    求问:V851SE Tinyvision 修改为SPI NAND flash 没有root登录
    167
      jaying LV 3 最后由 jaying 编辑
      U-Boot 2018.05-g3a34d5f-dirty (Jun 03 2025 - 05:56:56 -0400) Allwinner Technology
      [00.697]CPU:   Allwinner Family
      [00.700]Model: sun8iw21
      I2C:   [I2C-ERROR]:twi_send_clk_9pulse() 147 SDA is still Stuck Low, failed.
      ready
      [00.760]DRAM:  64 MiB
      [00.763]Relocation Offset is: 01eef000
      [00.792]secure enable bit: 0
      E/TC:0   tee_read_fdt:433 fine node /firmware/optee failed with FDT_ERR_NOTFOUND
      [00.806]smc_tee_inform_fdt failed with: ffff0000
      [I2C-ERROR]:twi_stop() 339 STOP can't sendout!
      [00.816]pmu_axp2101_probe pmic_bus_read fail
      [00.825]bmu_axp2101_probe pmic_bus_read fail
      [00.829]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz  MBus=300Mhz
      [00.835]gic: sec monitor mode
      sunxi flash map init
      [00.840]flash init start
      [00.842]workmode = 0,storage type = 2
      [00.845][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.851][mmc]: get sdc_type fail and use default host:tm4.
      [00.857][mmc]: get sdly from uboot header fail
      [00.862][mmc]: Is not EXT_PARA0_ID or EXT_PARA0_TUNING_SUCCESS_FLAG!
      [00.867][mmc]: SUNXI SDMMC Controller Version:0x50400
      [00.887][mmc]: card_caps:0x3000000a
      [00.890][mmc]: host_caps:0x7000003f
      [00.893][mmc]: read mmc 2 info ok
      [00.896]sunxi flash init ok
      [00.899]line:724 init_clocks
      [00.906]Loading Environment from SUNXI_FLASH... OK
      [00.933]Item0 (Map) magic is bad
      [00.936]the secure storage item0 copy0 magic is bad
      [00.945]Item0 (Map) magic is bad
      [00.948]the secure storage item0 copy1 magic is bad
      [00.953]Item0 (Map) magic is bad
      [00.956]out of usb burn from boot: not need burn key
      root_partition is rootfs
      set root to /dev/mmcblk0p4
      [00.965]update part info
      [00.968]update bootcmd
      [00.971]change working_fdt 0x42aaee70 to 0x42a8ee70
      [00.977][mmc]: no mmc-hs400-1_8v!
      [00.980][mmc]: no mmc-hs200-1_8v!
      [00.983][mmc]: no mmc-ddr-1_8v!
      disable nand error: FDT_ERR_BADPATH
      [00.993]The storage not support sample function
      [00.999]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      [01.004]update dts
      Hit any key to stop autoboot:  0
      input addr exceed dram scope
      [02.470]no vendor_boot partition is found
      Android's image name: sun8i_arm
      [02.530]Starting kernel ...
      [02.533][mmc]: mmc exit start
      [02.546][mmc]: mmc 2 exit ok
      [    0.000000] Booting Linux on physical CPU 0x0
      [    0.000000] Linux version 4.9.191 (book@100ask) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #31 PREEMPT Tue Jun 3 05:57:23 EDT 2025
      [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
      [    0.000000] CPU: div instructions available: patching division code
      [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
      [    0.000000] OF: fdt:Machine model: sun8iw21
      [    0.000000] ion_mem_reserve: err format for ion reserve list!
      [    0.000000] Memory policy: Data cache writeback
      [    0.000000] On node 0 totalpages: 16384
      [    0.000000] free_area_init_node: node 0, pgdat c0a40398, node_mem_map c3f78000
      [    0.000000]   Normal zone: 128 pages used for memmap
      [    0.000000]   Normal zone: 0 pages reserved
      [    0.000000]   Normal zone: 16384 pages, LIFO batch:3
      [    0.000000] psci: probing for conduit method from DT.
      [    0.000000] psci: PSCIv1.0 detected in firmware.
