    R128 打包失败 merge_full_rtos_img_failed
    9
    8459
      cai_yp LV 3 最后由 编辑
      请教各位大佬,R128S2 SDK 打包失败的问题
      从tb客服那里获取的SDK
      删除out和build文件夹后正常编译,但是打包失败了。
      系统openSUSE Tumbleweed
      A 1 条回复 最后回复 回复 引用 分享 1
        awwwwa LV 8 @cai_yp 最后由 awwwwa 编辑
        @cai_yp 分区参数错误,只打包了UDISK分区,但是UDISK是自动生成的分区
        32356+0 records in
        32356+0 records out
        8283136 bytes (8.3 MB) copied, 0.0394041 s, 210 MB/s
        this is not a partition key
        update mbr file ok
        ----------------mbr convert to gpt start---------------------
        out: sunxi_gpt_nor.fex
        source: sunxi_mbr_nor.fex
        input_logic_offset: 256
        input_flash_size: 16M
        gpt partition entry crc32 = 0x618ebc8
        gpt header crc32 = 0x4fdf09e2
        GPT----part num 10---
        gpt_entry: 128
        gpt_header: 92
        GPT:env         : 120           127
        GPT:env-redund  : 128           12f
        GPT:arm-lpsram  : 130           a8f
        GPT:rv-lpsram   : a90           1a2f
        GPT:dsp-hpsram  : 1a30          206f
        GPT:rtos-xip    : 2070          33f7
        GPT:arm-b       : 33f8          3d57
        GPT:config      : 3d58          3d77
        GPT:settings    : 3d78          3db7
        GPT:UDISK       : 3db8          7fff
        update gpt file ok
        ----------------mbr convert to gpt end---------------------
        boot0: boot0_spinor.fex
        redund boot0: boot0_spinor.fex
        mbr: sunxi_gpt_nor.fex
        partition: sys_partition_nor.bin
        UDISK_partition_size: 16968 sector
        outfile: rtos_16Mnor.bin
        logic_start: 128K
        total_image_size: 16M
        load file: boot0_spinor.fex ok
        load file: sunxi_gpt_nor.fex ok
        support redund boot0 at 0x10000
        load file: sys_partition_nor.bin ok
        part name=env
        file name:env.fex
        part size:8 sector
        load file: env.fex ok
        part name=env-redund
        file name:env.fex
        part size:8 sector
        part name=arm-lpsram
        file name:rtos_arm.fex
        part size:2400 sector
        load file: rtos_arm.fex ok
        part name=rv-lpsram
        file name:rtos_riscv.fex
        part size:4000 sector
        load file: rtos_riscv.fex ok
        part name=dsp-hpsram
        file name:rtos_dsp.fex
        part size:1600 sector
        load file: rtos_dsp.fex ok
        part name=rtos-xip
        file name:rtos_xip_rv.fex
        part size:5000 sector
        load file: rtos_xip_rv.fex ok
        part name=arm-b
        file name:etf.fex
        load file: etf.fex ok
        part name=config
        file name:config.fex
        part size:32 sector
        load file: config.fex ok
        part name=settings
        part size:64 sector
        part name=UDISK
        file name:data_udisk.fex
        load file: data_udisk.fex ok
        partname: UDISK
        merge_package ok
        C 1 条回复 最后回复 回复 引用 分享 2
          cai_yp LV 3 @awwwwa 最后由 编辑
          @awwwwa
          想问一下分区参数需要修改哪里呢?
