    因为喜欢用ADB,因为不喜欢插拔TF卡,所以D1直接用PhoenixSuit烧录TF(SDNAND)
    12
    16
    12085
    • T
      TEVET LV 7 最后由 编辑
      如题
      因为不喜欢插拔卡搞来搞去,喜欢直接USB插上直接干活烧录到底,
      那就,看下D1怎么搞TF直接通过PhoenixSuit烧录 TF卡或者SDNAND
      第一步,看启动过程的LOG:
      U-Boot 2018.05-g0a62f10 (Dec 31 2021 - 07:53:57 +0000) Allwinner Technology
      [03.820]DRAM:  512 MiB
      [03.825]Relocation Offset is: 1def0000
      [03.847]secure enable bit: 0
      [03.851]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [03.858]flash init start
      [03.860]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [03.867][mmc]: mmc driver ver uboot2018:2021-04-16 14:23:00-1
      [03.876][mmc]: get sdc_type fail and use default host:tm4.
      [03.900][mmc]: Is not Boot mode!
      [03.903][mmc]: SUNXI SDMMC Controller Version:0x50310
      [03.914][mmc]: ************Try SD card 2************
      [03.919][mmc]: mmc 2 cmd timeout 100 status 100
      [03.924][mmc]: smc 2 err, cmd 8,  RTO
      [03.927][mmc]: mmc 2 close bus gating and reset
      [03.932][mmc]: mmc 2 cmd timeout 100 status 100
      [03.936][mmc]: smc 2 err, cmd 55,  RTO
      [03.940][mmc]: mmc 2 close bus gating and reset
      [03.944][mmc]: ************Try MMC card 2************
      [03.953][mmc]: mmc 2 cmd timeout 100 status 100
      [03.957][mmc]: smc 2 err, cmd 1,  RTO
      [03.960][mmc]: mmc 2 close bus gating and reset
      [03.965][mmc]: Card did not respond to voltage select!
      [03.969][mmc]: ************SD/MMC 2 init error!************
      [03.975][mmc]: mmc init product failed
      MMC init failed
      try emmc fail
      [03.988]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
      [03.994]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
      [04.041]sunxi-spinand-phy: request spi0 gpio ok
      [04.045]sunxi-spinand-phy: request general tx dma channel ok!
      [04.050]sunxi-spinand-phy: request general rx dma channel ok!
      [04.056]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [04.060]sunxi-spinand-phy: init spic0 clk ok
      [04.085]sunxi-spinand-phy: read id failed : -110
      try nand fail
      [04.132]unrecognized JEDEC id bytes: ff, ff, ff
      try spinor fail
      initcall sequence 000000005ff948c8 failed at call 000000004200d70e (err=-1)
      看到关键的点
      try card 2
      set card number 2
      get card number 2
      这里默认从card 2 开始
      那么咱就先试试看,直接从card 0 行不行?
      直接搜索到代码中定位到的是:
      tina_d1_open_v1.0.1\lichee\brandy-2.0\u-boot-2018\drivers\sunxi_flash\mmc\sdmmc.c
      中的接口:
      int sunxi_sprite_mmc_probe(void)
      #ifndef CONFIG_MACH_SUN50IW11
      	return sdmmc_init_for_sprite(0, 2);
      #else
      	int workmode = uboot_spare_head.boot_data.work_mode;
      	if (workmode == WORK_MODE_CARD_PRODUCT)
      		return -1;
      		return sdmmc_init_for_sprite(0, 0);
      这里 CONFIG_MACH_SUN50IW11 没有定义
      默认是执行 return sdmmc_init_for_sprite(0, 2);
      那么咱就是说,直接改return sdmmc_init_for_sprite(0, 0); 试试看?
      好的说改就改了。
      #else
      		return -1;
      改动了下,直接烧录测一下:
      U-Boot 2018.05-g0a62f10-dirty (Jan 28 2022 - 22:35:17 +0800) Allwinner Technology
      [03.804]DRAM:  512 MiB
      [03.809]Relocation Offset is: 1def0000
      [03.831]secure enable bit: 0
      [03.835]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [03.842]flash init start
      [03.844]workmode = 16,storage type = 0
      running in sunxi_sprite_mmc_probe try card
      sdmmc_init_for_sprite try card 0
      set card number 0
      get card number 0
      [03.857][mmc]: mmc driver ver uboot2018:2021-04-16 14:23:00-1
      [03.866][mmc]: get sdc_type fail and use default host:tm1.
