    V853移植rk628成功出图,但是图片颜色异常,求个排查思路
    4544
    • X
      xjy_5 LV 6 最后由 xiaowenge 编辑
      驱动里设置
       * Store information about the video data format.
      static struct sensor_format_struct sensor_formats[] = {
      		.desc      = "UYVY 4:2:2",
      		.mbus_code = MEDIA_BUS_FMT_UYVY8_2X8, /*.mbus_code = MEDIA_BUS_FMT_SBGGR10_1X10, */
      		.regs      = 0,
      		.regs_size = 0,
      		.bpp       = 4,
      #define N_FMTS ARRAY_SIZE(sensor_formats)
       * Then there is the issue of window sizes.  Try to capture the info here.
      static struct sensor_win_size sensor_win_sizes[] = {
      		.width      = 1920,
      		.height     = 1080,
      		.hoffset    = 0,
      		.voffset    = 0,
      		.hts        = 2200,
      		.vts        = 1125,
      		.pclk       = 74250000*2,
      		.mipi_bps   = 375 * 1000 * 1000,
      		.fps_fixed  = 60,
      		.regs       = 0,
      		.regs_size  = 0,
      		.set_size   = NULL,
      修改了sunxi_isp.c和vin_tdm.c,增加对MEDIA_BUS_FMT_UYVY8_2X8的支持,设备树里设置 sensor0_isp_used = <0>; sensor0_fmt = <0>;
      static struct tdm_format sunxi_tdm_formats[] = {
      		.code = MEDIA_BUS_FMT_UYVY8_2X8,
      		.input_type = INPUTTPYE_8BIT,
      		.input_bit_width = RAW_8BIT,
      		.raw_fmt = BAYER_RGGB,
      static struct isp_pix_fmt sunxi_isp_formats[] = {
      		.fourcc = V4L2_PIX_FMT_UYVY,
      		.infmt = ISP_BGGR,
      		.input_bit = RAW_8,
      使用camerademo setting 抓图
      root@TinaLinux:/# camerademo setting
      [CAMERA]**********************************************************
      [CAMERA]*                                                        *
      [CAMERA]*              this is camera test.                      *
      [CAMERA]*                                                        *
      [CAMERA] Please input the setting parameters according to the prompts.
      [CAMERA] open /dev/video0!
      [CAMERA] Please enter the data save path:
      /root/pic
      [CAMERA] Please enter the number of captured photos:
      [CAMERA] Please enter the data save type:
      [CAMERA] 0:save BMP and YUV formats
      [CAMERA] 1:save BMP format
      [CAMERA] 2:save YUV format
      [CAMERA]************************[   38.522814] [rk628_mipi]PWR_ON!
      ********************************[   38.530221] [rk628_mipi]sensor_init
      [CAMERA] The path to data sa[   38.536887] rk628_mipi 1-0050: RK628 I2C driver version: 00.00.08
      ving is /root/pic.
      [CAMERA] The[   38.545311] [rk628_mipi]do nothing rk628 init over
       number of captured photos is 1.[   38.553725] [VIN]fmt yuv mask
      [CAMERA] save yuv format
      [   38.559577] [VIN]fmt yuv mask
      [   38.565431] [VIN]fmt yuv mask
      [   38.568777] [VIN]fmt yuv mask
      [   38.572136] [VIN]fmt yuv mask
      [   38.575590] [VIN]fmt yuv mask
      [   38.578934] [VIN]fmt yuv mask
      [   38.582275] [VIN]no fmt yuv mask mask:0x2 vinc->support_raw:0x0
      [   38.589048] [VIN]no fmt yuv mask mask:0x2 vinc->support_raw:0x0
      [   38.595745] [VIN]no fmt yuv mask mask:0x2 vinc->support_raw:0x0
      [   38.602458] [VIN]no fmt yuv mask mask:0x2 vinc->support_raw:0x0
      [   38.609179] [VIN]no fmt yuv mask mask:0x2 vinc->support_raw:0x0
      [   38.615919] [VIN]no fmt yuv mask mask:0x2 vinc->support_raw:0x0
      [   38.622589] [VIN]no fmt yuv mask mask:0x2 vinc->support_raw:0x0
      [   38.629328] [VIN]no fmt yuv mask mask:0x2 vinc->support_raw:0x0
      [   38.636020] [VIN]no fmt yuv mask mask:0x2 vinc->support_raw:0x0
      [   38.642742] [VIN]no fmt yuv mask mask:0x2 vinc->support_raw:0x0
      [   38.649440] [VIN]no fmt yuv mask mask:0x2 vinc->support_raw:0x0
      [   38.656219] [VIN]no fmt yuv mask mask:0x2 vinc->support_raw:0x0
      [   38.662874] [VIN]fmt yuv mask
      [   38.666308] [VIN]fmt yuv mask
      [   38.669643] [VIN]fmt yuv mask
      [   38.672999] [VIN]fmt yuv mask
      [   38.676424] [VIN]fmt yuv mask
      [   38.679768] [VIN]fmt yuv mask
      [   38.683100] [VIN]fmt yuv mask
      [   38.686521] [VIN]fmt yuv mask
      [   38.689881] [VIN]fmt yuv mask
      [   38.693214] [VIN]fmt yuv mask
      [   38.696641] [VIN]fmt yuv mask
      [   38.699984] [VIN]fmt yuv mask
      [CAMERA] The sensor supports the following formats :
      [CAMERA] index 0 : YUV422P
      [CAMERA] index 1 : NV16
      [CAMERA] index 2 : NV61
      [CAMERA] index 3 : YUV420
      [CAMERA] index 4 : YVU420
      [CAMERA] index 5 : NV12
      [CAMERA] index 6 : NV21
      [CAMERA] index 7 : BGGR8
      [CAMERA] index 8 : GBRG8
      [CAMERA] index 9 : GRBG8
      [CAMERA] index 10 : RGGB8
      [CAMERA] index 11 : BGGR10
      [CAMERA] index 12 : GBRG10
      [CAMERA] index 13 : GRBG10
      [CAMERA] index 14 : RGGB10
      [CAMERA] index 15 : BGGR12
      [CAMERA] index 16 : GBRG12
      [CAMERA] index 17 : GRBG12
      [CAMERA] index 18 : RGGB12
      [CAMERA] index 19 : YUYV
      [CAMERA] index 20 : UYVY
      [CAMERA] index 21 : VYUY
      [CAMERA] index 22 : YVYU
      [CAMERA] index 23 : YUYV
      [CAMERA] index 24 : UYVY
      [CAMERA] index 25 : VYUY
      [CAMERA] index 26 : YVYU
      [CAMERA] index 27 : UYVY
      [CAMERA] index 28 : VYUY
      [CAMERA] index 29 : YVYU
      [CAMERA] index 30 : YUYV
      [CAMERA] Please enter the serial number you need for pixelformat:
      [CAMERA] The input value is 0.
