    MQ-Quad H616 主线内核编译调试记录(u-boot、kernel、buildroot)
    H/F/TV Series
    20
    44
    52540
    • E
      Evlers LV 6 最后由 evler 编辑
      U-Boot 构建并从USB启动
      安装 sunxi-fel 工具:
      git clone https://github.com/linux-sunxi/sunxi-tools
      cd sunxi-tools/
      make
      Arm Trusted Firmware (arm64)
      git clone https://github.com/ARM-software/arm-trusted-firmware.git
      cd arm-trusted-firmware
      make CROSS_COMPILE=aarch64-linux-gnu- PLAT=<platform> DEBUG=1 bl31
      # platform = sun50i-h616
      下拉最新的 u-boot
      git clone git://git.denx.de/u-boot.git
      cd u-boot
      修改 u-boot
      • MQ-Quad 没有以太网接口 执行 make menuconfig 在主页关闭网络支持:【】Networking support
      • MQ-Quad 使用 axp313 电源管理芯片 修改drivers/power/axp305.c文件:
      # 注释掉 DCDC4 的设置 axp313并没有这路输出
      int axp_set_dcdc4(unsigned int mvolt)
      	int ret;
      	u8 cfg;
      	#if 0
      	if (mvolt >= 1600)
      		cfg = AXP305_DCDC4_1600MV_OFFSET +
      			axp305_mvolt_to_cfg(mvolt, 1600, 3300, 100);
      		cfg = axp305_mvolt_to_cfg(mvolt, 600, 1500, 20);
      	if (mvolt == 0)
      		return pmic_bus_clrbits(AXP305_OUTPUT_CTRL1,
      					AXP305_OUTPUT_CTRL1_DCDCD_EN);
      	ret = pmic_bus_write(AXP305_DCDCD_VOLTAGE, cfg);
      	if (ret)
      		return ret;
      	return pmic_bus_setbits(AXP305_OUTPUT_CTRL1,
      # 添加 DCDC3 的电压设置
      #define AXP305_DCDC3_1200MV_OFFSET 71
      int axp_set_dcdc3(unsigned int mvolt)
      	int ret;
      	u8 cfg;
      	if (mvolt >= 1220)
      		cfg = AXP305_DCDC3_1200MV_OFFSET +
      			axp305_mvolt_to_cfg(mvolt, 1220, 1840, 20);
      		cfg = axp305_mvolt_to_cfg(mvolt, 500, 1200, 10);
      	if (mvolt == 0)
      	if (ret)
      		return ret;
      				0x1f);
      # 修改芯片版本的检测 以及 设置 DCDC3 的电压为1.5v
      int axp_init(void)
      	u8 axp_chip_id;
      	int ret;
      	ret = pmic_bus_init();
      	if (ret)
      		return ret;
      	ret = pmic_bus_read(AXP305_CHIP_VERSION, &axp_chip_id);
      	if (ret)
      		return ret;
      	// if ((axp_chip_id & AXP305_CHIP_VERSION_MASK) != 0x40)
      	// 	return -ENODEV;
      	if ((axp_chip_id & AXP305_CHIP_VERSION_MASK) != 0x4b)
      		return -ENODEV;
      	printf("pmic id is 0x%x\n",axp_chip_id);
      	axp_set_dcdc3(1500);
      	return ret;
      编译 u-boot
      make CROSS_COMPILE=aarch64-linux-gnu- BL31=../arm-trusted-firmware/build/sun50i_h616/debug/bl31.bin orangepi_zero2_defconfig
      测试 u-boot
      • 通过 USB 启动 u-boot
      ../sunxi-tools/sunxi-fel uboot u-boot-sunxi-with-spl.bin
      UART0 中输出 LOG
      U-Boot SPL 2022.10-rc3-00069-g67fe8cc001-dirty (Sep 03 2022 - 18:10:41 +0800)
      pmic id is 0x4b
      DRAM: 1024 MiB
      Trying to boot from FEL
      NOTICE:  BL31: v2.7(debug):v2.7.0-312-g9a5dec669
      NOTICE:  BL31: Built : 17:14:37, Sep  3 2022
      NOTICE:  BL31: Detected Allwinner H616 SoC (1823)
      NOTICE:  BL31: Found U-Boot DTB at 0x4a081ff0, model: OrangePi Zero2
      INFO:    ARM GICv2 driver initialized
      INFO:    Configuring SPC Controller
      INFO:    PMIC: Probing AXP305 on RSB
      ERROR:   RSB: set run-time address: 0x10003
      INFO:    Could not init RSB: -65539
      INFO:    BL31: Platform setup done
      INFO:    BL31: Initializing runtime services
      INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
      INFO:    BL31: cortex_a53: CPU workaround for 1530924 was applied
      INFO:    PSCI: Suspend is unavailable
      INFO:    BL31: Preparing for EL3 exit to normal world
      INFO:    Entry point address = 0x4a000000
      INFO:    SPSR = 0x3c9
      INFO:    Changed devicetree.
      U-Boot 2022.10-rc3-00069-g67fe8cc001-dirty (Sep 03 2022 - 18:10:41 +0800) Allwinner Technology
      CPU:   Allwinner H616 (SUN50I)
      Model: OrangePi Zero2
      DRAM:  1 GiB
      Core:  49 devices, 17 uclasses, devicetree: separate
      WDT:   Not starting watchdog@30090a0
      MMC:   mmc@4020000: 0
      Loading Environment from FAT... MMC: no card present
      ** Bad device specification mmc 0 **
      In:    serial@5000000
      Out:   serial@5000000
      Err:   serial@5000000
      主线 Kernel 编译
      拉取/下载压缩 主线内核
      git clone git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git
      # 速度较慢,直接去官网下载 mainline 内核:https://kernel.org
      # 解压内核
      tar -xvzf linux-6.0-rc3.tar.gz
      修改设备树
      /arch/arm64/boot/dts/allwinner/sun50i-h616-orangepi-zero2.dts
      # 因为 MQ-Quad 的 3.3v 是没接 pmic 来控制的,所以要添加固定 3.3v 的节点
      # 在 reg_vcc5v 节点下面添加 reg_vcc3v3 节点 (否则无法初始化IO,导致串口无法初始化)
      reg_vcc3v3: vcc3v3 {
      	regulator-name = "vcc-3v3";
      	regulator-always-on;
      # 修改 pio 节点中的 reg_aldo1 为 reg_vcc3v3
      &pio {
      	vcc-pc-supply = <&reg_vcc3v3>;
      	vcc-pf-supply = <&reg_vcc3v3>;
      	vcc-pg-supply = <&reg_vcc3v3>;
      	vcc-ph-supply = <&reg_vcc3v3>;
      	vcc-pi-supply = <&reg_vcc3v3>;
      # 修改 mmc0 的 vmmc-supply 的 reg_dcdce 为 reg_vcc3v3(否则无法启动 sunxi-mmc 驱动)
      &mmc0 {
      	vmmc-supply = <&reg_vcc3v3>;
      	cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>;	/* PF6 */
      	bus-width = <4>;
      配置编译
      # 使用默认配置
      make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- defconfig
      # 编译内核镜像
      make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- -j8 Image
      # 编译设备树
      make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- -j8 dtbs
      # 编译模块(可选,后面做了文件系统后再使用)
      make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- -j8 modules
      make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- INSTALL_MOD_PATH=<any-path-you-like> modules modules_install
      构建成功后,可以在提供的 INSTALL_MOD_PATH 目录中找到模块
      # 安装头文件(可选,后面做了文件系统后再使用)
      make ARCH=arm64 INSTALL_HDR_PATH=<any-path-you-like> headers_install
