emmc 32800 sector
          [403]OLD version: 0.0
          [405]NEW version: 0.0
          [468]load rotpk hash
          [516]load monitor-key hash
          [519]load monitor hash
          [673]set arisc reset to assert state
          [681]set arisc reset to de-assert state
          [733]load boot-key hash
          [736]load boot hash
          [787]load vbmeta-key hash
          [789]load vbmeta hash
          [841]load recovery-key hash
          [844]load recovery hash
          [847]monitor entry=0x48000000
          [850]uboot entry=0x4a000000
          [853]optee entry=0x48600000
          [856]tunning data addr:0x4a0003e8
          [859]run out of boot0
          NOTICE:  BL3-1: v1.0(debug):0f6655c
          NOTICE:  BL3-1: Built : 15:24:20, 2022-07-05
          NOTICE:  BL3-1 commit: 8
          NOTICE:  info v0.0
          NOTICE:  cpuidle init version V1.0
          NOTICE:  secure os exist
          MESSAGE: [0x0] TEE-CORE: OP-TEE version: f37cc616 #1 Wed Jan 15 03:00:40 UTC 2020 arm
          NOTICE:  BL3-1: Preparing for EL3 exit to normal world
          NOTICE:  BL3-1: Next image address = 0x4a000000
          NOTICE:  BL3-1: Next image spsr = 0x1d3
          U-Boot 2018.05 (Jan 11 2023 - 07:09:48 +0000) Allwinner Technology
          [00.956]CPU:   Allwinner Family
          [00.959]Model: sun50iw10
          I2C:   ready
          [01.077]DRAM:  1 GiB
          [01.080]Relocation Offset is: 35f05000
          [01.110]secure enable bit: 1
          [01.114][ARISC ERROR] :get [allwinner,sunxi-hwspinlock] device node error
          CACHE: Misaligned operation at range [7ffa76e0, 7ffa79f8]
          [SCP] :sunxi-arisc driver begin startup 2
          [SCP] :0x1
          [SCP] :arisc version: [e08bf86ebc1eb22d80c2048eb0805b2501510f7frid-]
          [SCP] :arisc startup ready
          [SCP] :arisc startup notify message feedback
          [SCP] :send hard sync feedback message: 0x900200
          [SCP] :sunxi-arisc driver v1.10 is starting
          [01.154]pmu_axp806_probe pmic_bus_read fail
          [01.158]PMU: AXP803
          [01.275]PMU: AXP803
          FDT ERROR:fdt_get_regulator_name:get property handle twi-for-pmu-supply error:FDT_ERR_INTERNAL
          bias_name:pc_bias	 bias_vol:1800
          [01.331]TCS: TCS_probe
          [01.333]pmu_tcs4838_probe pmic_bus_read fail
          [01.337]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
          [01.344]drv_disp_init
          request pwm success, pwm0:pwm0:0x300a000.
          [01.397]drv_disp_init finish
          [01.402]gic: sec monitor mode
          [01.405]flash init start
          [01.407]workmode = 0,storage type = 2
          [01.410][mmc]: mmc driver ver uboot2018:2020-5-25 9:26:00-2021-09-17 14:45:00
          [01.418][mmc]: get sdc_type fail and use default host:tm4.
          [01.430][mmc]: SUNXI SDMMC Controller Version:0x50300
          [01.455][mmc]: Best spd md: 4-HS400, freq: 3-100000000, Bus width: 8
          [01.461]sunxi flash init ok
          [01.465]Loading Environment from SUNXI_FLASH... OK
          [01.472]Item0 (Map) magic is bad
          [01.475]the secure storage item0 copy0 magic is bad
          [01.479]Item0 (Map) magic is bad
          [01.482]the secure storage item0 copy1 magic is bad
          [01.487]Item0 (Map) magic is bad
          [01.493]secure storage read widevine fail with:-1
          [01.500]secure storage read ec_key fail with:-1
          [01.505]usb burn from boot
          delay time 0
          weak:otg_phy_config
          [01.516]usb prepare ok
          [01.950]usb sof ok
          [01.952]usb probe ok
          [01.953]usb setup ok
          set address 0x1a
          set address 0x1a ok
          try to update
          [04.960]do_burn_from_boot usb : have no handshake
          [04.964]boot_gui_init:start
          [04.969]set disp.dev2_output_type fail. using defval=0
          [04.978]boot_gui_init:finish
          4096056 bytes read in 25 ms (156.3 MiB/s)
          no support big size bmp[800x1280] on fb[1024x600]
          [05.016]show bm[05.018]soc ic_ver:0x4, qa_val:0x0, markid:0x1400 dclk[0-200] display_cfg_flag:0
          p on fb failed !-1
          [05.034]update dts
          [05.043]load file(ULI/factory/snum.txt) error.
          [05.056]load file(ULI/factory/mac.txt) error.
          [05.068]load file(ULI/factory/wifi_mac.txt) error.
          [05.080]load file(ULI/factory/bt_mac.txt) error.
          [05.093]load file(ULI/factory/specialstr.txt) error.
          [05.103]update part info
          [05.126]update bootcmd
          [05.228]LCD open finish
          [05.352]not supported key
          [05.354]actual n size:1000, e:10001
          [05.357]exptect n size:800, e:10001
          CACHE: Misaligned operation at range [44ffffe0, 465c9020]
          [05.563]Starting kernel ...
