    Kernel加载时Waiting for root device /dev/mtdblock4
    3029
      zhanweixin LV 5 最后由 编辑
      在V821的TINA-SDK里,参考IPC定义自己的主板,采用32MB NOR Flash,启动时发生了如题错误
      一、运行日志如下:
      U-Boot 2018.07-g90967e5 (Mar 01 2025 - 16:14:15 +0000) Allwinner Technology
      [00.374]DRAM:  64 MiB
      [00.376]Relocation Offset is: 01f7c000, reloc addr is: 83f7c000
      [00.383]secure enable bit: 0
      [00.386]CPU=960 MHz,PERI=3072 Mhz,AHB=192 Mhz, APB=96Mhz
      FDT sunxi flash disable
      SPI ALL:   ready
      [00.396]flash init start
      [00.398]workmode = 0,storage type = 3
      sunxi_get_spif_mode()227 - get dtr_mode_enable fail -13
      sunxi_get_spif_mode()236 - get io_mode_enable fail -13
      [00.416]spi sample_mode:0 sample_delay:24
      [00.421]spif sunxi_slave->max_hz:100000000
      SF: Detected py25q256hb( ) with page size 256 Bytes, erase size 64 KiB, total 32 MiB
      [00.433]sunxi flash init ok
      [00.436]Loading Environment from SUNXI_FLASH... OK
      root_partition is rootfs
      set root to /dev/mtdblock4
      [00.449]update part info
      [00.451]update bootcmd
      [00.455]change working_fdt 0x8394bea4 to 0x8392bea4
      [00.471]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      [00.478]update dts
      [03.549]no vendor_boot partition is found
      Android's image name: sun300i_riscv32
      Detect comp lzma
      ERROR: reserving fdt memory region failed (addr=80ffff00 size=100)
      [04.263]
      Starting kernel ...
      [    0.000000] Linux version 5.4.220 (beaan@ubuntu20-v85x) (gcc version 10.4.0 (2024-02-02_nds32le-linux-glibc-v5d-bbc31ec98)) #7 PREEMPT Tue Apr 22 14:52:16 UTC 2025
      [    0.000000] Reserved memory: created CMA memory pool at 0x0000000083c00000, size 4 MiB
      [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
      [    0.000000] Reserved memory: created DMA memory pool at 0x0000000081200000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node vdev0buffer@81200000, compatible id shared-dma-pool
      [    0.000000] Reserved memory: created DMA memory pool at 0x0000000081646000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node e907_rpbuf@81646000, compatible id shared-dma-pool
      [    0.000000] Zone ranges:
      [    0.000000]   Normal   [mem 0x0000000080000000-0x0000000083ffffff]
      [    0.000000]   node   0: [mem 0x0000000080000000-0x0000000080ffefff]
      [    0.000000]   node   0: [mem 0x0000000081244000-0x0000000081643fff]
      [    0.000000]   node   0: [mem 0x000000008164e000-0x0000000083ffffff]
      [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000083ffffff]
      [    0.000000] On node 0 totalpages: 15793
      [    0.000000]   Normal zone: 128 pages used for memmap
      [    0.000000]   Normal zone: 15793 pages, LIFO batch:3
      [    0.000000] SBI specification v0.3 detected
      [    0.000000] SBI implementation ID=0x1 Version=0x10000
      [    0.000000] SBI v0.2 TIME extension detected
      [    0.000000] SBI v0.2 IPI extension detected
      [    0.000000] SBI v0.2 RFENCE extension detected
      [    0.000000] SBI SRST extension detected
      [    0.000000] riscv: base ISA extensions acdfim
      [    0.000000] riscv: ELF capabilities acdfim
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 15665
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x42500000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mtdblock4 rootwait init=/init rdinit=/rdinit partitions=env@mtdblock1:boot@mtdblock2:riscv0@mtdblock3:rootfs@mtdblock4:rootfs_data@mtdblock5:UDISK@mtdblock6 cma=1M coherent_pool= androidboot.serialno=7c000c70f6c107d1fcf wifi_mac=60:c2:2a:10:1b:47 androidboot.hardware=sun300iw1p1 boot_type=3 androidboot.boot_type=3 gpt=1 uboot_message=2018.07-g90967e5(03/01/2025-16:14:15) mbr_offset=311296 androidboot.dramfreq=520 androidboot.dramsize=64 uboot_backup=ubootA
      [    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
      [    0.000000] Memory: 35072K/63172K available (3474K kernel code, 650K rwdata, 953K rodata, 136K init, 215K bss, 24004K reserved, 4096K cma-reserved)
      [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
      [    0.000000] NR_IRQS: 72, nr_irqs: 72, preallocated irqs: 0
      [    0.000000] plic: mapped 187 interrupts with 1 handlers for 2 contexts.
      [    0.000000] sunxi:ccu-ng:[INFO]: Current HOSC rate is 40000000HZ
      [    0.000000] AW BSP version: eb89978d76, 2025-03-02 00:15:40 +0800
      [    0.000000] sunxi:ccu-ng:[INFO]: aon_ccu: sunxi ccu init OK
      [    0.000000] sunxi:ccu-ng:[INFO]: sunxi ccu common driver version: 1.2.4
      [    0.000000] sunxi:ccu-ng:[INFO]: ccu: sunxi ccu init OK
      [    0.000000] sunxi:ccu-ng:[INFO]: sunxi app ccu driver version: 0.7.1
      [    0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x939a85c40, max_idle_ns: 440795202120 ns
      [    0.000010] sched_clock: 64 bits at 40MHz, resolution 25ns, wraps every 4398046511100ns
      [    0.008339] Calibrating delay loop (skipped), value calculated using timer frequency.. 80.00 BogoMIPS (lpj=40000)
      [    0.018233] pid_max: default: 32768 minimum: 301
      [    0.023029] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.030095] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.039700] rcu: Hierarchical SRCU implementation.
      [    0.043472] devtmpfs: initialized
      [    0.062482] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
      [    0.066641] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
      [    0.073606] pinctrl core: initialized pinctrl subsystem
      [    0.087670] phys:80000000 low vir:c0000000 non-cache:dfc80000~e3c80000
      [    0.089706] NET: Registered protocol family 16
      [    0.096365] sunxi:ccu-ng:[INFO]: sunxi prcm ccu driver version: 0.0.4
      [    0.107051] sunxi:pin-42000000.pinctrl:[INFO]: pinctrl withstand voltage config mode=auto_hard
      [    0.110063] sunxi:pin:[INFO]: sunxi pinctrl core driver version: 1.4.8
      [    0.116954] sunxi:pin:[INFO]: sunxi rtc-pinctrl version: 0.0.2
      [    0.124598] sunxi:pin-42000540.pinctrl:[INFO]: pinctrl withstand voltage config mode=auto_hard
      [    0.147659] usbcore: registered new interface driver usbfs
      [    0.147767] usbcore: registered new interface driver hub
      [    0.152974] usbcore: registered new device driver usb
      [    0.157977] mc: Linux media interface: v0.10
      [    0.162163] videodev: Linux video capture interface: v2.00
      [    0.168154] Advanced Linux Sound Architecture Driver Initialized.
