    R329开发板烧录失败
    A Series
    5864
      yimu163com LV 4 最后由 编辑
      开发板正在跑的时候(仅仅是系统启动了,没有跑其他任何应用),用“PhoenixSuit”一键刷机工具来升级固件,如图所示,点击“立即升级”
      之后,串口提示:
      [  717.701304] store rtc flag 0x5a
      [  717.704988] android_work: sent uevent USB_STATE=DISCONNECTED
      [  717.880590] br-lan: port 1(eth0) entered disabled state
      [  717.889436] device eth0 left promiscuous mode
      [  717.890083] sunxi-codec-machine sndcodec: sunxi_hifi_sndcodec_startup
      [  717.890327] sunxi-codec-machine sndcodec: sunxi_hifi_sndcodec_hw_params
      [  717.890336] sunxi-internal-cpudai cpudai: ======== hw_params ========
      [  717.890342] sunxi-internal-cpudai cpudai: pcm_params->format:2
      [  717.890347] sunxi-internal-cpudai cpudai: pcm_params->channels:2
      [  717.890353] sunxi-internal-cpudai cpudai: pcm_params->rate:48000
      [  717.890358] sunxi-internal-cpudai cpudai: pcm_params->period_size:1024
      [  717.890363] sunxi-internal-cpudai cpudai: pcm_params->periods:4
      [  717.890368] sunxi-internal-cpudai cpudai: pcm_params->pcm_frames:1024
      [  717.890374] sunxi-internal-cpudai cpudai: pcm_params->buffer_size:4096
      [  717.890378] sunxi-internal-cpudai cpudai: ===========================
      [  717.920540] ffs_data_put(): freeing
      [  717.976526] br-lan: port 1(eth0) entered disabled state
      [  717.983986] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
      [  718.049868] sunxi-internal-cpudai cpudai: sunxi_hifi_pcm_hw_params
      [  718.852487] [STA_WRN] !!! xradio_remove_interface: vif_id=0
      [  721.850950] sunxi-internal-cpudai cpudai: sunxi_hifi_pcm_hw_free
      [  722.030067] sunxi-codec-machine sndcodec: sunxi_hifi_sndcodec_shutdown
      [  723.553123] [alarmtimer] have no shutdown alarm! alarmtimer_shutdown 322
      [  723.968680] [LCD_FB] lcd_fb_gpio_set_value,line:353:
      [  723.974081] OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
      [  724.024640] [LCD_FB] lcd_fb_shutdown,line:89:
      [  724.029358] Finish
      [  724.031940] sunxi_ohci_hcd_shutdown, ohci0-controller is disable, need not shutdown
      [  724.040549] sunxi_ehci_hcd_shutdown, ehci0-controller is disable, need not shutdown
      [  724.049254] reboot: Restarting system
      [37]HELLO! BOOT0 is starting!
      [40]BOOT0 commit : 97444f5
      [43]set pll start
      [45]periph0 has been enabled
      [48]set pll end
      [50]board init ok
      [52]rtc[3] value = 0xa102
      [54]the chip id is 0x3
      [56]the chip id is 0x3
      [59]the chip id is 0x3
      [61]the chip id is 0x3
      [63]the chip id is 0x3
      [65]chip id check OK
      [68][AUTO DEBUG] two rank and full DQ!
      [72][AUTO DEBUG] DDR3 try success
      [76][AUTO DEBUG] single rank and full DQ!
      [81][AUTO DEBUG] rank 0 row = 14
      [84][AUTO DEBUG] rank 0 bank = 8
      [88][AUTO DEBUG] rank 0 page size = 2 KB
      [92]DRAM BOOT DRIVE INFO: V0.171
      [95]DRAM Type = 3 (2:DDR2,3:DDR3)
      [98]DRAMC read ODT  off.
      [101]DRAM ODT off.
      [104]DRAM CLK = 774 MHz
      [106]DRAM SIZE =256 M
      [112]DRAM simple test OK.
      [114]dram size =256
      [117]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [123]block from 8 to 32
      [232]Check is correct.
      [234]dma 0x107f70 int is not used yet
      [238]dma 0x107f70 int is free, you do not need to free it again
      [244]Entry_name        = u-boot
      [250]Entry_name        = monitor
      [254]Entry_name        = dtb
      [257]Jump to second Boot.
