    Orange pi zero2 H616 从emmc启动出现以下错误
    H/F/TV Series
    6831
      wilsonli LV 3 最后由 xiaowenge 编辑
      编译了H616 tina-linux sdk,生产镜像成功。烧录emmc卡成功后,系统启动遇到以下问题,请各位解答这是什么错误。
      [37]HELLO! BOOT0 is starting!
      [40]BOOT0 commit : 3ae35eb
      [43]set pll start
      [45]periph0 has been enabled
      [48]set pll end
      [50]unknow PMU
      [52]PMU: AXP806
      [59]dram para16 invalid use default para
      [63]vaild para:1  select dram para0
      [66]board init ok
      [68]DRAM BOOT DRIVE INFO: V0.648
      [71]the chip id is 0x5000
      [74]chip id check OK
      [76]DRAM_VCC set to 1500 mv
      [82]read_calibration error
      [87]read_calibration error
      [93]read_calibration error
      [99]read_calibration error
      [104]read_calibration error
      [110]read_calibration error
      [116]read_calibration error
      [122]read_calibration error
      [127]read_calibration error
      [133]read_calibration error
      [136]retraining final error
      [142][AUTO DEBUG]32bit,1 ranks training success!
      [154]DRAM CLK =720 MHZ
      [156]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
      [164]Actual DRAM SIZE =1024 M
      [167]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6041
      [180]DRAM simple test OK.
      [182]rtc standby flag is 0x0, super standby flag is 0x0
      [188]dram size =1024
      [191]card no is 0
      [192]sdcard 0 line count 4
      [195][mmc]: mmc driver ver 2021-10-12 13:56
      [199][mmc]: b mmc 0 bias 0
      [207][mmc]: Wrong media type 0x0
      [210][mmc]: ***Try SD card 0***
      [221][mmc]: HSSDR52/SDR25 4 bit
      [224][mmc]: 50000000 Hz
      [226][mmc]: 29818 MB
      [228][mmc]: ***SD/MMC 0 init OK!!!***
      [328]Loading boot-pkg Succeed(index=0).
      [331][mmc]: b mmc 0 bias 0
      [334]Entry_name        = u-boot
      [343]Entry_name        = monitor
      [347]Entry_name        = dtbo
      [350]Entry_name        = dtb
      [353]Jump to second Boot.
      NOTICE:  BL3-1: v1.0(debug):05d6c57
      NOTICE:  BL3-1: Built : 13:35:35, 2021-10-28
      NOTICE:  BL3-1 commit: 8
      NOTICE:  cpuidle init version V1.0
      ERROR:   Error initializing runtime service tspd_fast
      NOTICE:  BL3-1: Preparing for EL3 exit to normal world
      NOTICE:  BL3-1: Next image address = 0x4a000000
      ?OTICE:  BL3-1: Next image spsr = 0x1d3
      U-Boot 2018.05-g768449b (Apr 14 2023 - 15:44:12 +0800) Allwinner Technology
      [00.398]CPU:   Allwinner Family
      [00.401]Model: sun50iw9
      I2C:   ready
      [00.406]DRAM:  1 GiB
      [00.408]Relocation Offset is: 35ebf000
      [00.444]secure enable bit: 0
      [00.448]pmu_axp152_probe pmic_bus_read fail
      [00.452]PMU: AXP806
      [00.453]PMU: pmu_axp806 found
      [00.459]dcdcc_vol = 960, onoff=1
      [00.462]aldo1_vol = 3300, onoff=1
      [00.465]bldo1_vol = 1800, onoff=1
      [00.469]dcdcd_vol = 1340, onoff=1
      [00.472]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
      [00.479]init_clocks:finish
      [00.481]drv_disp_init
      [00.507]HDMI 2.0 driver init start!
      [00.515]__clk_enable: clk is null.
      [00.518]hdmi cec clk enable failed!
