    V851S Tina 5.0 SDK 无法使用文件锁的问题
    5575
      dream LV 6 最后由 编辑
      起初是为了分析 opkg 工具用不了的问题:
      root@TinaLinux:/# opkg list
      Collected errors:
       * opkg_conf_load: Could not lock /var/lock/opkg.lock: Permission denied.
      通过分析其系统调用链,发现 opkg 试图设置文件锁失败了:
      root@TinaLinux:/# strace opkg list
      execve("/bin/opkg", ["opkg", "list"], 0xbef8ad04 /* 21 vars */) = 0
      set_tls(0xb6f555d8)                     = 0
      set_tid_address(0xb6f5618c)             = 1120
      open("/usr/lib/eyesee-mpp/libubox.so.20210516", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
      open("/etc/ld-musl-armhf.path", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
      open("/lib/libubox.so.20210516", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
      fcntl64(3, F_SETFD, FD_CLOEXEC)         = 0
      fstat64(3, {st_mode=S_IFREG|0644, st_size=38084, ...}) = 0
      read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\244!\0\0004\0\0\0"..., 936) = 936
      mmap2(NULL, 106496, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xb6ec0000
      mmap2(0xb6ed8000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x8000) = 0xb6ed8000
      close(3)                                = 0
      mprotect(0xb6ed8000, 4096, PROT_READ)   = 0
      mprotect(0x3e000, 4096, PROT_READ)      = 0
      stat64("/etc/opkg.conf", {st_mode=S_IFREG|0644, st_size=85, ...}) = 0
      open("/etc/opkg.conf", O_RDONLY|O_LARGEFILE) = 3
      brk(NULL)                               = 0xd97000
      brk(0xd98000)                           = 0xd98000
      brk(0xd99000)                           = 0xd99000
      brk(0xd9a000)                           = 0xd9a000
      brk(0xd9b000)                           = 0xd9b000
      brk(0xd9c000)                           = 0xd9c000
      brk(0xd9d000)                           = 0xd9d000
      brk(0xd9f000)                           = 0xd9f000
      brk(0xda0000)                           = 0xda0000
      read(3, "dest root /\ndest ram /tmp\nlists_"..., 1024) = 85
      read(3, "", 1024)                       = 0
      close(3)                                = 0
      open("/etc/opkg/", O_RDONLY|O_LARGEFILE|O_CLOEXEC|O_DIRECTORY) = 3
      getdents64(3, 0xb6ed9378 /* 4 entries */, 2048) = 112
      getdents64(3, 0xb6ed9378 /* 0 entries */, 2048) = 0
      close(3)                                = 0
      open("/etc/opkg/customfeeds.conf", O_RDONLY|O_LARGEFILE) = 3
      read(3, "# add your custom package feeds "..., 1024) = 103
      close(3)                                = 0
      open("/var/lock/opkg.lock", O_WRONLY|O_CREAT|O_TRUNC|O_LARGEFILE, 0640) = 3
      fcntl64(3, F_SETLK64, {l_type=F_WRLCK, l_whence=SEEK_CUR, l_start=0, l_len=0}) = -1 EACCES (Permission denied)
      close(3)                                = 0
      writev(2, [{iov_base="", iov_len=0}, {iov_base="Collected errors:\n", iov_len=18}], 2Collected errors:
      ) = 18
      writev(2, [{iov_base=" * opkg_conf_load: Could not loc"..., iov_len=75}, {iov_base=NULL, iov_len=0}], 2 * opkg_conf_load: Could not lock /var/lock/opkg.lock: Permission denied.
      ) = 75
      exit_group(-1)                          = ?
