    T113S3双路 dual lvds驱动不起来
    9
    5708
    • Q
      quanzhi LV 3 最后由 编辑
      屏幕参数如下
      请问哪里不对呢
        awwwwa LV 8 最后由 编辑
        uboot和dtsi里面添加dual link IO的配置
        demo:
        lvds2link_pins_a: lvds2link@0 {
             allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7", \
             "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17";
             allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7", \
             allwinner,function = "lvds1";
             allwinner,muxsel = <3>;
             allwinner,drive = <3>;
             allwinner,pull = <0>;
        lvds2link_pins_b: lvds2link@1 {
             allwinner,function = "lvds1_suspend";
             allwinner,muxsel = <7>;
        dts中 修改为lvds dual link模式,并引用dtsi里配好的dual link IO
        &lcd0{
         lcd_lvds_if          = <1>;
        pinctrl-0 = <&lvds2link_pins_a>;
        pinctrl-1 = <&lvds2link_pins_b>;
        其他和single link的配置方法无异,如果点不亮请检查时序
        这里看到dclk配置是80
        但是手册需求的是54
        这里提供一套1920x720的时序作为参考
        &lcd0 {
        	lcd_used            = <1>;
        	lcd_backlight       = <50>;
        	lcd_if              = <3>;
        	lcd_x               = <1920>;
        	lcd_y               = <720>;
        	lcd_width           = <150>;
        	lcd_height          = <94>;
        	lcd_dclk_freq       = <94>;
        	lcd_pwm_used        = <1>;
        	lcd_pwm_ch          = <3>;
        	lcd_pwm_pol         = <1>;
        	lcd_pwm_max_limit   = <255>;
        	lcd_hbp             = <64>;
        	lcd_ht              = <2064>;
        	lcd_hspw            = <20>;
        	lcd_vbp             = <30>;
        	lcd_vt              = <760>;
        	lcd_vspw            = <10>;
        	lcd_lvds_if         = <1>;
        	lcd_lvds_colordepth = <0>;
        	lcd_lvds_mode       = <0>;
        	lcd_frm             = <1>;
        	lcd_hv_clk_phase    = <0>;
        	lcd_hv_sync_polarity= <0>;
        	lcd_gamma_en        = <0>;
        	lcd_bright_curve_en = <0>;
        	lcd_cmap_en         = <0>;
        	deu_mode            = <0>;
        	lcdgamma4iep        = <22>;
        	smart_color         = <90>;
        Q 2 条回复 最后回复 回复 引用 分享 1
        • Q
          quanzhi LV 3 @awwwwa 最后由 编辑
          @awwwwa 在 T113S3双路 dual lvds驱动不起来 中说:
          demo:
          &lcd0{
           lcd_lvds_if          = <1>;
          这里看到dclk配置是80
          但是手册需求的是54
          &lcd0 {
          	lcd_used            = <1>;
          	lcd_if              = <3>;
          	lcd_x               = <1920>;
          	lcd_y               = <720>;
          	lcd_width           = <150>;
          	lcd_height          = <94>;
          	lcd_pwm_used        = <1>;
          	lcd_pwm_ch          = <3>;
          	lcd_pwm_pol         = <1>;
          	lcd_hbp             = <64>;
          	lcd_ht              = <2064>;
          	lcd_hspw            = <20>;
          	lcd_vbp             = <30>;
          	lcd_vt              = <760>;
          	lcd_vspw            = <10>;
          	lcd_lvds_if         = <1>;
          	lcd_frm             = <1>;
          	lcd_gamma_en        = <0>;
          	lcd_cmap_en         = <0>;
          	deu_mode            = <0>;
          	smart_color         = <90>;
          /只有引用才能添加图片,回复图片报错***/
          @awwwwa 直接在uboot按原有的lvds0节点方式加节点报错Error:arch/arm/dts/board-ubootdts:96.1-18 Label or path lvds2link pins a not foundError:arch/arm/dts/board-ubootdts:107.1-18 Label or path lvds2link pins b not founc
          • Q
            @awwwwa @awwwwa 直接在uboot按原有的lvds0节点方式加节点报错Error:arch/arm/dts/board-ubootdts:96.1-18 Label or path lvds2link pins a not foundError:arch/arm/dts/board-ubootdts:107.1-18 Label or path lvds2link pins b not founc
              whycan晕哥 LV 9 最后由 whycan 编辑
              参考这个帖子:D1s调试lvds,求解?
