    测试GigaDevice SPINAND
    3989
      Lts52341314 LV 5 最后由 编辑
      试了GD5F2GQ5UEYIGR和GD5F4GQ6UEYIG两款芯片,连续换了好几片,日志都是全部坏块
      [987]fes begin commit:88480af
      [990]set pll start
      [992]fix vccio detect value:0xc0
      [995]periph0 has been enabled
      [998]set pll end
      [999][pmu]: bus read error
      [1002]board init ok
      [1003]beign to init dram
      [1006]ZQ value = 0x2f
      [1008]get_pmu_exist() = -1
      [1010]ddr_efuse_type: 0xa
      [1013]trefi:7.8ms
      [1015][AUTO DEBUG] single rank and full DQ!
      [1019]ddr_efuse_type: 0xa
      [1021]trefi:7.8ms
      [1024][AUTO DEBUG] rank 0 row = 13
      [1027][AUTO DEBUG] rank 0 bank = 4
      [1030][AUTO DEBUG] rank 0 page size = 2 KB
      [1034]DRAM BOOT DRIVE INFO: V0.33
      [1037]DRAM CLK = 528 MHz
      [1039]DRAM Type = 2 (2:DDR2,3:DDR3)
      [1043]DRAMC read ODT  off.
      [1045]DRAM ODT off.
      [1047]ddr_efuse_type: 0xa
      [1050]DRAM SIZE =64 M
      [1052]dram_tpr4:0x0
      [1054]PLL_DDR_CTRL_REG:0xf8002b00
      [1057]DRAM_CLK_REG:0xc0000000
      [1059][TIMING DEBUG] MR2= 0x0
      [1064]DRAM simple test OK.
      [1067]init dram ok
      U-Boot 2018.05-g24521d6-dirty (Sep 09 2022 - 18:55:37 +0800) Allwinner Technology
      [04.658]DRAM:  64 MiB
      [04.663]Relocation Offset is: 01ee7000
      [04.688]secure enable bit: 0
      [04.693]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [04.700]flash init start
      [04.702]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [04.710][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
      [04.719][mmc]: get sdc_type fail and use default host:tm4.
      [04.750][mmc]: Is not Boot mode!
      [04.753][mmc]: SUNXI SDMMC Controller Version:0x50310
      [04.764][mmc]: ************Try SD card 2************
      [04.769][mmc]: mmc 2 cmd timeout 100 status 100
      [04.773][mmc]: smc 2 err, cmd 8,  RTO
      [04.777][mmc]: mmc 2 close bus gating and reset
      [04.782][mmc]: mmc 2 cmd timeout 100 status 100
      [04.786][mmc]: smc 2 err, cmd 55,  RTO
      [04.789][mmc]: mmc 2 close bus gating and reset
      [04.794][mmc]: ************Try MMC card 2************
      [04.803][mmc]: mmc 2 cmd timeout 100 status 100
      [04.807][mmc]: smc 2 err, cmd 1,  RTO
      [04.810][mmc]: mmc 2 close bus gating and reset
      [04.814][mmc]: Card did not respond to voltage select!
      [04.819][mmc]: ************SD/MMC 2 init error!************
      [04.825][mmc]: mmc init product failed
      MMC init failed
      try emmc fail
      [04.841]sunxi-spinand: AW SPINand MTD Layer Version: 1.8 20220106
      [04.846]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211217
      [04.909]sunxi-spinand-phy: request spi0 gpio ok
      [04.913]sunxi-spinand-phy: request general tx dma channel ok!
      [04.918]sunxi-spinand-phy: request general rx dma channel ok!
      [04.924]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [04.928]sunxi-spinand-phy: init spic0 clk ok
      [04.932]sunxi-spinand-phy: detect munufacture from id table: GD
      [04.938]sunxi-spinand-phy: detect spinand id: ffff52c8 ffffffff
      [04.944]sunxi-spinand-phy: ========== arch info ==========
      [04.949]sunxi-spinand-phy: Model:               GD5F2GQ5UEYIGR
      [04.954]sunxi-spinand-phy: Munufacture:         GD
      [04.959]sunxi-spinand-phy: DieCntPerChip:       1
      [04.963]sunxi-spinand-phy: BlkCntPerDie:        2048
      [04.968]sunxi-spinand-phy: PageCntPerBlk:       64
      [04.972]sunxi-spinand-phy: SectCntPerPage:      4
      [04.977]sunxi-spinand-phy: OobSizePerPage:      64
      [04.981]sunxi-spinand-phy: BadBlockFlag:        0x0
      [04.986]sunxi-spinand-phy: OperationOpt:        0x7
      [04.991]sunxi-spinand-phy: MaxEraseTimes:       50000
      [04.995]sunxi-spinand-phy: EccFlag:             0x1
      [05.000]sunxi-spinand-phy: EccType:             7
      [05.004]sunxi-spinand-phy: EccProtectedType:    2
      [05.009]sunxi-spinand-phy: ========================================
      [05.015]sunxi-spinand-phy:
      [05.017]sunxi-spinand-phy: ========== physical info ==========
      [05.023]sunxi-spinand-phy: TotalSize:    256 M
      [05.027]sunxi-spinand-phy: SectorSize:   512 B
      [05.031]sunxi-spinand-phy: PageSize:     2 K
      [05.035]sunxi-spinand-phy: BlockSize:    128 K
      [05.039]sunxi-spinand-phy: OOBSize:      64 B
      [05.043]sunxi-spinand-phy: ========================================
      [05.049]sunxi-spinand-phy:
      [05.052]sunxi-spinand-phy: ========== logical info ==========
      [05.057]sunxi-spinand-phy: TotalSize:    256 M
      [05.061]sunxi-spinand-phy: SectorSize:   512 B
      [05.066]sunxi-spinand-phy: PageSize:     4 K
      [05.070]sunxi-spinand-phy: BlockSize:    256 K
      [05.074]sunxi-spinand-phy: OOBSize:      128 B
      [05.078]sunxi-spinand-phy: ========================================
      [05.094]sunxi-spinand-phy: set spic0 clk to 100 Mhz
      [05.098]sunxi-spinand-phy: block lock register: 0x00
      [05.103]sunxi-spinand-phy: feature register: 0x11
      [05.107]sunxi-spinand-phy: sunxi physic nand init end
      [05.118]Loading Environment from SUNXI_FLASH... OK
      [05.131]try to burn key
      [05.134]out of usb burn from boot: not need burn key
      [05.139]Net:   [05.140]No ethernet found.
      sunxi work mode=0x10
      run usb efex
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x14
      set address 0x14 ok
      set address 0x15
      set address 0x15 ok
      the 0 mbr table is ok
      the 1 mbr table is ok
      the 2 mbr table is ok
      the 3 mbr table is ok
      total mbr part 8
      part[0] classname :DISK
      part[0] addrlo    :0x800
      part[0] lenlo     :0x3f0
      part[0] user_type :32768
      part[0] keydata   :0
      part[0] ro        :0
      part[1] name      :env
      part[1] classname :DISK
      part[1] addrlo    :0xbf0
      part[1] lenlo     :0x1f8
      part[1] user_type :32768
      part[1] keydata   :0
      part[1] ro        :0
      part[2] name      :env-redund
      part[2] classname :DISK
      part[2] addrlo    :0xde8
      part[2] lenlo     :0x1f8
      part[2] user_type :32768
      part[2] keydata   :0
      part[2] ro        :0
      part[3] name      :boot
      part[3] classname :DISK
      part[3] addrlo    :0xfe0
      part[3] lenlo     :0x5000
      part[3] user_type :32768
      part[3] keydata   :0
      part[3] ro        :0
      part[4] name      :rootfs
      part[4] classname :DISK
      part[4] addrlo    :0x5fe0
      part[4] lenlo     :0xe600
      part[4] user_type :32768
      part[4] keydata   :0
      part[4] ro        :0
      part[5] name      :recovery
      part[5] classname :DISK
      part[5] addrlo    :0x145e0
      part[5] lenlo     :0x5780
      part[5] user_type :32768
      part[5] keydata   :0
      part[5] ro        :0
      part[6] classname :DISK
      part[6] addrlo    :0x19d60
      part[6] lenlo     :0x2800
      part[6] user_type :32768
      part[6] keydata   :0
      part[6] ro        :0
      part[7] name      :UDISK
      part[7] classname :DISK
      part[7] addrlo    :0x1c560
      part[7] lenlo     :0x0
      part[7] user_type :0
      part[7] keydata   :0
      part[7] ro        :0
      total part: 9
      mbr 0, 800, 8000
      boot-resource 1, 3f0, 8000
      env 2, 1f8, 8000
      env-redund 3, 1f8, 8000
      boot 4, 5000, 8000
      rootfs 5, e600, 8000
      recovery 6, 5780, 8000
      rootfs_data 7, 2800, 8000
      UDISK 8, 0, 0
      [08.406]erase blk 0 to blk 32
      [08.409]erase blk 0 failed with -110 back
      [08.413]sunxi-spinand-phy: erase phy blk 0 failed with -110 back
      [08.419]sunxi-spinand-phy: mark phy blk 0 page 0 as bad failed with -110 back
      [08.426]mark blk 0 as bad failed
      [08.429]blk 1 is bad, skip to erase
      [08.432]blk 2 is bad, skip to erase
      [08.435]blk 3 is bad, skip to erase
      [08.438]erase blk 4 failed with -110 back
      [08.442]sunxi-spinand-phy: erase phy blk 4 failed with -110 back
      [08.448]sunxi-spinand-phy: mark phy blk 4 page 0 as bad failed with -110 back
      [08.455]mark blk 4 as bad failed
      [08.458]blk 5 is bad, skip to erase
      [08.461]blk 6 is bad, skip to erase
      [08.464]blk 7 is bad, skip to erase
      [08.468]blk 8 is bad, skip to erase
      [08.471]blk 9 is bad, skip to erase
      [08.474]blk 10 is bad, skip to erase
      [08.477]blk 11 is bad, skip to erase
      [08.481]blk 12 is bad, skip to erase
      [08.484]blk 13 is bad, skip to erase
      [08.487]blk 14 is bad, skip to erase
      [08.491]blk 15 is bad, skip to erase
      [08.494]blk 16 is bad, skip to erase
      [08.497]blk 17 is bad, skip to erase
      [08.500]blk 18 is bad, skip to erase
      [08.504]blk 19 is bad, skip to erase
      [08.507]blk 20 is bad, skip to erase
      [08.510]blk 21 is bad, skip to erase
      [08.514]blk 22 is bad, skip to erase
      [08.517]blk 23 is bad, skip to erase
      [08.520]blk 24 is bad, skip to erase
      [08.523]blk 25 is bad, skip to erase
      [08.527]blk 26 is bad, skip to erase
      [08.530]blk 27 is bad, skip to erase
      [08.533]blk 28 is bad, skip to erase
      [08.537]blk 29 is bad, skip to erase
      [08.540]blk 30 is bad, skip to erase
      [08.543]blk 31 is bad, skip to erase
      need erase flash: 1
      [08.550]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
      defaults:
      mtdids  : nand0=nand
      [08.609]MTD info (4)
      [08.611]pagesize: 0x1000
      [08.613]blksize: 0x40000
      [08.616]num  offset     bytes      name
      [08.619]0    0x00000000 0x00100000 boot0
      [08.623]1    0x00100000 0x00300000 uboot
      [08.626]2    0x00400000 0x00100000 secure_storage
      [08.631]3    0x00500000 0x0fb00000 sys
      [08.634]ubi attach the last part of mtd device: NO.3
      [08.837]ubi0: attaching mtd4
      [08.840]ubi0 warning: scan_peb: bad ec header at pnum 2, drop this block
      [08.847]ubi0 warning: scan_peb: bad ec header at pnum 3, drop this block
      [08.856]ubi0 warning: scan_peb: bad ec header at pnum 19, drop this block
      [08.871]ubi0 warning: scan_peb: bad ec header at pnum 61, drop this block
      [08.886]ubi0 warning: scan_peb: bad ec header at pnum 108, drop this block
      [08.894]ubi0 warning: scan_peb: bad ec header at pnum 115, drop this block
      [08.905]ubi0 warning: scan_peb: bad ec header at pnum 136, drop this block
      [08.913]ubi0 warning: scan_peb: bad ec header at pnum 139, drop this block
      [08.922]ubi0 warning: scan_peb: bad ec header at pnum 152, drop this block
      [08.928]ubi0 warning: scan_peb: bad ec header at pnum 153, drop this block
      [08.936]ubi0 warning: scan_peb: bad ec header at pnum 156, drop this block
      [08.946]ubi0 warning: scan_peb: bad ec header at pnum 174, drop this block
      [08.954]ubi0 warning: scan_peb: bad ec header at pnum 185, drop this block
      [08.961]ubi0 warning: scan_peb: bad ec header at pnum 188, drop this block
      [08.970]ubi0 warning: scan_peb: bad ec header at pnum 199, drop this block
      [08.979]ubi0 warning: scan_peb: bad ec header at pnum 214, drop this block
      [08.987]ubi0 warning: scan_peb: bad ec header at pnum 218, drop this block
      [08.996]ubi0 warning: scan_peb: bad ec header at pnum 228, drop this block
      [09.003]ubi0 warning: scan_peb: bad ec header at pnum 234, drop this block
      [09.013]ubi0 warning: scan_peb: bad ec header at pnum 249, drop this block
      [09.024]ubi0 warning: scan_peb: bad ec header at pnum 276, drop this block
      [09.038]ubi0 warning: scan_peb: bad ec header at pnum 315, drop this block
      [09.049]ubi0 warning: scan_peb: bad ec header at pnum 335, drop this block
      [09.058]ubi0 warning: scan_peb: bad ec header at pnum 344, drop this block
      [09.065]ubi0 warning: scan_peb: bad ec header at pnum 347, drop this block
      [09.073]ubi0 warning: scan_peb: bad ec header at pnum 350, drop this block
      [09.080]ubi0 warning: scan_peb: bad ec header at pnum 356, drop this block
      [09.089]ubi0 warning: scan_peb: bad ec header at pnum 368, drop this block
      [09.098]ubi0 warning: scan_peb: bad ec header at pnum 383, drop this block
      [09.107]ubi0 warning: scan_peb: bad ec header at pnum 396, drop this block
      [09.114]ubi0 warning: scan_peb: bad ec header at pnum 398, drop this block
      [09.126]ubi0 warning: scan_peb: bad ec header at pnum 425, drop this block
      [09.133]ubi0 warning: scan_peb: bad ec header at pnum 434, drop this block
      [09.143]ubi0 warning: scan_peb: bad ec header at pnum 446, drop this block
      [09.151]ubi0 warning: scan_peb: bad ec header at pnum 453, drop this block
      [09.164]ubi0 warning: scan_peb: bad ec header at pnum 487, drop this block
      [09.172]ubi0 warning: scan_peb: bad ec header at pnum 492, drop this block
      [09.179]ubi0 warning: scan_peb: bad ec header at pnum 496, drop this block
      [09.187]ubi0 warning: scan_peb: bad ec header at pnum 502, drop this block
      [09.194]ubi0 warning: scan_peb: bad ec header at pnum 504, drop this block
      [09.202]ubi0 warning: scan_peb: bad ec header at pnum 509, drop this block
      [09.209]ubi0 warning: scan_peb: bad ec header at pnum 511, drop this block
      [09.220]ubi0 warning: scan_peb: bad ec header at pnum 536, drop this block
      [09.228]ubi0 warning: scan_peb: bad ec header at pnum 542, drop this block
      [09.238]ubi0 warning: scan_peb: bad ec header at pnum 560, drop this block
      [09.250]ubi0 warning: scan_peb: bad ec header at pnum 587, drop this block
      [09.259]ubi0 warning: scan_peb: bad ec header at pnum 601, drop this block
      [09.269]ubi0 warning: scan_peb: bad ec header at pnum 616, drop this block
      [09.277]ubi0 warning: scan_peb: bad ec header at pnum 623, drop this block
      [09.288]ubi0 warning: scan_peb: bad ec header at pnum 645, drop this block
      [09.297]ubi0 warning: scan_peb: bad ec header at pnum 657, drop this block
      [09.305]ubi0 warning: scan_peb: bad ec header at pnum 663, drop this block
      [09.314]ubi0 warning: scan_peb: bad ec header at pnum 675, drop this block
      [09.322]ubi0 warning: scan_peb: bad ec header at pnum 682, drop this block
      [09.330]ubi0 warning: scan_peb: bad ec header at pnum 692, drop this block
      [09.342]ubi0 warning: scan_peb: bad ec header at pnum 717, drop this block
      [09.350]ubi0 warning: scan_peb: bad ec header at pnum 724, drop this block
      [09.361]ubi0 warning: scan_peb: bad ec header at pnum 747, drop this block
      [09.370]ubi0 warning: scan_peb: bad ec header at pnum 759, drop this block
      [09.378]ubi0 warning: scan_peb: bad ec header at pnum 766, drop this block
      [09.385]ubi0 warning: scan_peb: bad ec header at pnum 769, drop this block
      [09.393]ubi0 warning: scan_peb: bad ec header at pnum 775, drop this block
      [09.403]ubi0 warning: scan_peb: bad ec header at pnum 792, drop this block
      [09.413]ubi0 warning: scan_peb: bad ec header at pnum 808, drop this block
      [09.421]ubi0 warning: scan_peb: bad ec header at pnum 821, drop this block
      [09.428]ubi0 warning: scan_peb: bad ec header at pnum 822, drop this block
      [09.436]ubi0 warning: scan_peb: bad ec header at pnum 830, drop this block
      [09.443]ubi0 warning: scan_peb: bad ec header at pnum 835, drop this block
      [09.452]ubi0 warning: scan_peb: bad ec header at pnum 844, drop this block
      [09.461]ubi0 warning: scan_peb: bad ec header at pnum 857, drop this block
      [09.469]ubi0 warning: scan_peb: bad ec header at pnum 864, drop this block
      [09.476]ubi0 warning: scan_peb: bad ec header at pnum 869, drop this block
      [09.485]ubi0 warning: scan_peb: bad ec header at pnum 881, drop this block
      [09.496]ubi0 warning: scan_peb: bad ec header at pnum 901, drop this block
      [09.503]ubi0 warning: scan_peb: bad ec header at pnum 902, drop this block
      [09.511]ubi0 warning: scan_peb: bad ec header at pnum 909, drop this block
      [09.519]ubi0 warning: scan_peb: bad ec header at pnum 919, drop this block
      [09.526]ubi0 warning: scan_peb: bad ec header at pnum 921, drop this block
      [09.533]ubi0 warning: scan_peb: bad ec header at pnum 922, drop this block
      [09.540]ubi0 warning: scan_peb: bad ec header at pnum 925, drop this block
      [09.551]ubi0 warning: scan_peb: bad ec header at pnum 948, drop this block
      [09.559]ubi0 warning: scan_peb: bad ec header at pnum 954, drop this block
      [09.566]ubi0 warning: scan_peb: bad ec header at pnum 958, drop this block
      [09.575]ubi0 warning: scan_peb: bad ec header at pnum 967, drop this block
      [09.585]ubi0 warning: scan_peb: bad ec header at pnum 987, drop this block
      [09.594]ubi0 warning: scan_peb: bad ec header at pnum 1002, drop this block
      [09.601]ubi0: scanning is finished
      [09.604]ubi0: empty MTD device detected
      [09.610]sunxi-spinand: [SPINAND]: erase block 1022 in addr 0xff80000 failed: -110
      [09.618]ubi0 warning: do_sync_erase: error -110 while erasing PEB 1002, retry
      [09.625]sunxi-spinand: [SPINAND]: erase block 1022 in addr 0xff80000 failed: -110
      [09.632]ubi0 warning: do_sync_erase: error -110 while erasing PEB 1002, retry
      [09.639]sunxi-spinand: [SPINAND]: erase block 1022 in addr 0xff80000 failed: -110
      [09.646]ubi0 warning: do_sync_erase: error -110 while erasing PEB 1002, retry
      [09.653]sunxi-spinand: [SPINAND]: erase block 1022 in addr 0xff80000 failed: -110
      [09.660]ubi0 error: do_sync_erase: cannot erase PEB 1002, error -110
      [09.666]sunxi-spinand: [SPINAND]: erase block 1007 in addr 0xfbc0000 failed: -110
      [09.673]ubi0 warning: do_sync_erase: error -110 while erasing PEB 987, retry
      [09.680]sunxi-spinand: [SPINAND]: erase block 1007 in addr 0xfbc0000 failed: -110
      [09.687]ubi0 warning: do_sync_erase: error -110 while erasing PEB 987, retry
      [09.694]sunxi-spinand: [SPINAND]: erase block 1007 in addr 0xfbc0000 failed: -110
      [09.701]ubi0 warning: do_sync_erase: error -110 while erasing PEB 987, retry
      [09.708]sunxi-spinand: [SPINAND]: erase block 1007 in addr 0xfbc0000 failed: -110
      [09.715]ubi0 error: do_sync_erase: cannot erase PEB 987, error -110
      [09.721]sunxi-spinand: [SPINAND]: erase block 987 in addr 0xf6c0000 failed: -110
      [09.728]ubi0 warning: do_sync_erase: error -110 while erasing PEB 967, retry
      [09.735]sunxi-spinand: [SPINAND]: erase block 987 in addr 0xf6c0000 failed: -110
      [09.742]ubi0 warning: do_sync_erase: error -110 while erasing PEB 967, retry
      [09.749]sunxi-spinand: [SPINAND]: erase block 987 in addr 0xf6c0000 failed: -110
      [09.756]ubi0 warning: do_sync_erase: error -110 while erasing PEB 967, retry
      [09.763]sunxi-spinand: [SPINAND]: erase block 987 in addr 0xf6c0000 failed: -110
      [09.770]ubi0 error: do_sync_erase: cannot erase PEB 967, error -110
      [09.776]sunxi-spinand: [SPINAND]: erase block 978 in addr 0xf480000 failed: -110
      [09.783]ubi0 warning: do_sync_erase: error -110 while erasing PEB 958, retry
      [09.790]sunxi-spinand: [SPINAND]: erase block 978 in addr 0xf480000 failed: -110
      [09.797]ubi0 warning: do_sync_erase: error -110 while erasing PEB 958, retry
      [09.803]sunxi-spinand: [SPINAND]: erase block 978 in addr 0xf480000 failed: -110
      [09.810]ubi0 warning: do_sync_erase: error -110 while erasing PEB 958, retry
      [09.817]sunxi-spinand: [SPINAND]: erase block 978 in addr 0xf480000 failed: -110
      [09.824]ubi0 error: do_sync_erase: cannot erase PEB 958, error -110
      [09.830]sunxi-spinand: [SPINAND]: erase block 974 in addr 0xf380000 failed: -110
      [09.837]ubi0 warning: do_sync_erase: error -110 while erasing PEB 954, retry
      [09.844]sunxi-spinand: [SPINAND]: erase block 974 in addr 0xf380000 failed: -110
      [09.851]ubi0 warning: do_sync_erase: error -110 while erasing PEB 954, retry
      [09.858]sunxi-spinand: [SPINAND]: erase block 974 in addr 0xf380000 failed: -110
      [09.865]ubi0 warning: do_sync_erase: error -110 while erasing PEB 954, retry
      [09.872]sunxi-spinand: [SPINAND]: erase block 974 in addr 0xf380000 failed: -110
      [09.879]ubi0 error: do_sync_erase: cannot erase PEB 954, error -110
      [09.885]sunxi-spinand: [SPINAND]: erase block 968 in addr 0xf200000 failed: -110
      [09.892]ubi0 warning: do_sync_erase: error -110 while erasing PEB 948, retry
      [09.899]sunxi-spinand: [SPINAND]: erase block 968 in addr 0xf200000 failed: -110
      [09.906]ubi0 warning: do_sync_erase: error -110 while erasing PEB 948, retry
      [09.913]sunxi-spinand: [SPINAND]: erase block 968 in addr 0xf200000 failed: -110
      [09.920]ubi0 warning: do_sync_erase: error -110 while erasing PEB 948, retry
      [09.927]sunxi-spinand: [SPINAND]: erase block 968 in addr 0xf200000 failed: -110
      [09.934]ubi0 error: do_sync_erase: cannot erase PEB 948, error -110
      [09.940]sunxi-spinand: [SPINAND]: erase block 945 in addr 0xec40000 failed: -110
      [09.947]ubi0 warning: do_sync_erase: error -110 while erasing PEB 925, retry
      [09.954]sunxi-spinand: [SPINAND]: erase block 945 in addr 0xec40000 failed: -110
      [09.961]ubi0 warning: do_sync_erase: error -110 while erasing PEB 925, retry
      [09.968]sunxi-spinand: [SPINAND]: erase block 945 in addr 0xec40000 failed: -110
      [09.975]ubi0 warning: do_sync_erase: error -110 while erasing PEB 925, retry
      [09.981]sunxi-spinand: [SPINAND]: erase block 945 in addr 0xec40000 failed: -110
      [09.988]ubi0 error: do_sync_erase: cannot erase PEB 925, error -110
      [09.995]sunxi-spinand: [SPINAND]: erase block 942 in addr 0xeb80000 failed: -110
      [10.002]ubi0 warning: do_sync_erase: error -110 while erasing PEB 922, retry
      [10.008]sunxi-spinand: [SPINAND]: erase block 942 in addr 0xeb80000 failed: -110
      [10.015]ubi0 warning: do_sync_erase: error -110 while erasing PEB 922, retry
      [10.022]sunxi-spinand: [SPINAND]: erase block 942 in addr 0xeb80000 failed: -110
      [10.029]ubi0 warning: do_sync_erase: error -110 while erasing PEB 922, retry
      [10.036]sunxi-spinand: [SPINAND]: erase block 942 in addr 0xeb80000 failed: -110
      [10.043]ubi0 error: do_sync_erase: cannot erase PEB 922, error -110
      [10.049]sunxi-spinand: [SPINAND]: erase block 941 in addr 0xeb40000 failed: -110
      [10.056]ubi0 warning: do_sync_erase: error -110 while erasing PEB 921, retry
      [10.063]sunxi-spinand: [SPINAND]: erase block 941 in addr 0xeb40000 failed: -110
      [10.070]ubi0 warning: do_sync_erase: error -110 while erasing PEB 921, retry
      [10.077]sunxi-spinand: [SPINAND]: erase block 941 in addr 0xeb40000 failed: -110
      [10.084]ubi0 warning: do_sync_erase: error -110 while erasing PEB 921, retry
      [10.091]sunxi-spinand: [SPINAND]: erase block 941 in addr 0xeb40000 failed: -110
      [10.098]ubi0 error: do_sync_erase: cannot erase PEB 921, error -110
      [10.104]sunxi-spinand: [SPINAND]: erase block 939 in addr 0xeac0000 failed: -110
      [10.111]ubi0 warning: do_sync_erase: error -110 while erasing PEB 919, retry
      [10.118]sunxi-spinand: [SPINAND]: erase block 939 in addr 0xeac0000 failed: -110
      [10.125]ubi0 warning: do_sync_erase: error -110 while erasing PEB 919, retry
      [10.132]sunxi-spinand: [SPINAND]: erase block 939 in addr 0xeac0000 failed: -110
      [10.139]ubi0 warning: do_sync_erase: error -110 while erasing PEB 919, retry
      [10.146]sunxi-spinand: [SPINAND]: erase block 939 in addr 0xeac0000 failed: -110
      [10.153]ubi0 error: do_sync_erase: cannot erase PEB 919, error -110
      [10.159]sunxi-spinand: [SPINAND]: erase block 929 in addr 0xe840000 failed: -110
      [10.166]ubi0 warning: do_sync_erase: error -110 while erasing PEB 909, retry
      [10.173]sunxi-spinand: [SPINAND]: erase block 929 in addr 0xe840000 failed: -110
      [10.180]ubi0 warning: do_sync_erase: error -110 while erasing PEB 909, retry
      [10.186]sunxi-spinand: [SPINAND]: erase block 929 in addr 0xe840000 failed: -110
      [10.193]ubi0 warning: do_sync_erase: error -110 while erasing PEB 909, retry
      [10.200]sunxi-spinand: [SPINAND]: erase block 929 in addr 0xe840000 failed: -110
      [10.207]ubi0 error: do_sync_erase: cannot erase PEB 909, error -110
      [10.213]sunxi-spinand: [SPINAND]: erase block 922 in addr 0xe680000 failed: -110
      [10.220]ubi0 warning: do_sync_erase: error -110 while erasing PEB 902, retry
      [10.227]sunxi-spinand: [SPINAND]: erase block 922 in addr 0xe680000 failed: -110
      [10.234]ubi0 warning: do_sync_erase: error -110 while erasing PEB 902, retry
      [10.241]sunxi-spinand: [SPINAND]: erase block 922 in addr 0xe680000 failed: -110
      [10.248]ubi0 warning: do_sync_erase: error -110 while erasing PEB 902, retry
      [10.255]sunxi-spinand: [SPINAND]: erase block 922 in addr 0xe680000 failed: -110
      [10.262]ubi0 error: do_sync_erase: cannot erase PEB 902, error -110
      [10.268]sunxi-spinand: [SPINAND]: erase block 921 in addr 0xe640000 failed: -110
      [10.275]ubi0 warning: do_sync_erase: error -110 while erasing PEB 901, retry
      [10.282]sunxi-spinand: [SPINAND]: erase block 921 in addr 0xe640000 failed: -110
      [10.289]ubi0 warning: do_sync_erase: error -110 while erasing PEB 901, retry
      [10.296]sunxi-spinand: [SPINAND]: erase block 921 in addr 0xe640000 failed: -110
      [10.303]ubi0 warning: do_sync_erase: error -110 while erasing PEB 901, retry
      [10.310]sunxi-spinand: [SPINAND]: erase block 921 in addr 0xe640000 failed: -110
      [10.317]ubi0 error: do_sync_erase: cannot erase PEB 901, error -110
      [10.323]sunxi-spinand: [SPINAND]: erase block 901 in addr 0xe140000 failed: -110
      [10.330]ubi0 warning: do_sync_erase: error -110 while erasing PEB 881, retry
      [10.337]sunxi-spinand: [SPINAND]: erase block 901 in addr 0xe140000 failed: -110
      [10.344]ubi0 warning: do_sync_erase: error -110 while erasing PEB 881, retry
      [10.351]sunxi-spinand: [SPINAND]: erase block 901 in addr 0xe140000 failed: -110
      [10.358]ubi0 warning: do_sync_erase: error -110 while erasing PEB 881, retry
      [10.364]sunxi-spinand: [SPINAND]: erase block 901 in addr 0xe140000 failed: -110
      [10.371]ubi0 error: do_sync_erase: cannot erase PEB 881, error -110
      [10.377]sunxi-spinand: [SPINAND]: erase block 889 in addr 0xde40000 failed: -110
      [10.385]ubi0 warning: do_sync_erase: error -110 while erasing PEB 869, retry
      [10.391]sunxi-spinand: [SPINAND]: erase block 889 in addr 0xde40000 failed: -110
      [10.398]ubi0 warning: do_sync_erase: error -110 while erasing PEB 869, retry
      [10.405]sunxi-spinand: [SPINAND]: erase block 889 in addr 0xde40000 failed: -110
      [10.412]ubi0 warning: do_sync_erase: error -110 while erasing PEB 869, retry
      [10.419]sunxi-spinand: [SPINAND]: erase block 889 in addr 0xde40000 failed: -110
      [10.426]ubi0 error: do_sync_erase: cannot erase PEB 869, error -110
      [10.432]sunxi-spinand: [SPINAND]: erase block 884 in addr 0xdd00000 failed: -110
      [10.439]ubi0 warning: do_sync_erase: error -110 while erasing PEB 864, retry
      [10.446]sunxi-spinand: [SPINAND]: erase block 884 in addr 0xdd00000 failed: -110
      [10.453]ubi0 warning: do_sync_erase: error -110 while erasing PEB 864, retry
      [10.460]sunxi-spinand: [SPINAND]: erase block 884 in addr 0xdd00000 failed: -110
      [10.467]ubi0 warning: do_sync_erase: error -110 while erasing PEB 864, retry
      [10.474]sunxi-spinand: [SPINAND]: erase block 884 in addr 0xdd00000 failed: -110
      [10.481]ubi0 error: do_sync_erase: cannot erase PEB 864, error -110
      [10.487]sunxi-spinand: [SPINAND]: erase block 877 in addr 0xdb40000 failed: -110
      [10.494]ubi0 warning: do_sync_erase: error -110 while erasing PEB 857, retry
      [10.501]sunxi-spinand: [SPINAND]: erase block 877 in addr 0xdb40000 failed: -110
      [10.508]ubi0 warning: do_sync_erase: error -110 while erasing PEB 857, retry
      [10.515]sunxi-spinand: [SPINAND]: erase block 877 in addr 0xdb40000 failed: -110
      [10.522]ubi0 warning: do_sync_erase: error -110 while erasing PEB 857, retry
      [10.529]sunxi-spinand: [SPINAND]: erase block 877 in addr 0xdb40000 failed: -110
      [10.536]ubi0 error: do_sync_erase: cannot erase PEB 857, error -110
      [10.542]sunxi-spinand: [SPINAND]: erase block 864 in addr 0xd800000 failed: -110
      [10.549]ubi0 warning: do_sync_erase: error -110 while erasing PEB 844, retry
      [10.555]sunxi-spinand: [SPINAND]: erase block 864 in addr 0xd800000 failed: -110
      [10.563]ubi0 warning: do_sync_erase: error -110 while erasing PEB 844, retry
      [10.569]sunxi-spinand: [SPINAND]: erase block 864 in addr 0xd800000 failed: -110
      [10.576]ubi0 warning: do_sync_erase: error -110 while erasing PEB 844, retry
      [10.583]sunxi-spinand: [SPINAND]: erase block 864 in addr 0xd800000 failed: -110
      [10.590]ubi0 error: do_sync_erase: cannot erase PEB 844, error -110
      [10.596]sunxi-spinand: [SPINAND]: erase block 855 in addr 0xd5c0000 failed: -110
      [10.603]ubi0 warning: do_sync_erase: error -110 while erasing PEB 835, retry
      [10.610]sunxi-spinand: [SPINAND]: erase block 855 in addr 0xd5c0000 failed: -110
      [10.617]ubi0 warning: do_sync_erase: error -110 while erasing PEB 835, retry
      [10.624]sunxi-spinand: [SPINAND]: erase block 855 in addr 0xd5c0000 failed: -110
      [10.631]ubi0 warning: do_sync_erase: error -110 while erasing PEB 835, retry
      [10.638]sunxi-spinand: [SPINAND]: erase block 855 in addr 0xd5c0000 failed: -110
      [10.645]ubi0 error: do_sync_erase: cannot erase PEB 835, error -110
      [10.651]sunxi-spinand: [SPINAND]: erase block 850 in addr 0xd480000 failed: -110
      [10.658]ubi0 warning: do_sync_erase: error -110 while erasing PEB 830, retry
      [10.665]sunxi-spinand: [SPINAND]: erase block 850 in addr 0xd480000 failed: -110
      [10.672]ubi0 warning: do_sync_erase: error -110 while erasing PEB 830, retry
      [10.679]sunxi-spinand: [SPINAND]: erase block 850 in addr 0xd480000 failed: -110
      [10.686]ubi0 warning: do_sync_erase: error -110 while erasing PEB 830, retry
      [10.693]sunxi-spinand: [SPINAND]: erase block 850 in addr 0xd480000 failed: -110
      [10.700]ubi0 error: do_sync_erase: cannot erase PEB 830, error -110
      [10.706]sunxi-spinand: [SPINAND]: erase block 842 in addr 0xd280000 failed: -110
      [10.713]ubi0 warning: do_sync_erase: error -110 while erasing PEB 822, retry
      [10.720]sunxi-spinand: [SPINAND]: erase block 842 in addr 0xd280000 failed: -110
      [10.727]ubi0 warning: do_sync_erase: error -110 while erasing PEB 822, retry
      [10.733]sunxi-spinand: [SPINAND]: erase block 842 in addr 0xd280000 failed: -110
      [10.741]ubi0 warning: do_sync_erase: error -110 while erasing PEB 822, retry
      [10.747]sunxi-spinand: [SPINAND]: erase block 842 in addr 0xd280000 failed: -110
      [10.754]ubi0 error: do_sync_erase: cannot erase PEB 822, error -110
      [10.760]sunxi-spinand: [SPINAND]: erase block 841 in addr 0xd240000 failed: -110
      [10.767]ubi0 warning: do_sync_erase: error -110 while erasing PEB 821, retry
      [10.774]sunxi-spinand: [SPINAND]: erase block 841 in addr 0xd240000 failed: -110
      [10.781]ubi0 warning: do_sync_erase: error -110 while erasing PEB 821, retry
      [10.788]sunxi-spinand: [SPINAND]: erase block 841 in addr 0xd240000 failed: -110
      [10.795]ubi0 warning: do_sync_erase: error -110 while erasing PEB 821, retry