      将 INSTALL_HDR_PATH 更改为希望安装到的路径,例如/usr或<some_prefix>/usr 方便后期交叉编译
      制作引导脚本(当然也可以在uboot中设置变量并执行booti)
      • 制作 boot.cmd 文件, USB 写入内核直接使用固定地址启动
      vi boot.cmd
      # 复制以下内容
      setenv bootargs console=ttyS0,115200
      booti 0x40200000 - 0x4fa00000
      • 转换打包boot.scr文件:mkimage -C none -A arm64 -T script -d boot.cmd boot.scr
      • booti 讲解:
        在u-boot中,bootm是一个可以执行位于memory中的应用程序的命令
        booti是bootm命令的一个子集,可用于执行位于memory中的ARM64 kernel Image,其格式如下:
        booti addr [initrd[:size]] [fdt]
        其中:addr是kernel Image文件所在的memory地址;[initrd[:size]]是initrd在memory中的位置和size,可以不指定,使用“-”代替即可;fdt是flat device tree(就是传说中的dtb文件)在memory中的地址,在ARM64中,它是必选的
      测试 USB 启动内核
      sunxi-fel -v uboot u-boot-sunxi-with-spl.bin \
                   write 0x40200000 Image \
                   write 0x4fa00000 sun50i-a64-pine64-lts.dtb \
                   write 0x4fc00000 boot.scr \
                   write 0x4ff00000 rootfs.cpio.lzma.uboot
      # 例如:
      ./sunxi-tools/sunxi-fel -v uboot u-boot/u-boot-sunxi-with-spl.bin \
      write 0x40200000 linux-6.0-rc3/arch/arm64/boot/Image \
      write 0x4fa00000 linux-6.0-rc3/arch/arm64/boot/dts/allwinner/sun50i-h616-orangepi-zero2.dtb \
      从 TF 卡启动 SPL、U-Boot、Kernel
      制作启动盘
      # 进入磁盘管理
      fdisk /dev/sdd
      # 多执行几次删除所有分区
      d
      # 新建分区 (扇区为单位,前面空开20MB用于存放uboot,制作128MB的分区)
      n
      p
      40960
      303104
      w
      # 进行 FAT 格式化
      sudo mkfs.fat /dev/sdd1
      # 写入 uboot 到 8KB 的位置
      sudo dd if=./u-boot/u-boot-sunxi-with-spl.bin of=/dev/sdd bs=8K seek=1
      # 挂载 FAT 文件系统
      sudo mount /dev/sdd1 /mnt/boot/
      # 复制内核以及设备树到FAT分区
      sudo cp linux-6.0-rc3/arch/arm64/boot/Image /mnt/boot/
      sudo cp linux-6.0-rc3/arch/arm64/boot/dts/allwinner/sun50i-h616-orangepi-zero2.dtb /mnt/boot/
      # 卸载 FAT 文件系统
      sudo umount /mnt/boot
      测试 TF 卡启动内核
      # 手动装载内核以及设备树并启动
      fatload mmc 0:1 0x40200000 Image
      fatload mmc 0:1 0x4fa00000 sun50i-h616-orangepi-zero2.dtb
      setenv bootargs 'console=ttyS0,115200 earlycon'
      # 使用如下设置变量并保存到FAT分区
      setenv bootargs 'console=ttyS0,115200'
      setenv bootcmd 'fatload mmc 0:1 0x40200000 Image;fatload mmc 0:1 0x4fa00000 sun50i-h616-orangepi-zero2.dtb;booti 0x40200000 - 0x4fa00000'
      saveenv
      # 使用 bootcmd 启动
      boot
      Buildroot 构建
      buildroot-2022.02.5
      配置编译
      make menuconfig
      # 配置 Target options
      > Target options
      	Target Architecture (AArch64 (little endian))  --->
      	Target Binary Format (ELF)  --->
      	Target Architecture Variant (cortex-A53)  --->
      	Floating point strategy (VFPv4)  --->
      # 配置 Toolchain
      > Toolchain
      	Toolchain type (External toolchain)  --->
      	Toolchain (Custom toolchain)  --->
      	Toolchain origin (Pre-installed toolchain)  --->
      	(/usr/local/arm64/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu$ /usr/local/arm64/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu) Toolchain path
      	(aarch64-linux-gnu-) Toolchain prefix  						//需要按住shift才能删减
      	External toolchain gcc version (7.x)  --->
      	External toolchain kernel headers series (4.10.x)  ---> 			//查看补充
      	[*] Toolchain has SSP support? (NEW)
      	[*] Toolchain has RPC support? (NEW)
      	[*] Toolchain has C++ support?
      	[*] Enable MMU support (NEW)
      # 配置 Filesystem images
      -> Filesystem images
      	-> [*] ext2/3/4 root filesystem 						//如果是 EMMC 或 SD 卡的话就用 ext3/ext4
      		-> ext2/3/4 variant = ext4 						//选择 ext4 格式
      		-> exact size =128M 							//ext4 格式根文件系统 1GB(根据实际情况修改)
      	-> [*] ubi image containing an ubifs root filesystem 				//如果使用 NAND 的话就用 ubifs
      # 编译
      make -j8
      补充
      • External toolchain kernel headers series 的设置:
        cat /usr/aarch64-linux-gnu/include/linux/version.h
      #define LINUX_VERSION_CODE 266002
      #define KERNEL_VERSION(a,b,c) (((a) << 16) + ((b) << 8) + (c))
      # 266002 转十六进制为 40A03 则版本号为 4.10.3
      制作根文件系统到 TF 卡
      # 新建第二分区 128MB 从 303106 扇区开始
      sudo fdisk /dev/sdc
      n
      p
      +262144
      w
      # 格式化文件系统为 ext4
      sudo mkfs.ext4 /dev/sdc2
      # 装载并复制文件系统
      sudo mount /dev/sdc2 /mnt/rootfs/
      sudo cp ./output/images/rootfs.tar /mnt/rootfs/
      sudo tar -vxf /mnt/rootfs/rootfs.tar -C /mnt/rootfs
      sudo rm /mnt/rootfs/rootfs.tar
      sudo umount /mnt/rootfs
      测试文件系统
      # 在进入 uboot 后检查文件是否存在
      ext4ls mmc 0:2
      # 设置启动命令
      # 设置 bootargs 变量
      setenv bootargs 'console=ttyS0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait rw  init=/sbin/init debug panic=30'
      # 启动内核以及根文件系统
      boot
      添加网络支持
      因为6.0的内核太新了,很多驱动没支持,所以使用稳定版内核进行驱动的移植
      下拉内核
      • H616主线内核维护者的内核:git clone -b h616-v13 https://github.com/apritzel/linux
      • 使用主线需修改设备树,按照主线内核的修改配置方法
      移植 RTL8723DS WiFi 驱动
      • git clone https://github.com/lwfinger/rtl8723ds 到 /drivers/net/wireless/realtek/rtl8723ds 目录中
      • 修改 rtl8723ds 的 Kconfig 中 ---help--- 为 help
      config RTL8723DS
      	tristate "Realtek 8723D SDIO or SPI WiFi"
      	help
      	  Help message of RTL8723DS
      • 修改 /drivers/net/wireless/realtek/ 目录中的Kconfig、Makefile:
      # Kconfig 中添加新的驱动
      source "drivers/net/wireless/realtek/rtl8723ds/Kconfig"
      # Makefile 中添加新的驱动
      obj-$(CONFIG_RTL8723DS)		+= rtl8723ds/
      打开 WiFi(RTL8723DS) 支持
      # make menuconfig
      > Device Drivers
      > 	> Network device support
      > 		> Wireless LAN
      > 			[*]   Realtek devices
      > 				<M>     Realtek 8723D SDIO or SPI WiFi
      # 编译内核模块(在此我已经将 ARCH 以及 CROSS_COMPILE 固定到Makefile中,所以不需要带参)
      make modules -j8
      Kernel 设备树配置
      # 在 reg_vcc3v3 后面添加 WiFi 的电源配置