          在/board/r128s2/pro/configs/里面找到了sys_partition_nor.fex和sys_partition_xip.fex两个文件
          sys_partition_nor.fex里面的内容是这样的:
          ;    mbr的大小, 以Kbyte为单位
          [mbr]
          size = 16
          ;  partition 定义范例:
          ; 注:1、name唯一, 不允许同名
          ;     2、name最大12个字符
          ;     4、为了安全和效率考虑,分区大小最好保证为16M字节的整数倍
          [partition_start]
          [partition]
              name         = env
              size         = 8
              downloadfile = "env.fex"
              user_type    = 0x8000
          [partition]
              name         = env-redund
              size         = 8
              user_type    = 0x8000
          [partition]
              name         = arm-lpsram
              size         = 2400
              downloadfile = "rtos_arm.fex"
              user_type    = 0x8000
          [partition]
              name         = rv-lpsram
              size         = 7000
              downloadfile = "rtos_riscv.fex"
              user_type    = 0x8000
          [partition]
              name         = dsp-hpsram
              size         = 1600
              downloadfile = "rtos_dsp.fex"
              user_type    = 0x8000
          [partition]
              name         = arm-b
              size         = 2400
              downloadfile = "etf.fex"
              user_type    = 0x8000
          [partition]
              name         = config
              size         = 32
              downloadfile = "config.fex"
              user_type    = 0x8000
          [partition]
              name         = UDISK
              downloadfile = "data_udisk.fex"
              user_type    = 0x8100
          sys_partition_xip.fex里面的内容是这样的:
          ;    mbr的大小, 以Kbyte为单位
          [mbr]
          size = 16
          ;  partition 定义范例:
          ; 注:1、name唯一, 不允许同名
          ;     2、name最大12个字符
          [partition_start]
          [partition]
              name         = env
              size         = 8
              user_type    = 0x8000
          [partition]
              name         = env-redund
              size         = 8
              user_type    = 0x8000
          [partition]
              name         = arm-lpsram
              size         = 2400
              user_type    = 0x8000
          [partition]
              name         = rv-lpsram
              size         = 4000
              user_type    = 0x8000
          	verify       = 0
          [partition]
              name         = dsp-hpsram
              size         = 1600
              user_type    = 0x8000
          [partition]
              name         = rtos-xip
              size         = 5000
              downloadfile = "rtos_xip_rv.fex"
              user_type    = 0x8000
          [partition]
              name         = arm-b
              size         = 2400
              user_type    = 0x8000
          [partition]
              name         = config
              size         = 32
              user_type    = 0x8000
          [partition]
              name         = UDISK
              user_type    = 0x8100
          DAIZEBIN 1 条回复 最后回复 回复 引用 分享 1
          • DAIZEBIN
            DAIZEBIN LV 7 @cai_yp 最后由 编辑
            @cai_yp
            1、完整打包log发下看看,刚试了一下挖坑网的SDK,还没遇到这个问题,看下是不是前面clean的时候把一些配置给干掉了
            2、另外,S2上面应该开启了XIP,关注 sys_partition_xip.fex 既可,
            这里补充下挖坑网的SDK中存在的编译问题解决方法:(https://whycan.com/t_10304.html)
            1、source envsetup.sh,选择C906方案,执行 mrtos distclean 指令既可
            2、M33重复以上步骤既可
            3、重新编译两个方案,打包既可
              cai_yp LV 3 @DAIZEBIN 最后由 编辑
              @daizebin
              打包的日志如下:
              suse@localhost:~/WorkSpace/R128-S2-WROOM-R16N16> p
              -DARM_TFM=0 -DARM_XIP=0 -DRV_XIP=1 -DARM_PSRAM=0 -DARM_PSRAM_LOAD_ADDR= -DARM_RECOVERY=0 -DARM_BOOT_RV=1 -DARM_BOOT_DSP=1 -DARM_LOAD_ADDR=0x08004000 -DRV_LOAD_ADDR=0x08200000 -DDSP_RUN_ADDR=0x0c000660 -DDSP_LOAD_ADDR=0x0c000000
              copying tools file
              copying configs file
              storage_type value is 3
              storage type is nor
              image_nor.cfg is exist
              mv image_nor.cfg image.cfg
              env_nor.cfg is exist
              mv env_nor.cfg env.cfg
              Compressed 875336 bytes into 585034 bytes ==> 66.84%
              CONFIG_XIP=y, use sys_partition_xip.fex
              '/home/suse/WorkSpace/R128-S2-WROOM-R16N16/out/r128s2/pro/image/sys_partition_xip.fex' -> '/home/suse/WorkSpace/R128-S2-WROOM-R16N16/out/r128s2/pro/image/sys_partition_nor.fex'