      [10.802]sunxi-spinand: [SPINAND]: erase block 841 in addr 0xd240000 failed: -110
      [10.809]ubi0 error: do_sync_erase: cannot erase PEB 821, error -110
      [10.815]sunxi-spinand: [SPINAND]: erase block 828 in addr 0xcf00000 failed: -110
      [10.822]ubi0 warning: do_sync_erase: error -110 while erasing PEB 808, retry
      [10.829]sunxi-spinand: [SPINAND]: erase block 828 in addr 0xcf00000 failed: -110
      [10.836]ubi0 warning: do_sync_erase: error -110 while erasing PEB 808, retry
      [10.843]sunxi-spinand: [SPINAND]: erase block 828 in addr 0xcf00000 failed: -110
      [10.850]ubi0 warning: do_sync_erase: error -110 while erasing PEB 808, retry
      [10.857]sunxi-spinand: [SPINAND]: erase block 828 in addr 0xcf00000 failed: -110
      [10.864]ubi0 error: do_sync_erase: cannot erase PEB 808, error -110
      [10.870]sunxi-spinand: [SPINAND]: erase block 812 in addr 0xcb00000 failed: -110
      [10.877]ubi0 warning: do_sync_erase: error -110 while erasing PEB 792, retry
      [10.884]sunxi-spinand: [SPINAND]: erase block 812 in addr 0xcb00000 failed: -110
      [10.891]ubi0 warning: do_sync_erase: error -110 while erasing PEB 792, retry
      [10.898]sunxi-spinand: [SPINAND]: erase block 812 in addr 0xcb00000 failed: -110
      [10.905]ubi0 warning: do_sync_erase: error -110 while erasing PEB 792, retry
      [10.912]sunxi-spinand: [SPINAND]: erase block 812 in addr 0xcb00000 failed: -110
      [10.919]ubi0 error: do_sync_erase: cannot erase PEB 792, error -110
      [10.925]sunxi-spinand: [SPINAND]: erase block 795 in addr 0xc6c0000 failed: -110
      [10.932]ubi0 warning: do_sync_erase: error -110 while erasing PEB 775, retry
      [10.938]sunxi-spinand: [SPINAND]: erase block 795 in addr 0xc6c0000 failed: -110
      [10.945]ubi0 warning: do_sync_erase: error -110 while erasing PEB 775, retry
      [10.952]sunxi-spinand: [SPINAND]: erase block 795 in addr 0xc6c0000 failed: -110
      [10.959]ubi0 warning: do_sync_erase: error -110 while erasing PEB 775, retry
      [10.966]sunxi-spinand: [SPINAND]: erase block 795 in addr 0xc6c0000 failed: -110
      [10.973]ubi0 error: do_sync_erase: cannot erase PEB 775, error -110
      [10.979]sunxi-spinand: [SPINAND]: erase block 789 in addr 0xc540000 failed: -110
      [10.986]ubi0 warning: do_sync_erase: error -110 while erasing PEB 769, retry
      [10.993]sunxi-spinand: [SPINAND]: erase block 789 in addr 0xc540000 failed: -110
      [11.000]ubi0 warning: do_sync_erase: error -110 while erasing PEB 769, retry
      [11.007]sunxi-spinand: [SPINAND]: erase block 789 in addr 0xc540000 failed: -110
      [11.014]ubi0 warning: do_sync_erase: error -110 while erasing PEB 769, retry
      [11.021]sunxi-spinand: [SPINAND]: erase block 789 in addr 0xc540000 failed: -110
      [11.028]ubi0 error: do_sync_erase: cannot erase PEB 769, error -110
      [11.034]sunxi-spinand: [SPINAND]: erase block 786 in addr 0xc480000 failed: -110
      [11.041]ubi0 warning: do_sync_erase: error -110 while erasing PEB 766, retry
      [11.048]sunxi-spinand: [SPINAND]: erase block 786 in addr 0xc480000 failed: -110
      [11.055]ubi0 warning: do_sync_erase: error -110 while erasing PEB 766, retry
      [11.062]sunxi-spinand: [SPINAND]: erase block 786 in addr 0xc480000 failed: -110
      [11.069]ubi0 warning: do_sync_erase: error -110 while erasing PEB 766, retry
      [11.076]sunxi-spinand: [SPINAND]: erase block 786 in addr 0xc480000 failed: -110
      [11.083]ubi0 error: do_sync_erase: cannot erase PEB 766, error -110
      [11.089]sunxi-spinand: [SPINAND]: erase block 779 in addr 0xc2c0000 failed: -110
      [11.096]ubi0 warning: do_sync_erase: error -110 while erasing PEB 759, retry
      [11.103]sunxi-spinand: [SPINAND]: erase block 779 in addr 0xc2c0000 failed: -110
      [11.110]ubi0 warning: do_sync_erase: error -110 while erasing PEB 759, retry
      [11.116]sunxi-spinand: [SPINAND]: erase block 779 in addr 0xc2c0000 failed: -110
      [11.123]ubi0 warning: do_sync_erase: error -110 while erasing PEB 759, retry
      [11.130]sunxi-spinand: [SPINAND]: erase block 779 in addr 0xc2c0000 failed: -110
        这个芯片确定驱动支持吗
          Lts52341314 LV 5 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru GD5F2GQ5UEYIGR是本来就有的,GD5F4GQ6UEYIG是找代理商要的最新SDK才有的,但都是这种效果
            柚木 鉉 LV 9 @Lts52341314 最后由 编辑
            @lts52341314 检查一下是不是有虚焊或者走线问题,这个储存芯片我自己加了参数运行没问题
