    T113/D1-H (MQ-Pro)驱动 OV5640 摄像头(内含驱动源码)
    15
    22669
      柚木 鉉 LV 9 最后由 awwwwa 编辑
      内核配置
      运行 m kernel_menuconfig 勾选下列驱动
      Device Drivers  --->
          <*> Multimedia support  --->
              [*]   V4L platform devices  --->
                  <*>   Video Multiplexer
              [*]   SUNXI platform devices  --->
                  <*>   sunxi video input (camera csi/mipi isp vipp)driver
                  <M>     v4l2 new driver for SUNXI
                  <*>     use cci function
                              select cci or cci to twi (chenge cci to twi)  --->
                  [*]     use IOMMU for memery alloc
                  [*]     ISP WDR module
                  [*]     sensor same i2c addr
                  sensor driver select  --->
                      <M> use ov5640 driver
              [*]   Memory-to-memory multimedia devices  --->
                  <*>   Deinterlace support
                  <*>   SuperH VEU mem2mem video processing driver
      设备树配置
      路径:lichee/linux-5.4/arch/riscv/boot/dts/sunxi/sun20iw1p1.dtsi
      		vind0: vind@5800800 {
      			#address-cells = <2>;
      			#size-cells = <2>;
      			ranges;
      			device_id = <0>;
      			csi_top = <336000000>;
      			csi_isp = <327000000>;
      				<0x0 0x05800000 0x0 0x800>;
      			clocks = <&ccu CLK_CSI_TOP>, <&ccu CLK_PLL_VIDEO1_2X>,
      				<&ccu CLK_CSI0_MCLK>, <&dcxo24M>, <&ccu CLK_PLL_VIDEO1>,
      				<&ccu CLK_BUS_CSI>, <&ccu CLK_MBUS_CSI>;
      					"csi_bus", "csi_mbus";
      			resets = <&ccu RST_BUS_CSI>;
      			reset-names = "csi_ret";
      			pinctrl-names = "mclk0-default", "mclk0-sleep";
      			pinctrl-0 = <&csi_mclk0_pins_a>;
      			pinctrl-1 = <&csi_mclk0_pins_b>;
      			csi0: csi@5801000{
      				reg = <0x0 0x05801000 0x0 0x1000>;
      				interrupts-extended = <&plic0 116 IRQ_TYPE_LEVEL_HIGH>;
      				pinctrl-0 = <&csi0_pins_a>;
      				pinctrl-1 = <&csi0_pins_b>;
      				device_id = <0>;
      				iommus = <&mmu_aw 1 1>;
      			isp0: isp@5809410 {
      				reg = <0x0 0x05809410 0x0 0x10>;
      				device_id = <0xfe>;
      			isp1: isp@5809420 {
      				reg = <0x0 0x05809420 0x0 0x10>;
      				device_id = <0xff>;
      			scaler0: scaler@5809430 {
      				reg = <0x0 0x05809430 0x0 0x10>;
      				device_id = <0xfe>;
      			scaler1: scaler@5809440 {
      				reg = <0x0 0x05809440 0x0 0x10>;
      				device_id = <0xff>;
      			actuator0: actuator@5809450 {
      				device_type = "actuator0";
      				reg = <0x0 0x05809450 0x0 0x10>;
      				actuator0_slave = <0x18>;
      				actuator0_af_pwdn = <>;
      			flash0: flash@5809460 {
      				device_type = "flash0";
      				reg = <0x0 0x05809460 0x0 0x10>;
      				flash0_type = <2>;
      				flash0_en = <>;
      				flash0_mode = <>;
      				flash0_flvdd = "";
      				flash0_flvdd_vol = <>;
      				device_id = <0>;
      			sensor0: sensor@5809470 {
      				device_type = "sensor0";
      				sensor0_mname = "ov5640";
      				sensor0_twi_cci_id = <2>;
      				sensor0_twi_addr = <0x78>;
      				sensor0_mclk_id = <0>;
      				sensor0_pos = "rear";
      				sensor0_isp_used = <0>;
      				sensor0_fmt = <0>;
      				sensor0_stby_mode = <0>;
      				sensor0_vflip = <0>;
      				sensor0_hflip = <0>;
      				sensor0_iovdd-supply = <>;
      				sensor0_iovdd_vol = <>;
      				sensor0_avdd-supply = <>;
      				sensor0_avdd_vol = <>;
      				sensor0_dvdd-supply = <>;
      				sensor0_dvdd_vol = <>;
      				sensor0_power_en = <>;