      reg_vcc33_wifi: vcc33-wifi {
      	/* Always on 3.3V regulator for WiFi and BT */
      	regulator-name = "vcc33-wifi";
      	vin-supply = <&reg_vcc5v>;
      reg_vcc_wifi_io: vcc-wifi-io {
      	/* Always on 1.8V/300mA regulator for WiFi and BT IO */
      	regulator-name = "vcc-wifi-io";
      	regulator-min-microvolt = <1800000>;
      	regulator-max-microvolt = <1800000>;
      	vin-supply = <&reg_vcc33_wifi>;
      wifi_pwrseq: wifi-pwrseq {
      	compatible = "mmc-pwrseq-simple";
      	clocks = <&rtc 1>;
      	clock-names = "osc32k-out";
      	reset-gpios = <&pio 6 18 GPIO_ACTIVE_LOW>; /* PG18 */
      	post-power-on-delay-ms = <200>;
      # 添加 WiFi 的 mmc1 配置
      &mmc1 {
      	vmmc-supply = <&reg_vcc33_wifi>;
      	vqmmc-supply = <&reg_vcc_wifi_io>;
      	mmc-pwrseq = <&wifi_pwrseq>;
      	bus-width = <4>;
      	non-removable;
      	mmc-ddr-1_8v;
      # 编译设备树
      make dtbs
      • 完成后需要重新拷贝新的设备树到 FAT 分区
      Buildrootfs 配置
      make menuconfig
      # 使用 mdev 动态加载模块
      > System configuration
      	Init system (BusyBox)  --->
      	/dev management (Dynamic using devtmpfs + mdev)  --->
      # 打开网络支持
      > Target packages
      	> Networking applications
      		[*] iperf3 						// 用于网速测试
      		[*] lftp						// 用于网络文件传输
      		[*]   SFTP protocol				 	// 使能 SFTP 协议
      		[*] openssh						// 使能远程 ssh
      		[*] wpa_supplicant  --->				// 使能 wpa 用于WiFi控制
      			[*]   Install wpa_cli binary
      	> System tools
      		[*] htop
      make -j8
      复制新的文件系统并安装模块
      # 在buildroot中执行 替换根文件系统
      sudo mount /dev/sdd2 /mnt/rootfs
      sudo rm -rf /mnt/rootfs/*
      sudo cp output/images/rootfs.tar /mnt/rootfs/
      sudo tar -xvf /mnt/rootfs/rootfs.tar -C /mnt/rootfs/
      # 在内核中执行 安装模块到第二分区的rootfs中(因为内核没经过裁剪会有大量的模块安装到第二分区,可能需要调整下第二分区的大小)
      make INSTALL_MOD_PATH=/mnt/rootfs/ modules modules_install
      # 卸载rootfs
      sync
      sudo umount /mnt/rootfs/
      测试网络
      # 检查WiFi是否自动挂载
      # lsmod
      Module                  Size  Used by
      ipv6                  462848  18
      8723ds               1466368  0
      cfg80211              380928  1 8723ds
      rfkill                 36864  2 cfg80211
      sunxi_wdt              20480  0
      dwmac_sun8i            28672  0
      stmmac_platform        20480  1 dwmac_sun8i
      stmmac                221184  2 dwmac_sun8i,stmmac_platform
      pcs_xpcs               24576  1 stmmac
      crct10dif_ce           20480  1
      # 配置 WiFi
      # vi /etc/wpa_supplicant.conf
      ctrl_interface=/var/run/wpa_supplicant
      ap_scan=1
      network={
              ssid="you wifi ssid"
              psk="you wifi password"
      # 连接WiFi
      # ifconfig wlan0 up
      # wpa_supplicant -Dnl80211 -iwlan0 -c/etc/wpa_supplicant.conf -B
      # udhcpc -i wlan0
      # 配置开机自动连接 WiFi
      # vi /etc/init.d/S45wifi
      #!/bin/sh
      # wlan0        Starts WiFi.
      start() {
              printf "Starting WiFi: "
              ifconfig wlan0 up
              udhcpc -i wlan0
              echo "OK"
      stop() {
              printf "Stopping WiFi: "
              killall udhcpc
              killall wpa_supplicant
              echo "OK"
      restart() {
              stop
              start
      case "$1" in
        start)
              start
        stop)
              stop
        restart|reload)
              restart
              exit 1
      esac
      exit $?
      # chmod +x /etc/init.d/S45wifi
      # 网络测速
      # iperf3 -c 192.168.10.164
      Connecting to host 192.168.10.164, port 5201
      [  5] local 192.168.10.196 port 43126 connected to 192.168.10.164 port 5201
      [ ID] Interval           Transfer     Bitrate         Retr  Cwnd
      [  5]   0.00-1.00   sec  1.75 MBytes  14.7 Mbits/sec    0   93.3 KBytes
      [  5]   1.00-2.00   sec  2.17 MBytes  18.2 Mbits/sec    0    123 KBytes
      [  5]   2.00-3.00   sec  2.42 MBytes  20.3 Mbits/sec    0    151 KBytes
      [  5]   3.00-4.00   sec  2.92 MBytes  24.5 Mbits/sec    0    158 KBytes
      [  5]   4.00-5.00   sec  2.61 MBytes  21.9 Mbits/sec    0    167 KBytes
      [  5]   5.00-6.00   sec  2.61 MBytes  21.9 Mbits/sec    0    167 KBytes
      [  5]   6.00-7.00   sec  2.61 MBytes  21.9 Mbits/sec    0    167 KBytes
      [  5]   7.00-8.00   sec  2.61 MBytes  21.9 Mbits/sec    0    167 KBytes
      [  5]   8.00-9.00   sec  2.61 MBytes  21.9 Mbits/sec    0    167 KBytes
      [  5]   9.00-10.00  sec  2.61 MBytes  21.9 Mbits/sec    0    167 KBytes
      [  5]   0.00-10.00  sec  24.9 MBytes  20.9 Mbits/sec    0             sender
      [  5]   0.00-10.00  sec  24.2 MBytes  20.3 Mbits/sec                  receiver
      iperf Done.
      # 远程连接 ssh 配置 sshd_config 文件
      # vi /etc/ssh/sshd_config
      PermitRootLogin yes    //修改
      AllowUsers root        //添加
      # 重启 sshd 服务
      # /etc/init.d/S50sshd restart
      # 设置 root 密码
      # passwd root
      # 配置终端
      # vi /etc/profile.d/myprofile.sh
      #!/bin/sh
      PS1='[\u@\h]:\w$ '
      export PS1
      # chmod +x /etc/profile.d/myprofile.sh
      # source /etc/profile.d/myprofile.sh
      启动日志
      pmic id is 0x4b
      DRAM: 1024 MiB
      Trying to boot from MMC1
      INFO:    SPSR = 0x3c9
      DRAM:  1 GiB
      MMC:   mmc@4020000: 0
      Loading Environment from FAT... OK
      In:    serial@5000000
      Out:   serial@5000000
      Err:   serial@5000000
      35908096 bytes read in 1489 ms (23 MiB/s)
      13222 bytes read in 2 ms (6.3 MiB/s)
      ## Flattened Device Tree blob at 4fa00000
         Booting using the fdt blob at 0x4fa00000
         Loading Device Tree to 0000000049ff9000, end 0000000049fff3a5 ... OK
      Starting kernel ...