      [03.891][mmc]: can't find node "mmc0",will add new node
      [03.896][mmc]: fdt err returned <no error>
      [03.900][mmc]: Using default timing para
      [03.904][mmc]: SUNXI SDMMC Controller Version:0x50310
      [03.922][mmc]: card_caps:0x3000000a
      [03.925][mmc]: host_caps:0x3000003f
      [03.933]Loading Environment from SUNXI_FLASH... OK
      [03.939]try to burn key
      [03.943]out of usb burn from boot: not need burn key
      sunxi work mode=0x10
      run usb efex
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x30
      set address 0x30 ok
      set address 0x31
      set address 0x31 ok
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x12
      origin_erase_flag = 0x1
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      the 0 mbr table is ok
      the 1 mbr table is ok
      the 2 mbr table is ok
      the 3 mbr table is ok
      total mbr part 9
      part[0] classname :DISK
      part[0] addrlo    :0x1f8
      part[0] lenlo     :0x1f80
      part[0] user_type :32768
      part[0] keydata   :0
      part[0] ro        :0
      part[1] name      :env
      part[1] classname :DISK
      part[1] addrlo    :0x2178
      part[1] lenlo     :0x1f8
      part[1] user_type :32768
      part[1] keydata   :0
      part[1] ro        :0
      part[2] name      :env-redund
      part[2] classname :DISK
      part[2] addrlo    :0x2370
      part[2] lenlo     :0x1f8
      part[2] user_type :32768
      part[2] keydata   :0
      part[2] ro        :0
      part[3] name      :boot
      part[3] classname :DISK
      part[3] addrlo    :0x2568
      part[3] lenlo     :0x50b8
      part[3] user_type :32768
      part[3] keydata   :0
      part[3] ro        :0
      part[4] name      :dsp0
      part[4] classname :DISK
      part[4] addrlo    :0x7620
      part[4] lenlo     :0x3f0
      part[4] user_type :32768
      part[4] keydata   :0
      part[4] ro        :0
      part[5] name      :recovery
      part[5] classname :DISK
      part[5] addrlo    :0x7a10
      part[5] lenlo     :0x6e40
      part[5] user_type :32768
      part[5] keydata   :0
      part[5] ro        :0
      part[6] name      :rootfs
      part[6] classname :DISK
      part[6] addrlo    :0xe850
      part[6] lenlo     :0x1000000
      part[6] user_type :32768
      part[6] keydata   :0
      part[6] ro        :0
      part[7] name      :rootfs_data
      part[7] classname :DISK
      part[7] addrlo    :0x100e850
      part[7] lenlo     :0x6400
      part[7] user_type :32768
      part[7] keydata   :0
      part[7] ro        :0
      part[8] name      :UDISK
      part[8] classname :DISK
      part[8] addrlo    :0x1014c50
      part[8] lenlo     :0x0
      part[8] user_type :33024
      part[8] keydata   :0
      part[8] ro        :0
      total part: 10
      mbr 0, 1f8, 8000
      boot-resource 1, 1f80, 8000
      env 2, 1f8, 8000
      env-redund 3, 1f8, 8000
      boot 4, 50b8, 8000
      dsp0 5, 3f0, 8000
      recovery 6, 6e40, 8000
      rootfs 7, 1000000, 8000
      rootfs_data 8, 6400, 8000
      UDISK 9, 0, 8100
      [07.119]erase all part start
      need erase flash: 18
      [07.125][mmc]: mmc_mmc_erase: sd card don't support erase
      [07.130]read item0 copy0
      [07.132][mmc]: memalign dst_align is NULL!
      read first backup failed in fun sunxi_sprite_mmc_secread line 468
      [07.142][mmc]: memalign dst_align is NULL!