      NOTICE:  BL3-1: v1.0(debug):3eba4b6
      NOTICE:  BL3-1: Built : 10:18:25, 2020-05-21
      NOTICE:  BL3-1 commit: 8
      ERROR:   Error initializing runtime service tspd_fast
      NOTICE:  BL3-1: Preparing for EL3 exit to normal world
      NOTICE:  BL3-1: Next image address = 0x43000000
      ÿOTICE:  BL3-1: Next image spsr = 0x1d3
      U-Boot 2018.05-00013-g7af46550cd (Dec 25 2020 - 08:28:52 +0000) Allwinner Technology
      [00.314]CPU:   Allwinner Family
      [00.317]Model: sun50iw11
      I2C:   ready
      [00.440]DRAM:  256 MiB
      [00.443]Relocation Offset is: 0ceff000
      [00.465]secure enable bit: 0
      [00.468]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=0Mhz
      [00.479]gic: sec monitor mode
      [00.481]flash init start
      [00.484]workmode = 0,storage type = 0
      [00.493]sunxi-spinand-phy: not detect any munufacture from id table
      [00.500]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [00.505]sunxi-spinand-phy: get phy info from fdt fail
      device nand0 <nand>, # parts = 5
       #: name		size		offset		mask_flags
       0: boot0               0x00100000	0x00000000	1
       1: uboot               0x00300000	0x00100000	1
       2: secure_storage      0x00100000	0x00400000	1
       3: pstore              0x00080000	0x00500000	1
       4: sys                 0x07a80000	0x00580000	0
      defaults:
      mtdids  : nand0=nand
      mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,512k@5242880(pstore)ro,-(sys)
      [00.762]ubi0: attaching mtd5
      [00.892]ubi0: scanning is finished
      [00.899]ubi0: attached mtd5 (name "sys", size 122 MiB)
      [00.903]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [00.910]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [00.916]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [00.922]ubi0: good PEBs: 490, bad PEBs: 0, corrupted PEBs: 0
      [00.928]ubi0: user volume: 12, internal volumes: 1, max. volumes count: 128
      [00.934]ubi0: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 0
      [00.942]ubi0: available PEBs: 0, total reserved PEBs: 490, PEBs reserved for bad PEB handling: 20
      [00.950]sunxi flash init ok
      307254 bytes read in 20 ms (14.7 MiB/s)
      [01.167]Loading Environment from SUNXI_FLASH... OK
      [01.192]Item0 (Map) magic is bad
      [01.195]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [01.207]usb prepare ok
      [01.413]usb sof ok
      [01.415]usb probe ok
      [01.417]usb setup ok
      set address 0x1b
      set address 0x1b ok
      [04.423]do_burn_from_boot usb : have no handshake
      [04.457]bootmode[2]:0x5a
      [43]set pll start
      [48]set pll end
      [50]board init ok
      [52]rtc[2] value = 0x5aa5a55a
      [54]rtc[3] value = 0xa102
      [57]eraly jump fel
      后面就卡住不动了,一会后,烧录工具跳出如下提示:
      手头四块板都是一样的现象,买到手之后没有烧录过。有大佬知道是什么原因吗?该如何解决?
        是什么开发板?希望烧录到什么储存设备上?
        Y 1 条回复 最后回复 回复 引用 分享 0
          yimu163com LV 4 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru 开发板是官网里( https://r329.docs.aw-ol.com/r329_evb5/ )介绍的这一块,NAND Flash用的ESMT F50L1G41LB,官网资料Allwinner SPI NAND Flash Support List_v1.9.pdf里提到了这一款存储芯片。
            试试使用全盘擦除升级
              @yuzukitsuru 试过的,结果一样。
                DOT小文哥 LV 8 最后由 编辑
                @yimu163com 在 R329开发板烧录失败 中说:
                这一款存储
                看开发板的log是正常的,板子大概率没有问题,检查一下电脑,是不是全志USB驱动没装啥的
                  yimu163com LV 4 @xiaowenge 最后由 编辑
                  @xiaowenge 你说得对,就是因为没有装驱动。谢谢了!🤝 🤝
