    一个补丁,让D1-H的SDK支持T113芯片
    25
    50
    56739
      wxid_disxysjskla LV 5 最后由 YuzukiTsuru 编辑
      补丁的地址:https://github.com/YuzukiHD/TinaAddons
      1. 在全新下载好的 Tina Linux SDK 的根目录内下拉仓库(一定要全新的SDK)
        git clone https://github.com/YuzukiHD/TinaAddons.git
      2. 导出补丁文件
        cp -rf TinaAddons/* .
      3. 打上补丁
        chmod 777 apply_patch.sh
        ./apply_patch.sh
      4. 完工,开始编译
      whycan C J Z L 6 条回复 最后回复 回复 引用 分享 19
        whycan晕哥 LV 9 @wxid_disxysjskla 最后由 编辑
        @wxid_disxysjskla
        谢谢楼主,开始表演.
        1 条回复 最后回复 回复 引用 分享 5
          @wxid_disxysjskla
          whycan@ubuntu:/opt/D1/tina_d1_open_v2_debug6$ clear
          whycan@ubuntu:/opt/D1/tina_d1_open_v2_debug6$ cp ../TinaAddons/0001-add-t113-platform-to-d1-h-sdk.patch .
          whycan@ubuntu:/opt/D1/tina_d1_open_v2_debug6$ cp ../TinaAddons/apply_patch.sh .
          whycan@ubuntu:/opt/D1/tina_d1_open_v2_debug6$ chmod +x apply_patch.sh
          whycan@ubuntu:/opt/D1/tina_d1_open_v2_debug6$ ./apply_patch.sh
          Prepare Environment... **!!!ROOT Require!!!**
          Reading package lists... Done
          Building dependency tree
          Reading state information... Done
          build-essential is already the newest version (12.4ubuntu1).
          bzr is already the newest version (2.7.0+bzr6622-10).
          flex is already the newest version (2.6.4-6).
          gawk is already the newest version (1:4.1.4+dfsg-1build1).
          libxml-parser-perl is already the newest version (2.44-2build3).
          cvs is already the newest version (2:1.12.13+real-26).
          quilt is already the newest version (0.63-8.2).
          git is already the newest version (1:2.17.1-1ubuntu0.12).
          lib32ncurses5 is already the newest version (6.1-1ubuntu1.18.04).
          lib32ncurses5 set to manually installed.
          lib32stdc++6 is already the newest version (8.4.0-1ubuntu1~18.04).
          lib32z1 is already the newest version (1:1.2.11.dfsg-0ubuntu2.2).
          lib32z1-dev is already the newest version (1:1.2.11.dfsg-0ubuntu2.2).
          libncurses5-dev is already the newest version (6.1-1ubuntu1.18.04).
          libssl-dev is already the newest version (1.1.1-1ubuntu2.1~18.04.20).
          libstdc++6 is already the newest version (8.4.0-1ubuntu1~18.04).
          unzip is already the newest version (6.0-21ubuntu1.1).
          xsltproc is already the newest version (1.1.29-5ubuntu0.3).
          zlib1g-dev is already the newest version (1:1.2.11.dfsg-0ubuntu2.2).
          libc6:i386 is already the newest version (2.27-3ubuntu1.6).
          libstdc++6:i386 is already the newest version (8.4.0-1ubuntu1~18.04).
          ecj is already the newest version (3.16.0-1~18.04).
          mercurial is already the newest version (4.5.3-1ubuntu2.2).
          subversion is already the newest version (1.9.7-4ubuntu1.1).
          You might want to run 'apt --fix-broken install' to correct these.
          The following packages have unmet dependencies:
           whoopsie : Depends: libwhoopsie0 (= 0.2.62ubuntu0.5) but 0.2.62ubuntu0.6 is to be installed
          E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
          Apply T113 Patch...
          0001-add-t113-platform-to-d1-h-sdk.patch:43672: trailing whitespace.
          0001-add-t113-platform-to-d1-h-sdk.patch:43727: trailing whitespace.
          0001-add-t113-platform-to-d1-h-sdk.patch:44036: trailing whitespace.
              sb_detect_type = <0x1>;
          0001-add-t113-platform-to-d1-h-sdk.patch:44261: trailing whitespace.
          0001-add-t113-platform-to-d1-h-sdk.patch:44285: trailing whitespace.
          error: device/config/chips/t113/bin/boot0_nand_sun8iw20p1.bin: already exists in working directory
          error: device/config/chips/t113/bin/boot0_sdcard_sun8iw20p1.bin: already exists in working directory
          error: device/config/chips/t113/bin/boot0_spinor_sun8iw20p1.bin: already exists in working directory
          error: device/config/chips/t113/bin/dsp0.bin: already exists in working directory
          error: device/config/chips/t113/bin/fes1_sun8iw20p1.bin: already exists in working directory
          error: device/config/chips/t113/bin/optee_sun8iw20p1.bin: already exists in working directory
          error: device/config/chips/t113/bin/sboot_sun8iw20p1.bin: already exists in working directory
          error: device/config/chips/t113/bin/u-boot-spinor-sun8iw20p1.bin: already exists in working directory
          error: device/config/chips/t113/bin/u-boot-sun8iw20p1.bin: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource.ini: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bat/bat0.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bat/bat1.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bat/bat10.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bat/bat2.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bat/bat3.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bat/bat4.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bat/bat5.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bat/bat6.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bat/bat7.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bat/bat8.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bat/bat9.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bat/battery.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bat/battery_charge.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bat/bempty.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bat/low_pwr.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/bootlogo.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/fastbootlogo.bmp: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/font24.sft: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/font32.sft: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/wavefile/default.awf: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/wavefile/default_5_8.awf: already exists in working directory
          error: device/config/chips/t113/boot-resource/boot-resource/wavefile/vcom.bin: already exists in working directory
          error: device/config/chips/t113/configs/default/BoardConfig.mk: already exists in working directory
          error: device/config/chips/t113/configs/default/BoardConfig_nor.mk: already exists in working directory
          error: device/config/chips/t113/configs/default/boot_package.cfg: already exists in working directory
          error: device/config/chips/t113/configs/default/boot_package_nor.cfg: already exists in working directory
          error: device/config/chips/t113/configs/default/default.awlic: already exists in working directory
          error: device/config/chips/t113/configs/default/diskfs.fex: already exists in working directory
          error: device/config/chips/t113/configs/default/dragon_toc.cfg: already exists in working directory
          error: device/config/chips/t113/configs/default/env.cfg: already exists in working directory
          error: device/config/chips/t113/configs/default/env_burn.cfg: already exists in working directory
          error: device/config/chips/t113/configs/default/env_dragon.cfg: already exists in working directory
          error: device/config/chips/t113/configs/default/fit-image.its: already exists in working directory
          error: device/config/chips/t113/configs/default/image.cfg: already exists in working directory
          error: device/config/chips/t113/configs/default/image_linux.cfg: already exists in working directory
          error: device/config/chips/t113/configs/default/image_nor.cfg: already exists in working directory
          error: device/config/chips/t113/configs/default/parameter.fex: already exists in working directory
          error: device/config/chips/t113/configs/default/sys_partition.fex: already exists in working directory
          error: device/config/chips/t113/configs/default/sys_partition_nor.fex: already exists in working directory
          error: device/config/chips/t113/configs/default/sysrecovery.fex: already exists in working directory
          error: device/config/chips/t113/configs/default/version_base.mk: already exists in working directory
          error: device/config/chips/t113/configs/nezha/BoardConfig.mk: already exists in working directory
          error: device/config/chips/t113/configs/nezha/board.dts: already exists in working directory
          error: device/config/chips/t113/configs/nezha/env.cfg: already exists in working directory
          error: device/config/chips/t113/configs/nezha/linux: already exists in working directory
          error: device/config/chips/t113/configs/nezha/linux-5.4/board.dts: already exists in working directory
          error: device/config/chips/t113/configs/nezha/linux-5.4/config-5.4: already exists in working directory
          error: device/config/chips/t113/configs/nezha/linux-5.4/config-5.4-bak: already exists in working directory
          error: device/config/chips/t113/configs/nezha/linux-5.4/config-5.4-mem-optimize: already exists in working directory
          error: device/config/chips/t113/configs/nezha/sys_config.fex: already exists in working directory
          error: device/config/chips/t113/configs/nezha/sys_partition.fex: already exists in working directory
          error: device/config/chips/t113/configs/nezha/uboot-board.dts: already exists in working directory
          error: device/config/chips/t113/tools/cardscript.fex: already exists in working directory
          error: lichee/brandy-2.0/spl/board/sun20iw1p1/sboot.mk: already exists in working directory
          error: lichee/brandy-2.0/spl/board/sun8iw20p1/Makefile: already exists in working directory
          error: lichee/brandy-2.0/spl/board/sun8iw20p1/board.c: already exists in working directory
          error: lichee/brandy-2.0/spl/board/sun8iw20p1/clock.c: already exists in working directory
          error: lichee/brandy-2.0/spl/board/sun8iw20p1/common.mk: already exists in working directory
          error: lichee/brandy-2.0/spl/board/sun8iw20p1/fes.mk: already exists in working directory
          error: lichee/brandy-2.0/spl/board/sun8iw20p1/mmc.mk: already exists in working directory
          error: lichee/brandy-2.0/spl/board/sun8iw20p1/nand.mk: already exists in working directory
          error: lichee/brandy-2.0/spl/board/sun8iw20p1/sboot.mk: already exists in working directory
          error: lichee/brandy-2.0/spl/board/sun8iw20p1/spinor.mk: already exists in working directory
          error: patch failed: lichee/brandy-2.0/spl/drivers/Makefile:44
          error: lichee/brandy-2.0/spl/drivers/Makefile: patch does not apply
          error: lichee/brandy-2.0/spl/drivers/dram/sun20iw1p1/libchipid: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/dram/sun8iw20p1/Makefile: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/dram/sun8iw20p1/libchipid: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/mmc/sun8iw20p1/Makefile: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/mmc/sun8iw20p1/mmc.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/mmc/sun8iw20p1/mmc.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/mmc/sun8iw20p1/mmc_bsp.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/mmc/sun8iw20p1/mmc_bsp.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/mmc/sun8iw20p1/mmc_def.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/Makefile: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand/adv_NF_read.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand/basic_nf_read.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/Makefile: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nand_common.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nand_for_boot0/bsp_nand.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nand_for_boot0/nand_for_boot0.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nand_for_boot0/nand_for_boot0.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nand_for_boot0/osal/nand_osal_boot0.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nfc_for_boot0/include/nand_drv_cfg.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nfc_for_boot0/include/nand_format.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nfc_for_boot0/include/nand_logic.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nfc_for_boot0/include/nand_physic.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nfc_for_boot0/include/nand_scan.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nfc_for_boot0/include/nand_simple.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nfc_for_boot0/include/nand_type.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nfc_for_boot0/include/nfc.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nfc_for_boot0/src/nand_scan_for_boot.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nfc_for_boot0/src/nand_simple_for_boot0.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/nfc_for_boot0/src/nfc_for_boot0.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_bsp/osal/nand_osal.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/nand_for_boot.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/spinand/spic.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/spinand/spic_op.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/spinand/spinand.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/spinand/spinand.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/spinand/spinand_basic_op.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/spinand/spinand_osal_boot0.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/nand/sun8iw20p1/spinand/spinand_osal_boot0.h: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/secure/Makefile: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/secure/ce.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/secure/ce_2.1.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/secure/ce_2.3.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/secure/efuse.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/secure/smc.c: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/secure/spc.c: already exists in working directory
          error: lichee/brandy-2.0/spl/include/arch/clock_sun8iw20.h: already exists in working directory
          error: lichee/brandy-2.0/spl/include/arch/efuse_sun8iw20.h: already exists in working directory
          error: lichee/brandy-2.0/spl/include/arch/sun8iw20p1/spinand_boot0.h: already exists in working directory
          error: lichee/brandy-2.0/spl/include/configs/sun8iw20p1.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/Makefile: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/main/Makefile: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/main/sboot_ceritf.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/main/sboot_ceritf.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/main/sboot_flash.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/main/sboot_flash.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/main/sboot_head.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/main/sboot_main.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/main/sboot_toc.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/main/sboot_toc1.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/CRYPTO_malloc.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/Makefile: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/ASN1_INTEGER_get.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/ASN1_STRING_print.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/EVP_pkey.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/RSAPublicKey_it.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/X509_PUBKEY_it.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/a_int.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/asn1_get_field_ptr.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/asn1_item_ex_new.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/asn1_lock_free.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/asn1_new_free.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/asn1_put_object.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/asn1_string.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/d2i_pu.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/d2i_rsapublikey.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/i2a_ASN1_INTEGER.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/i2d_pu.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/stk.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/tasn_enc.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/x509_extension_it.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/x_bignum.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/asn1/x_x509.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/bio/b_print.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/bio/bio.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/bio/bio_free.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/bio/bio_lib.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/bio/bio_read.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/bio/bio_s_mem.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/bio/bss_mem.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/bn/bn_asm.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/bn/bn_bn2dec.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/bn/bn_lib.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/bn/bn_print.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/bn/bn_shift.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/bn/bn_word.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/err/err.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/external/openssl_ext.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/asn1.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/asn1_locl.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/asn1_mac.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/asn1t.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/bio.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/bio_lcl.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/bn.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/bn_lcl.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/buffer.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/conf.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/cryptlib.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/crypto.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/e_os2.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/ec.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/eng_int.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/engine.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/err.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/evp.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/evp_locl.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/ext_dat.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/lhash.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/myfunction.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/obj_dat.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/obj_mac.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/objects.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/opensslconf.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/opensslv.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/ossl_typ.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/pem.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/pkcs7.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/rand.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/rsa.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/safestack.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/sha.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/stack.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/store.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/symhacks.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/ui.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/x509.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/x509_ext.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/x509_v3.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/x509_vfy.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/include/openssl/x509v3.h: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/lhash/lh_retrieve.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/objects/obj_dat.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/rsa/rsa.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/x509/extension.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/x509/x509_ext.c: already exists in working directory
          error: lichee/brandy-2.0/spl/sboot/openssl/x509/x509_v3.c: already exists in working directory
          error: lichee/brandy-2.0/u-boot-2018/arch/arm/dts/sun8iw20p1-clk.dtsi: already exists in working directory
          error: lichee/brandy-2.0/u-boot-2018/arch/arm/dts/sun8iw20p1-common-board.dts: already exists in working directory
          error: lichee/brandy-2.0/u-boot-2018/arch/arm/dts/sun8iw20p1-soc-system.dts: already exists in working directory
          error: lichee/brandy-2.0/u-boot-2018/configs/sun8iw20p1_defconfig: already exists in working directory
          error: lichee/brandy-2.0/u-boot-2018/configs/sun8iw20p1_nor_defconfig: already exists in working directory
          error: lichee/brandy-2.0/u-boot-2018/configs/sun8iw20p1_uart3_defconfig: already exists in working directory
          error: patch failed: lichee/brandy-2.0/u-boot-2018/drivers/clk/sunxi/Makefile:1
          error: lichee/brandy-2.0/u-boot-2018/drivers/clk/sunxi/Makefile: patch does not apply
          error: lichee/brandy-2.0/u-boot-2018/drivers/clk/sunxi/clk-sun8iw20.c: already exists in working directory
          error: lichee/brandy-2.0/u-boot-2018/drivers/clk/sunxi/clk-sun8iw20.h: already exists in working directory
          error: lichee/brandy-2.0/u-boot-2018/drivers/clk/sunxi/clk-sun8iw20_tbl.c: already exists in working directory
          error: lichee/linux-5.4/arch/arm/boot/dts/sun8iw20p1.dtsi: already exists in working directory
          error: package/allwinner/alsa-conf-aw/files/t113/t113-nezha/asound.conf: already exists in working directory
          error: target/allwinner/t113-common/BoardConfigCommon.mk: already exists in working directory
          error: target/allwinner/t113-common/base-files/etc/config/smartlinkd: already exists in working directory
          error: target/allwinner/t113-common/base-files/etc/fw_env.config: already exists in working directory
          error: target/allwinner/t113-common/base-files/etc/inittab: already exists in working directory
          error: target/allwinner/t113-common/modules.mk: already exists in working directory
          error: target/allwinner/t113-common/t113-common.mk: already exists in working directory
          error: target/allwinner/t113-nezha/BoardConfig.mk: already exists in working directory
          error: target/allwinner/t113-nezha/Makefile: already exists in working directory
          error: target/allwinner/t113-nezha/TinaProducts.mk: already exists in working directory
          error: target/allwinner/t113-nezha/base-files/etc/bluetooth/bluetooth.json: already exists in working directory
          error: target/allwinner/t113-nezha/base-files/etc/bluetooth/bt_init.sh: already exists in working directory
          error: target/allwinner/t113-nezha/base-files/etc/config/fstab: already exists in working directory
          error: target/allwinner/t113-nezha/base-files/etc/rc.local: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/bin/setusbconfig: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/asound.conf: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/init.d/S00mpp: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/init.d/S01logging: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/init.d/S10udev: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/init.d/S11dev: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/init.d/S20urandom: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/init.d/S40network: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/init.d/S41netparam: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/init.d/S50telnet: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/init.d/S50usb: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/init.d/load_script.conf: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/init.d/rc.final: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/init.d/rc.modules: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/init.d/rc.preboot: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/init.d/rcK: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/inittab: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/profile: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/swupdate_public.pem: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/udhcpd.conf: already exists in working directory
          error: target/allwinner/t113-nezha/busybox-init-base-files/etc/wpa_supplicant.conf: already exists in working directory
          error: target/allwinner/t113-nezha/defconfig: already exists in working directory
          error: target/allwinner/t113-nezha/modules.mk: already exists in working directory
          error: target/allwinner/t113-nezha/t113_nezha.mk: already exists in working directory
          error: target/allwinner/t113-nezha/vendorsetup.sh: already exists in working directory
          error: lichee/brandy-2.0/spl/drivers/dram/sun8iw20p1/libdram: already exists in working directory
          Fix Patch Error...
          Add Toolchains...
          --2022-09-02 17:15:23--  https://github.com/YuzukiHD/TinaAddons/releases/download/1.0/arm-toolchains.tar.gz
          Resolving github.com (github.com)... 140.82.114.4, 13.250.177.223
          Connecting to github.com (github.com)|140.82.114.4|:443... connected.
          HTTP request sent, awaiting response... 302 Found
          Location: https://objects.githubusercontent.com/github-production-release-asset-2e65be/531362264/4838a138-8165-46cc-aba3-c3bebf096ea2?X-Amz-                                                     Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20220902%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20220902T091445Z&X-Am                                                     z-Expires=300&X-Amz-Signature=7f75a1254a58507cde730ad567a10050809db15fecda14ce3b4403706d325a85&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&                                                     repo_id=531362264&response-content-disposition=attachment%3B%20filename%3Darm-toolchains.tar.gz&response-content-type=application%2Foctet-st                                                     ream [following]
          --2022-09-02 17:15:24--  https://objects.githubusercontent.com/github-production-release-asset-2e65be/531362264/4838a138-8165-46cc-aba3-c3be                                                     bf096ea2?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20220902%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=202209                                                     02T091445Z&X-Amz-Expires=300&X-Amz-Signature=7f75a1254a58507cde730ad567a10050809db15fecda14ce3b4403706d325a85&X-Amz-SignedHeaders=host&actor                                                     _id=0&key_id=0&repo_id=531362264&response-content-disposition=attachment%3B%20filename%3Darm-toolchains.tar.gz&response-content-type=applica                                                     tion%2Foctet-stream
          Resolving objects.githubusercontent.com (objects.githubusercontent.com)... 185.199.110.133, 185.199.108.133, 185.199.111.133
          Connecting to objects.githubusercontent.com (objects.githubusercontent.com)|185.199.110.133|:443... connected.
          HTTP request sent, awaiting response... 200 OK
          Length: 104821076 (100M) [application/octet-stream]
          Saving to: ‘arm-toolchains.tar.gz’
          arm-toolchains.tar.gz                            100%[=======================================================================================================>]  99.96M  1.91MB/s    in 52s
          2022-09-02 17:16:21 (1.93 MB/s) - ‘arm-toolchains.tar.gz’ saved [104821076/104821076]
          Done, Start Your Tina Linux
          好像没成功,这是什么原因呢?
          W 1 条回复 最后回复 回复 引用 分享 4
            wxid_disxysjskla LV 5 @whycan 最后由 编辑
            @whycan 打上了就别再打一次了
            1 条回复 最后回复 回复 引用 分享 3
              @wxid_disxysjskla
              谢谢大佬,搞定了,烧录固件: tina_t113-nezha_uart3.img
              启动日志:
              [29]HELLO! BOOT0 is starting!
              [32]BOOT0 commit : 88480af-dirty
              [35]set pll start
              [41]periph0 has been enabled
              [44]set pll end
              [45][pmu]: bus read error
              [48]board init ok
              [50]ZQ value = 0x30
              [51]get_pmu_exist() = -1
              [54]DRAM BOOT DRIVE INFO: V0.33
              [57]DRAM CLK = 936 MHz
              [59]DRAM Type = 3 (2:DDR2,3:DDR3)
              [62]DRAMC read ODT  off.
              [65]DRAM ODT value: 0x42.
              [67]ddr_efuse_type: 0xa
              [70]DRAM SIZE =128 M
              [72]dram_tpr4:0x0
              [74]PLL_DDR_CTRL_REG:0xf8004d00
              [77]DRAM_CLK_REG:0xc0000000
              [80][TIMING DEBUG] MR2= 0x20
              [87]DRAM simple test OK.
              [89]rtc standby flag is 0x0, super standby flag is 0x0
              [94]dram size =128
              [97]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
              [102]block from 8 to 32
              [189]Check is correct.
              [192]dma 0x29c0c int is not used yet
              [195]dma 0x29c0c int is free, you do not need to free it again
              [201]Entry_name        = u-boot
              [206]Entry_name        = optee
              [210]Entry_name        = dtb
              [213]Jump to second Boot.
              U-Boot 2018.05-g24521d6-dirty (Sep 02 2022 - 17:24:25 +0800) Allwinner Technology
              [00.267]CPU:   Allwinner Family
              [00.270]Model: sun8iw20
              ready
              [00.291]DRAM:  128 MiB
              [00.294]Relocation Offset is: 04f01000
              [00.313]secure enable bit: 0
              [00.316]smc_tee_inform_fdt failed with: -65526[00.321]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
              [00.327]gic: sec monitor mode
              [00.330]flash init start
              [00.332]workmode = 0,storage type = 0
              [BCC] 0x4025038 = 0x20000000, [DMA] 0x4025088 = 0x000000e5
              [00.379]sunxi-spinand-phy: not detect any munufacture from id table
              [00.385]sunxi-spinand-phy: get spi-nand Model from fdt fail
              [00.390]sunxi-spinand-phy: get phy info from fdt fail
              defaults:
              mtdids  : nand0=nand
              [00.507]ubi0: attaching mtd4
              [00.613]ubi0: scanning is finished
              [00.619]ubi0: attached mtd4 (name "sys", size 123 MiB)
              [00.624]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
              [00.630]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
              [00.636]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
              [00.642]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
              [00.648]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
              [00.654]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
              [00.662]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
              [00.671]sunxi flash init ok
              [00.772]Loading Environment from SUNXI_FLASH... OK
              [00.794]Item0 (Map) magic is bad
              [00.799]secure storage read widevine fail with:-1
              [00.807]secure storage read ec_key fail with:-1
              [00.814]secure storage read ec_cert1 fail with:-1
              [00.821]secure storage read ec_cert2 fail with:-1
              [00.829]secure storage read ec_cert3 fail with:-1
              [00.836]secure storage read rsa_key fail with:-1
              [00.844]secure storage read rsa_cert1 fail with:-1
              [00.851]secure storage read rsa_cert2 fail with:-1
              [00.859]secure storage read rsa_cert3 fail with:-1
              [00.863]out of usb burn from boot: not need burn key
              [00.879]update bootcmd
              [00.892]change working_fdt 0x43ec0e70 to 0x43ea0e70
              [00.910]update dts
              [02.125]no vendor_boot partition is found
              Android's image name: t113-nezha
              [02.136]Starting kernel ...
