    R328-S2使用W25N02问题
    8135
    • Q
      qqqlb LV 7 最后由 编辑
      我在R328-S2上使用W25N02KVZEIR,在uboot-id.c文件添加这个器件的支持,但是烧录的时候失败了。
      日志:
      [904]fes begin
      [906]set pll start
      [909]set pll end
      [910]board init ok
      [912]beign to init dram
      [915]the chip id is 0x1
      [917]the chip id is 0x1
      [919]the chip id is 0x1
      [922]the chip id is 0x1
      [924]the chip id is 0x1
      [927]chip id check OK
      [929][AUTO DEBUG] Bstart detect DDR3...
      [934][AUTO DEBUG] Bstart detect DDR2...
      [938][AUTO DEBUG] two rank and full DQ!
      [942][AUTO DEBUG] DDR2 try success
      [946][AUTO DEBUG] single rank and full DQ!
      [951][AUTO DEBUG] rank 0 row = 13
      [954][AUTO DEBUG] rank 0 bank = 4
      [957][AUTO DEBUG] rank 0 page size = 2 KB
      [962]DRAM BOOT DRIVE INFO: V0.18
      [965]DRAM CLK = 528 MHz
      [967]DRAM Type = 2 (2:DDR2,3:DDR3)
      [971]DRAMC read ODT  off.
      [973]DRAM ODT off.
      [976]DRAM SIZE =64 M
      [982]DRAM simple test OK.
      [984]init dram ok
      U-Boot 2018.05 (Jul 24 2023 - 15:36:42 +0800) Allwinner Technology
      [03.673]CPU:   Allwinner Family
      [03.675]Model: sun8iw18
      I2C:   Error, wrong i2c adapter 1 max 1 possible
      ready
      [03.682]DRAM:  64 MiB
      [03.685]Relocation Offset is: 00f0e000
      [03.711]secure enable bit: 0
      [03.714]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=264Mhz
      [03.724]gic: normal mode
      [03.727]flash init start
      [03.729]workmode = 16,storage type = 0
      [03.733]NAND_UbootProbe start
      [03.735]NB1 : enter phy init
      [03.738]nand_physic_init
      [03.745]nand not support! channel 0 chip 0: 03 03 03 03 03 03 03 03
      [03.750]nand not support! channel 0 chip 1: 03 03 03 03 03 03 03 03
      [03.756]nand not support! channel 0 chip 2: 03 03 03 03 03 03 03 03
      [03.762]nand not support! channel 0 chip 3: 03 03 03 03 03 03 03 03
      Change PC_Power Mode Select to 1.8V
      [03.772]nand not support! channel 0 chip 0: 03 03 03 03 03 03 03 03
      [03.778]nand not support! channel 0 chip 1: 03 03 03 03 03 03 03 03
      [03.784]nand not support! channel 0 chip 2: 03 03 03 03 03 03 03 03
      [03.790]nand not support! channel 0 chip 3: 03 03 03 03 03 03 03 03
      Change PC_Power Mode Select to 3.3V
      [03.799] no nand found !
      [03.801]nand_physic_init nand_build_nsi error
      [03.805]nand_physic_init error -1
      [03.808]SpiNandHwInit: Start Nand Hardware initializing .....
      [03.814]uboot: nand version: 3 6066 20190725 18212019
      [03.822]request spi gpio  ok!
      [03.824]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x43fa22c8
      [03.832]request general tx dma channel ok!
      [03.836]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x43fa22e4
      [03.843]request general rx dma channel ok!
      sclk0_reg_adr: 0x8300030e, src clock: 0xb8003100
      sclk0_reg_adr: 0x8300020e, src clock: 0xb8003100
      [03.855]SPI nand ID: 22aaef 0
      [03.858]SPI nand ID: 22aaef00 0
      [03.861]_SearchNandArchi fail
      [03.864][ERR]SpiNandHwInit: SCN_AnalyzeNandSystem() failed!
      [03.869]SpiNandHwInit: End Nand Hardware initializing ..... FAIL!
      [03.875]NB1 : nand phy init fail
      [03.878]NAND_UbootProbe end: 0xffffffff
      try nand fail
      [03.883]unrecognized JEDEC id bytes: ff, ef, aa
      data abort
      pc : [<43f28ba2>]          lr : [<43f28b85>]
      reloc pc : [<4301aba2>]    lr : [<4301ab85>]
      sp : 42adac40  ip : 00000007     fp : 43010fd9
      r10: 43010fb9  r9 : 42aeda78     r8 : 00000000
      r7 : 42b278d0  r6 : 43f6d670     r5 : ffffffed  r4 : 42b27908
      r3 : 00003000  r2 : 00000001     r1 : 0000000a  r0 : c0000000
      Flags: Nzcv  IRQs on  FIQs off  Mode SVC_32
      Resetting CPU ...
      resetting ...
      id.c
      		.Model		= "W25N02KVZEIR",
      		.NandID		= {0xef, 0xaa, 0x22, 0xff, 0xff, 0xff, 0xff, 0xff},
      		.DieCntPerChip  = 2,
      		.SectCntPerPage = 4,
      		.PageCntPerBlk  = 64,
      		.BlkCntPerDie	= 1024,
      		.OobSizePerPage = 64,
      		.OperationOpt	= SPINAND_QUAD_READ | SPINAND_QUAD_PROGRAM |
      			SPINAND_DUAL_READ,
      		.MaxEraseTimes  = 65000,
      		.EccType	= BIT2_LIMIT1_ERR2,
      		.EccProtectedType = SIZE16_OFF4_LEN4_OFF8,
      		.BadBlockFlag = BAD_BLK_FLAG_FRIST_1_PAGE,
      请教一下各位大佬,这是什么问题呢?id.c上的配置信息这样填写正确吗?
        WhycanService LV 8 @qinlinbin 最后由 编辑
        @qinlinbin 在 R328-S2使用W25N02问题 中说:
        参数有问题,没识别到NAND
        Q 1 条回复 最后回复 回复 引用 分享 0
        • Q
          qqqlb LV 7 @WhycanService 最后由 编辑
          @whycanservice 我对比了正常的flash芯片(支持列表里面的),这里也是会打印这个log,到了打印“SPI nand ID: 22aaef 0”之后,log才不一样。我看晕哥在其它帖子上说d1s/d1h支持了W25N02,那这个配置参数能发一下吗?
          DAIZEBIN 2 条回复 最后回复 回复 引用 分享 0
          • DAIZEBIN
            DAIZEBIN LV 7 @qinlinbin 最后由 编辑
            @qinlinbin R328的spinand驱动目前是不开源的
            • DAIZEBIN
              @qinlinbin 另外,目前在R328平台,释放了开源物料补丁,若是有R328 SDK权限的话,是可以在SDK下载页面获取到该补丁的
              • Q
                qqqlb LV 7 @DAIZEBIN 最后由 编辑
                @daizebin 好的,非常感谢。再请教一下,这个开源物料补丁是什么东西呢
                • DAIZEBIN
                  @qinlinbin 需要有R328的SDK权限,在对应的SDK下载页面下拉,会看到一个补丁名称为“R328方案添加spinand开源移植库”,按照里面的README操作即可
                  • Q
                    @daizebin 好的,非常感谢