      [00.524]drv_disp_init finish
      [00.527]gic: sec monitor mode
      [00.529]sunxi flash type@1 not support fast burn key
      [00.535]boot_gui_init:start
      tcon_de_attach:de=0,tcon=2[00.542][HDMI2.0]CEA VIC=16: [00.545]1920x1080p[00.546]@60 Hz [00.548]16:9, [00.549]8-bpp [00.550]YCbCr-444
      [00.552]BT709
      [00.553]eotf:SDR_LUMINANCE_RANGE
      [00.669]switch device: sel=0, type=4, mode=10, format=1, bits=0, eotf=4, cs=257
      [00.676]boot_gui_init:finish
      [00.679]flash init start
      [00.681]workmode = 17,storage type = 1
      try card 2
      set card number 2
      get card number 2
      [00.689][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
      [00.695][mmc]: get sdc_type fail and use default host:tm4.
      [00.706][mmc]: Is not Boot mode!
      [00.709][mmc]: SUNXI SDMMC Controller Version:0x40502
      [00.720][mmc]: ************Try SD card 2************
      [00.725][mmc]: mmc 2 cmd timeout 100 status 100
      [00.729][mmc]: smc 2 err, cmd 8,  RTO
      [00.733][mmc]: mmc 2 close bus gating and reset
      [00.738][mmc]: mmc 2 cmd timeout 100 status 100
      [00.742][mmc]: smc 2 err, cmd 55,  RTO
      [00.745][mmc]: mmc 2 close bus gating and reset
      [00.750][mmc]: ************Try MMC card 2************
      [00.758][mmc]: mmc 2 cmd timeout 100 status 100
      [00.762][mmc]: smc 2 err, cmd 1,  RTO
      [00.766][mmc]: mmc 2 close bus gating and reset
      [00.770][mmc]: Card did not respond to voltage select!
      [00.775][mmc]: ************SD/MMC 2 init error!************
      [00.780][mmc]: mmc init product failed
      MMC init failed
      try emmc fail
      nand common1 version: v1.17 2021-02-22 16:10
      [00.790]NB1 : enter phy init
      [00.793][NI]enter rawnand hardward init..
      [00.804][NE]rawnand not support chip 0: 06 06 06 06 06 06 06 06
      [00.809][NE]rawnand not support chip 1: 06 06 06 06 06 06 06 06
      [00.815][NE]rawnand not support chip 2: 06 06 06 06 06 06 06 06
      [00.821][NE]rawnand not support chip 3: 06 06 06 06 06 06 06 06
      [00.826][NE]no rawnand found!
      [00.829][NE]rawnand_channel_init channel@0 chips init fail
      [00.834][NI]rawnand hardward init fail
      [00.838][NI]---rawnand_dump_clock start---
      [00.841][NI]SUNXI_CCM_BASE: 0x03001000
      [00.845][NI]nand0 clk: 8300010e
      [00.848][NI]nand1 clk: 8300010e
      [00.851][NI]nand bus gating reset: 10001
      [00.854][NI]mbus cfg: c1000002
      [00.857][NI]mbus master clk gating: 25
      [00.861][NI]pll_peri0 ctrl: b8003100
      [00.864][NI]pll_peri1 ctrl: 88003100
      [00.867][NI]---rawnand_dump_clock end---
      [00.871][NI]---rawnand_dump_gpio_nand start---
      [00.875][NI]SUNXI_PIO_BASE: 0x0300b000
      [00.878][NI]pc cfg0: 22222222
      [00.881][NI]pc cfg1: 22222222
      [00.884][NI]pc cfg2 2
      [00.886][NI]pc data: 0
      [00.888][NI]pc drv0_lvl: 55555555
      [00.891][NI]pc drv1_lvl: 1
      [00.893][NI]pc pull_0: 40000440
      [00.896][NI]pc pull_1: 1
      [00.898][NI]voltage mode select: 0
      [00.901][NI]---rawnand_dump_gpio_nand end---
      [00.905][NE]nand_physic_init error -1
      [00.909]NB1 : nand phy init fail
      [00.912]Failed to probe nand flash
      try nand fail
      SF: Detected mx25l1606e with page size 256 Bytes, erase size 4 KiB, total 2 MiB
      [00.930]MMC:	 0
      [00.931][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
      [00.937][mmc]: get sdc_type fail and use default host:tm1.