          [05.566][mmc]: mmc exit start
          [05.585][mmc]: mmc 2 exit ok
          [    0.000000] Linux version 4.9.170 (zzze@Zzze) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #3 SMP PREEMPT Sun Jan 8 17:31:55 CST 2023
          [    0.000000] Boot CPU: AArch64 Processor [410fd034]
          [    0.000000] bootconsole [earlycon0] enabled
          [    0.000000] disp reserve base 0x7bf53140 ,size 0x258000
          [    0.000000] cma: Reserved 8 MiB at 0x000000007f800000
          [    0.000000] On node 0 totalpages: 262144
          [    0.000000]   DMA zone: 4096 pages used for memmap
          [    0.000000]   DMA zone: 0 pages reserved
          [    0.000000]   DMA zone: 262144 pages, LIFO batch:31
          [    0.000000] psci: Trusted OS migration not required
          [    0.000000] percpu: Embedded 23 pages/cpu @ffffffc03f6e9000 s53376 r8192 d32640 u94208
          [    0.000000] pcpu-alloc: s53376 r8192 d32640 u94208 alloc=23*4096
          [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
          [    0.000000] Detected VIPT I-cache on CPU0
          [    0.000000] CPU features: enabling workaround for ARM erratum 845719
          [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258048
          [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4 init=/init partitions=bootloader@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:super@mmcblk0p4:misc@mmcblk0p5:recovery@mmcblk0p6:cache@mmcblk0p7:vbmeta@mmcblk0p8:vbmeta_system@mmcblk0p9:vbmeta_vendor@mmcblk0p10:metadata@mmcblk0p11:private@mmcblk0p12:frp@mmcblk0p13:empty@mmcblk0p14:dtbo@mmcblk0p15:media_data@mmcblk0p16:UDISK@mmcblk0p17 cma=8M snum=2c00142201224711c50 mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.vbmeta.avb_version=2.0 androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=7168 androidboot.vbmeta.digest=ea9a512f6ccb2b0df9d7821e86fca6e7f8f88fd10254b1c99b2e1742f3122d94 androidboot.vbmeta.device_state=locked androidboot.mode=normal androidboot.serialno=2c00142201224711c50 androidboot.hardware=sun50iw10p1 boot_type=2 androidboot.boot_type=2 androidboot.secure_os_exist=1 androidboot.trustchain=false gpt=1 androidboot.verifiedbootstate[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
          [    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
          [    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
          [    0.000000] Memory: 979588K/1048576K available (10942K kernel code, 2208K rwdata, 3948K rodata, 4288K init, 599K bss, 60796K reserved, 8192K cma-reserved)
          [    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
          [    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
          [    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008b30000   ( 10944 KB)
          [    0.000000]     .rodata : 0xffffff8008b30000 - 0xffffff8008f10000   (  3968 KB)
          [    0.000000]       .init : 0xffffff8008f10000 - 0xffffff8009340000   (  4288 KB)
          [    0.000000]       .data : 0xffffff8009340000 - 0xffffff8009568008   (  2209 KB)
          [    0.000000]        .bss : 0xffffff8009568008 - 0xffffff80095fdc78   (   600 KB)
          [    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
          [    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
          [    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
          [    0.000000]               0xffffffbf00000000 - 0xffffffbf01000000   (    16 MB actual)
          [    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc040000000   (  1024 MB)
          [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
          [    0.000000] 	Build-time adjustment of leaf fanout to 64.
          [    0.000000] NR_IRQS:64 nr_irqs:64 0
          [    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
          [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
          [    0.008164] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
          [    0.018199] pid_max: default: 32768 minimum: 301
          [    0.023037] Security Framework initialized
          [    0.026879] SELinux:  Initializing.
          [    0.030480] SELinux:  Starting in permissive mode
          [    0.035137] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
          [    0.041697] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
          [    0.049550] ftrace: allocating 33752 entries in 132 pages
          [    0.131099] sched-energy: CPU device node has no sched-energy-costs
          [    0.131737] Invalid sched_group_energy for CPU0
          [    0.136275] CPU0: update cpu_capacity 1024
          [    0.150383] ASID allocator initialised with 32768 entries
          [    0.169228] nsi: set limit to fit 720P(ABCDE)
          [    0.169461] BOOTEVENT:       169.456665: ON
          [    0.202461] Detected VIPT I-cache on CPU1
          [    0.202512] Invalid sched_group_energy for CPU1
          [    0.202515] CPU1: update cpu_capacity 1024
          [    0.202518] CPU1: Booted secondary processor [410fd034]
          [    0.225840] Detected VIPT I-cache on CPU2
          [    0.225867] Invalid sched_group_energy for CPU2
          [    0.225870] CPU2: update cpu_capacity 1024
          [    0.225873] CPU2: Booted secondary processor [410fd034]
          [    0.249258] Detected VIPT I-cache on CPU3
          [    0.249284] Invalid sched_group_energy for CPU3
          [    0.249286] CPU3: update cpu_capacity 1024
          [    0.249289] CPU3: Booted secondary processor [410fd034]
          [    0.249373] Brought up 4 CPUs
          [    0.300007] SMP: Total of 4 processors activated.
          [    0.304698] CPU features: detected feature: 32-bit EL0 Support
          [    0.310504] CPU features: detected feature: Kernel page table isolation (KPTI)
          [    0.321353] CPU: All CPU(s) started at EL1
          [    0.321776] alternatives: patching kernel code
          [    0.326371] Invalid sched_group_energy for CPU3
          [    0.330702] CPU3: update max cpu_capacity 1024
          [    0.335117] Invalid sched_group_energy for Cluster3
          [    0.339970] Invalid sched_group_energy for CPU2
          [    0.344477] Invalid sched_group_energy for Cluster2
          [    0.349329] Invalid sched_group_energy for CPU1
          [    0.353837] Invalid sched_group_energy for Cluster1
          [    0.358689] Invalid sched_group_energy for CPU0
          [    0.363197] Invalid sched_group_energy for Cluster0
          [    0.368565] CPU1: update max cpu_capacity 1024
          [    0.373186] devtmpfs: initialized
          [    0.423493] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
          [    0.427622] futex hash table entries: 1024 (order: 5, 131072 bytes)
          [    0.434394] atomic64_test: passed
          [    0.437126] pinctrl core: initialized pinctrl subsystem
          [    0.444463] NET: Registered protocol family 16
          [    0.448159] dump_class_init,861, success
          [    0.464052] cpuidle: using governor menu
          [    0.465421] sunxi iommu: irq = 9
          [    0.466325] vdso: 2 pages (1 code @ ffffff8008b38000, 1 data @ ffffff8009344000)
          [    0.472953] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
          [    0.481078] DMA: preallocated 256 KiB pool for atomic allocations
          [    0.488971] sun50iw10p1-r-pinctrl r_pio: initialized sunXi PIO driver
          [    0.509537] sun50iw10p1-pinctrl pio: initialized sunXi PIO driver
          [    0.514186] iommu: Adding device 1c0e000.ve to group 0
          [    0.521467] iommu: Adding device soc@03000000:disp1@1 to group 0
          [    0.522724] iommu: Adding device 6000000.disp to group 0
          [    0.527684] iommu: Adding device 6400000.eink to group 0
          [    0.533591] iommu: Adding device 6480000.g2d to group 0
          [    0.572507] pwm module init!
          [    0.578172] sunxi-pm debug v3.10
          [    0.579532] SCSI subsystem initialized
          [    0.580220] usbcore: registered new interface driver usbfs
          [    0.585132] usbcore: registered new interface driver hub
          [    0.590382] usbcore: registered new device driver usb
          [    0.595512] sunxi_i2c_adap_init()2573 - init
          [    0.600053] sunxi_i2c_probe()2292 - [i2c6] twi_drv_used = 1
          [    0.605089] sunxi_i2c_probe()2296 - [i2c6] twi_pkt_interval = 0
          [    0.610987] twi6 supply twi not found, using dummy regulator
          [    0.616687] twi_request_gpio()454 - [i2c6] init name: twi6
          [    0.622690] axp20x-i2c 6-0034: AXP20x variant AXP803 found
          [    0.637350] axp2101-regulator axp2101-regulator.0: Setting DCDC frequency for unsupported AXP variant
          [    0.640959] axp2101-regulator axp2101-regulator.0: Error setting dcdc frequency: -22
          [    0.704272] axp20x-i2c 6-0034: AXP20X driver loaded
          [    0.704381] sunxi_i2c_dma_request()1124 - [i2c6] using dma0chan0 (tx) and dma0chan1 (rx)for DMA transfers
          [    0.713489] media: Linux media interface: v0.10
          [    0.717634] Linux video capture interface: v2.00
          [    0.723008] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
          [    0.729251] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
          [    0.735611] ion_parse_dt_heap_common: id 6 type 6 name secure align 1000
          [    0.742442] drm_base=0x80000000
          [    0.745204] drm_size=0x0
          [    0.747738] tee_base=0x2000000
          [    0.751289] Advanced Linux Sound Architecture Driver Initialized.
          [    0.757539] Bluetooth: Core ver 2.22
          [    0.760439] NET: Registered protocol family 31
          [    0.764805] Bluetooth: HCI device and connection manager initialized
          [    0.771142] Bluetooth: HCI socket layer initialized
          [    0.775991] Bluetooth: L2CAP socket layer initialized
          [    0.781051] Bluetooth: SCO socket layer initialized
          [    0.787333] clocksource: Switched to clocksource arch_sys_counter
          [    0.861388] VFS: Disk quotas dquot_6.6.0
          [    0.861527] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
          [    0.869355] udc_init,0
          [    0.870585] NET: Registered protocol family 2
          [    0.887528] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
          [    0.888999] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
          [    0.895581] TCP: Hash tables configured (established 8192 bind 8192)
          [    0.901849] UDP hash table entries: 512 (order: 2, 16384 bytes)
          [    0.907695] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
          [    0.914342] NET: Registered protocol family 1
          [    0.918625] Trying to unpack rootfs image as initramfs...
          [    0.951367] Freeing initrd memory: 752K
          [    0.952824] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
          [    0.960059] audit: initializing netlink subsys (disabled)
          [    0.962758] audit: type=2000 audit(0.789:1): initialized
          [    0.969036] workingset: timestamp_bits=45 max_order=18 bucket_order=0
          [    0.986175] Registering sdcardfs 0.1
          [    0.986749] ntfs: driver 2.1.32 [Flags: R/W].
          [    0.988972] fuse init (API version 7.26)
          [    0.994523] SELinux:  Registering netfilter hooks
          [    1.001544] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
          [    1.004564] io scheduler noop registered
          [    1.008315] io scheduler deadline registered
          [    1.012825] io scheduler cfq registered (default)
          [    1.019192] [DISP]disp_module_init
          [    1.021033] disp soc@03000000:disp1@1: unable to map de registers
          [    1.026725] disp: probe of soc@03000000:disp1@1 failed with error -22
          [    1.033916] [DISP] disp_init,line:2345:
          [    1.036758] smooth display screen:0 type:1 mode:4
          [    1.080585] [DISP] Fb_copy_boot_fb,line:1645:
          [    1.080629] no boot_fb0
          [    1.082979] [DISP] lcd_clk_config,line:675:
          [    1.085747] disp 0, clk: pll(240000000),clk(24000\F0YXK\82\B1\B1\A1288000000),clk(288000000),dclk(48000000) dsi_rate(0)
          [    1.086298] [DISP]disp_module_init finish
          [    1.095756] uart uart0: get regulator failed
          [    1.095794] uart0 supply uart not found, using dummy regulator
          [    1.096057] uart0: ttyS0 at MMIO 0x5000000 (irq = 349, base_baud = 1500000) is a SUNXI
          [    1.096077] sw_console_setup()1733 - console setup baud 115200 parity n bits 8, flow n
          [    1.125715] console [ttyS0] enabled
          [    1.135265] bootconsole [earlycon0] disabled
          [    1.144359] uart uart1: get regulator failed
          [    1.152568] uart1 supply uart not found, using dummy regulator
          [    1.159388] uart1: ttyS1 at MMIO 0x5000400 (irq = 350, base_baud = 1500000) is a SUNXI
          [    1.168897] uart uart2: get regulator failed
          [    1.173747] uart2 supply uart not found, using dummy regulator
          [    1.180548] uart2: ttyS2 at MMIO 0x5000800 (irq = 351, base_baud = 1500000) is a SUNXI
          [    1.190486] misc dump reg init
          [    1.195107] G2D: Module initialized.major:246
          [    1.200853] [drm] Initialized
          [    1.204377] Unable to detect cache hierarchy for CPU 0
          [    1.223819] brd: module loaded
          [    1.242790] loop: module loaded
          [    1.247195] zram: Added device: zram0
          [    1.251555] [NAND][NE] Not found valid nand node on dts
          [    1.258039] Boot type 2
          [    1.262942] libphy: Fixed MDIO Bus: probed
          [    1.267582] tun: Universal TUN/TAP device driver, 1.6
          [    1.273280] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
          [    1.280486] PPP generic driver version 2.4.2
          [    1.285532] PPP BSD Compression module registered
          [    1.290843] PPP Deflate Compression module registered
          [    1.296551] PPP MPPE Compression module registered
          [    1.301957] NET: Registered protocol family 24
          [    1.306963] PPTP driver version 0.8.5
          [    1.311446] usbcore: registered new interface driver rtl8150
          [    1.317902] usbcore: registered new interface driver r8152
          [    1.324159] usbcore: registered new interface driver asix
          [    1.330315] usbcore: registered new interface driver ax88179_178a
          [    1.337246] usbcore: registered new interface driver cdc_ether
          [    1.343897] usbcore: registered new interface driver smsc75xx
          [    1.350455] usbcore: registered new interface driver smsc95xx
          [    1.356989] usbcore: registered new interface driver net1080
          [    1.363435] usbcore: registered new interface driver cdc_subset
          [    1.370165] usbcore: registered new interface driver zaurus
          [    1.376509] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
          [    1.384924] usbcore: registered new interface driver cdc_ncm
          [    1.391309] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
          [    1.399029] get ehci0-controller, regulator_io is no nocare
          [    1.405319] get ehci0-controller wakeup-source is fail.
          [    1.411443] sunxi ehci0-controller don't init wakeup source
          [    1.417734] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff80095e9a10, 0x:ffffff800963d000, irq_no:162
          [    1.431440] [sunxi-ehci0]: Not init ehci0
          [    1.436098] get ehci1-controller, regulator_io is no nocare
          [    1.442379] get ehci1-controller wakeup-source is fail.