              [    0.000000] Linux version 5.4.61 (whycan@ubuntu) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #1 SMP PREEMPT Fri Sep 2 11:33:35 UTC 2022
              [    0.000000] cma: Reserved 8 MiB at 0x47800000
              [    0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/pseudo_init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:private@ubi0_6:rootfs_data@ubi0_7:UDISK@ubi0_8: cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-g24521d6-dirty(09/02/2022-17:24:25) aw-ubi-spinand.ubootblks=24 androidboot.dramsize=128
              [    0.000000] Memory: 109636K/131072K available (6144K kernel code, 264K rwdata, 1504K rodata, 1024K init, 1164K bss, 13244K reserved, 8192K cma-reserved)
              [    0.008007] Switching to timer-based delay loop, resolution 41ns
              [    0.014174] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
              [    0.023882] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
              [    0.034229] pid_max: default: 32768 minimum: 301
              [    0.038953] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
              [    0.046269] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
              [    0.054572] CPU: Testing write buffer coherency: ok
              [    0.059768] /cpus/cpu@0 missing clock-frequency property
              [    0.065101] /cpus/cpu@1 missing clock-frequency property
              [    0.070447] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
              [    0.076602] Setting up static identity map for 0x40100000 - 0x40100060
              [    0.083263] rcu: Hierarchical SRCU implementation.
              [    0.088462] smp: Bringing up secondary CPUs ...
              [    0.094088] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
              [    0.094207] smp: Brought up 1 node, 2 CPUs
              [    0.104010] SMP: Total of 2 processors activated (96.00 BogoMIPS).
              [    0.110197] CPU: All CPU(s) started in SVC mode.
              [    0.115272] devtmpfs: initialized
              [    0.129520] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
              [    0.137629] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
              [    0.147502] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
              [    0.154715] pinctrl core: initialized pinctrl subsystem
              [    0.160876] NET: Registered protocol family 16
              [    0.166756] DMA: preallocated 256 KiB pool for atomic coherent allocations
              [    0.202442] rtc_ccu: sunxi ccu init OK
              [    0.208397] ccu: sunxi ccu init OK
              [    0.212122] r_ccu: sunxi ccu init OK
              [    0.236385] iommu: Default domain type: Translated
              [    0.241451] sunxi iommu: irq = 24
              [    0.245629] SCSI subsystem initialized
              [    0.249591] usbcore: registered new interface driver usbfs
              [    0.255179] usbcore: registered new interface driver hub
              [    0.260576] usbcore: registered new device driver usb
              [    0.266648] Advanced Linux Sound Architecture Driver Initialized.
              [    0.273272] Bluetooth: Core ver 2.22
              [    0.276928] NET: Registered protocol family 31
              [    0.281383] Bluetooth: HCI device and connection manager initialized
              [    0.287757] Bluetooth: HCI socket layer initialized
              [    0.292637] Bluetooth: L2CAP socket layer initialized
              [    0.297703] Bluetooth: SCO socket layer initialized
              [    0.302835] pwm module init!
              [    0.306891] g2d 5410000.g2d: Adding to iommu group 0
              [    0.312149] G2D: rcq version initialized.major:252
              [    0.317741] clocksource: Switched to clocksource arch_sys_counter
              [    0.332240] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
              [    0.341503] NET: Registered protocol family 2
              [    0.346419] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
              [    0.354851] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
              [    0.362548] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
              [    0.369617] TCP: Hash tables configured (established 1024 bind 1024)
              [    0.376071] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
              [    0.382631] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
              [    0.389806] NET: Registered protocol family 1
              [    0.395124] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
              [    0.405427] spi spi0: spi0 supply spi not found, using dummy regulator
              [    0.412141] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
              [    0.418306] sunxi_spi_resource_get()2189 - Failed to get sample mode
              [    0.424650] sunxi_spi_resource_get()2194 - Failed to get sample delay
              [    0.431096] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
              [    0.439493] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
              [    0.445702] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c881f000, irq 40
              [    0.455305] workingset: timestamp_bits=30 max_order=15 bucket_order=0
              [    0.465871] squashfs: version 4.0 (2009/01/31) Phillip Lougher
              [    0.471897] ntfs: driver 2.1.32 [Flags: R/W].
              [    0.504254] io scheduler mq-deadline registered
              [    0.508808] io scheduler kyber registered
              [    0.514035] [DISP]disp_module_init
              [    0.517940] disp 5000000.disp: Adding to iommu group 0
              [    0.523591] [DISP] parser_disp_init_para,line:1430:
              [    0.523593] of_property_read fb0_width fail
              [    0.549060] display_fb_request,fb_id:0
              [    0.555893] [DISP] Fb_copy_boot_fb,line:1443:
              [    0.555897] no boot_fb0
              [    0.563158] disp_al_manager_apply ouput_type:0
              [    0.567983] [DISP] lcd_clk_config,line:732:
              [    0.567995] disp 0, clk: pll(420000000),clk(420000000),dclk(70000000) dsi_rate(70000000)
              [    0.567995]      clk real:pll(420000000),clk(420000000),dclk(105000000) dsi_rate(150000000)
              [    0.568061] [DISP]disp_module_init finish
              [    0.593661] sunxi_sid_init()551 - insmod ok
              [    0.598788] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
              [    0.608954] uart uart3: get regulator failed
              [    0.613247] uart uart3: uart3 supply uart not found, using dummy regulator
              [    0.620393] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
              [    0.628264] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
              000▒>000▒000▒▒0▒▒▒>00▒▒▒00>0▒0>>▒▒>0▒0000000▒0>>▒▒>000▒0000000▒0>>▒▒>0▒▒▒>0▒▒▒▒▒▒>0▒0>▒>▒▒0▒▒>▒▒>▒▒0▒▒▒▒0>▒▒0▒▒▒▒>▒>▒▒0▒▒▒▒▒▒>▒▒>0▒>0>▒▒▒▒▒▒▒▒>▒>▒▒▒>▒▒▒▒>▒>0>>▒▒>▒>▒▒▒>>>▒>>>>▒>▒▒>▒>▒▒▒>▒>▒>0>▒▒▒▒▒▒▒>>>▒>>▒▒>▒>>0>▒00000▒>▒>0▒0>0▒▒0▒▒0>▒▒▒▒▒00▒▒>▒>>▒>▒>▒▒0>▒▒▒▒▒0▒▒0▒▒0>▒>▒▒▒▒>0>▒▒▒▒▒▒▒▒>▒▒▒>>▒>▒▒▒▒>▒>0>>▒▒>▒>▒▒▒0>>▒>▒▒>▒>>▒>>>>▒>▒▒>▒>▒▒▒>>▒>>>▒>>▒>▒▒▒▒▒▒>0>▒>>▒>>▒▒>▒>>0>▒00000▒>0▒0▒0▒0▒0▒▒0▒▒0>▒▒▒▒▒00▒▒>▒>▒▒▒▒▒>▒>>▒>▒>▒▒0>▒▒▒>▒▒▒>▒>0▒▒0▒▒0▒▒▒▒>▒▒▒▒>0>▒▒▒▒▒▒▒▒>▒▒>▒▒▒>▒▒▒▒>>>>▒>▒▒▒>▒>>>>▒0>>▒>▒>▒>>▒▒>>0>▒▒▒▒▒▒▒▒>▒▒>>▒0▒▒>▒▒▒>>▒>>▒>▒▒>▒▒▒▒>0>>>>▒>▒>>▒0▒▒▒▒▒▒▒▒>0>>>>▒>▒>>0▒▒0▒▒▒▒▒▒▒▒>0>>>>▒>▒>>▒>>▒>>>>>▒▒▒>▒>▒>>▒>▒>▒▒>▒>▒▒>▒▒▒>>▒▒>>▒▒>▒▒▒>▒>0>>▒▒>▒▒▒>▒>>>>>▒>▒0>>▒>▒>>>▒>>0>>0>▒▒▒▒▒▒▒▒>▒>▒>▒▒>>▒▒▒▒>>▒>>>0>>▒0>▒>▒>0>>▒>▒>>>>>>▒▒▒▒▒▒▒▒0▒0>▒>▒>0>>▒>>▒0▒▒▒>▒>▒▒>▒>>▒▒>▒▒▒>>▒>▒>0>>▒>0▒▒▒▒>▒▒▒▒▒▒▒0>▒▒▒▒▒▒▒▒>▒>▒▒>▒▒>▒▒▒>>▒>>>0>>▒0>▒>▒>0>>▒>▒>>>>>>▒▒▒▒▒▒▒▒0▒0>▒>▒>0>>▒>>▒0▒▒▒▒>>▒>▒▒▒>>0>>▒>>>>>▒▒▒>>▒▒▒>>0>>▒▒>▒>>0>▒▒▒▒▒▒▒▒>▒>▒▒>▒▒>▒▒▒>>▒>>>0>>▒0>▒>▒>0>>▒>▒>>>>>>▒▒▒▒▒▒▒▒0▒0>▒>▒>0>>▒>>▒0▒▒▒▒>>▒>▒▒▒>>0>>▒>>▒▒>>▒>▒▒▒>>▒▒▒>>0>>▒▒>▒>>0>▒▒▒▒▒▒▒▒>▒▒>▒▒0▒▒▒▒>>▒>>>0>>▒0>▒>▒>0>>▒>▒>>>>>>▒▒▒▒▒▒▒▒0▒0>▒>▒>0>>▒>>▒0▒▒▒▒>>>>▒▒0>▒>▒>>▒▒>>>▒▒▒0>▒▒▒▒▒▒▒▒▒0▒▒>▒>▒▒▒▒>>▒>>>0>>▒0>▒>▒>0>>▒>▒>>>>>>▒▒▒▒▒▒▒▒0▒0>▒>▒>0>>▒>>▒0▒▒▒0>>>▒>0>>▒▒>▒▒▒>>>>▒▒~>▒▒>>▒>▒0>▒▒▒▒▒▒▒▒0▒▒▒>▒>>▒▒▒▒>>▒>>>0>>▒0>▒>▒>0>>▒>▒>>>>>>▒▒▒▒▒▒▒▒0▒0>▒>▒>0>>▒>>▒0▒▒▒▒>>>>▒>>>▒>>>▒>>>▒▒▒▒>▒0▒>>▒▒▒>>>▒>▒▒>▒>▒▒▒0>▒▒▒▒▒▒▒▒▒>▒▒>▒▒>▒▒▒>>▒>>>0>>▒0>▒>▒>0>>▒>▒>>>>>>▒▒▒▒▒▒▒▒0▒0>▒>▒>0>>▒>>▒0▒▒▒▒>>>>▒▒0>>▒>>▒>▒▒▒>>0>>▒▒0▒▒▒>▒>▒>▒>>▒>▒>▒▒▒▒0>▒▒▒▒▒▒▒▒▒>▒>▒▒>▒▒▒▒>>▒>>>0>>▒0>▒>▒>0>>▒>▒>>>>>>▒▒▒▒▒▒▒▒0▒0>▒>▒>0>>▒>>▒0▒▒▒▒>>>>▒▒>▒>>>▒>▒>>▒>>▒▒▒>>0>>▒▒0▒▒0▒▒>▒>▒>>▒>▒>▒▒▒▒0>▒▒▒▒▒▒▒▒▒▒>▒>▒▒▒▒▒>>▒>>>0>>▒0>▒>▒>0>>▒>▒>>>>>>▒▒▒▒▒▒▒▒0▒0>▒>▒>0>>▒>>▒0▒▒▒▒>>▒>>▒>>▒>>>▒▒>▒>▒>>▒>>>▒▒▒>>>▒>>▒▒>▒>>0>▒▒▒▒▒▒▒▒▒▒>▒>▒▒▒▒▒>>▒>>>0>>▒0>▒>▒>0>>▒>▒>>>>>>▒▒▒▒▒▒▒▒0▒0>▒>▒>0>>▒>>▒0▒▒▒0>>>▒>0>>▒▒>▒0>▒>▒>>▒▒>>▒>▒0>▒▒▒▒▒▒▒▒0▒▒▒>▒>0▒▒▒▒>>▒>>>0>>▒0>▒>▒>0>>▒>▒>>>>>>▒▒▒▒▒▒▒▒0▒0>▒>▒>0>>▒>>▒0▒▒0>▒>▒>>>▒>>>▒>>>▒▒▒▒>▒0▒>>▒▒▒>>>▒>▒▒>▒>▒▒▒0>▒▒▒▒▒▒▒▒>▒▒▒▒>▒▒▒▒>>▒>>>0>>▒0>▒>▒>0>>▒>▒>>>>>>▒▒▒▒▒▒▒▒0▒0>▒>▒>0>>▒>>▒0▒▒0>▒>▒0>▒>▒>▒▒▒>>0>>▒▒▒▒>▒▒>▒>▒>>▒>▒>▒▒▒▒0>▒▒▒▒▒▒▒▒▒>▒>▒▒▒>▒▒▒>▒▒▒>0>0>▒▒▒▒▒▒>0>▒>>▒▒▒>>▒>0>▒>>▒>▒>▒>>▒>>▒▒>▒>▒>>▒▒>▒▒▒>>>▒~>▒▒~▒>>▒>▒▒>▒▒0▒>▒>▒0▒▒0>▒▒▒▒▒▒▒▒▒>▒>▒0▒▒▒▒▒>▒>▒>>▒>>▒▒>▒>▒▒>>>▒▒▒>▒▒>▒>▒▒▒▒▒▒▒▒▒>>▒>▒▒0>▒▒▒▒▒▒▒▒▒>▒>▒▒>▒>▒▒▒>>▒>>▒>▒▒>▒▒▒▒>0>>>>▒>▒>>▒0▒▒▒▒▒▒▒▒>0>>>>▒>▒>>0▒▒0▒▒▒▒▒▒▒▒>0>>>>▒>▒>>▒>>▒>>>>>▒▒▒>▒>▒>>▒>>▒▒>▒>▒▒>▒▒▒>>▒▒>>▒▒>▒▒▒>▒>0>>▒▒>▒▒▒>▒>>>>>▒>▒0>>▒>▒>>>▒>>0>>0>▒▒▒▒▒▒▒▒▒>0▒▒▒▒>▒▒▒>▒▒▒>0>0>▒▒▒▒▒▒>0>▒>>▒▒▒>>▒>0>▒>>▒>▒>▒>>▒>>▒▒>▒>▒>>▒▒>▒▒▒>>>▒>>▒▒>▒>>▒>▒▒>▒▒0▒>▒▒>0▒▒0>▒▒▒▒▒▒▒▒▒>0▒▒0▒▒>▒▒▒▒▒>▒>>>▒▒▒▒▒>▒>▒▒>>▒▒▒▒▒▒>>>▒>▒▒0>▒>▒>0>0>▒>▒>▒▒▒0>0>▒>▒>▒▒>>▒▒>▒>▒▒▒>▒>>▒>▒▒▒▒▒▒>▒>0>▒>▒▒>>>0>▒▒0▒▒▒0>>>▒▒>>▒▒0▒▒>>▒>>>0▒▒▒0>>▒>0>>0▒▒▒0>▒▒▒▒▒▒▒▒▒0▒▒>>▒▒>▒▒▒>▒>▒>▒>0>▒▒0▒▒>▒>▒▒▒>▒>▒>▒>▒▒>▒▒>▒>▒>▒>>0>>▒▒▒▒>▒>▒▒>▒>>▒▒>▒▒▒>>▒>▒>0>>▒>0▒▒▒▒>▒▒▒▒▒▒▒▒0>▒▒▒▒▒▒▒▒▒>0▒▒>>▒▒▒▒▒>▒>▒>▒>0>▒▒0▒▒>▒>▒▒▒>▒>▒>▒>▒▒>▒▒>▒>▒>▒>>0>>▒▒▒>>▒>▒>▒>>▒>▒>▒0>▒▒▒▒▒▒▒▒▒>▒>0▒▒>▒▒▒▒▒▒>>>>>▒0>▒>▒>▒▒▒0▒▒▒>>▒>>▒>▒▒>▒>>>>>▒▒>▒>▒>>▒▒>▒>▒>>0>▒▒▒▒▒▒▒▒▒▒>▒>▒▒>▒▒▒▒▒>>>>>▒0>▒>▒>▒▒▒0▒▒▒>>▒>>▒>▒▒>▒▒▒>>>>▒▒▒>>>>>>>0>▒▒▒▒▒▒▒▒▒▒>▒▒>▒>▒▒▒>>0>▒>>>▒▒>▒▒>>>>▒▒▒>>>>>>0▒▒▒▒>▒▒0>▒▒▒▒▒▒▒▒▒▒>▒▒>▒▒▒▒▒▒>>>>>▒0>▒>▒>▒▒▒0▒▒▒>>▒>>▒>▒▒>▒▒▒>>>>▒▒▒>>>>>>>>>>>▒▒>▒>▒>>▒▒>▒>▒>>0>▒▒▒▒▒▒▒▒▒▒>▒>▒▒▒▒▒▒▒>>>>>▒0>▒>▒>▒▒▒0▒▒▒>>▒>>▒>▒▒>▒▒▒>>>>▒▒▒>>>>>>▒▒>>▒>▒>▒>>0>▒>>>>>▒>▒▒>>0>▒▒▒▒▒▒▒▒>▒▒▒>▒>▒▒▒▒▒▒>>>>>▒0>▒>▒>▒▒▒0▒▒▒>>▒>>▒>▒▒>▒▒▒>>>>▒▒▒>>>>>>▒▒>>▒>▒>▒>▒>▒>▒>>>>▒>0>>▒>▒>>0>▒▒▒▒▒▒▒▒▒>▒>▒0▒▒>▒▒▒▒▒>>>>>▒0>▒>▒>▒▒▒0▒▒▒>>▒>>▒>▒▒>▒▒▒>>>>▒▒▒>>>>>>▒▒>>▒>▒>▒▒>>▒>>▒>▒>▒>▒>>>>▒>0>>▒>▒>>0>▒▒▒▒▒▒▒▒▒>▒>▒▒>▒>▒▒▒▒▒>>>>>▒0>▒>▒>▒▒▒0▒▒▒>>▒>>▒>▒▒>▒▒▒>>>>▒▒▒>>>>>>▒▒>>▒>▒>▒0>>>▒>>>>▒>0>>▒>▒>>0>▒▒▒▒▒▒▒▒▒>▒>▒>▒▒▒▒▒▒▒>>>>>▒0>▒>▒>▒▒▒0▒▒▒>>▒>>▒>▒▒>▒▒▒>>>>▒▒▒>>>>>>▒▒>>▒>▒>▒▒>>▒>>▒0>>>▒>>>>▒>0>>▒>▒>>0>▒▒▒▒▒▒▒▒▒▒▒▒▒>▒▒▒▒▒>>>>>▒0>▒>▒>▒▒▒0▒▒▒>>▒>>▒>▒▒>▒▒▒>>>>▒▒▒>>>>>>▒▒>>▒>▒>▒>>▒>>▒>▒>▒>>0>▒▒▒▒▒▒▒0▒▒>▒▒>▒>▒▒▒▒▒▒>>>>>▒0>▒>▒>▒▒▒0▒▒▒>>▒>>▒>▒▒>▒▒▒>>>>▒▒▒>>>>>>▒▒>>▒>▒>▒▒▒>▒>▒>>0>>0>▒▒▒▒▒▒▒0▒▒▒>▒>▒>▒>▒▒▒▒▒>>>>>▒0>▒>▒>▒▒▒0▒▒▒>>▒>>▒>▒▒>▒▒▒>>>>▒▒▒>>>>>>▒▒>>▒>▒>▒▒▒>>0>▒>>0>▒▒▒▒▒▒▒0▒0▒▒▒0▒▒>▒▒▒▒▒>>>>>▒0>▒>▒>▒▒▒0▒▒▒>>▒>>▒>▒▒>▒▒▒>>>>▒▒▒>>>>>>▒▒>>▒>▒>▒▒▒>>0>▒>▒▒▒>0>>>>>▒▒>▒>>0>▒▒▒▒▒▒▒0▒▒>▒>▒>▒>>▒▒▒▒▒▒>>>>>▒0>▒>▒>▒▒▒0▒▒▒>>▒>>▒>▒▒>▒▒▒>>>>▒▒▒>>>>>>▒▒>>▒>▒>▒>>▒>▒>▒>>0>▒▒▒▒▒▒▒0▒▒▒0▒>▒▒▒▒▒▒▒>>>>>▒0>▒>▒>▒▒▒0▒▒▒>>▒>>▒>▒▒>▒▒▒>>>>▒▒▒>>>>>>0>>▒>>▒>>0>▒>>>>▒▒>>>>▒>0>>▒>▒>>0>▒▒▒▒▒▒▒>▒▒>▒>▒>▒>▒▒▒▒▒▒>>0>>>▒>▒>>0>▒>>>>▒▒>>>>▒>0>>▒>▒>>>▒▒▒▒>>>▒>>>▒▒>▒>>▒>▒>▒>▒▒>▒>▒>▒>>▒>▒>>▒>▒▒0▒▒▒>>>>▒>>▒>>0>▒▒▒▒▒▒▒>▒▒▒>▒>▒>▒>▒▒▒▒▒>>0>>>▒>▒>>0>▒>>>>▒▒>>>>▒>0>>▒>▒>>>▒▒▒▒▒>>>▒>>>▒▒>▒>>▒>▒>▒>▒▒>>▒▒>▒>>▒>▒>>▒>▒▒>▒>▒▒>>>>▒>>▒>>0>▒▒▒▒▒▒▒▒>▒>▒>▒>▒>▒>▒▒▒▒▒>>0>>>▒>▒>>0>▒>>>>▒▒>>>>▒>0>>▒>▒>>>▒▒▒▒>~>▒>>>▒▒>▒>>▒>▒>▒▒▒>▒>▒▒>>▒>▒>>▒>▒>▒▒▒>▒>▒▒▒>>>>▒>>▒>>0>▒▒▒▒▒▒▒▒>▒▒>>▒▒>>▒▒▒▒▒▒>>0>>>▒>▒>>0>▒>>>>▒▒>>>>▒>0>>▒>▒>>>▒▒▒▒▒>>>▒>>>▒▒>▒>>▒>▒>▒▒▒>▒>▒▒>>▒>▒>>▒>▒>▒▒▒>▒>▒▒▒>>>>▒>>▒>>0>▒▒▒▒▒▒▒▒>▒▒>▒>▒>▒▒▒▒>~▒~>>0>>▒>>>0>>>>▒▒>▒▒▒>▒>▒>▒▒0▒0>>▒▒>▒▒0▒▒>▒>▒▒0>▒>>▒>▒▒▒>>▒>▒>0>>▒>0▒▒0▒▒▒▒0▒▒0▒▒▒0▒0▒▒▒0>▒▒▒▒▒▒▒▒>0▒0▒▒▒▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒>▒>▒>▒▒0▒0>>▒▒>▒▒>>▒▒0>▒>>▒>▒▒▒>>▒>▒>0>>▒>0▒▒▒▒▒▒▒0▒▒0▒▒▒>▒▒▒>▒0>▒▒▒▒▒▒▒▒>▒>▒▒>▒▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒>▒>▒▒>▒▒▒>>▒>>▒>▒>▒>>>▒▒>▒▒>>▒▒>▒>>▒>▒>▒>▒>>▒▒▒>▒>>▒>▒>▒▒>▒▒▒>>▒>>▒▒>>0>▒▒▒▒▒▒▒▒>▒>▒▒>▒>▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒>>▒>▒>>>0>>▒▒>>>▒▒>▒▒0▒>▒▒>>>▒▒▒>▒>>▒>▒▒▒>▒>▒>▒▒▒>>0>>▒0>▒▒▒▒▒▒▒▒>▒>▒>▒>▒>0▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒>>▒>▒>>>▒>▒>▒▒>>▒▒▒>▒>>▒>▒▒▒>▒>▒>▒▒▒>>0>>▒0>▒▒▒▒▒▒▒▒>▒▒▒>▒▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒>▒>▒▒>▒▒▒>>▒>>▒>▒>▒▒>▒▒>>▒▒>▒>>▒>▒>▒>▒>>▒▒▒>▒>>▒>▒▒▒>▒>▒>>0>▒▒▒▒▒▒▒▒>▒▒>▒>▒▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒>>▒>>▒>▒>▒▒>▒▒>>▒▒>▒>>▒>▒>▒>▒>>▒▒▒>▒>>▒>▒>▒▒>▒▒▒>>▒>>▒▒>▒▒▒▒▒>0>>0>>▒>▒▒>>0>▒▒▒▒▒▒▒▒>0▒▒>▒▒>▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒>>▒>>▒>▒>▒>>>0>>>>▒▒>▒>▒▒>▒▒▒▒▒>▒>▒▒▒>>>▒>▒▒▒>▒>▒>▒>▒>▒>▒>▒>>0>▒▒▒▒▒▒▒▒>▒>▒▒▒▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒>▒>▒>>▒>▒>▒▒>>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒0>▒▒▒▒▒▒▒▒>▒>▒>▒▒>▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒0▒>▒▒>>>0▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒>▒▒▒>▒0▒▒▒▒>▒>>>>0>▒>>0>▒▒▒▒▒▒▒▒>▒>>▒▒▒>▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒0▒▒>>▒▒>▒>>▒>▒>▒>▒>>▒▒▒▒▒▒▒▒▒▒▒▒▒>0>>0>>▒>▒▒>>0>▒▒▒▒▒▒▒▒>▒▒▒▒▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒>0>>