    D1s 使用 XR829 BT 配置 a2dp-source 出错
    xr829 d1s
    11
    9475
      首先按照帖子《D1 开发板使用 XR829 mesh fw 出现 code(56) 错误,如何解决》:
      https://bbs.aw-ol.com/topic/361/share/1 配置了蓝牙,输出
      root@TinaLinux:/# hciattach -n ttyS1 xradio >/dev/null 2>&1 &
      root@TinaLinux:/# [  341.203731]sunxi-rfkill soc@3000000:rfkill@0: set block: 1
      [  341.210080]sunxi-rfkill soc@3000000:rfkill@0: bt power off success
      [  341.237565]sunxi-rfkill soc@3000000:rfkill@0: set block: 0
      [  341.253736]sunxi-rfkill soc@3000000:rfkill@0: bt power on success
      [  341.280858][XR_BT_LPM] bluedroid_write_proc_btwake: bluedroid_write_proc_btwake 1
      [  341.289318][XR_BT_LPM] bluedroid_write_proc_btwake: wakeup bt device
      [  341.296571][XR_BT_LPM] bluedroid_write_proc_lpm: disable lpm mode
      root@TinaLinux:/# hciconfig -a hci0 up
      hci0:   Type: Primary  Bus: UART
              BD Address: 22:22:65:05:28:FE  ACL MTU: 1021:8  SCO MTU: 255:4
              UP RUNNING
              RX bytes:1154 acl:0 sco:0 events:54 errors:0
              TX bytes:744 acl:0 sco:0 commands:54 errors:0
      然后bt_test -i -p a2dp-source
      root@TinaLinux:/# bt_test -i -p a2dp-source
      8163.127547: BTMG[bt_manager_enable:407]:  bt manager version:Version:3.0.1.202110291544,builed time:Oct 29 2021-09:42:35
      8163.128196: BTMG[bt_test_status_cb:82]:  bt is turnning on.
      Bluetooth init has been completed!!
      ln: /var/lib/bluetooth: No such file or directory
      bluetoothd[296]: Bluetooth daemon 5.54
      D-Bus setup failed: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
      bluetoothd[296]: Unable to get on D-Bus
      bluealsa: Couldn't initialize controller thread: Bad file descriptor
      8164.563437: BTMG[bt_profile_global_init:355]:  start bluealsa :1 times
      8164.572354: BTMG[bt_routine:68]:  Couldn't obtain D-Bus connection: Could not connect: No such file or directory
      8165.065054: BTMG[bt_manager_enable:449]:  init connection to bluez failed!
      [  577.128339]sunxi-rfkill soc@3000000:rfkill@0: block state already is 1
      stop bluetoothd and hciattach
      8165.198016: BTMG[bt_test_status_cb:65]:  BT is off
      估计是我什么配置的问题,麻烦大佬分析一下
        看起来好像没开 dbus?
        YuzukiTsuru X 4 条回复 最后回复 回复 引用 分享 1
          柚木 鉉 LV 9 @whycan 最后由 编辑
          @whycan dbus肯定开了的,不开都跑不起来
            @whycan 看着像dbus-daemon没起来,但是我没找到怎么启动
              @whycan
              dbus报错
              Unknown group "lp" in message bus configuration file
              Failed to start message bus: Configuration file needs one or more <listen> elements giving addresses
              X 1 条回复 最后回复 回复 引用 分享 0
                柚木 鉉 LV 9 最后由 YuzukiTsuru 编辑
                改了一下conf
                root@TinaLinux:/# cat /etc/dbus-1/system.d/bluetooth.conf
                <!-- This configuration file specifies the required security policies
                     for Bluetooth core daemon to work. -->
                <!DOCTYPE busconfig PUBLIC "-//freedesktop//DTD D-BUS Bus Configuration 1.0//EN"
                 "http://www.freedesktop.org/standards/dbus/1.0/busconfig.dtd">
                <busconfig>
                  <!-- ../system.conf have denied everything, so we just punch some holes -->
                  <policy user="root">
                    <allow own="org.bluez"/>
                    <allow send_destination="org.bluez"/>
                    <allow send_type="method_call"/>
                    <allow send_type="method_return"/>
                    <allow send_interface="org.bluez.Agent1"/>
                    <allow send_interface="org.bluez.MediaEndpoint1"/>
                    <allow send_interface="org.bluez.MediaPlayer1"/>
                    <allow send_interface="org.bluez.ThermometerWatcher1"/>
                    <allow send_interface="org.bluez.AlertAgent1"/>
                    <allow send_interface="org.bluez.Profile1"/>
                    <allow send_interface="org.bluez.HeartRateWatcher1"/>
                    <allow send_interface="org.bluez.CyclingSpeedWatcher1"/>
                    <allow send_interface="org.bluez.GattCharacteristic1"/>
                    <allow send_interface="org.bluez.GattDescriptor1"/>
                    <allow send_interface="org.freedesktop.DBus.ObjectManager"/>
                    <allow send_interface="org.freedesktop.DBus.Properties"/>
                  </policy>
                  <policy at_console="true">
                    <allow send_path="/"/>
                    <allow send_destination="org.bluez.Manager"/>
                    <allow receive_sender="org.bluez.Manager"/>
                    <allow send_destination="org.bluez.Adapter"/>
                    <allow receive_sender="org.bluez.Adapter"/>
                    <allow send_destination="org.bluez.Device"/>
                    <allow receive_sender="org.bluez.Device"/>
                    <allow send_destination="org.bluez.Service"/>
                    <allow receive_sender="org.bluez.Service"/>
                    <allow send_destination="org.bluez.Database"/>
                    <allow receive_sender="org.bluez.Database"/>
                    <allow send_destination="org.bluez.Security"/>
                    <allow receive_sender="org.bluez.Security"/>
                  </policy>
                  <!-- allow users of lp group (printing subsystem) to
                       communicate with bluetoothd -->
                  <policy context="default">
                    <deny send_destination="org.bluez"/>
                  </policy>
                </busconfig>
                  /etc/init.d/dbus restart
                  然后就好了
                  11964.769186: BTMG[bt_manager_enable:407]:  bt manager version:Version:3.0.1.202110291544,builed time:Oct 29 2021-09:42:35
                  11964.769783: BTMG[bt_test_status_cb:82]:  bt is turnning on.