          [    1.448401] sunxi ehci1-controller don't init wakeup source
          [    1.454684] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff80095e9d98, 0x:ffffff8009791000, irq_no:164
          [    1.468558] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
          [    1.478775] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
          [    1.488986] sunxi-ehci 5200000.ehci1-controller: irq 356, io mem 0xffffffc03db04010
          [    1.510689] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
          [    1.518539] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
          [    1.527397] hub 1-0:1.0: USB hub found
          [    1.531655] hub 1-0:1.0: 1 port detected
          [    1.537080] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
          [    1.544398] get ohci0-controller, regulator_io is no nocare
          [    1.550698] get ohci0-controller wakeup-source is fail.
          [    1.556801] sunxi ohci0-controller don't init wakeup source
          [    1.563198] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff80095ea4a8
          [    1.573678] [sunxi-ohci0]: Not init ohci0
          [    1.578317] get ohci1-controller, regulator_io is no nocare
          [    1.584598] get ohci1-controller wakeup-source is fail.
          [    1.590622] sunxi ohci1-controller don't init wakeup source
          [    1.596995] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff80095ea830
          [    1.607658] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
          [    1.617476] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 2
          [    1.627247] sunxi-ohci 5200000.ohci1-controller: irq 357, io mem 0xffffffc03db04400
          [    1.695673] hub 2-0:1.0: USB hub found
          [    1.699953] hub 2-0:1.0: 1 port detected
          [    1.705532] usbcore: registered new interface driver uas
          [    1.711657] usbcore: registered new interface driver usb-storage
          [    1.718509] usbcore: registered new interface driver ums-alauda
          [    1.725234] usbcore: registered new interface driver ums-cypress
          [    1.732062] usbcore: registered new interface driver ums-datafab
          [    1.738891] usbcore: registered new interface driver ums_eneub6250
          [    1.745914] usbcore: registered new interface driver ums-freecom
          [    1.752743] usbcore: registered new interface driver ums-isd200
          [    1.759475] usbcore: registered new interface driver ums-jumpshot
          [    1.766392] usbcore: registered new interface driver ums-karma
          [    1.773036] usbcore: registered new interface driver ums-onetouch
          [    1.779973] usbcore: registered new interface driver ums-realtek
          [    1.786800] usbcore: registered new interface driver ums-sddr09
          [    1.793532] usbcore: registered new interface driver ums-sddr55
          [    1.800262] usbcore: registered new interface driver ums-usbat
          [    1.806975] usbcore: registered new interface driver usbserial
          [    1.813745] usbcore: registered new interface driver option
          [    1.820076] usbserial: USB Serial support registered for GSM modem (1-port)
          [    1.828205] usb_serial_number:20080411
          [    1.833143] sunxikbd_key_init: key0 vol= 646 code= 115
          [    1.838947] sunxikbd_key_init: key1 vol= 900 code= 114
          [    1.844754] sunxikbd_key_init: key2 vol= 1077 code= 158
          [    1.850648] sunxikbd_key_init: key3 vol= 300 code= 187
          [    1.854017] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
          [    1.864031] sunxikbd_key_init: key4 vol= 880 code= 102
          [    1.870167] input: sunxi-keyboard as /devices/virtual/input/input0
          [    1.885320] input: axp803-pek as /devices/platform/soc/7081400.s_twi/i2c-6/6-0034/axp2101-pek.0/input/input1
          [    1.898344] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
          [    1.905281] sunxi-rtc rtc: RTC enabled
          [    1.909862] i2c /dev entries driver
          [    1.914262] sunxi cedar version 0.1
          [    1.918328] VE: install start!!!
          [    1.918328]
          [    1.923767] cedar_ve: cedar-ve the get irq is 347
          [    1.929469] VE: get debugfs_mpp_root is NULL, please check mpp
          [    1.929469]
          [    1.937730] VE: sunxi ve debug register driver failed!
          [    1.937730]
          [    1.951794] axp803_ac_power: axp803_ac_power_dt_parse: failed
          [    1.951794]
          [    1.959992] axp803_ac_power: axp803_ac_power_probe parse device tree err
          [    1.959992]
          [    1.969308] axp803-ac-power-supply: probe of axp803-ac-power-supply.0 failed with error -22
          [    1.979279] axp803_battery: axp803_bat_power_dt_parse: failed
          [    1.979279]
          [    1.987440] axp803_battery: axp803_bat_power_probe parse device tree err
          [    1.987440]
          [    1.996674] axp803-battery-power-supply: probe of axp803-battery-power-supply.0 failed with error -22
          [    2.008539] hub 1-1:1.0: USB hub found
          [    2.009384] device-mapper: uevent: version 1.0.3
          [    2.009872] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
          [    2.010031] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
          [    2.010037] Bluetooth: HCI UART driver ver 2.3
          [    2.010043] Bluetooth: HCI UART protocol H4 registered
          [    2.010046] Bluetooth: HCI UART protocol LL registered
          [    2.010050] Bluetooth: HCI UART protocol Three-wire (H5) registered
          [    2.015006] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
          [    2.015077] sunxi-mmc sdc2: ***ctl-spec-caps*** 308
          [    2.015487] sunxi-mmc sdc2: No vdmmc regulator found
          [    2.015492] sunxi-mmc sdc2: No vd33sw regulator found
          [    2.015497] sunxi-mmc sdc2: No vd18sw regulator found
          [    2.015501] sunxi-mmc sdc2: No vq33sw regulator found
          [    2.015505] sunxi-mmc sdc2: No vq18sw regulator found
          [    2.018093] sunxi-mmc sdc2: set host busy
          [    2.018180] mmc:failed to get gpios
          [    2.018442] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
          [    2.034008] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
          [    2.050695] sunxi-mmc sdc2: detmode:alway in(non removable)
          [    2.050718] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
          [    2.053184] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
          [    2.054261] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
          [    2.054515] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
          [    2.054597] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
          [    2.054667] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
          [    2.054739] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
          [    2.055958] sunxi-mmc sdc1: No vmmc regulator found
          [    2.055962] sunxi-mmc sdc1: No vqmmc regulator found
          [    2.055967] sunxi-mmc sdc1: No vdmmc regulator found
          [    2.055971] sunxi-mmc sdc1: No vd33sw regulator found
          [    2.055975] sunxi-mmc sdc1: No vd18sw regulator found
          [    2.055980] sunxi-mmc sdc1: No vq33sw regulator found
          [    2.055984] sunxi-mmc sdc1: No vq18sw regulator found
          [    2.057186] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
          [    2.057681] sunxi-mmc sdc1: set host busy
          [    2.057757] mmc:failed to get gpios
          [    2.057783] sunxi-mmc sdc1: min-frequency:400000
          [    2.058010] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.058034] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
          [    2.058582] random: fast init done
          [    2.074008] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.075421] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
          [    2.088791] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 8 timing LEGACY(SDR12) dt B
          [    2.090696] sunxi-mmc sdc1: detmode:manually by software
          [    2.090989] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS200 dt B
          [    2.091480] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS200 dt B
          [    2.091655] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.091770] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS(SDR20) dt B
          [    2.091920] sunxi-mmc sdc2: sdc set ios:clk 52000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS(SDR20) dt B
          [    2.092149] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS400 dt B
          [    2.092258] sunxi_mmc_get_hs400_cmd_dly,222
          [    2.092266] sunxi-mmc sdc2: failed to get HS400_cmd used default
          [    2.092310] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS400 dt B
          [    2.092416] sunxi_mmc_get_hs400_cmd_dly,222
          [    2.092424] sunxi-mmc sdc2: failed to get HS400_cmd used default
          [    2.092568] mmc0: new HS400 MMC card at address 0001
          [    2.094149] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.095439] hidraw: raw HID events driver (C) Jiri Kosina
          [    2.095571] sunxi-mmc sdc1: card claims to support voltages below defined range
          [    2.096744] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
          [    2.097864] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
          [    2.098254] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
          [    2.098643] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB
          [    2.099420] usbcore: registered new interface driver usbhid
          [    2.099422] usbhid: USB HID core driver
          [    2.099804] ashmem: initialized
          [    2.100588]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
          [    2.101812] optee: probing for conduit method from DT.