>>▒▒>▒▒▒>▒>>>>>▒▒▒▒▒▒▒▒▒▒▒0>▒▒▒▒▒▒▒▒>▒▒▒>▒>▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒0>>>>>>>▒▒>▒▒▒>▒>▒>0>>▒▒▒▒▒▒▒▒▒▒▒▒0▒▒>▒0>▒▒▒▒▒▒▒▒>▒▒>▒▒▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒>▒>>>>▒▒>▒▒▒>▒>>>>>0▒▒▒▒▒▒▒▒▒>▒>▒0>▒▒▒▒▒▒▒▒>0▒▒▒▒>▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒>▒▒▒>▒>▒>>>▒▒>▒▒▒>▒>▒>▒>>▒▒▒▒▒▒▒▒▒>▒0>▒▒▒▒▒▒▒▒>▒>>▒▒>▒▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒0▒>0>0>0>▒>>▒▒▒>▒>▒>▒>>▒▒▒▒▒▒▒▒▒>▒>▒0>▒▒▒▒▒▒▒▒>▒>▒>▒>▒▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒0>>▒>>>▒>>>▒>▒>>>▒>▒▒▒▒▒▒▒▒▒▒▒>▒▒0>▒▒▒▒▒▒▒▒>▒>▒▒>▒▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒0>>▒>>▒>0>>▒>▒0>▒>▒▒▒▒▒▒▒▒▒▒▒>>▒0>▒▒▒▒▒▒▒▒>▒▒>▒>▒▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒0>>>▒>>▒>>▒>0>>>>▒>▒▒▒▒▒▒▒▒▒▒>▒>▒▒▒▒0>▒▒▒▒▒▒▒▒▒▒0▒▒▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒>▒>▒>▒>>>▒>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒>▒▒0>▒▒▒▒▒▒▒▒▒▒>>▒▒▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒>▒>▒>▒>▒>>>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒0▒▒0>▒▒▒▒▒▒▒▒0▒▒▒0▒▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒>▒>▒>▒0>>▒▒>>▒>▒>>▒>▒>▒>>>▒▒▒▒▒▒>▒▒0>▒▒▒▒▒▒▒▒▒>▒▒>▒>▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒0>▒▒▒▒▒▒▒▒▒>▒▒>▒▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒0>▒▒▒▒▒▒▒▒▒>▒>▒▒▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒>>>▒>0>▒>>>▒>▒>▒▒>>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒0>▒▒▒▒▒▒▒▒▒▒>▒>▒▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒>>▒▒>>>>▒>0>>▒▒▒▒▒▒▒0▒▒▒▒0▒0>▒▒▒▒▒▒▒▒▒▒>▒>>▒▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒>▒▒▒>▒>▒>>0>0>0>▒>>▒▒▒▒▒▒>▒0▒▒0>>0>▒▒▒▒▒▒▒▒▒▒▒>▒>▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒>▒>>0>0>▒>>▒▒▒▒▒▒▒0▒▒>0▒0>▒▒▒▒▒▒▒▒0▒>▒▒0▒▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒0>>▒>>>▒>0>0>▒>>▒▒▒▒▒▒▒0▒▒▒>0▒0>▒▒▒▒▒▒▒▒>▒▒>▒▒>▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒0▒00>0>0>▒>>▒▒▒▒▒▒▒▒▒>▒>▒0>>0>▒▒▒▒▒▒▒▒▒>▒▒>▒>▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒0>▒▒▒▒▒▒▒▒▒>▒>▒>▒▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒0>▒▒▒▒▒▒▒▒▒>▒>▒▒0▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒>▒>▒▒>0>▒>>>▒>▒>▒▒>>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒0>▒▒▒▒▒▒▒▒▒▒▒>>▒▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒>>▒▒>>>>▒>0>>▒▒▒▒▒▒▒0▒▒▒▒0▒0>▒▒▒▒▒0▒▒▒▒▒>>▒▒>▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒>▒▒▒>▒>▒>>0>0>0>▒>>▒▒▒▒▒▒>▒0▒▒0>>0>▒▒▒▒▒0▒▒▒▒▒>>▒0▒0▒▒▒▒>>▒>>>0>>▒>~~0>>>>▒▒>>▒>>>▒▒▒▒>▒>>0>0>▒>>▒▒▒▒▒▒▒▒>▒>0▒0>▒▒▒▒▒0▒▒▒0▒▒▒>▒0▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒0>>▒>>>▒>0>0>▒>>▒▒▒▒▒▒0▒▒>▒>▒>0▒0>▒▒▒▒▒0▒▒▒▒>0▒▒>0▒▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒0▒00>0>0>▒>>▒▒▒▒▒▒▒▒▒0▒▒▒0>>0>▒▒▒▒▒0▒▒▒▒>▒>▒>▒>▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒0>▒▒▒▒▒0▒▒▒▒>>▒▒>▒▒>▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒0>>▒>>>▒>▒▒>▒>>>▒>▒0>>▒>0>▒>▒>>▒>▒▒▒▒>▒▒▒0>▒▒▒▒▒0▒▒▒▒▒▒▒>▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒▒▒>>>▒>▒>▒>>▒0>>▒>0>▒>▒>>▒>▒▒▒▒>▒▒▒▒0>▒▒▒▒▒0▒▒▒▒▒▒>▒>▒▒▒▒>>▒>>>0>>▒>>>0>>>>▒▒>>▒>>>▒▒▒>>▒>>>0>▒>>>▒>0>▒>▒▒>>>▒▒>▒>▒>>▒▒>▒▒▒>>▒▒>>0>▒▒▒▒▒0▒▒▒▒▒>▒>▒>▒>▒▒▒>>▒>>>▒>0>>▒▒>▒▒>▒▒0▒▒>▒>▒>>▒>▒>0>▒>0>>▒>>>▒▒>▒>▒0▒>>▒>>>0>▒▒>▒▒>▒>▒▒>>>▒▒>▒▒0▒▒0>▒▒▒▒▒0▒▒▒>▒▒▒>>▒▒>▒▒▒▒>▒▒▒▒▒▒▒▒▒▒▒▒▒▒>▒▒▒▒▒▒▒▒▒▒▒▒▒0▒▒0▒0>>▒>▒▒>▒0▒▒0>▒▒▒▒▒0▒▒▒▒>▒▒>▒>▒>▒▒▒▒>▒▒▒▒▒▒▒▒▒▒▒▒▒▒>▒▒▒▒▒▒▒>▒▒▒▒▒▒0▒▒0▒▒▒>▒>>▒>▒▒>▒▒▒0>▒▒▒▒▒0▒▒▒▒>▒>▒>▒0▒▒▒▒0>>>▒▒>>▒>0▒▒▒▒>>▒>▒>▒>▒>>▒▒>▒▒▒>>▒>▒▒>>0>▒▒▒▒▒0▒▒▒▒>▒▒>▒>▒>▒▒▒▒>▒▒▒▒▒▒▒>▒▒▒▒▒▒▒>▒▒▒▒▒▒▒>▒▒▒▒▒▒0▒▒0▒>>>▒>▒>▒>>▒>>▒>>0>>▒>>▒▒▒0>▒▒▒▒▒0▒▒0▒▒▒▒>▒▒>▒▒▒▒>▒▒▒▒▒▒▒>▒▒▒▒▒▒▒>▒▒▒▒▒▒▒▒▒▒▒▒▒0▒▒0▒>>▒>▒>▒▒▒0>▒▒▒▒▒0▒▒▒>▒>▒▒▒>▒>▒▒▒▒>>0>>>>▒▒▒▒▒>0>>>▒>▒▒0▒▒>0>0▒0>▒>▒>▒▒▒>▒>>0>>▒>>0>▒▒▒▒▒0▒▒▒>▒>▒▒▒▒>▒▒▒>>▒>>>0>▒▒▒>>>>▒>▒▒▒>▒>0>▒>>▒>0>>▒▒▒>>▒>▒>0>>▒>0▒▒▒▒▒▒▒▒0>▒▒▒▒▒0▒▒▒>▒>▒▒▒▒>▒▒▒▒▒>>>>▒>>▒>>▒▒>>▒>▒0▒▒▒0▒▒>0▒0▒0>▒▒▒▒▒0▒▒▒>▒▒▒▒▒▒▒▒▒▒>>>>▒>>▒>>▒▒>>▒>▒▒0▒▒▒0▒▒>0▒0▒0>▒▒▒▒▒0▒▒▒>▒▒▒0▒▒▒▒▒▒▒>>>>▒>>▒>>▒▒>>▒>▒▒0▒▒▒0▒▒>0▒0▒0>▒▒▒▒▒0▒▒▒>▒▒0▒▒▒>▒▒▒▒▒>>0>>▒▒>▒>▒▒▒>>▒>>▒>▒>>>▒▒>▒▒>▒▒▒0>▒▒▒▒▒0▒▒▒>▒▒>▒>▒▒▒▒▒▒▒>▒>>▒0▒▒▒▒>▒>>▒0>>>▒▒~>▒>▒▒>>▒>▒>▒>▒>▒>>▒>▒>>0>▒▒▒▒▒0▒▒▒>0▒▒>▒>▒>▒>▒▒▒▒▒>>>>0>▒>>>▒>▒▒▒▒▒>0>>▒0▒▒▒▒▒0▒▒>>>>>>>>▒>0▒0▒>>>▒>▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒>0>>0>0▒▒▒▒>▒>0>▒>>▒>>0>▒▒▒▒▒0▒▒▒>▒>▒>0▒▒▒>▒▒▒>>▒>>>0>>▒▒▒>>>>0>▒▒▒▒▒>0>>0>▒>▒▒▒>0▒0▒▒▒>▒>0>▒>>▒>>0>▒▒▒▒▒0▒▒▒>▒>▒>▒>▒▒▒▒▒▒▒>>▒>▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒>>▒>>▒>>>▒>>>▒▒>▒>▒>>▒>>>▒▒▒>>0>>▒▒0>▒▒▒▒▒0▒▒▒>▒>▒▒>▒>▒▒▒▒>>▒>>>0>▒▒▒>>>~0~▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒>>▒>▒0▒▒>▒>▒>>▒▒>▒▒▒>>▒>>▒>>▒>>>▒▒>▒>▒>>>0>▒▒▒▒▒0▒▒▒>▒▒>▒>▒>▒▒▒▒>▒>>▒>>>0>>▒▒▒>>>>0>▒▒▒▒0▒▒>▒>>0>>▒>▒>>▒>>▒▒▒▒>>>>>▒▒▒▒>0▒▒▒▒▒▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒>>▒>>>0>▒▒▒>>>>0>▒▒▒▒>▒>▒0>▒▒▒▒>>0>▒▒▒▒>▒▒>>▒▒>▒▒>▒▒▒▒▒>0>▒>▒▒>▒>0▒>▒>>>0>▒▒▒▒▒0▒▒▒>▒▒>▒>▒▒>▒▒▒>>▒>>>0>>▒▒▒>>>>0>▒▒>0▒▒▒▒▒▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒▒>0▒▒▒▒▒▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒>>▒>>>>>▒▒▒>▒>▒>▒>▒>▒>▒>▒▒>▒>▒▒>▒▒▒>>▒▒>>▒▒>▒▒▒>▒>0>>▒▒>▒▒▒>▒>>>>>▒>▒0>>▒>▒>>>▒>>0>>0>▒▒▒▒▒0▒▒▒>▒>▒>▒>0▒▒>▒▒▒>>▒>>>0>>▒▒▒>>>>0>▒▒>0▒▒▒▒▒▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒▒>0▒▒▒▒▒▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒>>▒>>>>>▒>>>0>▒▒>▒>▒▒>▒▒▒>>▒▒>>▒▒>▒▒▒>▒>0>>▒▒>▒▒▒>▒>>>>>▒>▒0>>▒>▒>>>▒>>0>>0>▒▒▒▒▒0▒▒▒>▒>>▒▒>▒▒>▒▒▒>>▒>>>0>>▒▒▒>>>>0>▒▒>0▒▒▒▒▒▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒▒▒>0>>0>▒0▒>>>▒>▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>>0>▒▒▒▒▒0▒▒▒>▒▒▒▒>▒▒▒▒>>▒>>>0>>▒▒▒>>>>0>▒▒>0▒▒▒▒▒▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒▒>▒▒>▒>▒▒▒>0>>▒0>▒>▒>▒0>>▒>0>▒>▒>>▒>>▒>▒>▒>▒>0>▒~>▒▒~▒>▒0>▒>▒>▒▒>▒▒>>>▒>>▒>▒▒▒0>▒▒▒▒▒0▒▒▒>▒▒>▒>▒>>▒▒▒▒>>▒>>>0>>▒▒▒>>>>0>▒▒>0▒▒▒▒▒▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒>0>▒>▒▒>▒▒▒>▒>▒▒>▒▒>>>▒▒>▒▒>0▒▒▒▒▒▒▒0>▒▒▒▒▒0▒▒▒>▒>▒>▒>▒>>▒▒▒▒>>▒>>>0>>▒▒▒>>>>0>▒▒>0▒▒▒▒▒▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒▒▒>0>>▒0▒▒▒▒>>▒>>▒>▒>>▒>▒▒▒>0>>0>▒▒▒▒▒▒0>▒▒▒▒▒0▒▒▒>▒▒>>▒▒>▒>▒▒▒>▒▒>▒>▒▒▒▒0▒▒▒▒0▒▒▒▒>0>>▒>▒▒>▒>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒0▒▒▒>▒▒>▒>▒>▒▒▒▒>▒▒>▒>▒▒▒▒0▒▒▒▒0▒▒▒▒>>0>▒>▒▒▒>>▒>>▒>▒>>▒>>0>▒▒▒▒▒0▒▒▒▒▒▒>▒▒▒▒▒▒>>>>0>▒>>>▒>▒▒▒▒▒>0>>▒▒▒▒▒▒0▒0>>>▒0▒0▒>>>▒>▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒00>>0>0▒▒▒▒>▒>0>▒>>▒>>0>▒▒▒▒▒0▒▒▒0▒▒>▒>>▒▒>▒▒▒>>▒>>>0>>▒▒>>>>0>▒▒▒▒00>>0>▒>▒▒▒>0▒0▒▒▒>▒>0>▒>>▒>>0>▒▒▒▒▒0▒▒▒>▒▒>▒>▒>▒▒▒▒▒▒>>▒>▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒>>▒>>▒>>>▒>>>▒▒>▒>▒>>▒>>>▒▒▒>>0>>▒▒0>▒▒▒▒▒0▒▒▒▒>▒▒▒>▒>▒▒▒>>▒>>>0>▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒>>▒>▒0▒▒>▒>▒>>▒▒>▒▒▒>>▒>>▒>>▒>>>▒▒>▒>▒>>>0>▒▒▒▒▒0▒▒▒▒>▒>▒>▒▒>▒▒▒>▒>>▒>>>0>>▒▒>>>>0>▒▒▒▒0▒▒>▒>>0>>▒>▒>>▒>>▒▒▒▒>~>~>▒▒▒▒>0▒▒▒▒>▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒~▒>>▒>▒>▒▒>▒>▒>>▒>>>0>▒▒>>>>0>▒▒▒▒~▒>▒0>▒▒▒▒>>▒>▒▒0>▒▒▒▒▒0▒▒▒▒▒>▒▒>▒>▒▒▒>>▒>>>0>>▒▒>>>>0>▒▒>0▒▒▒▒>▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒▒>0▒▒▒▒>▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒>>▒>>>>>▒▒▒>▒>▒>▒>▒>▒>▒>▒▒>▒>▒▒>▒▒▒>>▒▒>>▒▒>▒▒▒>▒>0>>▒▒>▒▒▒>▒>>>>>▒>▒0>>▒>▒>>>▒>>0>>0>▒▒▒▒▒0▒▒▒▒▒▒▒>▒>▒▒▒>>▒>>>0>>▒▒>>>>0>▒▒>0▒▒▒▒>▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒▒>0▒▒▒▒>▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒>>▒>>>>>▒>>>0>▒▒>▒>▒▒>▒▒▒>>▒▒>>▒▒>▒▒▒>▒>0>>▒▒>▒▒▒>▒>>>>>▒>▒0>>▒>▒>>>▒>>0>>0>▒▒▒▒▒0▒▒▒▒>▒▒0▒▒▒▒▒>>▒>>>0>>▒▒>>>>0>▒▒>0▒▒▒▒>▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒~▒~▒▒▒▒00>>0>▒0▒>>>▒>▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>>0>▒▒▒▒▒0▒▒▒▒>▒>▒>▒▒▒▒▒>>▒>>>0>>▒▒>>>>0>▒▒>0▒▒▒▒>▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒▒>▒▒>▒>▒▒▒>0>>▒0>▒>▒>▒0>>▒>0>▒>▒>>▒>>▒>▒>▒>▒>0>▒>>▒▒>▒>▒0>▒>▒>▒▒>▒▒>>>▒>>▒>▒0▒▒0>▒▒▒▒▒0▒▒▒▒▒▒▒▒▒▒▒>>▒>>>0>>▒▒>>>>0>▒▒>0▒▒▒▒>▒▒▒▒>>>>0>▒▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒>0>▒>▒▒>▒▒▒>▒>▒▒>▒▒>>>▒▒>▒▒>0▒▒▒▒>▒▒▒0>▒▒▒▒▒>▒▒▒▒>0▒▒>▒>▒▒▒▒>▒▒>▒>▒0▒▒▒0▒▒▒▒0▒▒▒▒>0>>▒>▒▒>▒>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒>▒▒▒▒0▒▒>▒>▒▒▒▒>▒▒>▒>▒0▒▒▒0▒▒▒▒0▒▒▒▒>>0>▒>▒▒▒>>▒>>▒>▒>>▒>>0>▒▒▒▒▒>▒▒▒▒▒>▒>▒▒>▒▒▒>0▒>>▒▒▒▒>>▒>▒▒▒>>▒▒>▒>0>>▒>▒▒▒>▒>0>▒>>▒>>0>▒▒▒▒▒>▒▒▒▒>▒▒>▒>▒>▒▒▒>>▒>>>0>▒>>>▒>>▒>▒▒▒>>▒>▒>0>>▒>▒▒▒▒▒0>▒▒▒▒▒>▒▒▒▒>▒▒▒>▒>▒▒▒>>▒>>>0>>▒>>>▒>>▒>▒▒>>▒▒▒>▒▒▒▒▒▒>>▒▒▒>▒>▒>0>>▒▒>▒▒▒>>▒>▒>▒>▒>▒▒>▒▒▒>▒>>▒▒>>▒▒▒0>▒▒▒▒▒>▒▒▒0▒▒0▒▒>▒▒▒▒▒▒>>▒▒▒>>▒>>>0>▒>>>▒>>▒>▒>▒>>0>>▒>>▒▒>>▒>>▒▒▒>>▒>>0>>▒>▒>>▒▒>▒▒▒▒0>▒▒▒▒▒>▒▒▒▒>0▒▒>▒▒>▒▒▒▒▒>>▒▒▒>▒>>>▒>>>▒>▒>>▒>>▒>▒>▒▒▒▒0>▒▒▒▒▒>▒▒▒▒>0▒▒>▒▒>▒▒▒▒0>▒▒▒▒▒>▒▒▒▒>▒>▒▒>▒▒▒▒▒▒>>▒▒▒>>>▒>>▒>>▒▒▒>>▒▒▒>>▒▒>▒▒▒>>▒>▒>0>▒>▒>>>▒▒>▒▒0>▒▒▒▒▒>▒▒▒▒>▒>▒▒>▒▒▒▒▒0>▒▒▒▒▒>▒▒▒▒>▒>▒▒>▒▒▒▒▒▒>>▒▒▒▒▒>>▒▒▒>>▒>▒>▒>▒>▒>>>>▒>▒>▒▒>>0▒>▒>▒>▒>>>▒▒▒▒>>▒>>▒▒>▒>▒>▒>>>▒▒▒>▒>>>▒>▒▒>▒>▒>▒>>>▒0>▒▒▒▒▒>▒▒▒▒>▒>▒▒>▒▒▒▒▒0>▒▒▒▒▒>▒▒▒▒0▒▒>▒0▒▒▒▒▒▒>>▒▒▒>▒>>>▒>>>▒>▒▒▒>>▒▒>▒▒▒▒0>▒▒▒▒▒>▒▒▒▒0▒▒>▒0▒▒▒▒▒0>▒▒▒▒▒>▒▒0▒▒▒>▒▒>▒>▒▒▒▒▒>>▒▒▒>>▒>>>0>▒>>>▒>>▒>▒>▒>>0>>>0>▒▒▒▒▒>▒▒0▒▒▒>▒▒>▒>▒▒▒0>>▒▒>>▒>>▒>▒▒>>0▒▒0>>0>▒▒▒>>0>▒>▒▒▒>▒>0>▒>>▒>▒▒▒>>▒>▒0▒▒>▒▒0>▒▒▒▒▒>▒▒0▒0▒▒>▒▒>▒>▒▒▒0>>▒▒>>▒>>▒>▒▒>>0▒▒0>>0>▒▒▒>>0>▒>▒>▒>>▒▒>>>>>▒>▒0▒>▒0>>▒>0>▒>▒>>▒>>▒>>0>▒▒▒▒▒>▒▒0▒▒>▒▒▒>▒>▒▒▒0>>▒▒>>▒>>▒>▒▒>>0▒▒0>>0>▒▒▒~~0>▒>▒>▒>>▒▒>>>>>▒>▒0>>0>▒▒0>>▒>0>▒>▒>>▒>>▒>>0>▒▒▒▒▒>▒▒0▒▒>▒>>▒▒▒>▒▒▒0>>▒▒>>▒>>▒>▒▒>>0▒▒▒0▒>▒>0>>▒0>>▒▒>>▒>>▒>▒▒>>▒▒0▒▒0▒▒0▒>▒▒>>▒▒▒>▒>0>▒>>▒>▒▒▒>>▒>▒▒▒▒▒▒▒▒0>▒▒▒▒▒>▒▒0▒▒>0▒▒>▒0▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>▒▒▒>▒0▒0>>>▒▒▒>0>0▒0▒>>>▒>▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒>▒>0>▒>>▒>▒▒>>▒0▒▒▒0▒▒0▒▒▒▒▒▒▒▒▒▒▒0▒▒0▒▒0>▒▒▒▒▒>▒▒0▒▒▒>▒>▒>▒>▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒000>>▒>>▒>>>>▒>>▒>>>>▒>▒▒00▒▒▒0>▒▒▒▒▒>▒▒>▒▒▒▒>▒>▒>▒▒▒>>▒>>~0~>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒0▒>▒▒▒>>>>>▒>▒0>>▒>▒>>>▒>>0>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒>▒▒>▒0▒▒>▒>▒▒>▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒0▒>▒▒▒>▒>>>>>▒>▒0>>▒>▒>>>▒>>0>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒>▒▒>▒▒>0▒>▒▒>▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒0▒>▒▒▒>▒>>>>>▒>▒0>>▒>▒>>>▒>>0>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒>▒▒>▒▒>▒>▒▒>▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒0▒>▒▒▒>▒>▒▒>▒>>▒>▒0>>▒>▒>>>▒>>0>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒>▒▒>▒▒>>▒▒>▒>▒>▒▒▒>~▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒0▒>▒▒▒>▒>▒▒▒>>▒>▒0>>▒>▒>>>▒>>0>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒>▒▒>▒▒▒>▒▒▒>▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒0▒>▒▒▒>▒>▒▒>▒>>▒>▒0>>▒>▒>>>▒>>0>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒>▒▒▒>▒▒>▒▒>▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒0▒>▒▒▒>▒>▒▒▒>>▒>▒0>>▒>▒>>>▒>>0>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒>▒▒▒>0▒▒>▒▒>▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒▒>>▒▒>▒>>▒>▒▒▒>▒0▒0▒0>▒▒▒▒▒>▒▒▒>>▒▒>▒0▒▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>>▒>▒>>▒>>▒▒▒>>0>>>>▒>▒>▒0▒▒>▒0▒▒▒>>0>>▒0>▒▒▒▒▒>▒▒▒>▒>▒▒>▒>▒>▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>▒>▒>▒>>>▒>▒>▒>>>▒▒>>>>>▒▒00>▒0>>>▒▒▒▒>>>▒▒▒>▒▒▒▒>▒>▒>▒0▒▒▒▒▒>0>▒>▒>>▒▒▒▒▒>0>>>0>>▒▒>▒▒0▒▒>▒>>>▒▒>▒▒▒>0>▒▒0▒▒▒▒>▒>▒0>>0>▒▒▒▒▒>▒▒▒>▒>▒>▒>0▒▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒>▒>▒▒▒>▒>>>>>▒>>>>▒▒>▒>▒>▒>▒▒>▒▒▒>>▒▒>▒>>▒>>>▒0>>▒>▒>>>▒>>0>>0>▒▒▒▒▒>▒▒▒>▒▒>▒>▒▒>▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>▒>▒>▒>>>▒>▒>▒>>>▒▒>>>>>▒▒>▒▒▒▒▒00>▒0>>>▒▒▒▒>>>▒▒0▒0▒▒▒>▒>▒>▒0▒▒▒▒▒>0>▒>▒>>▒▒▒▒▒>0>>>0>>▒▒>▒▒0▒▒>▒>>>▒▒>▒▒▒>0>▒▒0▒▒▒▒>▒>▒0>>0>▒▒▒▒▒>▒▒▒>▒>▒0▒▒▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>▒>▒>▒>>>▒>▒>▒>>>▒▒>>>>>▒▒00>▒0>>>▒▒▒▒>>>▒▒0▒▒>▒>▒▒▒>▒>▒>▒▒▒▒▒>0>▒>▒>>▒▒▒▒▒>0>>>0>>▒▒>▒▒0▒▒>▒>>>▒▒>▒▒▒>0>▒▒0▒▒▒▒>▒>▒0>>0>▒▒▒▒▒>▒▒▒>▒>▒>▒▒>▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒▒>>▒>>>>▒▒>>▒▒▒▒>>0>>▒>0>▒>>0>▒▒▒▒▒>▒▒▒>▒>▒>▒>▒▒>▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>▒▒▒>▒0▒0>>>▒▒▒>0>0▒0▒>>~▒~▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒>▒>0>▒>>▒>▒▒>>▒0▒▒▒0▒▒0▒▒▒▒▒▒▒▒▒▒▒0▒▒0▒▒0>▒▒▒▒▒>▒▒▒>▒0▒▒>▒>▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒000>>▒>>▒>>>>▒>>▒>>>>▒>▒▒00▒▒▒0>▒▒▒▒▒>▒▒▒>0▒▒>>▒▒0▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒0▒>▒▒▒>>>>>▒>▒0>>▒>▒>>>▒>>0>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒>▒▒▒>▒>0▒▒>▒>▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒0▒>▒▒▒>▒>>>>>▒>▒0>>▒>▒>>>▒>>0>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒>▒▒▒>▒>▒▒▒▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒0▒>▒▒▒>▒>>>>>▒>▒0>>▒>▒>>>▒>>0>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒>▒▒▒>▒>>▒▒>0▒▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒0▒>▒▒▒>▒>▒▒>▒>>▒>▒0>>▒>▒>>>▒>>0>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒>▒▒▒>▒▒>▒▒>▒>▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒0▒>▒▒▒>▒>▒▒▒>>▒>▒0>>▒>▒>>>▒>>0>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒>▒▒▒>▒▒>▒0▒▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒0▒>▒▒▒>▒>▒▒>▒>>▒>▒0>>▒>▒>>>▒>>0>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒>▒▒▒>0▒▒▒▒>▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒0▒>▒▒▒>▒>▒▒▒>>▒>▒0>>▒>▒>>>▒>>0>▒▒▒>>▒▒>>▒▒>>0>▒▒▒▒▒>▒▒▒>>▒▒>▒>>▒>▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>>>▒>▒0▒▒>▒▒▒>>▒>▒>0>>▒0>0>>▒>▒>>>▒>0>>>>▒>>▒>>>>>▒▒>▒>▒>▒>▒▒>▒▒>▒▒>>▒>>▒>>0>▒▒▒▒▒>▒▒▒>▒>▒0▒▒>▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>▒>▒>▒>>>▒>▒>▒>>>▒▒>>>>>▒▒00>▒0>>>▒▒▒▒>>>▒▒▒>▒▒▒▒>▒>▒>▒0▒▒▒▒▒>0>▒>▒>>▒▒▒▒▒>0>>>0>>▒▒>▒▒0▒▒>▒>>>▒▒>▒▒▒>0>▒▒0▒▒▒▒>▒>▒0>>0>▒▒▒▒▒>▒▒▒>▒▒>▒▒▒>▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒>▒>▒▒▒>▒>>>>>▒>>>>▒▒>▒>▒>▒>▒▒>▒▒▒>>▒▒>▒>>▒>>>▒0>>▒>▒>>>▒>>0>>0>▒▒▒▒▒>▒▒▒▒▒>▒▒>▒>▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>▒>▒>▒>>>▒>▒>▒>>>▒▒>>>>>▒▒>▒▒▒▒▒00>▒0>>>▒▒▒▒>>>▒▒0▒0▒▒▒>▒>▒>▒0▒▒▒▒▒>0>▒>▒>>▒▒▒▒▒>0>>>0>>▒▒>▒▒0▒▒>▒>>>▒▒>▒▒▒>0>▒▒0▒▒▒▒>▒>▒0>>0>▒▒▒▒▒>▒▒▒▒>▒>▒>▒>▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒▒▒>>▒>>>>▒▒>>▒▒▒>>>▒▒>>>▒>>▒0>▒>▒>>>▒▒>▒>▒>>▒>>>0>▒▒▒▒▒>▒▒▒▒>>▒▒▒▒>▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>>>▒>▒▒▒>▒▒▒▒▒>▒>▒>▒>>>>▒>▒▒>0▒▒▒0▒▒▒>0▒▒▒▒0>▒▒▒▒▒>▒▒▒▒>>▒▒▒>▒▒▒▒>>▒>>>0>▒▒>▒▒>▒>▒>▒>>0>>▒▒>▒>▒▒▒▒>>▒>>▒>▒>>0>▒▒▒▒▒>▒▒▒▒▒▒▒>▒▒▒▒>>▒>>>0>▒▒▒>>▒>▒>>▒>▒>▒▒>▒▒>▒>▒>>>>▒>▒>▒>▒▒>▒▒>▒▒▒▒▒>>0>>▒▒>▒>▒▒▒>>▒▒▒>>▒>▒▒▒>>▒▒>▒>>▒>▒>0>>▒▒>▒▒>▒▒>▒>▒>>>>>>>>▒▒>▒▒>▒>▒0>>▒>▒>>>▒>>0>▒▒0>▒▒▒▒▒>▒▒▒0▒▒>▒>▒▒>▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>>>▒>▒▒▒>▒▒▒▒▒>▒>▒>▒>>>>▒>▒▒>0▒▒▒0▒▒▒>0▒▒▒▒0>▒▒▒▒▒>▒▒▒0▒▒>▒▒>▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>▒>▒>▒>>>▒>▒>▒>>>▒▒>>>>>▒▒>▒▒▒▒▒00>▒0>>>▒▒▒▒>>>▒▒0▒0▒▒▒>▒>▒>▒0▒▒▒▒▒>0>▒>▒>>▒▒▒▒▒>0>>>0>>▒▒>▒▒0▒▒>▒>>>▒▒>▒▒▒>0>▒▒0▒▒▒▒>▒>▒0>>0>▒▒▒▒▒>▒▒▒▒>0▒▒▒▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>▒>▒>▒>>>▒>▒>▒>>>▒▒>>>>>▒▒>▒▒▒▒▒00>▒0>>>▒▒▒▒>>>▒▒0▒0▒▒▒>▒>▒>▒0▒▒▒▒▒>0>▒>▒>>▒▒▒▒▒>0>>>0>>▒▒>▒▒0▒▒>▒>>>▒▒>▒▒▒>0>▒▒0▒▒▒▒>▒>▒0>>0>▒▒▒▒▒>▒▒▒▒>▒▒>▒▒>▒▒▒>>▒>>>0>▒0>>▒>0>▒>▒>>▒>▒▒>▒▒>▒>▒>>>>▒>▒>▒>>▒>▒▒>▒>▒▒▒▒▒>▒▒>▒>▒>>>>▒>▒>▒>>▒>▒>>▒>>▒>▒>>0>▒▒▒▒▒▒>▒▒▒▒>0▒>▒▒>▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>>>▒>▒▒▒>▒▒▒▒▒>▒>▒>▒>>>>▒>▒▒>▒▒0▒▒▒>0▒▒▒▒0>▒▒▒▒▒▒>▒▒>▒▒▒>▒>▒>▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>>>▒>▒▒▒>▒▒▒▒▒>▒>▒>▒>>>>▒>▒▒>▒▒0▒▒▒>0▒▒▒▒0>▒▒▒▒▒▒>▒▒▒>▒>▒>▒▒>▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>>>▒>▒▒▒>▒▒▒▒▒>▒>▒>▒>>>>▒>▒▒>▒▒0▒▒▒>0▒▒▒▒0>▒▒▒▒▒▒>▒▒▒>0▒▒▒>0▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>>>▒>▒▒▒>▒▒▒▒▒>▒>▒>▒>>>>▒>▒▒>▒▒0▒▒▒>0▒▒▒▒0>▒▒▒▒▒▒>▒▒▒>0▒▒▒>▒▒▒▒>>▒>>>0>>▒▒>▒>>>▒▒>▒0▒▒▒▒▒▒>>▒>>>>>▒>▒▒▒>>▒>▒>▒>>>▒>▒>▒>>>▒▒>>>>>▒▒00>▒0>>>▒▒▒▒>>>▒▒0▒▒>▒>▒▒▒>▒>▒>▒▒▒▒▒>0>▒>▒>>▒▒▒▒▒>0>>>0>>▒▒>▒▒0▒▒>▒>>>▒▒>▒▒▒>0>▒▒0▒▒▒▒>▒>▒0>>0>▒▒▒▒▒▒>▒▒▒▒▒0▒▒>▒▒▒>>▒>>>0>▒▒>▒▒>▒>▒>▒>>0>>▒▒▒>▒>▒▒▒▒▒>0>>>>>>▒0>▒▒▒▒▒▒>▒▒▒▒>0▒▒>▒▒▒▒▒▒>>▒>>▒>▒▒▒▒▒>>▒>▒>0>>▒>▒▒▒>▒▒▒▒0>▒▒▒▒▒▒>▒▒0▒▒▒▒>▒▒▒▒>▒>▒▒▒▒>0>0>>0▒▒>>>▒▒>▒>>▒>>>0>▒>>>▒▒>>▒>▒>>▒>▒>>▒>>▒>>>>▒>▒▒>▒0▒▒>▒0▒▒▒0▒▒▒>0>▒>0>▒>>>▒▒▒▒>>▒>0▒▒▒▒▒>>▒>▒▒>>▒▒>▒>▒▒▒>>▒>0▒0▒▒>▒▒▒>>>>▒▒▒▒>>0>>0▒>▒▒▒▒▒>>>>▒▒▒▒>>0>>0▒>▒▒▒>>▒▒>>>>▒▒>>>▒▒▒0▒▒▒▒>>▒▒>▒▒>▒>>>0▒▒▒▒>>▒>▒>▒>▒▒>▒▒>▒>>>0▒▒▒0>▒▒▒▒▒▒>▒▒0▒▒▒▒>▒▒▒▒▒0>▒▒▒▒▒▒>▒▒▒>▒▒>0▒▒▒▒▒>▒>▒▒▒▒>0>0>>0▒▒>>>▒▒>▒>>▒>>>0>▒>>>▒▒>>▒>▒>>▒>▒>>▒>>▒>>>>▒>▒▒>▒0▒▒>▒>▒▒▒0▒>▒>▒>▒>▒>▒>▒>>▒>▒>▒▒▒▒▒>▒>▒>>>▒>▒>>▒>▒>▒▒▒▒▒▒▒>>▒>▒>▒>▒>▒>>▒>▒>▒▒▒▒▒▒▒>>▒>>>▒>▒▒▒▒0>▒▒▒▒▒▒>▒▒▒▒>0▒▒▒▒▒▒>▒>▒▒▒▒>0>0>>0▒▒>>>▒▒>▒>>▒>>>0>▒>▒>▒▒>>▒>>>>▒▒>>>▒▒>>▒>▒>▒>>0>>▒▒>▒0▒▒>▒▒▒▒0▒>>>▒▒>>▒>▒>▒>>0>>▒▒▒>0>>>>>>▒▒>▒>>0>▒▒▒▒▒▒>▒0▒▒▒>▒0▒▒>▒▒▒▒▒>>▒>▒>▒>▒>▒>▒▒▒▒▒>0>▒>>▒>▒>>0>▒>▒▒00▒▒>▒▒>▒▒>>>▒▒>▒>>>>>▒>▒>>>▒>▒>>0>0▒▒▒>0>▒>>▒>>▒>>>▒▒>▒▒0>▒>▒>0>>>>>▒▒>>▒>0▒>>0>>>▒>▒>▒>▒>>▒>>>▒▒>▒▒0>▒▒▒▒▒▒>▒0▒▒>▒▒>▒▒▒▒▒>▒>▒▒0▒▒>>0▒▒>~~▒▒>▒>>▒>>>0>▒>>>▒>▒>▒>▒>>▒▒>▒▒>▒▒>▒>▒▒▒0▒>>>▒>▒>▒>▒>>▒▒>▒▒▒>0>>>>>>▒▒>▒>>0>▒▒▒▒▒▒>▒0▒▒>▒>▒▒>▒>▒▒▒>>▒>>>0>>▒>>>▒▒>>▒>>▒▒>>▒>>>▒>▒▒>▒0▒▒>▒▒>▒▒>▒▒>>>▒▒>>▒▒>▒▒▒0▒▒>▒▒▒▒▒▒>>>▒▒>>▒>▒▒▒▒▒▒▒0▒▒>▒▒>▒▒>>>▒▒>▒>>>>>▒>▒>>>▒>▒>>0>▒▒>>>>0>>▒▒>▒▒>>>▒0>▒▒▒▒▒▒>▒0▒▒▒▒>▒>▒▒▒▒>▒>>▒>▒>▒▒▒>▒>▒>0>>>>>▒▒>>▒>▒>>▒>>>0>▒>▒>▒>0>>▒00>▒>▒>▒>▒>▒▒▒▒>>▒>0>▒>>▒>>>>▒>▒>>0>>>>>>>>>▒▒▒▒▒▒▒▒▒0▒▒>▒▒>▒▒>▒▒>>>▒▒>>▒▒>>>>▒▒>>▒▒>>>>▒>▒>▒▒>▒>>▒>▒>▒▒0>▒▒▒▒▒▒>▒>▒▒▒▒>▒>▒>▒▒▒>▒>▒▒0▒▒>>0▒▒>>>▒▒>▒>>▒>>>0>▒>>>▒>▒>▒▒▒>>▒>▒>▒>>0>>▒▒>▒▒>▒▒>▒▒0▒0>>▒>0>▒>▒>>▒>▒>>>▒>▒>▒▒▒>0>>>>>>▒▒>▒>>0>▒▒▒▒▒▒>▒>▒0▒▒>▒▒▒▒▒▒>▒>▒▒0▒▒>>0▒▒~~>▒▒>▒>>▒>>>0>▒>>>▒>▒>>▒▒>▒▒▒>>0>▒>▒▒>▒0▒▒>▒▒▒0▒0>>▒>▒>>>>>▒▒▒▒0>>>>0>▒>▒>>▒>0>▒>▒>>▒0>▒▒▒▒▒▒>▒>▒>▒▒▒>▒▒▒▒▒▒0▒▒>▒>▒▒▒0▒▒▒>▒>0>▒>▒>>▒>>▒>▒>▒>>▒▒>>>>>▒>▒▒▒>>>>0>>>▒▒▒▒0>▒▒▒▒▒▒>▒>▒▒>▒▒>▒▒▒▒▒>▒▒▒>▒>>>>>▒▒>▒0▒▒>▒▒>▒>0>>▒▒>▒▒▒>0>▒>>▒0▒▒▒>>▒0>▒▒▒▒▒▒>▒>▒▒>▒▒>▒▒▒▒▒▒0▒▒>▒>▒▒▒0▒▒▒>▒>0>▒>▒>>▒>>▒>▒>▒>>▒▒>>>>>▒>▒▒▒>>>>0>>>▒▒▒>▒0>▒▒▒▒▒▒>▒>▒▒▒▒>▒0▒▒▒▒0>>▒▒>>▒>>▒>▒▒>>0▒▒0▒▒▒>>0▒0▒0▒▒▒>▒>▒▒▒▒>>▒>>▒>▒>▒>>▒▒>0>>>>0>>▒>>0>▒▒▒▒▒▒>▒>▒▒>▒▒▒▒▒▒▒0>>▒▒>>▒>>▒>▒▒>>0▒▒0▒▒▒>>0▒0▒0▒>>>>>▒>>▒>▒▒>>▒>>▒>▒>▒>>▒▒>0>>>>0>>▒>>0>▒▒▒▒▒▒>▒▒>▒▒>▒▒▒▒▒▒0>>▒▒>>▒>>▒>▒▒>>0▒▒0▒▒▒>>0▒0▒0▒▒▒>>▒>▒▒▒▒▒▒0>▒▒▒▒▒▒>▒▒>▒▒▒>▒▒>▒▒▒0▒▒▒>▒>0>▒>▒>>▒>0>>▒▒>▒>▒▒▒>▒▒>▒▒▒>▒0>▒▒▒>>>▒>>>▒>0>>▒>▒>>>▒▒>>▒▒>▒>>0>▒▒▒▒▒▒>▒▒>▒>▒0▒0▒▒▒▒▒▒▒>>▒>▒▒▒>>>>0>▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒>>▒>>▒>>>▒>>>▒▒>▒>▒>>▒>>>▒▒▒>>0>>▒▒0>▒▒▒▒▒▒>▒▒>▒>0▒▒>▒>▒>▒▒▒>>▒>>>0>▒▒▒>>>>0>▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒>>▒>▒0▒▒>▒>▒>>▒▒>▒▒▒>>▒>>▒>>▒>>>▒▒>▒>▒>>>0>▒▒▒▒▒▒>▒▒>▒>▒>▒>▒0▒▒▒▒>▒>>▒>>>0>>▒▒▒>>>>0>▒▒▒0▒▒>▒>>0>>▒>▒>>▒>>▒▒▒▒>>>>>▒▒▒▒>▒▒▒▒▒▒▒▒▒>>>>0>▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒~▒>>▒>>>0>▒▒▒>>>>0>▒▒▒▒>▒>▒0>▒▒▒▒>▒>▒▒▒▒▒▒>▒▒>>▒▒>▒>▒▒▒▒▒>0>▒>▒▒>▒>0▒>▒>>0>▒▒▒▒▒▒>▒▒>▒▒>>▒▒▒▒▒▒>▒>>▒>>>0>>▒▒▒>>>>0>▒▒▒0▒▒▒0▒>▒▒>▒>▒>>▒▒>▒▒▒>>>>0>▒▒0>▒▒▒▒▒▒>▒▒>▒▒>▒>▒>▒▒▒▒▒▒>>▒>▒▒>>>>0>▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒>>▒>>▒>>>▒>>>▒▒>▒>▒>>▒>>>▒▒▒>>0>>▒▒0>▒▒▒▒▒▒>▒▒>>▒▒▒>▒▒>▒▒▒>>▒>>>0>▒▒>>>>0>▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒▒▒>>▒>▒0▒▒>▒>▒>>▒▒>▒▒▒>>▒>>▒>>▒>>>▒▒>▒>▒>>>0>▒▒▒▒▒▒>▒▒>▒>▒>▒>▒▒>▒▒▒>▒>>▒>>>0>>▒▒>>>>0>▒▒▒0▒▒>▒~>0>>▒>▒>>▒>>▒▒▒▒>>>>>▒▒▒▒>▒▒▒▒>▒▒▒▒>>>>0>▒▒>>>▒>▒▒>▒>>▒>▒>▒▒>▒>▒>>▒>>>0>▒▒>>>>0>▒▒▒▒>▒>▒0>▒▒▒▒>▒▒0▒▒▒0>▒▒▒▒▒▒>▒▒>▒>▒▒▒▒▒▒▒>▒>>▒>>>0>>▒▒>>>>0>▒▒▒0▒▒▒0▒>▒▒>▒>▒>>▒▒>▒▒>>>>0>▒▒0>▒▒▒▒▒▒>▒▒>▒▒▒>▒▒>▒▒▒▒▒>▒>0>▒0▒▒>▒>▒>>▒>>>▒>▒▒>▒▒>▒▒>▒>▒▒▒0>▒▒▒▒▒▒>▒▒▒0▒▒>▒>0▒▒▒▒0>>>▒▒>>▒>0▒▒>>▒>>▒▒>▒>▒>>▒▒>▒▒▒>>▒>▒▒>>0>▒▒▒▒▒▒>▒▒▒>▒>▒>>▒▒▒▒▒▒▒>▒>0>▒0▒▒>>▒>>>▒>>▒>▒▒>▒>>>▒▒▒>0>>>>>>▒▒>▒>>0>▒▒▒▒▒▒>▒▒▒>▒>▒▒▒>▒▒▒▒▒>▒>0>▒0▒▒>▒>▒>>▒>>▒▒>▒>▒▒>▒▒>▒>▒▒▒▒>>>>>▒0▒>>▒>▒>▒▒▒▒>>0>▒>>▒▒0▒>▒▒▒0>0>0▒▒0>▒▒▒▒▒▒>▒▒▒▒▒>▒>▒>▒▒▒▒▒>▒>0>▒0▒▒▒▒▒>>▒>>0>▒>>▒▒▒0▒▒>0▒▒▒>▒>▒0>▒>▒>>▒>▒0▒▒>▒>▒>0>0>0▒▒▒▒0▒▒>>▒>>0>▒>>▒▒▒0▒▒>▒▒▒>▒▒0>▒>▒>>▒>>0>▒▒▒▒▒▒>▒▒▒▒>▒>▒▒>▒▒▒▒▒>▒>0>▒0▒▒▒>>▒>▒▒▒>>>▒0▒▒0▒▒▒>>>▒▒>▒>>0>▒>>▒>▒▒▒▒>▒▒▒>▒▒>▒▒▒>▒▒>>▒>▒>>▒>>▒>>▒>>0>▒>>▒0▒▒▒>▒▒0>▒▒▒▒▒▒>▒▒0▒▒>▒>▒>▒▒▒▒▒▒>▒>0>▒0▒▒▒▒>0>▒>▒>▒▒>>▒>>▒>▒▒>▒▒>▒>▒>>▒>▒▒▒0▒▒▒>▒▒>>>▒▒>>▒▒>▒>▒0▒▒▒>▒▒▒▒▒>>▒>>▒▒>▒▒>▒>▒>>▒>▒▒▒▒>▒▒▒>▒0>▒▒▒▒▒▒>▒▒▒>▒>▒>▒>▒>▒▒▒▒▒>▒>0>▒0▒▒▒▒>>▒>▒▒>▒▒▒▒>>▒>▒▒▒▒>▒0▒▒▒0>>▒>▒▒▒▒>>▒>▒▒▒▒▒▒>>>0>▒>▒>>▒>>▒>▒▒▒▒>>▒>▒▒▒▒▒0>▒▒▒▒▒▒>▒▒▒>0▒▒>▒▒▒▒▒▒▒>▒>0>▒0▒▒▒▒>▒>>▒>▒▒▒>>▒>▒▒>>>>▒▒▒▒▒▒>▒>▒▒>>▒>>>>▒▒▒>>▒>▒▒>>>>▒>▒▒▒▒▒▒▒>>>▒▒▒>>▒>▒▒>>>>▒>▒>>>▒▒>>▒▒>▒▒▒▒0▒▒▒0>▒▒▒▒▒▒>▒▒▒0▒0▒▒▒>▒▒▒▒▒>▒>0>▒0▒▒▒>>>▒>▒▒>>>▒▒▒>▒>>▒>>▒>>>▒▒>>▒▒>>▒>▒▒▒0▒▒▒▒▒▒▒>0▒▒▒>>0>>▒>>▒>▒>▒▒>▒▒▒▒>▒▒▒>▒▒>▒>>▒>>▒>>>▒>▒>>>>>>▒▒>▒▒>>>▒>>▒>▒▒▒▒▒0>▒▒▒▒▒▒>▒▒▒▒>▒>▒>▒>▒▒▒▒▒>▒>0>▒0▒▒>▒>>0>>>▒>>▒▒>▒▒▒▒>>▒>▒▒▒▒▒▒▒▒>>▒▒>>>▒0>>▒>>▒>▒>>▒>▒▒▒▒>>▒>▒▒▒▒>▒0▒▒▒▒▒▒>>▒>▒0>>▒>>▒>▒>>▒>▒▒▒>>0>▒0>>▒>▒▒▒▒>>▒>>>▒▒>>>▒>▒▒>▒▒▒0▒▒▒0>▒▒▒▒▒▒>▒▒0▒▒▒>▒▒▒▒▒▒▒>▒>0>▒0▒▒0>>▒>▒>▒>▒>>▒▒>>▒▒>▒▒▒>>0>>>▒>▒0▒▒▒>▒>0>▒0>▒>▒>▒▒▒>▒▒▒>>▒>>▒>▒>>▒>▒▒0▒▒>▒▒>>▒▒0>▒▒▒▒▒▒>▒▒▒>▒>▒▒▒>▒▒▒0>>▒>>>▒>▒▒▒>▒>0>▒>>▒>>>▒>▒▒▒▒>0▒▒>>▒>>>▒>>▒>▒▒▒>▒>>▒>▒▒▒>▒>0>▒0▒▒>0>>▒>▒▒>▒>▒>0▒▒0>▒▒▒▒▒▒>▒▒▒>▒>▒>▒>▒▒▒▒>>>▒>▒>>0>>>▒0>>▒>▒>>>▒>>0>▒>▒0▒▒▒▒>0>▒>>▒>▒>▒▒▒>0>▒>>>▒>>▒>>▒▒>▒>>▒>▒▒▒>>0>▒0>>▒>▒>>>▒>>0>▒>▒▒>▒>▒▒▒>>0>>▒▒>▒>▒▒▒>0>▒>>▒▒▒>▒>▒>>0>▒▒0▒▒0>▒▒▒▒▒▒>▒▒▒▒>▒▒▒▒▒▒>>>>>0▒▒▒0▒>▒▒>▒▒▒>0>▒>>▒>>>▒>▒▒>▒▒▒>>▒▒>▒>>▒>▒>>>▒>>>▒>▒>>0>▒▒▒▒▒▒>▒▒▒▒>▒▒0▒▒▒▒>0>▒>▒▒▒>>▒>0>▒>>▒▒>>>>▒>▒▒▒0>▒▒▒▒▒▒>▒▒▒▒>▒▒▒▒▒▒▒▒>▒▒0▒▒>▒>▒>0>>>>>▒▒>>▒>>0>▒▒▒▒▒▒>▒▒▒▒▒>▒>▒▒▒▒>>▒>▒>▒▒0▒▒▒0▒▒▒▒>>0>>▒▒>▒>▒▒▒>>▒▒>▒>>▒>▒0>>▒>▒>>>▒>>0>▒>▒▒>▒>>0>▒▒▒▒▒▒>▒▒▒▒>▒>▒>▒>▒▒▒>>▒>▒>>>▒▒▒>▒>▒▒▒>>>▒>▒▒>▒▒▒▒>▒>▒▒>▒▒0▒▒>0▒0▒▒0[    5.141657] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
              [    5.152075] devtmpfs: mounted
              [    5.157300] Freeing unused kernel memory: 1024K
              [    5.187892] Run /pseudo_init as init process
              [    5.396096] UBIFS (ubi0:7): Mounting in unauthenticated mode
              [    5.402639] UBIFS (ubi0:7): background thread "ubifs_bgt0_7" started, PID 103
              [    5.474182] UBIFS (ubi0:7): recovery needed
              [    5.596434] UBIFS (ubi0:7): recovery completed
              [    5.601565] UBIFS (ubi0:7): UBIFS: mounted UBI device 0, volume 7, name "rootfs_data"
              [    5.610372] UBIFS (ubi0:7): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
              [    5.621509] UBIFS (ubi0:7): FS size: 3096576 bytes (2 MiB, 12 LEBs), journal size 1806337 bytes (1 MiB, 5 LEBs)
              [    5.632835] UBIFS (ubi0:7): reserved for root: 146258 bytes (142 KiB)
              [    5.640073] UBIFS (ubi0:7): media format: w5/r0 (latest is w5/r0), UUID 5826DE6E-A79D-4CD4-953E-705F4ECC547B, small LPT model
              [    5.768974] UBIFS (ubi0:8): Mounting in unauthenticated mode
              [    5.775477] UBIFS (ubi0:8): background thread "ubifs_bgt0_8" started, PID 132
              [    5.846871] UBIFS (ubi0:8): recovery needed
              [    5.896189] UBIFS (ubi0:8): recovery completed
              [    5.901402] UBIFS (ubi0:8): UBIFS: mounted UBI device 0, volume 8, name "UDISK"
              [    5.909644] UBIFS (ubi0:8): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
              [    5.920792] UBIFS (ubi0:8): FS size: 53932032 bytes (51 MiB, 209 LEBs), journal size 2580480 bytes (2 MiB, 10 LEBs)
              [    5.932524] UBIFS (ubi0:8): reserved for root: 2547342 bytes (2487 KiB)
              [    5.939967] UBIFS (ubi0:8): media format: w5/r0 (latest is w5/r0), UUID 800F2F23-791C-475F-ADD8-DBB996AF1127, small LPT model
              [    6.003302] sunxi_gpadc_init,2151, success
              [    6.008282] sunxi_gpadc_setup: get channel scan data failed
              [    6.014879] input: sunxi-gpadc0 as /devices/virtual/input/input1
              [    6.083020] ======== XRADIO WIFI OPEN ========
              [    6.088610] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
              [    6.095389] [XRADIO] Allocated hw_priv @ 437f1eed
              [    6.101232] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
              [    6.117517] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
              [    6.324704] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    6.335844] [XRADIO] Detect SDIO card 1
              [    6.347832] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
              [    6.367978] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    6.392849] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    6.407437] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    6.429597] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
              [    6.441194] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
              [    6.453036] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
              [    6.465610] mmc1: new high speed SDIO card at address 0001
              [    6.472163] [SBUS] XRadio Device:sdio clk=50000000
              [    6.478096] [XRADIO] XRADIO_HW_REV 1.0 detected.
              [    6.568198] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x00c00000.
              [    6.604146] [XRADIO] Bootloader complete
              [    6.693729] [XRADIO] Firmware completed.
              [    6.699778] [WSM] Firmware Label:XR_C09.08.52.73_DBG_02.122 2GHZ HT40 May 18 2021 13:36:09
              [    6.717204] [XRADIO] Firmware Startup Done.
              [    6.722200] [XRADIO_WRN] enable Multi-Rx!
              [    6.727377] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
              [    6.927689] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=38:c9:24:7b:b1:9e
              [    6.935898] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=38:c9:24:7b:b1:9e
              [    6.951382] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
              ------run rc.final file-----
                : values=on
              ------light up RGB LED-----
              [    7.192769] file system registered
              [    7.210184] configfs-gadget 4100000.udc-controller: failed to start g1: -19
              [    7.232850] read descriptors
              [    7.236098] read strings
              ------light up LED-----
              ------run profile file-----
              Wed Jun  1 00:00:00 GMT 2022
              nodev   debugfs
              root@TinaLinux:/# [    8.648023] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
              [    8.900790] android_work: sent uevent USB_STATE=CONNECTED
              [    9.000187] configfs-gadget gadget: high-speed config #1: c
              [    9.006521] android_work: sent uevent USB_STATE=CONFIGURED
              root@TinaLinux:/#
              root@TinaLinux:/#
              root@TinaLinux:/# ifconfig -a
              eth0      Link encap:Ethernet  HWaddr A2:CA:02:E9:35:D5
                        BROADCAST MULTICAST  MTU:1500  Metric:1
                        collisions:0 txqueuelen:1000
                        Interrupt:37
              wlan0     Link encap:Ethernet  HWaddr 38:C9:24:7B:B1:9E
              root@TinaLinux:/#
              Z 1 条回复 最后回复 回复 引用 分享 5
                Zhice.Yang LV 4 最后由 编辑
                请问楼主是用什么flash,我用了D1的tina SDK,编译SPI nor/nand flash固件不能正常跑起来
                whycan 2 条回复 最后回复 回复 引用 分享 4
                  whycan晕哥 LV 9 @Zhice.Yang 最后由 编辑
                  @zhice-yang 在 一个补丁,让D1-H的SDK支持T113芯片 中说:
                  楼主是用什么flash
                  华邦的 W25N01
                  Z 3 条回复 最后回复 回复 引用 分享 3
                    whycan晕哥 LV 9 @Zhice.Yang 最后由 whycan 编辑
                    @zhice-yang
                    在这个板子无缝运行