      [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
      [    0.000000] Linux version 5.19.0-rc1-609706-gc465e81f8859-dirty (evler@evler-Standard-PC-i440FX-PIIX-1996) (aarch64-linux-gnu-g2
      [    0.000000] Machine model: MQ-Quad_H616
      [   0.000000] efi: UEFI not found.
      []t[    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000007fffffff]
      [    0.000000] NUMA: NODE_DATA [mem 0x7fdebb40-0x7fdedfff]
      [    0.000000] Zone ranges:
      [    0.000000]   DMA      [mem 0x0000000040000000-0x000000007fffffff]
      [    0.000000]   DMA32    empty
      [    0.000000]   node   0: [mem 0x0000000040000000-0x000000004003ffff]
      [    0.000000]   node   0: [mem 0x0000000040040000-0x000000007fffffff]
      [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff]
      [    0.000000] cma: Reserved 32 MiB at 0x000000007cc00000
      [    0.000000] psci: PSCIv1.1 detected in firmware.
      [    0.000000] psci: SMC Calling Convention v1.2
      [    0.000000] percpu: Embedded 19 pages/cpu s40808 r8192 d28824 u77824
      [    0.000000] pcpu-alloc: s40808 r8192 d28824 u77824 alloc=19*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [    0.000000] Detected VIPT I-cache on CPU0
      [    0.000000] CPU features: detected: ARM erratum 845719
      [    0.000000] Fallback order for Node 0: 0
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258048
      [    0.000000] Policy zone: DMA
      [    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait rw  init=/sbin/init debug pa0
      [    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
      [    0.000000] Memory: 959476K/1048576K available (15680K kernel code, 3386K rwdata, 8928K rodata, 6912K init, 577K bss, 56332K re)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.000000] rcu:     RCU event tracing is enabled.
      [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
      [    0.000000]  Trampoline variant of Tasks RCU enabled.
      [    0.000000]  Tracing variant of Tasks RCU enabled.
      [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
      [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
      [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
      [    0.000000] Root IRQ handler: gic_handle_irq
      [    0.000000] GIC: Using split EOI/Deactivate mode
      [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
      [    0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.000676] Console: colour dummy device 80x25
      [    0.000771] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
      [    0.000786] pid_max: default: 32768 minimum: 301
      [    0.000858] LSM: Security Framework initializing
      [    0.000989] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
      [    0.001005] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
      [    0.002687] cblist_init_generic: Setting adjustable number of callback queues.
      [    0.002711] cblist_init_generic: Setting shift to 2 and lim to 1.
      [    0.002794] cblist_init_generic: Setting shift to 2 and lim to 1.
      [    0.002965] rcu: Hierarchical SRCU implementation.
      [    0.004261] EFI services will not be available.
      [    0.004620] smp: Bringing up secondary CPUs ...
      [    0.005158] Detected VIPT I-cache on CPU1
      [    0.005243] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
      [    0.005923] Detected VIPT I-cache on CPU2
      [    0.005995] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
      [    0.006627] Detected VIPT I-cache on CPU3
      [    0.006696] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
      [    0.006790] smp: Brought up 1 node, 4 CPUs
      [    0.006798] SMP: Total of 4 processors activated.
      [    0.006802] CPU features: detected: 32-bit EL0 Support
      [    0.006806] CPU features: detected: CRC32 instructions
      [    0.007163] CPU: All CPU(s) started at EL2
      [    0.007182] alternatives: patching kernel code
      [    0.008730] devtmpfs: initialized
      [    0.012355] KASLR disabled due to lack of seed
      [    0.012584] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
      [    0.012605] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      [    0.014003] pinctrl core: initialized pinctrl subsystem
      [    0.015167] DMI not present or invalid.
      [    0.016034] NET: Registered PF_NETLINK/PF_ROUTE protocol family
      [    0.017612] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
      [    0.017939] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
      [    0.018106] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
      [    0.018212] audit: initializing netlink subsys (disabled)
      [    0.018467] audit: type=2000 audit(0.016:1): state=initialized audit_enabled=0 res=1
      [    0.019563] thermal_sys: Registered thermal governor 'step_wise'
      [    0.019574] thermal_sys: Registered thermal governor 'power_allocator'
      [    0.019703] cpuidle: using governor menu
      [    0.020054] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
      [    0.020231] ASID allocator initialised with 65536 entries
      [    0.020241] HugeTLB: can optimize 4095 vmemmap pages for hugepages-1048576kB
      [    0.020247] HugeTLB: can optimize 127 vmemmap pages for hugepages-32768kB
      [    0.020252] HugeTLB: can optimize 7 vmemmap pages for hugepages-2048kB
      [    0.020256] HugeTLB: can optimize 0 vmemmap pages for hugepages-64kB
      [    0.021930] Serial: AMBA PL011 UART driver
      [    0.029582] platform 7000000.rtc: Fixing up cyclic dependency with 3001000.clock
      [    0.030090] platform 7010000.clock: Fixing up cyclic dependency with 7000000.rtc
      [    0.044690] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
      [    0.044705] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
      [    0.044711] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
      [    0.044716] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
      [    0.046360] ACPI: Interpreter disabled.
      [    0.049195] iommu: Default domain type: Translated
      [    0.049210] iommu: DMA domain TLB invalidation policy: strict mode
      [    0.049572] SCSI subsystem initialized
      [    0.049784] libata version 3.00 loaded.
      [    0.050061] usbcore: registered new interface driver usbfs
      [    0.050102] usbcore: registered new interface driver hub
      [    0.050137] usbcore: registered new device driver usb
      [    0.050867] pps_core: LinuxPPS API ver. 1 registered
      [    0.050873] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
      [    0.050892] PTP clock support registered
      [    0.050996] EDAC MC: Ver: 3.0.0
      [    0.052387] FPGA manager framework
      [    0.052558] Advanced Linux Sound Architecture Driver Initialized.
      [    0.053492] vgaarb: loaded
      [    0.054091] clocksource: Switched to clocksource arch_sys_counter
      [    0.054373] VFS: Disk quotas dquot_6.6.0
      [    0.054422] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
      [    0.054644] pnp: PnP ACPI: disabled
      [    0.061916] NET: Registered PF_INET protocol family
      [    0.062157] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
      [    0.063320] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
      [    0.063366] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.063497] TCP bind bhash tables hash table entries: 8192 (order: 5, 196608 bytes, linear)
      [    0.063743] TCP: Hash tables configured (established 8192 bind 8192)
      [    0.063914] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    0.063951] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    0.064165] NET: Registered PF_UNIX/PF_LOCAL protocol family
      [    0.064703] RPC: Registered named UNIX socket transport module.
      [    0.064715] RPC: Registered udp transport module.
      [    0.064718] RPC: Registered tcp transport module.
      [    0.064721] RPC: Registered tcp NFSv4.1 backchannel transport module.