          [    2.102429] optee: initialized driver
          [    2.103184] usbcore: registered new interface driver snd-usb-audio
          [    2.106006] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
          [    2.106138] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
          [    2.106318] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
          [    2.106910] sunxi-internal-codec codec: pa_power_always_on get failed and set it off.
          [    2.106917] digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_power_always_on:0
          [    2.106926] adcdrc_cfg:2, adchpf_cfg:1, dacdrc_cfg:2, dachpf:0
          [    2.106956] gpio-spk:166
          [    2.107077] sunxi-internal-codec codec: [sunxi_internal_codec_probe] codec probe finished.
          [    2.108297] [sunxi_card_init] card init finished.
          [    2.108574] Audio: [soc_new_pcm] -> 2699
          [    2.108579] Audio: [soc_new_pcm] -> 2718
          [    2.108697] Audio: [soc_new_pcm] -> 2746
          [    2.109222] sunxi-codec-machine sndcodec: sun50iw10codec <-> codec mapping ok
          [    2.110650] mmc1: new high speed SDIO card at address 0001
          [    2.111376] input: sun50iw10-codec sunxi Audio Jack as /devices/platform/soc/sndcodec/sound/card0/input2
          [    2.111803] [audio] hp_detect_case: 0
          [    2.111808] [audio] noheadphonemic missing or it has headphonemic.
          [    2.112069] sunxi-codec-machine sndcodec: [sunxi_card_dev_probe] register card finished.
          [    2.112543] u32 classifier
          [    2.112546]     Actions configured
          [    2.112554] Netfilter messages via NETLINK v0.30.
          [    2.112571] nfnl_acct: registering with nfnetlink.
          [    2.112870] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
          [    2.113099] ctnetlink v0.93: registering with nfnetlink.
          [    2.113632] xt_time: kernel timezone is -0000
          [    2.113732] ipip: IPv4 and MPLS over IPv4 tunneling driver
          [    2.114451] gre: GRE over IPv4 demultiplexor driver
          [    2.114455] ip_gre: GRE over IPv4 tunneling driver
          [    2.115636] IPv4 over IPsec tunneling driver
          [    2.140635] ip_tables: (C) 2000-2006 Netfilter Core Team
          [    2.140957] arp_tables: arp_tables: (C) 2002 David S. Miller
          [    2.151346] Initializing XFRM netlink socket
          [    2.151382] IPsec XFRM device driver
          [    2.152210] NET: Registered protocol family 10
          [    2.153908] mip6: Mobile IPv6
          [    2.153941] ip6_tables: (C) 2000-2006 Netfilter Core Team
          [    2.174014] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
          [    2.175474] NET: Registered protocol family 17
          [    2.175506] NET: Registered protocol family 15
          [    2.175540] l2tp_core: L2TP core driver, V2.0
          [    2.175554] l2tp_ppp: PPPoL2TP kernel driver, V2.0
          [    2.182913] Registered cp15_barrier emulation handler
          [    2.182924] Registered setend emulation handler
          [    2.183855] registered taskstats version 1
          [    2.198980] sid_rd_ver_reg()418 - ver >= 4, soc ver:4
          [    2.199561] sun50i_cpufreq_nvmem: using table: b0
          [    2.202519] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
          [    2.202530] cpu cpu0: _opp_add: OPP not supported by regulators (1464000000)
          [    2.202856] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
          [    2.202861] cpu cpu0: _opp_add: OPP not supported by regulators (1608000000)
          [    2.202908] cpu cpu1: opp_list_debug_create_link: Failed to create link
          [    2.202914] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
          [    2.202950] cpu cpu2: opp_list_debug_create_link: Failed to create link
          [    2.202955] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
          [    2.202991] cpu cpu3: opp_list_debug_create_link: Failed to create link
          [    2.202996] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
          [    2.205043] get usb_detect_mode is fail, 22
          [    2.205860] switch_init: hall is not used
          [    2.209736] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:24 UTC (24)
          [    2.210780] axp803-dcdc6: disabling
          [    2.211620] axp803-dldo1: disabling
          [    2.212227] axp803-dldo2: disabling
          [    2.212834] axp803-dldo3: disabling
          [    2.213441] axp803-dldo4: disabling
          [    2.214053] axp803-eldo2: disabling
          [    2.214668] axp803-eldo3: disabling
          [    2.215951] ALSA device list:
          [    2.215954]   #0: sun50iw10-codec
          [    2.935816] hub 1-1:1.0: 4 ports detected
          [    2.938107] Freeing unused kernel memory: 4288K
          [    2.938174] Kernel init done
          [    2.945780] init: init first stage started!