      [    0.175306] sun6i-dma 43002000.dma-controller: sunxi dma probed, driver version: 1.2.11
      [    0.182851] sunxi-soc-regulator 4a000800.soc_pmu0: Supply for ldo1 (ldo1) resolved to itself
      [    0.190027] ldo1: supplied by regulator-dummy
      [    0.194735] ion_size_pool heap_size_pool@0: no small_source configurated, use cma as default
      [    0.204297] sunxi:pin-42000000.pinctrl:[INFO]: Auto power withstand voltage configuration detected, automatically exit!
      [    0.213709] sunxi-twi 42502000.twi0: 42502000.twi0 supply twi not found, using dummy regulator
      [    0.222621] sunxi:twi-42502000.twi0:[INFO]: v2.7.8 probe success
      [    0.228681] sunxi:pwm-42000c00.pwm:[INFO]: start probe
      [    0.229198] sunxi:pwm-42000c00.pwm:[INFO]: pwmchip probe success
      [    0.240034] clocksource: Switched to clocksource riscv_clocksource
      [    0.246840] thermal_sys: Registered thermal governor 'fair_share'
      [    0.246850] thermal_sys: Registered thermal governor 'bang_bang'
      [    0.251474] thermal_sys: Registered thermal governor 'step_wise'
      [    0.257360] thermal_sys: Registered thermal governor 'user_space'
      [    0.263331] thermal_sys: Registered thermal governor 'power_allocator'
      [    0.269890] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
      [    0.284341] NET: Registered protocol family 2
      [    0.288496] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
      [    0.296395] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.303820] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.311396] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.318399] TCP: Hash tables configured (established 1024 bind 1024)
      [    0.324826] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
      [    0.331224] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
      [    0.338366] NET: Registered protocol family 1
      [    0.344960] workingset: timestamp_bits=30 max_order=14 bucket_order=0
      [    0.355367] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.355781] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
      [    0.362313] fuse: init (API version 7.31)
      [    0.366530] NET: Registered protocol family 38
      [    0.370171] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      [    0.377451] io scheduler mq-deadline registered
      [    0.381947] io scheduler kyber registered
      [    0.405466] loop: module loaded
      [    0.405994] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    0.409559] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    0.415814] i2c /dev entries driver
      [    0.421201] uart-ng uart-ng0: uart-ng0 supply uart not found, using dummy regulator
      [    0.426996] sunxi:uart-ng-uart-ng0:[INFO]: cannot get the TX DMA channel!
      [    0.433547] sunxi:uart-ng-uart-ng0:[INFO]: cannot get the RX DMA channel!
      [    0.440339] sunxi:uart-ng:[INFO]: sunxi uart-ng driver version: 1.1.10
      [    0.446835] uart-ng0: ttyS0 at MMIO 0x42500000 (irq = 134, base_baud = 12000000) is a SUNXI
      [    0.455158] sunxi:uart-ng-uart-ng0:[INFO]: console setup baud 115200 parity n bits 8, flow n
      [    0.463521] sunxi:uart-ng-uart-ng0:[INFO]: uart0, select set 0, baud 115200, uartclk 192000000 beyond rance[24000000, 120000000]
      [    0.475128] printk: console [ttyS0] enabled
      [    0.485362] printk: bootconsole [earlycon0] disabled
      [    0.495925] sunxi:rtc-4a000c00.rtc:[WARN]: Fail to get clock 'rtc-1k'
      [    0.507279] sunxi:rtc-4a000c00.rtc:[WARN]: Fail to get clock 'rtc-spi'
      [    0.514708] sunxi:rtc:[INFO]:  Saving SoC boot-reason: COLD-BOOT
      [    0.521518] sunxi:rtc-4a000c00.rtc:[INFO]: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
      [    0.533256] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    0.544663] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    0.556135] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    0.567503] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    0.578857] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    0.590751] sunxi-rtc 4a000c00.rtc: registered as rtc0
      [    0.596624] sunxi:rtc-4a000c00.rtc:[INFO]: sunxi rtc probed
      [    0.604256] sunxi-wdt 4a001000.watchdog: Watchdog enabled (timeout=300 sec, nowayout=0), driver version: 1.0.5
      [    0.617293] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: SD/MMC/SDIO Host Controller Driver(v5.55 2024-08-26 15:32)
      [    0.629260] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: ctl-spec-caps 8
      [    0.636752] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vmmc regulator found
      [    0.644971] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vqmmc regulator found
      [    0.653292] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vdmmc regulator found
      [    0.661615] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vd33sw regulator found
      [    0.670021] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vd18sw regulator found
      [    0.678491] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vq33sw regulator found
      [    0.686940] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: No vq18sw regulator found
      [    0.695401] sunxi:sunxi_mmc_host-44020000.sdmmc:[ERR]: manual set ocr
      [    0.702677] sunxi:sunxi_mmc_host-44020000.sdmmc:[WARN]: Cann't get pin bias hs pinstate,check if needed
      [    0.713386] sunxi:sunxi_mmc_host-44020000.sdmmc:[ERR]: Could not get store clock
      [    0.721737] sunxi:sunxi_mmc_host-44020000.sdmmc:[ERR]: Could not get msi_lite clock
      [    0.730829] sunxi-mmc 44020000.sdmmc: sunxi:sunxi_mmc_hostcd-set-debounce is missing, function is no used
      [    0.742100] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    0.767070] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    0.793091] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    0.806584] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: detmode:data3
      [    0.815739] sunxi:sunxi_spif-44f00000.spif:[INFO]: sample_mode:0 sample_delay:24
      [    0.824329] sunxi:sunxi_spif-44f00000.spif:[INFO]: [spi-flash0] mclk 24000000
      [    0.832587] sunxi_spif 44f00000.spif: unrecognized JEDEC id bytes: 85 20 19 85 20 19
      [    0.841351] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    0.854851] sunxi:sunxi_spif-44f00000.spif:[ERR]:  sunxi spif nor register error:-2
      [    0.863483] sunxi:pin-42000000.pinctrl:[INFO]: Auto power withstand voltage configuration detected, automatically exit!
      [    0.876026] sunxi_spif: probe of 44f00000.spif failed with error -2
      [    0.883646] sunxi sbi init success
      [    0.887483] sunxi:sunxi_mmc_host-44020000.sdmmc:[ERR]: smc 0 p0 err, cmd 8, RTO !!
      [    0.896459] sunxi:gpadc:[INFO]: sunxi_gpadc_init(): 2148: gpadc class register success
      [    0.905347] sunxi:sunxi_mmc_host-44020000.sdmmc:[ERR]: smc 0 p0 err, cmd 55, RTO !!
      [    0.914484] sunxi:gpadc-42009000.gpadc0:[WARN]: warn: sample rate not set
      [    0.922160] sunxi:sunxi_mmc_host-44020000.sdmmc:[ERR]: smc 0 p0 err, cmd 55, RTO !!
      [    0.931229] input: sunxi-gpadc0/channel0/input0 as /devices/platform/soc@2002000/42009000.gpadc0/input/input0
      [    0.942436] sunxi:sunxi_mmc_host-44020000.sdmmc:[ERR]: smc 0 p0 err, cmd 55, RTO !!
      [    0.951528] input: sunxi-gpadc0/channel1/input0 as /devices/platform/soc@2002000/42009000.gpadc0/input/input1
      [    0.962706] sunxi:sunxi_mmc_host-44020000.sdmmc:[ERR]: smc 0 p0 err, cmd 55, RTO !!
