    【FAQ】全志V853芯片 适配双目GC2053的操作步骤
    v853 faq 技术支持
    10
    21
    19568
      1.主题
      Tina V85x 平台适配双目GC2053的操作步骤
      2.问题背景
      Tina V85x 平台支持多目sensor场景。Tina V85x SDK默认配置一般都是单目sensor,比如SDK V1.0默认是单目GC2053。为方便用户适配双目或多目sensor,下面以V853 perf1方案+双目GC2053为例,介绍适配的操作步骤。
      3.解决办法
      一、双目GC2053适配
      适配双目GC2053主要修改以下几处:
      1、dts设备树
      文件:device/config/chips/v853/configs/perf1/board.dts
      修改:
      • (1)修改csi/isp频率
        为节省带宽,可将csi/isp频率由原来默认的300MHz降至200MHz。
      vind0:vind@0 {
      -			vind0_clk = <300000000>;
      +			vind0_clk = <200000000>;
      • (2)修改成离线模式
        因双目场景下,ISP需分时复用,故只能支持离线模式,即work_mode改成1(离线)。
      tdm0:tdm@0 {
      -				work_mode = <0>;
      +				work_mode = <1>;
       			isp00:isp@0 {
      -				work_mode = <0>;
      +				work_mode = <1>;
       			scaler00:scaler@0 {
      -				work_mode = <0>;
      +				work_mode = <1>;
       			scaler10:scaler@4 {
      -				work_mode = <0>;
      +				work_mode = <1>;
       			scaler20:scaler@8 {
      -				work_mode = <0>;
      +				work_mode = <1>;
       			scaler30:scaler@12 {
      -				work_mode = <0>;
      +				work_mode = <1>;
      • (3)修改sensor配置
        sensor0默认是gc2053,无需修改。但是需要修改sensor1的配置为gc2053。修改后,sensor0和sensor1的配置如下:
      sensor0:sensor@0 {
      				device_type = "sensor0";
      				sensor0_mname = "gc2053_mipi";
      				sensor0_twi_cci_id = <1>;
      				sensor0_twi_addr = <0x6e>;
      				sensor0_mclk_id = <0>;
      				sensor0_pos = "rear";
      				sensor0_isp_used = <1>;
      				sensor0_fmt = <1>;
      				sensor0_stby_mode = <0>;
      				sensor0_vflip = <0>;
      				sensor0_hflip = <0>;
      				sensor0_iovdd-supply = <&reg_aldo2>;
      				sensor0_iovdd_vol = <1800000>;
      				sensor0_avdd-supply = <&reg_bldo2>;
      				sensor0_avdd_vol = <2800000>;
      				sensor0_dvdd-supply = <&reg_dldo2>;
      				sensor0_dvdd_vol = <1200000>;
      				sensor0_power_en = <>;
      				sensor0_reset = <&pio PA 18 1 0 1 0>;
      				sensor0_pwdn = <&pio PA 19 1 0 1 0>;
      				sensor0_sm_hs = <>;
      				sensor0_sm_vs = <>;
      				flash_handle = <&flash0>;
      				act_handle = <&actuator0>;
      				status	= "okay";
      			sensor1:sensor@1 {
      				device_type = "sensor1";
      				sensor1_mname = "gc2053_mipi_2";
      				sensor1_twi_cci_id = <0>;
      				sensor1_twi_addr = <0x7e>;
      				sensor1_mclk_id = <1>;
      				sensor1_pos = "front";
      				sensor1_isp_used = <1>;
      				sensor1_fmt = <1>;
      				sensor1_stby_mode = <0>;
      				sensor1_vflip = <0>;
      				sensor1_hflip = <0>;
      				sensor1_iovdd-supply = <&reg_aldo2>;
      				sensor1_iovdd_vol = <1800000>;
      				sensor1_avdd-supply = <&reg_bldo2>;
      				sensor1_avdd_vol = <2800000>;
      				sensor1_dvdd-supply = <&reg_dldo2>;
      				sensor1_dvdd_vol = <1200000>;
      				sensor1_power_en = <>;
      				sensor1_reset = <&pio PA 20 1 0 1 0>;
      				sensor1_pwdn = <&pio PA 21 1 0 1 0>;
      				sensor1_sm_hs = <>;
      				sensor1_sm_vs = <>;
      				flash_handle = <>;
      				act_handle = <>;
      				status	= "okay";
      • (4)修改各video节点的配置
        双目GC2053场景下,可支持的video节点分别为:
        sensor0:video 0/4/8/12
        sensor1:video 1/5/9/13
        故只需修改以上8个video节点的配置即可。修改后的配置如下:
      vinc00:vinc@0 {
      				vinc0_csi_sel = <0>;
