    麻雀D1s ,编译了新的Tina_d1_open_v2,选择了D1S,用TF卡烧录,启动时候卡住了,挂载不了文件系统,各位大神帮忙看下
    5315
      daMing123 LV 6 最后由 YuzukiTsuru 编辑
      [170]HELLO! BOOT0 is starting!
      [173]BOOT0 commit : 88480af
      [175]set pll start
      [177]fix vccio detect value:0xc0
      [180]periph0 has been enabled
      [183]set pll end
      [185][pmu]: bus read error
      [188]board init ok
      [189]ZQ value = 0x30
      [191]get_pmu_exist() = -1
      [194]ddr_efuse_type: 0xa
      [196]trefi:7.8ms
      [198][AUTO DEBUG] single rank and full DQ!
      [202]ddr_efuse_type: 0xa
      [205]trefi:7.8ms
      [207][AUTO DEBUG] rank 0 row = 13
      [210][AUTO DEBUG] rank 0 bank = 4
      [213][AUTO DEBUG] rank 0 page size = 2 KB
      [217]DRAM BOOT DRIVE INFO: V0.33
      [220]DRAM CLK = 528 MHz
      [222]DRAM Type = 2 (2:DDR2,3:DDR3)
      [225]DRAMC read ODT  off.
      [228]DRAM ODT off.
      [230]ddr_efuse_type: 0xa
      [233]DRAM SIZE =64 M
      [234]dram_tpr4:0x0
      [236]PLL_DDR_CTRL_REG:0xf8002b00
      [239]DRAM_CLK_REG:0xc0000000
      [242][TIMING DEBUG] MR2= 0x0
      [246]DRAM simple test OK.
      [249]dram size =64
      [250]card no is 0
      [252]sdcard 0 line count 4
      [255][mmc]: mmc driver ver 2021-04-2 16:45
      [264][mmc]: Wrong media type 0x0
      [267][mmc]: ***Try SD card 0***
      [277][mmc]: HSSDR52/SDR25 4 bit
      [280][mmc]: 50000000 Hz
      [282][mmc]: 7681 MB
      [284][mmc]: ***SD/MMC 0 init OK!!!***
      [335]Loading boot-pkg Succeed(index=0).
      [338]Entry_name        = opensbi
      [341]Entry_name        = u-boot
      [345]Entry_name        = dtb
      [348]mmc not para
      U-Boot 2018.05-g24521d6-dirty-config-dirty (Mar 30 2022 - 15:25:54 +0800) Allwinner Technology
      [00.361]DRAM:  64 MiB
      [00.363]Relocation Offset is: 01eed000
      [00.367]secure enable bit: 0
      [00.370]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.377]flash init start
      [00.379]workmode = 0,storage type = 1
      [00.382][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
      [00.388][mmc]: get sdc_type fail and use default host:tm1.
      [00.394][mmc]: can't find node "mmc0",will add new node
      [00.399][mmc]: fdt err returned <no error>
      [00.403][mmc]: Using default timing para
      [00.407][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.425][mmc]: card_caps:0x3000000a
      [00.428][mmc]: host_caps:0x3000003f
      [00.433]sunxi flash init ok
      [00.435]line:703 init_clocks
      [00.438]drv_disp_init
      [00.459]drv_disp_init finish
      [00.461]boot_gui_init:start
      [00.465]set disp.dev2_output_type fail. using defval=0
      [00.471]boot_gui_init:finish
      54 bytes read in 2 ms (26.4 KiB/s)
      [00.510]bmp_name=bootlogo.bmp size 38454
      38454 bytes read in 5 ms (7.3 MiB/s)
      [00.551]Loading Environment from SUNXI_FLASH... OK
      [00.575]out of usb burn from boot: not need burn key
      [00.610]Item0 (Map) magic is bad
      [00.613]the secure storage item0 copy0 magic is bad
      [00.648]Item0 (Map) magic is bad
      [00.[00.653]LCD open finish
      651]the secure storage item0 copy1 magic is bad
      [00.659]Item0 (Map) magic is bad
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.675]update part info
      [00.680]update bootcmd
      [00.685]change working_fdt 0x42aacda0 to 0x42a8cda0
      [00.725]update dts
      noncached_alloc(): addr = 0x42c90080
      noncached_alloc(): addr = 0x42c900c0
      noncached_alloc(): addr = 0x42c90100
      noncached_alloc(): addr = 0x42c90940
      geth_sys_init fail!
      [00.745]Board Net Initialization Failed
      [00.749]No ethernet found.
      [02.075]no vendor_boot partition is found
      Android's image name: d1s-nezha
      Detect comp none
      [02.092]
      Starting kernel ...
      [02.095][mmc]: MMC Device 2 not found
      [02.099][mmc]: mmc 2 not find, so not exit
      Linux version 5.4.61 (kim@kimpc) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #15 PREEMPT Wed Mar 30 07:41:58 UTC 2022
      Zone ranges:
        DMA32    [mem 0x0000000040000000-0x0000000043ffffff]
        Normal   empty
      Movable zone start for each node
      Early memory node ranges
        node   0: [mem 0x0000000040000000-0x0000000043ffffff]
      On node 0 totalpages: 16384
        DMA32 zone: 0 pages reserved
      elf_hwcap is 0x20112d
      pcpu-alloc: [0] 0
      Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 init=/pseudo_init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:recovery@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g24521d6-dirty-config-dirty(03/30/
      Sorting __ex_table...
      Memory: 55284K/65536K available (4654K kernel code, 402K rwdata, 1776K rodata, 144K init, 231K bss, 10252K reserved, 0K cma-reserved)
      SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
      rcu: Preemptible hierarchical RCU implementation.
              Tasks RCU enabled.
      rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      devtmpfs: initialized
      random: get_random_u32 called from bucket_table_alloc.isra.27+0x10a/0x12c with crng_init=0
      clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      NET: Registered protocol family 16
      cpuidle: using governor menu
      rtc_ccu: sunxi ccu init OK
      clock: sunxi ccu init OK
      sunxi iommu: irq = 4
      SCSI subsystem initialized
      videodev: Linux video capture interface: v2.00
      Advanced Linux Sound Architecture Driver Initialized.
      pwm module init!
