    tiny version 编译遇到问题
    6
    5262
      shyDragon LV 3 最后由 q1215200171 编辑
      各位大佬编译遇到这个问题如何去解决
      [./etc/init.d/rcS: line 37: /proc/sys/kernel/printk: Permission denied
      hostname: you must be root to change the host name
      SIOCSIFFLAGS: Operation not permitted
      Enabling rcS
      /etc/init.d/rcS does not have a START or STOP value
      Enabling sysntpd
      Enabling wpa_supplicant
      sed -i "s/Installed-Time: .*/Installed-Time: 1657264429/" /home/shy/v853/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/root-v851se-tinyvision/usr/lib/opkg/status
      rm -rf /home/shy/v853/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/root-v851se-tinyvision/boot /home/shy/v853/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/root-v851se-tinyvision/tmp/* /home/shy/v853/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/root-v851se-tinyvision/usr/lib/opkg/info/*.postinst* /home/shy/v853/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/root-v851se-tinyvision/usr/lib/opkg/lists/* /home/shy/v853/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/root-v851se-tinyvision/var/lock/*.lock
      find /home/shy/v853/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/root-v851se-tinyvision/usr/lib/opkg/info -type f -and -not -name '*.control' -delete
      sed -i -ne '/^Require-User: /p' /home/shy/v853/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/root-v851se-tinyvision/usr/lib/opkg/info/*.control
      awk ' BEGIN { conffiles = 0; print "Conffiles:" } /^Conffiles:/ { conffiles = 1; next } !/^ / { conffiles = 0; next } conffiles == 1 { print } ' /home/shy/v853/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/root-v851se-tinyvision/usr/lib/opkg/status >/home/shy/v853/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/root-v851se-tinyvision/usr/lib/opkg/status.new
      mv /home/shy/v853/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/root-v851se-tinyvision/usr/lib/opkg/status.new /home/shy/v853/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/root-v851se-tinyvision/usr/lib/opkg/status
      find /home/shy/v853/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/root-v851se-tinyvision/usr/lib/opkg -empty -delete
      find /home/shy/v853/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/root-v851se-tinyvision/ -mindepth 1 -execdir touch -hcd "@1657264429" "{}" +
      find: The relative path 'Files' is included in the PATH environment variable, which is insecure in combination with the -execdir action of find.  Please remove that entry from $PATH
      package/Makefile:66: recipe for target 'package/install' failed
      make[2]: *** [package/install] Error 1
      make[2]: Leaving directory '/home/shy/v853/tina-v853-open/openwrt/openwrt'
      package/Makefile:111: recipe for target '/home/shy/v853/tina-v853-open/openwrt/openwrt/staging_dir/target/stamp/.package_install' failed
      make[1]: *** [/home/shy/v853/tina-v853-open/openwrt/openwrt/staging_dir/target/stamp/.package_install] Error 2
      make[1]: Leaving directory '/home/shy/v853/tina-v853-open/openwrt/openwrt'
      /home/shy/v853/tina-v853-open/openwrt/openwrt/include/toplevel.mk:236: recipe for target 'world' failed
      make: *** [world] Error 2
      make: Leaving directory '/home/shy/v853/tina-v853-open/openwrt/openwrt']
      F L 2 条回复 最后回复 回复 引用 分享 0
      • F
        felislynx LV 3 @shyDragon 最后由 编辑
          lee2333 LV 3 @shyDragon 最后由 编辑
          @shydragon 在 tiny version 编译遇到问题 中说:
          各位大佬编译遇到这个问题如何去解决
          Enabling rcS
          Enabling sysntpd
          我也碰到这个问题了,楼主解决了吗
            lee2333 LV 3 最后由 编辑
            我也碰到这个问题了,楼主解决了吗
            J 1 条回复 最后回复 回复 引用 分享 0
              jasonzhang LV 5 @lee2333 最后由 编辑
              @lee2333 在WSL-Ubuntu下编译的?这边显示的Files目录在env里面,find执行有安全风险,所以被禁止了。
              可以考虑在windows环境变量里删除这个路径,或者修改$PATH,把这个路径移除
                lee2333 LV 3 @jasonzhang 最后由 编辑
                @jasonzhang 感谢大佬提供的思路,wsl2默认继承windows里面的环境变量,有的环境变量中的路径带空格污染了$PATH,影响了find的执行