      				vinc0_mipi_sel = <0>;
      				vinc0_isp_sel = <0>;
      				vinc0_isp_tx_ch = <0>;
      				vinc0_tdm_rx_sel = <0>;
      				vinc0_rear_sensor_sel = <0>;
      				vinc0_front_sensor_sel = <0>;
      				vinc0_sensor_list = <0>;
      				work_mode = <0x1>;
      			vinc01:vinc@1 {
      				vinc1_csi_sel = <1>;
      				vinc1_mipi_sel = <1>;
      				vinc1_isp_sel = <1>;
      				vinc1_isp_tx_ch = <0>;
      				vinc1_tdm_rx_sel = <1>;
      				vinc1_rear_sensor_sel = <1>;
      				vinc1_front_sensor_sel = <1>;
      				vinc1_sensor_list = <0>;
      			vinc10:vinc@4 {
      				vinc4_csi_sel = <0>;
      				vinc4_mipi_sel = <0>;
      				vinc4_isp_sel = <0>;
      				vinc4_isp_tx_ch = <0>;
      				vinc4_tdm_rx_sel = <0>;
      				vinc4_rear_sensor_sel = <0>;
      				vinc4_front_sensor_sel = <0>;
      				vinc4_sensor_list = <0>;
      				work_mode = <0x1>;
      			vinc11:vinc@5 {
      				vinc5_csi_sel = <1>;
      				vinc5_mipi_sel = <1>;
      				vinc5_isp_sel = <1>;
      				vinc5_isp_tx_ch = <0>;
      				vinc5_tdm_rx_sel = <1>;
      				vinc5_rear_sensor_sel = <1>;
      				vinc5_front_sensor_sel = <1>;
      				vinc5_sensor_list = <0>;
      			vinc20:vinc@8 {
      				vinc8_csi_sel = <0>;
      				vinc8_mipi_sel = <0x0>;
      				vinc8_isp_sel = <0>;
      				vinc8_isp_tx_ch = <0>;
      				vinc8_tdm_rx_sel = <0>;
      				vinc8_rear_sensor_sel = <0>;
      				vinc8_front_sensor_sel = <0>;
      				vinc8_sensor_list = <0>;
      				work_mode = <0x1>;
      			vinc21:vinc@9 {
      				vinc9_csi_sel = <0>;
      				vinc9_mipi_sel = <0x0>;
      				vinc9_isp_sel = <0>;
      				vinc9_isp_tx_ch = <0>;
      				vinc9_tdm_rx_sel = <0>;
      				vinc9_rear_sensor_sel = <0>;
      				vinc9_front_sensor_sel = <0>;
      				vinc9_sensor_list = <0>;
      				work_mode = <0x1>;
      			vinc30:vinc@12 {
      				vinc12_csi_sel = <0>;
      				vinc12_mipi_sel = <0x0>;
      				vinc12_isp_sel = <0>;
      				vinc12_isp_tx_ch = <0>;
      				vinc12_tdm_rx_sel = <0>;
      				vinc12_rear_sensor_sel = <0>;
      				vinc12_front_sensor_sel = <0>;
      				vinc12_sensor_list = <0>;
      				work_mode = <0x1>;
      			vinc31:vinc@13 {
      				vinc13_csi_sel = <1>;
      				vinc13_mipi_sel = <1>;
      				vinc13_isp_sel = <1>;
      				vinc13_isp_tx_ch = <0>;
      				vinc13_tdm_rx_sel = <1>;
      				vinc13_rear_sensor_sel = <1>;
      				vinc13_front_sensor_sel = <1>;
      				vinc13_sensor_list = <0>;
      2、内核配置
      双mipi sensor场景下,ISP分时复用,需要使用TDM,故需打开TDM。
      文件:device/config/chips/v853/configs/perf1/linux/config-4.9
      修改:打开TDM配置
      CONFIG_SUPPORT_ISP_TDM=y
      CONFIG_TDM_LBC_EN=y
      3、mpp middleware
      首先,确保mpp配置中选中了gc2053 sensor。检查方法:
      make menuconfig,依次进入配置项:
      Allwinner  --->
          eyesee-mpp  --->
              [*]   select sensor
              [*]     use sensor gc2053
      然后,在ISP效果文件中,为第二个sensor添加效果文件配置。
      位置:external/eyesee-mpp/middleware/sun8iw21/media/LIBRARY/libisp/isp_cfg/isp_ini_parse.c
      修改:将原来的两组gc2053_mipi配置分别拷贝一份,然后修改名字为gc2053_mipi_2即可,其他参数不用修改。
      struct isp_cfg_array cfg_arr[] = {
      #ifdef SENSOR_GC2053
      	{"gc2053_mipi",  "gc2053_mipi_isp600_20220511_164617_vlc4_day", 1920, 1088, 20, 0, 0, &gc2053_mipi_v853_isp_cfg},