              /home/suse/WorkSpace/R128-S2-WROOM-R16N16/tools/scripts/pack_img.sh: 行 743: busybox: 未找到命令
              /home/suse/WorkSpace/R128-S2-WROOM-R16N16/tools/scripts/pack_img.sh: 行 752: busybox: 未找到命令
              /home/suse/WorkSpace/R128-S2-WROOM-R16N16/tools/scripts/pack_img.sh: 行 768: busybox: 未找到命令
              pack boot nor package
              /home/suse/WorkSpace/R128-S2-WROOM-R16N16/tools/scripts/pack_img.sh: 行 780: busybox: 未找到命令
              content_count=1
              boot0 file Path=/home/suse/WorkSpace/R128-S2-WROOM-R16N16/out/r128s2/pro/image/boot0_sdcard.fex
              script file Path=/home/suse/WorkSpace/R128-S2-WROOM-R16N16/out/r128s2/pro/image/sys_config.bin
              skip_length = 0
              update_for_boot0 703
              update_for_boot0 705
              update_for_boot0 707
              update_for_boot0 710
              boot0->head.length:49152
              update_for_boot0 714
              update_for_boot0 720
              update_for_boot0 725
              update_for_boot0 732
              debug_mode
              update_for_boot0 743
              update_for_boot0 749
              update_for_boot0 757
              update_for_boot0 761
              extd_head.select_mode:0
              magic:
              update_for_boot0 788
              update_for_boot0 794
              update_for_boot0 800
              update_for_boot0 810
              card_str :card0_boot_para
              card_str :card1_boot_para
              card_str :card2_boot_para
              card_str :card3_boot_para
              unable to find card{x}_boot_para
              pack boot package
              /home/suse/WorkSpace/R128-S2-WROOM-R16N16/tools/scripts/pack_img.sh: 行 801: busybox: 未找到命令
              content_count=1
              toc1 file Path=/home/suse/WorkSpace/R128-S2-WROOM-R16N16/out/r128s2/pro/image/boot_package.fex
              cant get board_id_enable
              script update toc1 ok
              packing for rtos
              normal
              cfg string:
              /* -- Autogenerated! Do not edit!!! */
               * mkimage configuration:
               *      magic: image header magic, AWIH
               *      hversion: image header version
               *      pversion: payload version
               *      key_type: crypto type of packing and verity
               *      image: image size configuration
               *              - max_size: firmware max size
               *              - bin_num: max binary number in firmware
               *      section: binary list
               *              - id: binary file id
               *              - bin: binary file name
               *              - flash_offs: the offset of the binary in flash. if not set, it will put the binary at the end of previous binary (1024B align).
               *              - sram_offs: the sram offset which the binary will be loaded to.
               *              - ep: entry point
               *              - attr: attribute
               *                      - bit[1:0]: file type, 00 - normal, 01 - executable, 10 - XIP, 11 - reserved.
               *                      - bit[3:2]: encrypt type, 00 - none, X1 - signature, 1X - flash encryptiion
               *                      - bit[4]: compress flag, 0 - none, 1 - compressed
               *                      - bit[5]: secure flag, 0 - none, 1 - secure
               *                      - bit[6]: storage data flag, 0 - none, 1 - has storage data at the end
               *                      - bit[7]: reserved
               *                      - bit[8]: gz flag, 0 - none, 1 - gzip
               *                      - bit[31:9]: reserved
                  "magic" : "AWIH",
                  "hversion" : "0.5",
                  "pversion" : "0",
                  "key_type" : "rsa",
                  "image" : {"max_size": "16384K"},
                  "section" :
                      {"id": "0xa5ff5a00", "bin": "boot0_spinor.fex", "attr": "0x01", "sram_offs": "0x40b0000", "ep": "0x40b0080", "sign_key" : ""},
                      {"id": "0xa5fd5a02", "bin": "boot0_sdcard.fex", "attr": "0x01", "sram_offs": "0x40b0000", "ep": "0x40b0080", "sign_key" : ""},
                      {"id": "0xa5df5a20", "bin": "rtos_arm.fex", "attr": "0x01", "sram_offs": "0x08004000", "ep": "0x08004000", "sign_key" : ""},
                      {"id": "0xa5cf5a30", "bin": "rtos_riscv.fex", "attr": "0x01", "sram_offs": "0x08200000", "ep": "0x08200000", "sign_key": ""},
