    Tina5.0 T113 编写makefile 编译驱动模块,都是提示不对,各位大请指教一下
    3192
      daMing123 LV 6 最后由 xiaowenge 编辑
      请教一下各位大神,全志的T113,编译 自已写的 驱动模块 时候,makefile ,应该如何写,有没有例子?
      我写了,老是提示有问题
      问题如下:
      lin@ubuntu:~/mydata2/T113_Tina5.0/usrdriver/focaltech_touch$ make
      make ARCH=arm  -I/home/lin/mydata2/T113_Tina5.0/T113-Tina5.0-V1.2/out/t113/kernel/build/    CROSS_COMPILE=/home/lin/mydata2/T113_Tina5.0/T113-Tina5.0-V1.2/out/toolchain/gcc-linaro-5.3.1-2016.05-x86_64_arm-linux-gnueabi/bin/arm-linux-gnueabi- -C /home/lin/mydata2/T113_Tina5.0/T113-Tina5.0-V1.2/kernel/linux-5.4/ M=/home/lin/mydata2/T113_Tina5.0/usrdriver/focaltech_touch modules
      make[1]: 进入目录“/home/lin/mydata2/T113_Tina5.0/T113-Tina5.0-V1.2/kernel/linux-5.4”
      awk: 致命错误: 无法以读模式打开文件“include/generated/asm-offsets.h”(没有那个文件或目录)
        CC [M]  /home/lin/mydata2/T113_Tina5.0/usrdriver/focaltech_touch/focaltech_core.o
      cc1: error: cannot load plugin ./scripts/gcc-plugins/arm_ssp_per_task_plugin.so
      ./scripts/gcc-plugins/arm_ssp_per_task_plugin.so: cannot open shared object file: No such file or directory
      scripts/Makefile.build:286: recipe for target '/home/lin/mydata2/T113_Tina5.0/usrdriver/focaltech_touch/focaltech_core.o' failed
      make[2]: *** [/home/lin/mydata2/T113_Tina5.0/usrdriver/focaltech_touch/focaltech_core.o] Error 1
      Makefile:1810: recipe for target '/home/lin/mydata2/T113_Tina5.0/usrdriver/focaltech_touch' failed
      make[1]: *** [/home/lin/mydata2/T113_Tina5.0/usrdriver/focaltech_touch] Error 2
      make[1]: 离开目录“/home/lin/mydata2/T113_Tina5.0/T113-Tina5.0-V1.2/kernel/linux-5.4”
      Makefile:36: recipe for target 'kernel_modules' failed
      make: *** [kernel_modules] Error 2
      makefile 如下:
      TINA_SDK_ROOT = /home/lin/mydata2/T113_Tina5.0/T113-Tina5.0
      KERNELDIR := $(TINA_SDK_ROOT)/kernel/linux-5.4/
      CURRENT_PATH := $(shell pwd)
      STAGING_DIR := $(TINA_SDK_ROOT)/out/t113/100ask_nand/openwrt/staging_dir/target
      obj-m := ft5446.o
      ft5446-objs += focaltech_core.o focaltech_ex_fun.o  focaltech_ex_mode.o
      ft5446-objs += focaltech_gesture.o focaltech_esdcheck.o  focaltech_i2c.o focaltech_point_report_check.o
      ARCH            := arm
      CROSS_COMPILE   := $(TINA_SDK_ROOT)/out/toolchain/gcc-linaro-5.3.1-2016.05-x86_64_arm-linux-gnueabi/bin/arm-linux-gnueabi-
      #CROSS_COMPILE = ${TINA_SDK_ROOT}/prebuilt/rootfsbuilt/arm/gcc-arm-10.3-2021.07-x86_64-arm-none-linux-gnueabihf/bin/arm-none-linux-gnueabihf-
      CFLAGS  += -I$(TINA_SDK_ROOT)/out/t113/kernel/build/
      build: kernel_modules
      kernel_modules:
      	$(MAKE) ARCH=$(ARCH)  $(CFLAGS)  $(LCOMPILELIBAll)  CROSS_COMPILE=$(CROSS_COMPILE) -C $(KERNELDIR) M=$(CURRENT_PATH) modules
      clean:
      	$(MAKE) -C $(KERNELDIR) M=$(CURRENT_PATH) clean
      J 1 条回复 最后回复 回复 引用 分享 1
        jasonzhang LV 5 @daMing123 最后由 编辑
        @daming123 KERNELDIR出错,不是kernel源码地址,而是kernel编译后的目录地址。大致目录为
        KERNELDIR := $(TINA_SDK_ROOT)/out/kernel/build
        D M 2 条回复 最后回复 回复 引用 分享 2
          daMing123 LV 6 @jasonzhang 最后由 编辑
          @jasonzhang 好的,谢谢,可以了
          M 1 条回复 最后回复 回复 引用 分享 1
            mehrdadlak LV 3 @jasonzhang 最后由 编辑
            @jasonzhang 在 Tina5.0 T113 编写makefile 编译驱动模块,都是提示不对,各位大请指教一下 中说:
            GOOD
              mehrdadlak LV 3 @daMing123 最后由 编辑
              @daming123
              but its error
