    QT时钟程序报不能加载.so库
    5765
      huanian LV 4 最后由 编辑
      这是t113 linux下的错误提示:
      # ./analogclock
      ./analogclock: error while loading shared libraries: libQt5Gui.so.5: cannot open shared object file: No such file or directory
      此文件是存在的
      # cd  /usr/local/Qt_5.12.5/lib/
      # find ./ -name  libQt5Gui.so.5
      ./libQt5Gui.so.5
      在PC端查看的analogclock的文件属性:
      $ file analogclock
      analogclock: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux.so.3, for GNU/Linux 3.2.0, BuildID[sha1]=619b54200f46c1ace574d1d6bd79ada7441318e4, with debug_info, not stripped
      $ readelf -d analogclock
      File: analogclock
      Dynamic section at offset 0x31ac contains 31 entries:
        Tag        Type                         Name/Value
       0x00000001 (NEEDED)                     Shared library: [libQt5Gui.so.5]
       0x00000001 (NEEDED)                     Shared library: [libQt5Core.so.5]
       0x00000001 (NEEDED)                     Shared library: [libpthread.so.0]
       0x00000001 (NEEDED)                     Shared library: [libstdc++.so.6]
       0x00000001 (NEEDED)                     Shared library: [libm.so.6]
       0x00000001 (NEEDED)                     Shared library: [libgcc_s.so.1]
       0x00000001 (NEEDED)                     Shared library: [libc.so.6]
       0x0000000f (RPATH)                      Library rpath: [/usr/local/Qt-5.12.5/lib]
       0x0000000c (INIT)                       0x11ea4
       0x0000000d (FINI)                       0x12cac
       0x00000019 (INIT_ARRAY)                 0x23000
       0x0000001b (INIT_ARRAYSZ)               4 (bytes)
       0x0000001a (FINI_ARRAY)                 0x23004
       0x0000001c (FINI_ARRAYSZ)               4 (bytes)
       0x00000004 (HASH)                       0x1018c
       0x00000005 (STRTAB)                     0x10d78
       0x00000006 (SYMTAB)                     0x10698
       0x0000000a (STRSZ)                      3253 (bytes)
       0x0000000b (SYMENT)                     16 (bytes)
       0x00000015 (DEBUG)                      0x0
       0x00000003 (PLTGOT)                     0x232cc
       0x00000002 (PLTRELSZ)                   712 (bytes)
       0x00000014 (PLTREL)                     REL
       0x00000017 (JMPREL)                     0x11bdc
       0x00000011 (REL)                        0x11bbc
       0x00000012 (RELSZ)                      32 (bytes)
       0x00000013 (RELENT)                     8 (bytes)
       0x6ffffffe (VERNEED)                    0x11b0c
       0x6fffffff (VERNEEDNUM)                 5
       0x6ffffff0 (VERSYM)                     0x11a2e
       0x00000000 (NULL)                       0x0
        柚木 鉉 LV 9 @huanian 最后由 编辑
        @huanian 两个的libc不同,可以尝试使用相同的编译器,libc库重新编译qt
        H 1 条回复 最后回复 回复 引用 分享 1
          huanian LV 4 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru 感谢回复,我自己摸索解决了。
          我用LonganSDK,参照/etc/init.d/rcS里的开机启动脚本,用下面这个指令可以正常启动QT的app
          #  /etc/qtenv.sh & ./analogclock
          [1] 16558
          /etc/qtenv.sh: line 17: [: too many arguments
          add /dev/input/event5 to Qt Application.
          find qt5 installed done
          xkbcommon: ERROR: failed to add default include path /usr/share/X11/xkb
          Failed to create xkb context
          这个xkbcommon: ERROR 报错不影响使用,就没管他
          V 1 条回复 最后回复 回复 引用 分享 1
          • V
            vejoker LV 5 @huanian 最后由 编辑
            @huanian 大佬,请问您的qtenv.sh脚本内容是什么。我也遇到相关qt程序开机自启不能加载so库的情况。