      				sensor0_reset = <&pio PE 14 GPIO_ACTIVE_LOW>;
      				sensor0_pwdn = <&pio PE 15 GPIO_ACTIVE_LOW>;
      				sensor0_sm_vs = <>;
      				flash_handle = <&flash0>;
      				act_handle = <&actuator0>;
      				device_id = <0>;
      				status	= "okay";
      			sensor1: sensor@5809480 {
      				reg = <0x0 0x05809480 0x0 0x10>;
      				device_type = "sensor1";
      				sensor1_mname = "ov5647";
      				sensor1_twi_cci_id = <3>;
      				sensor1_twi_addr = <0x6c>;
      				sensor1_mclk_id = <1>;
      				sensor1_pos = "front";
      				sensor1_isp_used = <0>;
      				sensor1_fmt = <0>;
      				sensor1_stby_mode = <0>;
      				sensor1_vflip = <0>;
      				sensor1_hflip = <0>;
      				sensor1_iovdd-supply = <>;
      				sensor1_iovdd_vol = <>;
      				sensor1_avdd-supply = <>;
      				sensor1_avdd_vol = <>;
      				sensor1_dvdd-supply = <>;
      				sensor1_dvdd_vol = <>;
      				sensor1_power_en = <>;
      				sensor1_sm_vs = <>;
      				flash_handle = <>;
      				act_handle = <>;
      				device_id = <1>;
      				status	= "disabled";
      			vinc0: vinc@5809000 {
      				device_type = "vinc0";
      				interrupts-extended = <&plic0 111 IRQ_TYPE_LEVEL_HIGH>;
      				vinc0_csi_sel = <0>;
      				vinc0_mipi_sel = <0xff>;
      				vinc0_isp_sel = <0>;
      				vinc0_tdm_rx_sel = <0xff>;
      				vinc0_rear_sensor_sel = <0>;
      				vinc0_front_sensor_sel = <0>;
      				vinc0_sensor_list = <0>;
      				device_id = <0>;
      			vinc1: vinc@5809200 {
      				device_type = "vinc1";
      				reg = <0x0 0x05809200 0x0 0x200>;
      				interrupts-extended = <&plic0 112 IRQ_TYPE_LEVEL_HIGH>;
      				vinc1_csi_sel = <0>;
      				vinc1_mipi_sel = <0xff>;
      				vinc1_isp_sel = <1>;
      				vinc1_tdm_rx_sel = <0xff>;
      				vinc1_rear_sensor_sel = <0>;
      				vinc1_front_sensor_sel = <0>;
      				vinc1_sensor_list = <0>;
      				device_id = <1>;
      ROOTFS 配置
      运行 m menuconfig,勾选 <*> kmod-sunxi-vin......................................... sunxi-vin support
      常见错误
      [VIN_ERR]media_entity_find_link null
      驱动版本不匹配所致,目前SDK分支过多驱动版本过多,用下列驱动替换即可:
      sunxi-vin.tar.gz
      解压,覆盖到 tina-d1-h/lichee/linux-5.4/drivers/media/platform/sunxi-vin 文件夹
      测试固件
      tina_d1-h-mq_pro_uart0.zip
      1 条回复 最后回复 回复 引用 分享 24
      • Referenced by  WhycanService WhycanService
        L 2 条回复 最后回复 回复 引用 分享 14
          linsen LV 7 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru 是不是可同样适用于T113-S3
            @yuzukitsuru 加载之后报段错误,这个版本能不能解决这个问题
            root@TinaLinux:/lib/modules/5.4.61# insmod videobuf2-memops.ko
            root@TinaLinux:/lib/modules/5.4.61# insmod videobuf2-dma-contig.ko
            root@TinaLinux:/lib/modules/5.4.61# insmod videobuf2-vmalloc.ko
            root@TinaLinux:/lib/modules/5.4.61# insmod vin_io.ko
            [   72.641600] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
            [   72.651954] [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
            [   72.661786] [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
            [   72.671670] [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
            [   72.682016] [VIN_WARN]sensor_helper_probe: cannot get sensor1_cameravdd supply, setting it to NULL!
            [   72.692318] [VIN_WARN]sensor_helper_probe: cannot get sensor1_iovdd supply, setting it to NULL!
            [   72.702155] [VIN_WARN]sensor_helper_probe: cannot get sensor1_avdd supply, setting it to NULL!