      [00.948][mmc]: Using default timing para
      [00.952][mmc]: SUNXI SDMMC Controller Version:0x40200
      [00.970][mmc]: card_caps:0x3000000a
      [00.973][mmc]: host_caps:0x3000003f
      [00.978]Loading Environment from SUNXI_FLASH... OK
      [00.983]try to burn key
      [00.986]out of usb burn from boot: not boot mode
      [00.990]Net:   [00.991]Net Initialization Skipped
      [00.994]No ethernet found.
      sunxi work mode=0x11
      run card sprite
      [01.010]try sprite_led_gpio config
      [01.014]sprite_led_gpio start
      [01.017]sunxi sprite begin
      screen_width = 1280
      screen_height = 720
      bar x1: 320 y1: 320
      bar x2: 960 y2: 400
      ** Unable to read file font32.sft **
      sunxi ui_char info error : unable to open font file font32.sft
      ui_char_info.word_size is 32
      boot_ui_char: open font failed
      firmware name <NULL>
      img start = 0x18000
      try to read mmc start 98304
      read mmc ok
      [01.062]firmware probe ok
      [01.064]fetch download map
      *************DOWNLOAD MAP DUMP************
      total download part 4
      download part[0] name          :bootloader
      download part[0] download file :BOOT-RESOURCE_FE
      download part[0] verify file   :VBOOT-RESOURCE_F
      download part[0] lenlo         :0x10000
      download part[0] addrlo        :0x8000
      download part[0] encrypt       :0x0
      download part[0] verify        :0x1
      download part[1] name          :env
      download part[1] download file :ENV_FEX000000000
      download part[1] verify file   :VENV_FEX00000000
      download part[1] lenlo         :0x8000
      download part[1] addrlo        :0x18000
      download part[1] encrypt       :0x0
      download part[1] verify        :0x1
      download part[2] name          :boot
      download part[2] download file :BOOT_FEX00000000
      download part[2] verify file   :VBOOT_FEX0000000
      download part[2] lenlo         :0x10000
      download part[2] addrlo        :0x20000
      download part[2] encrypt       :0x0
      download part[2] verify        :0x1
      download part[3] name          :rootfs
      download part[3] download file :ROOTFS_FEX000000
      download part[3] verify file   :VROOTFS_FEX00000
      download part[3] lenlo         :0x40000
      download part[3] addrlo        :0x30000
      download part[3] encrypt       :0x0
      download part[3] verify        :0x1
      [01.176]fetch mbr
      sunxi sprite error : buffer is smaller than data size
      sunxi sprite error : read mbr failed
      sunxi sprite error : fetch mbr error
      sprite_test - do a sprite test
      Usage:
      sprite_test NULL
      whycan W 2 条回复 最后回复 回复 引用 分享 0
        whycan晕哥 LV 9 @wilsonli 最后由 编辑
        @wilsonli 在 Orange pi zero2 H616 从emmc启动出现以下错误 中说:
        eMMC 多大?
          wilsonli LV 3 @whycan 最后由 编辑
            @whycan 32GB
              wilsonli LV 3 @wilsonli 最后由 编辑
              补充一个信息,使用orage 提供orange pi zero2 的img可以正常启动,但自己编译全志的tina-linux启动失败。
              Y 1 条回复 最后回复 回复 引用 分享 0
                YiXinTai LV 5 @wilsonli 最后由 编辑
                @wilsonli 配置文件最好对比一下
                W 1 条回复 最后回复 回复 引用 分享 0
                  wilsonli LV 3 @YiXinTai 最后由 编辑
                  @yixintai 谢谢,正在对比这里。
                  只是关于sys_config.fex配置等待文档较少,学习门槛比较陡峭