      G2D: rcq version initialized.major:252
      sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      NET: Registered protocol family 2
      tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
      TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
      TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
      TCP: Hash tables configured (established 512 bind 512)
      UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
      sunxi_spi_resource_get()2189 - Failed to get sample mode
      sunxi_spi_resource_get()2194 - Failed to get sample delay
      sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
      sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
      sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base ffffffd004058000, irq 31
      jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
      io scheduler kyber registered
      [DISP]disp_module_init
      [DISP] parser_disp_init_para,line:1430:
      of_property_read fb0_width fail
      [DISP] disp_init,line:2386:
      display_fb_request,fb_id:0
      Freeing logo buffer memory: 1500K
      sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [DISP]disp_module_init finish
      sunxi_sid_init()551 - insmod ok
      uart uart0: get regulator failed
      uart uart0: uart0 supply uart not found, using dummy regulator
      uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
      sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
      printk: console [ttyS0] enabled
      misc dump reg init
      sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=131 assert=1
      sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
      sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
      sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
      sunxi-spinand-phy: not detect any munufacture from id table
      sunxi-spinand-phy: get spi-nand Model from fdt fail
      sunxi-spinand-phy: get phy info from fdt fail
      sunxi-spinand-phy: not detect munufacture from fdt
      sunxi-spinand-phy: detect munufacture from id table: Winbond
      sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
      sunxi-spinand-phy: ========== arch info ==========
      sunxi-spinand-phy: Model:               W25N01GVZEIG
      sunxi-spinand-phy: Munufacture:         Winbond
      sunxi-spinand-phy: DieCntPerChip:       1
      sunxi-spinand-phy: BlkCntPerDie:        1024
      sunxi-spinand-phy: PageCntPerBlk:       64
      sunxi-spinand-phy: SectCntPerPage:      4
      sunxi-spinand-phy: OobSizePerPage:      64
      sunxi-spinand-phy: BadBlockFlag:        0x0
      sunxi-spinand-phy: OperationOpt:        0x7
      sunxi-spinand-phy: MaxEraseTimes:       65000
      sunxi-spinand-phy: EccFlag:             0x0
      sunxi-spinand-phy: EccType:             2
      sunxi-spinand-phy: EccProtectedType:    3
      sunxi-spinand-phy: ========================================
      sunxi-spinand-phy:
      sunxi-spinand-phy: ========== physical info ==========
      sunxi-spinand-phy: TotalSize:    128 M
      sunxi-spinand-phy: SectorSize:   512 B
      sunxi-spinand-phy: PageSize:     2 K
      sunxi-spinand-phy: BlockSize:    128 K
      sunxi-spinand-phy: OOBSize:      64 B
      sunxi-spinand-phy:
      sunxi-spinand-phy: ========== logical info ==========
      sunxi-spinand-phy: PageSize:     4 K
      sunxi-spinand-phy: BlockSize:    256 K
      sunxi-spinand-phy: OOBSize:      128 B
      sunxi-spinand-phy: W25N01GVZEIG reset rx bit width to 1
      sunxi-spinand-phy: W25N01GVZEIG reset tx bit width to 1
      sunxi-spinand-phy: block lock register: 0x00
      sunxi-spinand-phy: feature register: 0x19
      sunxi-spinand-phy: sunxi physic nand init end
      Creating 4 MTD partitions on "sunxi_mtd_nand":
      0x000000000000-0x000000100000 : "boot0"
      0x000000100000-0x000000500000 : "uboot"
      random: fast init done
      0x000000500000-0x000000600000 : "secure_storage"
      0x000000600000-0x000008000000 : "sys"
      sunxi-spinand-phy: phy blk 477 is bad
      sunxi-spinand-phy: phy blk 478 is bad
      sunxi-spinand-phy: phy blk 480 is bad
      sunxi-spinand-phy: phy blk 482 is bad
      sunxi-spinand-phy: phy blk 484 is bad
      sunxi-spinand-phy: phy blk 486 is bad
      sunxi-spinand-phy: phy blk 488 is bad
      sunxi-spinand-phy: phy blk 490 is bad
      sunxi-spinand-phy: phy blk 492 is bad
      sunxi-spinand-phy: phy blk 494 is bad
      sunxi-spinand-phy: phy blk 496 is bad
      sunxi-spinand-phy: ecc error 0x2
      sunxi-spinand-phy: phy blk 580 is bad
      sunxi-spinand-phy: phy blk 582 is bad
      sunxi-spinand-phy: phy blk 584 is bad
      sunxi-spinand-phy: phy blk 586 is bad
      sunxi-spinand-phy: phy blk 588 is bad
      sunxi-spinand-phy: phy blk 590 is bad
      sunxi-spinand-phy: phy blk 593 is bad
      sunxi-spinand-phy: phy blk 594 is bad
      sunxi-spinand-phy: phy blk 596 is bad
      sunxi-spinand-phy: phy blk 598 is bad
      sunxi-spinand-phy: phy blk 602 is bad
      sunxi-spinand-phy: phy blk 605 is bad
      sunxi-spinand-phy: phy blk 606 is bad
      sunxi-spinand-phy: phy blk 608 is bad
      sunxi-spinand-phy: phy blk 610 is bad
      sunxi-spinand-phy: phy blk 614 is bad
      sunxi-spinand-phy: phy blk 616 is bad
      sunxi-spinand-phy: phy blk 618 is bad
      sunxi-spinand-phy: phy blk 620 is bad
      sunxi-spinand-phy: phy blk 623 is bad
      sunxi-spinand-phy: phy blk 625 is bad
      sunxi-spinand-phy: phy blk 626 is bad
      sunxi-spinand-phy: phy blk 629 is bad
      sunxi-spinand-phy: phy blk 630 is bad