      [    0.000000] psci: Using standard PSCI v0.2 function IDs
      [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
      [    0.000000] psci: SMC Calling Convention v1.0
      [    0.000000] CPU: All CPU(s) started in SVC mode.
      [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
      [    0.000000] pcpu-alloc: [0] 0
      [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4 rootwait init=/init partitions=boot-res@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:rootfs@mmcblk0p4:rootfs_data@mmcblk0p5:UDISK@mmcblk0p6 cma= mac_addr= wifi_mac= bt_mac= selinux= specialstr= coherent_pool=16K ion_carveout_list= androidboot.mode=normal androidboot.hardware=sun8iw21p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.05-g3a34d5f-dirty(06/03/2025-05:56:56) mbr_offset=1032192 bootreason=button androidboot.dramsize=64
      [    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
      [    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
      [    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
      [    0.000000] Memory: 54796K/65536K available (6144K kernel code, 260K rwdata, 1340K rodata, 1024K init, 147K bss, 10740K reserved, 0K cma-reserved, 0K highmem)
      [    0.000000] Virtual kernel memory layout:
      [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
      [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
      [    0.000000]     vmalloc : 0xc4800000 - 0xff800000   ( 944 MB)
      [    0.000000]     lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
      [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
      [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      [    0.000000]       .text : 0xc0008000 - 0xc0700000   (7136 kB)
      [    0.000000]       .init : 0xc0900000 - 0xc0a00000   (1024 kB)
      [    0.000000]       .data : 0xc0a00000 - 0xc0a413b8   ( 261 kB)
      [    0.000000]        .bss : 0xc0a413b8 - 0xc0a66088   ( 148 kB)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
      [    0.000000] Preemptible hierarchical RCU implementation.
      [    0.000000]  Build-time adjustment of leaf fanout to 32.
      [    0.000000] NR_IRQS:16 nr_irqs:16 16
      [    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys).
      [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
      [    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.000020] Switching to timer-based delay loop, resolution 41ns
      [    0.000203] Console: colour dummy device 80x30
      [    0.000232] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.000246] pid_max: default: 32768 minimum: 301
      [    0.000446] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.000459] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.001029] CPU: Testing write buffer coherency: ok
      [    0.001661] Setting up static identity map for 0x40100000 - 0x40100058
      [    0.003392] devtmpfs: initialized
      [    0.035097] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.035676] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.035708] futex hash table entries: 256 (order: -1, 3072 bytes)
      [    0.035857] atomic64_test: passed
      [    0.035870] pinctrl core: initialized pinctrl subsystem
      [    0.037054] NET: Registered protocol family 16
      [    0.037642] DMA: preallocated 16 KiB pool for atomic coherent allocations
      [    0.039006] dump_class_init,857, success
      [    0.069586] cpuidle: using governor menu
      [    0.070915] platform 2010000.iommu: iova_base: 0x48400000
      [    0.071465] sunxi iommu: irq = 22
      [    0.092126] sun8iw21p1-pinctrl pio: initialized sunXi PIO driver
      [    0.095156] iommu: Adding device npu to group 0
      [    0.097213] iommu: Adding device 1c0e000.ve to group 0
      [    0.108438] iommu: Adding device 5410000.g2d to group 0
      [    0.109272] iommu: Adding device 5000000.disp to group 0
      [    0.120440] iommu: Adding device 5908000.tdm to group 0
      [    0.121209] iommu: Adding device 5900000.isp to group 0
      [    0.122160] iommu: Adding device 58ffffc.isp to group 0
      [    0.123085] iommu: Adding device 58ffff8.isp to group 0
      [    0.123823] iommu: Adding device 58ffff4.isp to group 0
      [    0.124459] iommu: Adding device 5800800.vind:isp@4 to group 0
      [    0.125178] iommu: Adding device 5910000.scaler to group 0
      [    0.125893] iommu: Adding device 590fffc.scaler to group 0
      [    0.126394] iommu: Adding device 590fff8.scaler to group 0
      [    0.127019] iommu: Adding device 590fff4.scaler to group 0
      [    0.127873] iommu: Adding device 5910400.scaler to group 0
      [    0.128642] iommu: Adding device 59103fc.scaler to group 0
      [    0.129118] iommu: Adding device 59103f8.scaler to group 0
      [    0.130095] iommu: Adding device 59103f4.scaler to group 0
      [    0.130871] iommu: Adding device 5910800.scaler to group 0
      [    0.131584] iommu: Adding device 59107fc.scaler to group 0
      [    0.132073] iommu: Adding device 59107f8.scaler to group 0
      [    0.132665] iommu: Adding device 59107f4.scaler to group 0
      [    0.133530] iommu: Adding device 5910c00.scaler to group 0
      [    0.134244] iommu: Adding device 5910bfc.scaler to group 0
      [    0.134861] iommu: Adding device 5910bf8.scaler to group 0
      [    0.135514] iommu: Adding device 5910bf4.scaler to group 0
      [    0.136718] iommu: Adding device vinc0 to group 0
      [    0.137591] iommu: Adding device vinc4 to group 0
      [    0.138556] iommu: Adding device vinc8 to group 0
      [    0.139482] iommu: Adding device vinc12 to group 0
      [    0.184635] pwm module init!
