    【tina_nezha】【求助】pwm无法启用/或寻其他途径控制舵机
    6050
    • T
      The_Qiang LV 4 最后由 编辑
      我尝试使用字符驱动和/sys/class/pwm/pwmchip0/export 启用pwm,驱动和用户层操作都是类似下面这种错误pinctrl_get failed
      [  868.035098] platform 2000c17.pwm7: pinctrl_get failed
      这是/sys/class下的pwm7(pwm1也是如此)
      root@TinaLinux:/sys/devices/platform/soc@3000000/2000c00.pwm/pwm/pwmchip0/pwm7# ls
      capture               output_type           power
      duty_cycle            period                uevent
      enable                polarity              waiting_for_supplier
      root@TinaLinux:/sys/devices/platform/soc@3000000/2000c00.pwm/pwm/pwmchip0/pwm7# echo 2000000 >period
      root@TinaLinux:/sys/devices/platform/soc@3000000/2000c00.pwm/pwm/pwmchip0/pwm7# echo 1000000 >duty_cycle
      root@TinaLinux:/sys/devices/platform/soc@3000000/2000c00.pwm/pwm/pwmchip0/pwm7# echo normal >polarity
      root@TinaLinux:/sys/devices/platform/soc@3000000/2000c00.pwm/pwm/pwmchip0/pwm7# echo 1 > enable
      ash: write error: No such device
      root@TinaLinux:/sys/devices/platform/soc@3000000/2000c00.pwm/pwm/pwmchip0/pwm7# cat capture
      [  885.724275] platform 2000c17.pwm7: pinctrl_get failed
      [  885.730046] time out is 1000
      [  894.621166] platform 2000c17.pwm7: pinctrl_get failed
      [  894.627001] sunxi_pwm_capture: pwm capture timeout !
      [  894.632728] platform 2000c17.pwm7: pinctrl_get failed
      [  894.638491] time out is 1000
      [  903.529004] platform 2000c17.pwm7: pinctrl_get failed
      [  903.534865] sunxi_pwm_capture: pwm capture timeout !
      cat: read error: Operation not permitted
      root@TinaLinux:/sys/devices/platform/soc@3000000/2000c00.pwm/pwm/pwmchip0/pwm7# cat /sys/kernel/debug/pwm
      platform/2000c00.pwm, 8 PWM devices
       pwm-0   (vdd-cpu             ): requested period: 0 ns duty: 0 ns polarity: inverse
       pwm-1   (sysfs               ): requested period: 2000000 ns duty: 0 ns polarity: inverse
       pwm-2   (lcd                 ): requested enabled period: 1000000 ns duty: 390625 ns polarity: normal
       pwm-3   ((null)              ): period: 0 ns duty: 0 ns polarity: inverse
       pwm-4   ((null)              ): period: 0 ns duty: 0 ns polarity: inverse
       pwm-5   ((null)              ): period: 0 ns duty: 0 ns polarity: inverse
       pwm-6   ((null)              ): period: 0 ns duty: 0 ns polarity: inverse
       pwm-7   (sysfs               ): requested period: 2000000 ns duty: 1000000 ns polarity: normal
      下面是修改过的设备树
       	pwm1_pin_a: pwm1@0 {
      		pins = "PB6";
                 // allwinner,muxsel = <5>;//这个地方尝试过,也是pinctrl_get failed
      		function = "pwm1";
      		drive-strength = <10>;
      		bias-pull-up;
      	pwm1_pin_b: pwm1@1 {
      		pins = "PB6";
      		function = "gpio_in";
      &pwm1 {
      	pinctrl-0 = <&pwm1_pin_a>;
      	pinctrl-1 = <&pwm1_pin_b>;
      我还把设备树中PB6相关的其他设备都“disable”了(TWI3和daudio2)(i2s2的我没找到😧 )结果和上面相同
      allwinner,muxsel = <5>;我试着加在了pwm1_pin_a: pwm1@0 {} 里,也没效果
      • T
        刚刚用gpio_direction_output()和usleep模拟PWM。。不过只能控制舵机0°~160°左右,达不到180°。不知道为什么。。还在摸索
          pwm7我记得在lcd绑定了
          T 1 条回复 最后回复 回复 引用 分享 0
          • T
            The_Qiang LV 4 @YuzukiTsuru 最后由 编辑
            @yuzukitsuru 好像是的。pwm0、pwm2、pwm7,在board.dts里面配置了休眠和常规两种状态,然后也是默认启用的。
            不过我自己添加的pwm1,也是这种情况。
              pwm应该不是这样绑定pin的,具体看一下pwm的文档
              T 2 条回复 最后回复 回复 引用 分享 0
              • T
                @yuzukitsuru
                我看了那个文档,不过估计是没有完全理解。
                类似这种,默认定义了0~7号pwm
                然后在板级dts里只配置了pwm0 pwm2 pwm7
                其他的写都没写。看样子是要自己添加。但是没有看到介绍如何添加。 019d7c24-0212-41d8-a211-8fa87a632bc8-image.png
                然后,提供的内核api需要 pwm号, 返回的错误信息在前面(和/sys/class/pwm下的信息一样)
                • T
                  @yuzukitsuru 在 【tina_nezha】【求助】pwm无法启用/或寻其他途径控制舵机 中说:
                  还有个问题,求大佬指条明路,之前询问控制DHT11,说道使用告诉I2C外设来实现。大佬,具体点,哪款芯片,或者哪一类呢
                  • Deleted by  T The_Qiang
                  • Restored by  xiaowenge xiaowenge