                    https://item.taobao.com/item.htm?id=672608097923
                      Zhice.Yang LV 4 @whycan 最后由 编辑
                      @whycan 多谢
                        @whycan 按大神的做法我能编译出固件,但是rootfs挂载不起来
                          Zhice.Yang LV 4 @whycan 最后由 xiaowenge 编辑
                          @whycan
                          [    0.000000] percpu: Embedded 15 pages/cpu s30284 r8192 d22964 u61440
                          [    0.000000] pcpu-alloc: s30284 r8192 d22964 u61440 alloc=15*4096
                          [    0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk= clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/pseudo_init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:private@ubi0_6:rootfs_data@ubi0_7:UDISK@ubi0_8: cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-g24521d6-dirty(09/06/2022-15:58:48) aw-ubi-spinand.ubootblks=24 androidboot.dramsize=128
                          [    0.000000] Memory: 110700K/131072K available (5120K kernel code, 235K rwdata, 1308K rodata, 1024K init, 1152K bss, 12180K reserved, 8192K cma-reserved)
                          [    0.008008] Switching to timer-based delay loop, resolution 41ns
                          [    0.014177] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
                          [    0.023878] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
                          [    0.034235] pid_max: default: 32768 minimum: 301
                          [    0.038984] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                          [    0.046308] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                          [    0.054614] CPU: Testing write buffer coherency: ok
                          [    0.059826] /cpus/cpu@0 missing clock-frequency property
                          [    0.065142] /cpus/cpu@1 missing clock-frequency property
                          [    0.070473] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                          [    0.076635] Setting up static identity map for 0x40100000 - 0x40100060
                          [    0.083280] rcu: Hierarchical SRCU implementation.
                          [    0.088475] smp: Bringing up secondary CPUs ...
                          [    0.094091] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                          [    0.094210] smp: Brought up 1 node, 2 CPUs
                          [    0.104005] SMP: Total of 2 processors activated (96.00 BogoMIPS).
                          [    0.110183] CPU: All CPU(s) started in SVC mode.
                          [    0.115270] devtmpfs: initialized
                          [    0.129276] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
                          [    0.137392] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                          [    0.147257] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
                          [    0.154470] pinctrl core: initialized pinctrl subsystem
                          [    0.160243] NET: Registered protocol family 16
                          [    0.166066] DMA: preallocated 256 KiB pool for atomic coherent allocations
                          [    0.201233] rtc_ccu: sunxi ccu init OK
                          [    0.207147] ccu: sunxi ccu init OK
                          [    0.210895] r_ccu: sunxi ccu init OK
                          [    0.235286] iommu: Default domain type: Translated
                          [    0.240387] sunxi iommu: irq = 24
                          [    0.244569] SCSI subsystem initialized
                          [    0.248553] usbcore: registered new interface driver usbfs
                          [    0.254141] usbcore: registered new interface driver hub
                          [    0.259543] usbcore: registered new device driver usb
                          [    0.266035] Bluetooth: Core ver 2.22
                          [    0.269647] NET: Registered protocol family 31
                          [    0.274083] Bluetooth: HCI device and connection manager initialized
                          [    0.280483] Bluetooth: HCI socket layer initialized
                          [    0.285374] Bluetooth: L2CAP socket layer initialized
                          [    0.290469] pwm module init!
                          [    0.294582] g2d 5410000.g2d: Adding to iommu group 0
                          [    0.299855] G2D: rcq version initialized.major:252
                          [    0.305390] clocksource: Switched to clocksource arch_sys_counter
                          [    0.312942] NET: Registered protocol family 2
                          [    0.318048] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                          [    0.326460] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
                          [    0.334136] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
                          [    0.341231] TCP: Hash tables configured (established 1024 bind 1024)
                          [    0.347696] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
                          [    0.354246] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
                          [    0.361445] NET: Registered protocol family 1
                          [    0.367866] workingset: timestamp_bits=30 max_order=15 bucket_order=0
                          [    0.378409] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                          [    0.384387] ntfs: driver 2.1.32 [Flags: R/W].
                          [    0.417244] io scheduler mq-deadline registered
                          [    0.421798] io scheduler kyber registered
                          [    0.427050] [DISP]disp_module_init
                          [    0.430866] disp 5000000.disp: Adding to iommu group 0
                          [    0.452727] display_fb_request,fb_id:0
                          [    0.460060] [DISP] Fb_copy_boot_fb,line:1443:
                          [    0.460063] no boot_fb0
                          [    0.467346] disp_al_manager_apply ouput_type:0
                          [    0.472402] [DISP]disp_module_init finish
                          [    0.477221] [DISP] lcd_clk_config,line:732:
                          [    0.477233] disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
                          [    0.477233]      clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
                          [    0.477485] sunxi_sid_init()551 - insmod ok
                          [    0.502495] misc dump reg init
                          [    0.506343] dma-buf: Running sanitycheck
                          [    0.510263] dma-buf: Running dma_fence
                          [    0.514013] sizeof(dma_fence)=48
                          [    0.517387] dma-buf: Running dma_fence/sanitycheck
                          [    0.522190] dma-buf: Running dma_fence/test_signaling
                          [    0.527281] dma-buf: Running dma_fence/test_add_callback
                          [    0.532603] dma-buf: Running dma_fence/test_late_add_callback
                          [    0.538378] dma-buf: Running dma_fence/test_rm_callback
                          [    0.543595] dma-buf: Running dma_fence/test_late_rm_callback
                          [    0.549266] dma-buf: Running dma_fence/test_status
                          [    0.554067] dma-buf: Running dma_fence/test_error
                          [    0.558784] dma-buf: Running dma_fence/test_wait
                          [    0.563396] dma-buf: Running dma_fence/test_wait_timeout
                          [    0.605408] dma-buf: Running dma_fence/test_stub
                          [    0.610065] dma-buf: Running dma_fence/race_signal_callback
                          [    0.685465] platform 2000c17.pwm7: pinctrl_get failed
                          [    0.690544] [DISP] disp_device_attached_and_enable,line:233:
                          [    0.690548] attached ok, mgr0<-->dev0
                          [    0.699925] thread_signal_callback[0] completed 37409 passes, 2729 misses
                          [    0.706767] thread_signal_callback[1] completed 48227 passes, 13547 misses
                          [    0.706790] [DISP] disp_device_attached_and_enable,line:236:
                          [    0.706798] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
                          [    0.795416] thread_signal_callback[0] completed 42021 passes, 42020 misses
                          [    0.802318] thread_signal_callback[1] completed 42076 passes, 42075 misses
                          [    0.809991] libphy: Fixed MDIO Bus: probed
                          [    0.814604] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                          [    0.821184] sunxi-ehci: EHCI SUNXI driver
                          [    0.825559] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                          [    0.831762] sunxi-ohci: OHCI SUNXI driver
                          [    0.836095] i2c /dev entries driver
                          [    0.839686] IR NEC protocol handler initialized
                          [    0.844232] IR RC5(x/sz) protocol handler initialized
                          [    0.849308] Bluetooth: HCI UART driver ver 2.3
                          [    0.853746] Bluetooth: HCI UART protocol H4 registered
                          [    0.858904] Bluetooth: HCI UART protocol BCSP registered
                          [    0.865492] exFAT: Version 1.3.0
                          [    0.869118] NET: Registered protocol family 17
                          [    0.873971] Registering SWP/SWPB emulation handler
                          [    0.895758] UBI error: cannot open mtd sys, error -2
                          [    0.900735] UBI: block: can't open volume on ubi0_-1, err=-19
                          [    0.908304] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
                          [    0.915439] clk: Not disabling unused clocks
                          [    0.917013] cfg80211: failed to load regulatory.db
                          [    0.921200] alloc_fd: slot 0 not NULL!
                          [    0.929795] Warning: unable to open an initial console.
                          [    0.935182] /dev/root: Can't open blockdev
                          [    0.939302] VFS: Cannot open root device "ubiblock0_5" or unknown-block(0,0): error -6
                          [    0.947254] Please append a correct "root=" boot option; here are the available partitions:
                          [    0.955624] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
                          [    0.963906] CPU0: stopping
                          [    0.966624] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.61 #26
                          [    0.972619] Hardware name: Generic DT based system
                          [    0.977432] [<c010de4c>] (unwind_backtrace) from [<c010a5f4>] (show_stack+0x10/0x14)
                          [    0.985196] [<c010a5f4>] (show_stack) from [<c0583c08>] (dump_stack+0x88/0xa4)
                          [    0.992437] [<c0583c08>] (dump_stack) from [<c010c234>] (handle_IPI+0xe4/0x180)
                          [    0.999759] [<c010c234>] (handle_IPI) from [<c02f13b4>] (gic_handle_irq+0x70/0x78)
                          [    1.007341] [<c02f13b4>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
                          [    1.014836] Exception stack(0xc0901f40 to 0xc0901f88)
                          [    1.019885] 1f40: 000002a4 c76b9334 00000000 c0114740 00000001 c0900000 c0903de8 c0903e24
                          [    1.028070] 1f60: c093b000 c77ff600 c08240c0 00000000 c0a41748 c0901f90 c0107f48 c0107f38
                          [    1.036250] 1f80: 60000013 ffffffff
                          [    1.039749] [<c01021cc>] (__irq_svc) from [<c0107f38>] (arch_cpu_idle+0x1c/0x38)
                          [    1.047165] [<c0107f38>] (arch_cpu_idle) from [<c013d3dc>] (do_idle+0xd4/0x128)
                          [    1.054493] [<c013d3dc>] (do_idle) from [<c013d6c8>] (cpu_startup_entry+0x18/0x20)
                          [    1.062066] [<c013d6c8>] (cpu_startup_entry) from [<c0800c74>] (start_kernel+0x358/0x3e8)
                          [    1.070243] [<c0800c74>] (start_kernel) from [<00000000>] (0x0)
                          [    1.076179] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
                          劳烦大神帮忙看看,我有修改过root=ubi0_5,也一样挂载不了
                          whycan YuzukiTsuru 2 条回复 最后回复 回复 引用 分享 2
                            @zhice-yang
                            用对比软件对比上面两个的日志看看。
                            Z 1 条回复 最后回复 回复 引用 分享 2
                            • K
                              kang2638729651 LV 2 最后由 编辑
                              我尝试了楼主的补丁,发现烧写到tf卡是可以正常启动的,但是烧写到spi nand也是挂载不了根文件系统,下面是出错的log,使用的芒果的mq-r开发板,spi nand flash型号为GD5F1GQ4UAYIG。
                              [30]HELLO! BOOT0 is starting!