      [    0.971421] sunxi:sunxi_mmc_host-44020000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    0.984764] sunxi:gpadc-42009000.gpadc0:[INFO]: sunxi_gpadc probe success
      [    0.997416] sunxi-msgbox 43033000.msgbox: sunxi:sunxi_msgboxsunxi_msgbox_probe(): sunxi msgbox start probe
      [    1.008649] sunxi-msgbox 43033000.msgbox: sunxi:sunxi_msgboxsunxi_msgbox_probe(): sunxi msgbox probe success
      [    1.020538] sunxi-rproc 43030000.e907_rproc: sunxi rproc driver 2.4.3
      [    1.028011] sunxi-rproc 43030000.e907_rproc: rv-cfg base: 0x43030000, va: 0xe3c95000
      [    1.036810] sunxi-rproc 43030000.e907_rproc: find rproc standby error
      [    1.044313] sunxi-rproc 43030000.e907_rproc: timeout_ms: 6000
      [    1.050853] sunxi-rproc 43030000.e907_rproc: reset_type: 2
      [    1.057058] sunxi-rproc 43030000.e907_rproc: reg:        43031000
      [    1.063922] sunxi-rproc 43030000.e907_rproc: irq_num:    151
      [    1.070306] sunxi-rproc 43030000.e907_rproc: panic_on_timeout: 1
      [    1.077309] sunxi-rproc 43030000.e907_rproc: register memory firmware('amp_rv0.bin') for 'e907', addr: 0x81244000, size: 2097152
      [    1.090342] sunxi_remoteproc: register mem fw('amp_rv0.bin'), addr=0x0000000081244000, len=2097152
      [    1.100406] sunxi_remoteproc: Image is corrupted (bad magic)
      [    1.106807] sunxi_remoteproc: please confirm the length of reserved mem in dts is greater or equal than the size of ELF firmware file('amp_rv0.bin')
      [    1.121736] sunxi-rproc 43030000.e907_rproc: register memory firmware('amp_rv0.bin') failed. ret: -22
      [    1.132639] Freeing amp_rv0.bin memory: 2048K
      [    1.137590] sunxi-rproc 43030000.e907_rproc: Register memory firmware failed when auto-boot is enabled!
      [    1.148157] sunxi-rproc 43030000.e907_rproc: is_using_kernel_fw: 0
      [    1.155206] remoteproc remoteproc0: e907_rproc is available
      [    1.161646] sunxi-rproc 43030000.e907_rproc: sunxi rproc driver probe ok
      [    1.169809] sunxi-rpbuf-controller rpbuf_controller0@0: assigned reserved memory node e907_rpbuf@81646000
      [    1.181238] [ADDR_MGT] addr_mgt_probe: module version: v1.0.13
      [    1.188379] [ADDR_MGT] addr_mgt_probe: success.
      [    1.194496] sunxi_gpio_motor: init success.
      [    1.199562] NET: Registered protocol family 17
      [    1.204662] NET: Registered protocol family 15
      [    1.226117] sunxi:rtc-4a000c00.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    1.237547] sunxi-rtc 4a000c00.rtc: setting system clock to 1970-01-01T00:00:05 UTC (5)
      [    1.248953] sunxi:disp:[WARN]: [DE]: not found boot_disp0
      [    1.255190] sunxi:disp:[WARN]: [DE]: sel 0, gamma_base=0xe4030040
      [    1.262087] sunxi:disp:[WARN]: [DE]: sel 0, gamma_ctrl_block 0xe4030040 val c36e0000 dirty 0 size 8 gamma_tab_block 0xe4030100 val c36e00c0 dirty 0 size 1024
      [    1.278711] sunxi:disp:[ERR]: [FB]: fb_num 1 fb_format 0
      [    1.284819] sunxi:disp:[ERR]: [FB]: fbinfo: fb: 0, disp: 0 channel: 0 layer: 0 zorder: 16 w: 320 h: 192
      [    1.295626] sunxi:disp:[ERR]: [FB]: fb_num 0 use rot 0 degree0
      [    1.302217] sunxi:disp:[ERR]: [FB]: smooth display disp0: type64 mode4 disp1: type0 mode0
      [    1.313217] sunxi:disp:[ERR]: [FB]: display logo on display 0 channel 0 layer 0 type 0
      [    1.322317] sunxi:disp:[ERR]: [FB]: fb 0 vir 0x(ptrval) phy 0x83c80000
      [    1.329688] sunxi:disp:[ERR]: [FB]: platform_fb_post_init start
      [    1.336679] sunxi:disp:[WARN]: [DE]: attached ok, mgr0<-->dev0
      [    1.343650] sunxi:VE:[INFO]: 2227 sunxi_cedar_init(): sunxi cedar version 1.1
      [    1.351730] sunxi:disp:[WARN]: [DE]: type:64,mode:4,fmt:rgb,bits:8bits,eotf:0,cs:0 dvi_hdmi:2, range:0 scan:0 ratio:8
      [    1.363962] sunxi:VE:[INFO]: 2149 sunxi_cedar_probe(): probe ve
      [    1.370986] sunxi-cedar 41c0e000.ve: 41c0e000.ve supply ve not found, using dummy regulator
      [    1.381740] sunxi:sound-common:[WARN]: 326 pacfg_level_trig_init(): pa-pin-msleep1-0 get failed, default 0
      [    1.393954] sunxi:sound-mach:[WARN]: 372 asoc_simple_parse_ucfmt(): set data late to default
      [    1.403924] debugfs: Directory 'soc@2002000:codec_plat' with parent 'audiocodec' already present!
      [    1.414137] sunxi-snd-mach soc@2002000:codec_mach: 42030000.codec <-> soc@2002000:codec_plat mapping ok
      [    1.428768] ALSA device list:
      [    1.432192]   #0: audiocodec
      [    1.435682] sunxi:uart-ng-uart-ng0:[INFO]: uart0, select set 0, baud 115200, uartclk 192000000 beyond rance[24000000, 120000000]
      [    1.448804] Waiting for root device /dev/mtdblock4...
      awbase abnormal...[0x33330001]
      二、uboot-board.dts
      * Allwinner Technology CO., Ltd. sun300iw1p1 soc board.
      * soc board support.
