    t113-s3因为硬件原因导致内核无法启动
    5
    11
    11276
      cjia3254 LV 5 最后由 cjia3254 编辑
      现尝试自编译的tina,在boot0和uboot阶段都有输出,内核没有。
      采用awboot的方式引导主线内核的方式,在boot阶段也有输出,内核没有。
      尝试使用芒果派的mq-r-t113-rtl8189fs-5113-dns-uart0.img,在boot0和uboot阶段也都有输出。
      所以我判断是因为硬件问题导致内核无法启动。
      VCC-PLL=1.8v
      RESET=3.3v
      LDOA-OUT=1.8v
      LDOB-OUT boot0未启动时1.35v,启动时1.5v
      vcc-pe=1.8v
      VDD_SYS0=0.9v
      VCC-DRAM0=1.5v
      VDD18-DRAM=1.8v
      VDD-SYS1=0.9v
      LVDS18=1.8v
      VCC-PD=3.3v
      VCC-TVOUT=3.3v
      VDD-SYS2=0.9v
      VCC-IO=3.3v
      AVCC=1.8v
      HPVCC=1.8v
      VCC-TVIN=1.8v
      VDD-CORE1=0.9v
      VCC-PG=3.3v
      望大佬解惑
        awwwwa LV 8 最后由 编辑
        正常的,内核没有输出检查一下设备树配置
          cjia3254 LV 5 @awwwwa 最后由 编辑
          @awwwwa 说来奇怪,我最近画的一块d1s也是这样的情况,boot0和uboot都能启动,就到内核没输出了
          U-Boot 2018.07-ge987def5-dirty (Mar 28 2024 - 20:41:35 +0800) Allwinner Technology
          [00.277]DRAM:  64 MiB
          [00.279]Relocation Offset is: 01ee9000
          [00.283]secure enable bit: 0
          can't support chip type 24064
          [00.289]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
          sunxi flash map init
          SPI ALL:   ready
          [00.300]flash init start
          [00.302]workmode = 0,storage type = 1
          card_no = 0
          [00.307][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
          nodeoffset=10900
          [00.314][mmc]: get sdc_type fail and use default host:tm1.
          [00.321][mmc]: can't find node "mmc0",will add new node
          [00.326][mmc]: fdt err returned <no error>
          [00.329][mmc]: Using default timing para
          [00.333][mmc]: SUNXI SDMMC Controller Version:0x50310
          if
          [00.353][mmc]: card_caps:0x3000000a
          [00.356][mmc]: host_caps:0x3000003f
          [00.360]sunxi flash init ok
          [00.362]line:703 init_clocks
          [00.366]drv_disp_init
          [00.387]drv_disp_init finish
          [00.396]Loading Environment from SUNXI_FLASH... OK
          [00.416]boot_gui_init:start
          [00.420]set disp.dev2_output_type fail. using defval=0
          [00.447]set disp.fb0_rot_used fail. using defval=0
          [00.452]set disp.fb0_rot_degree fail. using defval=0
          [00.622]boot_gui_init:finish
          [00.633]bmp_name=bootlogo.bmp size 38454
          [00.645]out of usb burn from boot: not need burn key
          [00.651]Item0 (Map) magic is bad
          [00.654]the secure storage item0 copy0 magic is bad
          [00.659]Item0 (Map) magic is bad
          [00.662]the secure storage item0 copy1 magic is bad
          [00.667]Item0 (Map) magic is bad
          root_partition is rootfs
          set root to /dev/mmFDT ERROR:fdt_get_all_pin:get property handle pinctrl-0 error:FDT_ERR_INTERNAL
          [00.691]LCD open finish
          cblk0p5
          [00.693]update part info
          [00.697]update bootcmd
          [00.700]change working_fdt 0x42aa8da0 to 0x42a88da0
          [00.710]The storage not support sample function
          [00.742]update dts
          input addr exceed dram scope
          [02.087]no vendor_boot partition is found
          Android's image name: d1s-nezha
          Detect comp none
          [02.107]
          Starting kernel ...
          [02.109][mmc]: MMC Device 2 not found
          [02.113][mmc]: mmc 2 not find, so not exit
          J A 2 条回复 最后回复 回复 引用 分享 0
            Jingyan LV 6 @cjia3254 最后由 编辑
            @cjia3254 earlyprint跟串口配置对了吗
              cjia3254 LV 5 @Jingyan 最后由 编辑
              @jingyan 这个我测试过,固件在另外一个d1s板子上能正常工作,在我新画的这个上面到内核就没输出了。
              J 1 条回复 最后回复 回复 引用 分享 0
                @cjia3254 确认下是卡死在内核了,还是只是没打印到终端上
                  Asoul_Ava LV 5 @cjia3254 最后由 编辑
                  @cjia3254 我最近也有这样!多按几次复位有几率能进入
                  • F
                    fanhuacloud LV 6 最后由 编辑
                    看着像是读取有问题
                      cjia3254 LV 5 最后由 编辑
                      又重新画了块t113的板子,加了几个滤波电容,就能正常启动内核了。
                        @cjia3254 你好,请问是在哪个部分要加滤波电容?
                          @asoul_ava 是个电源供电都加电容了。