      Starting syslogd[    0.064732] PCI: CLS 0 bytes, default 64
      : [    0.065880] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
      [    0.067407] Initialise system trusted keyrings
      [    0.067740] workingset: timestamp_bits=42 max_order=18 bucket_order=0
      OK[    0.075263] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.076086] NFS: Registering the id_resolver key type
      [    0.076137] Key type id_resolver registered
      [    0.076141] Key type id_legacy registered
      Starting klogd: [    0.076225] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    0.076231] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
      OK
      [    0.076456] 9p: Installing v9fs 9p2000 file system support
      [    0.119607] Key type asymmetric registered
      [    0.119618] Asymmetric key parser 'x509' registered
      Running sysctl: [    0.119691] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
      [    0.119698] io scheduler mq-deadline registered
      [    0.119702] io scheduler kyber registered
      [    0.129824] EINJ: ACPI disabled.
      OK[    0.149674] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
      [    0.153025] SuperH (H)SCI(F) driver initialized
      [    0.153497] msm_serial: driver initialized
      Starting mdev...[    0.155231] cacheinfo: Unable to detect cache hierarchy for CPU 0
       [    0.161996] loop: module loaded
      OK[    0.163289] megasas: 07.719.03.00-rc1
      [    0.169894] tun: Universal TUN/TAP device driver, 1.6
      [    0.171057] thunder_xcv, ver 1.0
      [    0.171110] thunder_bgx, ver 1.0
      [    0.171163] nicpf, ver 1.0
      [    0.172488] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
      [    0.172496] hns3: Copyright (c) 2017 Huawei Corporation.
      [    0.172585] hclge is initializing
      [    0.172609] e1000: Intel(R) PRO/1000 Network Driver
      [    0.172613] e1000: Copyright (c) 1999-2006 Intel Corporation.
      [    0.172656] e1000e: Intel(R) PRO/1000 Network Driver
      [    0.172659] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
      [    0.172699] igb: Intel(R) Gigabit Ethernet Network Driver
      [    0.172702] igb: Copyright (c) 2007-2014 Intel Corporation.
      [    0.172737] igbvf: Intel(R) Gigabit Virtual Function Network Driver
      [    0.172740] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
      [    0.173131] sky2: driver version 1.30
      [    0.174339] VFIO - User Level meta-driver version: 0.3
      [    0.176796] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    0.176810] ehci-pci: EHCI PCI platform driver
      [    0.176868] ehci-platform: EHCI generic platform driver
      [    0.177001] ehci-orion: EHCI orion driver
      [    0.177118] ehci-exynos: EHCI Exynos driver
      [    0.177215] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    0.177252] ohci-pci: OHCI PCI platform driver
      [    0.177309] ohci-platform: OHCI generic platform driver
      [    0.177430] ohci-exynos: OHCI Exynos driver
      [    0.177989] usbcore: registered new interface driver usb-storage
      [    0.181279] i2c_dev: i2c /dev entries driver
      [    0.189068] sdhci: Secure Digital Host Controller Interface driver
      [    0.189082] sdhci: Copyright(c) Pierre Ossman
      [    0.189877] Synopsys Designware Multimedia Card Interface Driver
      [    0.191189] sdhci-pltfm: SDHCI platform and OF driver helper
      [    0.193497] ledtrig-cpu: registered to indicate activity on CPUs
      [    0.195785] SMCCC: SOC_ID: ID = jep106:091e:1823 Revision = 0x00000000
      [    0.196728] usbcore: registered new interface driver usbhid
      [    0.196738] usbhid: USB HID core driver
      [    0.204363] NET: Registered PF_PACKET protocol family
      [    0.204548] 9pnet: Installing 9P2000 support
      [    0.204622] Key type dns_resolver registered
      [    0.205231] registered taskstats version 1
      [    0.205255] Loading compiled-in X.509 certificates
      [    0.229952] sun6i-rtc 7000000.rtc: registered as rtc0
      [    0.229992] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-02T01:00:55 UTC (90055)
      [    0.230669] sun6i-rtc 7000000.rtc: RTC enabled
      [    0.251225] sun50i-h616-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
      [    0.252741] sun50i-h616-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
      [    0.255230] printk: console [ttyS0] disabled
      [    0.275633] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 283, base_baud = 1500000) is a 16550A
      [    0.275860] printk: console [ttyS0] printing thread started
      [    0.275885] printk: console [ttyS0] enabled
      [    0.278807] sun6i-spi 5010000.spi: Failed to request TX DMA channel
      [    0.278825] sun6i-spi 5010000.spi: Failed to request RX DMA channel
      [    0.279672] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
      [    0.289313] sunxi-mmc 4020000.mmc: Got CD GPIO
      [    0.292181] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq
      [    0.292272] sun50i-h616-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator
      [    0.292656] sunxi-rsb 7083000.rsb: RSB running at 3000000 Hz
      [    0.292847] sunxi-rsb 7083000.rsb: /soc/rsb@7083000/pmic@745: set runtime address failed: -22
      [    0.293011] axp20x-rsb sunxi-rsb-745: AXP20x variant AXP806 found
      [    0.293908] axp20x-regulator axp20x-regulator.1: Error setting dcdc frequency: -5
      [    0.294060] vdd-cpu: failed to get the current voltage: -EIO
      [    0.294112] axp20x-regulator axp20x-regulator.1: Failed to register dcdca
      [    0.294118] axp20x-regulator: probe of axp20x-regulator.1 failed with error -5
      [    0.294520] axp20x-rsb sunxi-rsb-745: AXP20X driver loaded
      [    0.295500] ALSA device list:
      [    0.295514]   No soundcards found.
      [    0.314372] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
      [    0.364732] mmc0: host does not support reading read-only switch, assuming write-enable
      [    0.368126] mmc0: new high speed SDHC card at address aaaa
      [    0.369015] mmcblk0: mmc0:aaaa SL32G 28.8 GiB
      [    0.371681]  mmcblk0: p1 p2
      [    0.522656] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
      [    0.528860] sunxi-mmc 4021000.mmc: card claims to support voltages below defined range
      [    0.535716] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [    0.535815] VFS: Mounted root (ext4 filesystem) on device 179:2.