      &platform {
      	eraseflag   = <1>;
      	next_work   = <3>;
      	debug_mode  = <1>;
      &target {
      	boot_clock = <1008>;	/*CPU boot frequency, Unit: MHz*/
      	storage_type = <3>; /*boot medium, 0-nand, 1-card0, 2-card2, 3-nor, -1(defualt)auto scan*/
      	burn_key = <1>;		/*1:support burn key; 0:not support burn key*/
      &sdc0_pins_a {
      	allwinner,pins = "PC0", "PC1", "PC2",
      			"PC3", "PC4", "PC5";
      	allwinner,function = "sdc0";
      	allwinner,muxsel = <2>;
      	allwinner,drive = <3>;
      	allwinner,pull = <1>;
      	function = "sdc0";
      	drive-strength = <30>;
      	bias-pull-up;
      	power-source = <3300>;
      &sdc0_pins_b {
      	pins = "PF0", "PF1", "PF2",
      		"PF3", "PF4", "PF5";
      	function = "sdc0";
      	bias-pull-up;
      	power-source = <1800>;
      &sdc0_pins_c {
      	function = "gpio_in";
      &sdc2_pins_a {
      			"PC5", "PC6", "PC7";
      	allwinner,function = "sdc2";
      	allwinner,muxsel = <3>;
      	function = "sdc2";
      	bias-pull-up;
      &sdc2_pins_b {
      &card0_boot_para {  /* Avoid dtc compiling warnings. @TODO: Developer should modify this to the actual value */
      	/* reg = <0x0 0x2 0x0 0x0>;  [> Avoid dtc compiling warnings. @TODO: Developer should modify this to the actual value <] */
      	card_ctrl = <0x0>;
      	card_high_speed = <0x1>;
      	card_line = <0x4>;
      	pinctrl-0 = <&sdc0_pins_a>;
      	clk_type = "typ1";
      &card2_boot_para {  /* Avoid dtc compiling warnings. @TODO: Developer should modify this to the actual value */
      	/* reg = <0x0 0x3 0x0 0x0>;  [> Avoid dtc compiling warnings. @TODO: Developer should modify this to the actual value <] */
      	card_ctrl = <0x2>;
      	card_line = <0x4>;
      	pinctrl-0 = <&sdc2_pins_a>;
      	sdc_ex_dly_used = <0x2>;
      &gpio_bias {  /* Avoid dtc compiling warnings. @TODO: Developer should modify this to the actual value */
      	device_type = "gpio_bias";
      &aliases {
      	spi0 = &spi0;
      	spif = &spif;
      &pio{
      	spi0_pins_a: spi0@0 {
      		allwinner,pins = "PC9", "PC8", "PC11";
      		allwinner,pname = "spi0_sclk", "spi0_mosi",
      				"spi0_miso";
      		allwinner,function = "spi0";
      		allwinner,pull = <0>;
      	spi0_pins_b: spi0@1 {
      		allwinner,pins = "PC10", "PC7", "PC6";
      		allwinner,pname = "spi0_cs0", "spi0_hold",
      				"spi0_wp";
      		allwinner,pull = <1>;   // only CS should be pulled up
      	spi0_pins_c: spi0@2 {
      		allwinner,pins = "PC6", "PC7", "PC8", "PC9",
      				"PC10", "PC11";
      		allwinner,function = "gpio_in";
      		allwinner,muxsel = <0xf>;
      		allwinner,drive = <1>;
      	spif_pins_a: spif@0 {
      		allwinner,pins = "PC8", "PC9", "PC11";
      		allwinner,pname = "spif_mosi", "spif_clk", "spif_miso";
      		allwinner,function = "spif";
      	spif_pins_b: spif@1 {
      		allwinner,pins = "PC6", "PC7", "PC10";
      		allwinner,pname = "spif_wp", "spif_hold", "spif_cs0";
      	spif_pins_c: spif@2 {
      		allwinner,pins = "PC6", "PC7", "PC8", "PC9", "PC10", "PC11";
      &spi0 {
      	pinctrl-1 = <&spi0_pins_c>;
      	spi_slave_mode = <0>;
      	spi_dbi_enable = <0>;
      	spi0_cs_number = <1>;
      	status = "disabled";
      	spi_board0 {
      		device_type = "spi_board0";
      		compatible = "spi-nor";
      		spi-max-frequency = <100000000>;
      		m25p,fast-read = <1>;
      		/*individual_lock;*/
      		reg = <0x0>;
      		spi-rx-bus-width=<0x04>;
      		spi-tx-bus-width=<0x04>;
      		status="disabled";
      	spi-nand@0 {
      		compatible = "spi-nand";
      		spi-max-frequency=<0x05F5E100>;
      		reg = <0x0>;
      		spi-rx-bus-width=<0x01>;
      		spi-tx-bus-width=<0x01>;
      		status="disabled";
      &spif {
      	pinctrl-0 = <&spif_pins_a &spif_pins_b>;
      	pinctrl-1 = <&spif_pins_c>;
      	spif-nor {
      		spif-max-frequency = <100000000>;
      		reg = <0x0>;
      		spif-rx-bus-width=<0x04>;
      		spif-tx-bus-width=<0x04>;
      		status="disabled";
      &sunxi_flashmap {
      	/* Unit: Sector */
      	sdmmc_map {
      		logic_offset = <40960>;
      		boot_param_start = <24504>;
      		boot_param_size = <1>;
      		uboot_start = <32800>;
      		uboot_size = <4096>;
      		uboot_bak_start = <24576>;
      		uboot_bak_size = <4096>;
      		secure_storage_start = <12288>;
      		secure_storage_size = <512>;
      		tuning_data_start = <24512>;
      		tuning_data_size = <60>;
      *  |-44k-|   -4k-   |   -uboot size-    |-16k-|
      *  |boot0|boot_param|uboot(boot_package)| mbr |  ===> mtdblock0(need 64k aligned)
      *        |          |->uboot_start      |     |-> kernel start
      *        |->boot_param_start            |->logic_offset
      	nor_map {
      		/*Unit: Sector, 8M flash:16384, 16M flash:32768, 32M flash:65536*/
      		/* logic offset requires block size(64K) alignment - 32(mbr size) */
      		flash_size = <65536>;
      		logic_offset = <608>;
      		secure_logic_offset = <2016>;
      		rtos_logic_offset = <2016>;
      		rtos_secure_logic_offset = <2016>;
      		boot_param_start = <88>;
      		boot_param_size = <8>;
      		uboot_start = <96>;
      		uboot_size = <384>;
      		boot0_start = <0>;
      三、board.dts
      // SPDX-License-Identifier: (GPL-2.0+ or MIT)
      /dts-v1/;
      #include "sun300iw1p1.dtsi"
      	board = "V821", "V821-ipc";
      	compatible = "allwinner,v821", "riscv,sun300iw1p1";
      	aliases {
      	reg_vdd_cpu: vdd-cpu {
      		regulator-name = "vdd_cpu";
      		regulator-min-microvolt = <920000>;
      		regulator-max-microvolt = <920000>;
      		regulator-always-on;
      		regulator-boot-on;
      	/* used for hib & ultra standby poweron source enable mask */
      	/* bit 0 ~ bit 7 - pl 0 ~pl 7 */
      	/* bit 9 rtc alarm0 */
      	/* bit 10 rtc alarm1 */
      	/* bit 11 wakeuptimer */
      	/* bit 12 wlan, keep 0 because hib has no wlan and ultra wakes up by wlan on remote core */
      	poweron-source {
      		hib_poweron_source  = <0x000007FF>;
      		ultra_poweron_source  = <0x000007FF>;
      	reserved-memory {
      		rv_ddr_reserved: rvddrreserved@81000000 {
      			reg = <0x0 0x81000000 0x0 0x200000>;
      			no-map;
      		* The name should be "vdev%dbuffer".
      		* Its size should be not less than
      		*     RPMSG_BUF_SIZE * (num of buffers in a vring) * 2
      		*   = 512 * (num of buffers in a vring) * 2
      		rv_vdev0buffer: vdev0buffer@81200000 {
      			compatible = "shared-dma-pool";
      			reg = <0x0 0x81200000 0x0 0x40000>;
      			no-map;
      		* The name should be "vdev%dvring%d".
