    收到芒果大佬的库存 DVP与MIPI 双摄像头R11开发板
    A Series
    r11
    20
    18993
      whycan晕哥 LV 9 最后由 whycan 编辑
      5寸IPS 800x480 电容触摸屏推荐: https://item.taobao.com/item.htm?id=625081551655
      5寸IPS 800x480 电阻触摸屏推荐: https://item.taobao.com/item.htm?id=624199044282
      以上没有PY关系,仅推荐
      以上没有PY关系,仅推荐
      以上没有PY关系,仅推荐
      R11核心板原理图和PCB: R11_M7-原理图和PCB.pdf
      R11 核心板正面丝印: R11_M7-silk-T.pdf
      R11 核心板背面丝印: R11_M7-silk-B.pdf
      R11核心板BOM表: R11_M7_BOM.xls
      R11底板原理图: R11_KIT3.pdf
      R11底板BOM表: R11_KIT3-BOM.xlsx
      R11底板丝印图: R11_KIT3-silk.pdf
      其他元器件手册:
      SY7201A.pdf
      PAM8301.pdf
      NS2009_2018-06-21.PDF
      AP6181.pdf
      XC6206_超低功耗LDO.pdf
      tps5430.pdf
      其他参考链接:
      全志R11核心板和底板(主要跑RTT和柿饼UI)
      https://whycan.com/t_2683.html
      (V3s/S3/S3L/R11通吃)V3s开发板 u-boot/linux/buildroot测试
      https://whycan.com/t_7248.html
      R11 资料、SDK、数据手册、硬件参考设计
      https://bbs.aw-ol.com/topic/1313/share/1
        待编辑 ----------
          D 1 条回复 最后回复 回复 引用 分享 0
            主线Linux玩法 : (编辑中)
              Tina Linux玩法 : (编辑中)
                buildroot 2020.02.4 补丁包(直接解压即可):
                buildroot_20200204_mangopi_r11_kit4_src_patch_20220418_by_whycan.tar
                make br2_mangopi_kit4_v3_ddr2_uart0_pb8_pb9_tfcard_spinor_defconfig
                make
                生成固件:
                -rw-r--r-- 1 whycan whycan 133169152 Apr 18 14:14 output/images/firmware-mangopi-kit4-v1-sdcard.img
                -rw-r--r-- 1 whycan whycan  15728640 Apr 18 14:14 output/images/firmware-mangopi-kit4-v1-spinor.img
                调试串口日志:
                U-Boot SPL 2021.07 (Apr 18 2022 - 13:25:04 +0800)
                DRAM: 64 MiB
                Trying to boot from sunxi SPI
                U-Boot 2021.07 (Apr 18 2022 - 13:25:04 +0800) Allwinner Technology
                CPU:   Allwinner V3s (SUN8I 1681)
                Model: mangopi kit4
                DRAM:  64 MiB
                MMC:   mmc@1c0f000: 0
                Loading Environment from nowhere... OK
                In:    serial@1c28000
                Out:   serial@1c28000
                Err:   serial@1c28000
                Net:   No ethernet found.
                Card did not respond to voltage select! : -110
                MMC Device 1 not found
                no mmc device at slot 1
                SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
                Boot Device: spi
                Boot Slot 0: empty
                Boot Slot 1: spi-nor
                DFU waiting on SPI-NOR...
                Unknown command 'dfu' - try 'help'
                Booting from SPI-NOR...
                device 0 offset 0x70000, size 0x10000
                SF: 65536 bytes @ 0x70000 Read: OK
                device 0 offset 0x80000, size 0x500000
                SF: 5242880 bytes @ 0x80000 Read: OK
                Kernel image @ 0x40000000 [ 0x000000 - 0x499f30 ]
                ## Flattened Device Tree blob at 40700000
                   Booting using the fdt blob at 0x40700000
                   Loading Device Tree to 416f9000, end 416ff81c ... OK
                Starting kernel ...
                [    0.000000] Linux version 5.4.70-mangopi (whycan@ubuntu) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05)) #3 SMP Mon Apr 18 12:20:57 CST 2022
                [    0.000000] OF: fdt: Machine model: MANGOPI R11 KIT4
                [    0.000000] cma: Reserved 16 MiB at 0x42c00000
                [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
                [    0.000000] percpu: Embedded 15 pages/cpu s30668 r8192 d22580 u61440
                [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 16256
                [    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk rootwait consoleblank=0 net.ifnames=0 biosdevname=0 root=/dev/mtdblock3 overlayfsdev=/dev/mtdblock4
                [    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
                [    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
                [    0.000000] Memory: 36444K/65536K available (7168K kernel code, 422K rwdata, 1980K rodata, 1024K init, 254K bss, 12708K reserved, 16384K cma-reserved, 0K highmem)
                [    0.000000] rcu: Hierarchical RCU implementation.
