    自制的V853板子,串口无法输入,求帮助。
    6915
    • N
      Negro LV 5 最后由 编辑
      • 板子:参考官方的V853板子画的,用的PMU,DDR,EMMC是和官网一致的,就是加了一些自己的外围芯片进去。
      • 固件:源码编译出来的openwrt固件。dts中就做了一些简单的修改,修改后编译出来的固件可以在官网板子上跑起来。
      • 问题:板子上电后,用tf卡升级固件,升级成功后接debug串口开机。然后我是设置了倒数3秒进入uboot的,但是倒数时按任何按键都没有反应,进不去uboot。 系统内核也可以启动,但是起来后也卡住不动了,串口输入没有任何反应。想问下大家有没有遇到过类似的情况。
      log如下:
      [58]HELLO! BOOT0 is starting!
      [61]BOOT0 commit : 2a3ec52022
      [64]set pll start
      [65]periph0 has been enabled
      [68]set pll end
      [71]PMU: AXP21
      [74]board init ok
      [75]DRAM use external ZQ!!
      [78]chip id check OK
      [80]DRAM_VCC set to 1500 mv
      [83]DRAM BOOT DRIVE INFO: V0.16
      [86]DRAM CLK = 936 MHz
      [88]DRAM Type = 3 (2:DDR2,3:DDR3)
      [91]DRAMC ZQ value: 0x7b7bfb
      [94]DRAM ODT value: 0x42.
      [98]DRAM SIZE =512 M
      [100]dram_tpr4:0x0
      [107]DRAM simple test OK.
      [109]rtc standby flag is 0x0, super standby flag is 0x0
      [114]dram size =512
      [117]audio:avcc calibration
      [120]card no is 2
      [121]sdcard 2 line count 8
      [124][mmc]: mmc driver ver 2021-12-27 10:07
      [133][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [139][mmc]: ***Try MMC card 2***
      [154][mmc]: RMCA OK!
      [156][mmc]: bias 100
      [158][mmc]: mmc 2 bias 100
      [161][mmc]: MMC 5.1
      [163][mmc]: HSSDR52/SDR25 8 bit
      [166][mmc]: 50000000 Hz
      [168][mmc]: 7400 MB
      [170][mmc]: ***SD/MMC 2 init OK!!!***
      [223]Loading boot-pkg Succeed(index=0).
      [227]Entry_name        = optee
      [230]Entry_name        = u-boot
      [237]Entry_name        = dtb
      [240]tunning data addr:0x430003e8
      [243]Jump to second Boot.
      U-Boot 2018.05-00001-g1444403-dirty (Sep 06 2022 - 10:08:59 +0800) Allwinner Technology
      [00.417]CPU:   Allwinner Family
      [00.420]Model: sun8iw21
      I2C:   ready
      [00.446]DRAM:  512 MiB
      [00.450]Relocation Offset is: 1ced0000
      [00.474]secure enable bit: 0
      [00.489]PMU: AXP21
      [00.491]BMU: AXP21
      FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL
      bias_name:pc_bias        bias_vol:1800
      bias_name:pi_bias        bias_vol:1800
      [00.515]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz  MBus=300Mhz
      [00.521]gic: sec monitor mode
      sunxi flash map init
      [00.525]flash init start
      [00.527]workmode = 0,storage type = 2
      [00.531][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.536][mmc]: get sdc_type fail and use default host:tm4.
      [00.543][mmc]: SUNXI SDMMC Controller Version:0x50400
      [00.571][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
      [00.577]sunxi flash init ok
      [00.580]line:724 init_clocks
      [00.583]drv_disp_init
      request pwm success, pwm9:pwm9:0x2000c00.
      [00.597]drv_disp_init finish
      [00.601]Loading Environment from SUNXI_FLASH... OK
      [00.613]boot_gui_init:start
      [00.616]set disp.dev2_output_type fail. using defval=0
      [00.620][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
      [00.625][ICN6202 TO LVDS] LINE:0167-->lcd_power_on:
      [00.643]boot_gui_init:finish
      54 bytes read in 0 ms
      [00.652]bmp_name=bootlogo.bmp size 38454
      [00.656][ICN6202 TO LVDS] LINE:0575-->lcd_panel_init:
      [00.822][ICN6202 TO LVDS] LINE:0620-->lcd_panel_init:initialization:icn6202 init reg from mipi
      38454 bytes read in 187 ms (200.2 KiB/s)
      [00.850]Item0 (Map) magic is bad
      [00.853]the secure storage item0 copy0 magic is bad
      [00.858]Item0 (Map) magic is bad
      [00.861]the secure storage item0 copy1 magic is bad
      [00.865]Item0 (Map) magic is bad
      [00.868]out of usb burn from boot: not need burn key
      root_partition is rootfs
      set root to /dev/mmcblk0p4
      [00.878]update part info
      [00.880]update bootcmd
      [00.884]change working_fdt 0x5de8fe70 to 0x5de6fe70
      [00.891][mmc]: delete mmc-hs400-1_8v from dtb
      [00.895][mmc]: delete mmc-hs200-1_8v from dtb
      [00.899][mmc]: get max-frequency ok 50000000 Hz
      [00.912]The storage not support sample function
      [00.918]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      [00.928]update dts
      Hit any key to stop autoboot:  3 [00.955][ICN6202 TO LVDS] LINE:0203-->lcd_bl_open:
      [00.962]LCD open finish        0
      [04.053]no vendor_boot partition is found
      [04.102]Starting kernel ...