      		* The size of each should be not less than
      		*     PAGE_ALIGN(vring_size(num, align))
      		*   = PAGE_ALIGN(16 * num + 6 + 2 * num + (pads for align) + 6 + 8 * num)
      		* (Please refer to the vring layout in include/uapi/linux/virtio_ring.h)
      		rv_vdev0vring0: vdev0vring0@81240000 {
      			reg = <0x0 0x81240000 0x0 0x2000>;
      			no-map;
      		rv_vdev0vring1: vdev0vring1@81242000 {
      			reg = <0x0 0x81242000 0x0 0x2000>;
      			no-map;
      		e907_mem_fw: e907_mem_fw@81244000 {
      			/* boot0 & uboot0 load elf addr */
      			reg = <0x0 0x81244000 0x0 0x00200000>;
      		e907_share_irq_table: share_irq_table@81644000 {
      			reg = <0x0 0x81644000 0x0 0x2000>;
      			no-map;
      		e907_rpbuf_reserved:e907_rpbuf@81646000 {
      			reg = <0x0 0x81646000 0x0 0x8000>;
      			no-map;
      		size_pool {
      			reg = <0 0x82000000 0 0x0f00000>;
      		linux,cma {
      			size = <0x0 0x400000>;
      	reserved-irq {
      		share-e907 {
      			arch-name = "e907";
      			memory-region = <&e907_share_irq_table>;
      			/* defined by sun300iw1-share-irq-dt.h */
      			share-irq =
      					<1    0x1    E907_PA_IRQ_NUM    A27_PA_IRQ_NUM    0x00000000>,
      					<3    0x3    E907_PC_IRQ_NUM    A27_PC_IRQ_NUM    0x00000000>,
      					<4    0x4    E907_PD_IRQ_NUM    A27_PD_IRQ_NUM    0x00000000>,
      					<12   0xc    E907_PL_IRQ_NUM    A27_PL_IRQ_NUM    0x00000000>;
      	hifbypass: hifbypass {
      		compatible = "allwinner,sun300wi-sip-wifi";
      		interrupts-extended = <&plic0 160 IRQ_TYPE_LEVEL_HIGH>;
      	rpbuf_controller0: rpbuf_controller0@0 {
      		compatible = "allwinner,rpbuf-controller";
      		remoteproc = <&e907_rproc>;
      		ctrl_id = <0>;
      		memory-region = <&e907_rpbuf_reserved>;
      	rpbuf_xradio: rpbuf_xradio@0 {
      		compatible = "allwinner,rpbuf-xradio";
      		rpbuf = <&rpbuf_controller0>;
      	heap_size_pool@0{
      		compatible = "allwinner,size_pool";
      		heap-name = "size_pool";
      		heap-id = <0x7>;
      		heap-base = <0x82000000>;
      		heap-size = <0x0f00000>;
      		heap-type = "ion_size_pool";
      		thrs = <100>;
      		sizes = <0 15360>;
      		fall_to_big_pool = <1>;
      	gpio-motor@0 {
      		compatible = "allwinner,gpio-motor";
      		ab-pin-black = <&pio PD 12 GPIO_ACTIVE_HIGH>;
      		ab-pin-yellow = <&pio PD 13 GPIO_ACTIVE_HIGH>;
      		ab-pin-brown = <&pio PD 14 GPIO_ACTIVE_HIGH>;
      		ab-pin-blue = <&pio PD 15 GPIO_ACTIVE_HIGH>;
      		cd-pin-black = <&pio PD 16 GPIO_ACTIVE_HIGH>;
      		cd-pin-yellow = <&pio PD 17 GPIO_ACTIVE_HIGH>;
      		cd-pin-brown = <&pio PD 18 GPIO_ACTIVE_HIGH>;
      		cd-pin-blue = <&pio PD 19 GPIO_ACTIVE_HIGH>;
      	ae350_standby_debug:ae350_standby_debug@1 {
      		compatible = "allwinner,sun300iw1-ae350-standby-debug";
      		mboxes = <&msgbox 2>;
      		mbox-names = "ae350-notify";
      &rtc_pio {
      	uart0_pins_default: uart0_pins@0 {
      		pins = "PL4", "PL5";
      		function = "uart0";
      	uart0_pins_sleep: uart0_pins@1 {
      		function = "io_disabled";
      	uart3_pins_default: uart3_pins@0 {
      		pins = "PL2", "PL3";
      		function = "uart3";
      	uart3_pins_sleep: uart3_pins@1 {
      &pio {
      	uart1_pins_default: uart1_pins@0 {
      		pins = "PD7", "PD8", "PD9", "PD10";
      		function = "uart1";
      	uart1_pins_sleep: uart1_pins@1 {
      	uart2_pins_default: uart2_pins@0 {
      		pins = "PA5", "PA6", "PA7", "PA8";
      		function = "uart2";
      	uart2_pins_sleep: uart2_pins@1 {
      	gmac0_pins_default: gmac_pins@0 {
      		pins = "PD1", "PD2", "PD3",
      			"PD4", "PD5", "PD6", "PD7",
      			"PD8", "PD9", "PD10", "PD11";
      		function = "rmii";
      		bias-pull-up;
      	gmac0_pins_sleep: gmac_pins@1 {
      	pwm8_pins_active: pwm8@0 {
      		pins = "PD18";
      		function = "pwm0_8";
      	pwm8_pins_sleep: pwm8@1 {
      		pins = "PD18";
      		bias-pull-down;
      	pwm9_pins_active: pwm9@0 {
      		pins = "PD19";
      		function = "pwm0_9";
      	pwm9_pins_sleep: pwm9@1 {
      		pins = "PD19";
      		bias-pull-down;
      	twi0_pins_default: twi0@0 {
      		pins = "PA3", "PA4";
      		function = "twi0";
      		allwinner,drive = <0>;
      		bias-pull-up;
      	twi0_pins_sleep: twi0@1 {
      	spi0_pins_default: spi0@0 {
      		pins = "PC9", "PC8", "PC11"; /* clk, mosi, miso */
      		function = "spi0";
      	spi0_pins_cs: spi0@1 {
      		pins = "PC6", "PC7", "PC10"; /* wp, hold, cs */
      		function = "spi0";
      		bias-pull-up;
      	spi0_pins_sleep: spi0@2 {
      		pins = "PC6", "PC7", "PC9", "PC8", "PC11", "PC10";
      	sdc0_pins_a: sdc0@0 {
      				"PC3", "PC5";
      		function = "sdc0";
      		bias-pull-up;
      	sdc0_pins_c: sdc0@2 {
      	sdc0_pins_d: sdc0@3 {
      		pins = "PC4";
      		function = "sdc0";
      		bias-disable;
      	/* for uboot card probe */
      	sdc0_pins_uboot: sdc0@4 {
      	spif_pins_default: spif@0 {
      		function = "spif";
      	spif_pins_cs: spif@1 {
      		function = "spif";
      		bias-pull-up;
      	spif_pins_sleep: spif@2 {
      &soc {
      	card0_boot_para@0 {
      		card_ctrl = <0x0>;
      		card_line = <0x4>;
      		pinctrl-0 = <&sdc0_pins_uboot>;
      		clk_type = "typ1";
      	addr_mgt: addr_mgt {
      		compatible = "allwinner,sunxi-addr_mgt";
      		type_addr_wifi = <0x0>;
      		type_addr_bt   = <0x0>;
      		type_addr_eth  = <0x0>;
      &uart0 {
      	pinctrl-0 = <&uart0_pins_default>;
      	pinctrl-1 = <&uart0_pins_sleep>;