                [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
                [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
                [    0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
                [    0.000000] random: get_random_bytes called from start_kernel+0x2b4/0x44c with crng_init=0
                [    0.000012] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
                [    0.000029] Switching to timer-based delay loop, resolution 41ns
                [    0.000439] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
                [    0.000889] Console: colour dummy device 80x30
                [    0.000997] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
                [    0.001020] pid_max: default: 32768 minimum: 301
                [    0.001293] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                [    0.001315] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                [    0.001486] *** VALIDATE tmpfs ***
                [    0.002507] *** VALIDATE proc ***
                [    0.002791] *** VALIDATE cgroup1 ***
                [    0.002815] *** VALIDATE cgroup2 ***
                [    0.002843] CPU: Testing write buffer coherency: ok
                [    0.003753] /cpus/cpu@0 missing clock-frequency property
                [    0.003798] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                [    0.005110] Setting up static identity map for 0x40100000 - 0x40100060
                [    0.005479] rcu: Hierarchical SRCU implementation.
                [    0.006419] smp: Bringing up secondary CPUs ...
                [    0.006452] smp: Brought up 1 node, 1 CPU
                [    0.006464] SMP: Total of 1 processors activated (48.00 BogoMIPS).
                [    0.006472] CPU: All CPU(s) started in HYP mode.
                [    0.006478] CPU: Virtualization extensions available.
                [    0.007578] devtmpfs: initialized
                [    0.014063] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
                [    0.014636] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                [    0.014680] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
                [    0.015951] pinctrl core: initialized pinctrl subsystem
                [    0.018036] NET: Registered protocol family 16
                [    0.019888] DMA: preallocated 256 KiB pool for atomic coherent allocations
                [    0.022219] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                [    0.022248] hw-breakpoint: maximum watchpoint size is 8 bytes.
                [    0.049921] SCSI subsystem initialized
                [    0.050632] usbcore: registered new interface driver usbfs
                [    0.050741] usbcore: registered new interface driver hub
                [    0.050874] usbcore: registered new device driver usb
                [    0.051280] mc: Linux media interface: v0.10
                [    0.051341] videodev: Linux video capture interface: v2.00
                [    0.051396] pps_core: LinuxPPS API ver. 1 registered
                [    0.051407] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
                [    0.051436] PTP clock support registered
                [    0.051767] Advanced Linux Sound Architecture Driver Initialized.
                [    0.052835] Bluetooth: Core ver 2.22
                [    0.053001] NET: Registered protocol family 31
                [    0.053016] Bluetooth: HCI device and connection manager initialized
                [    0.053051] Bluetooth: HCI socket layer initialized
                [    0.053065] Bluetooth: L2CAP socket layer initialized
                [    0.053106] Bluetooth: SCO socket layer initialized
                [    0.055308] clocksource: Switched to clocksource arch_sys_counter
                [    0.055866] *** VALIDATE ramfs ***
                [    0.073086] thermal_sys: Registered thermal governor 'step_wise'
                [    0.073756] NET: Registered protocol family 2
                [    0.074995] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                [    0.075056] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
                [    0.075092] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
                [    0.075122] TCP: Hash tables configured (established 1024 bind 1024)
                [    0.075568] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
                [    0.075658] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
                [    0.076132] NET: Registered protocol family 1
                [    0.080267] Initialise system trusted keyrings
                [    0.080886] workingset: timestamp_bits=30 max_order=14 bucket_order=0
                [    0.091336] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                [    0.091879] utf8_selftest: All 154 tests passed
                [    0.091894] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
                [    0.092777] *** VALIDATE jffs2 ***
                [    0.140604] Key type asymmetric registered
                [    0.140637] Asymmetric key parser 'x509' registered
                [    0.140800] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
                [    0.140820] io scheduler mq-deadline registered
                [    0.140830] io scheduler kyber registered
                [    0.140838] test_strscpy: loaded.