      [    0.189315] sunxi-pm debug v3.10
      [    0.193630] SCSI subsystem initialized
      [    0.194488] usbcore: registered new interface driver usbfs
      [    0.194690] usbcore: registered new interface driver hub
      [    0.194863] usbcore: registered new device driver usb
      [    0.195182] sunxi_i2c_adap_init()2754 - init
      [    0.195410] sun8iw21p1-pinctrl pio: expect_func as:twi6, but muxsel(4) is func:twi3
      [    0.195428] sun8iw21p1-pinctrl pio: expect_func as:twi6, but muxsel(4) is func:twi3
      [    0.195742] sunxi_i2c_probe()2449 - [i2c3] twi_drv_used = 0
      [    0.195759] sunxi_i2c_probe()2456 - [i2c3] twi_pkt_interval = 0
      [    0.195826] twi_regulator_request()653 - [i2c3] regulator not found(isn't configured in dts)!
      [    0.195837] twi_request_gpio()469 - [i2c3] init name: (null)
      [    0.197313] media: Linux media interface: v0.10
      [    0.197531] Linux video capture interface: v2.00
      [    0.200849] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
      [    0.201218] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
      [    0.202611] Advanced Linux Sound Architecture Driver Initialized.
      [    0.203599] Bluetooth: Core ver 2.22
      [    0.203790] NET: Registered protocol family 31
      [    0.203802] Bluetooth: HCI device and connection manager initialized
      [    0.203827] Bluetooth: HCI socket layer initialized
      [    0.203842] Bluetooth: L2CAP socket layer initialized
      [    0.203909] Bluetooth: SCO socket layer initialized
      [    0.206993] G2D: rcq version initialized.major:251
      [    0.208403] clocksource: Switched to clocksource arch_sys_counter
      [    0.240313] udc_init,0
      [    0.242884] NET: Registered protocol family 2
      [    0.258795] TCP established hash table entries: 16 (order: -6, 64 bytes)
      [    0.258818] TCP bind hash table entries: 16 (order: -6, 64 bytes)
      [    0.258829] TCP: Hash tables configured (established 16 bind 16)
      [    0.258906] UDP hash table entries: 256 (order: 0, 4096 bytes)
      [    0.258926] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
      [    0.259171] NET: Registered protocol family 1
      [    0.263247] workingset: timestamp_bits=29 max_order=14 bucket_order=0
      [    0.280513] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.281133] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
      [    0.283455] io scheduler noop registered
      [    0.283474] io scheduler deadline registered
      [    0.283757] io scheduler cfq registered (default)
      [    0.287769] uart0 supply uart not found, using dummy regulator
      [    0.288036] uart0: ttyS0 at MMIO 0x2500000 (irq = 289, base_baud = 1500000) is a SUNXI
      [    0.288071] sw_console_setup()2050 - console setup baud 115200 parity n bits 8, flow n
      [    1.226318] console [ttyS0] enabled
      [    1.231686] misc dump reg init
      [    1.235851] npu[1][1] vipcore, platform driver device=0xc39d4010
      [    1.242917] npu[1][1] vipcore irq number is 290.