            [   72.711922] [VIN_WARN]sensor_helper_probe: cannot get sensor1_dvdd supply, setting it to NULL!
            root@TinaLinux:/lib/modules/5.4.61# insmod ov5640.ko
            root@TinaLinux:/lib/modules/5.4.61# insmod vin_v4l2.ko
            [   94.266161] vin_csi 5801000.csi: Adding to iommu group 0
            [   94.275576] sunxi-vin-core 5809000.vinc: Adding to iommu group 0
            [   94.282873] sunxi-vin-core 5809200.vinc: Adding to iommu group 0
            [   94.291191] [VIN_WARN]get csi isp clk fail
            [   94.295852] [VIN_WARN]get csi isp src clk fail
            [   94.300967] [VIN_WARN]get csi mipi clk fail
            [   94.305682] [VIN_WARN]get csi mipi src clk fail
            [   94.310798] [VIN_WARN]get csi isp clk fail
            [   94.315499] [VIN_WARN]Get isp reset control fail
            [   94.321390] 8<--- cut here ---
            [   94.324819] Unable to handle kernel paging request at virtual address e1d220c8
            [   94.332920] pgd = 8fd21213
            [   94.335950] [e1d220c8] *pgd=00000000
            [   94.339961] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
            [   94.345915] Modules linked in: vin_v4l2(+) ov5640 vin_io videobuf2_vmalloc videobuf2_dma_contig videobuf2_memops r8188eu(C) sunxi_gpadc
            [   94.359591] CPU: 0 PID: 228 Comm: insmod Tainted: G         C        5.4.61 #92
            [   94.367786] Hardware name: Generic DT based system
            [   94.373167] PC is at __device_attach_driver+0x14/0x98
            [   94.378833] LR is at bus_for_each_drv+0xa8/0xb8
            [   94.383911] pc : [<c03d4abc>]    lr : [<c03d2b9c>]    psr: 20000013
            [   94.390937] sp : c3c3fb28  ip : 00000000  fp : 00000000
            [   94.396794] r10: c0b36518  r9 : 00000000  r8 : c3c34088
            [   94.402652] r7 : c03d4aa8  r6 : c3c34020  r5 : c3c3fb64  r4 : bf015158
            [   94.409972] r3 : e1d220b0  r2 : 00000000  r1 : c3c3fb64  r0 : bf015158
            [   94.417292] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
            [   94.425295] Control: 10c5387d  Table: 43cfc06a  DAC: 00000051
            [   94.431738] Process insmod (pid: 228, stack limit = 0x52e7d2dc)
            [   94.438375] Stack: (0xc3c3fb28 to 0xc3c40000)
            [   94.443262] fb20:                   c3c3e000 00000000 c3c3fb64 c03d2b9c 00000000 c7491ebc
            [   94.452439] fb40: c41715dc 6b4b7779 c3c34020 c3c34020 c0b36548 c3c3e000 00000001 c03d480c
            [   94.461615] fb60: c3c34020 c3c34020 00000001 6b4b7779 c3c34020 c0b36548 c3c34020 c6df3080
            [   94.470792] fb80: c3c3e000 c03d37a0 c3c34020 00000000 c0b2b278 c03d1348 00000000 c6df3040
            [   94.479968] fba0: c3c34020 c3c34004 c3c4f2ec 6b4b7779 c3c34000 c3c3fc1c 00000000 c6df3040
            [   94.489144] fbc0: c3c34020 c3c34004 c3c4f2ec c04a2adc c6df3040 c3c3fc1c 6b4b7779 c3c4f8a0
            [   94.498321] fbe0: c3c3fc1c c6df3040 00000000 0000003c c3c4f2b8 c04a2b1c c3c4f8a0 c04bfea8
            [   94.507498] fc00: c3c3e000 c3c4f8a0 c6df3040 00000000 0000003c c04bff18 c3c4f8a0 3635766f
            [   94.516673] fc20: 00003034 00000000 00000000 00000000 003c0000 00000000 00000000 00000000
            [   94.525849] fc40: 00000000 00000000 00000000 00000000 00000000 6b4b7779 c3ce8600 0000003c
            [   94.535024] fc60: c3c4f2b8 00000000 c6df3040 c3c4f8a0 00000000 bf089be0 00000000 c3c4f2b8
            [   94.544200] fc80: 0000003c c3c4f040 c3c4f040 c3c4f8a0 c3c4f040 c3c4f0fc 00000000 bf08a4dc
            [   94.553377] fca0: 00000002 00000001 c7563410 c3c4f040 c3c4f5f0 c04f6ff0 ffffffff c3c4f6f0
