    T527 使用 DRM 驱动 edp 屏幕
    6392
      awwwwa LV 8 最后由 awwwwa 编辑
      进入 menuconfig 勾选 drm 驱动
      ./build.sh menuconfig
      先勾选 DRM
      再勾选 DRM 驱动
      选择驱动的phy
      选择屏幕
      选择 general 屏幕面板驱动
      关闭原来的 disp2 fbdev 驱动
      配置设备树
      	edp_panel_backlight: edp_backlight {
      		compatible = "pwm-backlight";
      		brightness-levels = <
      			  0   1   2   3   4   5   6   7
      			  8   9  10  11  12  13  14  15
      			 16  17  18  19  20  21  22  23
      			 24  25  26  27  28  29  30  31
      			 32  33  34  35  36  37  38  39
      			 40  41  42  43  44  45  46  47
      			 48  49  50  51  52  53  54  55
      			 56  57  58  59  60  61  62  63
      			 64  65  66  67  68  69  70  71
      			 72  73  74  75  76  77  78  79
      			 80  81  82  83  84  85  86  87
      			 88  89  90  91  92  93  94  95
      			 96  97  98  99 100 101 102 103
      			104 105 106 107 108 109 110 111
      			112 113 114 115 116 117 118 119
      			120 121 122 123 124 125 126 127
      			128 129 130 131 132 133 134 135
      			136 137 138 139 140 141 142 143
      			144 145 146 147 148 149 150 151
      			152 153 154 155 156 157 158 159
      			160 161 162 163 164 165 166 167
      			168 169 170 171 172 173 174 175
      			176 177 178 179 180 181 182 183
      			184 185 186 187 188 189 190 191
      			192 193 194 195 196 197 198 199
      			200 201 202 203 204 205 206 207
      			208 209 210 211 212 213 214 215
      			216 217 218 219 220 221 222 223
      			224 225 226 227 228 229 230 231
      			232 233 234 235 236 237 238 239
      			240 241 242 243 244 245 246 247
      			248 249 250 251 252 253 254 255>;
      		default-brightness-level = <200>;
      		enable-gpios = <&pio PI 5 GPIO_ACTIVE_HIGH>;
      		/* power-supply = <&reg_backlight_12v>; */
      		pwms = <&a_pwm 5 5000000 0>;
      	edp_panel: edp_panel {
      		compatible = "edp-general-panel";
      		power0-supply = <&reg_dcdc4>;
      		backlight = <&edp_panel_backlight>;
      		panel-timing {
      			clock-frequency = <348577920>; /* pixel clock */
      			hactive = <2560>;
      			hback-porch = <120>;
      			hfront-porch = <88>;
      			hsync-len = <32>;
      			vactive = <1600>;
      			vback-porch = <71>;
      			vfront-porch = <28>;
      			vsync-len = <5>;
      			/* hor_sync_polarity */
      			hsync-active = <1>;
      			/* ver_sync_polarity */
      			vsync-active = <1>;
      			// unused now
      			de-active = <1>;
      			pixelclk-active = <1>;
      			syncclk-active = <0>;
      			interlaced;
      			doublescan;
      			doubleclk;
      		ports {
      			#address-cells = <1>;
      			#size-cells = <0>;
      			panel_in: port@0 {
      				#size-cells = <0>;
      				reg = <0>;
      				edp_panel_in: endpoint@0 {
      					reg = <0>;
      					remote-endpoint = <&edp_panel_out>;
      和 drm_edp 的配置
      &drm_edp {
      	edp_ssc_en = <0>;
      	edp_ssc_mode = <0>;
      	edp_psr_support = <0>;
      	edp_colordepth = <8>; /* 6/8/10/12/16 */
      	edp_color_fmt = <0>; /* 0:RGB  1: YUV444  2: YUV422 */
      	lane1_sw = <0>;
      	lane1_pre = <0>;
      	lane2_sw = <0>;
      	lane2_pre = <0>;
      	lane3_sw = <0>;
      	lane3_pre = <0>;
      	efficient_training = <0>;
      	sink_capacity_prefer = <1>;
      	edid_timings_prefer = <1>;
      	timings_fixed = <1>;
      	vcc-edp-supply = <&reg_bldo3>;
      	vdd-edp-supply = <&reg_dcdc2>;
      	panel = <&edp_panel>;
      	ports {
      		edp_out: port@1 {
      			edp_panel_out: endpoint@0 {
      				reg = <0>;
      				remote-endpoint = <&edp_panel_in>;
        jameschen LV 2 最后由 编辑
        @awwwwa 哪里可以找到T527的评估板呢?项目要做但找不到板
          awwwwa LV 8 最后由 编辑
          DSI
          	dsi1_backlight: backlight0 {
          			  0   1   2   3   4   5   6   7
