    F133-A/D1S芒果派MQ-R在tina-sdk2.0下无法识别电阻触摸屏
    9
    65
    45980
    • E
      exoy28 LV 4 最后由 编辑
      测试显示屏为rgb接口的4.3寸800x480液晶屏,电阻触摸屏排线焊接在屏幕排线上
      刷入晕哥的5寸800x480屏固件,成功点亮屏幕,但是触摸后GUI无反应,运行getevent后得到电阻屏输入
      root@TinaLinux:/# cat /sys/class/disp/disp/attr/sys
      screen 0:
      de_rate 300000000 hz, ref_fps:60
      mgr0: 800x480 fmt[rgb] cs[0x204] range[full] eotf[0x4] bits[8bits] err[0] force_sync[0] unblank direct_show[false] iommu[1]
              lcd output      backlight( 50)  fps:87.7         800x 480
              err:0   skip:273        irq:93653       vsync:0 vsync_skip:0
         BUF    enable ch[1] lyr[0] z[16] prem[N] a[pixel 255] fmt[  0] fb[ 800, 480; 800, 480; 800, 480] crop[   0,   0, 800, 480] frame[   0,   0, 800, 480] addr[ffc00000,       0,       0] flags[0x       0] trd[0,0]
      depth[ 0] root@TinaLinux:/# getevent
      add device 1: /dev/input/event1
        name:     "audiocodec sunxi Audio Jack"
      add device 2: /dev/input/event0
      could not get driver version for /dev/input/mouse0, Inappropriate ioctl for device
      could not get driver version for /dev/input/mice, Inappropriate ioctl for device
      poll 3, returned 1
      /dev/input/event0: 0003 0000 00000676
      poll 3, returned 1
      /dev/input/event0: 0003 0001 0000097a
      poll 3, returned 1
      /dev/input/event0: 0001 014a 00000001
      poll 3, returned 1
      /dev/input/event0: 0000 0000 00000000
      poll 3, returned 1
      /dev/input/event0: 0001 014a 00000000
      poll 3, returned 1
      poll 3, returned 1
      /dev/input/event0: 0003 0000 000005b1
      poll 3, returned 1
      /dev/input/event0: 0003 0001 0000088b
      poll 3, returned 1
      poll 3, returned 1
      poll 3, returned 1
      /dev/input/event0: 0003 0000 000005dd
      poll 3, returned 1
      /dev/input/event0: 0003 0001 00000b2a
      poll 3, returned 1
      poll 3, returned 1
      /dev/input/event0: 0003 0000 00000777
      poll 3, returned 1
      /dev/input/event0: 0003 0001 00000ac3
      poll 3, returned 1
      poll 3, returned 1
      /dev/input/event0: 0003 0000 00000899
      poll 3, returned 1
      /dev/input/event0: 0003 0001 0000083a
      poll 3, returned 1
      poll 3, returned 1
      poll 3, returned 1
      在VM虚拟机中使用ubuntu14.04编译tina-sdk2.0,打上芒果派 MQ Pro,MQ 的板级配置文件,在menuconfig中选择lvgl_demo,修改board.dts中rtp项为
      &rtp {
      	allwinner,ts-attached;
      刷入MQ-R后运行lvgl_demo正常显示,终端显示
      root@TinaLinux:/# lv_examples 0
      wh=800x480, vwh=800x960, bpp=32,[  T158] VE: enable hw clock
       rotated=0
      Turn on double buffe[  T158] enable_cedar_hw_clk,552
      ring.
      Turn on 2d hardware acceleration.
      Turn on 2d hardware rotation acceleration.
      unable open evdev interface:: No such file or directory
      触摸无反应,运行getevent,终端显示
      add device 1: /dev/input/event0
      尝试替换芒果派麻雀固件与源码补丁2021-12-16.7z中的board.dts后重新编译打包,依然无法识别电阻触摸屏
        电阻屏请用 tslib / uinput,需要先校正触摸屏:
        F1C200 linux LVGL双缓冲支持
        https://whycan.com/t_7705.html#p74077
        E 1 条回复 最后回复 回复 引用 分享 0
        • E
          exoy28 LV 4 @whycan 最后由 编辑
          @whycan 请问大佬为什么运行校准会这样
          root@TinaLinux:/# ts_calibrate
          ts_setup: No such file or directory
          还有getevent看不到触摸屏输入
            @exoy28 tslib配置有问题,看着像缺模块
            • E
              exoy28 LV 4 @YuzukiTsuru 最后由 编辑
              @yuzukitsuru menuconfig中添加了这些tslib features
              请问还需要添加哪些项?