                [    0.140869] test_strscpy: all 32 tests passed
                [    0.149960] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
                [    0.151009] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
                [    0.152221] pwm-backlight backlight: backlight supply power not found, using dummy regulator
                [    0.332310] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
                [    0.339735] printk: console [ttyS0] disabled
                [    0.360213] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 34, base_baud = 1500000) is a U6_16550A
                [    1.002418] printk: console [ttyS0] enabled
                [    1.007957] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
                [    1.040170] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 35, base_baud = 1500000) is a U6_16550A
                [    1.053207] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
                [    1.097032] panel-simple panel: panel supply power not found, using dummy regulator
                [    1.107824] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
                [    1.120520] spi-nor spi0.0: w25q128 (16384 Kbytes)
                [    1.125588] 5 fixed-partitions partitions found on MTD device spi0.0
                [    1.131943] Creating 5 MTD partitions on "spi0.0":
                [    1.136809] 0x000000000000-0x000000070000 : "u-boot"
                [    1.145432] 0x000000070000-0x000000080000 : "dtb"
                [    1.153274] 0x000000080000-0x000000580000 : "kernel"
                [    1.161597] 0x000000580000-0x000000f00000 : "rom"
                [    1.169651] 0x000000f00000-0x000001100000 : "overlay"
                [    1.174736] mtd: partition "overlay" extends beyond the end of device "spi0.0" -- size truncated to 0x100000
                [    1.189281] libphy: Fixed MDIO Bus: probed
                [    1.194100] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
                [    1.200644] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
                [    1.206903] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
                [    1.212744] dwmac-sun8i 1c30000.ethernet: No regulator found
                [    1.219386] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
                [    1.226760] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
                [    1.233984] dwmac-sun8i 1c30000.ethernet: COE Type 2
                [    1.238986] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
                [    1.245794] dwmac-sun8i 1c30000.ethernet: Normal descriptors
                [    1.251451] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
                [    1.257152] dwmac-sun8i 1c30000.ethernet: device MAC address 7a:4b:e5:82:8a:e0
                [    1.264857] libphy: stmmac: probed
                [    1.269528] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
                [    1.276089] libphy: mdio_mux: probed
                [    1.279716] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
                [    1.286170] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
                [    1.392205] dwmac-sun8i 1c30000.ethernet: EMAC reset timeout
                [    1.398125] dwmac-sun8i 1c30000.ethernet: Error: Failed to register MDIO bus for child /soc/ethernet@1c30000/mdio-mux/mdio@1
                [    1.409406] dwmac-sun8i 1c30000.ethernet: Error: No acceptable child buses found
                [    1.416829] dwmac-sun8i 1c30000.ethernet: Failed to register mux
                [    1.422853] dwmac-sun8i 1c30000.ethernet eth0: stmmac_dvr_remove: removing driver
                [    1.456796] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                [    1.463353] ehci-platform: EHCI generic platform driver
                [    1.469255] ehci-platform 1c1a000.usb: EHCI Host Controller
                [    1.474963] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
                [    1.483441] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
                [    1.515282] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
                [    1.523185] hub 1-0:1.0: USB hub found
                [    1.527287] hub 1-0:1.0: 1 port detected
                [    1.532266] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                [    1.538732] ohci-platform: OHCI generic platform driver
                [    1.544533] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
                [    1.551358] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
                [    1.559801] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
                [    1.643793] hub 2-0:1.0: USB hub found
                [    1.647897] hub 2-0:1.0: 1 port detected
                [    1.653067] usbcore: registered new interface driver usb-storage
                [    1.660153] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
                [    1.672418] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
                [    1.678386] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
                [    1.688198] hub 3-0:1.0: USB hub found
                [    1.692094] hub 3-0:1.0: 1 port detected
                [    1.699343] mousedev: PS/2 mouse device common for all mice
                [    1.705839] i2c /dev entries driver
                [    1.713507] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
                [    1.722925] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
                [    1.761046] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
                [    1.785176] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
                [    1.792333] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
                [    1.797958] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
                [    1.805466] sun8i-v3s-pinctrl 1c20800.pinctrl: pin PC0 already requested by 1c68000.spi; cannot claim for 1c11000.mmc
                [    1.816141] sun8i-v3s-pinctrl 1c20800.pinctrl: pin-64 (1c11000.mmc) status -22
                [    1.823366] sun8i-v3s-pinctrl 1c20800.pinctrl: could not request pin 64 (PC0) from group PC0  on device 1c20800.pinctrl
                [    1.834166] sunxi-mmc 1c11000.mmc: Error applying setting, reverse things back
                [    1.841449] sunxi-mmc: probe of 1c11000.mmc failed with error -22
                [    1.849208] usbcore: registered new interface driver usbhid
                [    1.854798] usbhid: USB HID core driver
                [    1.863430] sun4i-codec 1c22c00.codec: Failed to register our card
                [    1.872755] IPv4 over IPsec tunneling driver
                [    1.878405] NET: Registered protocol family 17
                [    1.882992] Key type dns_resolver registered
                [    1.887675] Registering SWP/SWPB emulation handler
                [    1.892902] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
                [    1.899057] Loading compiled-in X.509 certificates
                [    1.915972] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
                [    1.929545] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc085ffa0)
                [    1.937754] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc085d100)
                [    1.945580] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
                [    1.952196] [drm] No driver support for vblank timestamp query.
                [    1.959611] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
                [    1.974701] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
                [    1.978180] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
                [    1.990167] mmc0: new high speed SDIO card at address 0001
                [    2.013308] Console: switching to colour frame buffer device 100x30
                [    2.052411] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
                [    2.061711] debugfs: Directory '1c22c00.codec' with parent 'V3s Audio Codec' already present!
                [    2.073660] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
                [    2.083822] hctosys: unable to open rtc device (rtc0)
                [    2.089522] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                [    2.102424] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                [    2.109436] ALSA device list:
                [    2.112429]   #0: V3s Audio Codec
                [    2.117132] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
                [    2.125995] cfg80211: failed to load regulatory.db
                [    2.132702] random: fast init done
                [    2.144172] VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
                [    2.155871] devtmpfs: mounted
                [    2.162054] Freeing unused kernel memory: 1024K
                [    2.167007] Run /sbin/init as init process
                [    2.297567] random: crng init done
                Mounting OverlayFS: [    3.126893] overlayfs: upper fs does not support tmpfile.