      [CAMERA] camera pixelformat: YUV422P
      [CAMERA] The YUV422P supports the following resolutions:
      [CAMERA] Index 0 : 1920 * 1080
      [CAMERA] Please enter the serial number you need for windows size:
      [   45.692968] [VIN]fmt yuv mask
      [CAMERA] Resolution size : 1920 [   45.699066] [rk628_mipi]ioctl cmd:0x0
      * 1080
      [CAMERA] The photo save path is /root/pic.
      [CAMERA] The number of photos taken is 1.
      [CAMERA]usr  cap mplane
      begin io[   45.714464] [cmb_phy_set_deskew_laneck0]-[239]:sel:0, delay:2
      n_alloc_open
      pid: 1118, g_allo[   45.723594] [cmb_phy_set_deskew_laneck0]-[239]:sel:1, delay:7
      c_context = 0xb6efcf70
      [CAMERA[   45.733361] [rk628_mipi]s_stream enable val:1
      ] Camera capture framerate is 60/1
      [CAMERA] VIDIOC_S_FMT succeed
      [CAMERA] fmt.type = 9
      [CAMER[   45.747495] rk628_mipi 1-0050: src 1920x1080 clock:148500000
      A] fmt.fmt.pix_mp.width = 1920
      [   45.755089] rk628_mipi 1-0050: dst 1920x1080 clock:148500000
      [CAMERA] fmt.fmt.pix_mp.height = 1080
      [CAMERA] fmt.fmt.pix_mp.pixelformat = YUV422P
      [CAMERA] fmt.fmt.pix_mp.field = 1
      [   45.901485] rk628_mipi 1-0050: rk628_is_avi_ready PDEC_AVI_PB:0x1084a80c, avi_rcv_rdy:1
      [   45.954623] rk628_mipi 1-0050: rk628_is_avi_ready PDEC_AVI_PB:0x1084a80c, avi_rcv_rdy:1
      [   46.014629] rk628_mipi 1-0050: rk628_is_avi_ready PDEC_AVI_PB:0x1084a80c, avi_rcv_rdy:1
      [   46.074626] rk628_mipi 1-0050: rk628_is_avi_ready PDEC_AVI_PB:0x1084a80c, avi_rcv_rdy:1
      [   46.134614] rk628_mipi 1-0050: rk628_is_avi_ready PDEC_AVI_PB:0x1084a80c, avi_rcv_rdy:1
      [   46.194637] rk628_mipi 1-0050: rk628_is_avi_ready PDEC_AVI_PB:0x1084a80c, avi_rcv_rdy:1
      [CAMERA] stream on succeed
      [CAMERA] camera0 capture num is [0]
      [CAMERA_PROMPT] the time interval from the start to the first frame is 28 ms
      [CAMERA] Capture thread finish[   46.583099] [rk628_mipi]s_stream enable val:0
      [CAMERA] close /dev/video0[   46.594185] [rk628_mipi]PWR_OFF!do nothing
      ion_alloc_close
      pid: 1118, release g_alloc_context = 0xb6efcf70
      root@TinaLinux:/#
      图片格式YUV422,宽高19201080理论上大小是19201080*2=4147200字节,实际上得到的图是4177920字节,多出来啥了?
      用yuvplayer看图,颜色设置YUV422,能看到图片还白加点偏移的颜色的
      X 1 条回复 最后回复 回复 引用 分享 1
      • X
        xjy_5 LV 6 @xjy_5 最后由 编辑
        @xjy_5 成了,用19201088像素格式查看数据就行了,为什么会是19201088啊??
          awwwwa LV 8 最后由 编辑
          @xjy_5 一般2M摄像头都是1920*1088的,可能就按这个来处理了
          X 2 条回复 最后回复 回复 引用 分享 0
          • X
            xjy_5 LV 6 @awwwwa 最后由 编辑
            @awwwwa 现在又开始烦了,我在sample_driverVipp里面用 V4L2_PIX_FMT_YUV422P 抓图,很顺利,不过得到的是1920x1088的图片,然后用sample_virvi抓图,怎么抓出来的图都是红红绿绿蓝蓝的,不过出来的图是1920x1080的了,理论上我应该选MM_PIXEL_FORMAT_UYVY_PACKAGE_422就对了
            • X
              @awwwwa 通过sample_virvi抓到的图比sample_driverVipp小一半,应该是哪没设置好吧