      [    0.537777] devtmpfs: mounted
      [    0.539706] mmc1: new high speed SDIO card at address 0001
      [    0.540981] Freeing unused kernel memory: 6912K
      [    0.642146] Run /sbin/init as init process
      [    0.642157]   with arguments:
      [    0.642159]     /sbin/init
      [    0.642161]   with environment:
      [    0.642163]     HOME=/
      [    0.642165]     TERM=linux
      [    0.991510] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      [    1.792288] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found
      [    1.792309] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found
      [    1.927520] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    1.931104] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found
      [    1.931124] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found
      [    1.978799] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    1.993547] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    1.993783] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    1.993809] cfg80211: failed to load regulatory.db
      [    2.332323] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found
      [    2.332347] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found
      Initializing random number generator: OK
      Saving random seed: [    3.998094] random: crng init done
      OK
      Starting system message bus: done
      Starting network: OK
      Starting WiFi: Successfully initialized wpa_supplicant
      udhcpc: started, v1.35.0
      udhcpc: broadcasting discover
      udhcpc: broadcasting select for 192.168.10.196, server 192.168.10.251
      udhcpc: lease of 192.168.10.196 obtained from 192.168.10.251, lease time 43200
      deleting routers
      adding dns 192.168.10.251
      OK
      Starting sshd: [    8.070171] NET: Registered PF_INET6 protocol family
      [    8.071640] Segment Routing with IPv6
      [    8.071670] In-situ OAM (IOAM) with IPv6
      OK
      Welcome to Buildroot
      buildroot login: root
      Password:
      [root@buildroot]:~$ lsmod
      Module                  Size  Used by
      ipv6                  462848  18
      8723ds               1466368  0
      sunxi_wdt              20480  0
      dwmac_sun8i            28672  0
      [root@buildroot]:~$ ifconfig
                collisions:0 txqueuelen:1000
      wlan0     Link encap:Ethernet  HWaddr 94:A4:08:D8:1C:EC
                inet addr:192.168.10.196  Bcast:192.168.10.255  Mask:255.255.255.0
                inet6 addr: fe80::96a4:8ff:fed8:1cec/64 Scope:Link
                inet6 addr: fd15:3be5:c6ac:0:96a4:8ff:fed8:1cec/64 Scope:Global
                RX packets:26 errors:0 dropped:9 overruns:0 frame:0
                TX packets:14 errors:0 dropped:0 overruns:0 carrier:0
                RX bytes:3949 (3.8 KiB)  TX bytes:2116 (2.0 KiB)
      [root@buildroot]:~$ uname -a
      Linux buildroot 5.19.0-rc1-609706-gc465e81f8859-dirty #1 SMP PREEMPT Mon Sep 5 23:37:32 CST 2022 aarch64 GNU/Linux
      [root@buildroot]:~$ df -h
      /dev/root                28.0G     93.7M     26.5G   0% /
      devtmpfs                468.5M         0    468.5M   0% /dev
      tmpfs                   487.9M         0    487.9M   0% /dev/shm
      tmpfs                   487.9M     36.0K    487.8M   0% /tmp
      tmpfs                   487.9M     28.0K    487.8M   0% /run
      [root@buildroot]:~$ free
                    total        used        free      shared  buff/cache   available
      Mem:         999156       30656      936852          64       31648      918856
      Swap:             0           0           0
      [root@buildroot]:~$
      CWEIB A 2 条回复 最后回复 回复 引用 分享 5
      • E
        Evlers LV 6 最后由 编辑
        参考文章:
        https://linux-sunxi.org/U-Boot
        https://linux-sunxi.org/Sunxi-tools
        https://linux-sunxi.org/FEL/USBBoot
        https://linux-sunxi.org/Mainline_Kernel_Howto
        https://linux-sunxi.org/U-Boot#Install_U-Boot
        感谢芒果群里两位 @sputnik @Syter 大佬的调试帮助
        M 1 条回复 最后回复 回复 引用 分享 2
        • E
          制作 TF 启动镜像
          准备工作
          # 创建 images 目录
          mkdir images
          cd images
          # 收集需要用到的文件到 file 目录
          mkdir file
          cp ../u-boot/u-boot-sunxi-with-spl.bin ./file
          cp ../linux-5.19.0/arch/arm64/boot/Image ./file
          cp ../linux-5.19.0/arch/arm64/boot/dts/allwinner/mq-quad.dtb ./file  // 这里我已经单独做了个设备树文件
          cp ../buildroot-2022.02.5/output/images/rootfs.tar ./file
          # 制作空的 img 文件
          sudo dd if=/dev/zero of=./sdcard.img bs=1M count=512
          分区
          sudo fdisk ./sdcard.img
          n
          p
          +131072 // 64MB
          n
          p
          1048575 // 默认
          w
          关联 img 文件到 loop
          sudo losetup -f ./sdcard.img
          #查看关联到哪个位置
          sudo losetup -l
          /dev/loop11         0      0         0  0 /home/evler/Allwinner/MangoPi/Quad/mainline/images/sdcard.img
          写入 uboot 到 img 文件中偏移 8KB 的位置
          sudo dd if=./file/u-boot-sunxi-with-spl.bin of=/dev/loop11 bs=8K seek=1
          关联分区设备
          # 参考分区:
          设备          启动   起点    末尾   扇区  大小 Id 类型
          ./sdcard.img1       40960  172032 131073   64M 83 Linux
          ./sdcard.img2      172033 1048575 876543  428M 83 Linux
          # -o (起始扇区 * 扇区大小)--sizelimit (扇区数量 * 扇区大小) 字节
          sudo losetup -f -o 20971520 --sizelimit 67109376 sdcard.img
          sudo losetup -f -o 88080896 --sizelimit 448790016 sdcard.img
          #查看关联到哪个位置
          sudo losetup -l
          /dev/loop30  67109376 20971520         0  0 /home/evler/Allwinner/MangoPi/Quad/mainline/images/sdcard.img
          /dev/loop26 448790016 88080896         0  0 /home/evler/Allwinner/MangoPi/Quad/mainline/images/sdcard.img
          格式化并挂载分区
          sudo mkfs.fat /dev/loop30
          sudo mkfs.ext4 /dev/loop26
          sudo mount /dev/loop30 /mnt/boot/
          sudo mount /dev/loop26 /mnt/rootfs/
          制作uboot引导脚本
          # 创建 boot.cmd 文件
          vi boot.cmd
          # 复制以下内容
          setenv bootargs console=ttyS0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait rw
          setenv bootcmd fatload mmc 0:1 0x4fc00000 boot.scr; fatload mmc 0:1 0x40200000 Image; fatload mmc 0:1 0x4fa00000 mq-quad.dtb; booti 0x40200000 - 0x4fa00000
          # 生成 boot.scr 文件
          制作 boot 分区
          sudo cp ./file/Image /mnt/boot/
          sudo cp ./file/mq-quad.dtb /mnt/boot/
          sudo cp ./file/boot.scr /mnt/boot/
          制作 rootfs
          # 解压 buildroot 制作出来的根文件系统压缩文件到 rootfs 分区
          sudo tar -vxf ./file/rootfs.tar -C /mnt/rootfs/
          # 安装内核模块到 rootfs 分区
          cd ../linux-5.19.0/
          sudo make INSTALL_MOD_PATH=/mnt/rootfs/ modules_install
          卸载文件系统
          sync
          取消环路的关联
          sudo losetup -d /dev/loop30
          sudo losetup -d /dev/loop26
          sudo losetup -d /dev/loop11
          写入到 TF 卡进行测试
          sudo dd if=./sdcard.img of=/dev/sdd
          1 条回复 最后回复 回复 引用 分享 7
          • F
            fumoumou LV 5 最后由 编辑
            太厉害了,真大佬!
              太厉害了,真大佬!