          [    2.946725] init: [libfs_mgr]ReadFstabFromDt(): failed to read fstab from dt
          [    2.949412] init: Using Android DT directory /proc/device-tree/firmware/android/
          [    2.979451] init: [libfs_mgr]Created logical partition system on device /dev/block/dm-0
          [    2.989861] init: [libfs_mgr]Created logical partition vendor on device /dev/block/dm-1
          [    3.000237] init: [libfs_mgr]Created logical partition product on device /dev/block/dm-2
          [    3.009964] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
          [    3.019244] init: [libfs_mgr]Filesystem on /dev/block/by-name/metadata was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x46
          [    3.034090] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/metadata,/metadata,ext4)=-1: No such file or directory
          [    3.046411] init: [libfs_mgr]Not running /system/bin/e2fsck on /dev/block/mmcblk0p11 (executable not in system image)
          [    3.062395] EXT4-fs (mmcblk0p11): recovery complete
          [    3.068305] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: errors=panic
          [    3.078132] plugin --> switch:1
          [    3.103690] EXT4-fs (dm-0): mounted filesystem without journal. Opts: barrier=1
          [    3.119458] EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1
          [    3.130745] EXT4-fs (dm-2): mounted filesystem without journal. Opts: barrier=1
          [    3.142991] FAT-fs (mmcblk0p16): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
          [    3.181660] FAT-fs (mmcblk0p16): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
          [    3.192882] SELinux: Unable to set superblock options before the security server is initialized
          [    3.215157] init: 16 output lines suppressed due to ratelimiting
          [    3.226539] random: init: uninitialized urandom read (40 bytes read)
          [    3.322226] random: init: uninitialized urandom read (40 bytes read)
          [    3.339819] init: Loading SELinux policy
          [    3.355131] SELinux: 8192 avtab hash slots, 22216 rules.
          [    3.373042] SELinux: 8192 avtab hash slots, 22216 rules.
          [    3.379044] SELinux:  1 users, 4 roles, 1369 types, 0 bools, 1 sens, 1024 cats
          [    3.387150] SELinux:  97 classes, 22216 rules
          [    3.395587] SELinux:  Completing initialization.
          [    3.400784] SELinux:  Setting up existing superblocks.
          [    3.494551] audit: type=1403 audit(25.786:2): policy loaded auid=4294967295 ses=4294967295
          [    3.504122] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
          [    3.504122]
          [    3.521317] selinux: SELinux:  Skipping /product/etc/selinux/product_file_contexts:  empty file
          [    3.521317]
          [    3.532960] selinux: SELinux: Loaded file_contexts
          [    3.532960]
          [    3.545322] random: init: uninitialized urandom read (40 bytes read)
          [    3.593516] init: init second stage started!
          [    3.603198] FAT-fs (mmcblk0p16): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
          [    3.648146] init: Using Android DT directory /proc/device-tree/firmware/android/
          [    3.662640] selinux: SELinux:  Skipping /product/etc/selinux/product_file_contexts:  empty file
          [    3.662640]
          [    3.674273] selinux: SELinux: Loaded file_contexts
          [    3.674273]
          [    3.681342] init: Running restorecon...
          [    3.705950] init: Overriding previous 'ro.' property 'ro.product.locale':'zh-CN' with new value 'zh-Hans-CN'
          [    3.717482] init: Overriding previous 'ro.' property 'pm.dexopt.shared':'speed' with new value 'quicken'
          [    3.728239] init: Overriding previous 'ro.' property 'ro.kernel.android.checkjni':'0' with new value '1'
          [    3.741668] selinux: avc:  denied  { set } for  scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
          [    3.741668]
          [    3.759019] selinux: avc:  denied  { set } for  scontext=u:r:vendor_init:s0 tcontext=u:object_r:dalvik_prop:s0 tclass=property_service permissive=1
          [    3.759019]
          [    3.939460] ueventd: ueventd started!
          [    3.948143] selinux: SELinux:  Skipping /product/etc/selinux/product_file_contexts:  empty file
          [    3.948143]
          [    3.952496] apexd: Bootstrap subcommand detected
          [    3.958928] apexd: Scanning /system/apex for embedded keys
          [    3.960386] apexd: Scanning /product/apex for embedded keys
          [    3.960538] apexd: ... does not exist. Skipping
          [    3.960714] apexd: Scanning /system/apex looking for APEX packages.
          [    3.960975] apexd: Found /system/apex/com.android.tzdata
          [    3.961584] apexd: Successfully bind-mounted flattened package /system/apex/com.android.tzdata on /apex/com.android.tzdata@290000000
          [    3.961838] apexd: Found /system/apex/com.android.runtime.release
          [    3.962395] apexd: Successfully bind-mounted flattened package /system/apex/com.android.runtime.release on /apex/com.android.runtime@1
          [    3.962626] apexd: Found /system/apex/com.android.media.swcodec
          [    3.966735] apexd: 9 output lines suppressed due to ratelimiting
          [    4.042690] selinux: SELinux: Loaded file_contexts
          [    4.042690]
          [    4.049966] ueventd: Parsing file /ueventd.rc...
          [    4.056376] ueventd: Parsing file /vendor/ueventd.rc...
          [    4.063279] ueventd: Parsing file /odm/ueventd.rc...
          [    4.068938] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
          [    4.079917] ueventd: Parsing file /ueventd.sun50iw10p1.rc...
          [    4.086327] ueventd: Unable to read config file '/ueventd.sun50iw10p1.rc': open() failed: No such file or directory
          [    4.319743] ueventd: Coldboot took 0.22 seconds
          [    4.355414] Registered swp emulation handler
          [    4.380313] audit: type=1400 audit(26.670:3): avc:  denied  { setattr } for  pid=1158 comm="init" name="/" dev="mmcblk0p16" ino=1 scontext=u:r:vendor_init:s0 tcontext=u:object_r:oemfs:s0 tclass=dir permissive=1
          [    4.435022] EXT4-fs (mmcblk0p17): Ignoring removed nomblk_io_submit option
          [    4.473402] logd.auditd: start
          [    4.515323] EXT4-fs (mmcblk0p17): recovery complete
          [    4.521399] EXT4-fs (mmcblk0p17): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
          [    4.892615] e2fsck: e2fsck 1.44.4 (18-Aug-2018)
          [    4.892615]
          [    4.899460] e2fsck: Pass 1: Checking inodes, blocks, and sizes
          [    4.899460]
          [    4.907660] e2fsck: Pass 2: Checking directory structure
          [    4.907660]
          [    4.915278] e2fsck: Pass 3: Checking directory connectivity
          [    4.915278]
          [    4.923218] e2fsck: Pass 4: Checking reference counts
          [    4.923218]
          [    4.930544] e2fsck: Pass 5: Checking group summary information
          [    4.930544]
          [    4.938747] e2fsck: /dev/block/by-name/UDISK: 1795/279440 files (6.5% non-contiguous), 45824/1116667 blocks
          [    4.938747]
          [    4.954970] EXT4-fs (mmcblk0p17): mounted filesystem with ordered data mode. Opts: discard
          [    4.965867] EXT4-fs (mmcblk0p7): Ignoring removed nomblk_io_submit option
          [    4.977937] EXT4-fs (mmcblk0p7): recovery complete
          [    4.983803] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
          [    5.078491] e2fsck: e2fsck 1.44.4 (18-Aug-2018)
          [    5.078491]
          [    5.085336] e2fsck: Pass 1: Checking inodes, blocks, and sizes
          [    5.085336]
          [    5.093537] e2fsck: Pass 2: Checking directory structure
          [    5.093537]
          [    5.102207] EXT4-fs (mmcblk0p7): Ignoring removed nomblk_io_submit option
          [    5.111625] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: barrier=1,data=ordered,nomblk_io_submit,noauto_da_alloc,errors=panic
          [    5.150805] init: 4 output lines suppressed due to ratelimiting
          [    5.162687] zram0: detected capacity change from 0 to 762482688
          [    5.195687] mkswap: Swapspace size: 744608k, UUID=2d045edb-899d-453c-bec0-5e58d04ac7e1
          [    5.205374] Adding 744608k swap on /dev/block/zram0.  Priority:-1 extents:1 across:744608k SS
          console:/ $ Keymaster_V4_CreateEntryPoint
          keymaster load rsa_key error!