      sunxi-spinand-phy: phy blk 632 is bad
      sunxi-spinand-phy: phy blk 634 is bad
      sunxi-spinand-phy: phy blk 636 is bad
      sunxi-spinand-phy: phy blk 639 is bad
      sunxi-spinand-phy: phy blk 641 is bad
      sunxi-spinand-phy: phy blk 642 is bad
      sunxi-spinand-phy: phy blk 644 is bad
      sunxi-spinand-phy: phy blk 647 is bad
      sunxi-spinand-phy: phy blk 649 is bad
      sunxi-spinand-phy: phy blk 650 is bad
      sunxi-spinand-phy: phy blk 652 is bad
      sunxi-spinand-phy: phy blk 654 is bad
      sunxi-spinand-phy: phy blk 658 is bad
      sunxi-spinand-phy: phy blk 661 is bad
      sunxi-spinand-phy: phy blk 669 is bad
      sunxi-spinand-phy: phy blk 670 is bad
      sunxi-spinand-phy: phy blk 672 is bad
      sunxi-spinand-phy: phy blk 674 is bad
      sunxi-spinand-phy: phy blk 681 is bad
      sunxi-spinand-phy: phy blk 682 is bad
      sunxi-spinand-phy: phy blk 688 is bad
      sunxi-spinand-phy: phy blk 692 is bad
      sunxi-spinand-phy: phy blk 695 is bad
      sunxi-spinand-phy: phy blk 696 is bad
      sunxi-spinand-phy: phy blk 698 is bad
      sunxi-spinand-phy: phy blk 700 is bad
      sunxi-spinand-phy: phy blk 702 is bad
      sunxi-spinand-phy: phy blk 704 is bad
      sunxi-spinand-phy: phy blk 709 is bad
      sunxi-spinand-phy: phy blk 713 is bad
      sunxi-spinand-phy: phy blk 714 is bad
      sunxi-spinand-phy: phy blk 719 is bad
      sunxi-spinand-phy: phy blk 721 is bad
      sunxi-spinand-phy: phy blk 723 is bad
      sunxi-spinand-phy: phy blk 725 is bad
      sunxi-spinand-phy: phy blk 726 is bad
      sunxi-spinand-phy: phy blk 730 is bad
      sunxi-spinand-phy: phy blk 732 is bad
      sunxi-spinand-phy: phy blk 734 is bad
      sunxi-spinand-phy: phy blk 737 is bad
      sunxi-spinand-phy: phy blk 738 is bad
      sunxi-ehci: EHCI SUNXI driver
      [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe0006face8, 0x:ffffffd00406f000, irq_no:31
      hub 1-0:1.0: USB hub found
      hub 1-0:1.0: 1 port detected
      sunxi-ohci: OHCI SUNXI driver
      [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe0006fb0b0
      hub 2-0:1.0: USB hub found
      hub 2-0:1.0: 1 port detected
      sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
      sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:03 UTC (3)
      i2c /dev entries driver
      uvcvideo: Unable to create debugfs directory
      usbcore: registered new interface driver uvcvideo
      USB Video Class driver (1.1.1)
      sunxi cedar version 1.1
      VE: install start!!!
      VE: cedar-ve the get irq is 6
      VE: install end!!!
      VE: sunxi_cedar_probe
      sun8iw20-pinctrl 2000000.pinctrl: pin PF2 already requested by 2500000.uart; cannot claim for 4020000.sdmmc
      sun8iw20-pinctrl 2000000.pinctrl: pin-162 (4020000.sdmmc) status -22
      sun8iw20-pinctrl 2000000.pinctrl: could not request pin 162 (PF2) from group PF2  on device 2000000.pinctrl
      sunxi-mmc 4020000.sdmmc: Error applying setting, reverse things back
      sunxi-mmc: probe of 4020000.sdmmc failed with error -22
      sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      ashmem: initialized
      exFAT: Version 1.3.0
      [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
      sid_rd_ver_reg()254 - ver >= 4, soc ver:5
      input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      Segment Routing with IPv6
      sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
      sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      sunxi-i2c sunxi-i2c2: probe success
      mmc0: new high speed SDIO card at address 0001
      [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe0006fa558, 0x:ffffffd0040fe000, irq_no:2e
      [sunxi-ehci0]: Not init ehci0
      [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe0006fa920
      [sunxi-ohci0]: Not init ohci0
      ALSA device list:
        #0: audiocodec
      alloc_fd: slot 0 not NULL!
      VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
      Please append a correct "root=" boot option; here are the available partitions:
      1f00            1024 mtdblock0
       (driver?)
      1f01            4096 mtdblock1
       (driver?)
      1f02            1024 mtdblock2
       (driver?)
      1f03          124928 mtdblock3
       (driver?)
      Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.61 #15
      Call Trace:
      [<ffffffe000026130>] walk_stackframe+0x0/0x98
      [<ffffffe0000262e8>] show_stack+0x2a/0x34
      [<ffffffe00049986e>] dump_stack+0x20/0x28
      [<ffffffe00002a6f0>] panic+0xec/0x272
      [<ffffffe000000ef6>] mount_block_root+0x214/0x27a
      [<ffffffe000000fe2>] mount_root+0x86/0x90
      [<ffffffe000001134>] prepare_namespace+0x148/0x152
      [<ffffffe000000b58>] kernel_init_freeable+0x166/0x198
      [<ffffffe0004aa420>] kernel_init+0x12/0xee
      [<ffffffe000024e9c>] ret_from_exception+0x0/0xc
      ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
        柚木 鉉 LV 9 最后由 YuzukiTsuru 编辑
        默认是mtd设备也就是spi flash 启动
        修改
        device/config/chips/d1-h/configs/nezha/sys_config.fex
        ;storage_type   = boot medium, 0-nand, 1-sd, 2-emmc, 3-nor, 4-emmc3, 5-spinand -1(defualt)auto scan
        [target]
        storage_type    = 1
        D 1 条回复 最后回复 回复 引用 分享 0
          daMing123 LV 6 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru 这里我已经 改成 storage_type = 1 ,一样的启动,就算改成5,用spinand,一样的卡死在这里,不知道为什么 。
            @daming123 设备树也要改一下
            board.dts
             * Allwinner Technology CO., Ltd. sun20iw1p1 fpga.
             * fpga support.