              E 1 条回复 最后回复 回复 引用 分享 0
              • E
                Evlers LV 6 @YuzukiTsuru 最后由 编辑
                @yuzukitsuru 您才是真大佬,我是小趴菜😳
                • F
                  上来就卡在第一步了,USB启动uboot串口没有反应
                  • E
                    Evlers LV 6 @fumoumou 最后由 编辑
                    @fumoumou 串口接对没,贴上fel的log看看写进去了不
                    F 1 条回复 最后回复 回复 引用 分享 0
                    • F
                      fumoumou LV 5 @evler 最后由 编辑
                      @evler 在执行../sunxi-tools/sunxi-fel uboot u-boot-sunxi-with-spl.bin的时候串口就没有反应,fel也没有提示
                      这时候开发板上没有启动介质
                      • E
                        @fumoumou 那就不清楚了,你检查下流程,试下我对应的uboot版本,还有开发板不要装TF卡,我这没装SPI Flash的,串口用PH0跟PH1脚。
                        • B
                          baimin LV 2 最后由 编辑
                          platform = sun50i-h616应该是sun50i_h616,下划线。
                          • mangogeek
                            mangogeek LV 8 最后由 编辑
                            厉害厉害,我还停留在5.16,你这都linux6.0了👍
                              SyntaxSugar LV 2 最后由 编辑
                              跟着题主的步骤试了一下,但是遇到了一点问题
                              用的 gcc 版本是 12.2.0
                              bintuils 版本是 2.39
                              第一个是 bintuils 2.39 版本加了个新特性,会出现 LOAD segment with RWX permissions 的警告,这个会导致 ATF 和 Uboot 都编译失败。
                              要成功编译,必须修改 Makefile
                              对于 ATF:
                              # LD = gcc-ld (ld) or llvm-ld (ld.lld) or other
                              TF_LDFLAGS		+=	--fatal-warnings -O1
                              TF_LDFLAGS		+=	--gc-sections
                              在底下加一条:
                              TF_LDFLAGS		+=	--no-warn-rwx-segments
                              对于 UBoot
                              KBUILD_LDFLAGS  := $(call ld-option, --no-warn-rwx-segments) \
                              		   $(call ld-option, --no-warn-execstack)
                              修改后还有几条 EFI_loader 相关的 LOAD segment with RWX permissions 警告,但是已经可以编译出来了。
                              但是通过 sunxi-fel 启动 uboot 会卡在 Trying to boot from FEL,并且报错 usb_bulk_send() ERROR -7: Operation timed out
                              $: sudo ../sunxi-tools/sunxi-fel uboot u-boot-sunxi-with-spl.bin
                              串口输出如下
                              U-Boot SPL 2022.10-00409-g2afa989fbe-dirty (Oct 07 2022 - 23:37:55 +0800)
                              pmic id is 0x4b
                              DRAM: 1024 MiB
                              然后就卡住了
                              包括使用群里别人编译的 u-boot,也是类似的结果
                              U-Boot SPL 2021.10-armbian (Sep 29 2022 - 17:22:28 +0800)
                              pmic id is 0x4b
                              DRAM: 1024 MiB
                              关于 usb_bulk_send() ERROR -7
                              有说重新编译 sunxi-tools 的,有说要接个 usb2.0 hub 的,有说降级 sunxi-tools 到 1.41版本的。前两个试了没用,最后一个 H616 太新了肯定不能降
                              • E
                                Evlers LV 6 @mangogeek 最后由 编辑
                                @mangogeek 芒果大佬过奖了,您编译的 debian 能开源吗,想白嫖驱动 哈哈哈哈😊
                                • E
                                  Evlers LV 6 @baimin 最后由 编辑
                                  @baimin 是的 上面是我写错了
                                  • mangogeek
                                    mangogeek LV 8 @evler 最后由 编辑
                                    @evler 这两天开源
                                    • Moved from Linux by  YuzukiTsuru YuzukiTsuru
                                    • F
                                      @evler 在 MQ-Quad H616 主线内核编译调试记录(u-boot、kernel、buildroot) 中说:
                                      266002
                                      大佬求助,编译模块报错了
                                        fumoumou@fumoumou-TM1801:~/Desktop/H616/stable/linux$ make INSTALL_MOD_PATH=/mnt/rootfs/ modules modules_install
                                        CALL    scripts/checksyscalls.sh
                                        CALL    scripts/atomic/check-atomics.sh
                                        CHK     include/generated/compile.h
                                        CC [M]  drivers/net/wireless/realtek/rtl8723ds/os_dep/linux/ioctl_cfg80211.o
                                      drivers/net/wireless/realtek/rtl8723ds/os_dep/linux/ioctl_cfg80211.c:6840:13: error: initialization of ‘int (*)(struct wiphy *, struct net_device *)’ from incompatible pointer type ‘int (*)(struct wiphy *, struct net_device *, unsigned int)’ [-Werror=incompatible-pointer-types]
                                       6840 |  .stop_ap = cfg80211_rtw_stop_ap,
                                      drivers/net/wireless/realtek/rtl8723ds/os_dep/linux/ioctl_cfg80211.c:6840:13: note: (near initialization for ‘rtw_cfg80211_ops.stop_ap’)
                                      drivers/net/wireless/realtek/rtl8723ds/os_dep/linux/ioctl_cfg80211.c: In function ‘rtw_wdev_unregister’:
                                      drivers/net/wireless/realtek/rtl8723ds/os_dep/linux/ioctl_cfg80211.c:7071:12: error: ‘struct wireless_dev’ has no member named ‘connected’; did you mean ‘connect_keys’?
                                       7071 |  if (wdev->connected) {
                                            |            connect_keys
                                      cc1: some warnings being treated as errors
                                      make[5]: *** [scripts/Makefile.build:249: drivers/net/wireless/realtek/rtl8723ds/os_dep/linux/ioctl_cfg80211.o] Error 1
                                      make[4]: *** [scripts/Makefile.build:466: drivers/net/wireless/realtek/rtl8723ds] Error 2
                                      make[3]: *** [scripts/Makefile.build:466: drivers/net/wireless/realtek] Error 2
                                      make[2]: *** [scripts/Makefile.build:466: drivers/net/wireless] Error 2
                                      make[1]: *** [scripts/Makefile.build:466: drivers/net] Error 2
                                      make: *** [Makefile:1842: drivers] Error 2
                                      Y A 3 条回复 最后回复 回复 引用 分享 0
                                        YiXinTai LV 5 @fumoumou 最后由 编辑
                                        @fumoumou 在 MQ-Quad H616 主线内核编译调试记录(u-boot、kernel、buildroot) 中说:
                                        wireless_dev
                                        看看板子上是否用的是这个wifi模块,如果不是在内核选项里面把它去掉不编译即可。
                                          MacLodge LV 3 最后由 编辑
                                          真大佬,膜拜~
                                          请教一下,要是从emmc启动,也是可以一样的操作吗?
                                          • B
                                            BigfootACA LV 2 最后由 编辑
                                            大佬折腾uboot的时候有遇到过DRAM: This DRAM setup is currently not supported.报错吗?
                                            U-Boot SPL 2023.01-rc4-00059-g8d6cbf5e6b-dirty (Jan 06 2023 - 06:24:08 +0800)
                                            DRAM:testing 32-bit width, rank = 2
                                            write leveling failed!
                                            testing 32-bit width, rank = 1
                                            testing 16-bit width, rank = 2
                                            read training failed!
                                            testing 16-bit width, rank = 1
                                            resetting ...