      [07.152]unknown error happen in item 0 read
      [07.155]get secure storage map err
      [07.159][mmc]: memalign src_align is NULL!
      write first backup failed in fun sunxi_sprite_mmc_secwrite line 533
      [07.168]erase secure storage block 0 err
      SUNXI_EFEX_MBR_TAG
      mbr size = 0x10000
      write primary GPT success
      write Backup GPT success
      [08.043]update partition map
      running in sunxi_sprite_mmc_init try card 2
      ******Has init
      FEX_CMD_fes_verify_value, start 0x1f8, size high 0x0:low 0x2f8c00
      FEX_CMD_fes_verify_value 0x3481d9f0
      FEX_CMD_fes_verify_value, start 0x2178, size high 0x0:low 0x20000
      FEX_CMD_fes_verify_value 0xcb347ad3
      FEX_CMD_fes_verify_value, start 0x2370, size high 0x0:low 0x20000
      FEX_CMD_fes_verify_value, start 0x2568, size high 0x0:low 0x91d000
      FEX_CMD_fes_verify_value 0xe5a32b17
      FEX_CMD_fes_verify_value, start 0x7620, size high 0x0:low 0x4059c
      FEX_CMD_fes_verify_value 0x413a5c54
      FEX_CMD_fes_verify_value, start 0xe850, size high 0x0:low 0x6400000
      FEX_CMD_fes_verify_value 0x87284509
      bootfile_mode=4
      SUNXI_EFEX_BOOT1_TAG
      boot1 size = 0xfc000, max size = 0x200000
      uboot size = 0xfc000
      storage type = 7
      bootfile_mode=4
      SUNXI_EFEX_BOOT0_TAG
      boot0 size = 0x10000
      [36.353][mmc]: write mmc 0 info ok
      dram para[0] = 318
      dram para[1] = 3
      dram para[2] = 7b7bfb
      dram para[3] = 1
      dram para[4] = 10f210f2
      dram para[5] = 4001000
      dram para[6] = 1c70
      dram para[7] = 42
      dram para[8] = 18
      dram para[9] = 0
      dram para[10] = 4a2195
      dram para[11] = 2423190
      dram para[12] = 8b061
      dram para[13] = b4787896
      dram para[14] = 0
      dram para[15] = 48484848
      dram para[16] = 48
      dram para[17] = 1620121e
      dram para[18] = 0
      dram para[19] = 0
      dram para[20] = 0
      dram para[21] = 870000
      dram para[22] = 24
      dram para[23] = b4056103
      dram para[24] = 0
      dram para[25] = 0
      dram para[26] = 0
      dram para[27] = 0
      dram para[28] = 0
      dram para[29] = 0
      dram para[30] = 0
      dram para[31] = 0
      storage type = 7
      sunxi_efex_next_action=2
      exit usb
      next work 2
      ▒[33]HELLO! BOOT0 is starting!T
      [36]BOOT0 commit : 603490b
      [38]set pll start
      [40]periph0 has been enabled
      [43]set pll end
      [44][pmu]: bus read error
      [47]board init ok
      [49]DRAM only have internal ZQ!!
      [52]get_pmu_exist() = -1
      [54]DRAM BOOT DRIVE INFO: V0.24
      [57]DRAM CLK = 792 MHz
      [59]DRAM Type = 3 (2:DDR2,3:DDR3)
      [62]DRAMC ZQ value: 0x7b7bfb
      [65]DRAM ODT value: 0x42.
      [67]ddr_efuse_type: 0x0
      [70]DRAM SIZE =1024 M
      [74]DRAM simple test OK.
      [76]dram size =1024
      [78]card no is 0
      [79]sdcard 0 line count 4
      [82][mmc]: mmc driver ver 2021-04-2 16:45
      [91][mmc]: Wrong media type 0x0
      [94][mmc]: ***Try SD card 0***
      [103][mmc]: HSSDR52/SDR25 4 bit
      [106][mmc]: 50000000 Hz
      [108][mmc]: 15280 MB
      [110][mmc]: ***SD/MMC 0 init OK!!!***
      [158]Loading boot-pkg Succeed(index=0).
      [162]Entry_name        = opensbi
      [165]Entry_name        = u-boot
      [169]Entry_name        = dtb
      [171]mmc not para
      [173]Jump to second Boot.