      	{"gc2053_mipi",  "gc2053_mipi_isp600_20220415_144837_ir", 1920, 1088, 20, 0, 1, &gc2053_mipi_ir_isp_cfg},
      	{"gc2053_mipi_2",  "gc2053_mipi_isp600_20220511_164617_vlc4_day", 1920, 1088, 20, 0, 0, &gc2053_mipi_v853_isp_cfg},
      	{"gc2053_mipi_2",  "gc2053_mipi_isp600_20220415_144837_ir", 1920, 1088, 20, 0, 1, &gc2053_mipi_ir_isp_cfg},
      按以上步骤修改完成后,需重新编译mpp和固件,命令如下:
      cleanmpp && mkmpp && mp
      二、双目GC2053验证
      支持验证双目GC2053的mpp sample有:
      sample_rtsp(支持双目采集+编码+RTSP)、sample_smartIPC_demo(支持双目采集+编码+RTSP+人形检测)、sample_smartPreview_demo(支持双目采集+预览)
      如果不需要RTSP功能,注释掉代码中的宏 #define SUPPORT_RTSP_TEST 即可。
      L Y N C 6 条回复 最后回复 回复 引用 分享 2
        lipeitong LV 4 @q1215200171 最后由 编辑
        @q1215200171 烧进去之后是这样的,找不到设备,正常吗?屏幕截图 2022-08-15 173149.png 求解!
          @q1215200171 配置和楼主是一样的
            @q1215200171 使用的是全志释放的sdk
              柚木 鉉 LV 9 @lipeitong 最后由 编辑
              @lipeitong 摄像头型号匹配吗
              L 2 条回复 最后回复 回复 引用 分享 0
                lipeitong LV 4 @YuzukiTsuru 最后由 编辑
                  @yuzukitsuru 官网介绍是gc2063,复用的是gc2053的代码。现在只通了一个。log的i2c地址的值是设备树的一半,不知道是怎么回事?屏幕截图 2022-08-15 173149.png
                    YterAA LV 7 最后由 编辑
                    两个摄像头的地址是不一样的,要配置一下。
                    https://bbs.aw-ol.com/assets/uploads/files/1655976276093-15c5a928-35ee-4228-a901-1d1f57ebeed7-iot362g6363-a-原理图.pdf
                    C L 3 条回复 最后回复 回复 引用 分享 1
                      cruise33 LV 6 @YterAA 最后由 编辑
                        cruise33 LV 6 最后由 编辑
                          lipeitong LV 4 @YterAA 最后由 编辑
                          @yteraa 设备树配置之后,还是报No such device这个错误。i2c依旧不通。
                            @yteraa 使用了1.0版本的sdk就可以了,再次感谢楼主分享
                              y1178427557 LV 4 @q1215200171 最后由 编辑
                              @q1215200171 你好,请问一下这个地方为什么要这么多个video的?两个GC2053,又不跑wdr,最多不是出两路吗?
                              (4)修改各video节点的配置
                                y1178427557 LV 4 最后由 编辑
                                请教一下,ISP的分时复用大致的框架是怎样的,相比于在线模式会有什么影响不,有没有相关的介绍资料可以分享一下莫?
                                  jiao1937284560 LV 1 最后由 编辑
                                  @q1215200171 在 【FAQ】全志V853芯片 适配双目GC2053的操作步骤 中说:
                                  《MPP_Sample_使用说明》具体位置在哪一我在一号通上找不见
                                  • bayche
                                    bayche LV 6 最后由 编辑
                                    gc2053_ds.pdf
                                    • N
                                      nimadibaj LV 4 @q1215200171 最后由 编辑
                                      @q1215200171
                                      你好
                                      我在哪里可以找到这个 : MPP_Sample_使用说明
                                        @nimadibaj @jiao1937284560
                                          柚木 鉉 LV 9 @nimadibaj 最后由 编辑
                                          @nimadibaj 【资料】V853&V851 软件开发指南
                                          https://bbs.aw-ol.com/topic/2266/share/1
                                          • Referenced by  R Rain_tk
                                            cola123456 LV 4 @q1215200171 最后由 编辑
                                            @q1215200171 都按照你的步骤做了 但是还是只有一路图像 请问下要怎么确认是哪里的问题呢?
                                              cola123456 LV 4 @lipeitong 最后由 编辑
                                              @lipeitong 您好 请问这个问题您解决了吗? 是双目GC2053是吧?