            /dts-v1/;
            /memreserve/ 0x42000000 0x100000;  /* dsp used 1MB */
            #include "sun20iw1p1.dtsi"
            	compatible = "allwinner,d1-h", "arm,sun20iw1p1", "allwinner,sun20iw1p1";
            	aliases {
            		dsp0 = &dsp0;
            		dsp0_gpio_int= &dsp0_gpio_int;
            		gmac0 = &gmac0;
            	dsp0: dsp0 {
            		compatible = "allwinner,sun20iw1-dsp";
            	dsp0_gpio_int: dsp0_gpio_int {
            		compatible = "allwinner,sun20iw1-dsp-gpio-int";
            		pin-group = "PB", "PC", "PD", "PE";
            		status = "disabled";
            	reg_vdd_cpu: vdd-cpu {
            		pwms = <&pwm 0 5000 1>;
            		regulator-name = "vdd_cpu";
            		regulator-ramp-delay = <25>;
            		regulator-always-on;
            		regulator-boot-on;
            	reg_usb1_vbus: usb1-vbus {
            		regulator-name = "usb1-vbus";
            		gpio = <&pio PD 19 GPIO_ACTIVE_HIGH>;
            		enable-active-high;
            &CPU0 {
            	cpu-supply = <&reg_vdd_cpu>;
            &pio {
            	sdc0_pins_a: sdc0@0 {
            				 "PF3", "PF4", "PF5";
            		allwinner,function = "sdc0";
            		allwinner,muxsel = <2>;
            		allwinner,drive = <3>;
            		allwinner,pull = <1>;
            		function = "sdc0";
            		drive-strength = <30>;
            		bias-pull-up;
            		power-source = <3300>;
            	sdc0_pins_b: sdc0@1 {
            		function = "sdc0";
            		bias-pull-up;
            		power-source = <1800>;
            	sdc0_pins_c: sdc0@2 {
            		function = "gpio_in";
            	/* TODO: add jtag pin */
            	sdc0_pins_d: sdc0@3 {
            		pins = "PF2", "PF4";
            		function = "uart0";
            		drive-strength = <10>;
            		bias-pull-up;
            	sdc0_pins_e: sdc0@4 {
            		pins = "PF0", "PF1", "PF3",
            			"PF5";
            		function = "jtag";
            		bias-pull-up;
            	sdc1_pins_a: sdc1@0 {
            		pins = "PG0", "PG1", "PG2",
            		       "PG3", "PG4", "PG5";
            		function = "sdc1";
            		bias-pull-up;
            	sdc1_pins_b: sdc1@1 {
            	sdc2_pins_a: sdc2@0 {
            				 "PC5", "PC6", "PC7";
            		allwinner,function = "sdc2";
            		allwinner,muxsel = <3>;
            		function = "sdc2";
            		bias-pull-up;
            	sdc2_pins_b: sdc2@1 {
            	wlan_pins_a:wlan@0 {
            		pins = "PG11";
            		function = "clk_fanout1";
            	uart0_pins_a: uart0_pins@0 {  /* For nezha board */
            		pins = "PB8", "PB9";
            		function = "uart0";
            		bias-pull-up;
            	uart0_pins_b: uart0_pins@1 {  /* For nezha board */
            		function = "uart1";
            		bias-pull-up;
            		pins = "PC0", "PC1";
            		function = "uart2";
            		bias-pull-up;
            		pins = "PD10", "PD11";
            		function = "uart3";
            		muxsel = <5>;
            		bias-pull-up;
            	twi0_pins_a: twi0@0 {
            		function = "twi0";
            	twi0_pins_b: twi0@1 {
            	twi1_pins_a: twi1@0 {
            		pins = "PB4", "PB5";
            		function = "twi1";
            	twi1_pins_b: twi1@1 {
            	twi2_pins_a: twi2@0 {
            		pins = "PB0", "PB1";
            		function = "twi2";
            	twi2_pins_b: twi2@1 {
            	twi3_pins_a: twi3@0 {
            		pins = "PB6", "PB7";
            		function = "twi3";
            	twi3_pins_b: twi3@1 {
            	gmac_pins_a: gmac@0 {
            		       "PE4", "PE5", "PE6", "PE7",
            		       "PE8", "PE9", "PE10", "PE11",
            		       "PE12", "PE13", "PE14", "PE15";
            		function = "gmac0";
            		muxsel = <8>; /* for uboot driver */
            	gmac_pins_b: gmac@1 {
            	dmic_pins_a: dmic@0 {
            		/* DMIC_PIN: CLK, DATA0, DATA1, DATA2 */
            		pins = "PE17", "PB11", "PB10", "PD17";
            		function = "dmic";
            		drive-strength = <20>;
            		bias-disable;
            	dmic_pins_b: dmic@1 {
            		function = "io_disabled";
            		bias-disable;
            	daudio0_pins_a: daudio0@0 {
            		/* MCLK, BCLK, LRCK */
            		pins = "PE17", "PE16", "PE15";
            		function = "i2s0";
            		bias-disable;
            	daudio0_pins_b: daudio0@1 {
            		/* DIN0 */
            		pins = "PE14";
            		function = "i2s0_din";
            		bias-disable;
            	daudio0_pins_c: daudio0@2 {
            		/* DOUT0 */
            		pins = "PE13";
            		function = "i2s0_dout";
            		bias-disable;
            	daudio0_pins_d: daudio0_sleep@0 {
            		bias-disable;
            	daudio1_pins_a: daudio1@0 {
            		/* MCLK, LRCK, BCLK */
            		pins = "PG11", "PG12", "PG13";
            		function = "i2s1";
            		bias-disable;
            	daudio1_pins_b: daudio1@1 {
            		/* DIN0 */
            		pins = "PG14";
            		function = "i2s1_din";
            		bias-disable;
            	daudio1_pins_c: daudio1@2 {
            		/* DOUT0 */
            		pins = "PG15";
            		function = "i2s1_dout";
            		bias-disable;
            	daudio1_pins_d: daudio1_sleep@0 {
            		bias-disable;
            	daudio2_pins_a: daudio2@0 {
            		pins = "PB7", "PB5", "PB6";
            		function = "i2s2";
            		bias-disable;
            	daudio2_pins_b: daudio2@1 {
            		/* I2S_PIN: DOUT0 */
            		pins = "PB4";
            		function = "i2s2_dout";
            		bias-disable;
            	daudio2_pins_c: daudio2@2 {
            		/* I2S_PIN: DIN0 */
            		pins = "PB3";
            		function = "i2s2_din";
            		bias-disable;
            		pins = "PB7", "PB5", "PB6", "PB4", "PB3";
            		bias-disable;
            	spdif_pins_a: spdif@0 {
            		/* SPDIF_PIN: SPDIF_OUT */
            		pins = "PB0";
            		function = "spdif";