                [    3.132407] overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off.
                OK
                Populating /dev using udev: [    3.666691] udevd[93]: starting version 3.2.9
                [    3.953716] udevd[94]: starting eudev-3.2.9
                fbv - The Framebuffer Viewer
                /usr/img/hehua.jpg
                1024 x 682
                [    5.237588] Goodix-TS 0-0014: 0-0014 supply AVDD28 not found, using dummy regulator
                [    5.245901] Goodix-TS 0-0014: 0-0014 supply VDDIO not found, using dummy regulator
                [    5.277424] gpio gpiochip0: (1c20800.pinctrl): gpiochip_lock_as_irq: tried to flag a GPIO set as output for IRQ
                [    5.287824] sun8i-v3s-pinctrl 1c20800.pinctrl: unable to lock HW IRQ 0 for IRQ
                [    5.295053] genirq: Failed to request resources for tsc2007 (irq 40) on irqchip sunxi_pio_edge
                [    5.304650] rtc-hym8563 0-0051: could not init device, -6
                [    5.406089] Goodix-TS 0-0014: i2c test failed attempt 1: -6
                [    5.445990] Goodix-TS 0-0014: i2c test failed attempt 2: -6
                [    5.455731] tsc2007 0-0048: Failed to request irq 40: -5
                [    5.485535] Goodix-TS 0-0014: I2C communication failure: -6
                [    5.491849] Goodix-TS 0-005d: 0-005d supply AVDD28 not found, using dummy regulator
                [    5.499919] Goodix-TS 0-005d: 0-005d supply VDDIO not found, using dummy regulator
                [    5.508495] tsc2007: probe of 0-0048 failed with error -5
                [    5.645859] Goodix-TS 0-005d: i2c test failed attempt 1: -6
                [    5.685828] Goodix-TS 0-005d: i2c test failed attempt 2: -6
                [    5.725549] Goodix-TS 0-005d: I2C communication failure: -6
                done
                Initializing random number generator: OK
                Saving random seed: OK
                Starting network: OK
                Starting DHCP server: FAIL
                hwclock: can't open '/dev/misc/rtc': No such file or directory
                Realtek Bluetooth :Realtek Bluetooth init uart with init speed:115200, type:HCI UART H5
                Realtek Bluetooth :Realtek hciattach version 3.1
                Realtek Bluetooth :Use epoll
                /etc/init.d/S94wifi: line 1: wpa_supplicant: not found
                1 udhcpc: SIOCGIFINDEX: No such device
                playing '/usr/wav/startup.wav': 2 ch, 48000 hz, 16 bit
                3.141592653589793238462643383279502884197169399375105820974944
                Realtek Bluetooth WARN: OP_H5_SYNC Transmission timeout
                2 3.141592653589793238462643383279502884197169399375105820974944
                3 3.141592653589793238462643383279502884197169399375105820974944
                4 3.141592653589793238462643383279502884197169399375105820974944
                5 3.141592653589793238462643383279502884197169399375105820974944
                6 3.141592653589793238462643383279502884197169399375105820974944
                7 3.141592653589793238462643383279502884197169399375105820974944
                8 3.141592653589793238462643383279502884197169399375105820974944
                9 Realtek Bluetooth WARN: OP_H5_SYNC Transmission timeout
                感谢:
                ① buildroot-tiny200 (F1C100/200s) 开发包近期更新内容 * 已支持DVP摄像头 *
                https://whycan.com/t_5221.html
                ② (V3s/V3x/S3/S3L/R11通吃)小智V3x开发板smallwitpi lite u-boot/linux/buildroot测试
                  修改楼上的 board/mangopi/kit4/v1/dts/linux-v5.4.70/sun8i-v3s.dtsi
                  添加:
                                          lcd_rgb666_pins_b: lcd-rgb666-pd {
                                                  pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5",
                                                         "PD6", "PD7", "PD8", "PD9", "PD10", "PD11",
                                                         "PD12", "PD13", "PD14", "PD15", "PD16", "PD17",
                                                  function = "lcd";
                  board/mangopi/kit4/v1/dts/linux-v5.4.70/devicetree.dts 修改为:
                  &tcon0 {
                          pinctrl-names = "default";
                          pinctrl-0 = <&lcd_rgb666_pins_b>;
                    进入Linux,tsc2007(ns2009)一直提示 -6错误,查了一下设备不存在,用 i2c-detect -y 0命令发现,果然不存在 0x48 设备,但是有 0x49 设备:
                    # i2cdetect -y 0
                         0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
                    00:          -- -- -- -- -- -- -- -- -- -- -- -- --
                    10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    40: -- -- -- -- -- -- -- -- -- 49 -- -- -- -- -- --
                    50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    70: -- -- -- -- -- -- -- --
                    这是怎么回事呢,查看一楼原理图,难道 0x49 是加密芯片DX81C04,
                    但是看了核心板背面的5脚芯片并没有焊上,
                    那这个 0x49 估计就是 ns2009 芯片了,对照手册和原理图,发现A0 上拉,地址是要 +1
                    修改 devicetree.dts,一切正常:
                    &i2c0 {
                            rtp@48 {
                                    compatible = "ti,tsc2007";
                                    reg = <0x49>;
