    内核阶段开机logo会出现黑线,黑线位置随机
    6
    4763
    • aiit111
      aiit111 LV 4 最后由 编辑
      屏幕是480x272的lcd电阻屏.
      淘宝购买的t113开发板卖家给的sdk开发镜像.
      原镜像分辨率是800x480,对照屏幕参数修改了设备树,uboot阶段logo正常,内核会出现黑线.
        DOT小文哥 LV 8 最后由 编辑
        看着是boot里的屏幕没配好,查查屏幕配置和驱动
        aiit111 M 2 条回复 最后回复 回复 引用 分享 2
        • aiit111
          aiit111 LV 4 @xiaowenge 最后由 编辑
          小文哥,之前上传的视频有问题,uboot和kernel关于lcd的配置都是一样的
          屏幕RGB 480x272 linux-5.4.273
          线索一 uboot-board.dts
          &disp {
          	fb0_width                = <480>;
          	fb0_height               = <272>;
          	/*VCC-LCD*/
          	/*VCC-DSI*/
          	/*VCC-PD*/
          &lcd0 {
          	lcd_used            = <1>;
          	lcd_if              = <0>;
          	lcd_x               = <480>;
          	lcd_y               = <272>;
          	lcd_width           = <95>;
          	lcd_height          = <54>;
          	lcd_dclk_freq       = <10>;
          	lcd_pwm_used        = <1>;
          	lcd_pwm_ch          = <7>;
          	lcd_pwm_freq        = <10000>;
          	lcd_pwm_pol         = <1>;
          	lcd_hbp             = <44>;/*43+1*/
          	lcd_ht              = <526>;
          	lcd_hspw            = <1>;/*1*/
          	lcd_vbp             = <13>;
          	lcd_vt              = <286>;
          	lcd_vspw            = <1>;
          	lcd_lvds_if         = <0>;
          	lcd_lvds_colordepth = <1>;
          	lcd_lvds_mode       = <0>;
          	lcd_frm             = <0>;
          	lcd_gamma_en        = <0>;
          	lcd_bright_curve_en = <0>;
          	lcd_cmap_en         = <0>;
          	deu_mode            = <0>;
          	lcdgamma4iep        = <22>;
          	smart_color         = <90>;
          	pinctrl-0 = <&rgb18_pins_a>;
          	pinctrl-1 = <&rgb18_pins_b>;
          board.dts
          &disp {
          	screen1_output_type      = <1>;/*3*/
          	disp_rotation_used	 = <1>;
          	degree0			 = <0>;
          	fb0_width                = <480>;
          	fb0_height               = <272>;
          	/*VCC-LCD*/
          	/*VCC-DSI*/
          	/*VCC-PD*/
          &lcd0 {
          	lcd_used            = <1>;
          	lcd_backlight       = <50>;
          	lcd_if              = <0>;
          	lcd_x               = <480>;
          	lcd_y               = <272>;
          	lcd_width           = <95>;
          	lcd_height          = <54>;
          	/*lcd_pwm_used        = <1>;
          	lcd_pwm_ch          = <7>;
          	lcd_pwm_pol         = <1>;*/
          	lcd_hbp             = <44>;
          	lcd_ht              = <526>;
          	lcd_hspw            = <1>;
          	lcd_vbp             = <13>;
          	lcd_vt              = <286>;
          	lcd_vspw            = <1>;
          	lcd_lvds_if         = <0>;
          	lcd_frm             = <0>;
          	lcd_gamma_en        = <0>;
          	lcd_cmap_en         = <0>;
          	deu_mode            = <0>;
          	smart_color         = <90>;
          线索二 内核输出
          [ 0.508712] [DISP]disp_module_init
          [ 0.512657] disp 5000000.disp: Adding to iommu group 0
          [ 0.518295] [DISP] parser_disp_init_para,line:1430:
          [ 0.518299] of_property_read fb0_width fail
          [ 0.527390] [DISP] disp_init,line:2386:
          [ 0.527394] smooth display screen:0 type:1 mode:4
          [ 0.552098] display_fb_request,fb_id:0
          [ 0.557423] Freeing logo buffer memory: 1500K
          [ 0.562297] disp_al_manager_apply ouput_type:1
          [ 0.566842] [DISP] lcd_clk_config,line:744:
          [ 0.566853] disp 0, clk: pll(60000000),clk(60000000),dclk(10000000) dsi_rate(60000000)
          [ 0.566853] clk real:pll(288000000),clk(288000000),dclk(12000000) dsi_rate(0)
          [ 0.570471] [DISP]disp_module_init finish
          [ 0.571150] sunxi_pwm_enable_dual: can't parse pwm device
          [ 0.587556] sunxi_sid_init()551 - insmod ok
          [ 0.601112] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
          所搜了网上许多资料,推测原因是由于内核初始化lcd屏幕fb内存释放引起,的目前有两个方向,更新新的sdk,更新的话,之前对虚拟机中做的配置还需要再来一遍,有没有其他解决方法,
          @xiaowenge
          D 1 条回复 最后回复 回复 引用 分享 1
            double_X LV 2 最后由 编辑
            有解决吗?也遇到到了会出现黑线的问题
              double_X LV 2 @aiit111 最后由 编辑
              @aiit111 有解决吗
                mehrdadlak LV 3 @xiaowenge 最后由 编辑
                @xiaowenge 学习了,谢谢分享!我正在研究 T113 的 CVBS 视频输入。
