    tina sdk 下ubuntu分配根文件系统分区大于4G时,启动无法挂载成功
    5
    8
    6587
      duanzhh LV 5 最后由 编辑
      环境:
      emmc:8G
      平台:r818
      系统:tina + ubuntu
      现象描述:
      当挂载的rootfs.img小于4G时,系统可以正常启动;当rootfs.img大于4G时,系统开机卡在挂载根文件系统系统阶段。
      目前给的分区大小:
      [partition]
          name         = rootfs
          size         = 10485760   # 5G大小
          downloadfile = "rootfs.fex"
          user_type    = 0x8000
      打包rootfs.img为4.9G大小:
      creating img file, wait...
      记录了5000+0 的读入
      记录了5000+0 的写出
      5242880000 bytes (5.2 GB, 4.9 GiB) copied, 13.2979 s, 394 MB/s
      [sudo] dzh 的密码:
      mke2fs 1.44.1 (24-Mar-2018)
      丢弃设备块: 完成
      创建含有 1280000 个块(每块 4k)和 320000 个inode的文件系统
      文件系统UUID:1f080f91-343c-414a-bea9-d1d0933daab1
      超级块的备份存储于下列块:
      	32768, 98304, 163840, 229376, 294912, 819200, 884736
      正在分配组表: 完成
      正在写入inode表: 完成
      创建日志(16384 个块) 完成
      写入超级块和文件系统账户统计信息: 已完成
      img file ----- ok!
      copy file to img,wait...
      mnt:
      bin  boot  dev	etc  home  lib	lost+found  media  mnt	opt  proc  root  run  sbin  srv  sys  tmp  usr	var
      copy file ----- ok!
      -rw-rw-r-- 1 dzh dzh 4.9G Sep 30 16:32 rootfs.img
      =============== filesystem: rootfs.img created ==============
      打包烧录到平台上时,报错如下:
      [    4.636292] ALSA device list:
      [    4.639640]   #0: audiocodec
      [    4.644789] EXT4-fs (mmcblk0p5): couldn't mount as ext3 due to feature incompatibilities
      [    4.657225] JBD2: no valid journal superblock found
      [    4.662736] EXT4-fs (mmcblk0p5): error loading journal
      [    4.669618] EXT2-fs (mmcblk0p5): error: couldn't mount because of unsupported optional features (2c0)
      [    4.682958] EXT4-fs (mmcblk0p5): couldn't mount as ext3 due to feature incompatibilities
      [    4.692129] plugin --> switch:1
      [    4.699038] JBD2: no valid journal superblock found
      [    4.704546] EXT4-fs (mmcblk0p5): error loading journal
      [    4.711452] EXT2-fs (mmcblk0p5): error: couldn't mount because of unsupported optional features (2c0)
      [    4.724335] List of all partitions:
      [    4.728285] b300         7634944 mmcblk0  driver: mmcblk
      [    4.734302]   b301             256 mmcblk0p1 a0085546-4166-744a-a353-fca9272b8e45
      [    4.742949]   b302             512 mmcblk0p2 a0085546-4166-744a-a353-fca9272b8e46
      [    4.751387]   b303             512 mmcblk0p3 a0085546-4166-744a-a353-fca9272b8e47
      [    4.759827]   b304           15360 mmcblk0p4 a0085546-4166-744a-a353-fca9272b8e48
      [    4.768261]   b305         5242880 mmcblk0p5 a0085546-4166-744a-a353-fca9272b8e49
      [    4.776695]   b306           25600 mmcblk0p6 a0085546-4166-744a-a353-fca9272b8e4a
      [    4.785129]   b307             256 mmcblk0p7 a0085546-4166-744a-a353-fca9272b8e4b
      [    4.793563]   103:00000    2328559 mmcblk0p8 a0085546-4166-744a-a353-fca9272b8e4c
      [    4.802006] b318             512 mmcblk0rpmb  (driver?)
      [    4.807901] b310            4096 mmcblk0boot1  (driver?)
      [    4.813902] b308            4096 mmcblk0boot0  (driver?)
      [    4.819890] No filesystem could mount root, tried:  ext3 ext4 ext2 squashfs vfat msdos ntfs
      [    4.829361] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5)
      [    4.838857] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 4.9.191 #405
      [    4.845805] Hardware name: sun50iw10 (DT)
      [    4.850312] Call trace:
      [    4.853070] [<ffffff8008087938>] dump_backtrace+0x0/0x204
      [    4.859142] [<ffffff8008087b50>] show_stack+0x14/0x1c
      [    4.864826] [<ffffff80082904ec>] dump_stack+0x88/0xb0
      [    4.870511] [<ffffff800811131c>] panic+0x120/0x310
      [    4.875901] [<ffffff8008911228>] mount_block_root+0x21c/0x2e4
      [    4.882362] [<ffffff8008911360>] mount_root+0x70/0x80
      [    4.888043] [<ffffff80089114e0>] prepare_namespace+0x170/0x180
      [    4.894603] [<ffffff8008910e34>] kernel_init_freeable+0x150/0x18c
      [    4.901459] [<ffffff80086ef06c>] kernel_init+0x10/0xf8
      [    4.907238] [<ffffff8008083180>] ret_from_fork+0x10/0x50
      [    4.913209] SMP: stopping secondary CPUs
      [    4.917624] Kernel Offset: disabled
      [    4.921555] Memory Limit: none
      [    4.925005] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5)
      请问有人遇到过这种吗,大佬们有没有解决思路提供啊😢
        柚木 鉉 LV 9 @duanzhh 最后由 编辑
        @duanzhh 一般来说大镜像是使用overlayfs的方法而不是固定容量
        另外:
        检查下是不是rootfs.img镜像也有问题
        D 1 条回复 最后回复 回复 引用 分享 0
          duanzhh LV 5 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru 感谢大佬 ,昨天按照你的指示检查了一下,rootfs.img确实有问题,需要额外加一句调整分区的指令才可以;后面得空再研究如何使用overlayfs,特别感谢👍 👍 👍
          • DAIZEBIN
            DAIZEBIN LV 7 @duanzhh 最后由 编辑
            @duanzhh 在 tina sdk 下ubuntu分配根文件系统分区大于4G时,启动无法挂载成功 中说:
            调整分区的指令
            这个额外的“调整分区的指令”指的是?🤔
              duanzhh LV 5 @DAIZEBIN 最后由 编辑
              @daizebin 我使用的时resize2fs这个指令调整文件系统分区大小的
              • DAIZEBIN
                @duanzhh 👏 👏
                  yang_wang LV 3 最后由 编辑
                  大佬,你是把Tina的OpenWRT替换成了Ubuntu操作系统吗?
                    jerrytech LV 2 最后由 编辑
                    请问大佬这个怎么替换?是直接在pack的时候把rootfs.img换掉还是在之前就事先换掉?