                whycan晕哥 LV 9 @exoy28 最后由 编辑
                @exoy28
                宿主机上面用 file ts_calibrate 命令看看。
                • E
                  @whycan 在 F133-A/D1S芒果派MQ-R在tina-sdk2.0下无法识别电阻触摸屏 中说:
                  file ts_calibrate
                  exoy29@ubuntu:~/MQ-R/tina_d1_open_v2$ file ts_calibrate
                  ts_calibrate: ERROR: cannot open `ts_calibrate' (No such file or directory)
                    @exoy28
                    后面那个参数用完整路径。
                    • E
                      exoy28 LV 4 @whycan 最后由 whycan 编辑
                      @whycan
                      exoy29@ubuntu:~/MQ-R/tina_d1_open_v2$ find /home/exoy29/MQ-R/tina_d1_open_v2 -name ts_calibrate
                      /home/exoy29/MQ-R/tina_d1_open_v2/out/d1s-mq/compile_dir/target/rootfs/usr/bin/ts_calibrate
                      /home/exoy29/MQ-R/tina_d1_open_v2/out/d1s-mq/compile_dir/target/tslib-1.15/ipkg-sunxi/tslib/usr/bin/ts_calibrate
                      /home/exoy29/MQ-R/tina_d1_open_v2/out/d1s-mq/compile_dir/target/tslib-1.15/tests/ts_calibrate
                      /home/exoy29/MQ-R/tina_d1_open_v2/out/d1s-mq/compile_dir/target/tslib-1.15/tests/.libs/ts_calibrate
                      /home/exoy29/MQ-R/tina_d1_open_v2/out/d1s-mq/compile_dir/target/tslib-1.15/ipkg-install/usr/bin/ts_calibrate
                      /home/exoy29/MQ-R/tina_d1_open_v2/out/d1s-mq/staging_dir/target/rootfs/usr/bin/ts_calibrate
                        @exoy28
                        嵌入式系统运行 /usr/bin/ldd /usr/bin/ts_calibrate 试一试。
                        • E
                          root@TinaLinux:/# /usr/bin/ldd /usr/bin/ts_calibrate
                          -/bin/sh: /usr/bin/ldd: Permission denied
                            @exoy28
                            宿主机运行这个:
                            file /home/exoy29/MQ-R/tina_d1_open_v2/out/d1s-mq/staging_dir/target/rootfs/usr/bin/ts_calibrate
                            • E
                              exoy29@ubuntu:~/MQ-R/tina_d1_open_v2$ file /home/exoy29/MQ-R/tina_d1_open_v2/out/d1s-mq/staging_dir/target/rootfs/usr/bin/ts_calibrate
                              /home/exoy29/MQ-R/tina_d1_open_v2/out/d1s-mq/staging_dir/target/rootfs/usr/bin/ts_calibrate: ELF 64-bit LSB  executable, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 4.15.0, not stripped
                                @exoy28
                                可能是依赖的某些so有问题,或者不存在
                                用 xxx-objdump -x 可执行文件 |grep NEED 一个一个检查一下:
                                $ prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/bin/riscv64-unknown-linux-gnu-objdump -x ./out/d1s-nezha/staging_dir/target/rootfs/bin/busybox |grep NEED
                                  NEEDED               libcrypt.so.1
                                  NEEDED               libm.so.6
                                  NEEDED               libc.so.6
                                E 1 条回复 最后回复 回复 引用 分享 1
                                • E
                                  @whycan 是这样吗?
                                  exoy29@ubuntu:~/MQ-R/tina_d1_open_v2$ ~/MQ-R/tina_d1_open_v2/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/bin/riscv64-unknown-linux-gnu-objdump -x /home/exoy29/MQ-R/tina_d1_open_v2/out/d1s-mq/staging_dir/target/rootfs/usr/bin/ts_calibrate |grep NEED
                                    NEEDED               libts.so.0
                                    NEEDED               libdl.so.2
                                    NEEDED               libc.so.6
                                    VERNEED              0x0000000000010a88
                                    VERNEEDNUM           0x0000000000000001
                                    whycan晕哥 LV 9 @exoy28 最后由 whycan 编辑
                                    @exoy28
                                    目标板执行 find / -name libts.so.0
                                    E 2 条回复 最后回复 回复 引用 分享 0
                                    • E
                                      @whycan
                                      root@TinaLinux:/#  find / -name libts.so.0
                                      /usr/lib/libts.so.0
                                      root@TinaLinux:/#  find / -name libdl.so.2
                                      /lib/libdl.so.2
                                      root@TinaLinux:/#  find / -name libc.so.6
                                      /lib/libc.so.6
                                      • E
                                        @whycan
                                        root@TinaLinux:/# /usr/lib/libts.so.0
                                        [  T169] libts.so.0[169]: unhandled signal 11 code 0x1 at 0x0000000000028946
                                        [  T169] CPU: 0 PID: 169 Comm: libts.so.0 Not tainted 5.4.61 #1
                                        [  T169] sepc: 0000000000028946 ra : 0000000000028946 sp : 0000003ffffb5b30
                                        [  T169]  gp : 0000000000055948 tp : 0000003fbf560720 t0 : 0000000000000000
                                        [  T169]  t1 : 0000000000015a1c t2 : 000000000000006a s0 : 0000000004ff65f0
                                        [  T169]  s1 : 0000000004ff6620 a0 : 0000003fd0872020 a1 : 0000000004ff6620
                                        [  T169]  a2 : 0000000004ff6630 a3 : 000000000000002f a4 : 000000000000002f
                                        [  T169]  a5 : 0000003fd0872020 a6 : 7efefefefefefeff a7 : 00000000000000dd
                                        [  T169]  s2 : 0000000000052031 s3 : 000000000004c688 s4 : 0000000004ff6630
                                        [  T169]  s5 : 0000000000055cd0 s6 : 0000000000000008 s7 : ffffffffffffffff
                                        [  T169]  s8 : 0000000000000000 s9 : 0000000004ff65f0 s10: ffffffffffffffff
                                        [  T169]  s11: 000000000000002d t3 : 0000003fbf5e5ad4 t4 : 0000000000000000
                                        [  T169]  t5 : 0000000000000008 t6 : 0000003fff998280
                                        [  T169] sstatus: 8000000201804020 sbadaddr: 0000000000028946 scause: 000000000000000c
                                        Segmentation fault
                                        root@TinaLinux:/# /lib/libdl.so.2
                                        [  T170] libdl.so.2[170]: unhandled signal 11 code 0x1 at 0x0000000000028946
                                        [  T170] CPU: 0 PID: 170 Comm: libdl.so.2 Not tainted 5.4.61 #1
                                        [  T170] sepc: 0000000000028946 ra : 0000000000028946 sp : 0000003fff866b40
                                        [  T170]  gp : 0000000000055948 tp : 0000003fbf560720 t0 : 0000000000000000
                                        [  T170]  t1 : 0000000000015a1c t2 : 000000000000006a s0 : 0000000004ff65e8
                                        [  T170]  s1 : 0000000004ff6610 a0 : 0000003feb0600f0 a1 : 0000000004ff6610
                                        [  T170]  a2 : 0000000004ff6620 a3 : 000000000000002f a4 : 000000000000002f
                                        [  T170]  a5 : 0000000000000000 a6 : 7efefefefefefeff a7 : 00000000000000dd
                                        [  T170]  s2 : 0000000000052031 s3 : 000000000004c688 s4 : 0000000004ff6620
                                        [  T170]  s5 : 0000000000055cd0 s6 : 0000000000000008 s7 : ffffffffffffffff
                                        [  T170]  s8 : 0000000000000000 s9 : 0000000004ff65e8 s10: ffffffffffffffff
                                        [  T170]  s11: 000000000000002d t3 : 0000003fbf5e5ad4 t4 : 0000000000000000
                                        [  T170]  t5 : 0000000000000008 t6 : 0000003fff998280
                                        [  T170] sstatus: 8000000201804020 sbadaddr: 0000000000028946 scause: 000000000000000c
                                        Segmentation fault
                                        root@TinaLinux:/# /lib/libc.so.6
                                        GNU C Library (GNU libc) stable release version 2.29.