          		enable-gpios = <&pio PH 18 GPIO_ACTIVE_HIGH>;
          		pwms = <&pwm0 0 50000 0>;
          &de {
          	chn_cfg_mode = <3>;
          &vo0 {
          &dlcd1 {
          &dsi1 {
          	pinctrl-0 = <&dsi1_4lane_pins_a>;
          	pinctrl-1 = <&dsi1_4lane_pins_b>;
          	pinctrl-names = "active","sleep";
          	ports {
          		dsi1_out: port@1{
          			reg = <1>;
          			dsi_out_panel: endpoint {
          				remote-endpoint = <&panel_in>;
          	panel: panel@0 {
          		compatible = "panel-dsi";
          		reg = <0>;
          		power0-supply = <&reg_cldo4>;
          		power1-supply = <&reg_cldo1>;
          		reset-gpios = <&pio PD 22 GPIO_ACTIVE_HIGH>; //reset
          		backlight = <&dsi1_backlight>;
          		dsi,flags = <MIPI_DSI_MODE_VIDEO>;
          		dsi,lanes = <4>;
          		dsi,format = <0>;
          		panel-init-sequence = [
          			15 00 02 E0 00
          			15 00 02 E1 93
          			15 00 02 E2 65
          			15 00 02 E3 F8
          			15 00 02 80 03
          			15 00 02 E0 01
          			15 00 02 00 00
          			15 00 02 01 25
          			15 00 02 03 00
          			15 00 02 04 30
          			15 00 02 0C 74
          			15 00 02 17 00
          			15 00 02 18 C7
          			15 00 02 19 01
          			15 00 02 1A 00
          			15 00 02 1B C7
          			15 00 02 1C 01
          			15 00 02 24 FE
          			15 00 02 37 19
          			15 00 02 35 28
          			15 00 02 38 05
          			15 00 02 39 08
          			15 00 02 3A 12
          			15 00 02 3C 7E
          			15 00 02 3D FF
          			15 00 02 3E FF
          			15 00 02 3F 7F
          			15 00 02 40 06
          			15 00 02 41 A0
          			15 00 02 43 1E
          			15 00 02 44 0B
          			15 00 02 55 02
          			15 00 02 57 6A
          			15 00 02 59 0A
          			15 00 02 5A 2E
          			15 00 02 5B 1A
          			15 00 02 5C 15
          			15 00 02 5D 7F
          			15 00 02 5E 61
          			15 00 02 5F 50
          			15 00 02 60 43
          			15 00 02 61 3F
          			15 00 02 62 32
          			15 00 02 63 35
          			15 00 02 64 1F
          			15 00 02 65 38
          			15 00 02 66 36
          			15 00 02 67 36
          			15 00 02 68 54
          			15 00 02 69 42
          			15 00 02 6A 48
          			15 00 02 6B 39
          			15 00 02 6C 34
          			15 00 02 6D 26
          			15 00 02 6E 14
          			15 00 02 6F 02
          			15 00 02 70 7F
          			15 00 02 71 61
          			15 00 02 72 50
          			15 00 02 73 43
          			15 00 02 74 3F
          			15 00 02 75 32
          			15 00 02 76 35
          			15 00 02 77 1F
          			15 00 02 78 38
          			15 00 02 79 36
          			15 00 02 7A 36
          			15 00 02 7B 54
          			15 00 02 7C 42
          			15 00 02 7D 48
          			15 00 02 7E 39
          			15 00 02 7F 34
          			15 00 02 80 26
          			15 00 02 81 14
          			15 00 02 82 02
          			15 00 02 E0 02
          			15 00 02 00 52
          			15 00 02 01 5F
          			15 00 02 02 5F
          			15 00 02 03 50
          			15 00 02 04 77
          			15 00 02 05 57
          			15 00 02 06 5F
          			15 00 02 07 4E
          			15 00 02 08 4C
          			15 00 02 09 5F
          			15 00 02 0A 4A
          			15 00 02 0B 48
          			15 00 02 0C 5F
          			15 00 02 0D 46
          			15 00 02 0E 44
          			15 00 02 0F 40
          			15 00 02 10 5F
          			15 00 02 11 5F
          			15 00 02 12 5F
          			15 00 02 13 5F
          			15 00 02 14 5F
          			15 00 02 15 5F
          			15 00 02 16 53
          			15 00 02 17 5F
          			15 00 02 18 5F
          			15 00 02 19 51
          			15 00 02 1A 77