              Q 1 条回复 最后回复 回复 引用 分享 0
              • Q
                quanzhi LV 3 @whycan 最后由 编辑
                @whycan 已参考,还是点不亮
                lvds0_pins_a: lvds0@0 {
                		allwinner,pins  = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
                		allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
                		allwinner,function = "lvds0";
                	lvds0_pins_b: lvds0@1 {
                	lvds1_pins_a: lvds1@0 {
                		allwinner,pins  = "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19";
                		allwinner,pname = "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19";
                	lvds1_pins_b: lvds1@1 {
                &lcd0 {
                	lcd_used            = <1>;
                	lcd_driver_name     = "default_lcd";	/* "bp101wx1"; */
                	lcd_if              = <3>;			/* 2:ttl; 3:lvds; 4:dsi */
                	lcd_x               = <1280>;
                	lcd_y               = <1024>;
                	lcd_width           = <338>;
                	lcd_height          = <270>;
                	lcd_dclk_freq       = <108>;
                	lcd_hbp             = <20>;
                	lcd_ht              = <1688>;
                	lcd_hspw            = <10>;
                	lcd_vbp             = <20>;
                	lcd_vt              = <1066>;
                	lcd_vspw            = <5>;
                	lcd_lvds_if         = <1>;
                	lcd_frm             = <1>;
                	lcd_gamma_en        = <0>;
                	lcd_cmap_en         = <0>;
                	lcd_pwm_used        = <0>;
                	lcd_pwm_ch          = <7>;
                	lcd_pwm_pol         = <0>;
                	lcd_backlight       = <100>;
                	deu_mode            = <0>;
                	smart_color         = <90>;
                	pinctrl-0 = <&lvds0_pins_a &lvds1_pins_a>;
                	pinctrl-1 = <&lvds0_pins_b &lvds1_pins_b>;
                检测PD引脚是全部UNCLAIMED的
                root@embedsky:/# mount -t debugfs none /sys/kernel/debug;
                root@embedsky:/# cat /sys/kernel/debug/pinctrl/pio/pinmux-pins
                Pinmux settings per pin
                Format: pin (name): mux_owner|gpio_owner (strict) hog?
                pin 32 (PB0): UNCLAIMED
                pin 33 (PB1): device 7040000.s_cir function ir group PB1
                pin 34 (PB2): UNCLAIMED
                pin 35 (PB3): GPIO pio:35
                pin 36 (PB4): UNCLAIMED
                pin 37 (PB5): UNCLAIMED
                pin 38 (PB6): device 2502c00.twi function gpio_in group PB6
                pin 39 (PB7): device 2502c00.twi function gpio_in group PB7
                pin 40 (PB8): UNCLAIMED
                pin 41 (PB9): UNCLAIMED
                pin 42 (PB10): UNCLAIMED
                pin 43 (PB11): UNCLAIMED
                pin 44 (PB12): UNCLAIMED
                pin 64 (PC0): UNCLAIMED
                pin 65 (PC1): UNCLAIMED
                pin 66 (PC2): device 4022000.sdmmc function sdc2 group PC2
                pin 67 (PC3): device 4022000.sdmmc function sdc2 group PC3
                pin 68 (PC4): device 4022000.sdmmc function sdc2 group PC4
                pin 69 (PC5): device 4022000.sdmmc function sdc2 group PC5
                pin 70 (PC6): device 4022000.sdmmc function sdc2 group PC6
                pin 71 (PC7): device 4022000.sdmmc function sdc2 group PC7
                pin 96 (PD0): UNCLAIMED
                pin 97 (PD1): UNCLAIMED
                pin 98 (PD2): UNCLAIMED
                pin 99 (PD3): UNCLAIMED
                pin 100 (PD4): UNCLAIMED
                pin 101 (PD5): UNCLAIMED
                pin 102 (PD6): UNCLAIMED
                pin 103 (PD7): UNCLAIMED
                pin 104 (PD8): UNCLAIMED
                pin 105 (PD9): UNCLAIMED
                pin 106 (PD10): UNCLAIMED
                pin 107 (PD11): UNCLAIMED
                pin 108 (PD12): UNCLAIMED
                pin 109 (PD13): UNCLAIMED
                pin 110 (PD14): UNCLAIMED
                pin 111 (PD15): UNCLAIMED
                pin 112 (PD16): UNCLAIMED
                pin 113 (PD17): UNCLAIMED
