    T113 MQ-R板子用tina 无法进入系统
    Linux
    8
    15
    14102
      mhcsoft LV 5 最后由 编辑
      用论坛下载得T113 tina sdk编译了一版固件,烧录到sd卡,启动不了。log如下:
      [113]HELLO! BOOT0 is starting!
      [116]BOOT0 commit : 4d16602
      [119]set pll start
      [121]fix vccio detect value:0xc0
      [128]periph0 has been enabled
      [131]set pll end
      [133][pmu]: bus read error
      [135]board init ok
      [137]ZQ value = 0x2f
      [139]get_pmu_exist() = -1
      [142]ddr_efuse_type: 0xa
      [144]trefi:7.8ms
      [147][AUTO DEBUG] single rank and full DQ!
      [151]ddr_efuse_type: 0xa
      [153]trefi:7.8ms
      [156][AUTO DEBUG] rank 0 row = 13
      [159][AUTO DEBUG] rank 0 bank = 8
      [162][AUTO DEBUG] rank 0 page size = 2 KB
      [166]DRAM BOOT DRIVE INFO: V0.33
      [170]DRAM CLK = 792 MHz
      [172]DRAM Type = 3 (2:DDR2,3:DDR3)
      [175]DRAMC read ODT  off.
      [178]DRAM ODT value: 0x42.
      [180]ddr_efuse_type: 0xa
      [184]DRAM SIZE =128 M
      [186]dram_tpr4:0x0
      [187]PLL_DDR_CTRL_REG:0xf8004100
      [191]DRAM_CLK_REG:0xc0000000
      [193][TIMING DEBUG] MR2= 0x18
      [200]DRAM simple test OK.
      [203]rtc standby flag is 0x0, super standby flag is 0x0
      [208]dram size =128
      [211]card no is 0
      [212]sdcard 0 line count 4
      [215][mmc]: mmc driver ver 2021-05-21 14:47
      [224][mmc]: Wrong media type 0x0
      [227][mmc]: ***Try SD card 0***
      [238][mmc]: HSSDR52/SDR25 4 bit
      [241][mmc]: 50000000 Hz
      [243][mmc]: 3840 MB
      [245][mmc]: ***SD/MMC 0 init OK!!!***
      [341]Loading boot-pkg Succeed(index=0).
      [345]Entry_name        = u-boot
      [352]Entry_name        = optee
      [356]Entry_name        = dtb
      [359]mmc not para
      [361]Jump to second Boot.
      M/TC: OP-TEE version: 6aef7bb2-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Jul 23 09:25:11 UTC 2021 arm
      E/TC:0 0 check_hardware_info:90 hardware check error1
      E/TC:0 0 Panic at core/arch/arm/plat-sun8iw20p1/main.c:301 <plat_init>
      E/TC:0 0 Call stack:
      E/TC:0 0  0x41b0a271
      B 1 条回复 最后回复 回复 引用 分享 1
        柚木 鉉 LV 9 最后由 编辑
        关闭optee功能
        M 1 条回复 最后回复 回复 引用 分享 0
          mhcsoft LV 5 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru 怎么关闭啊,uboot 添加CONFIG_NOT_USE_OPTEE25 选项编译报错
            mhcsoft LV 5 最后由 编辑
            问题解决:让基友少走弯路,把修改共享出来
            sun8iw20p1_evb2_lowmem_defconfig
            xiaowenge M C 3 条回复 最后回复 回复 引用 分享 0
              DOT小文哥 LV 8 @mhcsoft 最后由 编辑
              @mhcsoft 在 T113 MQ-R板子用tina 无法进入系统 中说:
              感谢基友👍
              E 1 条回复 最后回复 回复 引用 分享 1
                bynce LV 3 @mhcsoft 最后由 编辑
                @mhcsoft
                卡在这步。 老铁到底怎么关闭的。 对比你的defconfig 也区别。
                E 1 条回复 最后回复 回复 引用 分享 0
                  eddardzhu LV 5 @bynce 最后由 编辑
                  @bynce 请问板子串口是怎么接的,用这个config 通过tf卡启动,可以启动看到logo,就是死活没有串口日志
                    eddardzhu LV 5 @eddardzhu 最后由 编辑
                    @eddardzhu 接了E2和E3作收发,没有数据输出,但是有logo
                    e8379cba-5510-4115-9f4f-887652daa6a9-IMG_20220530_165101.jpg /home/eddard/IMG_20220530_165101.jpg
                      eddardzhu LV 5 @xiaowenge 最后由 编辑
                      @xiaowenge 请问板子串口是怎么接的,用这个config 通过tf卡启动,可以启动看到logo,就是死活没有串口日志
                        mhcsoft LV 5 @eddardzhu 最后由 编辑
                        @eddardzhu 串口接地了没有。
                          memory LV 7 @mhcsoft 最后由 编辑
                          大佬,这个文件与 brandy/brandy-2.0/u-boot-2018/configs/sun8iw20p1_evb2_defconfig 一模一样,一行都没改。
                          M 2 条回复 最后回复 回复 引用 分享 0
                            mhcsoft LV 5 @memory 最后由 编辑
                            @memory 呀,贴错了
                              @memory 没贴错,你看错名 了 ,还是我俩版本不一样
                                captain LV 5 @mhcsoft 最后由 编辑
                                @mhcsoft
                                能不能贴一下具体的选项呀!全局搜索了一下uboot 下面的 .config ,没发现打开OPTEE的选项被选中。
                                • TsMax
                                  TsMax LV 5 最后由 编辑
                                  @captain 在 T113 MQ-R板子用tina 无法进入系统 中说:
                                  @mhcsoft
                                  同问