                                    interrupt-parent = <&pio>;
                                    interrupts = <1 10 IRQ_TYPE_EDGE_FALLING>;
                                    gpios = <&pio 1 10 GPIO_ACTIVE_LOW>;
                                    pendown-gpio = <&pio 1 10 GPIO_ACTIVE_LOW>;
                                    ti,x-plate-ohms = <660>;
                                    wakeup-source;
                            rtc@51 {
                                    compatible = "nxp,pcf8563";
                                    reg = <0x51>;
                                    status = "disabled";
                            hym8563@51 {
                                    compatible = "haoyu,hym8563";
                                    reg = <0x51>;
                                    #clock-cells = <0>;
                            ds1307@68 {
                                    compatible = "dallas,ds1307";
                                    reg = <0x68>;
                            ctp@14 {
                                    compatible = "goodix,gt911";
                                    reg = <0x14>;
                                    interrupts = <1 1 IRQ_TYPE_EDGE_FALLING>; // PB1
                                    irq-gpios = <&pio 1 1 GPIO_ACTIVE_HIGH>; // PB1
                                    reset-gpios = <&pio 1 0 GPIO_ACTIVE_HIGH>; // PB0
                            ctp@5d {
                                    reg = <0x5d>;
                    触摸校正: TSLIB_TSDEVICE=/dev/input/event0 ts_calibrate
                    触摸测试: TSLIB_TSDEVICE=/dev/input/event0 ts_test
                      最新的源码包下载: buildroot_20200204_mangopi_r11_kit4_src_patch_20220419_by_whycan.tar
                      16M SPI NOR FLASH 固件下载: firmware-mangopi-kit4-v1-spinor.img
                      可以用 sunxi-fel 烧录,也可以用 xfel 烧录。
                        buildroot 快速重新编译某package的方法,
                        先执行删除 rm output/build/xxxxx/.stamp_built
                        然后执行 make 即可。
                        比如需要重新编译Linux,
                        执行:
                        rm output/build/linux-5.4.70/.stamp_built ; make
                          make menuconfig 删除了某些软件包,但是文件系统里面确没有同步更新,
                          那么执行以下操作:
                          rm output/target/ -rf; find output/build/ -name .stamp_target_installed | xargs rm -rf; make
                            LVGL7 源码下载: 哪吒D1开发板 LVGL7 源码下载(带git仓库)
                            LVGL固件下载: firmware-mangopi-kit4-v1-spinor.img
                              柚木 鉉 LV 9 @whycan 最后由 YuzukiTsuru 编辑
                              @whycan 试了一下,好像没有用,还是
                              touch ./output/images/a.dtb     # 防止出现未编译dtb情况
                              rm ./output/images/*.dtb          # 删除设备树
                              make linux-rebuild -j8 && make
                              或者更绝的
                              rm -rf output/build/linux*
                              rm -rf output/build/.linux*
                              make
                                whycan晕哥 LV 9 @YuzukiTsuru 最后由 编辑
                                @yuzukitsuru
                                你的使用姿势不对,应该是要先删除文件 .stamp_built。
                                  源码: buildroot_20200204_mangopi_r11_kit4_src_patch_20220421_by_whycan.tar
                                  烧录固件: firmware-mangopi-kit4-v1-spinor.img
                                  AP6181 WIFI 驱动 OK:
                                  DRAM: 64 MiB
                                  Model: mangopi kit4
                                  DRAM:  64 MiB
                                  MMC:   mmc@1c0f000: 0
                                  In:    serial@1c28000
                                  Out:   serial@1c28000
                                  Err:   serial@1c28000
                                  Boot Device: spi
                                  Boot Slot 0: empty
                                     Loading Device Tree to 416f9000, end 416ff95e ... OK
                                  Starting kernel ...
                                  [    0.000011] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
                                  [    0.000426] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
                                  [    0.000878] Console: colour dummy device 80x30
                                  [    0.000978] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
                                  [    0.001001] pid_max: default: 32768 minimum: 301
                                  [    0.001285] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                                  [    0.001309] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                                  [    0.001484] *** VALIDATE tmpfs ***
                                  [    0.002506] *** VALIDATE proc ***
                                  [    0.002839] CPU: Testing write buffer coherency: ok
                                  [    0.003797] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                                  [    0.005072] Setting up static identity map for 0x40100000 - 0x40100060
                                  [    0.005432] rcu: Hierarchical SRCU implementation.