                pin 114 (PD18): UNCLAIMED
                pin 115 (PD19): UNCLAIMED
                pin 116 (PD20): UNCLAIMED
                pin 117 (PD21): UNCLAIMED
                pin 118 (PD22): UNCLAIMED
                pin 128 (PE0): device 2502400.twi function gpio_in group PE0
                pin 129 (PE1): device 2502400.twi function gpio_in group PE1
                pin 130 (PE2): device 2500800.uart function uart2 group PE2
                pin 131 (PE3): device 2500800.uart function uart2 group PE3
                pin 132 (PE4): device 2501000.uart function uart4 group PE4
                pin 133 (PE5): device 2501000.uart function uart4 group PE5
                pin 134 (PE6): device 2501400.uart function uart5 group PE6
                pin 135 (PE7): device 2501400.uart function uart5 group PE7
                pin 136 (PE8): device 2500c00.uart function uart3 group PE8
                pin 137 (PE9): device 2500c00.uart function uart3 group PE9
                pin 138 (PE10): UNCLAIMED
                pin 139 (PE11): UNCLAIMED
                pin 140 (PE12): UNCLAIMED
                pin 141 (PE13): device 3-0024 function irq group PE13
                pin 142 (PE14): UNCLAIMED
                pin 143 (PE15): UNCLAIMED
                pin 144 (PE16): UNCLAIMED
                pin 145 (PE17): UNCLAIMED
                pin 160 (PF0): device 4020000.sdmmc function gpio_in group PF0
                pin 161 (PF1): device 4020000.sdmmc function gpio_in group PF1
                pin 162 (PF2): device 4020000.sdmmc function gpio_in group PF2
                pin 163 (PF3): device 4020000.sdmmc function gpio_in group PF3
                pin 164 (PF4): device 4020000.sdmmc function gpio_in group PF4
                pin 165 (PF5): device 4020000.sdmmc function gpio_in group PF5
                pin 166 (PF6): GPIO pio:166
                pin 192 (PG0): device 4500000.eth function gmac0 group PG0
                pin 193 (PG1): device 4500000.eth function gmac0 group PG1
                pin 194 (PG2): device 4500000.eth function gmac0 group PG2
                pin 195 (PG3): device 4500000.eth function gmac0 group PG3
                pin 196 (PG4): device 4500000.eth function gmac0 group PG4
                pin 197 (PG5): device 4500000.eth function gmac0 group PG5
                pin 198 (PG6): device 4500000.eth function gmac0 group PG6
                pin 199 (PG7): device 4500000.eth function gmac0 group PG7
                pin 200 (PG8): device 4500000.eth function gmac0 group PG8
                pin 201 (PG9): device 4500000.eth function gmac0 group PG9
                pin 202 (PG10): device 4500000.eth function gmac0 group PG10
                pin 203 (PG11): device 4500000.eth function gmac0 group PG11
                pin 204 (PG12): device 4500000.eth function gmac0 group PG12
                pin 205 (PG13): device 4500000.eth function gmac0 group PG13
                pin 206 (PG14): device 4500000.eth function gmac0 group PG14
                pin 207 (PG15): device 4500000.eth function gmac0 group PG15
                pin 208 (PG16): UNCLAIMED
                pin 209 (PG17): UNCLAIMED
                pin 210 (PG18): UNCLAIMED
                执行这个命令看到时钟什么的和手册差不多
                root@embedsky:/# fbset
                mode "1280x1024-60"
                        # D: 108.003 MHz, H: 63.983 kHz, V: 60.021 Hz
                        geometry 1280 1024 1280 2048 32
                        timings 9259 10 388 15 22 10 5
                        accel false
                        rgba 8/16,8/8,8/0,8/24
                endmode
                • X
                  xinhuak LV 2 最后由 编辑
                  请问一下解决了没?
                  H 1 条回复 最后回复 回复 引用 分享 0
                    hameyou LV 4 @xinhuak 最后由 编辑
                    @xinhuak D1s dual lvds 1920*1080 已驱动成功
                    • luohan.zzZ
                      Mortal LV 2 最后由 编辑
                      您好,我这边也正在尝试调通T113S双路LVDS,但是一直给我报错说找不到节点,我在sun8iw20p1-t113-100ask-t113-pro.dts文件中写入了对lvds2link_pins_a引脚和lvds2link_pins_b引脚的配置,但是不行,编译报错,请问您这边是否遇到过这个问题呢?或者是我需要怎么去做呢?
                      • Moved from Linux by  xiaowenge xiaowenge
