    T113S3改完调试串口问题
    6
    3899
      z2500abc LV 5 最后由 编辑
      T113S3调试串口从SDK中的UART0改到UART3后,串口能够打印出正确的log,但是不能够去进行敲命令进行交互。使用adb shell 就可以进行命令式交互。。
      以下是截取串口打印的部分log
       1.399524] CAN device driver interface
      [    1.404511] usbcore: registered new interface driver asix
      [    1.410653] usbcore: registered new interface driver ax88179_178a
      [    1.417622] usbcore: registered new interface driver cdc_ether
      [    1.424268] usbcore: registered new interface driver net1080
      [    1.430681] usbcore: registered new interface driver cdc_subset
      [    1.437410] usbcore: registered new interface driver zaurus
      [    1.443765] usbcore: registered new interface driver cdc_ncm
      [    1.450117] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.457456] sunxi-ehci: EHCI SUNXI driver
      [    1.462389] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    1.469369] sunxi-ohci: OHCI SUNXI driver
      [    1.474549] usbcore: registered new interface driver uas
      [    1.480601] usbcore: registered new interface driver usb-storage
      [    1.487456] usbcore: registered new interface driver ums-alauda
      [    1.494189] usbcore: registered new interface driver ums-cypress
      [    1.500985] usbcore: registered new interface driver ums-datafab
      [    1.507799] usbcore: registered new interface driver ums_eneub6250
      [    1.514817] usbcore: registered new interface driver ums-freecom
      [    1.521633] usbcore: registered new interface driver ums-isd200
      [    1.528354] usbcore: registered new interface driver ums-jumpshot
      [    1.535281] usbcore: registered new interface driver ums-karma
      [    1.541879] usbcore: registered new interface driver ums-onetouch
      [    1.548809] usbcore: registered new interface driver ums-realtek
      [    1.555631] usbcore: registered new interface driver ums-sddr09
      [    1.562331] usbcore: registered new interface driver ums-sddr55
      [    1.569050] usbcore: registered new interface driver ums-usbat
      [    1.575769] usbcore: registered new interface driver option
      [    1.582072] usbserial: USB Serial support registered for GSM modem (1-port)
      [    1.590943] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input1
      [    1.600472] sunxi_gpadc_init,2151, success
      [    1.605458] sunxi_gpadc_setup: get channel scan data failed
      [    1.612002] input: sunxi-gpadc0 as /devices/virtual/input/input2
      [    1.619761] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
      [    1.631102] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    1.641858] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    1.653201] sunxi-rtc 7090000.rtc: registered as rtc0
      [    1.658904] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    1.669577] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:44 UTC (44)
      [    1.678601] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [    1.684636] i2c /dev entries driver
      [    1.688772] IR NEC protocol handler initialized
      [    1.693879] IR RC5(x/sz) protocol handler initialized
      [    1.699996] sunxi-rc-recv 7040000.s_cir: sunxi_irrx_resource_get: get ir protocol failed
      [    1.709197] Registered IR keymap rc_map_sunxi
      [    1.714268] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
      [    1.722969] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
      [    1.733446] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
      [    1.743640] [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
      [    1.753427] [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
      [    1.763092] [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
      [    1.774906] usbcore: registered new interface driver uvcvideo
      [    1.781358] USB Video Class driver (1.1.1)
      [    1.785995] gspca_main: v2.14.0 registered
      [    1.790588] sunxi cedar version 1.1
      [    1.794734] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    1.801011] VE: sunxi_cedar_probe power-domain init!!!
      [    1.806800] VE: install start!!!
      [    1.806800]
      [    1.812386] VE: cedar-ve the get irq is 41
      [    1.812386]
      [    1.818913] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
      [    1.818913]
      [    1.828209] VE: install end!!!
      以下是ADB SHELL连接后的信息
      BusyBox v1.33.2 (2023-09-13 11:29:20 UTC) built-in shell (ash)
       Tina 5.0, OpenWrt 21.02-SNAPSHOT unknown
      root@TinaLinux:/#
      T J 2 条回复 最后回复 回复 引用 分享 0
      • T
        tivon LV 6 @z2500abc 最后由 编辑
        @z2500abc 看我以前的帖子
        Z 1 条回复 最后回复 回复 引用 分享 0
          jasonzhang LV 5 @z2500abc 最后由 编辑
          @z2500abc 串口能打印完整,表示内核中打印串口是正常的,ADB shell能连接,表示文件系统也启动了;那么大概率是你文件系统调试串口没有改,需要在/etc/inittab中将输出串口改成你当前的串口,例如这个
          ttyS3::respawn:/sbin/getty -L ttyS3 0 vt100 # GENERIC_SERIAL
            z2500abc LV 5 @jasonzhang 最后由 编辑
            @jasonzhang 好的 感谢 马上试试🤡
              z2500abc LV 5 @tivon 最后由 编辑
              @tivon 好,感谢大佬的指导
              • Q
                qz_18732517808 LV 4 最后由 编辑
                我最近也想拿全志的tina5.0 sdk来改一个自己的固件,想请问下,你试试用系统里面哪个型号改的,我硬件使用的spinand. 1 t113-dev-tina 使用 DA 机原型机, 默认 nor 介质
                2 t113-evb1_auto_nor-tina
                3 t113-evb1_auto-tina
                4 t113-evb1-tina
                5 t113_i-evb1_auto-tina
                6 t113-pro-tina
                7 t113s2-evb1-tina
                8 t113s2-evb_axp313a-tina