                                  [    0.006363] smp: Bringing up secondary CPUs ...
                                  [    0.006394] smp: Brought up 1 node, 1 CPU
                                  [    0.006406] SMP: Total of 1 processors activated (48.00 BogoMIPS).
                                  [    0.006416] CPU: All CPU(s) started in HYP mode.
                                  [    0.006422] CPU: Virtualization extensions available.
                                  [    0.007524] devtmpfs: initialized
                                  [    0.014071] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
                                  [    0.014647] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                                  [    0.014698] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
                                  [    0.016026] pinctrl core: initialized pinctrl subsystem
                                  [    0.018018] NET: Registered protocol family 16
                                  [    0.019874] DMA: preallocated 256 KiB pool for atomic coherent allocations
                                  [    0.022213] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                                  [    0.022247] hw-breakpoint: maximum watchpoint size is 8 bytes.
                                  [    0.049985] SCSI subsystem initialized
                                  [    0.050700] usbcore: registered new interface driver usbfs
                                  [    0.050791] usbcore: registered new interface driver hub
                                  [    0.050922] usbcore: registered new device driver usb
                                  [    0.051305] mc: Linux media interface: v0.10
                                  [    0.051410] videodev: Linux video capture interface: v2.00
                                  [    0.051471] pps_core: LinuxPPS API ver. 1 registered
                                  [    0.051481] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
                                  [    0.051514] PTP clock support registered
                                  [    0.051816] Advanced Linux Sound Architecture Driver Initialized.
                                  [    0.052898] Bluetooth: Core ver 2.22
                                  [    0.053069] NET: Registered protocol family 31
                                  [    0.053083] Bluetooth: HCI device and connection manager initialized
                                  [    0.053123] Bluetooth: HCI socket layer initialized
                                  [    0.053138] Bluetooth: L2CAP socket layer initialized
                                  [    0.053186] Bluetooth: SCO socket layer initialized
                                  [    0.055353] clocksource: Switched to clocksource arch_sys_counter
                                  [    0.055892] *** VALIDATE ramfs ***
                                  [    0.073051] thermal_sys: Registered thermal governor 'step_wise'
                                  [    0.073719] NET: Registered protocol family 2
                                  [    0.074949] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                                  [    0.075014] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
                                  [    0.075047] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
                                  [    0.075078] TCP: Hash tables configured (established 1024 bind 1024)
                                  [    0.075509] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
                                  [    0.075607] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
                                  [    0.076072] NET: Registered protocol family 1
                                  [    0.080225] Initialise system trusted keyrings
                                  [    0.080844] workingset: timestamp_bits=30 max_order=14 bucket_order=0
                                  [    0.091377] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                                  [    0.091943] utf8_selftest: All 154 tests passed
                                  [    0.091959] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
                                  [    0.092821] *** VALIDATE jffs2 ***
                                  [    0.140811] Key type asymmetric registered
                                  [    0.140842] Asymmetric key parser 'x509' registered
                                  [    0.140991] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
                                  [    0.141012] io scheduler mq-deadline registered
                                  [    0.141022] io scheduler kyber registered
                                  [    0.141030] test_strscpy: loaded.
                                  [    0.141062] test_strscpy: all 32 tests passed
                                  [    0.150362] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
                                  [    0.151378] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
                                  [    0.152565] pwm-backlight backlight: backlight supply power not found, using dummy regulator
                                  [    0.331820] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
                                  [    0.339230] printk: console [ttyS0] disabled
                                  [    0.359722] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 34, base_baud = 1500000) is a U6_16550A
                                  [    1.001897] printk: console [ttyS0] enabled
                                  [    1.007461] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
                                  [    1.039748] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 35, base_baud = 1500000) is a U6_16550A
                                  [    1.052700] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
                                  [    1.096453] panel-simple panel: panel supply power not found, using dummy regulator
                                  [    1.107243] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
                                  [    1.119944] spi-nor spi0.0: w25q128 (16384 Kbytes)
                                  [    1.124842] 5 fixed-partitions partitions found on MTD device spi0.0
                                  [    1.131371] Creating 5 MTD partitions on "spi0.0":
                                  [    1.136226] 0x000000000000-0x000000070000 : "u-boot"
                                  [    1.144708] 0x000000070000-0x000000080000 : "dtb"
                                  [    1.152719] 0x000000080000-0x000000580000 : "kernel"
                                  [    1.161080] 0x000000580000-0x000000f00000 : "rom"
                                  [    1.169143] 0x000000f00000-0x000001100000 : "overlay"
                                  [    1.174230] mtd: partition "overlay" extends beyond the end of device "spi0.0" -- size truncated to 0x100000
                                  [    1.188844] libphy: Fixed MDIO Bus: probed
                                  [    1.193662] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
                                  [    1.200207] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
                                  [    1.206474] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
                                  [    1.212308] dwmac-sun8i 1c30000.ethernet: No regulator found
                                  [    1.218952] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
                                  [    1.226323] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
                                  [    1.233547] dwmac-sun8i 1c30000.ethernet: COE Type 2
                                  [    1.238544] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
                                  [    1.245350] dwmac-sun8i 1c30000.ethernet: Normal descriptors