            		bias-disable;
            	spdif_pins_b: spdif_sleep@0 {
            		pins = "PB0";
            		bias-disable;
            	spi0_pins_a: spi0@0 {
            		function = "spi0";
            		muxsel = <2>;
            	spi0_pins_b: spi0@1 {
            		pins = "PC3", "PC7", "PC6";
            		function = "spi0";
            		muxsel = <2>;
            	spi0_pins_c: spi0@2 {
            		muxsel = <0>;
            	spi1_pins_a: spi1@0 {
            		function = "spi1";
            	spi1_pins_b: spi1@1 {
            		function = "spi1";
            	spi1_pins_c: spi1@2 {
            	ledc_pins_a: ledc@0 {
            		pins = "PC0";
            		function = "ledc";
            	ledc_pins_b: ledc@1 {
            		pins = "PC0";
            	pwm0_pin_a: pwm0@0 {
            		pins = "PD16";
            		function = "pwm0";
            		bias-pull-up;
            	pwm0_pin_b: pwm0@1 {
            		pins = "PD16";
            		bias-disable;
            	pwm2_pin_a: pwm2@0 {
            		pins = "PD18";
            		function = "pwm2";
            		bias-pull-up;
            	pwm2_pin_b: pwm2@1 {
            		pins = "PD18";
            		function = "gpio_out";
            	pwm7_pin_a: pwm7@0 {
            		pins = "PD22";
            		function = "pwm7";
            		bias-pull-up;
            	pwm7_pin_b: pwm7@1 {
            		pins = "PD22";
            	s_cir0_pins_a: s_cir@0 {
            		pins = "PB12";
            		function = "ir";
            		bias-pull-up;
            	s_cir0_pins_b: s_cir@1 {
            		pins = "PB12";
            	ir1_pins_a: ir1@0 {
            		pins = "PB0";
            		function = "ir";
            		bias-pull-up;
            	ir1_pins_b: ir1@1 {
            		pins = "PB0";
            &uart0 {
            	pinctrl-0 = <&uart0_pins_a>;
            	pinctrl-1 = <&uart0_pins_b>;
            &uart1 {
            	pinctrl-0 = <&uart1_pins_a>;
            	pinctrl-1 = <&uart1_pins_b>;
            &uart2 {
            	pinctrl-0 = <&uart2_pins_a>;
            	pinctrl-1 = <&uart2_pins_b>;
            &uart3 {
            	pinctrl-0 = <&uart3_pins_a>;
            	pinctrl-1 = <&uart3_pins_a>;
            &soc {
            	card0_boot_para@2 {
            		reg = <0x0 0x2 0x0 0x0>;
            		card_ctrl = <0x0>;
            		card_high_speed = <0x1>;
            		card_line = <0x4>;
            		pinctrl-0 = <&sdc0_pins_a>;
            	card2_boot_para@3 {
            		reg = <0x0 0x3 0x0 0x0>;
            		card_ctrl = <0x2>;
            		card_line = <0x4>;
            		pinctrl-0 = <&sdc2_pins_a>;
            		/*sdc_ex_dly_used = <0x2>;*/
            		sdc_io_1v8 = <0x1>;
            		/*sdc_type = "tm4";*/
            		sdc_ex_dly_used = <2>;
            		/*sdc_tm4_win_th = <8>;*/
            	rfkill: rfkill@0 {
            		chip_en;
            		power_en;
            		pinctrl-0 = <&wlan_pins_a>;
            		pinctrl-names = "default";
            		status        = "okay";
            		wlan: wlan@0 {
            			clock-names = "32k-fanout1";
            			wlan_busnum    = <0x1>;
            			/*interrupt-parent = <&pio>;
            			wakeup-source;
            		bt: bt@0 {
            			/*bt_power_num = <0x01>;*/
            			/*bt_io_vol = <3300000>;*/
            			/*bt_power_vol = <330000>;*/
            			bt_rst_n      = <&pio PG 18 GPIO_ACTIVE_LOW>;
            			status        = "okay";
            	btlpm: btlpm@0 {
            		uart_index  = <0x1>;
            		bt_wake     = <&pio PG 16 GPIO_ACTIVE_HIGH>;
            		bt_hostwake = <&pio PG 17 GPIO_ACTIVE_HIGH>;
            		status      = "okay";
            	addr_mgt: addr_mgt@0 {
            		type_addr_wifi = <0x0>;
            		type_addr_bt   = <0x0>;
            		type_addr_eth  = <0x0>;
            		status         = "okay";
            &sdc2 {
            	non-removable;
            	bus-width = <4>;
            	mmc-ddr-1_8v;
            	mmc-hs200-1_8v;
            	no-sdio;
            	no-sd;
            	ctl-spec-caps = <0x308>;
            	cap-mmc-highspeed;
            	sunxi-power-save-mode;
            	sunxi-dis-signal-vol-sw;
            	mmc-bootpart-noacc;
            	max-frequency = <150000000>;
            	/*emmc io vol 3.3v*/
            	/*emmc io vol 1.8v*/
            &sdc0 {
            	bus-width = <4>;
            	/*non-removable;*/
            	/*broken-cd;*/
            	cd-inverted;
            	/*data3-detect;*/
            	cd-used-24M;
            	cap-sd-highspeed;
            	/*sd-uhs-sdr50;*/
            	/*sd-uhs-ddr50;*/
            	/*sd-uhs-sdr104;*/
            	no-sdio;
            	no-mmc;
            	/*sunxi-dis-signal-vol-sw;*/
            	ctl-spec-caps = <0x8>;
            &sdc1 {
            	bus-width = <4>;
            	no-mmc;
            	no-sd;
            	cap-sd-highspeed;
            	/*sd-uhs-sdr12*/
            	/*sd-uhs-sdr25;*/
            	/*sd-uhs-sdr50;*/
            	/*sd-uhs-ddr50;*/
            	/*sd-uhs-sdr104;*/
            	/*sunxi-power-save-mode;*/
            	cap-sdio-irq;
            	keep-power-in-suspend;
            	ignore-pm-notify;
            tvd configuration
                                   mode,mean enable)
            &tvd {
            	tvd_sw          = <1>;
            	tvd_interface   = <0>;
            	tvd_format      = <0>;
            	tvd_system      = <1>;
            	tvd_row         = <1>;
            	tvd_column      = <1>;
            	tvd_channel0_en = <1>;
            	tvd_channel1_en = <0>;
            	tvd_channel2_en = <0>;
            	tvd_channel3_en = <0>;
            	/*tvd_power0      = "dc1sw"*/
            	/*tvd_power1      = "eldo3"*/
            &tvd0 {
            /* Audio Driver modules */
            &sunxi_rpaf_dsp0 {
            &codec {
            	mic1gain 	= <0x13>;
            	mic2gain 	= <0x13>;
            	mic3gain 	= <0x13>;
            	adcdrc_cfg 	= <0x0>;
            	adchpf_cfg 	= <0x1>;
            	dacdrc_cfg 	= <0x0>;
            	dachpf_cfg 	= <0x0>;
            	/* Volume about */
            	digital_vol 	= <0x00>;
            	lineout_vol 	= <0x1a>;