                                              mczor LV 4 @evler 最后由 编辑
                                              • radxiaohe
                                                radxiaohe LV 5 最后由 编辑
                                                向大神学习👍 👍
                                                  ymy0820 LV 2 最后由 编辑
                                                  make u-boot的时候报错了
                                                  aarch64-linux-gnu-ld.bfd: board/sunxi/board.o: in function sunxi_board_init': /home/c/桌面/h616/u-boot/board/sunxi/board.c:612: undefined reference to axp_set_dcdc4'
                                                  make[1]: *** [scripts/Makefile.spl:527:spl/u-boot-spl] 错误 1
                                                  make: *** [Makefile:2043:spl/u-boot-spl] 错误 2
                                                  大神咋整勒
                                                  • E
                                                    Evlers LV 6 @ymy0820 最后由 编辑
                                                    @ymy0820 将axp_set_dcdc4函数内的程序注释掉并return 0;不是注释掉函数
                                                      aromate LV 1 最后由 编辑
                                                      此处有错误, 实测应该是这个:
                                                      make CROSS_COMPILE=aarch64-none-elf- PLAT=sun50i_h616 DEBUG= bl31
                                                      解释:
                                                      三元组不对,目标平台none,生成格式elf,固件没有目标平台(linux)
                                                      • CWEIB
                                                        CWEIB LV 4 @evler 最后由 CWEIB 编辑
                                                        U-Boot SPL 2023.07-rc3-dirty (May 31 2023 - 22:33:38 +0800)
                                                        DRAM: 1024 MiB
                                                        NOTICE:  BL31: v2.9(debug):v2.9.0-51-gc0d8ee386
                                                        NOTICE:  BL31: Built : 12:13:51, May 30 2023
                                                        NOTICE:  BL31: Found U-Boot DTB at 0x4a097120, model: OrangePi Zero2
                                                        INFO:    SPSR = 0x3c9
                                                        U-Boot 2023.07-rc3-dirty (May 31 2023 - 22:33:38 +0800) Allwinner Technology
                                                        DRAM:  1 GiB
                                                        Core:  48 devices, 18 uclasses, devicetree: separate
                                                        MMC:   mmc@4020000: 0
                                                        Loading Environment from FAT... Card did not respond to voltage select! : -110
                                                        In:    serial@5000000
                                                        Out:   serial@5000000
                                                        Err:   serial@5000000
                                                        Net:   Could not get PHY for ethernet@5020000: addr 1
                                                        No ethernet found.
                                                        => d device specification mmc 0 **
                                                        Unknown command 'd' - try 'help'
                                                        Unknown command 'd' - try 'help'        0> ɥ▒▒▒▒▒
                                                        > Err::▒с▒▒*▒▒K▒Y▒hernet@5020000: addr 1
                                                        > No ethernet found.
                                                        > ▒▒Z▒偢▒▒▒ѽ▒
                                                        > ▒ѽ▒▒▒▒C▒=> d device specification mmc 0 **▒▒▒
                                                        >>> Err::▒с▒▒*▒▒K▒Y▒hernet@5020000: addr 1>> Unknown command 'd' - try 'help>> =>>> Unknown command 'd' - try 'help>> => ▒▒ɥ▒        >> Err::▒с▒▒*▒▒K▒Y▒hernet@5020000: addr 1>> No ethernet found>>>> ▒▒Z▒偢                               >> Unknown command 'd' - try 'help>> =>>> Unknown command 'd' - try 'help>> => ▒▒ɥ▒        >> Err::▒с▒▒*▒▒K▒Y▒hernet@5020000: addr 1>> No ethernet found>>>> ▒▒Z▒偢▒▒▒ѽ▒> ▒ѽ▒▒▒▒                                            >> Unknown command 'd' - try 'help>> =>>> Unknown command 'd' - try 'help>> => ▒▒ɥ▒        >> Err::▒с▒▒*▒▒K▒Y▒hernet@5020000: addr 1>> No ethernet found>>>> ▒▒Z▒偢▒▒▒ѽ▒> ▒ѽ▒▒▒▒                                            >> Unknown command 'd' - try 'help>> =>>> Unknown command 'd' - try 'help>> => ▒▒ɥ▒        >> Err::▒с▒▒*▒▒K▒Y▒hernet@5020000: addr 1>> No ethernet found>>>> ▒▒Z▒偢▒▒▒ѽ▒> ▒ѽ▒▒▒▒                                            >> Unknown command 'd' - try 'help>> =>>> Unknown command 'd' - try 'help>> => ▒▒ɥ▒        >>>
                                                        E 1 条回复 最后回复 回复 引用 分享 1
                                                        • E
                                                          Evlers LV 6 @CWEIB 最后由 编辑
                                                          @cweib 你这是接触不良吧.. 换个USB或者换个串口以及杜邦线试下
                                                          CWEIB 2 条回复 最后回复 回复 引用 分享 1
                                                          • CWEIB
                                                            CWEIB LV 4 @evler 最后由 编辑
                                                            @evler 我试试,但是用其他的镜像运行都挺正常的,然后好像Loading Environment from FAT... Card did not respond to voltage select! : -110这行和你的输出日志有点对不上
                                                            • CWEIB
                                                              @evler 确实是串口问题😧
                                                              • K
        kevin_allwinner LV 5 最后由 编辑
        • K
        我的开发板是orangepi_zero2 wifi是aw859a的
        搞定了,感谢博主!
        K 1 条回复 最后回复 回复 引用 分享 1
        • K
        有朋友接着这个帖子弄主线linux HDMI的吗?谢谢
        • K
        king.zhao LV 2 @kevin_allwinner 最后由 编辑
        @kevin_allwinner 哥们请问下,你的aw859a的wifi驱动在哪里能找到?能否分享一下,谢谢
        awwwwa LV 8 @king.zhao 最后由 编辑
        @king-zhao aw859a 的 WIFI 驱动可以在 OrangePi 官方仓库里找到
        K X 3 条回复 最后回复 回复 引用 分享 0
        • K
        king.zhao LV 2 @awwwwa 最后由 编辑
        @awwwwa 谢谢,已经到官方仓库找到了对应wifi驱动,正尝试移植中。
        anglersking LV 2 @evler 最后由 编辑
        @evler 里面支持apt 工具吗,要是想移植ubuntu或者debain 还要怎么做,是不是跟文件系统换成Ubuntu就行了
        • X
        xiaobai LV 2 @awwwwa 最后由 编辑
        • X
        @awwwwa 请问是 drivers/net/wireless/uwe5622 这个驱动吗,它好像和aw859a是一个东西
        • E
        Evlers LV 6 @anglersking 最后由 编辑
        @anglersking 可以参考armbian
        @evler uboot 还有linux内核都不用换,改跟文件系统就行对吧
        anglersking LV 2 最后由 编辑
        anglersking LV 2 @fumoumou 最后由 编辑
        @fumoumou 这个问题我解决了,把 change static int cfg80211_rtw_stop_ap(struct wiphy *wiphy, struct net_device *ndev, unsigned int link_id) 改成 static int cfg80211_rtw_stop_ap(struct wiphy *wiphy, struct net_device *ndev) in /linux/drivers/net/wireless/realtek/rtl8723ds/os_dep/linux/ioctl_cfg80211.c 还有 wdev->connected改成 connect_keys再编译就过了
        @fumoumou 把static int cfg80211_rtw_stop_ap(struct wiphy *wiphy, struct net_device *ndev, unsigned int link_id)改为 static int cfg80211_rtw_stop_ap(struct wiphy *wiphy, struct net_device *ndev) 还有 (wdev->connected 改为 wdev->connect_keys再编译就过了
        • G
        gerryqd LV 2 最后由 编辑
        我用最新的版本进行验证。
        1. atf 编译没问题。
        2. uboot 中做的修改如下,
        a. axp313 的驱动已经包含在uboot,禁止掉原来的axp305, 使用 axp313.
        b. 将axp313 的输出做如下调整,
        DCDC2 调整为1200, DCDC3 调整为 1500
        编译下载后打印如下内容就没任何输出了,
        U-Boot SPL 2024.07-rc2-00388-g676903c1b9 (May 17 2024 - 22:20:11 +0800)
        DRAM: 2048 MiB
        疑问: 好像 DRAM 的大小就没识别正确? 应该是 1024 MiB .
        各位有什么建议吗?