                                        Copyright (C) 2019 Free Software Foundation, Inc.
                                        This is free software; see the source for copying conditions.
                                        There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
                                        PARTICULAR PURPOSE.
                                        Compiled by GNU CC version 8.1.0.
                                        libc ABIs: UNIQUE ABSOLUTE
                                        For bug reporting instructions, please see:
                                        <http://www.gnu.org/software/libc/bugs.html>.
                                          终于想起哪里出错了: X1000 Linux 执行 ts_test ts_calibrate 都提示 No such file or directory, 求教
                                          TSLIB_TSDEVICE=/dev/input/eventX ts_calibrate
                                          X 用 0 / 1 / 2 ...代替
                                          • E
                                            ts_calibrate
                                            root@TinaLinux:/# TSLIB_TSDEVICE=/dev/input/event0
                                            xres = 800, yres = 480
                                            tslib: Selected device is not a touchscreen (must support ABS event type)
                                            ts_read: No such file or directory
                                            root@TinaLinux:/# TSLIB_TSDEVICE=/dev/input/event1
                                            root@TinaLinux:/# TSLIB_TSDEVICE=/dev/input/event2
                                            root@TinaLinux:/# TSLIB_TSDEVICE=/dev/input/event3
                                            输入getevent显示
                                            在/dev/input/目录下只有
                                            root@TinaLinux:/dev/input# ls
                                            event0
                                              你的 config-5.4 和 board.dts 是怎么修改的?
                                              • E
                                                @whycan 使用的是芒果派 MQ Pro,MQ 的板级配置文件,之后在menuconfig里面选择tslib和lvgl
                                                config-5.4 board.dts
                                                  @exoy28
                                                  # CONFIG_TOUCHSCREEN_SUN4I is not set
                                                  # CONFIG_TOUCHSCREEN_SUNXI is not set
                                                  这两个驱动中的一个需要打开,我不确定是那个,你把两个都勾上吧。
                                                  • E
                                                    exoy28 LV 4 最后由 编辑
                                                    @whycan 这个是在menuconfig里修改吗?还是直接改文件
                                                      @exoy28
                                                      都可以,我习惯直接改。
                                                      • E
                                                        @whycan getevent能够看到触控屏了
                                                        root@TinaLinux:/dev/input# getevent
                                                        poll 3, returned 1
                                                        /dev/input/event0: 0003 0000 000007ea
                                                        poll 3, returned 1
                                                        /dev/input/event0: 0003 0001 0000099a
                                                        poll 3, returned 1
                                                        poll 3, returned 1
                                                        poll 3, returned 1
                                                        poll 3, returned 1
                                                        poll 3, returned 1
                                                        /dev/input/event0: 0003 0000 00000953
                                                        poll 3, returned 1
                                                        /dev/input/event0: 0003 0001 000006cc
                                                        poll 3, returned 1
                                                        poll 3, returned 1
                                                        poll 3, returned 1
                                                        /dev/input/event0: 0003 0000 00000a65
                                                        poll 3, returned 1
                                                        /dev/input/event0: 0003 0001 00000750
                                                        poll 3, returned 1
                                                        poll 3, returned 1
                                                        poll 3, returned 1
                                                        运行ts_test显示
                                                        root@TinaLinux:/dev/input# TSLIB_TSDEVICE=/dev/input/event0 ts_test
                                                        558.762950:    459    225    255
                                                        558.838669:    459    225      0
                                                        559.418308:    531    247    255
                                                        559.559565:    531    247      0
                                                        560.008132:    399    248    255
                                                        560.280459:    399    248      0
                                                        560.597963:    501    171    255
                                                        561.001354:    579    191      0
                                                        561.581002:    495    217    255
                                                        561.787794:    495    217      0
                                                        562.170817:    306    220    255
                                                        562.498498:    351    109    255
                                                        562.826181:    318    376    255
                                                        563.153860:    275    225    255
                                                        563.481537:    365    353    255
                                                        563.809218:    294    267    255
                                                        564.409227:    541    340      0
                                                        ^Csignal 2 caught
                                                        但是在lv_example里没有触控
                                                          重新回到原点:
                                                          D1S芒果派MQ-R在tina-sdk2.0下无法识别电阻触摸屏:
                                                          https://bbs.aw-ol.com/topic/1444/share/2
                                                          • E
                                                            @whycan 修改lv_examples下的lv_drv_conf.h,将event3替换为event0
                                                             * Mouse or touchpad as evdev interface (for Linux based systems)
                                                            #ifndef USE_EVDEV
                                                            #  define USE_EVDEV           1
                                                            #ifndef USE_BSD_EVDEV
                                                            #  define USE_BSD_EVDEV       0
                                                            #if USE_EVDEV || USE_BSD_EVDEV
                                                            #  define EVDEV_NAME   "/dev/input/event0"        /*You can use the "evtest" Linux tool to get the list of devices and test them*/
                                                            #  define EVDEV_SWAP_AXES         0               /*Swap the x and y axes of the touchscreen*/
                                                            #  define EVDEV_CALIBRATE         0               /*Scale and offset the touchscreen coordinates by using maximum and minimum values for each axis*/
                                                            #  if EVDEV_CALIBRATE
                                                            #    define EVDEV_HOR_MIN         0               /*to invert axis swap EVDEV_XXX_MIN by EVDEV_XXX_MAX*/
                                                            #    define EVDEV_HOR_MAX      4096               /*"evtest" Linux tool can help to get the correct calibraion values>*/
                                                            #    define EVDEV_VER_MIN         0
                                                            #    define EVDEV_VER_MAX      4096
                                                            #  endif  /*EVDEV_CALIBRATE*/
                                                            #endif  /*USE_EVDEV*/
                                                            运行
                                                            export TSLIB_TSDEVICE=/dev/input/event0
                                                            ts_calibrate
                                                            显示
                                                            Took 2 samples...