      [04.105][mmc]: mmc exit start
      [04.123][mmc]: mmc 2 exit ok
      Uncompressing Linux...0229.749ms done, booting the kernel.
      [    0.000000] Linux version 4.9.191 (gray@PC) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #18 PREEMPT Fri Aug 12 15:51:32 CST 2022
      [    0.000000] OF: fdt:Machine model: sun8iw21
      [    0.000000] bootconsole [earlycon0] enabled
      [    0.000000] ion_mem_reserve: err format for ion reserve list!
      [    0.000000] disp reserve base 0x5df1a000 ,size 0x3e8000
      [    0.000000] Reserved memory: created DMA memory pool at 0x47000000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node vdev0buffer@47000000, compatible id shared-dma-pool
      [    0.000000] Memory policy: Data cache writeback
      [    0.000000] On node 0 totalpages: 129920
      [    0.000000] free_area_init_node: node 0, pgdat c0b5d4d4, node_mem_map dfbf8000
      [    0.000000]   Normal zone: 1024 pages used for memmap
      [    0.000000]   Normal zone: 129920 pages, LIFO batch:31
      [    0.000000] CPU: All CPU(s) started in SVC mode.
      [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 128896
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4 rootwait init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:rootfs@mmcblk0p4:rootfs_data@mmcblk0p5:recovery@mmcblk0p6:dtb@mmcblk0p7:UDISK@mmcblk0p8 cma= mac_addr= wifi_mac= bt_mac= selinux= specialstr= coherent_pool=32K ion_carveout_list= androidboot.mode=normal androidboot.hardware=sun8iw21p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.05-00001-g1444403-dirty(09/06/2022-10:08:59) mbr_offset=1032192 disp_reserve=4096000,0x5df1a000 bootreason=usb androidboot.dramsize=512
      [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
      [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
      [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
      [    0.000000] Memory: 498684K/519680K available (6144K kernel code, 377K rwdata, 2268K rodata, 1024K init, 182K bss, 20996K reserved, 0K cma-reserved, 0K highmem)
      [    0.000000]     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
      [    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
      [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      [    0.000000]       .text : 0xc0008000 - 0xc0700000   (7136 kB)
      [    0.000000]       .init : 0xc0a00000 - 0xc0b00000   (1024 kB)
      [    0.000000]       .data : 0xc0b00000 - 0xc0b5e5d0   ( 378 kB)
      [    0.000000]        .bss : 0xc0b5e5d0 - 0xc0b8be68   ( 183 kB)
      [    0.008104] Switching to timer-based delay loop, resolution 41ns
      [    0.014436] Console: colour dummy device 80x30
      [    0.018988] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.029439] pid_max: default: 32768 minimum: 301
      [    0.034335] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.041058] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.048735] CPU: Testing write buffer coherency: ok
      [    0.054299] Setting up static identity map for 0x40100000 - 0x40100058
      [    0.062439] devtmpfs: initialized
      [    0.100560] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.108906] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.119068] futex hash table entries: 256 (order: -1, 3072 bytes)
      [    0.125419] atomic64_test: passed
      [    0.128820] pinctrl core: initialized pinctrl subsystem
      [    0.135716] NET: Registered protocol family 16
      [    0.140887] DMA: preallocated 32 KiB pool for atomic coherent allocations
      [    0.149971] dump_class_init,857, success
      [    0.177995] cpuidle: using governor menu
      [    0.183218] platform 2010000.iommu: iova_base: 0x48400000
      [    0.189490] sunxi iommu: irq = 22
      [    0.212605] sun8iw21p1-pinctrl pio: initialized sunXi PIO driver
      [    0.220618] sunxi hwspinlock vbase:0xe0824000
      [    0.226955] iommu: Adding device npu to group 0
      [    0.232810] iommu: Adding device 1c0e000.ve to group 0
      [    0.246733] iommu: Adding device 5410000.g2d to group 0
      [    0.253343] iommu: Adding device 5000000.disp to group 0
      [    0.264736] iommu: Adding device 5908000.tdm to group 0
      [    0.270961] iommu: Adding device 5900000.isp to group 0
      [    0.277136] iommu: Adding device 58ffffc.isp to group 0
      [    0.283270] iommu: Adding device 58ffff8.isp to group 0
      [    0.289420] iommu: Adding device 58ffff4.isp to group 0
      [    0.295321] iommu: Adding device 5800800.vind:isp@4 to group 0
      [    0.302007] iommu: Adding device 5910000.scaler to group 0
      [    0.308179] iommu: Adding device 590fffc.scaler to group 0
      [    0.314309] iommu: Adding device 590fff8.scaler to group 0
      [    0.320431] iommu: Adding device 590fff4.scaler to group 0
      [    0.326773] iommu: Adding device 5910400.scaler to group 0
      [    0.332938] iommu: Adding device 59103fc.scaler to group 0
      [    0.339072] iommu: Adding device 59103f8.scaler to group 0
      [    0.345224] iommu: Adding device 59103f4.scaler to group 0
      [    0.351577] iommu: Adding device 5910800.scaler to group 0
      [    0.357735] iommu: Adding device 59107fc.scaler to group 0
      [    0.363843] iommu: Adding device 59107f8.scaler to group 0
      [    0.370001] iommu: Adding device 59107f4.scaler to group 0
      [    0.376355] iommu: Adding device 5910c00.scaler to group 0
      [    0.382509] iommu: Adding device 5910bfc.scaler to group 0
      [    0.388642] iommu: Adding device 5910bf8.scaler to group 0
      [    0.394838] iommu: Adding device 5910bf4.scaler to group 0
      [    0.443643] pwm module init!
      [    0.453013] sunxi-pm debug v3.10
      [    0.458485] SCSI subsystem initialized
      [    0.463793] usbcore: registered new interface driver usbfs
      [    0.469897] usbcore: registered new interface driver hub
      [    0.475781] usbcore: registered new device driver usb
      [    0.481373] sunxi_i2c_adap_init()2754 - init
      [    0.486642] sunxi_i2c_probe()2449 - [i2c4] twi_drv_used = 0
      [    0.492328] sunxi_i2c_probe()2456 - [i2c4] twi_pkt_interval = 0
      [    0.498572] twi_regulator_request()653 - [i2c4] regulator not found(isn't configured in dts)!
      [    0.507190] twi_request_gpio()469 - [i2c4] init name: (null)
      [    0.513993] axp20x-i2c 4-0034: AXP20x variant AXP2101 found
      [    0.535460] random: fast init done
      [    0.552341] axp20x-i2c 4-0034: AXP20X driver loaded
      [    0.559505] media: Linux media interface: v0.10
      [    0.564467] Linux video capture interface: v2.00
      [    0.571821] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
      [    0.579787] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
      [    0.587245] Advanced Linux Sound Architecture Driver Initialized.
      [    0.594781] Bluetooth: Core ver 2.22
      [    0.598846] NET: Registered protocol family 31
      [    0.603401] Bluetooth: HCI device and connection manager initialized
      [    0.610005] Bluetooth: HCI socket layer initialized
      [    0.614978] Bluetooth: L2CAP socket layer initialized
      [    0.620282] Bluetooth: SCO socket layer initialized
      [    0.627563] G2D: rcq version initialized.major:251
      [    0.634575] clocksource: Switched to clocksource arch_sys_counter
      [    0.666448] sunxi udc is no enable
      [    0.671008] udc_init,0
      [    0.675006] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
      [    0.683716] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
      [    0.692211] NET: Registered protocol family 2
      [    0.724730] TCP established hash table entries: 16 (order: -6, 64 bytes)
      [    0.731561] TCP bind hash table entries: 16 (order: -6, 64 bytes)
      [    0.737771] TCP: Hash tables configured (established 16 bind 16)
      [    0.743938] UDP hash table entries: 256 (order: 0, 4096 bytes)
      [    0.749935] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
      [    0.756532] NET: Registered protocol family 1
      [    0.764679] workingset: timestamp_bits=29 max_order=17 bucket_order=0
      [    0.787369] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.798134] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      [    0.806170] io scheduler noop registered
      [    0.810212] io scheduler deadline registered
      [    0.815113] io scheduler cfq registered (default)
      [    0.821532] [DISP]disp_module_init
      [    0.826606] [DISP] disp_init,line:2340:
      [    0.830287] smooth display screen:0 type:1 mode:4
      [    0.836189] lcd 0, driver_name ,  panel_name default_lcd
      [    0.841623] lcd 0, driver_name ,  panel_name he0801a068
      [    0.847114] lcd 0, driver_name ,  panel_name inet_dsi_panel
      [    0.852801] lcd 0, driver_name ,  panel_name lq101r1sx03
      [    0.858272] lcd 0, driver_name ,  panel_name WilliamLcd
      [    0.863604] lcd 0, driver_name ,  panel_name bp101wx1
      [    0.868782] lcd 0, driver_name ,  panel_name k101im2qa04
      [    0.874190] lcd 0, driver_name ,  panel_name t050k589
      [    0.879390] lcd 0, driver_name ,  panel_name kd080d24
      [    0.884538] lcd 0, driver_name ,  panel_name icn6202
      [    0.889631] lcd 0, driver_name ,  panel_name super_lcd_driver
      [    0.895613] display_fb_request,fb_id:0
      [    0.899489] [DISP] display_fb_request,line:2196:
      [    0.903943] invalid paras xres(0), yres(0) bpp(32)
      [    0.909726] [DISP] de_fcm_set_para,line:491:
      [    0.913838] fcm lut 0 not find, auto retry after init
      [    0.919933] [DISP]disp_module_init finish
      [    0.927667] [DISP] de_fcm_set_para,line:491:
      [    0.932343] fcm lut 0 not find, auto retry after init
      [    0.938712] [DISP] de_fcm_set_para,line:491:
      [    0.942848] fcm lut 0 not find, auto retry after init
      [    0.951074] uart0: ttyS0 at MMIO 0x2500000 (irq = 289, base_baud = 1500000) is a SUNXI
      [    0.951096] sw_console_setup()2050 - console setup baud 115200 parity n bits 8, flow n
      [    0.967531] console [ttyS0] enabled
      [    0.975103] [DISP] lcd_clk_config,line:702:
      [    0.975104] disp 0, clk: pll(0),clk(0),dclk(0) dsi_rate(0)
      [    0.975104]      clk real:pll(297000000),clk(420000000),dclk(70000000) dsi_rate(0)
      [    1.012092] bootconsole [earlycon0] disabled
      [    1.022738] uart3: ttyS3 at MMIO 0x2500c00 (irq = 290, base_baud = 1500000) is a SUNXI
      [    1.033000] misc dump reg init
      [    1.037354] npu[1][1] vipcore, platform driver device=0xdf5ee410
      [    1.044152] npu[1][1] vipcore irq number is 291.
      [    1.049514] gckvip_drv_adjust_param 232 SUCCESS
      [    1.054717] Want set pclk rate(504000000) support(504000000) real(504000000)
      [    1.062669] Want set mclk rate(504000000) support(504000000) real(504000000)
      [    1.070671] npu[1][1] This device support 64bits DMA
      [    1.076733] npu[1][1] core_0, request irqline=291, name=vipcore_0
      [    1.083626] npu[1][1] =======vipcore parameter=====
      [    1.089305] npu[1][1] registerMemBase     0x03050000,
      [    1.095116] npu[1][1] registerMemSize     0x00020000,
      [    1.100868] npu[1][1] irqLine             0x00000123,
      [    1.106652] npu[1][1] contiguousSize      0x02000000
      [    1.112211] npu[1][1] contiguousBase      0x30000000
      [    1.117835] npu[1][1] vipContiguousBase   0x0
      [    1.122714] npu[1][1] drvType             0x00000000
      [    1.128303] npu[1][1] AXISramSize         0x00000000
      [    1.133862] npu[1][1] AXISramBaseAddress  0x00000000
      [    1.139447] npu[1][1] VIPSramSize         0x00020000
      [    1.145019] npu[1][1] VIPSramBaseAddress  0x00400000
      [    1.150580] npu[1][1] sysHeapSize         0x00200000
      [    1.156147] npu[1][1] ===============================
      [    1.161883] npu[1][1] VIPLite driver version 1.8.0.0-AW-2022-04-21
      [    1.169903] sun8iw21p1-pinctrl pio: expect_func as:fanout0, but muxsel(3) is func:clk
      [    1.178986] sunxi-wlan soc@03000000:wlan@0: wlan_busnum (1)
      [    1.185300] sunxi-wlan soc@03000000:wlan@0: wlan power voltage (3300000)
      [    1.192808] sunxi-wlan soc@03000000:wlan@0: wlan io voltage (3300000)
      [    1.200065] sunxi-wlan soc@03000000:wlan@0: wlan_power_num (1)
      [    1.206674] sunxi-wlan soc@03000000:wlan@0: wlan_power_name (axp2101-dcdc1)
      [    1.214476] sunxi-wlan soc@03000000:wlan@0: io_regulator_name (axp2101-dcdc1)
      [    1.222541] sunxi-wlan soc@03000000:wlan@0: wlan_regon gpio=239  mul-sel=1  pull=1  drv_level=2  data=0
      [    1.233133] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
      [    1.240193] sunxi-wlan soc@03000000:wlan@0: wlan_hostwake gpio=199  mul-sel=14  pull=1  drv_level=2  data=0
      [    1.251223] sunxi-wlan soc@03000000:wlan@0: clk_name ()
      [    1.258543] libphy: Fixed MDIO Bus: probed
      [    1.263897] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.271626] get ehci0-controller, regulator_io is no nocare
      [    1.277940] get ehci0-controller wakeup-source is fail.
      [    1.283791] sunxi ehci0-controller is no enable
      [    1.288985] sunxi-ehci 4101000.ehci0-controller: init_sunxi_hci is fail
      [    1.296458] sunxi-ehci: probe of 4101000.ehci0-controller failed with error -1
      [    1.304965] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    1.312239] get ohci0-controller, regulator_io is no nocare
      [    1.318646] get ohci0-controller wakeup-source is fail.
      [    1.324498] sunxi ohci0-controller is no enable
      [    1.329624] sunxi-ohci 4101000.ohci0-controller: init_sunxi_hci is fail
      [    1.337091] sunxi-ohci: probe of 4101000.ohci0-controller failed with error -1
      [    1.345748] usbcore: registered new interface driver uas
      [    1.352043] usbcore: registered new interface driver usb-storage
      [    1.358992] usbcore: registered new interface driver ums-alauda
      [    1.365906] usbcore: registered new interface driver ums-cypress
      [    1.372871] usbcore: registered new interface driver ums-datafab
      [    1.379864] usbcore: registered new interface driver ums_eneub6250
      [    1.387107] usbcore: registered new interface driver ums-freecom
      [    1.394095] usbcore: registered new interface driver ums-isd200
      [    1.400941] usbcore: registered new interface driver ums-jumpshot
      [    1.408042] usbcore: registered new interface driver ums-karma
      [    1.414901] usbcore: registered new interface driver ums-onetouch
      [    1.421989] usbcore: registered new interface driver ums-realtek
      [    1.428946] usbcore: registered new interface driver ums-sddr09
      [    1.435863] usbcore: registered new interface driver ums-sddr55
      [    1.442742] usbcore: registered new interface driver ums-usbat
      [    1.449504] usb_serial_number:20080411
      [    1.454121] get ctp_power is fail, -22
      [    1.458604] get ctp_power_ldo_vol is fail, -22
      [    1.463582] sunxi_ctp_startup: ctp_power_io is invalid.
      [    1.469558] fw_index:22
      [    1.510946] sunxi_i2c_do_xfer()1974 - [i2c4] incomplete xfer (status: 0x20, dev addr: 0x40)
      [    1.527021] input: axp2101-pek as /devices/platform/soc/twi4/i2c-4/4-0034/axp2101-pek.0/input/input0
      [    1.538497] sunxi_gpadc_init,1949, success
      [    1.543443] sunxi_gpadc_setup: get channel scan data failed
      [    1.551148] input: sunxi-gpadc0 as /devices/virtual/input/input1
      [    1.560069] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
      [    1.567266] sunxi-rtc rtc: RTC enabled
      [    1.571538] fix to cold boot, save boot reason
      [    1.577014] i2c /dev entries driver
      [    1.581524] sunxi cedar version 0.1
      [    1.586037] VE: install start!!!
      [    1.586037]
      [    1.591407] VE: cedar-ve the get irq is 292
      [    1.596320] VE: regs_csi = e086b000
      [    1.600813] VE: ve_debug_proc_info:c0b83888, data:df63c000, lock:c0b83910, flag: 1
      [    1.600813]
      [    1.611208] VE: install end!!!
      [    1.611208]
      [    1.616758] google_vp9: sunxi google vp9 version 0.1
      [    1.626685] axp2101_charger: read chipid = 4a
      [    1.626685]
      [    1.640676] thermal thermal_zone3: power_allocator: sustainable_power will be estimated
      [    1.672086] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    1.681741] Bluetooth: HCI UART driver ver 2.2.d448471.20181218-163903
      [    1.689487] Bluetooth: HCI UART protocol H4 registered
      [    1.695871] Bluetooth: HCI H4 protocol initialized
      [    1.701979] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.07
      [    1.710873] axp2101_charger: the gauge have been reset, need to reload param
      [    1.710873]
      [    1.720655] bt_fdi debugfs_init
      [    1.724345] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 900000 KHz
      [    1.764632] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 912000 KHz
      [    1.805185] cpuidle: enable-method property 'psci' found operations
      [    1.814281] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
      [    1.823440] sunxi-mmc sdc2: ***ctl-spec-caps*** 308
      [    1.829804] sunxi-mmc sdc2: No vdmmc regulator found
      [    1.835502] sunxi-mmc sdc2: No vd33sw regulator found
      [    1.841172] sunxi-mmc sdc2: No vd18sw regulator found
      [    1.846936] sunxi-mmc sdc2: No vq33sw regulator found
      [    1.852605] sunxi-mmc sdc2: No vq18sw regulator found
      [    1.858715] sunxi-mmc sdc2: set host busy
      [    1.863280] mmc:failed to get gpios
      [    1.867545] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    1.904625] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    1.944633] sunxi-mmc sdc2: detmode:alway in(non removable)
      [    1.944654] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    1.953010] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    1.954074] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    1.964910] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    1.964975] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    1.977794] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    2.023073] usbcore: registered new interface driver usbhid
      [    2.029602] usbhid: USB HID core driver
      [    2.037316] Netfilter messages via NETLINK v0.30.
      [    2.043438] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
      [    2.050503] ctnetlink v0.93: registering with nfnetlink.
      [    2.057014] ip_tables: (C) 2000-2006 Netfilter Core Team
      [    2.064051] NET: Registered protocol family 10
      [    2.070508] NET: Registered protocol family 17
      [    2.075776] NET: Registered protocol family 15
      [    2.080873] Bluetooth: RFCOMM TTY layer initialized
      [    2.086550] Bluetooth: RFCOMM socket layer initialized
      [    2.092361] Bluetooth: RFCOMM ver 1.11
      [    2.097713] Registering SWP/SWPB emulation handler
      [    2.110549] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:06 UTC (6)
      [    2.119901] clk: Not disabling unused clocks
      [    2.124818] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    2.135973] usb-vbus: disabling
      [    2.139811] axp2101-dcdc2: disabling
      [    2.144502] axp2101-rtcldo1: disabling
      [    2.149064] axp2101-aldo2: disabling
      [    2.154002] axp2101-aldo3: disabling
      [    2.158075] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing MMC-HS(SDR20) dt B
      [    2.168961] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 22 width 1 timing MMC-HS(SDR20) dt B
      [    2.180125] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS(SDR20) dt B
      [    2.191552] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 22 width 8 timing MMC-DDR52 dt B
      [    2.202828] mmc0: new DDR MMC card at address 0001
      [    2.209397] mmcblk0: mmc0:0001 AT2S38 7.23 GiB
      [    2.209682] mmcblk0boot0: mmc0:0001 AT2S38 partition 1 4.00 MiB
      [    2.215106] mmcblk0boot1: mmc0:0001 AT2S38 partition 2 4.00 MiB
      [    2.228696] mmcblk0rpmb: mmc0:0001 AT2S38 partition 3 4.00 MiB
      [    2.237271]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
      [    2.242414] axp2101-aldo4: disabling
      [    2.252132] axp2101-bldo2: disabling
      [    2.264240] axp2101-dldo2: disabling
      [    2.270079] axp2101-cpusldo: disabling
      [    2.274859] ALSA device list:
      [    2.278190]   No soundcards found.
      [    2.285939] VFS: Mounted root (squashfs filesystem) readonly on device 179:4.
      [    2.296172] devtmpfs: mounted
      [    2.301213] Freeing unused kernel memory: 1024K
      [    2.306453] will run init ...
      [    2.914440] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
      [    2.928934] EXT4-fs (mmcblk0p8): mounted filesystem with journalled data mode. Opts: data=journal
      Cannot parse config file '/etc/fw_env.config': No such file or directory
      starting pid 784, tty '': '/etc/preinit'
      starting pid 785, tty '': '/bin/mount -t proc proc /proc'
      starting pid 786, tty '': '/bin/mount -t tmpfs tmpfs /run'
      starting pid 787, tty '': '/bin/mount -o remount,rw /'
      starting pid 788, tty '': '/bin/mkdir -p /dev/pts'
      starting pid 789, tty '': '/bin/mkdir -p /dev/shm'
      starting pid 790, tty '': '/bin/mount -a'
      starting pid 791, tty '': '/bin/hostname -F /etc/hostname'
      starting pid 792, tty '': '/etc/init.d/rcS boot'
      mke2fs 1.45.6 (20-Mar-2020)
      /dev/mmcblk0p8 is mounted; will not make a filesystem here!
      [    3.217343] ======== XRADIO WIFI OPEN ========
      [    3.222344] [XRADIO] Driver Label:XR_V02.16.91 _HT40_01.33  Jul 22 2022 10:28:12
      [    3.231116] [XRADIO] Allocated hw_priv @ df664c80
      [    3.236623] [XRADIO_ERR] Access_file failed, path:/data/misc/wifi/xr_wifi.conf!
      [    3.245626] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
      [    3.252918] sunxi-wlan soc@03000000:wlan@0: check wlan wlan_power voltage: 3300000
      [    3.262850] sunxi-wlan soc@03000000:wlan@0: check wlan io_regulator voltage: 3300000
      [    3.381650] sunxi_hosts[1] should not be null
      [    3.386353] [XRADIO] Detect SDIO card 1
      [    5.555404] sunxi_hosts[1] should not be null
      [    5.560099] [XRADIO] Remove SDIO card 1
      [    5.574614] [SBUS_ERR] sdio probe timeout!
      [    5.579206] [XRADIO_ERR] sbus_sdio_init failed
      [    5.585256] ======== XRADIO WIFI OPEN ========
      [    5.590252] [XRADIO] Driver Label:XR_V02.16.91 _HT40_01.33  Jul 22 2022 10:28:12
      [    5.598857] [XRADIO] Allocated hw_priv @ defacc80
      [    5.604175] [XRADIO_ERR] Access_file failed, path:/data/misc/wifi/xr_wifi.conf!
      [    5.613123] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
      [    5.620528] sunxi-wlan soc@03000000:wlan@0: check wlan wlan_power voltage: 3300000
      [    5.630479] sunxi-wlan soc@03000000:wlan@0: check wlan io_regulator voltage: 3300000
      [    5.749287] sunxi_hosts[1] should not be null
      [    5.753981] [XRADIO] Detect SDIO card 1
      [    7.875419] sunxi_hosts[1] should not be null
      [    7.880114] [XRADIO] Remove SDIO card 1
      [    7.894617] [SBUS_ERR] sdio probe timeout!
      [    7.899210] [XRADIO_ERR] sbus_sdio_init failed
      insmod: can't insert '/lib/modules/4.9.191/xradio_wlan.ko': Operation timed out
      ------run rc.final file-----
      Load mpp modules
      insmod: can't insert '/lib/modules/4.9.191/sunxi_aio.ko': No such file or directory
      insmod: can't insert '/lib/modules/4.9.191/sunxi_eise.ko': No such file or directory
      Starting logging: start-stop-daemon: unrecognized option: exec
      OK
      Starting audio: Failed to open mixer
      Successfully play boot music
      mkdir: can't create directory '/dev/pts': File exists
      mkdir: can't create directory '/dev/shm': File exists
      Initializing random number generator... failed to open for pcm 0,0
      [    8.184488] random: dd: uninitialized urandom read (512 bytes read)
      done.
      Starting network: Failed to connect to ubus
      /sbin/ifup: line 43: /sbin/wifi: not found
      FAIL
      ifconfig: invalid hw-addr 00:
      udhcpc: SIOCGIFINDEX: No such device
      Starting telnetd: OK
      enable android usb
      insmod: can't insert '/lib/modules/4.9.191/sunxi_usb_udc.ko': No such file or directory
      insmod: can't insert '/lib/modules/4.9.191/sunxi_usbc.ko': No such file or directory
      [    8.563962] random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
      [    8.581147] random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
      service: file '/usr/sbin/dbus-daemon' is not executable
      [    8.632333] file system registered
      Starting wifi_daemon....: [    8.683470] read descriptors
      [    8.694827] read strings
      1970-01-01 00:00:13:163: WMG_INFO [wifi_daemon.c:main:817]:  debug log level is: 3
      1970-01-01 00:00:13:163: WMG_INFO [wifi_daemon.c:main:819]:  now set to debug level: 6
      [ACT D][ring_buff_init,27]enter
      [ACT D][ring_buff_start,173]ring buffer start enter
      [ACT D][ring_buff_start,187]ring buffer start quit
      1970-01-01 00:00:15:174: WMG_DEBUG [wifi_daemon.c:cmd_handle_thread:702]:  get cmd: o sta
      1970-01-01 00:00:15:174: WMG_DEBUG [wifi_daemon.c:cmd_handle_o:49]:  cmd handle o: sta
      1970-01-01 00:00:15:174: WMG_INFO [wifi_daemon.c:cmd_handle_o:51]:  open sta mode
      1970-01-01 00:00:15:174: WMG_INFO [src/wmg_sta.c:sta_mode_init:363]:  sta mode init now
      1970-01-01 00:00:15:174: WMG_INFO [src/os/linux/linux_wpa.c:linux_supplicant_init:1355]:  linux supplicant init now
      1970-01-01 00:00:15:174: WMG_INFO [src/wmg_ap.c:ap_mode_init:216]:  ap mode init now
      1970-01-01 00:00:15:174: WMG_INFO [[   10.838876] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
      src/os/linux/linux_hapd.c:linux_ap_hapd_init:754]:  linux hostapd init now
      1970-01-01 00:00:15:174: WMG_INFO [src/wmg_monitor.c:monitor_mode_init:206]:  monitor mode init now
      1970-01-01 00:00:15:174: WMG_INFO [src/os/linux/linux_nl.c:linux_monitor_nl_init:250]:  linux monitor nl init now
      1970-01-01 00:00:15:175: WMG_DEBUG [src/os/linux/linux_nl.c:linux_monitor_nl_init:255]:  nl80211 init success
      1970-01-01 00:00:15:175: WMG_DEBUG [src/wmg_common.c:wifimg_init:143]:  wifi_manager initialize, version: 2.0.1
      Copyright (c) 2019-2025 Allwinner Technology Co., Ltd. ALL rights reserved
      1970-01-01 00:00:15:175: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:256]:  switch wifi mode from current_mode 'unknown' to new_mode 'station'
      1970-01-01 00:00:15:175: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:260]:  switch_mode_bitmap:0x1
      1970-01-01 00:00:15:175: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:261]:  current_mode_bitmap:0x0
      1970-01-01 00:00:15:175: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:264]:  disable_mode_bitmap:0x0
      1970-01-01 00:00:15:175: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:294]:  enable_mode_bitmap:0x1
      1970-01-01 00:00:15:176: WMG_DUMP [src/wmg_sta.c:sta_mode_enable:412]: wifi station enabling...