                              [36]set pll start
                              [44]set pll end
                              [46][pmu]: bus read error
                              [48]board init ok
                              [50]ZQ value = 0x2f
                              [52]get_pmu_exist() = -1
                              [60]DRAM Type = 3 (2:DDR2,3:DDR3)
                              [63]DRAMC read ODT  off.
                              [68]ddr_efuse_type: 0xa
                              [71]DRAM SIZE =128 M
                              [73]dram_tpr4:0x0
                              [90]rtc standby flag is 0x0, super standby flag is 0x0
                              [95]dram size =128
                              [98]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
                              [103]block from 8 to 32
                              [204]Check is correct.
                              [206]dma 0x29c0c int is not used yet
                              [209]dma 0x29c0c int is free, you do not need to free it again
                              [215]Entry_name        = u-boot
                              [221]Entry_name        = optee
                              [225]Entry_name        = dtb
                              [228]Jump to second Boot.
                              U-Boot 2018.05-g24521d6-dirty (Sep 07 2022 - 00:18:43 +0800) Allwinner Technology
                              [00.281]CPU:   Allwinner Family
                              [00.284]Model: sun8iw20
                              ready
                              [00.305]DRAM:  128 MiB
                              [00.308]Relocation Offset is: 04f01000
                              [00.328]secure enable bit: 0
                              [00.330]smc_tee_inform_fdt failed with: -65526[00.335]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
                              [00.341]gic: sec monitor mode
                              [00.344]flash init start
                              [00.346]workmode = 0,storage type = 0
                              [00.393]sunxi-spinand-phy: not detect any munufacture from id table
                              [00.399]sunxi-spinand-phy: get spi-nand Model from fdt fail
                              [00.404]sunxi-spinand-phy: get phy info from fdt fail
                              defaults:
                              mtdids  : nand0=nand
                              [00.519]sunxi-spinand-phy: [SPINAND]: ecc err 0x8
                              [00.548]ubi0: attaching mtd4
                              [00.663]ubi0: scanning is finished
                              [00.670]ubi0: attached mtd4 (name "sys", size 123 MiB)
                              [00.675]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
                              [00.681]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
                              [00.687]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
                              [00.693]ubi0: good PEBs: 426, bad PEBs: 66, corrupted PEBs: 0
                              [00.699]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
                              [00.706]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
                              [00.713]ubi0: available PEBs: 0, total reserved PEBs: 426, PEBs reserved for bad PEB handling: 0
                              [00.722]sunxi flash init ok
                              [00.847]Loading Environment from SUNXI_FLASH... OK
                              [00.871]Item0 (Map) magic is bad
                              [00.877]secure storage read widevine fail with:-1
                              [00.884]secure storage read ec_key fail with:-1
                              [00.892]secure storage read ec_cert1 fail with:-1
                              [00.899]secure storage read ec_cert2 fail with:-1
                              [00.907]secure storage read ec_cert3 fail with:-1
                              [00.914]secure storage read rsa_key fail with:-1
                              [00.921]secure storage read rsa_cert1 fail with:-1
                              [00.929]secure storage read rsa_cert2 fail with:-1
                              [00.937]secure storage read rsa_cert3 fail with:-1
                              [00.941]out of usb burn from boot: not need burn key
                              [00.960]update bootcmd
                              [00.975]change working_fdt 0x43ec0e70 to 0x43ea0e70
                              [00.993]update dts
                              [02.264]no vendor_boot partition is found
                              [02.275]Starting kernel ...
                              [    0.000000] Linux version 5.4.61 (kang@ubuntu) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #6 SMP PREEMPT Tue Sep 6 17:40:36 UTC 2022
                              [    0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/pseudo_init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:private@ubi0_6:rootfs_data@ubi0_7:UDISK@ubi0_8: cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-g24521d6-dirty(09/07/2022-00:18:43) aw-ubi-spinand.ubootblks=24 androidboot.dramsize=128
                              [    0.000000] Memory: 117844K/131072K available (6144K kernel code, 264K rwdata, 1504K rodata, 1024K init, 1164K bss, 13228K reserved, 0K cma-reserved)
                              [    0.008016] Switching to timer-based delay loop, resolution 41ns
                              [    0.014209] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
                              [    0.023915] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
                              [    0.034280] pid_max: default: 32768 minimum: 301
                              [    0.039004] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                              [    0.046318] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                              [    0.054669] CPU: Testing write buffer coherency: ok
                              [    0.059869] /cpus/cpu@0 missing clock-frequency property
                              [    0.065202] /cpus/cpu@1 missing clock-frequency property
                              [    0.070540] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                              [    0.076691] Setting up static identity map for 0x40100000 - 0x40100060
                              [    0.083348] rcu: Hierarchical SRCU implementation.
                              [    0.088563] smp: Bringing up secondary CPUs ...
                              [    0.094197] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                              [    0.094315] smp: Brought up 1 node, 2 CPUs
                              [    0.104135] SMP: Total of 2 processors activated (96.00 BogoMIPS).
                              [    0.110313] CPU: All CPU(s) started in SVC mode.
                              [    0.115396] devtmpfs: initialized
                              [    0.129682] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
                              [    0.137802] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                              [    0.147666] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
                              [    0.154574] pinctrl core: initialized pinctrl subsystem
                              [    0.160709] NET: Registered protocol family 16
                              [    0.165764] DMA: preallocated 256 KiB pool for atomic coherent allocations
                              [    0.201311] rtc_ccu: sunxi ccu init OK
                              [    0.207224] ccu: sunxi ccu init OK
                              [    0.210957] r_ccu: sunxi ccu init OK
                              [    0.236558] iommu: Default domain type: Translated
                              [    0.241617] sunxi iommu: irq = 24
                              [    0.245796] SCSI subsystem initialized
                              [    0.249757] usbcore: registered new interface driver usbfs
                              [    0.255344] usbcore: registered new interface driver hub
                              [    0.260746] usbcore: registered new device driver usb
                              [    0.266565] Advanced Linux Sound Architecture Driver Initialized.
                              [    0.273197] Bluetooth: Core ver 2.22
                              [    0.277070] NET: Registered protocol family 31
                              [    0.281508] Bluetooth: HCI device and connection manager initialized
                              [    0.287905] Bluetooth: HCI socket layer initialized
                              [    0.292805] Bluetooth: L2CAP socket layer initialized
                              [    0.297882] Bluetooth: SCO socket layer initialized
                              [    0.303027] pwm module init!
                              [    0.307146] g2d 5410000.g2d: Adding to iommu group 0
                              [    0.312430] G2D: rcq version initialized.major:252
                              [    0.318025] clocksource: Switched to clocksource arch_sys_counter
                              [    0.332554] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
                              [    0.341805] NET: Registered protocol family 2
                              [    0.346733] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                              [    0.355147] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
                              [    0.362844] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
                              [    0.369931] TCP: Hash tables configured (established 1024 bind 1024)
                              [    0.376375] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
                              [    0.382963] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
                              [    0.390140] NET: Registered protocol family 1
                              [    0.395435] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
                              [    0.405718] spi spi0: spi0 supply spi not found, using dummy regulator
                              [    0.412443] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
                              [    0.418617] sunxi_spi_resource_get()2189 - Failed to get sample mode
                              [    0.424987] sunxi_spi_resource_get()2194 - Failed to get sample delay
                              [    0.431443] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
                              [    0.439861] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
                              [    0.446104] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8860000, irq 40
                              [    0.455713] workingset: timestamp_bits=30 max_order=15 bucket_order=0
                              [    0.466332] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                              [    0.472380] ntfs: driver 2.1.32 [Flags: R/W].
                              [    0.507169] io scheduler mq-deadline registered
                              [    0.511734] io scheduler kyber registered
                              [    0.516992] [DISP]disp_module_init
                              [    0.520926] disp 5000000.disp: Adding to iommu group 0
                              [    0.526565] [DISP] parser_disp_init_para,line:1430:
                              [    0.526568] of_property_read fb0_width fail
                              [    0.552043] display_fb_request,fb_id:0
                              [    0.558967] [DISP] Fb_copy_boot_fb,line:1443:
                              [    0.558971] no boot_fb0
                              [    0.566342] disp_al_manager_apply ouput_type:0
                              [    0.568239] [DISP]disp_module_init finish
                              [    0.571333] [DISP] lcd_clk_config,line:744:
                              [    0.571344] disp 0, clk: pll(420000000),clk(420000000),dclk(70000000) dsi_rate(70000000)
                              [    0.571344]      clk real:pll(420000000),clk(420000000),dclk(105000000) dsi_rate(150000000)
                              [    0.575810] sunxi_sid_init()551 - insmod ok
                              [    0.600677] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
                              [    0.610866] uart uart3: get regulator failed
                              [    0.615151] uart uart3: uart3 supply uart not found, using dummy regulator
                              [    0.622318] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
                              [    0.630185] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
                              ?[    0.638185] printk: console [ttyS3] enabled
                              [    0.647070] printk: bootconsole [earlycon0] disabled
                              [    0.648554] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
                              [    0.679184] misc dump reg init
                              [    0.683687] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
                              [    0.694816] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
                              [    0.702014] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
                              [    0.709298] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
                              [    0.716657] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
                              [    0.723160] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
                              [    0.730069] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
                              [    0.737730] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
                              [    0.745540] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
                              [    0.753598] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
                              [    0.761181] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
                              [    0.767872] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
                              [    0.775370] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=141 assert=0
                              [    0.782841] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
                              [    0.794489] [ADDR_MGT] addr_mgt_probe: module version: v1.0.10
                              [    0.801633] [ADDR_MGT] addr_mgt_probe: success.
                              [    0.806921] dma-buf: Running sanitycheck
                              [    0.811348] dma-buf: Running dma_fence
                              [    0.815514] sizeof(dma_fence)=48
                              [    0.819212] dma-buf: Running dma_fence/sanitycheck
                              [    0.824555] dma-buf: Running dma_fence/test_signaling
                              [    0.830223] dma-buf: Running dma_fence/test_add_callback
                              [    0.836134] dma-buf: Running dma_fence/test_late_add_callback
                              [    0.842548] dma-buf: Running dma_fence/test_rm_callback
                              [    0.848370] dma-buf: Running dma_fence/test_late_rm_callback
                              [    0.854664] dma-buf: Running dma_fence/test_status
                              [    0.859999] dma-buf: Running dma_fence/test_error
                              [    0.865224] dma-buf: Running dma_fence/test_wait
                              [    0.870371] dma-buf: Running dma_fence/test_wait_timeout
                              [    0.908035] dma-buf: Running dma_fence/test_stub
                              [    0.913185] dma-buf: Running dma_fence/race_signal_callback
                              [    0.968202] [DISP] disp_device_attached_and_enable,line:233:
                              [    0.968208] attached ok, mgr0<-->dev0
                              [    0.988028] [DISP] disp_device_attached_and_enable,line:236:
                              [    0.988036] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
                              [    1.003638] thread_signal_callback[0] completed 30889 passes, 31 misses
                              [    1.011040] thread_signal_callback[1] completed 38892 passes, 8033 misses
                              [    1.088048] thread_signal_callback[0] completed 43504 passes, 43503 misses
                              [    1.095723] thread_signal_callback[1] completed 43476 passes, 43475 misses
                              [    1.103886] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
                              [    1.111116] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
                              [    1.118982] sunxi-spinand-phy: not detect any munufacture from id table
                              [    1.126343] sunxi-spinand-phy: get spi-nand Model from fdt fail
                              [    1.132950] sunxi-spinand-phy: get phy info from fdt fail
                              [    1.138966] sunxi-spinand-phy: not detect munufacture from fdt
                              [    1.145595] sunxi-spinand-phy: detect munufacture from id table: GD
                              [    1.152591] sunxi-spinand-phy: get spi-nand Model from fdt fail
                              [    1.159229] sunxi-spinand-phy: get phy info from fdt fail
                              [    1.165231] sunxi-spinand-phy: not detect munufacture from fdt
                              [    1.171731] sunxi-spinand-phy: not match spinand: f1c8f1c8 f1c8f1c8
                              [    1.179121] libphy: Fixed MDIO Bus: probed
                              [    1.184395] sunxi gmac driver's version: 1.0.0
                              [    1.189513] gmac-power0: NULL
                              [    1.192809] gmac-power1: NULL
                              [    1.196103] gmac-power2: NULL
                              [    1.200503] Failed to alloc md5
                              [    1.204006] eth0: Use random mac address
                              [    1.208662] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                              [    1.215923] sunxi-ehci: EHCI SUNXI driver
                              [    1.220840] get ehci1-controller wakeup-source is fail.
                              [    1.226748] sunxi ehci1-controller don't init wakeup source
                              [    1.232968] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b5e4e0, 0x:c8877000, irq_no:3c
                              [    1.244907] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
                              [    1.257319] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
                              [    1.269399] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
                              [    1.276592] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
                              [    1.286320] sunxi-ehci 4200000.ehci1-controller: irq 60, io mem 0x04200000
                              [    1.318039] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
                              [    1.326587] hub 1-0:1.0: USB hub found
                              [    1.330828] hub 1-0:1.0: 1 port detected
                              [    1.335757] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                              [    1.342699] sunxi-ohci: OHCI SUNXI driver
                              [    1.347636] get ohci1-controller wakeup-source is fail.
                              [    1.353573] sunxi ohci1-controller don't init wakeup source
                              [    1.359788] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b5e770
                              [    1.369403] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
                              [    1.381780] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
                              [    1.393893] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
                              [    1.401109] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
                              [    1.410844] sunxi-ohci 4200400.ohci1-controller: irq 61, io mem 0x04200400
                              [    1.492821] hub 2-0:1.0: USB hub found
                              [    1.497029] hub 2-0:1.0: 1 port detected
                              [    1.502085] i2c /dev entries driver
                              [    1.506050] sunxi cedar version 1.1
                              [    1.510140] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
                              [    1.516372] VE: sunxi_cedar_probe power-domain init!!!
                              [    1.522108] VE: install start!!!
                              [    1.522108]
                              [    1.527581] VE: cedar-ve the get irq is 41
                              [    1.527581]
                              [    1.533984] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
                              [    1.533984]
                              [    1.543203] VE: install end!!!
                              [    1.543203]
                              [    1.548253] VE: sunxi_cedar_probe
                              [    1.552206] Bluetooth: HCI UART driver ver 2.3
                              [    1.557151] Bluetooth: HCI UART protocol H4 registered
                              [    1.562889] Bluetooth: HCI UART protocol BCSP registered
                              [    1.568806] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
                              [    1.577432] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
                              [    1.587340] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
                              [    1.593517] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
                              [    1.599823] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
                              [    1.606214] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
                              [    1.612634] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
                              [    1.619137] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
                              [    1.625626] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
                              [    1.632122] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
                              [    1.639047] sunxi-mmc 4020000.sdmmc: Got CD GPIO
                              [    1.644282] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
                              [    1.650876] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                              [    1.661952] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
                              [    1.682050] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                              [    1.706387] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
                              [    1.712059] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                              [    1.723594] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
                              [    1.733488] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
                              [    1.739669] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
                              [    1.745967] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
                              [    1.752372] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
                              [    1.758780] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
                              [    1.765269] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
                              [    1.771775] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
                              [    1.778273] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
                              [    1.784771] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
                              [    1.794034] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                              [    1.805144] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                              [    1.825241] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                              [    1.849389] sunxi-mmc 4021000.sdmmc: detmode:manually by software
                              [    1.857012] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                              [    1.864059] sunxi_led_probe()1749 - start
                              [    1.868552] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                              [    1.875370] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                              [    1.886945] sunxi_get_str_of_property()1595 - failed to get the string of propname led_regulator!
                              [    1.889914] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                              [    1.896844] sunxi_register_led_classdev()1483 - led_classdev start
                              [    1.910494] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                              [    1.916171] sunxi_led_probe()1845 - finish
                              [    1.922743] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                              [    1.926685] exFAT: Version 1.3.0
                              [    1.933987] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                              [    1.944365] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                              [    1.945197] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
                              [    1.945197]
                              [    1.951172] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                              [    1.968137] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
                              [    1.968585] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
                              [    1.999082] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
                              [    2.008864] [SNDCODEC][sunxi_card_init][583]:card init finished
                              [    2.015772] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
                              [    2.026587] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
                              [    2.038466] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
                              [    2.046779] NET: Registered protocol family 10
                              [    2.052825] Segment Routing with IPv6
                              [    2.056978] NET: Registered protocol family 17
                              [    2.061974] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
                              [    2.068221] Bluetooth: RFCOMM TTY layer initialized
                              [    2.074665] Bluetooth: RFCOMM socket layer initialized
                              [    2.080451] Bluetooth: RFCOMM ver 1.11
                              [    2.085195] Registering SWP/SWPB emulation handler
                              [    2.107250] get ehci0-controller wakeup-source is fail.
                              [    2.113280] sunxi ehci0-controller don't init wakeup source
                              [    2.119523] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b5dfc0, 0x:c88fb000, irq_no:3a
                              [    2.131461] [sunxi-ehci0]: Not init ehci0
                              [    2.136259] get ohci0-controller wakeup-source is fail.
                              [    2.142191] sunxi ohci0-controller don't init wakeup source
                              [    2.148431] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b5e250
                              [    2.158024] [sunxi-ohci0]: Not init ohci0
                              [    2.163026] UBI error: cannot open mtd sys, error -2
                              [    2.168600] UBI: block: can't open volume on ubi0_-1, err=-19
                              [    2.177702] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
                              [    2.187348] cfg80211: failed to load regulatory.db
                              [    2.187355] clk: Not disabling unused clocks
                              [    2.197454] ALSA device list:
                              [    2.200763]   #0: audiocodec
                              [    2.203970] alloc_fd: slot 0 not NULL!
                              [    2.208496] /dev/root: Can't open blockdev
                              [    2.213063] VFS: Cannot open root device "ubiblock0_5" or unknown-block(0,0): error -6
                              [    2.221887] Please append a correct "root=" boot option; here are the available partitions:
                              [    2.231188] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
                              [    2.240389] CPU0: stopping
                              [    2.243404] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.61 #6
                              [    2.249985] Hardware name: Generic DT based system
                              [    2.255337] [<c010de4c>] (unwind_backtrace) from [<c010a5f4>] (show_stack+0x10/0x14)
                              [    2.263954] [<c010a5f4>] (show_stack) from [<c061fb28>] (dump_stack+0x88/0xa4)
                              [    2.271997] [<c061fb28>] (dump_stack) from [<c010c234>] (handle_IPI+0xe4/0x180)
                              [    2.280132] [<c010c234>] (handle_IPI) from [<c02f13b4>] (gic_handle_irq+0x70/0x78)
                              [    2.288564] [<c02f13b4>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
                              [    2.296881] Exception stack(0xc0a01f40 to 0xc0a01f88)
                              [    2.302505] 1f40: 000006a8 c7ebd334 00000000 c0114740 00000001 c0a00000 c0a03de8 c0a03e24
                              [    2.311600] 1f60: c0a43000 c7ffc580 c09270c0 00000000 c0b49748 c0a01f90 c0107f48 c0107f38
                              [    2.320698] 1f80: 60000013 ffffffff
                              [    2.324583] [<c01021cc>] (__irq_svc) from [<c0107f38>] (arch_cpu_idle+0x1c/0x38)
                              [    2.332819] [<c0107f38>] (arch_cpu_idle) from [<c013d3dc>] (do_idle+0xd4/0x128)
                              [    2.340953] [<c013d3dc>] (do_idle) from [<c013d6c8>] (cpu_startup_entry+0x18/0x20)
                              [    2.349383] [<c013d6c8>] (cpu_startup_entry) from [<c0900c74>] (start_kernel+0x358/0x3e8)
                              [    2.358484] [<c0900c74>] (start_kernel) from [<00000000>] (0x0)
                              [    2.365079] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
                              YuzukiTsuru DAIZEBIN 2 条回复 最后回复 回复 引用 分享 3
                                柚木 鉉 LV 9 @kang2638729651 最后由 编辑
                                @kang2638729651
                                nand型号没识别上,估计驱动要加一下型号
                                K 1 条回复 最后回复 回复 引用 分享 2
                                  柚木 鉉 LV 9 @Zhice.Yang 最后由 xiaowenge 编辑
                                  @zhice-yang
                                  UBI 完全没有挂载上,检查一下UBI驱动配置部分,mtd那部分是不是适配nand芯片
                                  Z 2 条回复 最后回复 回复 引用 分享 2
                                      Zhice.Yang LV 4 @YuzukiTsuru 最后由 编辑
                                      • K
                                        kang2638729651 LV 2 @YuzukiTsuru 最后由 编辑
                                        @yuzukitsuru 非常感谢您,我确实只在uboot中添加了nand flash相应的参数,未在kernel中添加nand flash的参数。
                                        重新在kernel中添加GD NAND Flash GD5F1GQ4UBYIG的相关参数后,我的Mq-R已经可以正常启动了。
                                        下面是添加的Nand Flash参数,需要同时在
                                        tina-d1-h/lichee/brandy-2.0/u-boot-2018/drivers/mtd/awnand/spinand/physic/id.c
                                        和
                                        tina-d1-h/lichee/linux-5.4/drivers/mtd/awnand/spinand/physic/id.c
                                        添加下面的参数。
                                        struct aw_spinand_phy_info gigadevice[] =
                                        		.Model		= "GD5F1GQ4UBYIG",
                                        		.NandID		= {0xc8, 0xf1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff},
                                        		.DieCntPerChip  = 1,
                                        		.SectCntPerPage = 4,
                                        		.PageCntPerBlk  = 64,
                                        		.BlkCntPerDie	= 1024,
                                        		.OobSizePerPage = 64,
                                        		.OperationOpt	= SPINAND_QUAD_READ | SPINAND_QUAD_PROGRAM |
                                        			SPINAND_DUAL_READ,
                                        		.MaxEraseTimes  = 50000,
                                        		.EccFlag	= HAS_EXT_ECC_SE01,
                                        		.EccType	= BIT4_LIMIT5_TO_7_ERR8_LIMIT_12,
                                        		.EccProtectedType = SIZE16_OFF4_LEN8_OFF4,
                                        		.BadBlockFlag	= BAD_BLK_FLAG_FRIST_1_PAGE,
                                        最后是我的启动日志
                                        [158]HELLO! BOOT0 is starting!
