    公司垃圾堆翻出来的F1C200s + EP952 板子
    8
    7563
      memory LV 7 最后由 编辑
      L 1 条回复 最后回复 回复 引用 分享 1
        memory LV 7 最后由 编辑
        [update_key]
        key_type = 1
        key_value0 = 0
        port0 = 1
        port_num0 = 1
        key_value1 = 0
        port1 = 1
        port_num1 = 1
        key_value2 = 0
        port2 = 1
        port_num2 = 2
        [bt_para]
        bt_name = "AMMT"
        bt_pin = "0000"
        bt_mic_vol = 40
        [target]
        debugenable = 0
        storage_mode = 0
        boot_clock = 408
        core_vol = 1100
        [product]
        eraseflag = 0
        jtag = 0
        [card_boot]
        logical_start = 40960
        [card_boot0_para]
        card_ctrl = 0
        card_high_speed = 1
        card_line = 1
        SDC_CLK = port:PF02<2><1><1><1>
        SDC_CMD = port:PF03<2><1><1><1>
        SDC_D0 = port:PF01<2><1><1><1>
        SDC_D1 = port:PF00<2><1><1><1>
        SDC_D2 = port:PF05<2><1><1><1>
        SDC_D3 = port:PF04<2><1><1><1>
        [iis_para]
        IIS_BCLK = port:PE03<4><1><1><1>
        IIS_LRCK = port:PE04<4><1><1><1>
        IIS_DO0 = port:PE06<4><1><1><1>
        [twi_para]
        twi_port = 0
        twi_scl = port:PA06<2><1><1><default>
        twi_sda = port:PA07<2><1><1><default>
        [simu_para]
        uart_io_used = 1
        uart_io_tx = port:PA00<3><1><1><default>
        [jtag_para]
        jtag_enable = 0
        [twi0_para]
        twi0_used = 0
        twi_scl = port:PE11<3><1><1><1>
        twi_sda = port:PE12<3><1><1><1>
        [twi1_para]
        twi1_used = 0
        twi1_scl = port:PB00<3><1><1><1>
        twi1_sda = port:PB01<3><1><1><1>
        [twi2_para]
        twi2_used = 1
        twi2_scl = port:PE00<4><1><1><1>
        twi2_sda = port:PE01<4><1><1><1>
        [uart_para0]
        uart_used = 0
        uart_port = 0
        uart_type = 2
        uart_debug_tx = port:PE01<5><1><1><default>
        uart_debug_rx = port:PE00<5><1><1><default>
        [uart_para1]
        uart_used = 0
        uart_port = 1
        uart_type = 2
        [uart_para2]
        uart_used = 1
        uart_port = 2
        uart_type = 2
        uart_debug_tx = port:PE07<3><1><1><default>
        uart_debug_rx = port:PE08<3><1><1><default>
        [power_para]
        power_used = 0
        power_msg = 56
        power_twi = 0
        adc_exp = 1027
        [rtc_para]
        rtc_exist = 0
        inner_timer = 1
        [display_mode]
        pvp_mode = 1
        [tvout_para]
        tv_en = port:PC11<1><2><1><1>
        [auto_test_para]
        auto_test_enable = 0
        [matrixkey_para]
        period = 5
        pw_off_time = 2000
        row_num = 2
        [dsa_para]
        DSA_USED = 0
        [sddet_para]
        detect_pin = port:PF04<0><1><1><1>
        [sdcard_global]
        used_card_no = 1
        [pwm0_para]
        pwm0 = port:PE12<4><0><1><1>
        [pwm1_para]
        pwm1 = port:PF05<4><0><1><1>
        [sdcard0_para]
        bus_width = 1
        [sdcard1_para]
        bus_width = 1
        SDC_CLK = port:PC00<3><1><1><1>
        SDC_CMD = port:PC01<3><1><1><1>
        SDC_D0 = port:PC02<3><1><1><1>
        [audio_para]
        hp_driver_need = 1
        PA_SHDN = port:PC09<1><1><1><1>
        [tp_para]
        if_reverse = 1
        [spi_global]
        spi_used = 1
        [spi0_para]
        spi_cs_bitmap = 1
        SPI_CS0 = port:PC01<2><1><1><1>
        SPI_CLK = port:PC00<2><1><1><1>
        SPI_MOSI = port:PC03<2><1><1><1>
        SPI_MISO = port:PC02<2><1><1><1>
        [ir_para]
        IR_RX = port:PF00<4><1><1><1>
        [lcd0_para]
        lcd_power_used = 0
        lcd_bl_en_used = 0
        lcd_pwm_used = 0
        lcdd2 = port:PD00<2><1><3><1>
        lcdd3 = port:PD01<2><1><3><1>
        lcdd4 = port:PD02<2><1><3><1>
        lcdd5 = port:PD03<2><1><3><1>
        lcdd6 = port:PD04<2><1><3><1>
        lcdd7 = port:PD05<2><1><3><1>
