    D1s 的 usb host 口插U盘正常,插键盘没有生成 /dev/input/event* ,这个怎么解决呢?
    d1s usb键盘
    4957
    • cube_work
      cube_work LV 5 最后由 编辑
      YuzukiTsuru whycan 2 条回复 最后回复 回复 引用 分享 0
        柚木 鉉 LV 9 @cube_work 最后由 编辑
        @cube_work USB里开启USB HID设备
        cube_work 1 条回复 最后回复 回复 引用 分享 0
          whycan晕哥 LV 9 @cube_work 最后由 编辑
          @cube_work
          CONFIG_USB_KBD
          CONFIG_USB_MOUSE
          • cube_work
            cube_work LV 5 @YuzukiTsuru 最后由 编辑
            @yuzukitsuru @whycan
            谢谢两位 ,搞定啦。
            lichee/linux-5.4/drivers/hid/usbhid/Kconfig
            menu "USB HID Boot Protocol drivers"
                    depends on USB!=n && USB_HID!=y && EXPERT
            config USB_KBD
                    tristate "USB HIDBP Keyboard (simple Boot) support"
                    depends on USB && INPUT
                    ---help---
                      Say Y here only if you are absolutely sure that you don't want
                      to use the generic HID driver for your USB keyboard and prefer
                      to use the keyboard in its limited Boot Protocol mode instead.
                      This is almost certainly not what you want.  This is mostly
                      useful for embedded applications or simple keyboards.
                      To compile this driver as a module, choose M here: the
                      module will be called usbkbd.
                      If even remotely unsure, say N.
            config USB_MOUSE
                    tristate "USB HIDBP Mouse (simple Boot) support"
                    ---help---
                      to use the generic HID driver for your USB mouse and prefer
                      to use the mouse in its limited Boot Protocol mode instead.
                      useful for embedded applications or simple mice.
                      module will be called usbmouse.
            神奇了,一定要屏蔽 USB_HID 才能打开 USB_KBD和 USB_MOUSE
            难道是互斥的吗?
              @cube_work 配置USB HID要在input里打开input设备,HID是一个较低层的接口,上层还需要input的支持,或者直接打开USB KEYBOARD这样的,直接提过支持