      &uart1 {
      	pinctrl-0 = <&uart1_pins_default>;
      	pinctrl-1 = <&uart1_pins_sleep>;
      &uart2 {
      	pinctrl-0 = <&uart2_pins_default>;
      	pinctrl-1 = <&uart2_pins_sleep>;
      &uart3 {
      	pinctrl-0 = <&uart3_pins_default>;
      	pinctrl-1 = <&uart3_pins_sleep>;
      &twi0 {
      	clock-frequency = <400000>;
      	pinctrl-0 = <&twi0_pins_default>;
      	pinctrl-1 = <&twi0_pins_sleep>;
      	/* For stability and backwards compatibility, we recommend setting 'twi_drv_used' to 1 */
      	twi_drv_used = <1>;
      &soc_pmu0 {
      &sdc0 {
      	pinctrl-0 = <&sdc0_pins_a &sdc0_pins_d>;
      	pinctrl-1 = <&sdc0_pins_c>;
      	bus-width = <4>;
      	cd-used-24M;
      	/*cd-gpios = <&pio PC 15 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;*/
      	/*non-removable;*/
      	/*broken-cd;*/
      	/*cd-inverted*/
      	data3-detect;
      	cap-sd-highspeed;
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	no-sdio;
      	no-mmc;
      	/*sunxi-power-save-mode;*/
      	sunxi-dis-signal-vol-sw;
      	max-frequency = <50000000>;
      	ctl-spec-caps = <0x8>;
      &pwm0_8 {
      	pinctrl-0 = <&pwm8_pins_active>;
      	pinctrl-1 = <&pwm8_pins_sleep>;
      &pwm0_9 {
      	pinctrl-0 = <&pwm9_pins_active>;
      	pinctrl-1 = <&pwm9_pins_sleep>;
      &spi0 {
      	pinctrl-0 = <&spi0_pins_default &spi0_pins_cs>;
      	pinctrl-1 = <&spi0_pins_sleep>;
      	sunxi,spi-bus-mode = <SUNXI_SPI_BUS_NOR>;
      	sunxi,spi-cs-mode = <SUNXI_SPI_CS_SOFT>;
      	dmas;
      	dma-names;
      	spi_board0 {
      		reg = <0x0>;
      		spi-rx-bus-width = <4>;
      		spi-tx-bus-width = <4>;
      &spif0 {
      	pinctrl-0 = <&spif_pins_default &spif_pins_cs>;
      	pinctrl-1 = <&spif_pins_sleep>;
      	spif-rx-bus-width = <0x4>;
      	spif-tx-bus-width = <0x4>;
      	//prefetch_read_mode_enabled;	/* choose prefect read mode */
      	//dtr_mode_enabled;				/* choose double edge trigger mode */
      	//dqs_mode_enabled;				/* choose dqs mode(nand provide clk mode) */
      	spif-nor  {
      		compatible = "spif-nor";
      		reg = <0x0>;
      &mdio0 {
      	phy0: ethernet-phy@0 {
      		/* JL11x1 */
      		compatible = "ethernet-phy-id937c.4024",
      			"ethernet-phy-ieee802.3-c22";
      		reg = <0>;
      		max-speed = <100>;  /* Max speed capability for rmii */
      		reset-gpios = <&pio PC 16 GPIO_ACTIVE_LOW>;
      		/* PHY datasheet rst time */
      		reset-assert-us = <200000>;
      		reset-deassert-us = <150000>;
      &gmac0 {
      	phy-mode = "rmii";
      	pinctrl-0 = <&gmac0_pins_default>;
      	pinctrl-1 = <&gmac0_pins_sleep>;
      	sunxi,phy-clk-type = <0>;
      	phy-handle = <&phy0>;
      	tx-delay = <0>;
      	rx-delay = <0>;
      &vind0 {
      	csi_top = <200000000>;
      	csi1: csi@45821000 {
      		pinctrl-0 = <&ncsi_bt656_pins_a>;
      		pinctrl-1 = <&ncsi_bt656_pins_b>;
      	tdm0: tdm@45908000 {
      		work_mode = <0x0>;
      	isp00:isp@45900000 {
      		work_mode = <0x0>;
      		ldci_select = <0x1>;
      	isp01:isp@458ffffc {
      	isp10:isp@4 {
      	scaler00:scaler@45910000 {
      		work_mode = <0x0>;
      	scaler01:scaler@4590fffc {
      		work_mode = <0xff>;
      	scaler10:scaler@45910400 {
      		work_mode = <0x0>;
      	scaler11:scaler@459103fc {
      		work_mode = <0xff>;
      	actuator0: actuator@2108180 {
      		device_type = "actuator0";
      		actuator0_slave = <0x18>;
      		actuator0_af_pwdn = <>;
      		actuator0_name;
      	flash0: flash@2108190 {
      		device_type = "flash0";
      		flash0_type = <2>;
      		flash0_en = <>;
      		flash0_mode = <>;
      		flash0_flvdd = "";
      		flash0_flvdd_vol = <>;
      		device_id = <0>;
      	sensor0: sensor@5812000 {
      		device_type = "sensor0";
      		sensor0_mname = "gc1084_mipi";
      		sensor0_twi_cci_id = <0>;
      		sensor0_twi_addr = <0x6e>;
      		sensor0_mclk_id = <0>;
      		sensor0_pos = "rear";
      		sensor0_isp_used = <1>;
      		sensor0_fmt = <1>;
      		sensor0_stby_mode = <0>;
      		sensor0_vflip = <0>;
      		sensor0_hflip = <0>;
      		sensor0_iovdd-supply = <>;
      		sensor0_iovdd_vol = <>;
      		sensor0_avdd-supply = <&pmu_soc_ldo1>;
      		sensor0_avdd_vol = <2800000>;
      		sensor0_dvdd-supply = <>;
      		sensor0_dvdd_vol = <>;
      		sensor0_power_en = <>;
      		sensor0_reset = <&pio PA 0 GPIO_ACTIVE_LOW>;
      		sensor0_pwdn = <>;
      		act_handle = <>;
      	sensor1: sensor@5812010 {
      		device_type = "sensor1";
      		sensor1_mname = "gc1084_2";
      		sensor1_twi_cci_id = <0>;
      		sensor1_twi_addr = <0x6c>;
      		sensor1_mclk_id = <1>;
      		sensor1_pos = "front";
      		sensor1_isp_used = <1>;
      		sensor1_fmt = <1>;
      		sensor1_stby_mode = <0>;
      		sensor1_vflip = <0>;
      		sensor1_hflip = <0>;
      		sensor1_iovdd-supply = <>;
      		sensor1_iovdd_vol = <>;
      		sensor1_avdd-supply = <>;
      		sensor1_avdd_vol = <>;
      		sensor1_dvdd-supply = <>;
      		sensor1_dvdd_vol = <>;
      		sensor1_power_en = <>;
      		sensor1_reset = <&pio PD 13 GPIO_ACTIVE_LOW>;
      	sensor_list0:sensor_list@200b820 {
      		sensor00_mname = "gc5035_mipi";
      		sensor00_twi_addr = <0x6c>;
      		sensor00_type = <1>;
      		sensor00_hflip = <0>;
      		sensor00_vflip = <0>;
      		sensor00_act_used = <1>;
      		sensor00_act_name = "dw9714_act";
      		sensor00_act_twi_addr = <0x18>;
      		sensor01_mname = "ov5675_mipi";
      		sensor01_twi_addr = <0x6c>;
      		sensor01_type = <1>;
      		sensor01_hflip = <0>;