                  hcidump_xr existed
                  11964.938952: [a2dp_sink_thread_process:318]:  Couldn't read event: Bad message
                  11964.939616: [hfp_thread_process:711]:  Couldn't read event: Bad message
                  bluetoothd[275]: Endpoint unregistered: sender=:1.1 path=/A2DP/SBC/Sink/1
                  bluetoothd[275]: Endpoint registered: sender=:1.3 path=/A2DP/SBC/Source/1
                  11965.263831: BTMG[bt_profile_global_init:355]:  start bluealsa :1 times
                  11965.825855: BTMG[bt_test_adapter_power_state_cb:47]:  Turn on bt successfully
                  11966.266042: BTMG[bt_test_status_cb:67]:  BT is ON
                  scan 0[bt]1
                  [bt]#12145.074175: BTMG[bt_test_discovery_status_cb:91]:  bt start scanning.
                  12145.074243: BTMG[btmg_gap_bluez_callback:1228]:  Discovery started
                  12145.206434: BTMG[bt_test_dev_add_cb:115]:  address:EC:FA:5C:63:37:94,name:MI BT18 BLE,class:0,icon:(null),address type:public,rssi:-86
                  [bt]#12147.415742: BTMG[bt_test_dev_add_cb:115]:  address:A4:FC:77:29:EA:7A,name:KD-43X8500F,class:0,icon:(null),address type:public,rssi:-96
                  s
                  Invalid command
                  [bt]#
                  [bt]#sca12150.809068: BTMG[bt_test_dev_add_cb:115]:  address:EC:FA:5C:DD:66:16,name:MI BT18,class:3408900,icon:audio-card,address type:public,rssi:-53
                  12150.862888: BTMG[bt_test_update_rssi_cb:139]:  address:A4:FC:77:29:EA:7A,name:KD-43X8500F,rssi:-81
                  12150.872707: BTMG[bt_test_update_rssi_cb:139]:  address:EC:FA:5C:DD:66:16,name:MI BT18,rssi:-25
                  12150.893906: BTMG[bt_test_update_rssi_cb:139]:  address:EC:FA:5C:DD:66:16,name:MI BT18,rssi:-53
                  n12151.284176: BTMG[bt_test_update_rssi_cb:139]:  address:EC:FA:5C:DD:66:16,name:MI BT18,rssi:-25
                  12151.334754: BTMG[bt_test_update_rssi_cb:139]:  address:EC:FA:5C:DD:66:16,name:MI BT18,rssi:-55
                  12151.887915: BTMG[cmd_bt_discovery:86]:  Unexpected argc: 0, see help
                  [bt]#
                  [bt]#scan 0
                  [bt]#12155.870176: BTMG[btmg_gap_bluez_callback:1232]:  Discovery Stopped due to user input
                  12155.870297: BTMG[bt_test_discovery_status_cb:97]:  stop scan by user.
                  [bt]#connect EC:FA:5C:DD:66:16
                  12190.724040: BTMG[bt_test_a2dp_source_connection_state_cb:296]:  A2DP source connecting with device: EC:FA:5C:DD:66:16
                  addr:EC:FA:5C:DD:66:16,name:MI BT18,state:CONNECTED
                  bluetoothd[385]: Endpoint registered: sender=:1.4 path=/A2DP/SBC/Source/2
                  [bt]#bluetoothd[385]: Can't open input device: No such file or directory (2)
                  bluetoothd[385]: AVRCP: failed to init uinput for MI BT18
                  12192.076985: BTMG[bt_test_a2dp_source_connection_state_cb:298]:  A2DP source connected with device: EC:FA:5C:DD:66:16
                    R 1 条回复 最后回复 回复 引用 分享 1
                    • Referenced by  D diancity
                    • X
                      xuan946248446 LV 2 @YuzukiTsuru 最后由 编辑
                      @yuzukitsuru 请教下dbus-daemon没起来怎么解决的
                      • X
                        xuan946248446 LV 2 @whycan 最后由 编辑
                        @whycan 大佬,怎么从根本上解决这个问题,dbus-daemon能够自启动
                        • R
                          Reidosclones123456 LV 1 @YuzukiTsuru 最后由 编辑
                          @yuzukitsuru 你好朋友,我联系你是因为我开始使用电视盒,我遇到了一个问题,我找不到在 Linux 操作系统 Ubuntu 24.04.1 上刷新带有 Allwinner 处理器的盒子的工具长期运输服务
