    【复刻麦当劳游戏机】用 ST7789V LCD 在 lichee pi nano (f1c100s)
    6674
    • bankbank
      bankbank LV 3 最后由 xiaowenge 编辑
      大家好。 我是一个外国人,对不起我中文一点不好 🤠
      我买 lichee pi nano (f1c100s), 用这个 buildroot https://github.com/mclewell/licheepi-nano-lcd
      here is the display I am using:
      now, when I power on the system, nothing appears on the display
      what should I do to use this LCD display on the lichee pi nano?
      I want to create a 游戏机 using this 麦当劳 outer shell:
      I am a big fan of allwinner arm soc, they are very power efficient and cost effective
      总功耗极低,效率高
      https://jaycarlson.net/embedded-linux/#1602627646108-72e75a29-4918
      please help me figure out how to connect this 40-pin LCD to my lichee pi nano board. it can use SPI or MCU/CPU
      thank you very much for your help!
      bankbank
      • steward
        司徒 LV 6 最后由 编辑
        @bankbank long time no see. 💃
        Please post the pinout information of the LCD panel and then we can decide how to connect it to F1C100S.
        bankbank 1 条回复 最后回复 回复 引用 分享 2
        • bankbank
          bankbank LV 3 @steward 最后由 编辑
          @steward 真棒, here's the information regarding the LCD pinout:
          • steward
            司徒 LV 6 最后由 编辑
            Here is the schematic of PocketGo handheld: https://github.com/steward-fu/archives/releases/download/pocketgo/doc_schematic.pdf
            It seems the pinout are not same as PocketGo. So, you cannot replace it directly.
              lovexulu LV 7 @bankbank 最后由 编辑
              @bankbank Hello, F1c100 supports MCU display drivers, but to use it correctly, you need to modify the Linux device tree configuration and configure the corresponding driver yourself, including the initialization program for the screen you currently have. This is a relatively complicated process, and if you are familiar with Linux drivers, it may be very simple. Here is a reference imagergb-mcu.png
              bankbank 1 条回复 最后回复 回复 引用 分享 1
              • bankbank
                bankbank LV 3 @lovexulu 最后由 bankbank 编辑
                @lovexulu hey lovexulu, thanks for the information. I'm looking to learn exactly how to do what you describe, so thanks for pointing me in the right direction.
                someone has shared with me some st7789 display driver code
                https://github.com/MiyooCFW/kernel/blob/master/drivers/video/fbdev/st7789sfb.c
                this comes from the miyoo 游戏机 that also uses f1c100s
                so maybe if I drop this st7789sfb.c file in
                licheenano/licheepi-nano-lcd/buildroot/dl/linux/git/drivers/video/fbdev/
                and then make buildroot it'll bring it in? or do I need to explicitly declare the file somewhere?
                more information about using this display with miyoo cfw:
                https://github.com/MiyooCFW/kernel/blob/master/Documentation/devicetree/bindings/display/panel/sitronix%2Cst7789v.txt
                • steward
                  司徒 LV 6 最后由 编辑
                  No, you need to fix your hardware firstly. Here is the LCD pinout for Lichee Nano:
                  And here is your LCD panel:
