    R329 SPI Nand 分区问题
    A Series
    5000
    • R
      ROIDMI LV 4 最后由 编辑
      系统启动到这一步就停了,看上去像是分区出问题了?求解决思路。
      [    2.481794] UBI error: cannot open mtd sys, error -2
      [    2.487198] UBI: block: can't open volume on ubi0_-1, err=-19get usb_detect_mode is fail, 22
      [    2.497659] sunxi-rtc rtc: setting system clock to 1970-01-01 12:58:03 UTC (46683)
      [    2.507102] ALSA device list:
      [    2.510437]   No soundcards found.
      [    2.514590] VFS: Cannot open root device "ubiblock0_5" or unknown-block(0,0): error -6
      [    2.523469] Please append a correct "root=" boot option; here are the available partitions:
      [    2.532847] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [    2.542114] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.9.191 #21
      [    2.548941] Hardware name: sun50iw11 (DT)
      [    2.553427] Call trace:
      [    2.556175] [<ffffff8008087938>] dump_backtrace+0x0/0x204
      [    2.562231] [<ffffff8008087b50>] show_stack+0x14/0x1c
      [    2.567894] [<ffffff80082928ec>] dump_stack+0x88/0xb0
      [    2.573552] [<ffffff8008110bc8>] panic+0x120/0x358
      [    2.578921] [<ffffff80087d1210>] mount_block_root+0x268/0x330
      [    2.585358] [<ffffff80087d1348>] mount_root+0x70/0x80
      [    2.591013] [<ffffff80087d14bc>] prepare_namespace+0x164/0x174
      [    2.597547] [<ffffff80087d0dd0>] kernel_init_freeable+0x150/0x18c
      [    2.604374] [<ffffff800861e5d0>] kernel_init+0x10/0xf8
      [    2.610137] [<ffffff8008083180>] ret_from_fork+0x10/0x50
      [    2.616086] SMP: stopping secondary CPUs
      [    2.620515] Kernel Offset: disabled
      [    2.624433] Memory Limit: none
      [    2.627859] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
        whycan晕哥 LV 9 @roidmi 最后由 编辑
        @roidmi
        贴出全部日志
        R 1 条回复 最后回复 回复 引用 分享 0
        • R
          ROIDMI LV 4 @whycan 最后由 编辑
          @whycan c756d259-ea4a-4b94-b923-d6cf26435a46-error.log
          帮忙看下 谢谢
            [    0.795463] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
            [    0.802712] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211125
            [    0.810597] sunxi-spinand-phy: not detect any munufacture from id table
            [    0.818054] sunxi-spinand-phy: get spi-nand Model from fdt fail
            [    0.824704] sunxi-spinand-phy: get phy info from fdt fail
            [    0.830762] sunxi-spinand-phy: not detect munufacture from fdt
            [    0.837414] sunxi-spinand-phy: detect munufacture from id table: GD
            [    0.844453] sunxi-spinand-phy: get spi-nand Model from fdt fail
            [    0.851095] sunxi-spinand-phy: get phy info from fdt fail
            [    0.857156] sunxi-spinand-phy: not detect munufacture from fdt
            [    0.863700] sunxi-spinand-phy: not match spinand: 52c852c8 52c852c8
            在ID表里没有这个NAND的料号,not match spinand: 52c852c8 52c852c8
            参考:一个补丁,让D1-H的SDK支持T113芯片 https://bbs.aw-ol.com/topic/2027/share/18
            • R
              ROIDMI LV 4 @YuzukiTsuru 最后由 编辑
              @yuzukitsuru
              id.c里面是有这个料的,id是c852, log日志里是52c8 52c8 懵了😢 求指点