            	headphonegain	= <0x03>;
            	/* Pa enabled about */
            	pa_level 	= <0x01>;
            	pa_pwr_level 	= <0x01>;
            	pa_msleep_time 	= <0x78>;
            	/* gpio-spk	= <&pio PF 2 GPIO_ACTIVE_HIGH>; */
            	/* regulator about */
            &sndcodec {
            	hp_detect_case	= <0x01>;
            	jack_enable	= <0x01>;
            &dummy_cpudai {
            	/* CMA config about */
            	playback_cma	= <128>;
            	capture_cma	= <256>;
            &dmic {
            &sounddmic {
            &dmic_codec {
             * tdm_config		0 --> pcm
             *			1 --> i2s
             * mclk_div		0 --> not output
             *			1 --> HDMI audio type
            &daudio0 {
            	mclk_div 	= <0x01>;
            	frametype 	= <0x00>;
            	tdm_config 	= <0x01>;
            	sign_extend 	= <0x00>;
            	msb_lsb_first 	= <0x00>;
            	pcm_lrck_period = <0x80>;
            	slot_width_select = <0x20>;
            	pinctrl-0       = <&daudio0_pins_a &daudio0_pins_b &daudio0_pins_c>;
            	pinctrl-1       = <&daudio0_pins_d>;
            	pinctrl_used	= <0x0>;
            &sounddaudio0 {
            		/* sound-dai = <&ac108>; */
            &daudio1 {
            	mclk_div 	= <0x01>;
            	frametype 	= <0x00>;
            	pinctrl-0       = <&daudio1_pins_a &daudio1_pins_b &daudio1_pins_c>;
            	pinctrl-1       = <&daudio1_pins_d>;
            &sounddaudio1 {
            &daudio2 {
            	mclk_div 	= <0x00>;
            	frametype 	= <0x00>;
            	tx_data_mode 	= <0x00>;
            	rx_data_mode 	= <0x00>;
            	pcm_lrck_period = <0x20>;
            	asrc_function_en  = <0x00>;
            	/*pinctrl-0       = <&daudio2_pins_a &daudio2_pins_b &daudio2_pins_c>;*/
            	/*pinctrl-1       = <&daudio2_pins_d>;*/
            	/* HDMI audio, no need pin */
            	pinctrl-0;
            	pinctrl-1;
            	daudio_type	= <0x1>;
            &hdmiaudio {
            &sounddaudio2 {
            	simple-audio-card,name = "sndhdmi";
            		sound-dai = <&hdmiaudio>;
            &spdif {
            &soundspdif {
            &usbc0 {
            	device_type = "usbc0";
            	usb_port_type = <0x2>;
            	usb_detect_type = <0x1>;
            	usb_detect_mode = <0>;
            	usb_id_gpio = <&pio PD 21 GPIO_ACTIVE_HIGH>;
            	enable-active-high;
            	usb_det_vbus_gpio = <&pio PD 20 GPIO_ACTIVE_HIGH>;
            	usb_wakeup_suspend = <0>;
            	usb_serial_unique = <0>;
            	rndis_wceis = <1>;
            &ehci0 {
            &ohci0 {
            &usbc1 {
            	device_type = "usbc1";
            	usb_regulator_io = "nocare";
            &ehci1 {
            &ohci1 {
            &twi0 {
            	clock-frequency = <400000>;
            	pinctrl-0 = <&twi0_pins_a>;
            	pinctrl-1 = <&twi0_pins_b>;
            	eeprom@50 {
            		compatible = "atmel,24c16";
            		reg = <0x50>;
            &twi1 {
            	pinctrl-0 = <&twi1_pins_a>;
            	pinctrl-1 = <&twi1_pins_b>;
            &twi2 {
            	pinctrl-0 = <&twi2_pins_a>;
            	pinctrl-1 = <&twi2_pins_b>;
            	dmas = <&dma 45>, <&dma 45>;
            	dma-names = "tx", "rx";
            	/* pcf8574-usage:
            	 * pin set:
            	 * interrupt set:
            	pcf8574: gpio@38 {
            		compatible = "nxp,pcf8574";
            		reg = <0x38>;
            		gpio_base = <2020>;
            		gpio-controller;
            		#gpio-cells = <2>;
            		interrupt-controller;
            		#interrupt-cells = <2>;
            	ctp@14 {
            		device_type = "ctp";
            		reg = <0x14>;
            		ctp_name = "gt9xxnew_ts";
            		ctp_twi_id = <0x2>;
            		ctp_twi_addr = <0x14>;
            		ctp_screen_max_x = <0x320>;
            		ctp_screen_max_y = <0x500>;
            		ctp_revert_x_flag = <0x0>;
            		ctp_revert_y_flag = <0x1>;
            		ctp_int_port = <&pio PG 14 GPIO_ACTIVE_HIGH>;
            		ctp_wakeup = <&pio PG 15 GPIO_ACTIVE_HIGH>;
            &twi3 {
            	pinctrl-0 = <&twi3_pins_a>;
            	pinctrl-1 = <&twi3_pins_b>;
            &gmac0 {
            	phy-mode = "rgmii";
            	use_ephy25m = <1>;
            	pinctrl-0 = <&gmac_pins_a>;
            	pinctrl-1 = <&gmac_pins_b>;
            	phy-rst = <&pio PE 16 GPIO_ACTIVE_HIGH>;
            	tx-delay = <3>; /*2~4*/
            	rx-delay = <0>;
            &spi0 {
            	pinctrl-1 = <&spi0_pins_c>;
            	spi_slave_mode = <0>;
            	spi0_cs_number = <1>;
                    spi0_cs_bitmap = <1>;
            	spi-nand@0 {
            		compatible = "spi-nand";
            		spi-max-frequency=<0x5F5E100>;
            		reg = <0x0>;
            		spi-rx-bus-width=<0x04>;
            		spi-tx-bus-width=<0x04>;
            		status="disabled";
            &spi1 {
            	pinctrl-1 = <&spi1_pins_c>;
            	spi1_cs_number = <1>;
            	spi1_cs_bitmap = <1>;
            	spi_dbi_enable = <1>;
            	spi_board1@0 {
            		device_type = "spi-dbi";
            		compatible = "sunxi,spidbi";
            		reg = <0x0>;
            		spi-rx-bus-width = <0x4>;
            		spi-tx-bus-width = <0x4>;
            	/* spi_board1@0 {
            		device_type = "spi_board1";
            		compatible = "rohm,dh2228fv";
            		reg = <0x0>;
            &ledc {
            	pinctrl-0 = <&ledc_pins_a>;
            	pinctrl-1 = <&ledc_pins_b>;
            	led_count = <12>;
            	output_mode = "GRB";
            	reset_ns = <84>;
            	t1h_ns = <800>;
            	t1l_ns = <320>;
            	t0h_ns = <300>;
            	t0l_ns = <800>;
            	wait_time0_ns = <84>;
            	wait_time1_ns = <84>;
            	wait_data_time_ns = <600000>;
            	status	= "okay";
            &keyboard0 {
            	key0 = <210 0x160>;
            	wakeup-source;
            disp init configuration
            set fbX_height to lcd_x)
                               in display.