                      {"id": "0xa5bf5a40", "bin": "rtos_dsp.fex", "attr": "0x01", "sram_offs": "0x0c000000", "ep": "0x0c000660", "sign_key": ""},
                      {"id": "0xa5ce5a31", "bin": "rtos_xip_rv.fex", "attr": "0x02", "sram_offs": "0x08200000", "ep": "", "sign_key" : ""},
                      {"id": "0xa59f5a60", "bin": "etf.fex", "attr": "0x01", "sram_offs": "0x08004000", "ep": "0x08004000", "sign_key" : ""},
                  "asyn_keys" :
                      {"key": "RootKey"},
                      {"key": "TFKey"},
                      {"key": "SoCFKey"},
                      {"key": "NonTFKey"},
                      {"key": "DebugKey"}
              Flash Layout:
              sec bin 0 boot0_spinor.fex  :   flash_offs: 0x00000000(   0K)   data_size: 0x0000C080(  49K)
              sec bin 1 boot0_sdcard.fex  :   flash_offs: 0x0000C400(  49K)   data_size: 0x0000C080(  49K)
              sec bin 2 rtos_arm.fex      :   flash_offs: 0x00018800(  98K)   data_size: 0x00121E48(1160K)
              sec bin 3 rtos_riscv.fex    :   flash_offs: 0x0013A800(1258K)   data_size: 0x000D5BC8( 855K)
              sec bin 4 rtos_dsp.fex      :   flash_offs: 0x00210400(2113K)   data_size: 0x0007A168( 489K)
              sec bin 5 rtos_xip_rv.fex   :   flash_offs: 0x0028A800(2602K)   data_size: 0x0023C250(2289K)
              sec bin 6 etf.fex           :   flash_offs: 0x004C6C00(4891K)   data_size: 0x000E8338( 929K)
              generate image: xr_system.img
              已重命名 'boot0_spinor.fex' -> 'boot0_spinor.fex.nopack'
              'boot0_spinor.fex.pack' -> 'boot0_spinor.fex'
              已重命名 'boot0_sdcard.fex' -> 'boot0_sdcard.fex.nopack'
              'boot0_sdcard.fex.pack' -> 'boot0_sdcard.fex'
              已重命名 'rtos_arm.fex' -> 'rtos_arm.fex.nopack'
              'rtos_arm.fex.pack' -> 'rtos_arm.fex'
              已重命名 'etf.fex' -> 'etf.fex.nopack'
              'etf.fex.pack' -> 'etf.fex'
              已重命名 'rtos_riscv.fex' -> 'rtos_riscv.fex.nopack'
              'rtos_riscv.fex.pack' -> 'rtos_riscv.fex'
              已重命名 'rtos_xip_rv.fex' -> 'rtos_xip_rv.fex.nopack'
              'rtos_xip_rv.fex.pack' -> 'rtos_xip_rv.fex'
              已重命名 'rtos_dsp.fex' -> 'rtos_dsp.fex.nopack'
              'rtos_dsp.fex.pack' -> 'rtos_dsp.fex'
              输入了 32+0 块记录
              输出了 32+0 块记录
              32768 字节 (33 kB, 32 KiB) 已复制,0.000106348 s,308 MB/s
              输入了 32+0 块记录
              输出了 32+0 块记录
              32768 字节 (33 kB, 32 KiB) 已复制,0.000158159 s,207 MB/s
              ====for card product====
              /home/suse/WorkSpace/R128-S2-WROOM-R16N16/tools/scripts/pack_img.sh: 行 1201: busybox: 未找到命令
              content_count=1
              making data image for 16M nor
              data_udisk.fex
              try to create image: UDISK to data_udisk.fex with size 8650752
              The filesystem path: /home/suse/WorkSpace/R128-S2-WROOM-R16N16/board/r128s2/pro/data/UDISK
              --- creating littlefs image ---
              /xr_wifi.conf
              /sys_sdd_40M.bin
              /init.sh
              /etf_r128.bin
              /wlan_fw.bin
              /demo
              /boot.mp3
              /wlan_bl.bin
              --- create littlefs image end ---
              cut zero to reduce fs size
              cut /home/suse/WorkSpace/R128-S2-WROOM-R16N16/out/r128s2/pro/image/data_udisk.fex.cut from 8650752 to 8280576
              输入了 32346+0 块记录
              输出了 32346+0 块记录
              8280576 字节 (8.3 MB, 7.9 MiB) 已复制,0.0432897 s,191 MB/s
              update mbr file ok
              gpt partition entry crc32 = 0x802bb966
              gpt header crc32 = 0xc717a21
              GPT----part num 1---
              gpt_entry: 128
              gpt_header: 92
              GPT:UDISK       : 120           7fff
              update gpt file ok
              UDISK_partition_size: 17032 sector
              logic_start: 128K
              part name=UDISK
              partname: UDISK
              merge_package fail
              ERROR: merge_full_rtos_img failed
              • DAIZEBIN
                @cai_yp 执行busybox看下:
                C 2 条回复 最后回复 回复 引用 分享 0
                  @daizebin
                  suse@localhost:~/WorkSpace/R128-S2-WROOM-R16N16> busybox
                  BusyBox v1.36.1 () multi-call binary.
                  BusyBox is copyrighted by many authors between 1998-2015.
                  Licensed under GPLv2. See source distribution for detailed
                  copyright notices.
