    t113-s3 XR829模块导入出错
    6
    13
    10369
      captain LV 5 最后由 编辑
      主控:t113-s3
      SDK: longan_SDK
      wifi 模块:XR829
      导入的时候报错:
      # insmod lib/modules/5.4.61/xr829.ko
      [  381.819597] xr829: loading out-of-tree module taints kernel.
      [  381.831613] ======== XRADIO WIFI OPEN ========
      [  381.837252] [XRADIO] Driver Label:XR_V02.16.84_P2P_HT40_01.31
      [  381.844093] [XRADIO] Allocated hw_priv @ 1e7dceda
      [  381.849377] [ADDR_MGT] get_addr_by_name: t->addr:
      [  381.955930] [XRADIO] Detect SDIO card 0
      [  384.090284] [XRADIO] Remove SDIO card 0
      [  384.104598] [SBUS_ERR] sdio probe timeout!
      [  384.109195] [XRADIO_ERR] sbus_sdio_init failed
      [  384.114639] xradio_core_init failed (-110)!
      [  384.251814] ======== XRADIO WIFI OPEN ========
      [  384.257742] [XRADIO] Driver Label:XR_V02.16.84_P2P_HT40_01.31
      [  384.264613] [XRADIO] Allocated hw_priv @ 1e7dceda
      [  384.269898] [ADDR_MGT] get_addr_by_name: t->addr:
      [  384.379940] [XRADIO] Detect SDIO card 0
      [  386.570280] [XRADIO] Remove SDIO card 0
      [  386.584595] [SBUS_ERR] sdio probe timeout!
      [  386.589196] [XRADIO_ERR] sbus_sdio_init failed
      [  386.594766] xradio_core_init failed (-110)!
      insmod: can't insert 'lib/modules/5.4.61/xr829.ko': Connection timed out
        柚木 鉉 LV 9 @captain 最后由 编辑
        @captain 感觉sdc1被禁用了
          captain LV 5 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru
          在device/config/chips/t113/configs/evb1_auto/board.dts 是开启的。
          然后在sys_config.fex 里面没有SDC1得配置。
          这应该就算是开启了吧!
          &sdc1 {
                  bus-width = <4>;
                  no-mmc;
                  no-sd;
                  cap-sd-highspeed;
                  /*sd-uhs-sdr12*/
                  /*sd-uhs-sdr25;*/
                  /*sd-uhs-sdr50;*/
                  /*sd-uhs-ddr50;*/
                  /*sd-uhs-sdr104;*/
                  /*sunxi-power-save-mode;*/
                  /*sunxi-dis-signal-vol-sw;*/
                  cap-sdio-irq;
                  keep-power-in-suspend;
                  ignore-pm-notify;
                  max-frequency = <150000000>;
                  ctl-spec-caps = <0x8>;
            看一下wl_reg_on有没有拉高了
            C 2 条回复 最后回复 回复 引用 分享 0
              @yuzukitsuru
              在sys/class/gpio 里面看了一下,是拉高的。
                @yuzukitsuru
                对比了韦东山老师的官方固件XR829.KO的导入,
                我发现它的log里面多了rfkill 信息,但是我在设备树里面打开rfkill 之后,仍然没有任何反应。
                # insmod /lib/modules/5.4.61/kernel/drivers/net/wireless/xr829/xr829.ko
                [  109.785544] ======== XRADIO WIFI OPEN ========
                [  109.792019] [XRADIO] Driver Label:XR_V02.16.84_P2P_HT40_01.31
                [  109.798958] [XRADIO] Allocated hw_priv @ c5bbaa78
                [  109.804236] [ADDR_MGT] get_addr_by_name: t->addr:
                [  109.810854] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
                [  109.827340] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
                [  110.034535] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                [  110.037836] [XRADIO] Detect SDIO card 1
                [  110.045775] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                [  110.070163] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                [  110.095111] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                [  110.109829] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                [  110.132088] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                [  110.143717] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                [  110.155594] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
                [  110.168181] mmc1: new high speed SDIO card at address 0001
                [  110.175370] [SBUS] XRadio Device:sdio clk=50000000
                [  110.240380] [XRADIO] XRADIO_HW_REV 1.0 detected.
                [  110.336874] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x01400000.
                [  110.378148] [XRADIO] Bootloader complete
                [  110.487714] [XRADIO] Firmware completed.
                [  110.511171] [WSM] Firmware Label:XR_C09.08.52.64_DBG_02.100 2GHZ HT40 Jan  3 2020 13:14:37
                [  110.520697] [XRADIO] Firmware Startup Done.
                [  110.528645] [XRADIO_WRN] enable Multi-Rx!
                [  110.534086] mac80211_register_hw signal_type CFG80211_SIGNAL_TYPE_MBM
                [  110.534394] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
                        rfkill: rfkill@0 {
                                chip_en;
                                power_en;
                                pinctrl-0 = <&wlan_pins_a>;
                                pinctrl-names = "default";
                                status        = "okay";
                                wlan: wlan@0 {
                                        clock-names = "32k-fanout1";
                                        wlan_busnum    = <0x1>;
                                        wlan_hostwake  = <&pio PG 14 GPIO_ACTIVE_HIGH>;
                                        /*interrupt-parent = <&pio>;
                                        wakeup-source;
                  captain LV 5 最后由 编辑
                  破案了!!!
                  最后发现是rfkill没能正确导入的问题。
                  在设备树里面,rfkill的配置有问题,导致不能正确启用rfkill功能。(可在启动log里面查看rfkill启动情况。)
                  而wifi是依赖于rfkill的,所以wifi功能也不能正常启用。
                    lipeitong LV 4 @captain 最后由 编辑
                    @captain 可以分享下怎么配置rfkill嘛,我现在在t113也有这个问题
                      captain LV 5 @lipeitong 最后由 编辑
                      @lipeitong
                      要修改引脚和开发板对应,然后其它地方不能占用这组引脚。
                        @captain 引脚和开发板是对应的,也没有被其他功能复用。现在就是移植ap6256时,insmod bcmdhd.ko出现了类似的情况。麻烦帮忙看一下。22fefd1a-b229-4978-8e02-47cf1c42b93d-image.png
                        K 1 条回复 最后回复 回复 引用 分享 1
                        • K
                          Kamila LV 3 @lipeitong 最后由 编辑
                          @lipeitong 哈喽,该问题最后解决了吗?目前我也遇到类似情况,可以指点下吗?
                          S 1 条回复 最后回复 回复 引用 分享 1
                            sadaharu LV 1 @Kamila 最后由 编辑
                            @kamila 老哥,我这边也是一样的问题,你解决了吗
                              yyh5961 LV 4 最后由 编辑
                              @lipeitong 问题解决了吗 大佬