      [    1.248066] gckvip_drv_adjust_param 232 SUCCESS
      [    1.253248] the freq of pll_npux4 clk is fixed
      [    1.258208] Want set pclk rate(348000000) support(1392000000) real(1392000000)
      [    1.266409] Want set mclk rate(348000000) support(348000000) real(348000000)
      [    1.274363] npu[1][1] This device support 64bits DMA
      [    1.280485] npu[1][1] core_0, request irqline=290, name=vipcore_0
      [    1.287357] npu[1][1] =======vipcore parameter=====
      [    1.293032] npu[1][1] registerMemBase     0x03050000,
      [    1.298830] npu[1][1] registerMemSize     0x00020000,
      [    1.304556] npu[1][1] irqLine             0x00000122,
      [    1.310322] npu[1][1] contiguousSize      0x02000000
      [    1.315853] npu[1][1] contiguousBase      0x30000000
      [    1.321462] npu[1][1] vipContiguousBase   0x0
      [    1.326317] npu[1][1] drvType             0x00000000
      [    1.331882] npu[1][1] AXISramSize         0x00000000
      [    1.337415] npu[1][1] AXISramBaseAddress  0x00000000
      [    1.342974] npu[1][1] VIPSramSize         0x00020000
      [    1.348519] npu[1][1] VIPSramBaseAddress  0x00400000
      [    1.354052] npu[1][1] sysHeapSize         0x00200000
      [    1.359593] npu[1][1] ===============================
      [    1.365312] npu[1][1] VIPLite driver version 1.8.0.0-AW-2022-04-21
      [    1.374964] libphy: Fixed MDIO Bus: probed
      [    1.381227] sunxi gmac driver's version: 2.0.2
      [    1.388669] Failed to alloc md5
      [    1.392190] eth0: Use random mac address
      [    1.397127] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.404919] get ehci0-controller, regulator_io is no nocare
      [    1.411417] get ehci0-controller wakeup-source is fail.
      [    1.417438] sunxi ehci0-controller don't init wakeup source
      [    1.423750] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0a5a388, 0x:c4834000, irq_no:12f
      [    1.435831] [sunxi-ehci0]: Not init ehci0
      [    1.440786] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    1.448097] get ohci0-controller, regulator_io is no nocare
      [    1.454525] get ohci0-controller wakeup-source is fail.
      [    1.460605] sunxi ohci0-controller don't init wakeup source
      [    1.466915] [sunxi-ohci0]: probe, pdev->name: 4101000.ohci0-controller, sunxi_ohci: 0xc0a5a5ac
      [    1.476592] [sunxi-ohci0]: Not init ohci0
      [    1.481785] usbcore: registered new interface driver uas
      [    1.488144] usbcore: registered new interface driver usb-storage
      [    1.495139] usbcore: registered new interface driver ums-alauda
      [    1.502096] usbcore: registered new interface driver ums-cypress
      [    1.509220] usbcore: registered new interface driver ums-datafab
      [    1.516203] usbcore: registered new interface driver ums_eneub6250
      [    1.523408] usbcore: registered new interface driver ums-freecom
      [    1.530451] usbcore: registered new interface driver ums-isd200
      [    1.537373] usbcore: registered new interface driver ums-jumpshot
      [    1.544510] usbcore: registered new interface driver ums-karma
      [    1.551429] usbcore: registered new interface driver ums-onetouch
      [    1.558629] usbcore: registered new interface driver ums-realtek
      [    1.565511] usbcore: registered new interface driver ums-sddr09
      [    1.572461] usbcore: registered new interface driver ums-sddr55
      [    1.579420] usbcore: registered new interface driver ums-usbat
      [    1.586043] usb_serial_number:20080411
      [    1.591366] sunxi_gpadc_init,1949, success
      [    1.596359] sunxi_gpadc_setup: get channel scan data failed
      [    1.604224] input: sunxi-gpadc0 as /devices/virtual/input/input0
      [    1.613534] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
      [    1.620797] sunxi-rtc rtc: RTC enabled
      [    1.625058] fix to cold boot, save boot reason
      [    1.630576] i2c /dev entries driver
      [    1.635222] sunxi cedar version 0.1
      [    1.639562] VE: install start!!!