                  Usage: busybox [function [arguments]...]
                    or: busybox --list
                    or: function [arguments]...
                         BusyBox is a multi-call binary that combines many common Unix
                         utilities into a single executable.  Most people will create a
                         link to busybox for each function they wish to use and BusyBox
                         will act like whatever it was invoked as.
                  Currently defined functions:
                         [, [[, addgroup, adduser, ar, arch, arp, arping, ascii, ash, awk, base32, base64, basename, bc, beep, blkid, brctl, bunzip2, bzcat, bzip2, cal, cat, chattr, chcon, chgrp, chmod, chown, chpasswd, chroot, chvt, cksum, clear, cmp, comm, cp, cpio, cryptpw, cut,
                         date, dd, deallocvt, delgroup, deluser, depmod, df, diff, dirname, dmesg, dnsdomainname, dos2unix, du, echo, ed, egrep, env, envdir, ether-wake, expand, expr, factor, fallocate, false, fatattr, fdisk, fgrep, find, findfs, flock, fold, free, fsck, fsync, fuser,
                         getenforce, getopt, getsebool, grep, groups, gunzip, gzip, head, hexdump, hexedit, hostid, hostname, hush, id, ifconfig, ifdown, ifenslave, ifup, insmod, install, iostat, ip, ipaddr, ipcrm, ipcs, iplink, ipneigh, iproute, iprule, iptunnel, kill, killall,
                         killall5, last, less, link, linux32, linux64, ln, load_policy, loadfont, loadkmap, logger, login, logname, losetup, ls, lsattr, lsmod, lsof, lspci, lsscsi, lsusb, lzcat, lzma, lzop, man, matchpathcon, md5sum, mdev, mesg, mkdir, mkdosfs, mke2fs, mkfifo,
                         mkfs.ext2, mkfs.vfat, mknod, mkpasswd, mkswap, mktemp, modinfo, modprobe, more, mount, mountpoint, mpstat, mv, nameif, nbd-client, nc, netstat, nice, nl, nmeter, nohup, nologin, nproc, nsenter, nslookup, od, openvt, passwd, paste, patch, pgrep, pidof, ping,
                         ping6, pkill, pmap, printenv, printf, ps, pscan, pstree, pwd, pwdx, readlink, realpath, renice, reset, resize, restorecon, rev, rm, rmdir, rmmod, route, runcon, script, scriptreplay, sed, seedrng, selinuxenabled, sendmail, seq, sestatus, setarch, setconsole,
                         setenforce, setfattr, setfiles, setfont, setkeycodes, setlogcons, setpriv, setsebool, setsid, sh, sha1sum, sha256sum, sha3sum, sha512sum, showkey, shred, shuf, slattach, sleep, smemcap, sort, split, ssl_client, stat, strings, stty, su, sulogin, sum,
                         switch_root, sync, sysctl, syslogd, tac, tail, tar, tc, tee, telnet, test, tftp, time, timeout, top, touch, tr, traceroute, traceroute6, tree, true, truncate, tsort, tty, ttysize, tunctl, udhcpc, uevent, umount, uname, uncompress, unexpand, uniq, unix2dos,
                         unlink, unlzma, unshare, unxz, unzip, uptime, users, usleep, uudecode, uuencode, vconfig, vi, vlock, w, wall, watch, wc, wget, which, who, whoami, whois, xargs, xxd, xz, xzcat, yes, zcat, zcip
                    @daizebin
                    之前解压文件选择了“解压到当前文件夹,自动创建子文件夹”
                    今天解压文件的时候换了一种解压方式,“解压到当前文件夹”,运行lunch_rtos, 打包通过了。
                    suse@localhost:~/workspace/R128-S2-WROOM-R16N16> p
                    copying tools file
                    storage type is nor
                    Compressed 875336 bytes into 584965 bytes ==> 66.83%
                    '/home/suse/workspace/R128-S2-WROOM-R16N16/out/r128s2/pro/image/sys_partition_xip.fex' -> '/home/suse/workspace/R128-S2-WROOM-R16N16/out/r128s2/pro/image/sys_partition_nor.fex'
                    content_count=1
                    boot0 file Path=/home/suse/workspace/R128-S2-WROOM-R16N16/out/r128s2/pro/image/boot0_sdcard.fex
                    script file Path=/home/suse/workspace/R128-S2-WROOM-R16N16/out/r128s2/pro/image/sys_config.bin
                    skip_length = 0
                    debug_mode
                    magic:
                    pack boot package
                    content_count=1
                    toc1 file Path=/home/suse/workspace/R128-S2-WROOM-R16N16/out/r128s2/pro/image/boot_package.fex
                    packing for rtos
                    normal
                    cfg string:
                     *              - ep: entry point
                     *              - attr: attribute
                        "magic" : "AWIH",
                        "hversion" : "0.5",
                        "pversion" : "0",
                        "key_type" : "rsa",
                        "section" :
                        "asyn_keys" :