      		sensor01_vflip = <0>;
      		sensor01_act_used = <1>;
      		sensor01_act_name = "dw9714_act";
      		sensor01_act_twi_addr = <0x18>;
      		sensor02_mname = "sp5409_mipi";
      		sensor02_twi_addr = <0x78>;
      		sensor02_type = <1>;
      		sensor02_hflip = <0>;
      		sensor02_vflip = <0>;
      		sensor02_act_used = <1>;
      		sensor02_act_name = "dw9714_act";
      		sensor02_act_twi_addr = <0x18>;
      	sensor_list1:sensor_list@200b830 {
      		sensor10_mname = "gc02m2_mipi";
      		sensor10_twi_addr = <0x20>;
      		sensor10_type = <1>;
      		sensor10_hflip = <0>;
      		sensor10_vflip = <0>;
      		sensor10_act_used = <0>;
      		sensor10_act_name = "";
      		sensor10_act_twi_addr = <>;
      		sensor11_mname = "ov02a10_mipi";
      		sensor11_twi_addr = <0x7a>;
      		sensor11_type = <1>;
      		sensor11_hflip = <1>;
      		sensor11_vflip = <0>;
      		sensor11_act_used = <0>;
      		sensor11_act_name = "";
      		sensor11_act_twi_addr = <>;
      		sensor12_mname = "gc030a_mipi";
      		sensor12_twi_addr = <0x42>;
      		sensor12_type = <1>;
      		sensor12_hflip = <0>;
      		sensor12_vflip = <0>;
      		sensor12_act_used = <0>;
      		sensor12_act_name = "";
      		sensor12_act_twi_addr = <>;
      	vinc00:vinc@45830000 {
      		vinc0_csi_sel = <0>;
      		vinc0_mipi_sel = <0>;
      		vinc0_isp_sel = <0>;
      		vinc0_isp_tx_ch = <0>;
      		vinc0_tdm_rx_sel = <0>;
      		vinc0_rear_sensor_sel = <0>;
      		vinc0_front_sensor_sel = <0>;
      		vinc0_sensor_list = <0>;
      		work_mode = <0x0>;
      	vinc01:vinc@4582fffc {
      		vinc1_csi_sel = <1>;
      		vinc1_mipi_sel = <1>;
      		vinc1_isp_sel = <1>;
      		vinc1_isp_tx_ch = <0>;
      		vinc1_tdm_rx_sel = <1>;
      		vinc1_rear_sensor_sel = <0>;
      		vinc1_front_sensor_sel = <0>;
      		vinc1_sensor_list = <0>;
      	vinc10:vinc@45831000 {
      		vinc4_csi_sel = <0>;
      		vinc4_mipi_sel = <0>;
      		vinc4_isp_sel = <0>;
      		vinc4_isp_tx_ch = <0>;
      		vinc4_tdm_rx_sel = <0>;
      		vinc4_rear_sensor_sel = <0>;
      		vinc4_front_sensor_sel = <0>;
      		vinc4_sensor_list = <0>;
      		work_mode = <0x0>;
      	vinc11:vinc@45830ffc {
      		vinc5_csi_sel = <1>;
      		vinc5_mipi_sel = <1>;
      		vinc5_isp_sel = <1>;
      		vinc5_isp_tx_ch = <0>;
      		vinc5_tdm_rx_sel = <1>;
      		vinc5_rear_sensor_sel = <0>;
      		vinc5_front_sensor_sel = <0>;
      		vinc5_sensor_list = <0>;
      &msgbox {
      /* audio dirver module -> audio codec */
      &codec {
      	tx-hub-en;
      	rx-sync-en;
      	dac-vol	= <63>;		/* default value:63 range:0->63 */
      	dacl-vol	= <160>;	/* default value:160 range:0->255 */
      	adc-vol		= <160>;	/* default value:160 range:0->255 */
      	lineout-gain	= <31>;		/* default value:31 range:0->31 */
      	mic-gain	= <31>;		/* default value:31 range:0->31 */
      	adcdelaytime	= <0>;	/* default value:0 range:0,5,10,20,30 */
      	pa-pin-max	= <1>;
      	pa-pin-0	= <&pio PC 15 GPIO_ACTIVE_HIGH>;
      	pa-pin-level-0	= <1>;
      	pa-pin-msleep-0	= <0>;
      	rglt-max	= <0>;
      	//rglt0-mode	= "AUDIO";
      	//rglt0-voltage	= <1800000>;
      	//rglt1-mode	= "PMU";
      	//rglt1-voltage	= <3300000>;
      	//rglt1-supply	= <&reg_dldo1>;
      &codec_plat {
      &codec_mach {
      	soundcard-mach,cpu {
      		sound-dai = <&codec_plat>;
      	soundcard-mach,codec {
      		sound-dai = <&codec>;
      /* audio dirver module -> I2S/PCM */
      &i2s0_plat {
      	tdm-num		= <0>;
      	/* "tx-pin"
      	* 1. tx pin enable setting.
      	* 2. we can set it like tx_pin = <3 0> - enable tx_pin0 and tx_pin3.
      	* "rx-pin"
      	* 1. rx pin enable setting.
      	* 2. we can set it like rx_pin = <1 2> - enable rx_pin1 and rx_pin2.
      	* "tx-pin-chmap"
      	* 1. tx pin channel map setting.
      	* 2. the subscript of value corresponds to the channel number.
      	* 3. the value corresponds to slot number.
      	* 4. we can use it like tx-pin1-chmap = <1 2 ... 15> to set pin1 channel map.
      	* 5. if enabled the pin, but not set "tx-pin-chmap", default set <0 1 2 ...>.
      	* 6. if the count of value is less than 16, then missing member will be set 0.
      	* rxfifo map
      	* 1. "rxfifo-pinmap" - set the corresponding pin.
      	* 2. "rxfifo-chmap" - set the corresponding slot.
      	* 3. we can use it like rxfifo-pinmap = <0 1 2>; rxfifo-chmap = <1 2 14>; to set rxfifo map.
      	* 4. the count of value of "rxfifo-pinmap" can != the count of value of "rxfifo-pinmap",
      	*    then missing member would be set 0.
      	tx-pin		= <0>;
      	rx-pin		= <0>;
      	/* tx-pin0-chmap = <0 1 5>; */
      	/* rxfifo-pinmap = <0 0>; */
      	/* rxfifo-chmap = <0 1>; */
      	//pinctrl-used;
      	//pinctrl-names	= "default","sleep";
      	//pinctrl-0	= <&i2s0_pins_a &i2s0_pins_c &i2s0_pins_d>;
      	//pinctrl-1	= <&i2s0_pins_b>;
      	tx-hub-en;
      	rx-sync-en;
      &i2s0_mach {
      	soundcard-mach,format		= "i2s";
      	soundcard-mach,frame-master	= <&i2s0_cpu>;
      	soundcard-mach,bitclock-master	= <&i2s0_cpu>;
      	/* soundcard-mach,frame-inversion; */
      	/* soundcard-mach,bitclock-inversion; */
      	soundcard-mach,slot-num		= <2>;
      	soundcard-mach,slot-width	= <32>;
      	i2s0_cpu: soundcard-mach,cpu {
      		sound-dai = <&i2s0_plat>;
      		/* note: pll freq = 24.576M or 22.5792M * pll-fs */
      		soundcard-mach,pll-fs	= <1>;
      		/* note:
      		* "mclk-fs"
      		* if not defined it or equal to 0, disable mclk.
