    R11 Linux3.4 挂载 4T 移动硬盘出错,请问应该怎么解决呢?
    A Series
    r11 移动硬盘 挂载
    4865
      memory LV 7 最后由 编辑
      buildroot login:
      [ 1493.810493] usb 1-1.4: new high-speed usb device number 5 using sunxi-ehci1494.011341] scsi2 :usb-storage 1-1.4:1.0
      1495.033101] scsi 2:0:0:0:Direct-Access Seagate One Touch w/PW 1707 PQ:日ANSI:6
      login: timed out after 60 seconds
      welcome to Buildroot
      buildroot login: [ 1500.795252]sd 2:0:0:0:[sda] Very big device. Trying to use READ CAPACITY(16).
      1500.806187] sd 2:0:0:0:[sda]9767541167 512-byte logical blocks: (5.00 TB/4.54 TiB)
      1500.81488日 sd 2:0:0:0: [sda] 4096-byte physical blocks
      1500.8222531 sd 2:0:0:0: [sda] Write Protect is off
      1500.8275971 sd 2:0:0:0: [sda] Mode Sense: bf 00 00 e
      1500.834484 sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
      1500.848285 sd 2:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16)
      1500.970265] sda:sdal
      1500.983815] sd 2:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16)
      1501.006303 sd 2:0:0:0:[sda] Attached scsI disk
      1501.2193661 FAT-fs(sdal):utf8 is not a recommended I0 charset for FAT filesystems, filesystem will be case sensitive!1501.234100][EXFAT] trying to mount... root
      Last login: Thu Jan 1 00:26:20 on console cd/run/media/ ls
        好像没看到什么错误
          whycan晕哥 LV 9 @YuzukiTsuru 最后由 whycan 编辑
          @yuzukitsuru
          # [  425.938667] ehci_irq: highspeed device connect
          [  426.220057] usb 1-1: new high-speed USB device number 3 using sunxi-ehci
          [  426.378206] scsi1 : usb-storage 1-1:1.0
          [  427.406884] scsi 1:0:0:0: Direct-Access     ST4000DM 004-2CV104       0    PQ: 0 ANSI: 6
          [  427.428022] sd 1:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
          [  427.437739] sd 1:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.63 TiB)
          [  427.446461] sd 1:0:0:0: [sda] 4096-byte physical blocks
          [  427.458820] sd 1:0:0:0: [sda] Write Protect is off
          [  427.464283] sd 1:0:0:0: [sda] Mode Sense: 43 00 00 00
          [  427.471460] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
          [  427.486642] sd 1:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
          [  427.519479]  sda: sda1
          [  427.530715] sd 1:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
          [  427.553590] sd 1:0:0:0: [sda] Attached SCSI disk
          # mount /dev/sda1 /tmp/aaa
          [  461.620756] FAT-fs (sda1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
          mount: mounting /dev/sda1 on /tmp/aaa failed: Invalid argument
          # mount /dev/sda /tmp/aaa
          [  475.037018] FAT-fs (sda): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
          mount: mounting /dev/sda on /tmp/aaa failed: Invalid argument
          确实挂载不上,这是什么原因呢?
            whycan晕哥 LV 9 @whycan 最后由 whycan 编辑
            @whycan
            # fdisk -l
            Disk /dev/mmcblk0: 7.39 GiB, 7933526016 bytes, 15495168 sectors
            Units: sectors of 1 * 512 = 512 bytes
            Sector size (logical/physical): 512 bytes / 512 bytes
            I/O size (minimum/optimal): 512 bytes / 512 bytes
            Disklabel type: dos
            Disk identifier: 0x00000000
            Device         Boot  Start      End  Sectors  Size Id Type
            /dev/mmcblk0p1      141696 15493118 15351423  7.3G  b W95 FAT32
            /dev/mmcblk0p2 *     41984    43007     1024  512K  6 FAT16
            /dev/mmcblk0p3           1   141696   141696 69.2M 85 Linux extended
            /dev/mmcblk0p5       43008    43263      256  128K 83 Linux
            /dev/mmcblk0p6       43264    51455     8192    4M 83 Linux
            /dev/mmcblk0p7       51456   121455    70000 34.2M 83 Linux
            /dev/mmcblk0p8      121456   141695    20240  9.9M 83 Linux
            Partition table entries are not in disk order.
            Disk /dev/sda: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
            Disk model: 004-2CV104
            Sector size (logical/physical): 512 bytes / 4096 bytes
            I/O size (minimum/optimal): 4096 bytes / 4096 bytes
            Disklabel type: gpt
            Disk identifier: DDC2F977-1D93-4541-B48F-CB71B9A58E0B
            Device     Start        End    Sectors  Size Type
            /dev/sda1     34      32767      32734   16M Microsoft reserved
            /dev/sda2  32768 7814033407 7814000640  3.6T Microsoft basic data
            Partition 1 does not start on physical sector boundary.
            fdisk 列出了sda1,却没有列出 sda2,这是什么问题呢?
            YuzukiTsuru whycan 2 条回复 最后回复 回复 引用 分享 0
              柚木 鉉 LV 9 @whycan 最后由 编辑
              @whycan 家境贫寒,告辞
                whycan晕哥 LV 9 @whycan 最后由 编辑
                @whycan
                https://forums.gentoo.org/viewtopic-t-1076996-start-0.html
                $ grep EFI_P /usr/src/linux/.config
                CONFIG_EFI_PARTITION=y
                That's a must have for your 4Tb drive.
                试一试这个?
                  @whycan
                  root@sun8i:/# mount -t ntfs /dev/sda2 /mnt/udisk
                  [   96.146467] NTFS-fs error (device sda2): parse_ntfs_boot_sector(): Volume size (3TiB) is too large for this architecture.  Maximum supported is 2TiB.  Sorry.
                  mount: mounting /dev/sda2 on /mnt/udisk failed: Invalid argument
                  看起来有起色了。
                  M 1 条回复 最后回复 回复 引用 分享 0
                    memory LV 7 @whycan 最后由 编辑
                    @whycan
                    感谢感谢,终于搞定了!👍
                    就是配好 CONFIG_EFI_PARTITION
                    • Moved from 创龙科技专区 by  xiaowenge xiaowenge