                                  [    1.251007] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
                                  [    1.256704] dwmac-sun8i 1c30000.ethernet: device MAC address e2:16:b0:58:2d:16
                                  [    1.264377] libphy: stmmac: probed
                                  [    1.269030] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
                                  [    1.275594] libphy: mdio_mux: probed
                                  [    1.279225] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
                                  [    1.285662] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
                                  [    1.391668] dwmac-sun8i 1c30000.ethernet: EMAC reset timeout
                                  [    1.397582] dwmac-sun8i 1c30000.ethernet: Error: Failed to register MDIO bus for child /soc/ethernet@1c30000/mdio-mux/mdio@1
                                  [    1.408858] dwmac-sun8i 1c30000.ethernet: Error: No acceptable child buses found
                                  [    1.416283] dwmac-sun8i 1c30000.ethernet: Failed to register mux
                                  [    1.422308] dwmac-sun8i 1c30000.ethernet eth0: stmmac_dvr_remove: removing driver
                                  [    1.456836] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                                  [    1.463390] ehci-platform: EHCI generic platform driver
                                  [    1.469358] ehci-platform 1c1a000.usb: EHCI Host Controller
                                  [    1.475009] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
                                  [    1.483494] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
                                  [    1.515335] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
                                  [    1.523239] hub 1-0:1.0: USB hub found
                                  [    1.527346] hub 1-0:1.0: 1 port detected
                                  [    1.532359] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                                  [    1.538826] ohci-platform: OHCI generic platform driver
                                  [    1.544632] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
                                  [    1.551461] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
                                  [    1.559870] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
                                  [    1.643781] hub 2-0:1.0: USB hub found
                                  [    1.647887] hub 2-0:1.0: 1 port detected
                                  [    1.653064] usbcore: registered new interface driver usb-storage
                                  [    1.660188] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
                                  [    1.672488] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
                                  [    1.678463] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
                                  [    1.688230] hub 3-0:1.0: USB hub found
                                  [    1.692143] hub 3-0:1.0: 1 port detected
                                  [    1.699312] mousedev: PS/2 mouse device common for all mice
                                  [    1.705823] i2c /dev entries driver
                                  [    1.713164] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
                                  [    1.722569] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
                                  [    1.760356] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
                                  [    1.784584] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
                                  [    1.791734] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
                                  [    1.797365] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
                                  [    1.804830] sun8i-v3s-pinctrl 1c20800.pinctrl: pin PC0 already requested by 1c68000.spi; cannot claim for 1c11000.mmc
                                  [    1.815583] sun8i-v3s-pinctrl 1c20800.pinctrl: pin-64 (1c11000.mmc) status -22
                                  [    1.822809] sun8i-v3s-pinctrl 1c20800.pinctrl: could not request pin 64 (PC0) from group PC0  on device 1c20800.pinctrl
                                  [    1.833617] sunxi-mmc 1c11000.mmc: Error applying setting, reverse things back
                                  [    1.840918] sunxi-mmc: probe of 1c11000.mmc failed with error -22
                                  [    1.848713] usbcore: registered new interface driver usbhid
                                  [    1.854304] usbhid: USB HID core driver
                                  [    1.863049] sun4i-codec 1c22c00.codec: Failed to register our card
                                  [    1.871893] IPv4 over IPsec tunneling driver
                                  [    1.877534] NET: Registered protocol family 17
                                  [    1.882112] Key type dns_resolver registered
                                  [    1.886810] Registering SWP/SWPB emulation handler
                                  [    1.892520] Loading compiled-in X.509 certificates
                                  [    1.908002] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
                                  [    1.914735] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
                                  [    1.928562] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc085ffa0)
                                  [    1.936810] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc085d100)
                                  [    1.944493] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
                                  [    1.951243] [drm] No driver support for vblank timestamp query.
                                  [    1.958691] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
                                  [    1.974414] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
                                  [    1.977885] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
                                  [    1.989869] mmc0: new high speed SDIO card at address 0001
                                  [    2.012386] Console: switching to colour frame buffer device 100x30
                                  [    2.051547] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
                                  [    2.060874] debugfs: Directory '1c22c00.codec' with parent 'V3s Audio Codec' already present!
                                  [    2.072778] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
                                  [    2.082916] hctosys: unable to open rtc device (rtc0)
                                  [    2.088619] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                                  [    2.101498] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                                  [    2.108508] ALSA device list:
                                  [    2.111506]   #0: V3s Audio Codec
                                  [    2.116242] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
                                  [    2.124948] cfg80211: failed to load regulatory.db
                                  [    2.131683] random: fast init done
                                  [    2.141790] VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
                                  [    2.153594] devtmpfs: mounted
                                  [    2.159854] Freeing unused kernel memory: 1024K
                                  [    2.175698] Run /sbin/init as init process
                                  [    2.314836] random: crng init done
                                  Mounting OverlayFS: [    3.139500] overlayfs: upper fs does not support tmpfile.