                                                            Top left : X =  378 Y =  643
                                                            Took 2 samples...
                                                            Top right : X = 3643 Y =  725
                                                            Took 2 samples...
                                                            Bot right : X = 3669 Y = 3440
                                                            Took 2 samples...
                                                            Bot left : X =  353 Y = 3451
                                                            Took 3 samples...
                                                            Center : X = 2011 Y = 2123
                                                            -27.727510 0.212721 -0.000005
                                                            -42.589745 -0.001469 0.137518
                                                            Calibration constants: -1817150 13940 0 -2791161 -96 9012 65536
                                                            运行ts_test,点击屏幕后开发板重启
                                                            再次运行
                                                            ts_calibrate
                                                            运行lv_examples 0显示
                                                            wh=800x480, vwh=800x960, bpp=32,[  T156] VE: enable hw clock
                                                             rotated=0
                                                            Turn on double buffe[  T156] enable_cedar_hw_clk,552
                                                            ring.
                                                            无evdev interface报错,画面显示正常,触摸屏幕后开发板重启
                                                            • E
                                                              @whycan 运行ts_test后开发板重启前的输出
                                                              root@TinaLinux:/# ts_test
                                                              1224.843824:    658    201    255
                                                              1225.171497:    696    303    255
                                                              1225.499180:    582    364    255
                                                              1225.826854:    299    338    255
                                                              1226.154542:    479    133    255
                                                              1226.482225:    647    194    255
                                                              1226.809898:    448    281    255
                                                              1227.137577:    199    319    255
                                                              1227.465257:    214    204    255
                                                              1227.792936:    423    223    255
                                                              1228.120622:    569    295    255
                                                              1228.448298:    493    350    255
                                                              1228.775984:    261    277    255
                                                              1229.103655:    392    170    255
                                                              1229.431339:    597    193    255
                                                              1229.759022:    616    298    255
                                                              1230.086696:    408    373    255
                                                              1230.414384:    326    270    255
                                                              1230.742061:    498    171    255
                                                              1231.069736:    622    205    255
                                                              1231.669747:    565    321      0
                                                              1233.297962:    467     18    255
                                                              1233.439221:    467     18      0
                                                              1235.132969:    593    179    255
                                                              1235.460655:    634    254    255
                                                              1235.788329:    645    318    255
                                                              1236.116015:    503    398    255
                                                              1236.443688:    325    295    255
                                                              1236.771369:    364    204    255
                                                              1237.099055:    471    196    255
                                                              1237.426732:    572    263    255
                                                              1237.754416:    497    357    255
                                                              1238.082089:    366    360    255
                                                              1238.409767:    197    287    255
                                                              1238.737458:    129    207    255
                                                              1239.065130:     97    271    255
                                                              1239.392809:    154    362    255
                                                              1239.720488:    233    367    255
                                                              1240.048172:    343    306    255
                                                              1240.375853:    485    196    255
                                                              1240.703532:    608    182    255
                                                              1241.031216:    680    218    255
                                                              1241.358890:    672    300    255
                                                              1241.686568:    582    349    255
                                                              1242.014256:    443    288    255
                                                              1242.341926:    357    207    255
                                                              1242.669610:    270    149    255
                                                              1242.997289:    193    143    255
                                                              1243.324975:    173    225    255
                                                              1243.652654:    214    314    255
                                                              1243.980330:    321    340    255
                                                              1244.308009:    463    273    255
                                                              1244.635688:    547    190    255
                                                              1244.963371:    633    158    255
                                                              1245.291056:    695    212    255
                                                              1245.618728:    672    271    255
                                                              1246.218741:    596    314      0
                                                              1252.434480:    702     23    255
                                                              1252.837881:    701     22      0
                                                              root@TinaLinux:/# [32]HELLO! BOOT0 is starting!
                                                              [35]BOOT0 commit : 88480af
                                                              U-Boot 2018.05-g24521d6 (Feb 11 2022 - 08:52:39 +0000) Allwinner Technology
                                                              [00.112]DRAM:  64 MiB
                                                              [00.114]Relocation Offset is: 01ee7000
                                                              [00.118]secure enable bit: 0
                                                              [00.121]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
                                                              [00.127]flash init start
                                                              [00.129]workmode = 0,storage type = 1
                                                              [00.133][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
                                                              [00.138][mmc]: get sdc_type fail and use default host:tm1.