      23333 还真就烧录进去了,也不知道这会有什么隐患没,反正我用着很舒服,不用插拔卡了。若有啥隐患还请大佬们指正。
      同时呢,这个烧录口USB还能做adb shell调试用,美滋滋了。
      而且呢额外挂载的 /mnt/SDCARD 空间等可以在烧录后保留,不会被擦除。
      芜湖,起飞!
      mangogeek S 2 条回复 最后回复 回复 引用 分享 3
      • mangogeek
        mangogeek LV 8 @TEVET 最后由 编辑
        @tevet 有用,鬼才!
        T 1 条回复 最后回复 回复 引用 分享 0
        • T
          TEVET LV 7 @mangogeek 最后由 编辑
          @mangogeek
          太巧了,改一个数字解决了,期待没有什么毛病
          • aozima
            aozima LV 7 最后由 编辑
            D1S好改不?烧录速度多少?
            我现在烧录D1S的SDNAND,是改写了xfel来实现的
            https://whycan.com/t_7730.html
            • T
              TEVET LV 7 @aozima 最后由 编辑
              @aozima 一样的改法,亲测有效,烧录速度,200MB的固件我用tf卡烧录大概50秒
              • Referenced by  C captain
              • Referenced by  ftwtwzy ftwtwzy
              • DAIZEBIN
                DAIZEBIN LV 7 最后由 编辑
                这里的“try card 2”是尝试启动什么介质呢?sd卡?
                • Referenced by  A a1314258
                  a1314258 LV 3 @TEVET 最后由 编辑
                  @tevet
                  [37.465]workmode = 16,storage type = 0
                  try card 0
                  set card number 0
                  get card number 0
                  [37.473][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
                  [37.481][mmc]: get sdc_type fail and use default host:tm1.
                  [37.507][mmc]: can't find node "mmc0",will add new node
                  [37.512][mmc]: fdt err returned <no error>
                  [37.516][mmc]: Using default timing para
                  [37.519][mmc]: SUNXI SDMMC Controller Version:0x50310
                  [37.537][mmc]: card_caps:0x3000000a
                  [37.540][mmc]: host_caps:0x3000003f
                  [37.548]Loading Environment from SUNXI_FLASH... OK
                  [37.559]try to burn key
                  [37.562]out of usb burn from boot: not need burn key
                  [37.566]Net:   [37.568]No ethernet found.
                  run usb efex
                  delay time 2500
                  weak:otg_phy_config
                  usb init ok
                  set address 0x1d
                  set address 0x1d ok
                  卡在 set address 0x1d ok 这里就不动了。
                  • aldfaaa
                    whycan矿工-小叶 LV 7 最后由 编辑
                    要是能不用按任何物理按键,那就可以远程电脑进行烧录了?
                    H whycan 2 条回复 最后回复 回复 引用 分享 0
                      huanian LV 4 @aldfaaa 最后由 编辑
                      @aldfaaa OTG接口连电脑,修改之前只有用flash可以这么烧录,用tf卡要拔卡用读卡器烧录。按键楼主的方法修改后,用tf卡也能直接OTG烧录。
                        whycan晕哥 LV 9 @aldfaaa 最后由 编辑
                        @aldfaaa
                        上电之后一直按数字2就可以进入烧录模式
                          soso90 LV 7 @TEVET 最后由 编辑
                          @tevet t113是否同样适用,我改了,好像不行。晚点上日志
                          • T
                            TEVET LV 7 @soso90 最后由 编辑
                            @soso90 适用的,大佬, 记得muboot
                            • Referenced by  T TEVET
                              memory LV 7 最后由 编辑
                              谢谢楼主,V853也可以!
                              • Referenced by  WhycanService WhycanService
                                cfxcfx LV 5 最后由 编辑
                                大佬同样的问题什么原因导致的
                                卡这就不动了
                                • T
                                  TEVET LV 7 @cfxcfx 最后由 编辑
                                  @cfxcfx
                                  换个卡看看?
                                    l19900099 LV 3 最后由 编辑
                                    正想找这个,感谢分享