      +++ exited with 255 +++
      然后自己写一个测试程序,确实会失败:
      root@TinaLinux:/tmp# strace ./test
      execve("./test", ["./test"], 0xbeb32d00 /* 22 vars */) = 0
      set_tls(0xb6f9c5d8)                     = 0
      set_tid_address(0xb6f9d18c)             = 1133
      open("/usr/lib/eyesee-mpp/libstdc++.so.6", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
      open("/lib/libstdc++.so.6", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
      fstat64(3, {st_mode=S_IFREG|0775, st_size=976512, ...}) = 0
      read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\340\2\7\0004\0\0\0"..., 936) = 936
      mmap2(NULL, 1048576, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xb6e21000
      mmap2(0xb6f18000, 36864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xe7000) = 0xb6f18000
      mmap2(0xb6f20000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb6f20000
      close(3)                                = 0
      open("/usr/lib/eyesee-mpp/libgcc_s.so.1", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
      open("/lib/libgcc_s.so.1", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
      fstat64(3, {st_mode=S_IFREG|0664, st_size=38356, ...}) = 0
      read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\230'\0\0004\0\0\0"..., 936) = 936
      mmap2(NULL, 106496, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xb6e07000
      mmap2(0xb6e1f000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x8000) = 0xb6e1f000
      close(3)                                = 0
      mprotect(0xb6f18000, 20480, PROT_READ)  = 0
      mprotect(0xb6e1f000, 4096, PROT_READ)   = 0
      mprotect(0x20000, 4096, PROT_READ)      = 0
      brk(NULL)                               = 0xc2f000
      brk(0xc34000)                           = 0xc34000
      open("/tmp/opkg.lock", O_WRONLY|O_CREAT|O_TRUNC|O_LARGEFILE, 0644) = 3
      ioctl(1, TIOCGWINSZ, {ws_row=0, ws_col=0, ws_xpixel=0, ws_ypixel=0}) = 0
      writev(1, [{iov_base="fd:[3] rc:[-1", iov_len=13}, {iov_base="]\n", iov_len=2}], 2fd:[3] rc:[-1]
      ) = 15
      close(3)                                = 0
      exit_group(0)                           = ?
      +++ exited with 0 +++
      在 ubuntu 上测试实例代码是可以上锁的,说明用法没问题:
      ubuntu@ubuntu1804:~/work/v85x-tina-open/openwrt/package/dream/test/src$ g++ -o main main.cpp
      ubuntu@ubuntu1804:~/work/v85x-tina-open/openwrt/package/dream/test/src$ ./main
      fd:[3] rc:[0]
      请问各位大佬,有谁知道是咋回事吗?(附文件系统类型)
      root@TinaLinux:/tmp# df -Th
      Filesystem           Type            Size      Used Available Use% Mounted on
      /dev/root            squashfs       12.0M     12.0M         0 100% /rom
      devtmpfs             devtmpfs       23.8M         0     23.8M   0% /dev
      tmpfs                tmpfs          25.0M     16.0K     25.0M   0% /tmp
      /dev/by-name/UDISK   ubifs          10.4M     36.0K      9.8M   0% /mnt/UDISK
      overlayfs:/mnt/UDISK/overlay
                           overlay        10.4M     36.0K      9.8M   0% /
      tmpfs                tmpfs          25.0M         0     25.0M   0% /run
      D 1 条回复 最后回复 回复 引用 分享 0
      • F
        fanhuacloud LV 6 最后由 编辑
        Tina的SDK,确实是有点问题,之前遇到过hexdump触摸evnet导致失败,在D1s下面又没有这个问题
          dream LV 6 @dream 最后由 编辑
          @dream 同步最新的信息, 已经使用了 mutex 的方式,替换文件锁,可以解决 opkg remove 和 opkg list 等指令不能正常使用的问题,目前 opkg install 会出现段错误。
          原以为解决了文件锁,就能解决 opkg 不能使用的问题,没想到只解决了一半🙄
          *** libopkg\opkg_conf.c	2022-02-25 04:27:58.000000000 +0800
          --- libopkg\opkg_conf.c	2024-03-03 14:20:36.000000000 +0800
          *** 19,30 ****
          --- 19,31 ----
            #include <sys/types.h>
            #include <sys/stat.h>
            #include <fcntl.h>
            #include <glob.h>
            #include <unistd.h>
          + #include <sys/mman.h>
            #include "opkg_conf.h"
            #include "pkg_vec.h"
            #include "pkg.h"
            #include "xregex.h"
            #include "sprintf_alloc.h"
          *** 423,436 ****
          --- 424,452 ----
            int opkg_conf_init(void)