                                                              [00.144][mmc]: can't find node "mmc0",will add new node
                                                              [00.149][mmc]: fdt err returned <no error>
                                                              [00.153][mmc]: Using default timing para
                                                              [00.157][mmc]: SUNXI SDMMC Controller Version:0x50310
                                                              [00.174][mmc]: card_caps:0x3000000a
                                                              [00.177][mmc]: host_caps:0x3000003f
                                                              [00.180]sunxi flash init ok
                                                              [00.183]line:703 init_clocks
                                                              [00.186]drv_disp_init
                                                              fdt_getprop_u32 s_pwm.pwm-base fail
                                                              [00.202]drv_disp_init finish
                                                              [00.204]boot_gui_init:start
                                                              [00.207]set disp.dev2_output_type fail. using defval=0
                                                              [00.214]boot_gui_init:finish
                                                              54 bytes read in 3 ms (17.6 KiB/s)
                                                              [00.256]bmp_name=bootlogo.bmp size 38454
                                                              38454 bytes read in 7 ms (5.2 MiB/s)
                                                              [00.300]Loading Environment from SUNXI_FLASH... OK
                                                              [00.322]out of usb burn from boot: not need burn key
                                                              [00.350]Item0 (Map) magic is bad
                                                              [00.352]the secure storage item0 copy0 magic is bad
                                                              [00.380]Item0 (Map) magic is bad
                                                              [00.383]the secure storage item0 copy1 magic is bad
                                                              [00.387]Item0 (Map) magic is bad
                                                              [00.393]LCD open finish
                                                              root_partition is rootfs
                                                              set root to /dev/mmcblk0p5
                                                              [00.407]update part info
                                                              [00.412]update bootcmd
                                                              [00.418]change working_fdt 0x42aa6da0 to 0x42a86da0
                                                              [00.448]update dts
                                                              noncached_alloc(): addr = 0x42c8a080
                                                              noncached_alloc(): addr = 0x42c8a0c0
                                                              noncached_alloc(): addr = 0x42c8a100
                                                              noncached_alloc(): addr = 0x42c8a940
                                                              geth_sys_init fail!
                                                              [00.468]Board Net Initialization Failed
                                                              [00.472]No ethernet found.
        @exoy28
        需要tslib里面的uinput app,驱动记得开启 USER INPUT配置。
        • E
        @whycan uinput app具体应该怎么使用呢?
        menuconfig中已经勾选ts_uinput选项
        @exoy28 后台跑着 uinput,然后再用ts_test测试这个生成后的 eventX。
        • E
        @whycan 运行ts_calibrate,运行ts_uinput_start.sh中的代码
        root@TinaLinux:/# export TSLIB_TSDEVICE=/dev/input/event0
        Took 1 samples...
        Top left : X =  350 Y =  691
        Took 1 samples...
        Top right : X = 3633 Y =  723
        Took 1 samples...
        Bot right : X = 3617 Y = 3478
        Took 1 samples...
        Bot left : X =  367 Y = 3424
        Took 1 samples...
        Center : X = 1993 Y = 2107
        -26.796770 0.214292 -0.000035
        -45.028530 -0.001821 0.138470
        Calibration constants: -1756153 14043 -2 -2950989 -119 9074 65536
        root@TinaLinux:/# TS_UINPUT_DEV_FILE=$(ts_uinput -d -v)
        [  T158] input: ts_uinput as /devices/virtual/input/input2
        root@TinaLinux:/# TS_UINPUT_DEV_FILE_CHECKED=$(ls "$TS_UINPUT_DEV_FILE" | grep '
        event')
        ls: tslib: WARNING: no multitouch using VARIANCE filter
        /dev/input/event2: No such file or directory
        root@TinaLinux:/# if [ ! -z "$TS_UINPUT_DEV_FILE_Crm -f /dev/input/ts_uinput
        > ln -s $TS_UINPUT_DEV_FILE_CHECKED /dev/input/ts_uinput
        > else
        > echo "ts_uinput: Error creating event device"
        > exit 1
        > fi
        ts_uinput
        ------run profile file-----
        add device 1: /dev/input/event2
        add device 2: /dev/input/event1
        add device 3: /dev/input/event0
        [    C0] random: crng init done
        poll 4, returned 2
        /dev/input/event2: 0001 014a 00000001
        /dev/input/event0: 0003 0000 00000608
        poll 4, returned 2
        /dev/input/event2: 0003 0000 0000012f
        /dev/input/event0: 0003 0001 00000aa7
        poll 4, returned 2
        /dev/input/event2: 0003 0001 00000149
        poll 4, returned 2
        /dev/input/event2: 0000 0000 00000000
        poll 4, returned 1
        poll 4, returned 1
        ^C
        root@TinaLinux:/# ^C
        root@TinaLinux:/# ts_test dev/input/event2
        ts_open: No such file or directory
        root@TinaLinux:/# ts_test dev/input/event0
        生成了新的event,但是ts_test报错
        @exoy28
        TSLIB_TSDEVICE=/dev/input/event2 ts_test
        • E
        能够输出结果,但是光标位置不对
        root@TinaLinux:/# TSLIB_TSDEVICE=/dev/input/event2 ts_test
        876.254707:     66     -3    255
        876.910048:     99      3    255
        877.237729:    109      7    255
        877.565413:    105      7    255
        877.893097:     12      2    255
        878.220772:    -17     -7    255
        878.548451:    -10    -25    255
        878.876130:      9    -34    255
        879.203822:     62    -27    255
        879.531498:    100     -2    255
        879.859168:     78     13    255
        • E
        @whycan 运行TSLIB_TSDEVICE=/dev/input/event2 ts_calibrate重新校准,点击屏幕无反应
        @exoy28
        ① 用这个先生成校准文件:
        TSLIB_TSDEVICE=/dev/input/event0 ts_calibrate
        ② 后台运行 uinput:
        TSLIB_TSDEVICE=/dev/input/event0 ts_uinput
        ③ 前台执行 测试:
        这个坐标应该是正确的。
        • E
        不行,坐标还是不对,光标会漂移到左上角
        @exoy28
        ③ 前台执行 测试:
        不好意思这个不对,纠正一下:
        ③ 前台执行 测试:
        evtest /dev/input/event2
        或者 getevent
        • E
        root@TinaLinux:/# TSLIB_TSDEVICE=/dev/input/event0 ts_calibrate
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 364
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 681
        [    C0] evbug: Event. Dev: input0, Type: 1, Code: 330, Value: 1
        [    C0] evbug: Event. Dev: input0, Type: 0, Code: 0, Value: 0
        [    C0] evbug: Event. Dev: input0, Type: 1, Code: 330, Value: 0
        Took 1 samples...