                                  [    3.145015] overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off.
                                  OK
                                  Populating /dev using udev: [    3.623995] udevd[93]: starting version 3.2.9
                                  [    3.979816] udevd[94]: starting eudev-3.2.9
                                  /usr/img/hehua.jpg
                                  1024 x 682
                                  [    5.270926] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43362-sdio for chip BCM43362/1
                                  [    5.391407] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43362-sdio.mangopi,mangopi-kit4.txt failed with error -2
                                  [    5.474701] Goodix-TS 0-0014: 0-0014 supply AVDD28 not found, using dummy regulator
                                  [    5.482990] Goodix-TS 0-0014: 0-0014 supply VDDIO not found, using dummy regulator
                                  [    5.678780] Goodix-TS 0-0014: ID 911, version: 1060
                                  [    5.684264] Goodix-TS 0-005d: 0-005d supply AVDD28 not found, using dummy regulator
                                  [    5.692435] Goodix-TS 0-005d: 0-005d supply VDDIO not found, using dummy regulator
                                  [    5.749241] input: Goodix Capacitive TouchScreen as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0014/input/input0
                                  [    5.767671] Goodix-TS: probe of 0-005d failed with error -16
                                  [    5.807984] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43362-sdio for chip BCM43362/1
                                  [    5.817255] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
                                  [    5.889978] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43362/1 wl0: Apr 22 2013 14:50:00 version 5.90.195.89.6 FWID 01-b30a427d
                                  done
                                  [    8.470088] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
                                  udhcpc: started, v1.31.1
                                  1 playing '/usr/wav/startup.wav': 2 ch, 48000 hz, 16 bit
                                  udhcpc: sending discover
                                  2 Realtek Bluetooth WARN: OP_H5_SYNC Transmission timeout
                                  ^C
                                  [1]+  Done                       tinyplay /usr/wav/startup.wav
                                  # Realtek Bluetooth WARN: OP_H5_SYNC Transmission timeout
                                  Realtek Bluetooth ERROR: Retransmission exhausts
                                  # udhcpc: sending discover
                                  udhcpc: sending select for 192.168.187.193
                                  # udhcpc: sending select for 192.168.187.193
                                  udhcpc: lease of 192.168.187.193 obtained, lease time 3599
                                  deleting routers
                                  adding dns 192.168.187.8
                                  # ping www.163.com
                                  PING www.163.com (183.252.198.12): 56 data bytes
                                  64 bytes from 183.252.198.12: seq=0 ttl=52 time=54.442 ms
                                  64 bytes from 183.252.198.12: seq=1 ttl=52 time=52.302 ms
                                  64 bytes from 183.252.198.12: seq=2 ttl=52 time=49.202 ms
                                  64 bytes from 183.252.198.12: seq=3 ttl=52 time=155.962 ms
                                  64 bytes from 183.252.198.12: seq=4 ttl=52 time=48.698 ms
                                  ^C
                                  --- www.163.com ping statistics ---
                                  5 packets transmitted, 5 packets received, 0% packet loss
                                  round-trip min/avg/max = 48.698/72.121/155.962 ms
                                    源码: buildroot_20200204_mangopi_r11_kit4_src_patch_20220422_by_whycan.tar
                                    设置ov2640 摄像头默认格式:
                                    media-ctl --set-v4l2 '"ov2640 1-0030":0[fmt:YUYV8_2X8/640x480]'
                                    开启
                                    LD_LIBRARY_PATH=/usr/lib/mjpg-streamer/:$LD_LIBRARY_PATH mjpg_streamer -i "input_uvc.so -y -d /dev/video0" -o "output_http.so -p 8080 -w /usr/share/mjpg-streamer/www"
                                      OV5640 源码下载: buildroot_20200204_mangopi_r11_kit4_src_patch_20220422B_by_whycan.tar
                                      OV5640 固件下载: firmware-mangopi-kit4-v1-spinor.img
                                      设置ov5640 摄像头默认格式:
                                      media-ctl --set-v4l2 '"ov5640 1-003C":0[fmt:YUYV8_2X8/640x480]'
                                      开启:
                                      • mangogeek
                                        mangogeek LV 8 最后由 编辑
                                        牛逼!
                                        哈哈我准备抄作业了,搞到D1-H上去😀
                                          周末整活,成功挽救这台伊拉克成色的15寸显示器于闲鱼市场:
                                          https://bbs.aw-ol.com/topic/1293/share/35
                                          受这个帖子影响,我打算把这个 R11开发板 也驱动 15寸显示屏:
                                            dream LV 6 @whycan 最后由 编辑
                                            @whycan 大佬,哪里有的卖?
                                            • Referenced by  M memory
                                            • Moved from 创龙科技专区 by  xiaowenge xiaowenge