            &disp {
            	/*VCC-LCD*/
            	/*VCC-DSI*/
            	/*VCC-PD*/
            ;lcd0 configuration
            ;Pin setting for gpio:
            ;fsync setting, pulse to csi
            &lcd0 {
            	lcd_used            = <1>;
            	lcd_driver_name     = "tft08006";
            	lcd_backlight       = <100>;
            	lcd_if              = <4>;
            	lcd_x               = <800>;
            	lcd_y               = <1280>;
            	lcd_width           = <52>;
            	lcd_height          = <52>;
            	lcd_dclk_freq       = <70>;
            	lcd_pwm_used        = <1>;
            	lcd_pwm_ch          = <2>;
            	lcd_pwm_freq        = <1000>;
            	lcd_pwm_pol         = <0>;
            	lcd_pwm_max_limit   = <255>;
            	lcd_hbp             = <32>;
            	lcd_ht              = <868>;
            	lcd_hspw            = <4>;
            	lcd_vbp             = <12>;
            	lcd_vt              = <1311>;
            	lcd_vspw            = <4>;
            	lcd_dsi_if          = <0>;
            	lcd_dsi_lane        = <4>;
            	lcd_lvds_if         = <0>;
            	lcd_lvds_colordepth = <0>;
            	lcd_lvds_mode       = <0>;
            	lcd_frm             = <0>;
            	lcd_hv_clk_phase    = <0>;
            	lcd_hv_sync_polarity= <0>;
            	lcd_gamma_en        = <0>;
            	lcd_bright_curve_en = <0>;
            	lcd_cmap_en         = <0>;
            	lcd_fsync_en        = <0>;
            	lcd_fsync_act_time  = <1000>;
            	lcd_fsync_dis_time  = <1000>;
            	lcd_fsync_pol       = <0>;
            	deu_mode            = <0>;
            	lcdgamma4iep        = <22>;
            	smart_color         = <90>;
            &hdmi {
            	hdmi_used = <1>;
            	hdmi_power_cnt = <0>;
            	hdmi_cts_compatibility = <1>;
            	hdmi_hdcp_enable = <1>;
            	hdmi_hdcp22_enable = <0>;
            	hdmi_cec_support = <1>;
            	hdmi_cec_super_standby = <0>;
            	ddc_en_io_ctrl = <0>;
            	power_io_ctrl = <0>;
            &pwm0 {
            	pinctrl-0 = <&pwm0_pin_a>;
            	pinctrl-1 = <&pwm0_pin_b>;
            &pwm2 {
            	pinctrl-0 = <&pwm2_pin_a>;
            	pinctrl-1 = <&pwm2_pin_b>;
            &pwm7 {
            	pinctrl-0 = <&pwm7_pin_a>;
            	pinctrl-1 = <&pwm7_pin_b>;
            &rtp {
            	allwinner,ts-attached;
            &gpadc {
            	channel_num = <2>;
            	channel_select = <3>;
            	channel_data_select = <3>;
            	channel_compare_select = <3>;
            	channel_cld_select = <3>;
            	channel_chd_select = <3>;
            &s_cir0 {
            	pinctrl-0 = <&s_cir0_pins_a>;
            	pinctrl-1 = <&s_cir0_pins_b>;
            &ir1 {
            	pinctrl-0 = <&ir1_pins_a>;
            	pinctrl-1 = <&ir1_pins_b>;
            /* &lcd_fb0 {
            	lcd_used = <1>;
            	lcd_driver_name = "kld35512";
            	lcd_if = <1>;
            	lcd_dbi_if = <4>;
            	lcd_data_speed = <60>;
            	lcd_spi_bus_num = <1>;
            	lcd_x = <320>;
            	lcd_y = <480>;
            	lcd_pixel_fmt = <10>;
            	lcd_dbi_fmt = <2>;
            	lcd_rgb_order = <0>;
            	lcd_width = <60>;
            	lcd_height = <95>;
            	lcd_pwm_used = <1>;
            	lcd_pwm_ch = <7>;
            	lcd_pwm_freq = <5000>;
            	lcd_pwm_pol = <1>;
            	lcd_frm = <1>;
            	lcd_gamma_en = <1>;
            	fb_buffer_num = <2>;
            	lcd_fps = <40>;
            	lcd_dbi_te = <1>;
            	lcd_dbi_clk_mode = <1>;
            	lcd_gpio_0 = <&pio PC 0 GPIO_ACTIVE_HIGH>;
            /* &lcd_fb0 {
            	lcd_used = <1>;
            	lcd_driver_name = "kld2844b";
            	lcd_if = <1>;
            	lcd_dbi_if = <4>;
            	lcd_x = <240>;
            	lcd_y = <320>;
            	lcd_width = <60>;
            	lcd_height = <95>;
            	lcd_pwm_used = <1>;
            	lcd_pwm_ch = <7>;
            	lcd_pwm_pol = <0>;
            	lcd_pixel_fmt = <0>;
            	lcd_dbi_fmt = <3>;
            	lcd_frm = <1>;
            	lcd_gamma_en = <1>;
            	lcd_dbi_te = <1>;
            	lcd_fps = <60>;
            然后 env.cfg
            #kernel command arguments
            initcall_debug=0
            nand_root=/dev/ubiblock0_5
            mmc_root=/dev/mmcblk0p5
            mtd_name=sys
            rootfstype=squashfs
            root_partition=rootfs
            boot_partition=boot
            init=/sbin/init
            loglevel=8
            cma=8M
            mac=
            wifi_mac=
            bt_mac=
            specialstr=
            keybox_list=widevine,ec_key,ec_cert1,ec_cert2,ec_cert3,rsa_key,rsa_cert1,rsa_cert2,rsa_cert3
            dsp0_partition=dsp0
            #set kernel cmdline if boot.img or recovery.img has no cmdline we will use this