        Top left : X =  364 Y =  681
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3658
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 690
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 688
        Took 2 samples...
        Top right : X = 3658 Y =  689
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3656
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3496
        Took 1 samples...
        Bot right : X = 3656 Y = 3496
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 343
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3500
        Took 1 samples...
        Bot left : X =  343 Y = 3500
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2017
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2053
        Took 1 samples...
        Center : X = 2017 Y = 2053
        -27.222799 0.211892 0.000877
        -41.296440 -0.000077 0.135066
        Calibration constants: -1784073 13886 57 -2706403 -5 8851 65536
        root@TinaLinux:/# TSLIB_TSDEVICE=/dev/input/event0 ts_uinput -d
        [  T157] input: ts_uinput as /devices/virtual/input/input2
        [  T157] evbug: Connected device: input2 (ts_uinput at unknown)
        input2
        root@TinaLinux:/# evtest /dev/input/event2
        -/bin/sh: evtest: not found
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2766
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 1954
        [  T158] evbug: Event. Dev: input2, Type: 1, Code: 330, Value: 1
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 560
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 222
        [  T158] evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 0
        poll 4, returned 2
        /dev/input/event0: 0003 0000 00000ace
        poll 4, returned 2
        /dev/input/event2: 0003 0000 00000230
        /dev/input/event0: 0003 0001 000007a2
        poll 4, returned 2
        /dev/input/event2: 0003 0001 000000de
        poll 4, returned 2
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2251
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3012
        poll 4, returned 1
        /dev/input/event0: 0003 0000 000008cb
        poll 4, returned 1
        /dev/input/event0: 0003 0001 00000bc4
        poll 4, returned 1
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2784
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 452
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 365
        poll 4, returned 2
        /dev/input/event2: 0003 0000 000001c4
        /dev/input/event0: 0003 0000 000004e7
        poll 4, returned 2
        /dev/input/event2: 0003 0001 0000016d
        /dev/input/event0: 0003 0001 00000ae0
        poll 4, returned 2
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1609
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2272
        poll 4, returned 1[  T158] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 241
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 334
        /dev/input/event0: 0003 0000 00000649
        poll 4, returned 1
        /dev/input/event0: 0003 0001 000008e0
        poll 4, returned 1
        poll 4, returned 1
        /dev/input/event2: 0003 0000 000000f1
        poll 4, returned 1
        /dev/input/event2: 0003 0001 0000014e
        poll 4, returned 1
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2751
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2562
        poll 4, returned 1[  T158] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 315
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 265
        /dev/input/event0: 0003 0000 00000abf
        poll 4, returned 1
        /dev/input/event0: 0003 0001 00000a02
        poll 4, returned 1
        poll 4, returned 1
        /dev/input/event2: 0003 0000 0000013b
        poll 4, returned 1
        /dev/input/event2: 0003 0001 00000109
        poll 4, returned 1
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3569
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3526
        poll 4, returned 1[  T158] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 557
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 304
        /dev/input/event0: 0003 0000 00000df1
        poll 4, returned 1
        /dev/input/event0: 0003 0001 00000dc6
        poll 4, returned 1
        poll 4, returned 1
        /dev/input/event2: 0003 0000 0000022d
        poll 4, returned 1
        /dev/input/event2: 0003 0001 00000130
        poll 4, returned 1
        poll 4, returned 1[  T158] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 732
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 434
        poll 4, returned 1
        poll 4, returned 1
        /dev/input/event2: 0003 0000 000002dc
        poll 4, returned 1
        /dev/input/event2: 0003 0001 000001b2
        poll 4, returned 1
        @exoy28
        现在坐标对了吗?
        • E
        @whycan 坐标应该是对了,但是运行lv_example触摸还是没反应,有时候连续触摸几下就会直接重启
        wh=800x480, vwh=800x960, bpp=32,[  T160] VE: enable hw clock
        rotated=0
        Turn on double buffe[  T160] enable_cedar_hw_clk,552
        ring.
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1770
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 1624
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 348
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 179
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3392
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2034
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 692
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 232
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3389
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2015
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 230
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1720
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2008
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 337
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 231
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2090
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 1926
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 416
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 219
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2962
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 834
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 600
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 71
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2971
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 846
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 602
        [  T158] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 72
        @exoy28
        用我这个试一试:
        这个比较简单: 哪吒D1开发板 LVGL7 源码下载(带git仓库)
        • E
        exoy28 LV 4 最后由 编辑
        @whycan 排查了一下异常重启可能是tf卡的问题,我买张新卡再试试看
        • E
        @whycan 换了张新的tf卡试了下,基本没有重启的问题了,但是触摸还是不太行。
        在lv_drv_conf.h中指定输入为event0,即不使用tslib,在lvgl中触摸左上角时有反应,触摸其他区域无反应。
        在lv_drv_conf.h中指定输入为event2,同时使用ts_uinput生成event2,在lvgl中触摸所有区域均无反应。运行getevent可以发现生成的event2坐标正确。
        是不是uinput生成的event2和event0冲突了?