            [   94.562554] fcc0: 00000000 1406f400 5f697363 6b6c636d 6c705f30 0000006c 00000000 6b4b7779
            [   94.571730] fce0: 00000000 c7563410 00000000 bf0923b0 bf0923b0 c0c68b80 00000017 c0c68b84
            [   94.580907] fd00: c3c3ff28 c03d60f4 c7563410 00000000 00000000 c03d45b4 c7563410 bf0923b0
            [   94.590084] fd20: bf0923b0 c03d4ba4 00000000 00000021 c8e9d8e4 c03d49e0 bf0923b0 c7563410
            [   94.599261] fd40: 6b4b7779 00000000 c7563410 bf0923b0 c03d4ba4 00000000 00000021 c03d4b8c
            [   94.608437] fd60: 00000000 c7563410 bf0923b0 c03d4c50 c7563410 c3c3e000 bf0923b0 c03d2aa8
            [   94.617614] fd80: c8e9d8e4 c74902a8 c7552eb4 6b4b7779 c74902bc bf0923b0 c3c74900 00000000
            [   94.626791] fda0: c0b2ba50 c03d3a24 bf08fd2f bf08fd3a 00000000 bf0923b0 c3c3e000 bf09b000
            [   94.635967] fdc0: 00000028 c03d5428 00000000 c3c3e000 bf09b000 bf09b07c c0b4f000 c0102efc
            [   94.645144] fde0: c7401c00 8040003f 00000000 c3c3e000 00000001 c7b706e0 c7b706e0 c3c3e000
            [   94.654320] fe00: c7401e00 c3cb71c0 0000804c c3c3e000 00000001 c01c2858 00000001 c3cb71c0
            [   94.663497] fe20: bf092440 c01c33f0 bf092440 6b4b7779 bf092440 00000021 c3c75940 00000028
            [   94.672672] fe40: 00000000 c0181a34 bf092440 07081000 bf092440 00000021 bf092488 c01804c8
            [   94.681849] fe60: bf09244c 00007fff bf092440 c017dcf8 00000000 c8e9d3e4 c8e9d8e4 c08023ec
            [   94.691025] fe80: bf0925dc b6e6af90 c8e79000 000003d6 00000001 00000080 c3cbcec0 c8e79000
            [   94.700201] fea0: c3c14c00 00000025 00000000 00000000 00000000 00000000 00000000 00000000
            [   94.709377] fec0: 6e72656b 00006c65 00000000 00000000 00000000 00000000 00000000 00000000
            [   94.718552] fee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 6b4b7779
            [   94.727729] ff00: 00000000 0000490c b6e5091c 00000000 c8e9d90c c3c3e000 b6e6af90 c3c3e000
            [   94.736906] ff20: 00000051 c0180c18 c8e8db91 c8e8f0c0 c8e79000 0002490c c8e9d3e4 c8e9d2a4
            [   94.746082] ff40: c8e9509c 00018000 0001bd70 00008de0 0001e5dd 00000000 00000000 00000000
            [   94.755258] ff60: 00008dd0 0000001f 00000020 00000017 00000000 00000010 00000000 6b4b7779
            [   94.764434] ff80: 00000000 00000000 00000000 00000003 00000080 c0101228 c3c3e000 00000080
            [   94.773610] ffa0: 00000000 c0101000 00000000 00000000 b6e2c010 0002490c b6e6af90 00000011
            [   94.782786] ffc0: 00000000 00000000 00000003 00000080 0002490c 00000000 004c0f14 00000000
            [   94.791963] ffe0: be90fa84 be90fa68 004afe88 b6eb37ac 60000010 b6e2c010 00000000 00000000
            [   94.801151] [<c03d4abc>] (__device_attach_driver) from [<c03d2b9c>] (bus_for_each_drv+0xa8/0xb8)
            [   94.811014] [<c03d2b9c>] (bus_for_each_drv) from [<c03d480c>] (__device_attach+0xc8/0x13c)
            [   94.820290] [<c03d480c>] (__device_attach) from [<c03d37a0>] (bus_probe_device+0x28/0x80)
            [   94.829469] [<c03d37a0>] (bus_probe_device) from [<c03d1348>] (device_add+0x5bc/0x6a4)
            [   94.838356] [<c03d1348>] (device_add) from [<c04a2adc>] (i2c_new_client_device+0x1a4/0x1dc)
            [   94.847729] [<c04a2adc>] (i2c_new_client_device) from [<c04a2b1c>] (i2c_new_device+0x8/0x14)
            [   94.857201] [<c04a2b1c>] (i2c_new_device) from [<c04bfea8>] (v4l2_i2c_new_subdev_board+0xd0/0xd8)
            [   94.867159] [<c04bfea8>] (v4l2_i2c_new_subdev_board) from [<c04bff18>] (v4l2_i2c_new_subdev+0x68/0x84)