          keymaster load hardware attestation key fail!
          [    5.486272] vdc: Waited 0ms for vold
          [    5.516120] fscrypt: AES-256-CTS-CBC using implementation "cts(cbc-aes-ce)"
          [    5.611899] fscrypt: AES-256-XTS using implementation "xts-aes-ce"
          [    5.654340] apexd: Marking APEXd as starting
          [    5.659987] apexd: Scanning /system/apex for embedded keys
          [    5.668304] apexd: Scanning /product/apex for embedded keys
          [    5.674746] apexd: ... does not exist. Skipping
          [    5.679976] apexd: Populating APEX database from mounts...
          [    5.686618] apexd: Failed to walk /product/apex : Can't open /product/apex for reading : No such file or directory
          [    5.699030] apexd: Found "/apex/com.android.tzdata@290000000"
          [    5.705725] apexd: Found "/apex/com.android.runtime@1"
          [    5.711764] apexd: 2 packages restored.
          [    5.716297] apexd: Scanning /data/apex/sessions looking for sessions to be activated.
          [    5.760632] vdc: Waited 0ms for vold
          [    5.854745] type=1400 audit(28.146:4): avc: denied { setattr } for comm="init" name="audio_d" dev="mmcblk0p17" ino=71858 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
          [    5.854762] init: Setting policy on /data/audio_d
          [    5.881779] type=1400 audit(28.146:4): avc: denied { setattr } for comm="init" name="audio_d" dev="mmcblk0p17" ino=71858 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
          [    5.903224] type=1400 audit(28.146:5): avc: denied { read } for comm="init" name="audio_d" dev="mmcblk0p17" ino=71858 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
          [    5.903418] init: Policy for /data/audio_d set to 160cce2f0f2365c0 modes 1/4
          [    5.932562] type=1400 audit(28.146:5): avc: denied { read } for comm="init" name="audio_d" dev="mmcblk0p17" ino=71858 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
          [    5.953779] type=1400 audit(28.146:6): avc: denied { open } for comm="init" path="/data/audio_d" dev="mmcblk0p17" ino=71858 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
          [    5.975679] type=1400 audit(28.146:6): avc: denied { open } for comm="init" path="/data/audio_d" dev="mmcblk0p17" ino=71858 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
          [    5.997504] type=1400 audit(28.193:7): avc: denied { ioctl } for comm="init" path="/data/audio_d" dev="mmcblk0p17" ino=71858 ioctlcmd=0x6613 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
          [    6.084855] logd.daemon: reinit
          [    6.195145] treadahead: /data/vendor/treadahead/readahead_file_offset not exist;
          [    6.209539] treadahead: go to open trace
          [    6.340348] healthd: No battery devices found
          [    6.386815] healthd: battery none chg=
          [    6.453479] file system registered
          [    6.469127] using random self ethernet address
          [    6.483006] using random host ethernet address
          Gatekeeper_TA_CreateEntryPoint
          [    6.539648] type=1400 audit(28.193:7): avc: denied { ioctl } for comm="init" path="/data/audio_d" dev="mmcblk0p17" ino=71858 ioctlcmd=0x6613 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
          [    6.587143] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.06
          [    7.006510] read descriptors
          [    7.037583] read strings
          [    7.132618] pvrsrvkm: loading out-of-tree module taints kernel.
          [    7.602086] pvrsrvkm gpu: IC version: 0x00000004
          [    7.619080] pvrsrvkm gpu: gpu core id:0x1400 core:504000000
          [    7.661466] pvrsrvkm gpu: set gpu core rate:504000000 freq:504000000-950000uV dfs:0x00000001
          [    7.723503] pvrsrvkm gpu: set gpu core rate:504000000 freq:472500000-950000uV dfs:0x00000002
          [    7.778035] pvrsrvkm gpu: set gpu core rate:504000000 freq:441000000-950000uV dfs:0x00000004
          [    7.826961] pvrsrvkm gpu: set gpu core rate:252000000 freq:252000000-950000uV dfs:0x00000001
          [    7.883098] pvrsrvkm gpu: idle:0 dvfs:0 power:0 Yes mode:1 volt:950000 core:504000000
          [    7.914727] PVR_K:  1713: Read BVNC 22.102.54.38 from HW device registers
          [    7.947675] PVR_K:  1713: RGX Device registered with BVNC 22.102.54.38
          [    7.987949] [drm] Initialized pvr 1.11.5516664 20170530 on minor 0
          [    8.020047] PVR_K:  1719: RGX Firmware image 'rgx.fw.22.102.54.38' loaded
          [    8.733075] init: Received control message 'start' for 'bootanim' from pid: 1719 (/system/bin/surfaceflinger)
          [    8.749095] init: starting service 'bootanim'...
          [    9.058557] init: Received control message 'interface_start' for 'android.hardware.camera.provider@2.4::ICameraProvider/legacy/0' from pid: 1536 (/system/bin/hwservicemanager)
          [    9.391612] selinux: avc:  denied  { set } for property=display.frame.log pid=1703 uid=1000 gid=1003 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
          [    9.391612]
          [   10.059768] init: Received control message 'interface_start' for 'android.hardware.camera.provider@2.4::ICameraProvider/legacy/0' from pid: 1536 (/system/bin/hwservicemanager)
          [   10.165731] random: crng init done
          [   10.169547] random: 7 urandom warning(s) missed due to ratelimiting
          [   13.182599] healthd: battery none chg=
          [   14.295536] healthd: battery none chg=
          [   14.301350] healthd: battery none chg=
          [   14.786406] init: processing action (sys.sysctl.extra_free_kbytes=*) from (/init.rc:806)
          [   15.481806] acc_open
          [   15.484305] acc_release
          [   15.762066] init: Received control message 'interface_start' for 'android.hardware.wifi@1.0::IWifi/default' from pid: 1536 (/system/bin/hwservicemanager)
          [   15.779108] init: starting service 'vendor.wifi_hal_legacy'...
          [   15.789454] init: Received control message 'interface_start' for 'android.hardware.wifi@1.0::IWifi/default' from pid: 1536 (/system/bin/hwservicemanager)
          [   18.778205] binder_alloc: 2096: binder_alloc_buf, no vma
          [   18.784322] binder: 1715:1896 transaction failed 29189/-3, size 92-0 line 3235
          [   18.787979] binder: undelivered transaction 13164, process died.
          [   21.781427] init: processing action (sys.boot_completed=1) from (/init.rc:800)
          [   21.809813] sdcardfs version 2.0
          [   21.809819] sdcardfs: dev_name -> /data/media
          [   21.809821] sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,derive_gid,default_normal,unshared_obb,mask=6,userid=0,gid=1015
          [   21.809825] sdcardfs: mnt -> ffffffc00e798aa0
          [   21.809923] sdcardfs: mounted on top of /data/media type ext4
          [   21.811368] Remount options were mask=23,gid=9997 for vfsmnt ffffffc033ade020.
          [   21.811382] sdcardfs : options - debug:1
          [   21.811385] sdcardfs : options - gid:9997
          [   21.811387] sdcardfs : options - mask:23
          [   21.811980] Remount options were mask=7,gid=9997 for vfsmnt ffffffc033adefe0.
          [   21.811993] sdcardfs : options - debug:1
          [   21.811995] sdcardfs : options - gid:9997
          [   21.811997] sdcardfs : options - mask:7
          [   21.812557] Remount options were mask=7,gid=9997 for vfsmnt ffffffc023a2e560.
          [   21.812570] sdcardfs : options - debug:1
          [   21.812573] sdcardfs : options - gid:9997
          [   21.812575] sdcardfs : options - mask:7
          [   21.978101] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.device.rc:43)
          [   21.991020] axp803_usb_power: current limit not set: usb adapter type
          [   21.991020]
          [   22.022865] init: Service 'bootanim' (pid 1908) exited with status 0
          [   22.030034] init: Sending signal 9 to service 'bootanim' (pid 1908) process group...
          [   22.039161] libprocessgroup: Successfully killed process cgroup uid 1003 pid 1908 in 0ms
          [   22.051240] init: processing action (sys.boot_completed=1) from (/system/etc/init/aw_thermal.rc:10)
          [   22.061871] init: starting service 'aw_thermal'...
          [   22.072083] init: processing action (sys.boot_completed=1 && sys.logbootcomplete=1) from (/system/etc/init/bootstat.rc:78)
          [   22.074116] selinux: SELinux: Skipping restorecon on directory(/data/system_ce/0)
          [   22.074116]
          [   22.095708] init: starting service 'exec 12 (/system/bin/bootstat --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l)'...
          [   22.260206] treadahead: /data/vendor/treadahead/readahead_file_offset not exist;
          [   22.268964] treadahead: go to read trace
          [   22.651482] type=1400 audit(31.680:28): avc: denied { getattr } for comm="composer@2.2-se" path="/dev/__properties__/u:object_r:default_prop:s0" dev="tmpfs" ino=9738 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1
          [   22.678972] type=1400 audit(1675902609.063:29): avc: denied { search } for comm="CompactionThrea" name="irq" dev="proc" ino=4026531869 scontext=u:r:system_server:s0 tcontext=u:object_r:proc_irq:s0 tclass=dir permissive=1
          [   24.771204] apexd: Can't open /product/apex for reading : No such file or directory
          [   32.186654] type=1400 audit(1675902609.063:29): avc: denied { search } for comm="CompactionThrea" name="irq" dev="proc" ino=4026531869 scontext=u:r:system_server:s0 tcontext=u:object_r:proc_irq:s0 tclass=dir permissive=1
          [   32.209079] type=1400 audit(1675902618.603:30): avc: denied { dac_override } for comm="irqbalance" capability=1 scontext=u:r:shell:s0 tcontext=u:r:shell:s0 tclass=capability permissive=1
          [   34.199678] type=1400 audit(1675902618.603:30): avc: denied { dac_override } for comm="irqbalance" capability=1 scontext=u:r:shell:s0 tcontext=u:r:shell:s0 tclass=capability permissive=1
          [   34.204816] treadahead: read trace end
          [   34.222703] type=1400 audit(1675902620.616:31): avc: denied { ptrace } for comm="crash_dump32" scontext=u:r:crash_dump:s0 tcontext=u:r:vendor_init:s0 tclass=process permissive=1
          [   34.340254] logd: logdr: UID=0 GID=0 PID=2983 n tail=50 logMask=8 pid=2478 start=0ns timeout=0ns
          [   34.352816] logd: logdr: UID=0 GID=0 PID=2983 n tail=50 logMask=1 pid=2478 start=0ns timeout=0ns
          [   34.365066] logd: logdr: UID=0 GID=0 PID=2983 n tail=0 logMask=8 pid=2478 start=0ns timeout=0ns
          [   34.376233] logd: logdr: UID=0 GID=0 PID=2983 n tail=0 logMask=1 pid=2478 start=0ns timeout=0ns
          [   34.392224] init: Untracked pid 2983 exited with status 0
          [   34.398741] init: Untracked pid 2985 exited with status 0
          [   34.418448] treadahead: parser trace end
          [   34.439791] init: Service 'treadahead_trace' (pid 2478) exited with status 0
          [   34.447749] init: Sending signal 9 to service 'treadahead_trace' (pid 2478) process group...
          [   34.457630] libprocessgroup: Successfully killed process cgroup uid 0 pid 2478 in 0ms
            zhoutian LV 5 @whycan 最后由 编辑
            @whycan 日志见下,您帮忙看下
              @zhoutian
              然后串口终端不能输入了吗?
                @whycan 您好,串口是可以正常输入的,但是,adb识别不到
                正常adb是可以识别到的
                  @zhoutian
                  如果串口可以输入,说明系统问题不大。
                  只是adb不能通讯吗?
                    @whycan 是的,adb没有启动
                    还有一个问题是,怎么判断系统是否已经开机完毕?
                      @zhoutian
                      命令行可以输入,系统基本上起来了。
                      usb口可以烧录吗?
                        @whycan 您好,问题已清除,感谢您的回答