        @exoy28
        理论上没有问题的,实在不行可以在lvgl把event数据打印出来看看。
        您再参考这个帖子:
        收到芒果大佬的库存 DVP与MIPI 双摄像头R11开发板
        https://bbs.aw-ol.com/topic/1305/share/8
        • E
        @whycan 运行TSLIB_TSDEVICE=/dev/input/event2 ts_test得到的结果有点奇怪,光标会漂移到左上角,触摸数据和evbug的对不上
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3788
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3478
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 773
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 422
        [  T167] evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 0
        5415.808755:    128     14    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3821
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3546
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3835
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3557
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 781
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 432
        5416.136435:    128     13    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3826
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3547
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 784
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 433
        5416.791784:    129     15    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3543
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 782
        5417.119476:    130     15    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3823
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3540
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 431
        5417.440668:    130     15    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3827
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3553
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3832
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3566
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 783
        5417.774830:    130     15    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3860
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3857
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3874
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3809
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 790
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 474
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3859
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3678
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 793
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 467
        5419.085551:    131     20    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3858
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 450
        5419.413279:    132     19    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3861
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3672
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 789
        5419.734420:    131     17    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3857
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3675
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 449
        5420.068592:    131     17    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3862
        5420.396277:    131     17    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3867
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3680
        5420.723954:    131     17    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3870
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3683
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 791
        5421.051640:    131     17    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3872
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3685
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 792
        5421.379314:    132     17    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3864
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3684
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 451
        5421.707000:    132     17    255
        5422.034675:    132     17    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3681
        5422.355931:    132     17    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3682
        5423.017706:    131     17    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3865
        5423.345393:    131     17    255
        5424.000746:    132     17    255
        5424.328436:    132     17    255
        ^Csignal 2 caught
        root@TinaLinux:/# clear
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 405
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3597
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 48
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 446
        5490.919324:    -27     18    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 540
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3565
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 756
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3493
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 441
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1093
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3415
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 123
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1547
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3391
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 196
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 420
        5491.896054:    -11     16    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2055
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3395
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 293
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 415
        5492.223752:      4     14    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2510
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3432
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 402
        5492.551421:     25     13    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2816
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3424
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 500
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 419
        5492.879089:     48     13    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3143
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3412
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 566
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 417
        5493.206905:     69     14    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3543
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3457
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 636
        5493.534454:     83     13    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3778
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 722
        5493.862179:     98     13    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3957
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3460
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 772
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 416
        5494.189815:    117     13    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3985
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 811
        5494.517495:    128     13    255
        [  T167] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 817
        5494.845169:    136     13    255
        @exoy28 发个照片看看。
        • E
        @whycan
        触控测试视频
        shell输出
        [   T59] [sunxi-ehci0]: remove, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe000752910
        nice: can't execute '/usr/bin/story_ota_bin': No such file or directory
        [  T147] read descriptors
        [   T59] sunxi-ehci 4101000.ehci0-controller: remove, state 4
        [   T59] usb usb3: USB disconnect, device number 1
        | |   _ |   [  T147] read strings
        ||   |  |  |__ | ||   || | ||_'_|
        [   T59] sunxi-ehci 4101000.ehci0-controller: USB bus 3 deregistered
        [   T59] [ohci0-controller]: sunxi_usb_disable_ohci
        [   T59] [sunxi-ohci0]: remove, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe000752cd8
        nodev   debugfs
        [   T59] sunxi-ohci 4101400.ohci0-controller: remove, state 4
        [   T59] usb usb4: USB disconnect, device number 1
        [   T59] sunxi-ohci 4101400.ohci0-controller: USB bus 4 deregistered
        [   T59]
        [   T59] insmod_device_driver
        [   T59]
        root@TinaLinux:/# [   T59] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
        [   T59] device_chose finished 139!
        [   T13] sunxi_set_cur_vol_work()397 WARN: get power supply failed
        [   T13] android_work: sent uevent USB_STATE=CONNECTED
        [    C0] configfs-gadget gadget: high-speed config #1: c
        [   T13] android_work: sent uevent USB_STATE=CONFIGURED
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 372
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 615
        Took 1 samples...
        Top left : X =  372 Y =  615
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3683
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 726
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3681
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 735
        Took 2 samples...
        Top right : X = 3682 Y =  730
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3682
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3494
        Took 1 samples...
        Bot right : X = 3682 Y = 3494
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 393
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3440
        Took 3 samples...
        Bot left : X =  387 Y = 3432
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2021
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2090
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2089
        Took 2 samples...
        Center : X = 2019 Y = 2089
        -28.785591 0.211973 -0.000569
        -34.737820 -0.003649 0.136168
        Calibration constants: -1886492 13891 -37 -2276577 -239 8923 65536
        root@TinaLinux:/# TSLIB_TSDEVICE=/dev/input/event0 ts_uinput -d -v
        [  T163] input: ts_uinput as /devices/virtual/input/input2
        [  T163] evbug: Connected device: input2 (ts_uinput at unknown)
        /dev/input/event2
        root@TinaLinux:/# TSLIB_TSDEVICE=/dev/input/event2 ts_test[    C0] random: crng init done
        ^Csignal 2 caught
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 278
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3696
        [  T164] evbug: Event. Dev: input2, Type: 1, Code: 330, Value: 1
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 28
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 467
        [  T164] evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 0
        6125.790361:    -23     28    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 422
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3732
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 543
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3748
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 58
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 471
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 904
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3774
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 84
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 473
        6126.439293:    -16     29    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1340
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 160
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 475
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1855
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3852
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 253
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 478
        6127.094758:      4     29    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2228
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3840
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 362
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 482
        6127.422437:     24     29    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2647
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3784
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 441
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 479
        6127.750120:     47     29    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3041
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3753
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 530
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 470
        6128.077806:     64     28    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3318
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3713
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 613
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 465
        6128.405497:     83     27    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3492
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3712