            [   94.877691] [<c04bff18>] (v4l2_i2c_new_subdev) from [<bf089be0>] (vin_remove+0x1a8/0x288 [vin_v4l2])
            [   94.888047] [<bf089be0>] (vin_remove [vin_v4l2]) from [<bf08a4dc>] (vin_probe+0x728/0xe2c [vin_v4l2])
            [   94.898447] [<bf08a4dc>] (vin_probe [vin_v4l2]) from [<c03d60f4>] (platform_drv_probe+0x48/0x94)
            [   94.908308] [<c03d60f4>] (platform_drv_probe) from [<c03d45b4>] (really_probe+0x1f8/0x388)
            [   94.917585] [<c03d45b4>] (really_probe) from [<c03d49e0>] (driver_probe_device+0x13c/0x154)
            [   94.926959] [<c03d49e0>] (driver_probe_device) from [<c03d4b8c>] (device_driver_attach+0x44/0x5c)
            [   94.936917] [<c03d4b8c>] (device_driver_attach) from [<c03d4c50>] (__driver_attach+0xac/0xb4)
            [   94.946486] [<c03d4c50>] (__driver_attach) from [<c03d2aa8>] (bus_for_each_dev+0x6c/0xa4)
            [   94.955664] [<c03d2aa8>] (bus_for_each_dev) from [<c03d3a24>] (bus_add_driver+0x150/0x1b0)
            [   94.964940] [<c03d3a24>] (bus_add_driver) from [<c03d5428>] (driver_register+0xb4/0xf8)
            [   94.973975] [<c03d5428>] (driver_register) from [<bf09b07c>] (init_module+0x7c/0x1000 [vin_v4l2])
            [   94.983985] [<bf09b07c>] (init_module [vin_v4l2]) from [<c0102efc>] (do_one_initcall+0x70/0x18c)
            [   94.993849] [<c0102efc>] (do_one_initcall) from [<c0181a34>] (do_init_module+0x54/0x1dc)
            [   95.002932] [<c0181a34>] (do_init_module) from [<c01804c8>] (load_module+0x1834/0x1e44)
            [   95.011915] [<c01804c8>] (load_module) from [<c0180c18>] (sys_init_module+0x140/0x150)
            [   95.020800] [<c0180c18>] (sys_init_module) from [<c0101000>] (ret_fast_syscall+0x0/0x54)
            [   95.029874] Exception stack(0xc3c3ffa8 to 0xc3c3fff0)
            [   95.035540] ffa0:                   00000000 00000000 b6e2c010 0002490c b6e6af90 00000011
            [   95.044716] ffc0: 00000000 00000000 00000003 00000080 0002490c 00000000 004c0f14 00000000
            [   95.053890] ffe0: be90fa84 be90fa68 004afe88 b6eb37ac
            [   95.059558] Code: e1a04000 e5903004 e1a05001 e5916000 (e5933018)
            [   95.066392] ---[ end trace 4ef5ab75bbabd3a8 ]---
            Segmentation fault
            YuzukiTsuru D 2 条回复 最后回复 回复 引用 分享 2
              柚木 鉉 LV 9 @lansecd 最后由 WhycanService 编辑
              @lansecd 段错误位于_device_attach_driver,iic调用,查看配置文件是否配置iic as cci,查看iic是否扫卡,iic配置是否正常,这个报错与vin无关。另外SDK请问使用的是哪一个,mangopi开源的那个版本测试vin驱动不能用,所以我才单独打了一个包,考虑iic驱动也有类似的问题
              L 1 条回复 最后回复 回复 引用 分享 6
                @yuzukitsuru 用的芒果派Tina-Linux_20220818这个固件,我也怀疑就是II2这的问题,如果我不配置IIC AS CCI就不会段错误,这个一配上就会段错误,我再捋一下
                L 1 条回复 最后回复 回复 引用 分享 2
                  linsen LV 7 @lansecd 最后由 编辑
                  @lansecd Tina-Linux-20220815
                  • Referenced by  A awwwwa
                    zhongwenhua LV 3 最后由 编辑
                    你们sdk是这么来的
                    • X
                      xiaxia LV 3 最后由 编辑
                      我的MQ-D1S吃灰1年多了,准备找出来玩玩
                        hu_smhr LV 1 最后由 编辑
                        学习中,看看资料
                          darwin LV 4 @lansecd 最后由 编辑
                          • R
                            rong001 LV 3 最后由 编辑
                            这货支持isp吗?
                              wakerzer1 LV 2 最后由 编辑
                              正在学习摄像头这块内容,前来打卡做个记录
                              • F
                                fxq56457250 LV 2 最后由 编辑
                                感谢分享,刚好使用到
                                • Q
                                  qwss_7410Ljq LV 2 最后由 编辑
                                  有没有在lcd上显示图像的相关配置啊