      [    1.639562]
      [    1.644999] VE: cedar-ve the get irq is 291
      [    1.649941] VE: regs_csi = c486d000
      [    1.654514] VE: ve_debug_proc_info:c0a5db3c, data:c3ba4000, lock:c0a5dbc4, flag: 1
      [    1.654514]
      [    1.664925] VE: install end!!!
      [    1.664925]
      [    1.670517] google_vp9: sunxi google vp9 version 0.1
      [    1.679105] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    1.689022] Bluetooth: HCI UART driver ver 2.2.d448471.20181218-163903
      [    1.696329] Bluetooth: HCI UART protocol H4 registered
      [    1.702337] Bluetooth: HCI H4 protocol initialized
      [    1.707951] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.07
      [    1.715777] bt_fdi debugfs_init
      [    1.721446] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 900000 KHz
      [    1.758502] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 912000 KHz
      [    1.768874] cpuidle: enable-method property 'psci' found operations
      [    1.778685] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
      [    1.787661] sunxi-mmc sdc2: ***ctl-spec-caps*** 8
      [    1.793292] sunxi-mmc sdc2: No vmmc regulator found
      [    1.798907] sunxi-mmc sdc2: No vqmmc regulator found
      [    1.804473] sunxi-mmc sdc2: No vdmmc regulator found
      [    1.810111] sunxi-mmc sdc2: No vd33sw regulator found
      [    1.815772] sunxi-mmc sdc2: No vd18sw regulator found
      [    1.821467] sunxi-mmc sdc2: No vq33sw regulator found
      [    1.827125] sunxi-mmc sdc2: No vq18sw regulator found
      [    1.833403] sunxi-mmc sdc2: set host busy
      [    1.837983] mmc:failed to get gpios
      [    1.842336] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.852820] sunxi-mmc sdc2: no vqmmc,Check if there is regulator
      [    1.888436] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.928448] sunxi-mmc sdc2: detmode:alway in(non removable)
      [    1.928481] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.936851] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.937929] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.948747] sunxi-mmc sdc2: smc 0 p2 err, cmd 1, RTO !!
      [    1.948812] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    1.949919] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.950004] sunxi-mmc sdc2: no vqmmc,Check if there is regulator
      [    1.987784] sunxi-mmc sdc2: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.015796] sunxi-mmc sdc2: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.028721] sunxi-mmc sdc2: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.029825] sunxi-mmc sdc2: sdc set ios:clk 300000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.040641] sunxi-mmc sdc2: smc 0 p2 err, cmd 1, RTO !!
      [    2.040674] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.041787] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.041878] sunxi-mmc sdc2: no vqmmc,Check if there is regulator
      [    2.068791] sunxi-mmc sdc2: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.097335] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
      [    2.106211] sunxi-mmc sdc2: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.119158] sunxi-mmc sdc2: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.120271] sunxi-mmc sdc2: sdc set ios:clk 200000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.131104] sunxi-mmc sdc2: smc 0 p2 err, cmd 1, RTO !!
      [    2.131139] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.132249] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.132356] sunxi-mmc sdc2: no vqmmc,Check if there is regulator
      [    2.159261] sunxi-mmc sdc2: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.187310] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
      [    2.192645] sunxi-mmc sdc2: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.205670] sunxi-mmc sdc2: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.206826] sunxi-mmc sdc2: sdc set ios:clk 100000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.217737] sunxi-mmc sdc2: smc 0 p2 err, cmd 1, RTO !!