        lcdd10 = port:PD06<2><1><3><1>
        lcdd11 = port:PD07<2><1><3><1>
        lcdd12 = port:PD08<2><1><3><1>
        lcdd13 = port:PD09<2><1><3><1>
        lcdd14 = port:PD10<2><1><3><1>
        lcdd15 = port:PD11<2><1><3><1>
        lcdd18 = port:PD12<2><1><3><1>
        lcdd19 = port:PD13<2><1><3><1>
        lcdd20 = port:PD14<2><1><3><1>
        lcdd21 = port:PD15<2><1><3><1>
        lcdd22 = port:PD16<2><1><3><1>
        lcdd23 = port:PD17<2><1><3><1>
        lcdclk = port:PD18<2><1><3><1>
        lcdde = port:PD19<2><1><3><1>
        lcdhsync = port:PD20<2><1><3><1>
        lcdvsync = port:PD21<2><1><3><1>
        [csi0_para]
        [usb_para]
        usb_global_enable = 1
        usbc_num = 1
        mode = 1
        [usbc0]
        usb_enable = 1
        usb_port_type = 2
        usb_detect_type = 3
        [dram_para]
        baseaddr = -2147483648
        size = 0
        clk = 156
        access_mode = 1
        cs_num = 1
        ddr8_remap = 0
        sdr_ddr = 1
        bwidth = 16
        col_width = 10
        row_width = 13
        bank_size = 4
        cas = 3
        [standby_eint_para]
        [display]
        out_type = 0
        lcd_swap = 0
        lcd_x = 800
        lcd_y = 480
        lcd_dclk_div = 8
        sta_dly = 10
        lcd_basic_valid = 0
        lcd_uf = 0
        lcd_vt = 1050
        lcd_ht = 1055
        lcd_vbp = 34
        lcd_hbp = 215
        lcd_if = 0
        lcd_hv_if = 0
        lcd_hv_smode = 0
        lcd_hv_s888_if = 0
        lcd_hv_syuv_if = 0
        lcd_hv_vspw = 0
        lcd_hv_hspw = 0
        lcd_hv_lde_used = 0
        lcd_hv_lde_iovalue = 0
        lcd_cpu_if = 0
        lcd_io_cfg0 = 67108864
        lcd_io_cfg1 = 0
        [spinor_para]
        spinor_patten_num = 5
        [spinor0]
        rdid = 1450178
        capaticy = 32
        freq_read = 33000000
        freq = 86000000
        [spinor1]
        rdid = 4627839
        capaticy = 32
        freq_read = 10000000
        freq = 50000000
        [spinor2]
        rdid = 1581250
        capaticy = 128
        freq = 86000000
        [spinor3]
        rdid = 1515714
        capaticy = 64
        freq = 86000000
        [spinor4]
        rdid = 1581250
        capaticy = 128
        freq = 86000000
        [power]
        Battery_cap = 2200
        Discharge_rate = 10
        [boot_extend]
        hold_key_min = -268435456
        hold_key_max = -268435456
        vol_threshold = 3500
        [modupdate]
        reset = 1
        [mbr]
        size = 1
        [part_num]
        num = 1
        [partition0]
        class_name = "000"
        name = "000"
        size_hi = 0
        size_lo = 3823
        [down_num]
        down_num = 1
        [download0]
        part_name = "000"
        pkt_name = "000000000"
        verify_file = "000000000"
        encrypt = 0
        这是fex文件,免得用万用表去量引脚了。
          memory LV 7 最后由 编辑
          card_line = 1
          bus_width = 1
          bus_width = 1
          hp_driver_need = 1
          浓缩了一下
            lovexulu LV 8 @memory 最后由 编辑
            @memory 有ep952的资料嘛?。。
            S 1 条回复 最后回复 回复 引用 分享 0
              memory LV 7 最后由 whycan 编辑
              手册: EP952-技术参数.pdf
              https://raw.githubusercontent.com/naobsd/sunxi-boards/nes-classic-edition/sys_config/a33/nintendo_nes_classic_edition.fex
              https://bitbucket.org/bakueikozo/workspace/snippets/RLz6ok
              https://github.com/linux-sunxi/sunxi-boards/blob/master/sys_config/a33/nintendo_nes_classic_clv001.fex
              应用原理图:EP952_应用原理图.pdf
              v0.5 datasheet:EP952(B)_DS_V05.pdf
              L G 2 条回复 最后回复 回复 引用 分享 0
                @memory 谢谢大佬!。。打算用这个芯片做个转换版
                  szwensn LV 3 @lovexulu 最后由 编辑
                  @lovexulu 膜拜呀,老大。
                  • G
                    godzhou0909 LV 6 @memory 最后由 编辑
                    @memory 老板,有EP952的驱动代码吗 ?