          			15 00 02 1B 57
          			15 00 02 1C 5F
          			15 00 02 1D 4F
          			15 00 02 1E 4D
          			15 00 02 1F 5F
          			15 00 02 20 4B
          			15 00 02 21 49
          			15 00 02 22 5F
          			15 00 02 23 47
          			15 00 02 24 45
          			15 00 02 25 41
          			15 00 02 26 5F
          			15 00 02 27 5F
          			15 00 02 28 5F
          			15 00 02 29 5F
          			15 00 02 2A 5F
          			15 00 02 2B 5F
          			15 00 02 2C 13
          			15 00 02 2D 1F
          			15 00 02 2E 1F
          			15 00 02 2F 01
          			15 00 02 30 17
          			15 00 02 31 17
          			15 00 02 32 1F
          			15 00 02 33 0D
          			15 00 02 34 0F
          			15 00 02 35 1F
          			15 00 02 36 05
          			15 00 02 37 07
          			15 00 02 38 1F
          			15 00 02 39 09
          			15 00 02 3A 0B
          			15 00 02 3B 11
          			15 00 02 3C 1F
          			15 00 02 3D 1F
          			15 00 02 3E 1F
          			15 00 02 3F 1F
          			15 00 02 40 1F
          			15 00 02 41 1F
          			15 00 02 42 12
          			15 00 02 43 1F
          			15 00 02 44 1F
          			15 00 02 45 00
          			15 00 02 46 17
          			15 00 02 47 17
          			15 00 02 48 1F
          			15 00 02 49 0C
          			15 00 02 4A 0E
          			15 00 02 4B 1F
          			15 00 02 4C 04
          			15 00 02 4D 06
          			15 00 02 4E 1F
          			15 00 02 4F 08
          			15 00 02 50 0A
          			15 00 02 51 10
          			15 00 02 52 1F
          			15 00 02 53 1F
          			15 00 02 54 1F
          			15 00 02 55 1F
          			15 00 02 56 1F
          			15 00 02 57 1F
          			15 00 02 58 40
          			15 00 02 5B 10
          			15 00 02 5C 06
          			15 00 02 5D 40
          			15 00 02 5E 00
          			15 00 02 5F 00
          			15 00 02 60 40
          			15 00 02 61 03
          			15 00 02 62 04
          			15 00 02 63 6C
          			15 00 02 64 6C
          			15 00 02 65 75
          			15 00 02 66 08
          			15 00 02 67 B4
          			15 00 02 68 08
          			15 00 02 69 6C
          			15 00 02 6A 6C
          			15 00 02 6B 0C
          			15 00 02 6D 00
          			15 00 02 6E 00
          			15 00 02 6F 88
          			15 00 02 75 BB
          			15 00 02 76 00
          			15 00 02 77 05
          			15 00 02 78 2A
          			15 00 02 E0 04
          			15 00 02 37 58
          			15 00 02 00 0E
          			15 00 02 02 B3
          			15 00 02 09 61
          			15 00 02 0E 48
          			15 00 02 E0 00
          			05 32 01 11
          			05 05 01 29
          			15 32 02 35 00
          		panel-exit-sequence = [
          			05 14 01 28
          			05 50 01 10
          		display-timings {
          			native-mode = <&dsi1_timing0>;
          			dsi1_timing0: timing0 {
          				clock-frequency = <68215200>;
          				hback-porch = <20>;
          				hactive = <800>;
          				hfront-porch = <20>;
          				hsync-len = <20>;
          				vback-porch = <8>;
          				vactive = <1280>;
          				vfront-porch = <30>;
          				vsync-len = <4>;
          		port {
          			panel_in: endpoint {
                                          remote-endpoint = <&dsi_out_panel>;
          &dsi0combophy {
          	status = "disabled";
          &dsi1combophy {
          • Moved from 其它全志芯片讨论区 by  Kirin Kirin
          • T
            TEVET LV 7 最后由 编辑
            请问大佬, EDP 的OLED 怎么调整亮度?
            T 1 条回复 最后回复 回复 引用 分享 1
            • T
              TEVET LV 7 @TEVET 最后由 编辑
              @tevet
              已解决,
              https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1198540/sn65dsi86-how-does-linux-read-write-hdcp?keyMatch=edp oled&tisearch=universal_search