                                        [161]BOOT0 commit : 88480af-dirty
                                        [164]set pll start
                                        [166]fix vccio detect value:0xc0
                                        [174]periph0 has been enabled
                                        [177]set pll end
                                        [178][pmu]: bus read error
                                        [181]board init ok
                                        [183]ZQ value = 0x2e
                                        [185]get_pmu_exist() = -1
                                        [187]DRAM BOOT DRIVE INFO: V0.33
                                        [190]DRAM CLK = 936 MHz
                                        [192]DRAM Type = 3 (2:DDR2,3:DDR3)
                                        [196]DRAMC read ODT  off.
                                        [198]DRAM ODT value: 0x42.
                                        [201]ddr_efuse_type: 0xa
                                        [204]DRAM SIZE =128 M
                                        [206]dram_tpr4:0x0
                                        [208]PLL_DDR_CTRL_REG:0xf8004d00
                                        [211]DRAM_CLK_REG:0xc0000000
                                        [214][TIMING DEBUG] MR2= 0x20
                                        [221]DRAM simple test OK.
                                        [223]rtc standby flag is 0x0, super standby flag is 0x0
                                        [229]dram size =128
                                        [232]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
                                        [237]block from 8 to 32
                                        [338]Check is correct.
                                        [340]dma 0x29c0c int is not used yet
                                        [343]dma 0x29c0c int is free, you do not need to free it again
                                        [349]Entry_name        = u-boot
                                        [355]Entry_name        = optee
                                        [358]Entry_name        = dtb
                                        [361]Jump to second Boot.
                                        U-Boot 2018.05-g24521d6-dirty (Sep 07 2022 - 11:48:59 +0800) Allwinner Technology
                                        [00.415]CPU:   Allwinner Family
                                        [00.418]Model: sun8iw20
                                        ready
                                        [00.439]DRAM:  128 MiB
                                        [00.442]Relocation Offset is: 04f01000
                                        [00.462]secure enable bit: 0
                                        [00.464]smc_tee_inform_fdt failed with: -65526[00.469]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
                                        [00.475]gic: sec monitor mode
                                        [00.478]flash init start
                                        [00.480]workmode = 0,storage type = 0
                                        [BCC] 0x4025038 = 0x20000000, [DMA] 0x4025088 = 0x000000e5
                                        [00.527]sunxi-spinand-phy: not detect any munufacture from id table
                                        [00.533]sunxi-spinand-phy: get spi-nand Model from fdt fail
                                        [00.538]sunxi-spinand-phy: get phy info from fdt fail
                                        defaults:
                                        mtdids  : nand0=nand
                                        [00.653]sunxi-spinand-phy: [SPINAND]: ecc err 0x8
                                        [00.682]ubi0: attaching mtd4
                                        [00.797]ubi0: scanning is finished
                                        [00.804]ubi0: attached mtd4 (name "sys", size 123 MiB)
                                        [00.809]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
                                        [00.815]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
                                        [00.821]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
                                        [00.827]ubi0: good PEBs: 426, bad PEBs: 66, corrupted PEBs: 0
                                        [00.833]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
                                        [00.839]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
                                        [00.847]ubi0: available PEBs: 0, total reserved PEBs: 426, PEBs reserved for bad PEB handling: 0
                                        [00.856]sunxi flash init ok
                                        [00.981]Loading Environment from SUNXI_FLASH... OK
                                        [01.005]Item0 (Map) magic is bad
                                        [01.011]secure storage read widevine fail with:-1
                                        [01.018]secure storage read ec_key fail with:-1
                                        [01.026]secure storage read ec_cert1 fail with:-1
                                        [01.033]secure storage read ec_cert2 fail with:-1
                                        [01.041]secure storage read ec_cert3 fail with:-1
                                        [01.048]secure storage read rsa_key fail with:-1
                                        [01.055]secure storage read rsa_cert1 fail with:-1
                                        [01.063]secure storage read rsa_cert2 fail with:-1
                                        [01.071]secure storage read rsa_cert3 fail with:-1
                                        [01.075]out of usb burn from boot: not need burn key
                                        [01.094]update bootcmd
                                        [01.109]change working_fdt 0x43ec0e70 to 0x43ea0e70
                                        [01.127]update dts
                                        [02.398]no vendor_boot partition is found
                                        Android's image name: t113-nezha
                                        [02.408]Starting kernel ...
                                        [    0.000000] Linux version 5.4.61 (kang@ubuntu) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #9 SMP PREEMPT Wed Sep 7 03:55:00 UTC 2022
                                        [    0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/pseudo_init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:private@ubi0_6:rootfs_data@ubi0_7:UDISK@ubi0_8: cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-g24521d6-dirty(09/07/2022-11:48:59) aw-ubi-spinand.ubootblks=24 androidboot.dramsize=128
                                        [    0.008017] Switching to timer-based delay loop, resolution 41ns
                                        [    0.014198] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
                                        [    0.023901] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
                                        [    0.034283] pid_max: default: 32768 minimum: 301
                                        [    0.039016] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                                        [    0.046340] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                                        [    0.059878] /cpus/cpu@0 missing clock-frequency property
                                        [    0.065228] /cpus/cpu@1 missing clock-frequency property
                                        [    0.070558] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                                        [    0.076698] Setting up static identity map for 0x40100000 - 0x40100060
                                        [    0.083353] rcu: Hierarchical SRCU implementation.
                                        [    0.088561] smp: Bringing up secondary CPUs ...
                                        [    0.094187] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                                        [    0.094304] smp: Brought up 1 node, 2 CPUs
                                        [    0.104133] SMP: Total of 2 processors activated (96.00 BogoMIPS).
                                        [    0.110311] CPU: All CPU(s) started in SVC mode.
                                        [    0.115387] devtmpfs: initialized
                                        [    0.129645] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
                                        [    0.137781] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                                        [    0.147653] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
                                        [    0.154603] pinctrl core: initialized pinctrl subsystem
                                        [    0.160750] NET: Registered protocol family 16
                                        [    0.165802] DMA: preallocated 256 KiB pool for atomic coherent allocations
                                        [    0.201359] rtc_ccu: sunxi ccu init OK
                                        [    0.207294] ccu: sunxi ccu init OK
                                        [    0.211029] r_ccu: sunxi ccu init OK
                                        [    0.236536] iommu: Default domain type: Translated
                                        [    0.241597] sunxi iommu: irq = 24
                                        [    0.245771] SCSI subsystem initialized
                                        [    0.249724] usbcore: registered new interface driver usbfs
                                        [    0.255311] usbcore: registered new interface driver hub
                                        [    0.260702] usbcore: registered new device driver usb
                                        [    0.266545] Advanced Linux Sound Architecture Driver Initialized.
                                        [    0.273170] Bluetooth: Core ver 2.22
                                        [    0.277021] NET: Registered protocol family 31
                                        [    0.281477] Bluetooth: HCI device and connection manager initialized
                                        [    0.287866] Bluetooth: HCI socket layer initialized
                                        [    0.292747] Bluetooth: L2CAP socket layer initialized
                                        [    0.297842] Bluetooth: SCO socket layer initialized
                                        [    0.303004] pwm module init!
                                        [    0.307126] g2d 5410000.g2d: Adding to iommu group 0
                                        [    0.312394] G2D: rcq version initialized.major:252
                                        [    0.317990] clocksource: Switched to clocksource arch_sys_counter
                                        [    0.332511] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
                                        [    0.341801] NET: Registered protocol family 2
                                        [    0.346744] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                                        [    0.355163] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
                                        [    0.362869] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
                                        [    0.369948] TCP: Hash tables configured (established 1024 bind 1024)
                                        [    0.376412] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
                                        [    0.382998] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
                                        [    0.390186] NET: Registered protocol family 1
                                        [    0.395495] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
                                        [    0.405785] spi spi0: spi0 supply spi not found, using dummy regulator
                                        [    0.412518] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
                                        [    0.418673] sunxi_spi_resource_get()2189 - Failed to get sample mode
                                        [    0.425044] sunxi_spi_resource_get()2194 - Failed to get sample delay
                                        [    0.431499] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
                                        [    0.439916] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
                                        [    0.446134] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8860000, irq 40
                                        [    0.455760] workingset: timestamp_bits=30 max_order=15 bucket_order=0
                                        [    0.466378] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                                        [    0.472417] ntfs: driver 2.1.32 [Flags: R/W].
                                        [    0.505191] io scheduler mq-deadline registered
                                        [    0.509761] io scheduler kyber registered
                                        [    0.515016] [DISP]disp_module_init
                                        [    0.518925] disp 5000000.disp: Adding to iommu group 0
                                        [    0.524588] [DISP] parser_disp_init_para,line:1430:
                                        [    0.524592] of_property_read fb0_width fail
                                        [    0.550062] display_fb_request,fb_id:0
                                        [    0.556929] [DISP] Fb_copy_boot_fb,line:1443:
                                        [    0.556932] no boot_fb0
                                        [    0.564316] disp_al_manager_apply ouput_type:0
                                        [    0.568208] [DISP]disp_module_init finish
                                        [    0.569201] [DISP] lcd_clk_config,line:744:
                                        [    0.569211] disp 0, clk: pll(420000000),clk(420000000),dclk(70000000) dsi_rate(70000000)
                                        [    0.569211]      clk real:pll(420000000),clk(420000000),dclk(105000000) dsi_rate(150000000)
                                        [    0.573831] sunxi_sid_init()551 - insmod ok
                                        [    0.598635] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
                                        [    0.608831] uart uart3: get regulator failed
                                        [    0.613106] uart uart3: uart3 supply uart not found, using dummy regulator
                                        [    0.620264] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
                                        [    0.628121] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
                                         ▒ 0.628533] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
                                        [    0.645768] printk: console [ttyS3] enabled
                                        [    0.654627] printk: bootconsole [earlycon0] disabled
                                        [    0.665928] misc dump reg init
                                        [    0.670485] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
                                        [    0.681613] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
                                        [    0.688812] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
                                        [    0.696079] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
                                        [    0.703452] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
                                        [    0.709954] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
                                        [    0.716838] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
                                        [    0.724515] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
                                        [    0.732312] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
                                        [    0.740377] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
                                        [    0.747951] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
                                        [    0.754678] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
                                        [    0.762165] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=141 assert=0
                                        [    0.769631] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
                                        [    0.781282] [ADDR_MGT] addr_mgt_probe: module version: v1.0.10
                                        [    0.788426] [ADDR_MGT] addr_mgt_probe: success.
                                        [    0.793716] dma-buf: Running sanitycheck
                                        [    0.798137] dma-buf: Running dma_fence
                                        [    0.802303] sizeof(dma_fence)=48
                                        [    0.805983] dma-buf: Running dma_fence/sanitycheck
                                        [    0.811345] dma-buf: Running dma_fence/test_signaling
                                        [    0.816963] dma-buf: Running dma_fence/test_add_callback
                                        [    0.822909] dma-buf: Running dma_fence/test_late_add_callback
                                        [    0.829316] dma-buf: Running dma_fence/test_rm_callback
                                        [    0.835129] dma-buf: Running dma_fence/test_late_rm_callback
                                        [    0.841434] dma-buf: Running dma_fence/test_status
                                        [    0.846765] dma-buf: Running dma_fence/test_error
                                        [    0.852011] dma-buf: Running dma_fence/test_wait
                                        [    0.857151] dma-buf: Running dma_fence/test_wait_timeout
                                        [    0.898008] dma-buf: Running dma_fence/test_stub
                                        [    0.903174] dma-buf: Running dma_fence/race_signal_callback
                                        [    0.928172] [DISP] disp_device_attached_and_enable,line:233:
                                        [    0.928177] attached ok, mgr0<-->dev0
                                        [    0.947991] [DISP] disp_device_attached_and_enable,line:236:
                                        [    0.947999] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
                                        [    0.978029] thread_signal_callback[0] completed 22267 passes, 39 misses
                                        [    0.985417] thread_signal_callback[1] completed 22251 passes, 25 misses
                                        [    1.058028] thread_signal_callback[0] completed 40309 passes, 40308 misses
                                        [    1.065697] thread_signal_callback[1] completed 40277 passes, 40277 misses
                                        [    1.073863] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
                                        [    1.081117] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
                                        [    1.089004] sunxi-spinand-phy: not detect any munufacture from id table
                                        [    1.096362] sunxi-spinand-phy: get spi-nand Model from fdt fail
                                        [    1.102969] sunxi-spinand-phy: get phy info from fdt fail
                                        [    1.109029] sunxi-spinand-phy: not detect munufacture from fdt
                                        [    1.115687] sunxi-spinand-phy: detect munufacture from id table: GD
                                        [    1.122684] sunxi-spinand-phy: detect spinand id: fffff1c8 ffffffff
                                        [    1.129672] sunxi-spinand-phy: ========== arch info ==========
                                        [    1.136157] sunxi-spinand-phy: Model:               GD5F1GQ4UBYIG
                                        [    1.142938] sunxi-spinand-phy: Munufacture:         GD
                                        [    1.148661] sunxi-spinand-phy: DieCntPerChip:       1
                                        [    1.154282] sunxi-spinand-phy: BlkCntPerDie:        1024
                                        [    1.160197] sunxi-spinand-phy: PageCntPerBlk:       64
                                        [    1.165903] sunxi-spinand-phy: SectCntPerPage:      4
                                        [    1.171533] sunxi-spinand-phy: OobSizePerPage:      64
                                        [    1.177239] sunxi-spinand-phy: BadBlockFlag:        0x0
                                        [    1.183071] sunxi-spinand-phy: OperationOpt:        0x7
                                        [    1.188897] sunxi-spinand-phy: MaxEraseTimes:       50000
                                        [    1.194893] sunxi-spinand-phy: EccFlag:             0x1
                                        [    1.200713] sunxi-spinand-phy: EccType:             7
                                        [    1.206328] sunxi-spinand-phy: EccProtectedType:    4
                                        [    1.211950] sunxi-spinand-phy: ========================================
                                        [    1.219307] sunxi-spinand-phy:
                                        [    1.222796] sunxi-spinand-phy: ========== physical info ==========
                                        [    1.229674] sunxi-spinand-phy: TotalSize:    128 M
                                        [    1.234998] sunxi-spinand-phy: SectorSize:   512 B
                                        [    1.240328] sunxi-spinand-phy: PageSize:     2 K
                                        [    1.245459] sunxi-spinand-phy: BlockSize:    128 K
                                        [    1.250788] sunxi-spinand-phy: OOBSize:      64 B
                                        [    1.256016] sunxi-spinand-phy: ========================================
                                        [    1.263371] sunxi-spinand-phy:
                                        [    1.266860] sunxi-spinand-phy: ========== logical info ==========
                                        [    1.273645] sunxi-spinand-phy: TotalSize:    128 M
                                        [    1.278982] sunxi-spinand-phy: SectorSize:   512 B
                                        [    1.284305] sunxi-spinand-phy: PageSize:     4 K
                                        [    1.289447] sunxi-spinand-phy: BlockSize:    256 K
                                        [    1.294769] sunxi-spinand-phy: OOBSize:      128 B
                                        [    1.300103] sunxi-spinand-phy: ========================================
                                        [    1.307581] sunxi-spinand-phy: block lock register: 0x00
                                        [    1.313683] sunxi-spinand-phy: feature register: 0x11
                                        [    1.319319] sunxi-spinand-phy: sunxi physic nand init end
                                        [    1.325764] Creating 4 MTD partitions on "sunxi_mtd_nand":
                                        [    1.331898] 0x000000000000-0x000000100000 : "boot0"
                                        [    1.348905] 0x000000100000-0x000000400000 : "uboot"
                                        [    1.357808] random: fast init done
                                        [    1.368884] 0x000000400000-0x000000500000 : "secure_storage"
                                        [    1.388839] 0x000000500000-0x000008000000 : "sys"
                                        [    1.463764] sunxi-spinand-phy: phy blk 384 is bad
                                        [    1.469225] sunxi-spinand-phy: phy blk 386 is bad
                                        [    1.474650] sunxi-spinand-phy: phy blk 388 is bad
                                        [    1.480089] sunxi-spinand-phy: phy blk 390 is bad
                                        [    1.485522] sunxi-spinand-phy: phy blk 392 is bad
                                        [    1.490961] sunxi-spinand-phy: phy blk 394 is bad
                                        [    1.496387] sunxi-spinand-phy: phy blk 396 is bad
                                        [    1.501833] sunxi-spinand-phy: phy blk 398 is bad
                                        [    1.507257] sunxi-spinand-phy: phy blk 400 is bad
                                        [    1.512693] sunxi-spinand-phy: phy blk 402 is bad
                                        [    1.518107] sunxi-spinand-phy: phy blk 404 is bad
                                        [    1.523531] sunxi-spinand-phy: phy blk 406 is bad
                                        [    1.528967] sunxi-spinand-phy: phy blk 408 is bad
                                        [    1.534397] sunxi-spinand-phy: phy blk 410 is bad
                                        [    1.539838] sunxi-spinand-phy: phy blk 412 is bad
                                        [    1.545258] sunxi-spinand-phy: phy blk 414 is bad
                                        [    1.550702] sunxi-spinand-phy: phy blk 416 is bad
                                        [    1.556124] sunxi-spinand-phy: phy blk 418 is bad
                                        [    1.561558] sunxi-spinand-phy: phy blk 420 is bad
                                        [    1.566985] sunxi-spinand-phy: phy blk 422 is bad
                                        [    1.572418] sunxi-spinand-phy: phy blk 424 is bad
                                        [    1.577838] sunxi-spinand-phy: phy blk 426 is bad
                                        [    1.583286] sunxi-spinand-phy: phy blk 428 is bad
                                        [    1.588732] sunxi-spinand-phy: phy blk 430 is bad
                                        [    1.594156] sunxi-spinand-phy: phy blk 432 is bad
                                        [    1.599601] sunxi-spinand-phy: phy blk 434 is bad
                                        [    1.605024] sunxi-spinand-phy: phy blk 436 is bad
                                        [    1.610464] sunxi-spinand-phy: phy blk 438 is bad
                                        [    1.615895] sunxi-spinand-phy: phy blk 440 is bad
                                        [    1.621341] sunxi-spinand-phy: phy blk 442 is bad
                                        [    1.626765] sunxi-spinand-phy: phy blk 444 is bad
                                        [    1.632210] sunxi-spinand-phy: phy blk 446 is bad
                                        [    1.637636] sunxi-spinand-phy: phy blk 448 is bad
                                        [    1.643073] sunxi-spinand-phy: phy blk 450 is bad
                                        [    1.648526] sunxi-spinand-phy: phy blk 452 is bad
                                        [    1.653951] sunxi-spinand-phy: phy blk 454 is bad
                                        [    1.659390] sunxi-spinand-phy: phy blk 456 is bad
                                        [    1.664818] sunxi-spinand-phy: phy blk 458 is bad
                                        [    1.670257] sunxi-spinand-phy: phy blk 460 is bad
                                        [    1.675681] sunxi-spinand-phy: phy blk 462 is bad
                                        [    1.681126] sunxi-spinand-phy: phy blk 464 is bad
                                        [    1.686552] sunxi-spinand-phy: phy blk 466 is bad
                                        [    1.691989] sunxi-spinand-phy: phy blk 468 is bad
                                        [    1.697420] sunxi-spinand-phy: phy blk 470 is bad
                                        [    1.702856] sunxi-spinand-phy: phy blk 472 is bad
                                        [    1.708295] sunxi-spinand-phy: phy blk 474 is bad
                                        [    1.713723] sunxi-spinand-phy: phy blk 476 is bad
                                        [    1.719168] sunxi-spinand-phy: phy blk 478 is bad
                                        [    1.724593] sunxi-spinand-phy: phy blk 480 is bad
                                        [    1.730037] sunxi-spinand-phy: phy blk 482 is bad
                                        [    1.735461] sunxi-spinand-phy: phy blk 484 is bad
                                        [    1.740900] sunxi-spinand-phy: phy blk 486 is bad
                                        [    1.746330] sunxi-spinand-phy: phy blk 488 is bad
                                        [    1.751767] sunxi-spinand-phy: phy blk 490 is bad
                                        [    1.757191] sunxi-spinand-phy: phy blk 492 is bad
                                        [    1.762640] sunxi-spinand-phy: phy blk 494 is bad
                                        [    1.768076] sunxi-spinand-phy: phy blk 496 is bad
                                        [    1.773499] sunxi-spinand-phy: phy blk 498 is bad
                                        [    1.778944] sunxi-spinand-phy: phy blk 500 is bad
                                        [    1.784367] sunxi-spinand-phy: phy blk 502 is bad
                                        [    1.789803] sunxi-spinand-phy: phy blk 504 is bad
                                        [    1.795236] sunxi-spinand-phy: phy blk 506 is bad
                                        [    1.800674] sunxi-spinand-phy: phy blk 508 is bad
                                        [    1.806099] sunxi-spinand-phy: phy blk 510 is bad
                                        [    1.861461] sunxi-spinand-phy: ecc err 0x8
                                        [    1.866014] sunxi-spinand-phy: phy blk 768 is bad
                                        [    1.920744] sunxi-spinand-phy: phy blk 1022 is bad
                                        [    1.929292] libphy: Fixed MDIO Bus: probed
                                        [    1.934583] sunxi gmac driver's version: 1.0.0
                                        [    1.939751] gmac-power0: NULL
                                        [    1.943045] gmac-power1: NULL
                                        [    1.946342] gmac-power2: NULL
                                        [    1.950735] Failed to alloc md5
                                        [    1.954241] eth0: Use random mac address
                                        [    1.958891] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                                        [    1.966154] sunxi-ehci: EHCI SUNXI driver
                                        [    1.971073] get ehci1-controller wakeup-source is fail.
                                        [    1.976982] sunxi ehci1-controller don't init wakeup source
                                        [    1.983206] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b5e4e0, 0x:c8877000, irq_no:3c
                                        [    1.995142] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
                                        [    2.007532] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
                                        [    2.019609] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
                                        [    2.026816] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
                                        [    2.036549] sunxi-ehci 4200000.ehci1-controller: irq 60, io mem 0x04200000
                                        [    2.068004] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
                                        [    2.076538] hub 1-0:1.0: USB hub found
                                        [    2.080776] hub 1-0:1.0: 1 port detected
                                        [    2.085695] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                                        [    2.092646] sunxi-ohci: OHCI SUNXI driver
                                        [    2.097593] get ohci1-controller wakeup-source is fail.
                                        [    2.103534] sunxi ohci1-controller don't init wakeup source
                                        [    2.109749] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b5e770
                                        [    2.119362] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
                                        [    2.131778] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
                                        [    2.143874] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
                                        [    2.151084] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
                                        [    2.160820] sunxi-ohci 4200400.ohci1-controller: irq 61, io mem 0x04200400
                                        [    2.242820] hub 2-0:1.0: USB hub found
                                        [    2.247028] hub 2-0:1.0: 1 port detected
                                        [    2.252099] i2c /dev entries driver
                                        [    2.256055] sunxi cedar version 1.1
                                        [    2.260148] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
                                        [    2.266382] VE: sunxi_cedar_probe power-domain init!!!
                                        [    2.272119] VE: install start!!!
                                        [    2.272119]
                                        [    2.277581] VE: cedar-ve the get irq is 41
                                        [    2.277581]
                                        [    2.284004] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
                                        [    2.284004]
                                        [    2.293224] VE: install end!!!