      [    2.217773] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.245778] sunxi-mmc sdc0: No vmmc regulator found
      [    2.251324] sunxi-mmc sdc0: No vqmmc regulator found
      [    2.256885] sunxi-mmc sdc0: No vdmmc regulator found
      [    2.262467] sunxi-mmc sdc0: No vd33sw regulator found
      [    2.268122] sunxi-mmc sdc0: No vd18sw regulator found
      [    2.273790] sunxi-mmc sdc0: No vq33sw regulator found
      [    2.279457] sunxi-mmc sdc0: No vq18sw regulator found
      [    2.285701] sunxi-mmc sdc0: set host busy
      [    2.290365] sunxi-mmc sdc0: Got CD GPIO
      [    2.295197] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.348764] random: fast init done
      [    2.548523] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
      [    2.578425] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.618669] sunxi-mmc sdc0: detmode:gpio irq
      [    2.625012] usbcore: registered new interface driver usbhid
      [    2.631622] usbhid: USB HID core driver
      [    2.640180] sun8iw21p1-pinctrl pio: expect_func as:dmic, but muxsel(7) is func:i2s1
      [    2.649559] sun8iw21p1-pinctrl pio: expect_func as:dmic, but muxsel(7) is func:i2s1
      [    2.658160] sun8iw21p1-pinctrl pio: expect_func as:dmic, but muxsel(7) is func:i2s1
      [    2.666919] sun8iw21p1-pinctrl pio: expect_func as:dmic, but muxsel(7) is func:i2s1
      [    2.675640] sun8iw21p1-pinctrl pio: expect_func as:dmic, but muxsel(7) is func:i2s1
      [    2.684875] [sound  676][DMIC snd_sunxi_dts_params_init] rx-fifo-size miss,using default value
      [    2.695622] sun8iw21p1-pinctrl pio: pin PE7 already requested by 2031000.dmic_plat; cannot claim for 2033000.daudio1_plat
      [    2.708238] sun8iw21p1-pinctrl pio: pin-135 (2033000.daudio1_plat) status -22
      [    2.716320] sun8iw21p1-pinctrl pio: could not request pin 135 (PE7) from group PE7  on device pio
      [    2.726304] sunxi-snd-plat-daudio 2033000.daudio1_plat: Error applying setting, reverse things back
      [    2.736527] sunxi-snd-plat-daudio: probe of 2033000.daudio1_plat failed with error -22
      [    2.746769] sunxi-snd-mach soc@03000000:dmic_mach: snd-soc-dummy-dai <-> 2031000.dmic_plat mapping ok
      [    2.761544] NET: Registered protocol family 10
      [    2.768674] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [    2.776738] NET: Registered protocol family 17
      [    2.782053] NET: Registered protocol family 15
      [    2.787166] Bluetooth: RFCOMM TTY layer initialized
      [    2.792939] Bluetooth: RFCOMM socket layer initialized
      [    2.798901] Bluetooth: RFCOMM ver 1.11
      [    2.804358] Registering SWP/SWPB emulation handler
      [    2.819414] get det_vbus is fail, 84
      [    2.823447] get id is fail, 84
      [    2.828120] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:05 UTC (5)
      [    2.836330] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.848151] clk: Not disabling unused clocks
      [    2.853176] ALSA device list:
      [    2.856510]   #0: snddmic
      [    2.859887] Waiting for root device /dev/mmcblk0p4...
      [    3.848418]
      [    3.848418] insmod_device_driver
      [    3.848418]
      [    3.855941] device_chose finished 122!