            	pkg_src_list_init(&conf->pkg_src_list);
            	pkg_dest_list_init(&conf->pkg_dest_list);
            	pkg_dest_list_init(&conf->tmp_dest_list);
            	nv_pair_list_init(&conf->arch_list);
          + 	conf->mlock = mmap(NULL, sizeof(struct mt_lock), PROT_READ|PROT_WRITE, MAP_SHARED|MAP_ANON, -1, 0);
          + 	memset(conf->mlock, 0, sizeof(struct mt_lock));
          + 	pthread_mutexattr_init(&conf->mlock->mutexattr);
          + 	pthread_mutexattr_setpshared(&conf->mlock->mutexattr, PTHREAD_PROCESS_SHARED);
          + 	pthread_mutex_init(&conf->mlock->mutex, &conf->mlock->mutexattr);
          + static int my_lockf(int fd, int cmd, off_t len)
          + 	switch(cmd){
          + 		case F_TLOCK: return pthread_mutex_trylock(&conf->mlock->mutex);
          + 		case F_ULOCK: return pthread_mutex_unlock(&conf->mlock->mutex);
          + 	return -22;
            int opkg_conf_load(void)
            	int i, glob_ret;
            	char *tmp, *tmp_dir_base, **tmp_val;
          *** 498,510 ****
            	lock_fd = creat(lock_file, S_IRUSR | S_IWUSR | S_IRGRP);
            	if (lock_fd == -1) {
            		opkg_perror(ERROR, "Could not create lock file %s", lock_file);
            		goto err2;
          ! 	if (lockf(lock_fd, F_TLOCK, (off_t) 0) == -1) {
            		opkg_perror(ERROR, "Could not lock %s", lock_file);
            		if (close(lock_fd) == -1)
            			opkg_perror(ERROR, "Couldn't close descriptor %d (%s)",
            				    lock_fd, lock_file);
            		lock_fd = -1;
            		goto err2;
          --- 514,526 ----
            		goto err2;
          ! 	if (my_lockf(lock_fd, F_TLOCK, (off_t) 0) == -1) {
            		lock_fd = -1;
            		goto err2;
          *** 573,585 ****
            	hash_table_deinit(&conf->file_hash);
            	hash_table_deinit(&conf->obs_file_hash);
            	if (rmdir(conf->tmp_dir) == -1)
            		opkg_perror(ERROR, "Couldn't remove dir %s", conf->tmp_dir);
            err3:
          ! 	if (lockf(lock_fd, F_ULOCK, (off_t) 0) == -1)
            		opkg_perror(ERROR, "Couldn't unlock %s", lock_file);
            	if (unlink(lock_file) == -1)
          --- 589,601 ----
            err3:
          ! 	if (my_lockf(lock_fd, F_ULOCK, (off_t) 0) == -1)
          *** 652,664 ****
            	pkg_hash_deinit();
            	if (lock_fd != -1) {
          --- 668,680 ----
            	pkg_hash_deinit();
          *** libopkg\opkg_conf.h	2022-02-25 04:27:58.000000000 +0800
          --- libopkg\opkg_conf.h	2024-03-03 14:20:05.000000000 +0800
          *** 20,31 ****
          --- 20,32 ----
            typedef struct opkg_conf opkg_conf_t;
            extern opkg_conf_t *conf;
            #include <stdarg.h>
            #include <fnmatch.h>		/* FNM_CASEFOLD */
          + #include <pthread.h>
            #include "hash_table.h"
            #include "pkg_src_list.h"
            #include "pkg_dest_list.h"
            #include "nv_pair_list.h"
          *** 39,50 ****
          --- 40,56 ----
            /* In case the config file defines no dest */
            #define OPKG_CONF_DEFAULT_DEST_NAME "root"
            #define OPKG_CONF_DEFAULT_DEST_ROOT_DIR "/"
            #define OPKG_CONF_DEFAULT_HASH_LEN 1024
          + struct mt_lock {
          +     pthread_mutex_t mutex;
          +     pthread_mutexattr_t mutexattr;
            struct opkg_conf {
            	pkg_src_list_t pkg_src_list;
            	pkg_dest_list_t pkg_dest_list;
            	pkg_dest_list_t tmp_dest_list;
            	nv_pair_list_t arch_list;
          *** 105,116 ****
          --- 111,125 ----
            	char *signature_ca_file;
            	char *signature_ca_path;
            	hash_table_t pkg_hash;
            	hash_table_t file_hash;
            	hash_table_t obs_file_hash;
          + 	// replace file lock
          + 	struct mt_lock *mlock;
            enum opkg_option_type {
            	OPKG_OPT_TYPE_BOOL,
            	OPKG_OPT_TYPE_INT,
            	OPKG_OPT_TYPE_STRING
            ajie2025 LV 2 最后由 编辑
            最后咋样了啊》?我的现在也是不能下载?也是文件锁的问题,还要mmp也不能推流,据说是删减版