      /etc/init.d/rcS: /etc/init.d/rc.final: line 36: powerkey_daemon: not found
      1970-01-01 00:00:15:206: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: hostapd not exist
      1970-01-01 00:00:15:253: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: wpa_supplicant not exist
      1970-01-01 00:00:15:254: WMG_DEBUG [src/os/linux/linux_wpa.c:linux_connect_to_supplicant:1429]:  wpa_supplicant is not running, need to start it
      starting pid 1002, tty '/dev/console': '-/bin/sh'
      BusyBox v1.33.2 (2022-07-08 07:13:49 UTC) built-in shell (ash)
      swu_param: ####
      swu_software: ####
      swu_mode: ####
      ------run profile file-----
       Tina Linux (5.0, r0-7277fac)
      root@TinaLinux:/# [   11.093091] random: wpa_supplicant: uninitialized urandom read (3 bytes read)
      [   11.101375] random: wpa_supplicant: uninitialized urandom read (1024 bytes read)
      1970-01-01 00:00:16:282: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:29]: wpa_supplicant exist
      1970-01-01 00:00:16:282: WMG_DEBUG [src/os/linux/linux_wpa.c:start_supplicant:359]:  start wpa_supplicant times 1 success
      1970-01-01 00:00:16:283: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:linux_connect_to_supplicant:1436]: start wpa_supplicant success
      1970-01-01 00:00:16:283: WMG_ERROR [src/os/linux/linux_wpa.c:linux_connect_to_supplicant:1445]:  wpa_supplicant socket interface not exists
      1970-01-01 00:00:16:283: WMG_ERROR [src/wmg_sta.c:sta_mode_enable:416]:  failed to connect to wpa_supplicant
      1970-01-01 00:00:16:283: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:297]:  wifi sta mode enable faile
      1970-01-01 00:00:16:283: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:320]:  switch after current_mode_bitmap:0x0
      1970-01-01 00:00:16:283: WMG_ERROR [src/wmg_common.c:wifimg_switch_mode:327]:  switch mode faile
      1970-01-01 00:00:16:283: WMG_ERROR [src/wifimg.c:__wifi_on:34]:  failed to switch wifi mode
      1970-01-01 00:00:16:283: WMG_ERROR [wifi_daemon.c:cmd_handle_o:58]:  wifi on sta mode failed
      [   12.391968] random: crng init done
      看了log没有看出什么比较有用的信息,希望有大佬可以支支招,感谢。难道说还是硬件有问题?
      • DAIZEBIN
        DAIZEBIN LV 7 @Negro 最后由 编辑
        @negro 能否看一下你在dts里面添加的内容,看启动log,好像是存在一些其他外设初始化,另外就是能否提供一下你烧录的这份固件,对比一下
        • N
          Negro LV 5 @DAIZEBIN 最后由 编辑
          @daizebin 哎呀,万分抱歉。真的是硬件问题。debug那边电路图封装弄错了导致debug接口出问题了。感谢回复😊
          • DAIZEBIN
            @negro 难怪,启动log里面提示你的一些设备初始化不成功,但不确定是不是这个引起的🙌 :
            • N
              @daizebin 是的,因为有一些硬件做了点小改动可能导致初始化不成功,我也为了排查问题disabled了一些不相关的节点,所以会有一些报错。
                DOT小文哥 LV 8 最后由 编辑
                想看看你自己作的板子,可以拍给大家分享一下吗
                • N
                  Negro LV 5 @xiaowenge 最后由 编辑
                  @xiaowenge 不好意思哦,这个是公司做的,不是我个人做的。涉及到一些保密的东西,没办法放出来。😥
                    DOT小文哥 LV 8 @Negro 最后由 编辑
                    @negro 在 自制的V853板子,串口无法输入,求帮助。 中说:
                    那坐等产品上市拆机