      [   15.370906] random: crng init done```
        jasonzhang LV 5 @jaying 最后由 编辑
        @jaying 在 求问:V851SE Tinyvision 修改为SPI NAND flash 没有root登录 中说:
        Kernel command line:"root=/dev/mmcblk0p4 rootwait init=/init partitions=boot-res@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:rootfs@mmcblk0p4:rootfs_data@mmcblk0p5:UDISK@mmcblk0p6"
        问题出在上面,bootargs指向的地址还是rootfs根目录还是emmc地址,而你硬件不存在mmcblk0p4,导致一直在等待;需要改成nand对应的文件系统。
        你可以在u-boot直接修改bootcmd,将其中的setargs_mmc替换为setargs_nand,sync后重启。如果是SDK里,就修改你选择的板级下的env.cfg文件(不确定具体目录,自己找下,在device目录下),再进行测试。
        J 2 条回复 最后回复 回复 引用 分享 0
          jaying LV 3 @jasonzhang 最后由 jaying 编辑
          @jasonzhang
          #kernel command arguments
          initcall_debug=0
          nand_root=ubi0_4
          mmc_root=/dev/mmcblk0p4
          nor_root=/dev/mtdblock1
          init=/init
          loglevel=8
          coherent_pool=16K
          #reserve_list=30M@64M,78M@128M,200M@512M
          mac=
          wifi_mac=
          bt_mac=
          specialstr=
          root_partition=rootfs
          mtd_name=sys
          rootfstype=ubifs, rw
          #set kernel cmdline if boot.img or recovery.img has no cmdline we will use this
          setargs_nor=setenv bootargs  earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nor_root} rootwait init=${init} rdinit=${rdinit} partitions=${partitions} cma=${cma} coherent_pool=${coherent_pool} ion_carveout_list=${reserve_list}
          setargs_nand=setenv bootargs earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel}  ubi.mtd=${mtd_name} root=${nand_root} rootfstype=${rootfstype} rootwait init=${init} rdinit=${rdinit} partitions=${partitions} cma=${cma} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} selinux=${selinux} specialstr=${specialstr} coherent_pool=${coherent_pool} ion_carveout_list=${reserve_list}
          setargs_nand_ubi=setenv bootargs ubi.mtd=${mtd_name} earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
          setargs_mmc=setenv  bootargs earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${mmc_root}  rootwait init=${init} partitions=${partitions} cma=${cma} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} selinux=${selinux} specialstr=${specialstr} coherent_pool=${coherent_pool} ion_carveout_list=${reserve_list}
          #nand command syntax: sunxi_flash read address partition_name read_bytes
          #0x4007f800 = 0x40080000(kernel entry) - 0x800(boot.img header 2k)
          boot_partition=boot
          boot_normal=sunxi_flash read 44800000 ${boot_partition};bootm 44800000
          boot_recovery=sunxi_flash read 44800000 extend;bootm 44800000
          boot_fastboot=fastboot
          #recovery key
          recovery_key_value_max=0x13
          recovery_key_value_min=0x10
          #fastboot key
          fastboot_key_value_max=0x8
          fastboot_key_value_min=0x2
          #uboot system env config
          bootdelay=1
          #default bootcmd, will change at runtime according to key press
          bootcmd=run setargs_nand boot_normal#default nand boot
          #verify the kernel
          verify=N看起来好像也是setargs_nand
            jaying LV 3 @jasonzhang 最后由 编辑
            @jasonzhang 启动时进进入 U-Boot 命令行打印出来的不对(还是mmc),感谢大佬
              1.设备树中的 SDC2 节点修改如下:
              &sdc2 {
                  non-removable;
                  bus-width = <4>;
                  mmc-ddr-3_3v;
                  /*mmc-hs200-1_8v;*/
                  /*mmc-hs400-1_8v;*/
                  no-sdio;
                  /delete-property/ no-sd;
                  no-mmc;
                  ctl-spec-caps = <0x8>;
                  cap-mmc-highspeed;
                  sunxi-signal-vol-sw-without-pmu;
                  sunxi-power-save-mode;
                  /*sunxi-dis-signal-vol-sw;*/
                  max-frequency = <50000000>;
                  /*vmmc-supply = <&reg_dcdc1>;*/
                  /*emmc io vol 3.3v*/
                  /*vqmmc-supply = <&reg_aldo1>;*/
                  /*emmc io vol 1.8v*/
                  /*vqmmc-supply = <&reg_eldo1>;*/
                  status = "okay";
              2.前往文件夹 brandy/brandy-2.0/u-boot-2018/drivers/sunxi_flash/mmc/sdmmc.c
              将return sdmmc_init_for_sprite(0, 0); 修改为return sdmmc_init_for_sprite(0, 2);
              3.配置ubifs等等 即可
                awwwwa LV 8 最后由 编辑
                Tinyvision 怎么修改 SPINAND的?飞线么,默认焊盘不支持挂nand的