            setargs_nand=setenv bootargs ubi.mtd=${mtd_name} ubi.block=0,${root_partition} earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
            setargs_nand_ubi=setenv bootargs ubi.mtd=${mtd_name} ubi.block=0,${root_partition} earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
            setargs_mmc=setenv  bootargs earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${mmc_root}  init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
            #nand command syntax: sunxi_flash read address partition_name read_bytes
            #0x4007f800 = 0x40080000(kernel entry) - 0x800(boot.img header 2k)
            boot_dsp0=sunxi_flash read 45000000 ${dsp0_partition};bootr 45000000 0 0
            boot_normal=sunxi_flash read 45000000 ${boot_partition};bootm 45000000
            boot_recovery=sunxi_flash read 45000000 recovery;bootm 45000000
            boot_fastboot=fastboot
            #uboot system env config
            bootdelay=0
            #default nand boot
            bootcmd=run setargs_nand boot_dsp0 boot_normal
            D 2 条回复 最后回复 回复 引用 分享 0
              @yuzukitsuru 不行,修改了env.cfg ,和设备树,直接uboot宕机
              [171]HELLO! BOOT0 is starting!
              [174]BOOT0 commit : 88480af
              [177]set pll start
              [179]fix vccio detect value:0xc0
              [182]periph0 has been enabled
              [185]set pll end
              [186][pmu]: bus read error
              [189]board init ok
              [191]ZQ value = 0x30
              [193]get_pmu_exist() = -1
              [195]ddr_efuse_type: 0xa
              [198]trefi:7.8ms
              [200][AUTO DEBUG] single rank and full DQ!
              [204]ddr_efuse_type: 0xa
              [206]trefi:7.8ms
              [208][AUTO DEBUG] rank 0 row = 13
              [211][AUTO DEBUG] rank 0 bank = 4
              [215][AUTO DEBUG] rank 0 page size = 2 KB
              [218]DRAM BOOT DRIVE INFO: V0.33
              [221]DRAM CLK = 528 MHz
              [224]DRAM Type = 2 (2:DDR2,3:DDR3)
              [227]DRAMC read ODT off.
              [229]DRAM ODT off.
              [231]ddr_efuse_type: 0xa
              [234]DRAM SIZE =64 M
              [236]dram_tpr4:0x0
              [238]PLL_DDR_CTRL_REG:0xf8002b00
              [241]DRAM_CLK_REG:0xc0000000
              [243][TIMING DEBUG] MR2= 0x0
              [248]DRAM simple test OK.
              [250]dram size =64
              [252]card no is 0
              [254]sdcard 0 line count 4
              [256][mmc]: mmc driver ver 2021-04-2 16:45
              [266][mmc]: Wrong media type 0x0
              [268][mmc]: Try SD card 0
              [279][mmc]: HSSDR52/SDR25 4 bit
              [281][mmc]: 50000000 Hz
              [284][mmc]: 7681 MB
              [285][mmc]: SD/MMC 0 init OK!!!
              [337]Loading boot-pkg Succeed(index=0).
              [341]Entry_name = opensbi
              [344]Entry_name = u-boot
              [348]Entry_name = dtb
              [350]mmc not para
              U-Boot 2018.05-g24521d6 (Feb 11 2022 - 08:52:39 +0000) Allwinner Technology
              [00.364]Relocation Offset is: 01ee7000
              [00.368]secure enable bit: 0
              [00.371]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
              [00.380]workmode = 0,storage type = 1
              [00.383][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
              [00.389][mmc]: get sdc_type fail and use default host:tm1.
              [00.395][mmc]: can't find node "mmc0",will add new node
              [00.400][mmc]: fdt err returned <no error>
              [00.404][mmc]: Using default timing para
              [00.408][mmc]: SUNXI SDMMC Controller Version:0x50310
              [00.426][mmc]: card_caps:0x3000000a
              [00.429][mmc]: host_caps:0x3000003f
              [00.436]line:703 init_clocks
              [00.439]drv_disp_init
              [00.460]drv_disp_init finish
              [00.463]boot_gui_init:start
              [00.466]set disp.dev2_output_type fail. using defval=0
              [00.473]boot_gui_init:finish
              [00.511]bmp_name=bootlogo.bmp size 38454
              [00.552]Loading Environment from SUNXI_FLASH... OK
              [00.576]out of usb burn from boot: not need burn key
              [00.611]Item0 (Map) magic is bad
              [00.614]the secure storage item0 copy0 magic is bad
              [00.649]Item0 (Map) magic is bad
              [00.[00.654]LCD open finish
              652]the secure storage item0 copy1 magic is bad
              [00.660]Item0 (Map) magic is bad
              [00.676]update part info
              [00.681]update bootcmd
              [00.686]change working_fdt 0x42aa6da0 to 0x42a86da0
              [00.723]update dts
              noncached_alloc(): addr = 0x42b12b80
              noncached_alloc(): addr = 0x42b12bc0
              noncached_alloc(): addr = 0x42c8a040
              noncached_alloc(): addr = 0x42c8a880
                @yuzukitsuru 试试,我已经解决了,在board.dts中,有个引脚占用了,我修改了下,就行了。
