    melis4.0启动问题
    4376
      honglingjin LV 3 最后由 编辑
      请教一下,能否有人指导一下F133-A的melis4.0启动!
      芯片型号:F133-A
      平台:D1S
      编译环境:Ubuntu16.04
      NORFLASH型号:
      请问出现这种情况是FLASH芯片不支持吗?
        [40]BOOT0 commit : 889f614
        [42]set pll start
        [44]periph0 has been enabled
        [47]set pll end
        [48][pmu]: bus read error
        [51]board init ok
        [53]enable_jtag
        [54]ZQ value = 0x2d
        [56]get_pmu_exist() = -1
        [58]DRAM BOOT DRIVE INFO: V0.32
        [61]DRAM CLK = 528 MHz
        [63]DRAM Type = 2 (2:DDR2,3:DDR3)
        [66]DRAMC read ODT  off.
        [69]DRAM ODT off.
        [71]ddr_efuse_type: 0xa
        [73]mark_id: 0x5c
        [75]DRAM SIZE =64 M
        [77]PLL_DDR_CTRL_REG:0xf9002b00
        [80]DRAM_CLK_REG:0xc0000000
        [82][TIMING DEBUG] MR2= 0x0
        [87]DRAM simple test OK.
        [89]dram size =64
        [91]spinor id is: ef 70 18, read cmd: 6b
        [94]Succeed in reading toc file head.
        [98]The size of toc is 98000.
        [126]Entry_name        = melis-lzma
        [129]LZMA: Image address............... 0x41000400
        [134]LZMA: Properties address.......... 0x41000400
        [138]LZMA: Uncompressed size address... 0x41000405
        [143]LZMA: Compressed data address..... 0x4100040d
        [147]LZMA: Destination address......... 0x40000000
        [152]LZMA: Uncompresed size............ 0xffffffffffffffff
        [157]LZMA: Compresed size.............. 0xfffffffa
        [337]LZMA: Uncompressed ............... 0x00123410
        [342]Entry_name        = melis-config
        [345]image_base:43000000
        [348]Jump to second Boot.
        [350]jump to rtos
        sbi2ekernel
        |                   /'\_/`\       (_ )  _                       /'_  )    /'_ `\   /' _`\                     |
        |                   |     |   __   | | (_)  ___  ______  _   _ (_)_) |   ( (_) |   | ( ) |                    |
        |                   | (_) | /'__`\ | | | |/',__)(______)( ) ( ) _(_ <     \__, |   | | | |                    |
        |                   | | | |(  ___/ | | | |\__, \        | \_/ |( )_) | _     | | _ | (_) |                    |
        |                   (_) (_)`\____)(___)(_)(____/        `\___/'`\____)(_)    (_)(_)`\___/'                    |
        |version : V3.9.0        |
        |commitid: c6bf140930185e29f6e12888005ea61634ae7e5a                                                           |
        |sunxiver: 30800        |
        |timever : Tue, 29 Mar 2022 20:33:56 +0800        |
        |compiler: gcc version 8.4.0 (T-HEAD RISCV Tools V1.10.2 B20201104)                                           |
        |optimal : -Os -g -gdwarf-2 -gstrict-dwarf        |
        |linker  : GNU ld (GNU Binutils) 2.32        |
        |newlibc : 3.0.0        |
        |author  : yuzuki        |
        [DBG]: [__mount_parts:0273]:                                classname=DMS
        [DBG]: [__mount_parts:0274]:                                devname=dms01
        [DBG]: [__mount_parts:0301]:                                find last lun.
        [DBG]: [__mount_parts:0331]:                                nPart = 1.
        [DBG]: [__mount_parts:0460]:                                dmsPart: "DMS\dms010" is linked to symbel "B".
        [ERR]: [esFSYS_pread:0318]:                                 fs fatal err
        [DBG]: [esFSYS_mntfs:0317]:                                 devfs,mount on B.
        [DBG]: [kservice_maintask:0834]:                            partition [B] plug in..
        [DBG]: [__mount_parts:0273]:                                classname=DISK
        [DBG]: [__mount_parts:0274]:                                devname=RAMDISK
        [DBG]: [__mount_parts:0460]:                                rawpart: "DISK\▒[ERR]: [match_nor:0376]: spinor: not match any id on factory 0xef ids table
        [ERR]: [nor_scan:0495]:                                     spinor: scan nor flash failed
        [ERR]: [nor_init:0571]:                                     spinor: init nor flash failed
        [ERR]: [nor_read:0880]:                                     spinor: read address 0xc000 with len 16384 failed
        [ERR]: [register_blk_device:0862]:                          get gpt from nor flash failed - 4294967291
        SDC:hal_sdc_create host:0x401b65d8 id:0
        [ERR] SDC:name sdc0_d1,port 6,port_num 0,mul_sel 2, pull 1, drv_level 1
        [ERR] SDC:name sdc0_d0,port 6,port_num 1,mul_sel 2, pull 1, drv_level 1
        [ERR] SDC:name sdc0_clk,port 6,port_num 2,mul_sel 2, pull 1, drv_level 1
        [ERR] SDC:name sdc0_cmd,port 6,port_num 3,mul_sel 2, pull 1, drv_level 1
        [ERR] SDC:name sdc0_d3,port 6,port_num 4,mul_sel 2, pull 1, drv_level 1
        [ERR] SDC:name sdc0_d2,port 6,port_num 5,mul_sel 2, pull 1, drv_level 1
        SDC:Not implement __mci_restore_io,793
        SDC:Not imp hal_sdc_init,2206
        SDC:hal_sdc_init,2239 no imp
        SDC:hal_sdc_init,2248 no imp
        SDC:SDC Host Capability:0x3820f Ocr avail:0x3f0000
        SDC:SDC cd_mode:2 present_val:0
        SDC:SDC id:0 dma_use:1 present:1
         driver version SD/MMC/SDIO Host Controller Driver(v0.28 2021-08-24 16:50) init ok.
        host_id =0!
        [ERR]: [hal_ths_init:0094]:                                 0x2009404, 0x2009400, 0
        我这更惨
        G 1 条回复 最后回复 回复 引用 分享 0
          memory LV 7 最后由 编辑
          感觉TF卡的问题
          • G
            godzhou0909 LV 6 @YuzukiTsuru 最后由 编辑
            @yuzukitsuru 我也是这个问题,请问怎么解决呢?