                                        [    2.293224]
                                        [    2.298272] VE: sunxi_cedar_probe
                                        [    2.302209] Bluetooth: HCI UART driver ver 2.3
                                        [    2.307152] Bluetooth: HCI UART protocol H4 registered
                                        [    2.312889] Bluetooth: HCI UART protocol BCSP registered
                                        [    2.318808] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
                                        [    2.327489] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
                                        [    2.337388] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
                                        [    2.343572] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
                                        [    2.349884] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
                                        [    2.356276] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
                                        [    2.362694] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
                                        [    2.369194] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
                                        [    2.375682] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
                                        [    2.382179] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
                                        [    2.389105] sunxi-mmc 4020000.sdmmc: Got CD GPIO
                                        [    2.394344] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
                                        [    2.400955] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    2.412022] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
                                        [    2.432115] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    2.456446] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
                                        [    2.462106] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                                        [    2.473649] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
                                        [    2.483557] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
                                        [    2.489726] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
                                        [    2.496030] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
                                        [    2.502435] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
                                        [    2.508861] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
                                        [    2.515350] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
                                        [    2.521854] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
                                        [    2.528360] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
                                        [    2.534858] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
                                        [    2.544102] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    2.555191] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                                        [    2.575305] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    2.599450] sunxi-mmc 4021000.sdmmc: detmode:manually by software
                                        [    2.607067] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                                        [    2.614141] sunxi_led_probe()1749 - start
                                        [    2.618634] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                                        [    2.625453] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    2.637013] sunxi_get_str_of_property()1595 - failed to get the string of propname led_regulator!
                                        [    2.646936] sunxi_register_led_classdev()1483 - led_classdev start
                                        [    2.654823] sunxi_led_probe()1845 - finish
                                        [    2.656838] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    2.659628] exFAT: Version 1.3.0
                                        [    2.673092] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                                        [    2.682136] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                                        [    2.682919] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
                                        [    2.682919]
                                        [    2.689741] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                                        [    2.705909] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
                                        [    2.713432] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                                        [    2.723848] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
                                        [    2.730157] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                                        [    2.739138] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
                                        [    2.759057] [SNDCODEC][sunxi_card_init][583]:card init finished
                                        [    2.765964] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
                                        [    2.776779] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
                                        [    2.788620] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
                                        [    2.796910] NET: Registered protocol family 10
                                        [    2.803001] Segment Routing with IPv6
                                        [    2.807165] NET: Registered protocol family 17
                                        [    2.812159] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
                                        [    2.818193] Bluetooth: RFCOMM TTY layer initialized
                                        [    2.824849] Bluetooth: RFCOMM socket layer initialized
                                        [    2.830611] Bluetooth: RFCOMM ver 1.11
                                        [    2.835372] Registering SWP/SWPB emulation handler
                                        [    2.857364] get ehci0-controller wakeup-source is fail.
                                        [    2.863371] sunxi ehci0-controller don't init wakeup source
                                        [    2.869636] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b5dfc0, 0x:c88fb000, irq_no:3a
                                        [    2.881560] [sunxi-ehci0]: Not init ehci0
                                        [    2.886363] get ohci0-controller wakeup-source is fail.
                                        [    2.892294] sunxi ohci0-controller don't init wakeup source
                                        [    2.898515] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b5e250
                                        [    2.908121] [sunxi-ohci0]: Not init ohci0
                                        [    2.913117] ubi0: attaching mtd3
                                        [    3.069011] random: crng init done
                                        [    3.171152] ubi0: scanning is finished
                                        [    3.183587] ubi0 warning: ubi_eba_init: number of bad PEBs (66) is above the expected limit (20), not reserving any PEBs for bad PEB handling, will use available PEBs (if any)
                                        [    3.202875] ubi0: attached mtd3 (name "sys", size 123 MiB)
                                        [    3.209034] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
                                        [    3.216679] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
                                        [    3.224250] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
                                        [    3.232012] ubi0: good PEBs: 426, bad PEBs: 66, corrupted PEBs: 0
                                        [    3.238800] ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
                                        [    3.246835] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
                                        [    3.256142] ubi0: available PEBs: 0, total reserved PEBs: 426, PEBs reserved for bad PEB handling: 0
                                        [    3.266337] ubi0: background thread "ubi_bgt0d" started, PID 73
                                        [    3.274103] block ubiblock0_5: created from ubi0:5(rootfs)
                                        [    3.283026] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
                                        [    3.292681] clk: Not disabling unused clocks
                                        [    3.292696] ALSA device list:
                                        [    3.297476] cfg80211: failed to load regulatory.db
                                        [    3.300747]   #0: audiocodec
                                        [    3.300761] alloc_fd: slot 0 not NULL!
                                        [    3.316945] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
                                        [    3.327482] devtmpfs: mounted
                                        [    3.332714] Freeing unused kernel memory: 1024K
                                        [    3.358138] Run /pseudo_init as init process
                                        [    3.571498] UBIFS (ubi0:7): Mounting in unauthenticated mode
                                        [    3.577950] UBIFS (ubi0:7): background thread "ubifs_bgt0_7" started, PID 104
                                        [    3.655167] UBIFS (ubi0:7): recovery needed
                                        [    3.768630] UBIFS (ubi0:7): recovery completed
                                        [    3.773745] UBIFS (ubi0:7): UBIFS: mounted UBI device 0, volume 7, name "rootfs_data"
                                        [    3.782531] UBIFS (ubi0:7): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
                                        [    3.793605] UBIFS (ubi0:7): FS size: 3096576 bytes (2 MiB, 12 LEBs), journal size 1806337 bytes (1 MiB, 5 LEBs)
                                        [    3.804855] UBIFS (ubi0:7): reserved for root: 146258 bytes (142 KiB)
                                        [    3.812048] UBIFS (ubi0:7): media format: w5/r0 (latest is w5/r0), UUID 96E754AE-02DC-4851-B645-5F13A3BC8374, small LPT model
                                        [    3.940809] UBIFS (ubi0:8): Mounting in unauthenticated mode
                                        [    3.947254] UBIFS (ubi0:8): background thread "ubifs_bgt0_8" started, PID 132
                                        [    4.038025] UBIFS (ubi0:8): recovery needed
                                        [    4.092902] UBIFS (ubi0:8): recovery completed
                                        [    4.097965] UBIFS (ubi0:8): UBIFS: mounted UBI device 0, volume 8, name "UDISK"
                                        [    4.106128] UBIFS (ubi0:8): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
                                        [    4.117187] UBIFS (ubi0:8): FS size: 42061824 bytes (40 MiB, 163 LEBs), journal size 2064385 bytes (1 MiB, 8 LEBs)
                                        [    4.128753] UBIFS (ubi0:8): reserved for root: 1986683 bytes (1940 KiB)
                                        [    4.136115] UBIFS (ubi0:8): media format: w5/r0 (latest is w5/r0), UUID 4C9944F6-4B29-438E-BC48-10B3FB168B63, small LPT model
                                        [    4.201265] sunxi_gpadc_init,2151, success
                                        [    4.206125] sunxi_gpadc_setup: get channel scan data failed
                                        [    4.212715] input: sunxi-gpadc0 as /devices/virtual/input/input1
                                        [    4.284130] ======== XRADIO WIFI OPEN ========
                                        [    4.289643] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
                                        [    4.296390] [XRADIO] Allocated hw_priv @ e35a60c3
                                        [    4.302217] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
                                        [    4.318501] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
                                        [    4.525625] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    4.536668] [XRADIO] Detect SDIO card 1
                                        [    4.548083] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                                        [    4.568162] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    4.592983] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    4.607479] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    4.620662] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
                                        [    4.639317] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                                        [    4.650813] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                                        [    4.662551] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
                                        [    4.675046] mmc1: new high speed SDIO card at address 0001
                                        [    6.608058] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
                                        [    6.715281] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                                        [    6.722016] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                                        [    6.728735] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                                        [    6.728739] [XRADIO] Remove SDIO card 1
                                        [    6.738744] [SBUS_ERR] sdio probe timeout!
                                        [    6.739730] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                                        [    6.744228] [XRADIO_ERR] sbus_sdio_init failed
                                        [    6.751082] mmc1: card 0001 removed
                                        [    6.756139] xradio_core_init failed (-110)!
                                        [    6.759874] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                                        [    6.776819] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    6.787954] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                                        [    6.808013] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    6.832974] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                                        [    6.840580] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                                        [    6.847389] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    6.861884] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    6.875569] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                                        [    6.883082] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                                        [    6.890039] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
                                        [    6.902620] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                                        [    6.910138] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                                        [    6.916857] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                                        [    6.926818] ======== XRADIO WIFI OPEN ========
                                        [    6.933414] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
                                        [    6.940165] [XRADIO] Allocated hw_priv @ 2a227f9d
                                        [    6.945956] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
                                        [    6.962221] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
                                        [    7.169360] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    7.180409] [XRADIO] Detect SDIO card 1
                                        [    7.188083] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                                        [    7.208161] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    7.232986] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    7.247475] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    7.260664] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
                                        [    7.279327] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                                        [    7.290825] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                                        [    7.302560] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
                                        [    7.315038] mmc1: new high speed SDIO card at address 0001
                                        [    9.248083] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
                                        [    9.355285] [XRADIO] Remove SDIO card 1
                                        [    9.355296] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                                        [    9.366259] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                                        [    9.369562] [SBUS_ERR] sdio probe timeout!
                                        [    9.377503] [XRADIO_ERR] sbus_sdio_init failed
                                        [    9.377514] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                                        [    9.389156] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                                        [    9.396037] xradio_core_init failed (-110)!
                                        [    9.396043] mmc1: card 0001 removed
                                        [    9.396147] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                                        [    9.416999] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    9.428112] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                                        [    9.448006] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    9.472949] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                                        [    9.480551] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                                        [    9.487351] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    9.501880] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                        [    9.515556] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                                        [    9.523061] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                                        [    9.530566] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                                        [    9.538073] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                                        [    9.544773] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                                        insmod: can't insert '/lib/modules/5.4.61/xr829.ko': Operation timed out
                                        ------run rc.final file-----
                                          : values=on
                                        ------light up RGB LED-----
                                        [    9.968702] file system registered
                                        [    9.986018] configfs-gadget 4100000.udc-controller: failed to start g1: -19
                                        [   10.008322] read descriptors
                                        [   10.011544] read strings
                                        [   10.251059] android_work: sent uevent USB_STATE=CONNECTED
                                        [   10.556293] configfs-gadget gadget: high-speed config #1: c
                                        [   10.562568] android_work: sent uevent USB_STATE=CONFIGURED
                                        ------light up LED-----
                                        ------run profile file-----
                                        Wed Jun  1 00:00:00 GMT 2022
                                        nodev   debugfs
                                        root@TinaLinux:/# df -sh
                                        df: unrecognized option: s
                                        root@TinaLinux:/# df -h
                                        /dev/root                 5.5M      5.5M         0 100% /rom
                                        devtmpfs                 57.5M         0     57.5M   0% /dev
                                        tmpfs                    58.0M         0     58.0M   0% /tmp
                                        /dev/by-name/rootfs_data
        1.4M     28.0K      1.2M   2% /overlay
                                        overlayfs:/overlay        1.4M     28.0K      1.2M   2% /
                                        tmpfs                    58.0M         0     58.0M   0% /run
                                        /dev/ubi0_8              36.3M     24.0K     34.4M   0% /mnt/UDISK
                                        root@TinaLinux:/# [   33.808021] usb1-vbus: disabling
                                          @yuzukitsuru 原因找到了,不小心把电源域配置关掉了,打开就能正常启动了,CONFIG_REGULATOR和CONFIG_REGULATOR_FIXED_VOLTAGE
                                          • ftwtwzy
                                            ftwtwzy LV 6 最后由 编辑
                                            生成的镜像是可以刷到TF卡吗?
                                            我这边报这个错误
                                            [19]HELLO! BOOT0 is starting!
                                            [22]BOOT0 commit : 88480af-dirty
                                            [25]set pll start
                                            [27]fix vccio detect value:0xc0
                                            [34]periph0 has been enabled
                                            [37]set pll end
                                            [39][pmu]: bus read error
                                            [41]board init ok
                                            [43]ZQ value = 0x2f
                                            [45]get_pmu_exist() = -1
                                            [47]ddr_efuse_type: 0xa
                                            [50]trefi:7.8ms
                                            [52][AUTO DEBUG] single rank and full DQ!
                                            [56]ddr_efuse_type: 0xa
                                            [58]trefi:7.8ms
                                            [61][AUTO DEBUG] rank 0 row = 13
                                            [64][AUTO DEBUG] rank 0 bank = 8
                                            [67][AUTO DEBUG] rank 0 page size = 2 KB
                                            [71]DRAM BOOT DRIVE INFO: V0.33
                                            [74]DRAM CLK = 936 MHz
                                            [76]DRAM Type = 3 (2:DDR2,3:DDR3)
                                            [79]DRAMC read ODT  off.
                                            [81]DRAM ODT value: 0x42.
                                            [84]ddr_efuse_type: 0xa
                                            [87]DRAM SIZE =128 M
                                            [89]dram_tpr4:0x0
                                            [91]PLL_DDR_CTRL_REG:0xf8004d00
                                            [94]DRAM_CLK_REG:0xc0000000
                                            [96][TIMING DEBUG] MR2= 0x20
                                            [104]DRAM simple test OK.
                                            [106]rtc standby flag is 0x0, super standby flag is 0x0
                                            [112]dram size =128
                                            [114]card no is 0
                                            [116]sdcard 0 line count 4
                                            [118][mmc]: mmc driver ver 2021-05-21 14:47
                                            [128][mmc]: Wrong media type 0x0
                                            [131][mmc]: ***Try SD card 0***
                                            [140][mmc]: HSSDR52/SDR25 4 bit
                                            [143][mmc]: 50000000 Hz
                                            [145][mmc]: 29818 MB
                                            [147][mmc]: ***SD/MMC 0 init OK!!!***
                                            [219]Loading boot-pkg Succeed(index=0).
                                            [223]Entry_name        = u-boot
                                            [229]Entry_name        = optee
                                            [233]Entry_name        = dtb
                                            [236]mmc not para
                                            [237]Jump to second Boot.
                                            U-Boot 2018.05-g24521d6-dirty (Sep 07 2022 - 16:07:39 +0800) Allwinner Technology
                                            [00.289]CPU:   Allwinner Family
                                            [00.292]Model: sun8iw20
                                            ready
                                            [00.314]optee version: major:3 minor:7
                                            [00.317]DRAM:  128 MiB
                                            [00.320]Relocation Offset is: 04f01000
                                            [00.340]secure enable bit: 0
                                            [00.342]smc_tee_inform_fdt failed with: -65526[00.347]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
                                            [00.353]gic: sec monitor mode
                                            [00.356]flash init start
                                            [00.358]workmode = 17,storage type = 1
                                            try card 2
                                            set card number 2
                                            get card number 2
                                            [00.366][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
                                            [00.372][mmc]: Is not Boot mode!
                                            [00.375][mmc]: SUNXI SDMMC Controller Version:0x50310
                                            [00.386][mmc]: ************Try SD card 2************
                                            [00.392][mmc]: mmc 2 cmd timeout 100 status 100
                                            [00.396][mmc]: smc 2 err, cmd 8,  RTO
                                            [00.399][mmc]: mmc 2 close bus gating and reset
                                            [00.404][mmc]: mmc 2 cmd timeout 100 status 100
                                            [00.408][mmc]: smc 2 err, cmd 55,  RTO
                                            [00.412][mmc]: mmc 2 close bus gating and reset
                                            [00.416][mmc]: ************Try MMC card 2************
                                            [00.425][mmc]: mmc 2 cmd timeout 100 status 100
                                            [00.429][mmc]: smc 2 err, cmd 1,  RTO
                                            [00.432][mmc]: mmc 2 close bus gating and reset
                                            [00.437][mmc]: Card did not respond to voltage select!
                                            [00.441][mmc]: ************SD/MMC 2 init error!************
                                            [00.447][mmc]: mmc init product failed
                                            MMC init failed
                                            try emmc fail
                                            [00.453]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
                                            [00.459]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
                                            [00.467]sunxi-spinand-phy: request spi0 gpio ok
                                            [00.471]sunxi-spinand-phy: request general tx dma channel ok!
                                            [00.476]sunxi-spinand-phy: request general rx dma channel ok!
                                            [00.482]sunxi-spinand-phy: set spic0 clk to 20 Mhz
                                            [00.486]sunxi-spinand-phy: init spic0 clk ok
                                            [00.553]sunxi-spinand-phy: read id failed : -110
                                            try nand fail
                                            initcall sequence 47f90548 failed at call 4300d5a1 (err=-1)
                                              柚木 鉉 LV 9 @ftwtwzy 最后由 YuzukiTsuru 编辑
                                              @ftwtwzy 在 一个补丁,让D1-H的SDK支持T113芯片 中说:
                                              刷到TF卡吗?
                                              刷到TF卡请参考: 因为喜欢用ADB,因为不喜欢插拔TF卡,所以D1直接用PhoenixSuit烧录TF(SDNAND): https://bbs.aw-ol.com/topic/1002/share/1
                                              要改一个数字
                                              ftwtwzy 1 条回复 最后回复 回复 引用 分享 2
                                              • ftwtwzy
                                                ftwtwzy LV 6 @YuzukiTsuru 最后由 编辑
                                                @yuzukitsuru 在 一个补丁,让D1-H的SDK支持T113芯片 中说:
                                                刷到TF卡吗?
                                                要改一个数字
                                                这个暂时先保留,不玩这么花,先看看启动的问题
                                                  captain LV 5 @wxid_disxysjskla 最后由 编辑
                                                  @wxid_disxysjskla
                                                  下载到TF卡之后,发现文件系统是只读的,重新挂载之后也不行。
                                                  root@TinaLinux:/# mount -o remount -w
                                                  /dev/root on / type squashfs (ro,relatime)
                                                  devtmpfs on /dev type devtmpfs (rw,relatime,size=54304k,nr_inodes=13576,mode=755)
                                                  /proc on /proc type proc (rw,relatime)
                                                  tmpfs on /tmp type tmpfs (rw,relatime)
                                                  sys on /sys type sysfs (rw,relatime)
                                                  devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620,ptmxmode=000)
                                                  none on /sys/kernel/debug type debugfs (rw,relatime)
                                                  root@TinaLinux:/# mkdir t113
                                                  mkdir: can't create directory 't113': Read-only file system
                                                    柚木 鉉 LV 9 @captain 最后由 编辑
                                                    @captain TF卡要自己配置overlayfs
                                                      captain LV 5 最后由 编辑
                                                      参看Tina Linux 存储介质切换:eMMC,SPI NAND,SPI NOR,SD Card,SD NAND 里面的spinor切换emmc 小节进行修改之后,现在系统是可读写的了。
                                                      L 1 条回复 最后回复 回复 引用 分享 1
                                                      • Referenced by  W wxid_disxysjskla
                                                      • Referenced by  C captain
                                                      • DAIZEBIN
                                                        DAIZEBIN LV 7 @kang2638729651 最后由 编辑
                                                        @kang2638729651 这个是自己在MQ-R上面加焊的spinand?
                                                          chzfmx LV 4 最后由 编辑
                                                          最新的Tina Linux是已经支持T113了,不需要再打这个补丁了吧???
                                                          https://github.com/mangopi-sbc/Tina-Linux
                                                          WhycanService 1 条回复 最后回复 回复 引用 分享 2
                                                            WhycanService LV 8 @chzfmx 最后由 WhycanService 编辑
                                                            @chzfmx 这个是芒果派发布的SDK,不是官方发布的,这里的补丁是适配官方SDK的
                                                            C 1 条回复 最后回复 回复 引用 分享 2
                                                              chzfmx LV 4 @WhycanService 最后由 编辑
                                                              @whycanservice 好的,了解了
                                                              D 1 条回复 最后回复 回复 引用 分享 1
        jr_online LV 7 @wxid_disxysjskla 最后由 编辑
        @wxid_disxysjskla 在 一个补丁,让D1-H的SDK支持T113芯片 中说:
        补丁的地址:https://github.com/YuzukiHD/TinaAddons
        1. 在全新下载好的 Tina Linux SDK 的根目录内下拉仓库(一定要全新的SDK)
        git clone https://github.com/YuzukiHD/TinaAddons.git
        2. 导出补丁文件
        cp -rf TinaAddons/* .
        3. 打上补丁
        chmod 777 apply_patch.sh
        ./apply_patch.sh
        4. 完工,开始编译
        大佬,我打上你的补丁之后,mboot、make编译报错是咋回事呢?
        Q 1 条回复 最后回复 回复 引用 分享 1
        • Q
        qqqlb LV 7 @jr_online 最后由 编辑
        @jr_online 安装bison
        J 1 条回复 最后回复 回复 引用 分享 1
        jr_online LV 7 @qinlinbin 最后由 编辑
        @qinlinbin 在 一个补丁,让D1-H的SDK支持T113芯片 中说:
        @jr_online 安装bison
        好滴,谢谢大佬,我试试。
        dhgao38 LV 2 @chzfmx 最后由 编辑
        @chzfmx 在 一个补丁,让D1-H的SDK支持T113芯片 中说:
        这个补丁是支持官方那个版本的sdk,V2.0还是V2.1?
        DAIZEBIN 1 条回复 最后回复 回复 引用 分享 1
        • DAIZEBIN
        DAIZEBIN LV 7 @dhgao38 最后由 编辑
        @dhgao38 实测两个都可以,建议使用最新的V2.1吧,修复了部分bug
        jnny_cn LV 2 最后由 编辑
        感谢分享。。。。。
        • F
        fameL LV 2 最后由 编辑
        请问一下这几个包没加载到会有问题吗?虽然最后提示成功了
        • F
        fameL LV 2 最后由 编辑
        打补丁就有这样的错误
        编译的是由也会报错
        czlz_fun 1 条回复 最后回复 回复 引用 分享 2
        lhb882 LV 2 @captain 最后由 编辑
        @captain 你好能分享一下t113的官方sdk吗
        • czlz_fun
        粗制乱造 LV 3 @fameL 最后由 编辑
        @famel 我跟你的问题一样,估计是补丁没更新。但是D1-H的代码已经更新了
        wmwangzi1 LV 3 最后由 编辑
        下载不下来啊?这是怎么回事 大神求指教
        版主大人,这个仓库是一个私有仓库吗?我是不是用我的git账号无法访问?
        S 1 条回复 最后回复 回复 引用 分享 0
        znstj LV 2 最后由 编辑
        支持T113-I的RISC-V核跑linux吗?
        并且补丁git失效了
        skyshine LV 6 @wmwangzi1 最后由 编辑
        @wmwangzi1 估计是不开放了,github上很多tinalinux的仓库也没了
        W 1 条回复 最后回复 回复 引用 分享 0
        wmwangzi1 LV 3 @skyshine 最后由 编辑
        @skyshine 你那可有给我分享一个
        @wmwangzi1 有芒果派的sdk,想要官方的sdk估计只能找代理
        tinaq LV 2 @wxid_disxysjskla 最后由 编辑
        @wxid_disxysjskla github连接没有了咋办
        • Referenced by  S skiinder
        madrat LV 2 最后由 编辑
        链接失效了啊,有备份吗?
        zyy386 LV 2 最后由 编辑
        谢谢分享!!!!!!!!!
        lin2012 LV 2 @wxid_disxysjskla 最后由 编辑
        @wxid_disxysjskla 仓库404啦
        zhaoqiankun_quanzhi LV 2 @whycan 最后由 编辑
        @whycan patch可否分享下