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 672
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 458
        6128.733157:    100     26    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3575
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3723
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 709
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 457
        6129.060856:    113     25    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3733
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 726
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 459
        6129.388522:    121     24    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3739
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 780
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 813
        6130.043886:    136     24    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3323
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3793
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 673
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 469
        6130.113010:    143     24    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3048
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3722
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2651
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3657
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 615
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 460
        6132.344078:    113     26    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2388
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3648
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 531
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 453
        6132.993003:    101     25    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2229
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3650
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 475
        6133.320696:     83     25    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2005
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3658
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 454
        6133.648358:     71     25    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1790
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3714
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 394
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 456
        6133.976041:     64     25    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1802
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3702
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 348
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 464
        6134.303723:     54     25    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2156
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3456
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2560
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 3207
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 426
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 427
        6134.631409:     44     27    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2911
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2942
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 512
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 392
        6135.286759:     61     21    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3107
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2862
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 586
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 355
        6135.614441:     79     16    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3247
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2803
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 628
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 343
        6135.942119:     95     11    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3351
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2727
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 657
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 335
        6136.269811:    104      9    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3428
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2690
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 679
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 324
        6136.597482:    110      8    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3469
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2665
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 696
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 319
        6136.925163:    114      6    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3528
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2584
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 704
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 315
        6137.252853:    118      6    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3527
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2576
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 717
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 304
        6137.580524:    120      5    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3043
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2481
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2466
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2296
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 614
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 291
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1933
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2194
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 492
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 268
        6138.563549:    101      2    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1736
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2126
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 379
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 256
        6138.891242:     75      0    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1589
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2093
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 337
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 248
        6139.219069:     51     -1    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1587
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2096
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 306
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 244
        6139.546609:     42     -2    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1602
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 2066
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 1865
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 1911
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 309
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 240
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2421
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 1672
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 365
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 218
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 2824
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 1548
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 483
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 184
        6140.857325:     48     -6    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3134
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 1490
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 568
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 165
        6141.184996:     73    -11    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3340
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 1412
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 634
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 156
        6141.512692:     91    -14    255
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 3448
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 1375
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 678
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 145
        6141.840359:    105    -15    255
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 701
        [  T164] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 139
        6142.168041:    114    -17    255
        @exoy28
        event2 已经用 uinput 转换成屏幕坐标了,不是原始adc值了。
        所以用 ts_test 不能再测试 event2 了。
        但是这样操作或许可以:
        • E
        @whycan 运行
        后触摸屏幕无反应,shell显示
        root@TinaLinux:/# TSLIB_TSDEVICE=/dev/input/event2 ts_calibrate
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 370
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 668
        [  T166] evbug: Event. Dev: input2, Type: 1, Code: 330, Value: 1
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 48
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 53
        [  T166] evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 0
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 379
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 674
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 673
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 50
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 54
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 51
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 56
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 415
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 694
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 58
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 57
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 414
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 710
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 409
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 699
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 59
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 411
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 57
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 58
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 416
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 687
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 399
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 697
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 54
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 691
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 55
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 391
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 684
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 662
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 53
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 676
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 0, Value: 52
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 677
        [  T166] evbug: Event. Dev: input2, Type: 3, Code: 1, Value: 55
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 384
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 388
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 1, Value: 682
        [    C0] evbug: Event. Dev: input0, Type: 3, Code: 0, Value: 392
        @exoy28
        那或许不能这么操作了,你只要保证 evtest / getevent 输出的坐标和液晶显示一致,lvgl7 触摸问题不大,实在不行就在读 event 设备那地方加点调试代码。
        yelong98 LV 7 最后由 编辑
        D1S的电阻触摸现在还没有帖子说解决了,我今天试了menuconfig里面选上tslib都会编译失败,先驱们知道咋回事么
        • E
        @whycan 将ts.conf中除了module linear之外的代码全部注释,勉强可以触控,但是灵敏度很差
        有什么提高性能的办法吗?
        • E
        exoy28 LV 4 @yelong98 最后由 编辑
        @yelong98 你用的什么环境?我用ubuntu14.04虚拟机按照官方教程配置,基本没出过编译问题。
        Y 1 条回复 最后回复 回复 引用 分享 0
        @exoy28
        电阻屏太不适合做滑动,
        你再微调一下 ts.conf 试一试或许可以。
        有空可以参考一下: ns2009驱动去飞点
        • E
        @whycan 滑动还是其次,按压延迟很严重,接触屏幕后要半秒左右才有响应。
        请问大佬哪里可以调节电阻屏的采样频率?我调低了lv_conf.h里面的LV_INDEV_DEF_READ_PERIOD,但是效果不明显。
        A A 2 条回复 最后回复 回复 引用 分享 0
        yelong98 LV 7 @exoy28 最后由 编辑
        @exoy28 20.04,14.04都没源了,我没有用虚拟机,装的真系统。昨晚发现make -j1没问题,make -j8就完蛋,搞不懂
        • E
        @yelong98 我一直都用的make -j16,基本上没有报过错
        adaoz LV 4 @exoy28 最后由 编辑
        @exoy28 老哥触摸延迟的问题你解决了么,可否提点一下。
        我弄 RTP 电阻触摸也遇到同样的问题,ts_test 测试点击触摸屏接近 1s 才有反应,点的快了 ts_test 没有任何输出,感觉也像是触摸的采用频率低了或过滤参数高了
        • G
        guozhaifa LV 3 最后由 编辑
        你好,这边这个tslib怎么编译的,可否告知一下。谢谢
        as86455011 LV 2 @exoy28 最后由 编辑
        @exoy28 if (of_device_is_compatible(np, "allwinner,sun8i-ts"))
        writel(ADC_FIRST_DLY(0xf) | ADC_FIRST_DLY_MODE(1)
        | ADC_CLK_DIV(2) | FS_DIV(6) | T_ACQ(63),
        ts->base + TP_CTRL0);
        触摸屏驱动改一下寄存器的参数
        as86455011 LV 2 @adaoz 最后由 编辑
        @adaoz if (of_device_is_compatible(np, "allwinner,sun8i-ts"))
        改一下触摸屏驱动的时钟初始化寄存器参数
        chdeng1 LV 5 最后由 编辑
        请问,800480这个屏,用原始代码,我的是上下反,您这里出现过上下反吗?是怎样修改的?谢谢
        damifan110 LV 5 最后由 编辑
        大佬 有相关的文档推荐吗?我没有找到RTP相关的文档,只打开了设备树中的RTP,后面就不知道应该怎么调整了,还望指点一二,谢谢