                            {"key": "RootKey"},
                            {"key": "TFKey"},
                            {"key": "SoCFKey"},
                            {"key": "DebugKey"}
                    Flash Layout:
                    sec bin 5 rtos_xip_rv.fex   :   flash_offs: 0x0028A800(2602K)   data_size: 0x0023C220(2289K)
                    输入了 32+0 块记录
                    输出了 32+0 块记录
                    32768 字节 (33 kB, 32 KiB) 已复制,0.00011565 s,283 MB/s
                    输入了 32+0 块记录
                    输出了 32+0 块记录
                    32768 字节 (33 kB, 32 KiB) 已复制,0.000108326 s,302 MB/s
                    content_count=1
                    data_udisk.fex
                    The filesystem path: /home/suse/workspace/R128-S2-WROOM-R16N16/board/r128s2/pro/data/UDISK
                    /xr_wifi.conf
                    /sys_sdd_40M.bin
                    /init.sh
                    /etf_r128.bin
                    /wlan_fw.bin
                    /demo
                    /boot.mp3
                    /wlan_bl.bin
                    cut /home/suse/workspace/R128-S2-WROOM-R16N16/out/r128s2/pro/image/data_udisk.fex.cut from 8650752 to 8280576
                    输入了 32346+0 块记录
                    输出了 32346+0 块记录
                    8280576 字节 (8.3 MB, 7.9 MiB) 已复制,0.0446896 s,185 MB/s
                    update mbr file ok
                    gpt partition entry crc32 = 0xdd670c0b
                    gpt header crc32 = 0x49b232ba
                    GPT----part num 9---
                    gpt_entry: 128
                    gpt_header: 92
                    GPT:env         : 120           127
                    GPT:UDISK       : 3d78          7fff
                    update gpt file ok
                    logic_start: 128K
                    part name=env
                    file name:env.fex
                    part size:8 sector
                    file name:env.fex
                    part size:8 sector
                    part name=rv-lpsram
                    part name=rtos-xip
                    part name=arm-b
                    file name:etf.fex
                    part name=config
                    part size:32 sector
                    part name=UDISK
                    partname: UDISK
                    merge_package ok
                    /home/suse/workspace/R128-S2-WROOM-R16N16/out/r128s2/pro/image/rtos_16Mnor.bin
                    cut rtos_16Mnor.bin from 16777216 to 16337168
                      [mbr]
                      mbr_size  : 16 Kbyte
                      partition_name  : env
                      partition_size  : 8
                      downloadfile  : env.fex
                      env.fex size : 4.0K byte
                      partition_name  : env-redund
                      partition_size  : 8
                      partition_name  : arm-lpsram
                      partition_size  : 2400
                      downloadfile  : rtos_arm.fex
                      rtos_arm.fex size : 1.2M byte
                      partition_name  : rv-lpsram
                      partition_size  : 4000
                      downloadfile  : rtos_riscv.fex
                      rtos_riscv.fex size : 855K byte
                      verify  : 0
                      partition_name  : dsp-hpsram
                      partition_size  : 1600
                      downloadfile  : rtos_dsp.fex
                      rtos_dsp.fex size : 489K byte
                      partition_name  : rtos-xip
                      partition_size  : 5000
                      downloadfile  : rtos_xip_rv.fex
                      rtos_xip_rv.fex size : 2.3M byte
                      partition_name  : arm-b
                      downloadfile  : etf.fex
                      etf.fex size : 929K byte
                      partition_name  : config
                      partition_size  : 32
                      downloadfile  : config.fex
                      config.fex size : 15K byte
                      partition_name  : UDISK
                      downloadfile  : data_udisk.fex
                      data_udisk.fex size : 7.9M byte
                    dragon: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
                    -----------rtos_freertos_r128s2_pro_uart0_16Mnor.img----------------
                    pack finish
                    J 1 条回复 最后回复 回复 引用 分享 0
                      jiamh LV 1 @cai_yp 最后由 编辑
                      我也遇到了这种情况,是没有安装busybox的原因,安装完就好了。
                      • Moved from A Series by  xiaowenge xiaowenge