      		* "mclk-fp" (if defined "mclk-fs")
      		* 1. if not defined "mclk-fp", mclk_freq = mclk-fs * sample_rate;
      		* 2. if defined "mclk-fp" but no value, mclk_freq = mclk-fs * 11.2896M or 12.288M;
      		* 3. if defined "mclk-fp" with 2 value, like: mclk-fp = <val1 val2>;
      		*    it means: mclk_freq(44.1k fp) = mclk-fs * val1;
      		*              mclk_freq(48k fp)   = mclk-fs * val2.
      	i2s0_codec: soundcard-mach,codec {
      &e907_rproc {
      	firmware-name = "amp_rv0.bin";
      	mboxes = <&msgbox 0>;
      	mbox-names = "arm-kick";
      	auto-boot;
      	skip-shutdown;
      	fw-region = <&e907_mem_fw>;
      	memory-region = <&rv_ddr_reserved>, <&rv_vdev0buffer>, <&rv_vdev0vring0>, <&rv_vdev0vring1>, <&e907_share_irq_table>;
      	fw-partitions = "riscv0", "riscv0-r";
      	fw-partition-sectors = <2176>;
      	memory-mappings =
      	/* < DA         len             PA >    */
      	/* SRAM ISP */
      	< 0x2000000        0xa800        0x2000000 >,
      	/* SRAM VE */
      	< 0x200a800        0x17400       0x200a800 >,
      	/* SRAM WIFI */
      	< 0x68000000       0x1000000     0x68000000 >,
      	/* DRAM */
      	< 0x80000000       0x0fffffff    0x80000000 >;
      	stop-record-reg = <0x4a00020c>;
      	share-irq = "e907";
      	rproc_wdt: rproc_wdt@0 {
      		timeout_ms = <6000>;
      		try_times = <1>;
      		reset_type = <0x2>;
      		panic_on_timeout = <1>;
      *usb_port_type: usb mode: 0-device, 1-host, 2-otg.
      &usbc0 {
      	device_type = "usbc0";
      	usb_port_type = <0x2>;
      	usb_detect_type = <0x0>;
      	usb_detect_mode = <0x0>;
      	//usb_id_gpio;
      	//usb_det_vbus_gpio;
      	//usb_det_vbus_gpio = "axp_ctrl";
      	//det_vbus_supply;
      	usb_regulator_io = "nocare";
      	usb_wakeup_suspend = <0x0>;
      	usb_luns = <0x3>;
      	usb_serial_unique = <0x0>;
      &udc {
      	//det_vbus_supply = <&gpio_charger>;
      &ehci0 {
      	//drvvbus-supply = <&reg_usb_vbus>;
      &ohci0 {
      &gpadc0 {
      	channel_num = <4>;
      	channel_select = <0x3>;
      	channel_data_select = <0x0>;
      	channel_compare_select = <0x0>;
      	channel_cld_select = <0x0>;
      	channel_chd_select = <0x0>;
      disp init configuration
      set fbX_height to lcd_x)
      				in display.
      &disp {
      	screen0_output_type      = <7>;
      	screen0_to_lcd_index     = <0>;
      	screen1_to_lcd_index     = <2>;
      	fb_format                = <0>;
      	fb_num                   = <1>;
      	fb_debug                 = <1>;
      	/*<disp channel layer zorder>*/
      	fb0_map                  = <0 0 0 16>;
      	fb0_width                = <320>;
      	fb0_height               = <192>;
      	fb1_map                  = <0 2 0 16>;
      	fb1_width                = <300>;
      	fb1_height               = <300>;
      	fb2_map                  = <1 0 0 16>;
      	fb2_width                = <1280>;
      	fb2_height               = <720>;
      	fb3_map                  = <1 1 0 16>;
      	fb3_width                = <300>;
      	fb3_height               = <300>;
      ircut_pin_a   : IRCUT PIN+
      ircut_pin_b   : IRCUT PIN-
      ircut_pin_drv : Set the driver strength for the IR cut pins
      ircut_open    : Define the GPIO states for opening the IR cut <ircut_pin_a ircut_pin_b>
      hold_time     : Set the hold time for the IR cut operation (in milliseconds)
      &ircut {
      	ircut_pin_a = <&pio PD 22 GPIO_ACTIVE_HIGH>;
      	ircut_pin_b = <&pio PD 23 GPIO_ACTIVE_HIGH>;
      	ircut_pin_drv = <3>;
      	ircut_open = <GPIO_ACTIVE_HIGH GPIO_ACTIVE_LOW>;
      	hold_time = <100>;
      &cpu0 {
      	cpu-supply = <&reg_vdd_cpu>;
        补充下u-boot的env配置信息如下
        => env print
        arm-smmu-v3=0
        boot_fastboot=fastboot
        boot_normal=sunxi_flash read 82000000 ${boot_partition};bootm 82000000
        boot_partition=boot
        boot_recovery=sunxi_flash read 82000000 recovery;bootm 82000000
        boot_riscv=bootrv 82000000 200000 0 riscv0 riscv0-r
        bootcmd=run setargs_nor boot_normal
        bootdelay=3
        cma=1M
        fastboot_key_value_max=0x8
        fastboot_key_value_min=0x2
        fdtcontroladdr=8394bea4
        force_normal_boot=1
        init=/init
        initcall_debug=0
        loglevel=8
        mmc_root=/dev/mmcblk0p5
        mtdids=▒Bs▒0▒
        mtdparts=▒Bs▒0▒
        nor_root=/dev/mtdblock4
        partition=▒Bs▒0▒
        rdinit=/rdinit
        recovery_key_value_max=0x13
        recovery_key_value_min=0x10
        riscv_partition=riscv0
        root_partition=rootfs
        rotpk_status=0
        selinux=0
        setargs_mmc=setenv bootargs earlyprintk=${earlyprintk} initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${mmc_root} rootwait init=${init} rdinit=${rdinit} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} selinux=${selinux} specialstr=${specialstr} gpt=1 arm-smmu-v3.disable_bypass=${arm-smmu-v3}
        setargs_nand=setenv bootargs earlyprintk=${earlyprintk} initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootwait init=${init} rdinit=${rdinit} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} selinux=${selinux} specialstr=${specialstr} gpt=1 arm-smmu-v3.disable_bypass=${arm-smmu-v3}
        setargs_nor=setenv bootargs earlyprintk=${earlyprintk} initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nor_root} rootwait init=${init} rdinit=${rdinit} partitions=${partitions} cma=${cma} coherent_pool=${coherent_pool}
        snum=7c000c70f6c107d1fcf
        Environment size: 1978/65532 bytes
          通过分析日志发现无法识别到型号为PY25Q256HB的NOR Flash
          解决办法如下:
          1、打开${SDK_PATH}/bsp/drivers/mtd/spi-nor-5.4/spi-nor.c文件
          搜索找到/* PUYA */位置,在后面添加
          	{ "py25q256hb", INFO(0x852019, 0x0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | USE_IO_MODE | USE_RX_DTR) },
          2、打开${SDK_PATH}/device/config/chips/v821/configs/v2w/linux-5.4-ansc/board.dts文件
          将&spif0里添加取消dtr_mode_enabled的注释
          &spif0 {
          	io_mode_enabled;				/* 1_x_x && x_x_x mode */
          	spif-nor  {
          		reg = <0x0>;
          此问题顺利解决
          • I
            indream LV 5 最后由 编辑
            刚好碰到这个问题,谢谢分享
